File:Wallace M8 X carriage 2.jpg
Revision as of 16:20, 27 June 2012 by Bushing (talk | contribs) (uploaded a new version of "File:Wallace M8 X carriage 2.jpg")
X-Carriage with 3rd installed bearing
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 16:20, 27 June 2012 | 142 × 149 (24 KB) | Bushing (talk | contribs) | ||
16:14, 27 June 2012 | 478 × 512 (23 KB) | Bushing (talk | contribs) | |||
16:07, 27 June 2012 | 1,707 × 1,941 (1.13 MB) | Bushing (talk | contribs) | X-Carriage with 3rd installed bearing |
- You cannot overwrite this file.
File usage
The following page links to this file:
Metadata
This file contains additional information, probably added from the digital camera or scanner used to create or digitize it.
If the file has been modified from its original state, some details may not fully reflect the modified file.
Camera manufacturer | Apple |
Camera model | iPhone 4S |
Exposure time | 1/20 sec (0.05) |
F Number | f/2.4 |
ISO speed rating | 200 |
Date and time of data generation | 22:38, 26 June 2012 |
Lens focal length | 4.28 mm |
Latitude | 37° 15′ 6.6″ N |
Longitude | 121° 48′ 46.8″ W |
Altitude | 49 meters above sea level |
Orientation | Normal |
Horizontal resolution | 72 dpi |
Vertical resolution | 72 dpi |
Software used | QuickTime 7.7.1 |
File change date and time | 13:11, 27 June 2012 |
Y and C positioning | Centered |
Exposure Program | Normal program |
Exif version | 2.2 |
Date and time of digitizing | 22:38, 26 June 2012 |
Meaning of each component |
APEX shutter speed | 4.3219284603421 |
APEX aperture | 2.5260688216893 |
APEX brightness | 1.724999538311 |
Metering mode | Pattern |
Flash | Flash did not fire, auto mode |
User comments | {
AddDebugInfoToUserComments = 1; Orientation = 6; "{Diagnostic}" = { AEAdjustedMinWeight = 0; AEAverage = 257; AECenterMean = 0; AELimitsReached = 0; AELocked = 0; AEOverallAverageLuma = 0; AEPatternMean = 0; AEPatternScene = 0; AEStable = 1; AETarget = 259; AFLocked = 0; AFStable = 1; AFStatus = 4; AFWindowEdgeSumArray = <af040000 22020000 db010000 a9040000 da0a0000 4e050000 7b040000 cd0a0000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000>; AGC = 1170; AWBBGain = 9762; AWBGGain = 4096; AWBLocked = 0; AWBRGain = 7560; AWBStable = 1; AccelerometerDeltas = "(0.0025 0.0049) @ 0.0200"; AdaptedFilterStrength = 0; AdaptiveLuxValue = 131; AddDebugInfoToUserComments = 1; ApertureValue = 3; AverageFocusScore = 154222; BinningGainFactor = 256; BinningMode = 0; BrightnessValue = "1.724999538335737"; Build = "6.0 (10A339)"; CCT = 3734; CameraDriverName = AppleH4CameraInterface; ConfigMode = 0; ConversionGain = 10878; CurrentFocusPosition = 115; CurrentFrameRate = 19; DRCLocked = 0; DetectedFacesArray = ( ); DnPerLuxSec = 309985; DynamicToneCurveLocked = 0; ExposureBias = 0; ExposureTime = "0.05"; FDExposureDebug = "face avg:0 wgt:0 scene xl:9 xm:61 xh:68 target:259 scale:1622 (0.7EV) aeBlend:0 aeAverage:257 aeTarget:259 darkOut:3 brightOut:24"; FlashCaptureSequence = 0; Fnumber = "2.4"; FocalLenIn35mmFilm = 35; FocalLength = "4.28"; FocusBand = "15.04 in [11.94, 22.88]"; FocusPeakSumArray = ( 154429, 147343, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ); FocusScan = "(31,6.75) (54,7.60) (75,9.63) (95,12.56) (115,15.91) (133,15.42) (151,10.58) 2.4s ago 0.41s duration"; FocusScanArray = ( ( 31, 6752714 ), ( 54, 7596877 ), ( 75, 9632814 ), ( 95, 12561341 ), ( 115, 15914499 ), ( 133, 15415078 ), ( 151, 10579477 ) ); FocusScanID = "#12 Blocked since last scan: 0"; FocusScoresArray = ( 154429, 147343, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ); FocusWindow = ( 365, 320, 270, 360 ); FullyExposed = 0; GlobalMotion = 0; GlobalMotionHistory = 0; GlobalShutterFlag = 0; ISOBase = 46; ISOSpeedRating = 225; LowLightBinnedModeActive = 0; LowerLimitGM = 0; LumaLUTUpdated = 0; LuxLevel = 291; MeteringMode = 5; MotionHistoryB = 0; MotionHistoryGb = 0; MotionHistoryGr = 0; MotionHistoryR = 0; MotionLUTUpdated = 0; MotionSumB = 0; MotionSumGb = 0; MotionSumGr = 0; MotionSumR = 0; NormalizedSNR = "24.6739298551166"; OneFrameAEMode = 1; OverflowOccurred = 0; PowerBlur = 1; PreBracketingFrame = 0; PreviousFocusBand = "6.08 in [0.00, 0.00]"; PreviousFocusScan = "(31,7.01) (54,6.76) (75,9.17) (95,10.89) (115,10.76) (133,12.08) (151,8.79) (168,6.29) 12.2s ago 0.51s duration"; PreviousGlobalMotionAdjusted = 0; RawCropRect = { Height = 2448; Width = 3264; X = 0; Y = 0; }; RawSensorHeight = 2448; RawSensorWidth = 3264; "ReadNoise_1x" = 327680; "ReadNoise_8x" = 150732; RelativeEntropy = 0; RollingShutterSkew = 44064; SNR = "24.6739298551166"; SensorID = 325; SensorTemperature = 48; ShutterSpeedValue = "4.321928094887363"; TemporalNoiseReductionActive = 0; TimeMachine = 1; TimeMachineSelection = 3; ToneCurveDebug = <00000700 00003b01 eb009a00 00000000 33008000 04010000>; UpperLimitGM = 0; WYSIWYG = 1; WaitForAF = 1; WaitForAFSkipCount = 0; WellCapacity = 6170; ispDGain = 274; sensorDGain = 256; }; "{Exif}" = { ApertureValue = "2.526068811667588"; BrightnessValue = "1.724999538335737"; ColorSpace = 1; DateTimeDigitized = "2012:06:26 22:38:39"; DateTimeOriginal = "2012:06:26 22:38:39"; ExposureMode = 0; ExposureProgram = 2; ExposureTime = "0.05"; FNumber = "2.4"; Flash = 24; FocalLenIn35mmFilm = 35; FocalLength = "4.28"; ISOSpeedRatings = ( 200 ); MeteringMode = 5; PixelXDimension = 3264; PixelYDimension = 2448; SceneType = 1; SensingMethod = 2; ShutterSpeedValue = "4.321928094887363"; SubjectArea = ( 1631, 1223, 881, 881 ); WhiteBalance = 0; }; "{TIFF}" = { DateTime = "2012:06:26 22:38:39"; Make = Apple; Model = "iPhone 4S"; Software = "6.0"; XResolution = 72; YResolution = 72; };} |
Supported Flashpix version | 0,100 |
Color space | sRGB |
Sensing method | One-chip color area sensor |
Exposure mode | Auto exposure |
White balance | Auto white balance |
Focal length in 35 mm film | 35 mm |
Scene capture type | Standard |
GPS time (atomic clock) | 05:38 |
Reference for direction of image | True direction |
Direction of image | 106.23692307692 |
JPEG file comment | AppleMark |
