File Formats
This page provides a list of the various file types that are used in the reprap software toolchain. You may also want to take a look at Useful Software Packages.
AOI
AOI filenames end with .aoi
AOI files are the native file format for Art of Illusion. AoI was never intended to be used as CAD software but you will find a lot of reprap files in this format because AoI is an open source app and is easy to use. In the long run though this app is probably a dead end for designing parts.
COLLADA
GCODE
GCODE filenames normally end with .gcode
These are ascii files that have a list of G-codes. G-codes are the instructions the arduino firmware reads for moving the stepper motors and extruder head.
IGES
IGES filenames normally end with .igs
This is an older open-format CAD file. It has since been superceded by STEP files as of 1995 or so More detail on IGES files can be found in Wikipedia
INO
INO files are for the arduino IDE as of ver 1.0. They used to be PDE files but I guess they changed the file extension because PDE was for the Processing programming language.
PDE
PDE filenames end with .pde
Processing Development Environment files are used by the arduino IDE. Processing is basically just C++ with some extra libraries thrown on top.
PLY
- The PLY format is similar to STL in that it is a wireframe mesh representation of a 3D part
STL
STL filenames end with .stl, from "STereoLitography" - the format was actually developed for feeding 3D printers.
STL files are an open file standard and are widely used in Computer Aided Manufacturing (CAM) and rapid prototyping. The STL file format is good for printing out parts because it describes a part's surface geometry. Unfortunately, STL files are terrible for doing Computer Aided Design (CAD). They can be imported into CAD applications but are difficult to change. See the link to the article 'CAD vs CAM' in the discussion section below.
STEP
STEP filenames normally end with .stp, from "STandard for the Exchange of Product model data"
STEP files are basically the gold standard for translating between different CAD applications. People that do CAD for a living use STEP files because it is an ISO Standard
Discussions about File Formats
- A community specification for an improvement to STL files.
- A community specification for an open 3D file wrapper.
- ""CAD" files vs CAM files - a designer's plea". ... "STLs are to CAD models as a PDF full of photographs of words is to a text file. You can send them both to a printer just fine, but it's a big hassle to fix a typo." ... "the .scad files contain formulas that document what we in the SolidWorks community call "design intent"." ...
Here's some junk from the old 'file format' page
The community takes up the slack?
Yup. Check in the forum. I think we've got CAD drawings for Mendel molds somewhere, which will boost replication rate 30x? or so. Eventually a RepRap developer will manifest whose job it is to keep track of these things.
Really?
People love to argue about this. This is why we've got Library Administration, Announcements, and Policy, where we get very passionate about file formats, and other library matters, like "What goes up in the Library, anyway?" (Hint. Everything.)
Photographers say "The best camera is the one you've got." Likewise, the best file format is the one you upload, and the one you like to use. Telling other people with strong opinions that they should use your favorite file format is like telling other people they should like the kind of food you like. And it cuts into your time playing in the kitchen. Or rather, doing hardware development and printing things.
File Formats
Transcluded from File Formats:
AMF
AMF filenames end with .amf, from "Additive Manufacturing File Format" - the open format was developed from 2009 and onwards by Committee F42 on Additive Manufacturing Technologies. The syntax used is xml. The specification can be bought here: Specification for Data Exchange Format for Additive Manufacturing.
AOI
COLLADA
DXF and DWG
Files ending with ".dxf" (AutoCAD Drawing Interchange Format) or ".dwg" (AutoCAD DraWinG) are popular 2D CAD file formats. Apparently a surprisingly large number of people like drawing things in a 2D CAD system such as Inkscape or AutoCad, then exporting to DXF, then importing to SCAD to extrude the shape into 3D, and then printing the shape.
GCODE
These are ascii files that have a list of G-codes. G-codes are the instructions the electronics firmware reads for moving the stepper motors and extruder head.
IGES
INO
OBJ
Obj files are simple 3D models. Originally developed by Wavefront, it is now a common input format. Almost every 3D software can import/export in.
PDE
PLY
SCAD
Perhaps the most popular fully parametric file format for 3D printers ends with .scad. Typically people use OpenSCAD to generate STL files from the scad file.
STL
STEP
STEP files are basically the gold standard for translating between different CAD applications. People that do CAD for a living use STEP files because it is an ISO Standardlink iso registration
