Revision as of 01:31, 1 May 2012 by Darkpaw (talk | contribs) (Position data from the "camrap" software. The camera wasn't moved during this run, so this data is a result of: camera noise, lighting changes, vibration and other errors. The values are in 4mm = 1 unit. The data points are 10 frame averages, so the x ax)
Size of this preview: 796 × 600 pixels. Other resolutions: 319 × 240 pixels | 812 × 612 pixels.
Original file (812 × 612 pixels, file size: 28 KB, MIME type: image/png)
The data points are 10 frame averages, so the x axis units are frames x 10.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 01:31, 1 May 2012 | 812 × 612 (28 KB) | Darkpaw (talk | contribs) | Position data from the "camrap" software. The camera wasn't moved during this run, so this data is a result of: camera noise, lighting changes, vibration and other errors. The values are in 4mm = 1 unit. The data points are 10 frame averages, so the x a |
- You cannot overwrite this file.
File usage
The following page links to this file:
