File:Nylon1 elements of smps assembly v1p00.stl
Revision as of 18:10, 8 February 2014 by Rapatan (talk | contribs) (Rapatan uploaded a new version of "File:Nylon1 elements of smps assembly v1p00.stl")
Nylon1_elements_of_smps_assembly_v1p00.stl(file size: 175 KB, MIME type: application/acad)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
Nylon1_elements_of_smps_assembly_v1p00.stl 1 of 3 nylon insulator elements of MetalicaRap 63KV power supply
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current18:10, 8 February 2014 (175 KB)Rapatan (talk | contribs)
06:56, 5 February 2014 (106 KB)Rapatan (talk | contribs)Nylon1_elements_of_smps_assembly_v1p00.stl 1 of 3 nylon insulator elements of MetalicaRap 63KV power supply
  • You cannot overwrite this file.
The following file is a duplicate of this file (more details):
The following page links to this file:
