File:SDSL reset.jpg
Revision as of 10:05, 6 January 2012 by Skyfanatic (talk | contribs) (SDSL card mounted on a Sanguinololu board. Highlighted is the jumper that needs to be open in order for the Sanguinololu not to reset when the USB is disconnected. The ATMEGA chip is removed in this picture inoder to clearly show the reset jumper.)
Size of this preview: 800 × 453 pixels. Other resolutions: 320 × 181 pixels | 1,098 × 622 pixels.
Original file (1,098 × 622 pixels, file size: 215 KB, MIME type: image/jpeg)
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 10:05, 6 January 2012 | 1,098 × 622 (215 KB) | Skyfanatic (talk | contribs) | SDSL card mounted on a Sanguinololu board. Highlighted is the jumper that needs to be open in order for the Sanguinololu not to reset when the USB is disconnected. The ATMEGA chip is removed in this picture inoder to clearly show the reset jumper. |
- You cannot overwrite this file.
File usage
The following page links to this file:
