Firmware/FiveD on Arduino
Rewrite of FiveD firmware for the atmega168-based Arduino by Triffid Hunter
This firmware is loosely based on the official FiveD Firmware, however it uses 100% integer math, and works very hard to minimize/eliminate long math operations in interrupt context.
- 1 Constant Acceleration
- 2 Transmission of Multiple Commands
- 3 Patches, Enhancements
- 3.1 Make sources buildable with the Arduino IDE.
- 3.2 Achieve C89 compatibility, Arduino IDE's default.
- 3.3 RepRap host software expects a lowercase "ok" for confirmation.
- 3.4 Moved REQUIRE_LINENUMBER and REQUIRE_CHECKSUM #defines to gcode.h as well.
- 3.5 An M-code stuck when receiving G commands and vice-versa.
- 3.6 If line numbers aren't required, don't bother about their actual value either.
- 3.7 Allow non-consecutive line numbers.
- 3.8 Count only line numbers with N seen.
- 3.9 Don't fail on unknown commands.
- 3.10 Make resend requests RepRap host compatible, too.
- 3.11 Add the option to not include the asterisk in checksum calculation.
- 3.12 Every character, plus *, starts a new field.
- 3.13 Achieve RepRap Host compatibility for temperature readouts as well.
- 3.14 Major overhaul of machine.h.
- 3.15 Eliminate serial_writechar_P()
- 3.16 dda.c: eliminated abs32() in favour of the ABS() macro.
- 3.17 Implement start/stop ramping.
The official FiveD firmware changes speed by a fixed amount each step, however this also alters the step time. acceleration = dv/dt, so with a fixed dv but a changing dt, acceleration changes during a move. This makes high speeds quite unattainable as the acceleration quickly outstrips the motor's ability to keep up.
FiveD on Arduino contains a constant acceleration implementation.
FiveD on Arduino has the capability to receive additional commands while working on the first one. This avoids short stops between commands and will allow for even more smooth transitions from one movement to the next in the future.
As Triffid Hunter is apparently out of town currently (2010-07-03), the Git Repository doesn't allow to upload patches and I don't want to do yet another fork, I'll upload patches here.
To apply those patches, type git apply
in your terminal, inside your local copy of git repo, then copy the text given her into the terminal and hit ctrl-d. Well, I hope it works that way.
If you work on FiveD on Arduino as well, please do commits in small pieces, one topic/bug at a time. This helps a lot in reviewing patches. That done, you can create a set of patches easily:
git format-patch --keep-subject -o out origin
You'll find each of your patches in the out/
directory, nicely equipped with a mail header and a proper file name.
--- mendel/mendel.pde | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-) create mode 100644 mendel/mendel.pde diff --git a/mendel/mendel.pde b/mendel/mendel.pde new file mode 100644 index 0000000..1c3f190 --- /dev/null +++ b/mendel/mendel.pde @@ -0,0 +1,4 @@ + +/* + The existence of this file makes sources buildable with the Arduino IDE. +*/ --
--- mendel/serial.c | 12 ++++++++---- 1 files changed, 8 insertions(+), 4 deletions(-) diff --git a/mendel/serial.c b/mendel/serial.c index bce947b..767bdeb 100644 --- a/mendel/serial.c +++ b/mendel/serial.c @@ -146,7 +146,9 @@ void serial_writechar(uint8_t data) void serial_writeblock(void *data, int datalen) { - for (int i = 0; i < datalen; i++) + int i; + + for (i = 0; i < datalen; i++) serial_writechar(((uint8_t *) data)[i]); } @@ -170,15 +172,17 @@ void serial_writechar_P(PGM_P data) void serial_writeblock_P(PGM_P data, int datalen) { - for (int i = 0; i < datalen; i++) + int i; + + for (i = 0; i < datalen; i++) serial_writechar_P(&data[i]); } void serial_writestr_P(PGM_P data) { - uint8_t i = 0; + uint8_t r, i = 0; // yes, this is *supposed* to be assignment rather than comparison, so we break when r is assigned zero - for (uint8_t r; (r = pgm_read_byte(&data[i])); i++) + for (r; (r = pgm_read_byte(&data[i])); i++) serial_writechar(r); } --
--- mendel/gcode.c | 4 ++++ mendel/gcode.h | 3 +++ 2 files changed, 7 insertions(+), 0 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index 6d06e08..04a7e71 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -312,7 +312,11 @@ void scan_char(uint8_t c) { ) { process_gcode_command(&next_target); + #ifdef LOWERCASE_OK + serial_writestr_P(PSTR("ok\n")); + #else serial_writestr_P(PSTR("OK\n")); + #endif // expect next line number next_target.N_expected++; diff --git a/mendel/gcode.h b/mendel/gcode.h index bfc9061..4805501 100644 --- a/mendel/gcode.h +++ b/mendel/gcode.h @@ -5,6 +5,9 @@ #include "dda.h" +// host software expectations +#define LOWERCASE_OK + // this is a very crude decimal-based floating point structure. a real floating point would at least have signed exponent typedef struct { uint32_t sign :1; --
--- mendel/Makefile | 4 +--- mendel/gcode.h | 2 ++ 2 files changed, 3 insertions(+), 3 deletions(-) diff --git a/mendel/Makefile b/mendel/Makefile index fcc78f6..3dfd4b6 100644 --- a/mendel/Makefile +++ b/mendel/Makefile @@ -38,8 +38,6 @@ OBJCOPY = $(ARCH)objcopy DEFS = -DF_CPU=$(F_CPU) # DEFS += "-DDEBUG=1" -# DEFS += "-DREQUIRE_LINENUMBER" -# DEFS += "-DREQUIRE_CHECKSUM" OPTIMIZE = -Os -ffunction-sections -finline-functions-called-once -DDEBUG # OPTIMIZE = -O0 @@ -103,4 +101,4 @@ size: $(PROGRAM).hex %.sym: %.elf @echo " SYM $@" - @$(OBJDUMP) -t $< | perl -ne 'BEGIN { printf " ADDR NAME SIZE\n"; } /([0-9a-f]+)\s+(\w+)\s+O\s+\.(bss|data)\s+([0-9a-f]+)\s+(\w+)/ && printf "0x%04x %-20s +%d\n", eval("0x$$1") & 0xFFFF, $$5, eval("0x$$4")' | sort -k1 > $@ \ No newline at end of file + @$(OBJDUMP) -t $< | perl -ne 'BEGIN { printf " ADDR NAME SIZE\n"; } /([0-9a-f]+)\s+(\w+)\s+O\s+\.(bss|data)\s+([0-9a-f]+)\s+(\w+)/ && printf "0x%04x %-20s +%d\n", eval("0x$$1") & 0xFFFF, $$5, eval("0x$$4")' | sort -k1 > $@ diff --git a/mendel/gcode.h b/mendel/gcode.h index 4805501..9fd1795 100644 --- a/mendel/gcode.h +++ b/mendel/gcode.h @@ -7,6 +7,8 @@ // host software expectations #define LOWERCASE_OK +//#define REQUIRE_LINENUMBER +//#define REQUIRE_CHECKSUM // this is a very crude decimal-based floating point structure. a real floating point would at least have signed exponent typedef struct { --
Testcase:
M105 G1 F100
--> Temperatures would be sent the second time as well.
--- mendel/gcode.c | 7 ++++++- 1 files changed, 6 insertions(+), 1 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index 04a7e71..c05c598 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -335,7 +335,12 @@ void scan_char(uint8_t c) { } // reset variables - next_target.seen_X = next_target.seen_Y = next_target.seen_Z = next_target.seen_E = next_target.seen_F = next_target.seen_S = next_target.seen_P = next_target.seen_N = next_target.seen_checksum = next_target.seen_comment = next_target.checksum_read = next_target.checksum_calculated = 0; + next_target.seen_X = next_target.seen_Y = next_target.seen_Z = \ + next_target.seen_E = next_target.seen_F = next_target.seen_G = \ + next_target.seen_S = next_target.seen_P = next_target.seen_N = \ + next_target.seen_M = next_target.seen_checksum = \ + next_target.seen_comment = next_target.checksum_read = \ + next_target.checksum_calculated = 0; last_field = 0; read_digit.sign = 0; read_digit.mantissa = 0; --
Failing case was RepRap host software, sending
N0 T8 *18 N0 G21 *58
on each build start.
Also saves a whopping 124 bytes of memory on ignoring line numbers. next_target.N_expected is never used and it's handling should be optimized out.
--- mendel/gcode.c | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index c05c598..86259b0 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -297,11 +297,11 @@ void scan_char(uint8_t c) { // process if (next_target.seen_G || next_target.seen_M) { if ( - #ifdef REQUIRE_LINENUMBER - ((next_target.N_expected == next_target.N) && (next_target.seen_N == 1)) - #else - ((next_target.N_expected == next_target.N) || (next_target.seen_N == 0)) - #endif + #ifdef REQUIRE_LINENUMBER + ((next_target.N_expected == next_target.N) && (next_target.seen_N == 1)) + #else + 1 + #endif ) { if ( #ifdef REQUIRE_CHECKSUM --
There isn't much point in insisting on consecutive line numbers. Some CNC softwares even do steps of 5 or 10 intentionally.
--- mendel/gcode.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index 86259b0..a9cb139 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -298,7 +298,7 @@ void scan_char(uint8_t c) { if (next_target.seen_G || next_target.seen_M) { if ( #ifdef REQUIRE_LINENUMBER - ((next_target.N_expected == next_target.N) && (next_target.seen_N == 1)) + ((next_target.N >= next_target.N_expected) && (next_target.seen_N == 1)) #else 1 #endif @@ -319,7 +319,7 @@ void scan_char(uint8_t c) { #endif // expect next line number - next_target.N_expected++; + next_target.N_expected = next_target.N + 1; } else { serial_writestr_P(PSTR("RESEND: BAD CHECKSUM: EXPECTED ")); --
This allows to issue manual commands in midst of a (paused) build.
--- mendel/gcode.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index a9cb139..1622b51 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -319,7 +319,8 @@ void scan_char(uint8_t c) { #endif // expect next line number - next_target.N_expected = next_target.N + 1; + if (next_target.seen_N == 1) + next_target.N_expected = next_target.N + 1; } else { serial_writestr_P(PSTR("RESEND: BAD CHECKSUM: EXPECTED ")); --
For example, RepRap host sends T commands, which are not (yet) known.
Previously, the firmware would fail silently, which was even worse.
--- mendel/gcode.c | 54 +++++++++++++++++++++++++++++++----------------------- 1 files changed, 31 insertions(+), 23 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index 1622b51..d75e18e 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -221,7 +221,7 @@ void scan_char(uint8_t c) { // process character switch (c) { - // each command is either G or M, so preserve previous G/M unless a new one has appeared + // each currently known command is either G or M, so preserve previous G/M unless a new one has appeared case 'G': next_target.seen_G = 1; next_target.seen_M = 0; @@ -294,46 +294,54 @@ void scan_char(uint8_t c) { if ((c == 10) || (c == 13)) { if (debug_flags & DEBUG_ECHO) serial_writechar(c); - // process - if (next_target.seen_G || next_target.seen_M) { + + if ( + #ifdef REQUIRE_LINENUMBER + ((next_target.N >= next_target.N_expected) && (next_target.seen_N == 1)) + #else + 1 + #endif + ) { if ( - #ifdef REQUIRE_LINENUMBER - ((next_target.N >= next_target.N_expected) && (next_target.seen_N == 1)) + #ifdef REQUIRE_CHECKSUM + ((next_target.checksum_calculated == next_target.checksum_read) && (next_target.seen_checksum == 1)) #else - 1 + ((next_target.checksum_calculated == next_target.checksum_read) || (next_target.seen_checksum == 0)) #endif ) { - if ( - #ifdef REQUIRE_CHECKSUM - ((next_target.checksum_calculated == next_target.checksum_read) && (next_target.seen_checksum == 1)) - #else - ((next_target.checksum_calculated == next_target.checksum_read) || (next_target.seen_checksum == 0)) - #endif - ) { + // process + if (next_target.seen_G || next_target.seen_M) { process_gcode_command(&next_target); - #ifdef LOWERCASE_OK serial_writestr_P(PSTR("ok\n")); #else serial_writestr_P(PSTR("OK\n")); #endif - - // expect next line number - if (next_target.seen_N == 1) - next_target.N_expected = next_target.N + 1; } else { - serial_writestr_P(PSTR("RESEND: BAD CHECKSUM: EXPECTED ")); - serwrite_uint8(next_target.checksum_calculated); - serial_writestr_P(PSTR("\n")); + // write "OK" for invalid/unknown commands as well + #ifdef LOWERCASE_OK + serial_writestr_P(PSTR("ok huh?\n")); + #else + serial_writestr_P(PSTR("OK Huh?\n")); + #endif } + + // expect next line number + if (next_target.seen_N == 1) + next_target.N_expected = next_target.N + 1; } else { - serial_writestr_P(PSTR("RESEND: BAD LINE NUMBER: EXPECTED ")); - serwrite_uint32(next_target.N_expected); + serial_writestr_P(PSTR("RESEND: BAD CHECKSUM: EXPECTED ")); + serwrite_uint8(next_target.checksum_calculated); serial_writestr_P(PSTR("\n")); } } + else { + serial_writestr_P(PSTR("RESEND: BAD LINE NUMBER: EXPECTED ")); + serwrite_uint32(next_target.N_expected); + serial_writestr_P(PSTR("\n")); + } // reset variables next_target.seen_X = next_target.seen_Y = next_target.seen_Z = \ --
Elaborate on the various #defines related to host expectations in gcode.h
--- mendel/gcode.c | 25 +++++++++++++++++++++++-- mendel/gcode.h | 12 ++++++++++++ 2 files changed, 35 insertions(+), 2 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index d75e18e..8460737 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -332,15 +332,17 @@ void scan_char(uint8_t c) { next_target.N_expected = next_target.N + 1; } else { - serial_writestr_P(PSTR("RESEND: BAD CHECKSUM: EXPECTED ")); + serial_writestr_P(PSTR("Expected checksum ")); serwrite_uint8(next_target.checksum_calculated); serial_writestr_P(PSTR("\n")); + request_resend(); } } else { - serial_writestr_P(PSTR("RESEND: BAD LINE NUMBER: EXPECTED ")); + serial_writestr_P(PSTR("Expected line number ")); serwrite_uint32(next_target.N_expected); serial_writestr_P(PSTR("\n")); + request_resend(); } // reset variables @@ -725,3 +727,22 @@ void process_gcode_command(GCODE_COMMAND *gcmd) { } } } + +/**************************************************************************** +* * +* Request a resend of the current line - used from various places. * +* * +* Relies on the global variable next_target.N being valid. * +* * +****************************************************************************/ + +void request_resend() { + #ifdef LOWERCASE_OK + serial_writestr_P(PSTR("Resend:")); + #else + serial_writestr_P(PSTR("RESEND: ")); + #endif + serwrite_uint8(next_target.N); + serial_writestr_P(PSTR("\n")); +} + diff --git a/mendel/gcode.h b/mendel/gcode.h index 9fd1795..8b37e46 100644 --- a/mendel/gcode.h +++ b/mendel/gcode.h @@ -6,10 +6,19 @@ #include "dda.h" // host software expectations + +// wether host software expects all caps or (mostly) lowercase responses +// keeping it defined makes us matching RepRap host software's expectations #define LOWERCASE_OK + +// wether to insist on N line numbers +// if not defined, N's are completely ignored //#define REQUIRE_LINENUMBER + +// wether to insist on a checksum //#define REQUIRE_CHECKSUM + // this is a very crude decimal-based floating point structure. a real floating point would at least have signed exponent typedef struct { uint32_t sign :1; @@ -68,4 +77,7 @@ void scan_char(uint8_t c); // when we have a whole line, feed it to this void process_gcode_command(GCODE_COMMAND *gcmd); +// uses the global variable next_target.N +void request_resend(); + #endif /* _GCODE_H */ --
RepRap host software does it this way.
--- mendel/gcode.c | 11 +++++++++-- mendel/gcode.h | 4 ++++ 2 files changed, 13 insertions(+), 2 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index 8460737..c1065f1 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -17,6 +17,8 @@ uint8_t last_field = 0; const char alphabet[] = "GMXYZEFSPN*"; +#define crc(a, b) (a ^ b) + decfloat read_digit __attribute__ ((__section__ (".bss"))); GCODE_COMMAND next_target __attribute__ ((__section__ (".bss"))); @@ -103,10 +105,10 @@ void SpecialMoveE(int32_t e, uint32_t f) { ****************************************************************************/ void scan_char(uint8_t c) { - // move this below switch(c) if the asterisk isn't included in the checksum - #define crc(a, b) (a ^ b) + #ifdef ASTERISK_IN_CHECKSUM_INCLUDED if (next_target.seen_checksum == 0) next_target.checksum_calculated = crc(next_target.checksum_calculated, c); + #endif // uppercase if (c >= 'a' && c <= 'z') @@ -290,6 +292,11 @@ void scan_char(uint8_t c) { } } + #ifndef ASTERISK_IN_CHECKSUM_INCLUDED + if (next_target.seen_checksum == 0) + next_target.checksum_calculated = crc(next_target.checksum_calculated, c); + #endif + // end of line if ((c == 10) || (c == 13)) { if (debug_flags & DEBUG_ECHO) diff --git a/mendel/gcode.h b/mendel/gcode.h index 8b37e46..c4bc440 100644 --- a/mendel/gcode.h +++ b/mendel/gcode.h @@ -11,6 +11,10 @@ // keeping it defined makes us matching RepRap host software's expectations #define LOWERCASE_OK +// wether the asterisk (checksum-command) is included for checksum calculation +// undefined for RepRap host software +//#define ASTERISK_IN_CHECKSUM_INCLUDED + // wether to insist on N line numbers // if not defined, N's are completely ignored //#define REQUIRE_LINENUMBER --
Previously, unknown commands would mess up decimals handling. Failing testcase was "N11 T22", which was interpreted as "N1122".
The new code now also compiles to 56 bytes less.
--- mendel/gcode.c | 16 ++++++---------- 1 files changed, 6 insertions(+), 10 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index c1065f1..ed0db29 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -15,8 +15,6 @@ uint8_t last_field = 0; -const char alphabet[] = "GMXYZEFSPN*"; - #define crc(a, b) (a ^ b) decfloat read_digit __attribute__ ((__section__ (".bss"))); @@ -117,7 +115,8 @@ void scan_char(uint8_t c) { // process previous field if (last_field) { // check if we're seeing a new field or end of line - if ((indexof(c, alphabet) >= 0) || (c == 10) || (c ==13)) { + // any character will start a new field, even invalid/unknown ones + if ((c >= 'A' && c <= 'Z') || c == '*' || (c == 10) || (c == 13)) { switch (last_field) { case 'G': next_target.G = read_digit.mantissa; @@ -206,16 +205,14 @@ void scan_char(uint8_t c) { } // reset for next field last_field = 0; - read_digit.sign = 0; - read_digit.mantissa = 0; - read_digit.exponent = 0; + read_digit.sign = read_digit.mantissa = read_digit.exponent = 0; } } // skip comments if (next_target.seen_comment == 0) { // new field? - if (indexof(c, alphabet) >= 0) { + if ((c >= 'A' && c <= 'Z') || c == '*') { last_field = c; if (debug_flags & DEBUG_ECHO) serial_writechar(c); @@ -289,6 +286,7 @@ void scan_char(uint8_t c) { if (read_digit.exponent) read_digit.exponent++; } + // everything else is ignored } } @@ -360,9 +358,7 @@ void scan_char(uint8_t c) { next_target.seen_comment = next_target.checksum_read = \ next_target.checksum_calculated = 0; last_field = 0; - read_digit.sign = 0; - read_digit.mantissa = 0; - read_digit.exponent = 0; + read_digit.sign = read_digit.mantissa = read_digit.exponent = 0; } } --
--- mendel/temp.c | 4 ++++ mendel/temp.h | 3 +++ 2 files changed, 7 insertions(+), 0 deletions(-) diff --git a/mendel/temp.c b/mendel/temp.c index 913b91c..c1310b9 100644 --- a/mendel/temp.c +++ b/mendel/temp.c @@ -159,7 +159,11 @@ void temp_print() { c = (current_temp & 3) * 25; t = (target_temp & 3) * 25; + #ifdef REPRAP_HOST_COMPATIBILITY + sersendf_P(PSTR("T: %u.%u\n"), current_temp >> 2, c); + #else sersendf_P(PSTR("T: %u.%u/%u.%u :%u\n"), current_temp >> 2, c, target_temp >> 2, t, temp_residency); + #endif } } diff --git a/mendel/temp.h b/mendel/temp.h index 71902fd..44c3acd 100644 --- a/mendel/temp.h +++ b/mendel/temp.h @@ -3,6 +3,9 @@ #include <stdint.h> +// RepRap host software isn't exactly tolerant on what it ready back. +#define REPRAP_HOST_COMPATIBILITY + // extruder heater PID factors // google "PID without a PHD" if you don't understand this PID stuff extern int32_t p_factor; --
All those calculations were confusingly complex and made for one type of machine, only.
--- mendel/gcode.c | 32 ++++++++-------- mendel/machine.h | 108 +++++++++++++++++++++-------------------------------- mendel/mendel.c | 2 +- 3 files changed, 60 insertions(+), 82 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index ed0db29..49687b4 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -398,7 +398,7 @@ void process_gcode_command(GCODE_COMMAND *gcmd) { // G0 - rapid, unsynchronised motion // since it would be a major hassle to force the dda to not synchronise, just provide a fast feedrate and hope it's close enough to what host expects case 0: - gcmd->target.F = FEEDRATE_FAST_XY; + gcmd->target.F = MAXIMUM_FEEDRATE_X; enqueue(&gcmd->target); break; @@ -449,15 +449,15 @@ void process_gcode_command(GCODE_COMMAND *gcmd) { Home XY first */ // hit endstops, no acceleration- we don't care about skipped steps - startpoint.F = FEEDRATE_FAST_XY; - SpecialMoveXY(-250L * STEPS_PER_MM_X, -250L * STEPS_PER_MM_Y, FEEDRATE_FAST_XY); + startpoint.F = MAXIMUM_FEEDRATE_X; + SpecialMoveXY(-250L * STEPS_PER_MM_X, -250L * STEPS_PER_MM_Y, MAXIMUM_FEEDRATE_X); startpoint.X = startpoint.Y = 0; // move forward a bit - SpecialMoveXY(5 * STEPS_PER_MM_X, 5 * STEPS_PER_MM_Y, FEEDRATE_SLOW_XY); + SpecialMoveXY(5 * STEPS_PER_MM_X, 5 * STEPS_PER_MM_Y, SEARCH_FEEDRATE_X); // move back in to endstops slowly - SpecialMoveXY(-20 * STEPS_PER_MM_X, -20 * STEPS_PER_MM_Y, FEEDRATE_SLOW_XY); + SpecialMoveXY(-20 * STEPS_PER_MM_X, -20 * STEPS_PER_MM_Y, SEARCH_FEEDRATE_X); // wait for queue to complete for (;!queue_empty();); @@ -469,15 +469,15 @@ void process_gcode_command(GCODE_COMMAND *gcmd) { Home Z */ // hit endstop, no acceleration- we don't care about skipped steps - startpoint.F = FEEDRATE_FAST_Z; - SpecialMoveZ(-250L * STEPS_PER_MM_Z, FEEDRATE_FAST_Z); + startpoint.F = MAXIMUM_FEEDRATE_Z; + SpecialMoveZ(-250L * STEPS_PER_MM_Z, MAXIMUM_FEEDRATE_Z); startpoint.Z = 0; // move forward a bit - SpecialMoveZ(5 * STEPS_PER_MM_Z, FEEDRATE_SLOW_Z); + SpecialMoveZ(5 * STEPS_PER_MM_Z, SEARCH_FEEDRATE_Z); // move back into endstop slowly - SpecialMoveZ(-20L * STEPS_PER_MM_Z, FEEDRATE_SLOW_Z); + SpecialMoveZ(-20L * STEPS_PER_MM_Z, SEARCH_FEEDRATE_Z); // wait for queue to complete for (;queue_empty();); @@ -495,9 +495,9 @@ void process_gcode_command(GCODE_COMMAND *gcmd) { Home F */ - // F has been left at FEEDRATE_SLOW_Z by the last move, this is a usable "home" + // F has been left at SEARCH_FEEDRATE_Z by the last move, this is a usable "home" // uncomment the following or substitute if you prefer a different default feedrate - // startpoint.F = FEEDRATE_SLOW_XY + // startpoint.F = SEARCH_FEEDRATE_Z break; @@ -516,7 +516,7 @@ void process_gcode_command(GCODE_COMMAND *gcmd) { startpoint.X = startpoint.Y = startpoint.Z = startpoint.E = current_position.X = current_position.Y = current_position.Z = current_position.E = 0; startpoint.F = - current_position.F = FEEDRATE_SLOW_Z; + current_position.F = SEARCH_FEEDRATE_Z; break; // unknown gcode: spit an error @@ -545,8 +545,8 @@ void process_gcode_command(GCODE_COMMAND *gcmd) { do { // backup feedrate, move E very quickly then restore feedrate uint32_t f = startpoint.F; - startpoint.F = FEEDRATE_FAST_E; - SpecialMoveE(E_STARTSTOP_STEPS, FEEDRATE_FAST_E); + startpoint.F = MAXIMUM_FEEDRATE_E; + SpecialMoveE(E_STARTSTOP_STEPS, MAXIMUM_FEEDRATE_E); startpoint.F = f; } while (0); break; @@ -558,8 +558,8 @@ void process_gcode_command(GCODE_COMMAND *gcmd) { do { // backup feedrate, move E very quickly then restore feedrate uint32_t f = startpoint.F; - startpoint.F = FEEDRATE_FAST_E; - SpecialMoveE(-E_STARTSTOP_STEPS, FEEDRATE_FAST_E); + startpoint.F = MAXIMUM_FEEDRATE_E; + SpecialMoveE(-E_STARTSTOP_STEPS, MAXIMUM_FEEDRATE_E); startpoint.F = f; } while (0); break; diff --git a/mendel/machine.h b/mendel/machine.h index 2c91c6c..067391e 100644 --- a/mendel/machine.h +++ b/mendel/machine.h @@ -1,85 +1,56 @@ #ifndef _MACHINE_H #define _MACHINE_H -/* - move buffer size, in number of moves - note that each move takes a fair chunk of ram (69 bytes as of this writing) so don't make the buffer too big - a bigger serial readbuffer may help more than increasing this unless your gcodes are more than 70 characters long on average. - however, a larger movebuffer will probably help with lots of short consecutive moves, as each move takes a bunch of math (hence time) to set up -*/ -#define MOVEBUFFER_SIZE 8 - -/* - axis calculations, adjust as necessary -*/ - -// XY can have lots of precision and still move speedily, so microstepping is helpful -#define X_STEPS_PER_REV 3200.0 -#define Y_STEPS_PER_REV X_STEPS_PER_REV - -// we need far more speed than precision on Z due to the threaded rod drive, maybe just half stepping -#define Z_STEPS_PER_REV 400.0 - -#define X_COG_CIRCUMFERENCE (4.77 * 16.0) -#define Y_COG_CIRCUMFERENCE X_COG_CIRCUMFERENCE -// also try: -// #define XY_COG_RADIUS 9.5 -// #define XY_COG_CIRCUMFERENCE (XY_COG_RADIUS * PI * 2) - -// this is the ratio between number of teeth on the Z motor gear, and teeth on the Z leadscrew base gear. -#define Z_GEAR_RATIO 1.0 - -// we need more torque and smoothness at very low speeds on E, maximum microstepping -#define E_STEPS_PER_REV 3200.0 -#define EXTRUDER_SHAFT_RADIUS 5.0 -#define EXTRUDER_INLET_DIAMETER 3.0 -#define EXTRUDER_NOZZLE_DIAMETER 0.8 +// -------------------------------------------------------------------------- +// values reflecting the gearing of your machine +// all numbers are integers, so no decimals, please :-) -// these feedrates are used during homing and G0 rapid moves -#define FEEDRATE_FAST_XY 6000 -#define FEEDRATE_SLOW_XY 300 +// calculate these values appropriate for your machine +#define STEPS_PER_MM_X 320 +#define STEPS_PER_MM_Y 320 +#define STEPS_PER_MM_Z 320 -#define FEEDRATE_FAST_Z 6000 -#define FEEDRATE_SLOW_Z 300 - -#define FEEDRATE_FAST_E 1200 +// http://blog.arcol.hu/?p=157 may help with this next one +#define STEPS_PER_MM_E 320 // this is how many steps to suck back the filament by when we stop -#define E_STARTSTOP_STEPS 20 +#define E_STARTSTOP_STEPS 20 -// extruder settings -#define TEMP_HYSTERESIS 20 -#define TEMP_RESIDENCY_TIME 60 +// -------------------------------------------------------------------------- +// values depending on the capabilities of your stepper motors and other mechanics +// again, all numbers are integers -/* - calculated values - you shouldn't need to touch these - however feel free to put in your own values if they can be more precise than the calculated approximations, remembering that they must end up being integers- floating point by preprocessor only thanks! -*/ +// used for G0 rapid moves and as a cap for all other feedrates +#define MAXIMUM_FEEDRATE_X 200 +#define MAXIMUM_FEEDRATE_Y 200 +#define MAXIMUM_FEEDRATE_Z 200 +#define MAXIMUM_FEEDRATE_E 200 -#define STEPS_PER_MM_X ((uint32_t) ((X_STEPS_PER_REV / X_COG_CIRCUMFERENCE) + 0.5)) -#define STEPS_PER_MM_Y ((uint32_t) ((Y_STEPS_PER_REV / Y_COG_CIRCUMFERENCE) + 0.5)) -#define STEPS_PER_MM_Z ((uint32_t) ((Z_STEPS_PER_REV * Z_GEAR_RATIO) + 0.5)) +// used when searching endstops and similar +#define SEARCH_FEEDRATE_X 50 +#define SEARCH_FEEDRATE_Y 50 +#define SEARCH_FEEDRATE_Z 50 +#define SEARCH_FEEDRATE_E 50 -// http://blog.arcol.hu/?p=157 may help with this next one -// I haven't tuned this at all- it's just a placeholder until I read the above carefully enough -// does this refer to filament or extrudate? extrudate depends on XY distance vs E distance.. hm lets go with filament -// #define STEPS_PER_MM_E ((uint32_t) ((E_STEPS_PER_REV / (EXTRUDER_SHAFT_RADIUS * PI * EXTRUDER_INLET_DIAMETER / EXTRUDER_NOZZLE_DIAMETER)) + 0.5)) +// extruder settings +#define TEMP_HYSTERESIS 20 +#define TEMP_RESIDENCY_TIME 60 -#define STEPS_PER_MM_E ((uint32_t) ((E_STEPS_PER_REV * EXTRUDER_NOZZLE_DIAMETER / EXTRUDER_SHAFT_RADIUS / PI / EXTRUDER_INLET_DIAMETER) + 0.5)) +// -------------------------------------------------------------------------- +// you shouldn't need to edit something below this line // same as above with 25.4 scale factor -#define STEPS_PER_IN_X ((uint32_t) ((25.4 * X_STEPS_PER_REV / X_COG_CIRCUMFERENCE) + 0.5)) -#define STEPS_PER_IN_Y ((uint32_t) ((25.4 * Y_STEPS_PER_REV / Y_COG_CIRCUMFERENCE) + 0.5)) -#define STEPS_PER_IN_Z ((uint32_t) ((25.4 * Z_STEPS_PER_REV * Z_GEAR_RATIO) + 0.5)) -#define STEPS_PER_IN_E ((uint32_t) ((25.4 * E_STEPS_PER_REV * EXTRUDER_NOZZLE_DIAMETER / (EXTRUDER_SHAFT_RADIUS * PI * EXTRUDER_INLET_DIAMETER)) + 0.5)) +#define STEPS_PER_IN_X ((uint32_t) ((25.4 * STEPS_PER_MM_X) + 0.5)) +#define STEPS_PER_IN_Y ((uint32_t) ((25.4 * STEPS_PER_MM_Y) + 0.5)) +#define STEPS_PER_IN_Z ((uint32_t) ((25.4 * STEPS_PER_MM_Z) + 0.5)) +#define STEPS_PER_IN_E ((uint32_t) ((25.4 * STEPS_PER_MM_E) + 0.5)) // inverse, used in distance calculation during DDA setup -#define UM_PER_STEP_X ((uint32_t) ((1000.0 / STEPS_PER_MM_X) + 0.5)) -#define UM_PER_STEP_Y ((uint32_t) ((1000.0 / STEPS_PER_MM_Y) + 0.5)) -#define UM_PER_STEP_Z ((uint32_t) ((1000.0 / STEPS_PER_MM_Z) + 0.5)) -#define UM_PER_STEP_E ((uint32_t) ((1000.0 / STEPS_PER_MM_E) + 0.5)) +#define UM_PER_STEP_X ((uint32_t) ((1000.0 / STEPS_PER_MM_X) + 0.5)) +#define UM_PER_STEP_Y ((uint32_t) ((1000.0 / STEPS_PER_MM_Y) + 0.5)) +#define UM_PER_STEP_Z ((uint32_t) ((1000.0 / STEPS_PER_MM_Z) + 0.5)) +#define UM_PER_STEP_E ((uint32_t) ((1000.0 / STEPS_PER_MM_E) + 0.5)) -// should be the same for all machines! ;) -#define PI 3.1415926535 /* firmware build options @@ -92,4 +63,11 @@ // Xon/Xoff flow control. Should be redundant // #define XONXOFF +/* + move buffer size, in number of moves + note that each move takes a fair chunk of ram (69 bytes as of this writing) so don't make the buffer too big - a bigger serial readbuffer may help more than increasing this unless your gcodes are more than 70 characters long on average. + however, a larger movebuffer will probably help with lots of short consecutive moves, as each move takes a bunch of math (hence time) to set up +*/ +#define MOVEBUFFER_SIZE 8 + #endif /* _MACHINE_H */ diff --git a/mendel/mendel.c b/mendel/mendel.c index 37128b8..f2b8b60 100644 --- a/mendel/mendel.c +++ b/mendel/mendel.c @@ -89,7 +89,7 @@ void init(void) { temp_init(); // set up default feedrate - current_position.F = startpoint.F = next_target.target.F = FEEDRATE_SLOW_Z; + current_position.F = startpoint.F = next_target.target.F = SEARCH_FEEDRATE_Z; // enable interrupts sei(); --
-> serial_writechar() perfoms better, uses less memory. Also, reviewed all code for usage of single-character strings.
--- mendel/gcode.c | 6 +++--- mendel/serial.c | 14 ++++++++------ mendel/serial.h | 1 - 3 files changed, 11 insertions(+), 10 deletions(-) diff --git a/mendel/gcode.c b/mendel/gcode.c index 49687b4..5030ccb 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -339,14 +339,14 @@ void scan_char(uint8_t c) { else { serial_writestr_P(PSTR("Expected checksum ")); serwrite_uint8(next_target.checksum_calculated); - serial_writestr_P(PSTR("\n")); + serial_writechar('\n'); request_resend(); } } else { serial_writestr_P(PSTR("Expected line number ")); serwrite_uint32(next_target.N_expected); - serial_writestr_P(PSTR("\n")); + serial_writechar('\n'); request_resend(); } @@ -746,6 +746,6 @@ void request_resend() { serial_writestr_P(PSTR("RESEND: ")); #endif serwrite_uint8(next_target.N); - serial_writestr_P(PSTR("\n")); + serial_writechar('\n'); } diff --git a/mendel/serial.c b/mendel/serial.c index 767bdeb..13703c2 100644 --- a/mendel/serial.c +++ b/mendel/serial.c @@ -163,19 +163,21 @@ void serial_writestr(uint8_t *data) /* Write from FLASH -*/ -void serial_writechar_P(PGM_P data) -{ - serial_writechar(pgm_read_byte(data)); -} + Extensions to output flash memory pointers. This prevents the data to + become part of the .data segment instead of the .code segment. That means + less memory is consumed for multi-character writes. + + For single character writes (i.e. '\n' instead of "\n"), using + serial_writechar() directly is the better choice. +*/ void serial_writeblock_P(PGM_P data, int datalen) { int i; for (i = 0; i < datalen; i++) - serial_writechar_P(&data[i]); + serial_writechar(pgm_read_byte(&data[i])); } void serial_writestr_P(PGM_P data) diff --git a/mendel/serial.h b/mendel/serial.h index 1f30c2c..73a7b18 100644 --- a/mendel/serial.h +++ b/mendel/serial.h @@ -24,7 +24,6 @@ void serial_writeblock(void *data, int datalen); void serial_writestr(uint8_t *data); // write from flash -void serial_writechar_P(PGM_P data); void serial_writeblock_P(PGM_P data, int datalen); void serial_writestr_P(PGM_P data); --
Saves 50 bytes.
