Revision as of 01:42, 11 April 2010 by MattMoses (talk | contribs) (Second attempt. Vent and drain tubes run in parallel, with a sort of notch at the tip to allow molten wax to be replaced with air from the vent, then moved up the drain tube into the case. Push-to-connect fitting (visible behind case) is used to connect)
Size of this preview: 800 × 600 pixels. Other resolutions: 320 × 240 pixels | 1,024 × 768 pixels.
Original file (1,024 × 768 pixels, file size: 90 KB, MIME type: image/jpeg)
Second attempt. Vent and drain tubes run in parallel, with a sort of notch at the tip to allow molten wax to be replaced with air from the vent, then moved up the drain tube into the case. Push-to-connect fitting (visible behind case) is used to connect to vacuum pump. Thermistor board is visible on side. Lid is missing due to blowout (see “Construction”). This version worked somewhat, but the broad tooltip did not make very good cuts in the wax.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 01:42, 11 April 2010 | 1,024 × 768 (90 KB) | MattMoses (talk | contribs) | Second attempt. Vent and drain tubes run in parallel, with a sort of notch at the tip to allow molten wax to be replaced with air from the vent, then moved up the drain tube into the case. Push-to-connect fitting (visible behind case) is used to connect |
- You cannot overwrite this file.
File usage
The following page links to this file:
