File:Think3DPrint3D DUET Arduino DUE Compatible 3DPrinter Controller.jpg
Revision as of 17:14, 15 January 2014 by T3P3 (talk | contribs) (The Duet is a next generation electronics board to control a 3D printer or other stepper motor driven robot. Based on the SAM3X8E, ARM 32 bit processor that also powers the Arduino Due it has much more capability than 8 bit based 3D printer controllers...)
The Duet is a next generation electronics board to control a 3D printer or other stepper motor driven robot. Based on the SAM3X8E, ARM 32 bit processor that also powers the Arduino Due it has much more capability than 8 bit based 3D printer controllers. It comes with Ethernet built in allowing it to run as a network printer controller, along with USB and an SD card. In addition it takes an expansion board with a further 4 stepper channels - for a total of 8 axis controls (3 axis + 5 extruders for example).
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 17:14, 15 January 2014 | 640 × 505 (137 KB) | T3P3 (talk | contribs) | The Duet is a next generation electronics board to control a 3D printer or other stepper motor driven robot. Based on the SAM3X8E, ARM 32 bit processor that also powers the Arduino Due it has much more capability than 8 bit based 3D printer controllers... |
- You cannot overwrite this file.
File usage
The following page links to this file:
