File:XXXXYYZ Bateson 24 Motors 44 Blocks 18 Struts Req v1.png
Revision as of 11:45, 6 February 2018 by DGoncz (talk | contribs) (XXXX, four redundant mounting point moving X axis, 2 for table, 2 for head; YY, two parallel rails for each bed and table allowing fitting mounting points to diagonal mountings of metric or inch rectangular grids, Z lowering head to bed actively, not j...)
Size of this preview: 600 × 600 pixels. Other resolutions: 240 × 240 pixels | 640 × 640 pixels.
Original file (640 × 640 pixels, file size: 224 KB, MIME type: image/png)
XXXX, four redundant mounting point moving X axis, 2 for table, 2 for head; YY, two parallel rails for each bed and table allowing fitting mounting points to diagonal mountings of metric or inch rectangular grids, Z lowering head to bed actively, not just by weight, using all 24 motor mounting points on a cube, allowing head and bed counter motion on X axis to fabricate slots in full length struts by milling, and possibly even grow.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 11:45, 6 February 2018 | 640 × 640 (224 KB) | DGoncz (talk | contribs) | XXXX, four redundant mounting point moving X axis, 2 for table, 2 for head; YY, two parallel rails for each bed and table allowing fitting mounting points to diagonal mountings of metric or inch rectangular grids, Z lowering head to bed actively, not j... |
- You cannot overwrite this file.
File usage
The following page links to this file:
