File:Sample 2 5mm wall.JPG
Revision as of 07:05, 8 July 2014 by AlbertDesigns (talk | contribs) (In this picture you can see the width of the infill. Because the wall is printed in one go, the resulting object is much stronger and stiffer than it would be if the wall was made by 5 times 0.5mm.)
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 07:05, 8 July 2014 | 374 × 250 (25 KB) | AlbertDesigns (talk | contribs) | In this picture you can see the width of the infill. Because the wall is printed in one go, the resulting object is much stronger and stiffer than it would be if the wall was made by 5 times 0.5mm. |
- You cannot overwrite this file.
File usage
The following page links to this file:
