File:Spool support vertical axis.jpg
Revision as of 12:24, 17 August 2016 by PRZ (talk | contribs) (clarifs)
Original file(3,443 × 2,172 pixels, file size: 529 KB, MIME type: image/jpeg)
A spool support with vertical axis for space constrained installation. Use adaptation rings for different diameters All parts are printed, no bearing (a vertical axis spool support need to be braked). see https://github.com/PRouzeau/3D-printer-spool-on-top
Own work licence GFDL1.2 and CC BY-SA 3.0
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current12:23, 17 August 2016Thumbnail for version as of 12:23, 17 August 20163,443 × 2,172 (529 KB)PRZ (talk | contribs)A spool support with vertical axis for space constrained installation. Use adaptation rings for different diameters All printed part. see https://github.com/PRouzeau/3D-printer-spool-on-top Own work licence GFDL1.2 and CC BY-SA 3.0
  • You cannot overwrite this file.
The following page links to this file:
Metadata
