Revision as of 06:20, 28 May 2018 by Hobsie (talk | contribs) (Hobsie uploaded a new version of File:SteelCoreBeltFibreSnapped.jpg)
Size of this preview: 600 × 600 pixels. Other resolutions: 240 × 240 pixels | 1,536 × 1,536 pixels.
Original file (1,536 × 1,536 pixels, file size: 439 KB, MIME type: image/jpeg)
Image of a Steel Core Polyurethane belt used with a 16 tooth pulley. The metal fibres have snapped were the belt engages with the pulley due to small diameter of the pulley creating a tight bend in the belt. The failure presented itself as an elongated print in the problem axis.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 06:20, 28 May 2018 | 1,536 × 1,536 (439 KB) | Hobsie (talk | contribs) | ||
05:54, 28 May 2018 | 1,536 × 2,048 (620 KB) | Hobsie (talk | contribs) | Image of a Steel Core Polyurethane belt used with a 16 tooth pulley. The metal fibres have snapped were the belt engages with the pulley due to small diameter of the pulley creating a tight bend in the belt. The failure presented itself as an elongated... |
- You cannot overwrite this file.
File usage
The following page links to this file:
