Revision as of 01:40, 11 April 2010 by MattMoses (talk | contribs) (First attempt. This is just a single-tube needle with a heater and thermistor. The air tube is stuck in place with caulk. The lid, heater, ports, etc are held in place with JB-weld. This design did not work at all because there was not sufficient heat)
Size of this preview: 800 × 600 pixels. Other resolutions: 320 × 240 pixels | 1,024 × 768 pixels.
Original file (1,024 × 768 pixels, file size: 78 KB, MIME type: image/jpeg)
First attempt. This is just a single-tube needle with a heater and thermistor. The air tube is stuck in place with caulk. The lid, heater, ports, etc are held in place with JB-weld. This design did not work at all because there was not sufficient heat transfer through the needle to melt wax at the end. The case is a polyurethane casting and the lid is transparent plastic (approx 1/8 inch thick). Tube diameter approx 1/16 inch.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 01:40, 11 April 2010 | 1,024 × 768 (78 KB) | MattMoses (talk | contribs) | First attempt. This is just a single-tube needle with a heater and thermistor. The air tube is stuck in place with caulk. The lid, heater, ports, etc are held in place with JB-weld. This design did not work at all because there was not sufficient heat |
- You cannot overwrite this file.
File usage
The following page links to this file:
