File:Rroofl extruder clearance issues.jpg
Revision as of 00:08, 8 September 2012 by Vikolliver (talk | contribs) (Image showing the extruder gear nearly colliding with the trapezoidal hole on the upper left. That whole side needs to be moved over, and the top M8 rod closest to it removed. If we then move the remaining rod further away, we should be able to let quite )
Size of this preview: 800 × 600 pixels. Other resolutions: 320 × 240 pixels | 2,048 × 1,536 pixels.
Original file (2,048 × 1,536 pixels, file size: 1.37 MB, MIME type: image/jpeg)
Image showing the extruder gear nearly colliding with the trapezoidal hole on the upper left. That whole side needs to be moved over, and the top M8 rod closest to it removed. If we then move the remaining rod further away, we should be able to let quite a large extruder rise up into the gap.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 00:08, 8 September 2012 | 2,048 × 1,536 (1.37 MB) | Vikolliver (talk | contribs) | Image showing the extruder gear nearly colliding with the trapezoidal hole on the upper left. That whole side needs to be moved over, and the top M8 rod closest to it removed. If we then move the remaining rod further away, we should be able to let quite |
- You cannot overwrite this file.
File usage
There are no pages that link to this file.
