File:SpoolHead WIP 02.PNG
Revision as of 04:16, 3 February 2010 by Jbayless (talk | contribs) (Illustration of proposed wire-cutting method. Z bed is lowered (Darwin model); wire is placed under slight tension and cut with solenoid lever cutter. Spring (not illustrated) returns cutter to elevated position to avoid interfering with normal printing p)
Original file(1,180 × 886 pixels, file size: 130 KB, MIME type: image/png)
Illustration of proposed wire-cutting method. Z bed is lowered (Darwin model); wire is placed under slight tension and cut with solenoid lever cutter. Spring (not illustrated) returns cutter to elevated position to avoid interfering with normal printing process.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current04:16, 3 February 2010Thumbnail for version as of 04:16, 3 February 20101,180 × 886 (130 KB)Jbayless (talk | contribs)Illustration of proposed wire-cutting method. Z bed is lowered (Darwin model); wire is placed under slight tension and cut with solenoid lever cutter. Spring (not illustrated) returns cutter to elevated position to avoid interfering with normal printing p
  • You cannot overwrite this file.
The following page links to this file:
