Revision as of 12:20, 10 October 2014 by Jcollasius (talk | contribs) (For ATX power supply (controlled with RUMBA) Set the power jumper in "stand alone" position Connect GND from your ATX power supply to USB header Pin1 (where the arrow is) Connect 5 VSB from your ATX power supply (+5 VDC Standby Voltage) to USB header...)
Original file(1,024 × 579 pixels, file size: 127 KB, MIME type: image/jpeg)
Set the power jumper in "stand alone" position Connect GND from your ATX power supply to USB header Pin1 (where the arrow is) Connect 5 VSB from your ATX power supply (+5 VDC Standby Voltage) to USB header Pin4 Connect GND and PS ON (Power Supply On) from your ATX power supply to PS ON header, polarity doesn't matter
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current12:20, 10 October 2014Thumbnail for version as of 12:20, 10 October 20141,024 × 579 (127 KB)Jcollasius (talk | contribs)For ATX power supply (controlled with RUMBA) Set the power jumper in "stand alone" position Connect GND from your ATX power supply to USB header Pin1 (where the arrow is) Connect 5 VSB from your ATX power supply (+5 VDC Standby Voltage) to USB header...
  • You cannot overwrite this file.
The following 2 pages link to this file:
Metadata