--- mendel/dda.c | 18 +++++------------- 1 files changed, 5 insertions(+), 13 deletions(-) diff --git a/mendel/dda.c b/mendel/dda.c index fe0ef27..9fdf6d3 100644 --- a/mendel/dda.c +++ b/mendel/dda.c @@ -92,12 +92,6 @@ uint32_t approx_distance_3( uint32_t dx, uint32_t dy, uint32_t dz ) return (( approx + 512 ) >> 10 ); } -uint32_t abs32(int32_t v) { - if (v < 0) - return (uint32_t) (-v); - return (uint32_t) (v); -} - uint32_t delta32(uint32_t v1, uint32_t v2) { if (v1 >= v2) return v1 - v2; @@ -126,7 +120,6 @@ void dda_create(DDA *dda, TARGET *target) { // initialise DDA to a known state dda->live = 0; -// dda->total_steps = 0; dda->waitfor_temp = 0; if (debug_flags & DEBUG_DDA) @@ -135,10 +128,10 @@ void dda_create(DDA *dda, TARGET *target) { // we end at the passed target memcpy(&(dda->endpoint), target, sizeof(TARGET)); - dda->x_delta = abs32(target->X - startpoint.X); - dda->y_delta = abs32(target->Y - startpoint.Y); - dda->z_delta = abs32(target->Z - startpoint.Z); - dda->e_delta = abs32(target->E - startpoint.E); + dda->x_delta = ABS(target->X - startpoint.X); + dda->y_delta = ABS(target->Y - startpoint.Y); + dda->z_delta = ABS(target->Z - startpoint.Z); + dda->e_delta = ABS(target->E - startpoint.E); dda->x_direction = (target->X >= startpoint.X)?1:0; dda->y_direction = (target->Y >= startpoint.Y)?1:0; @@ -162,8 +155,7 @@ void dda_create(DDA *dda, TARGET *target) { serial_writestr_P(PSTR("] [")); } -// if (dda->x_delta > dda->total_steps) - dda->total_steps = dda->x_delta; + dda->total_steps = dda->x_delta; if (dda->y_delta > dda->total_steps) dda->total_steps = dda->y_delta; if (dda->z_delta > dda->total_steps) --
This accounts for the fact real-world machines can't gain full speed instantly. In tests with my setup it also allowed more than the doubling target speed - over 1000 rpm with an ordinary NEMA-23 stepper!
The code allowing slow acceleration over the whole move had to be dropped. To be honest, I see no use in this code other than a hack in the wrong place (i.e. the G-code producing application) to achieve what's now done by firmware.
A fact of the current implementation is, it stops after each move. This means slow average speeds in case of many short moves.
It'll be possible to improve this situation by taking the next move into account when ramping down. A not-so-trivial task, predestined for a hacking week sometimes in the future.
--- mendel/dda.c | 122 ++++++++++++++++------------------------------------- mendel/dda.h | 38 ++++++++++++---- mendel/gcode.c | 2 - mendel/machine.h | 8 ++++ 4 files changed, 73 insertions(+), 97 deletions(-) diff --git a/mendel/dda.c b/mendel/dda.c index 9fdf6d3..bffbfa3 100644 --- a/mendel/dda.c +++ b/mendel/dda.c @@ -98,19 +98,6 @@ uint32_t delta32(uint32_t v1, uint32_t v2) { return v2 - v1; } -// this is an ultra-crude pseudo-logarithm routine, such that: -// 2 ^ msbloc(v) >= v -const uint8_t msbloc (uint32_t v) { - uint8_t i; - uint32_t c; - for (i = 31, c = 0x80000000; i; i--) { - if (v & c) - return i; - c >>= 1; - } - return 0; -} - /* CREATE a dda given current_position and a target, save to passed location so we can write directly into the queue */ @@ -210,66 +197,17 @@ void dda_create(DDA *dda, TARGET *target) { // distance * 2400 .. * F_CPU / 40000 so we can move a distance of up to 1800mm without overflowing uint32_t move_duration = ((distance * 2400) / dda->total_steps) * (F_CPU / 40000); + #ifdef ACCELERATION_RAMPING + dda->ramp_steps = dda->total_steps / 2; + dda->step_no = 0; // c is initial step time in IOclk ticks - dda->c = (move_duration / startpoint.F) << 8; - - if (debug_flags & DEBUG_DDA) { - serial_writestr_P(PSTR(",md:")); serwrite_uint32(move_duration); - serial_writestr_P(PSTR(",c:")); serwrite_uint32(dda->c >> 8); - } - - if (startpoint.F != target->F) { - uint32_t stF = startpoint.F / 4; - uint32_t enF = target->F / 4; - // now some constant acceleration stuff, courtesy of http://www.embedded.com/columns/technicalinsights/56800129?printable=true - uint32_t ssq = (stF * stF); - uint32_t esq = (enF * enF); - int32_t dsq = (int32_t) (esq - ssq) / 4; - - uint8_t msb_ssq = msbloc(ssq); - uint8_t msb_tot = msbloc(dda->total_steps); - - dda->end_c = (move_duration / target->F) << 8; - // the raw equation WILL overflow at high step rates, but 64 bit math routines take waay too much space - // at 65536 mm/min (1092mm/s), ssq/esq overflows, and dsq is also close to overflowing if esq/ssq is small - // but if ssq-esq is small, ssq/dsq is only a few bits - // we'll have to do it a few different ways depending on the msb locations of each - if ((msb_tot + msb_ssq) <= 30) { - // we have room to do all the multiplies first - if (debug_flags & DEBUG_DDA) - serial_writechar('A'); - dda->n = ((int32_t) (dda->total_steps * ssq) / dsq) + 1; - } - else if (msb_tot >= msb_ssq) { - // total steps has more precision - if (debug_flags & DEBUG_DDA) - serial_writechar('B'); - dda->n = (((int32_t) dda->total_steps / dsq) * (int32_t) ssq) + 1; - } - else { - // otherwise - if (debug_flags & DEBUG_DDA) - serial_writechar('C'); - dda->n = (((int32_t) ssq / dsq) * (int32_t) dda->total_steps) + 1; - } - - if (debug_flags & DEBUG_DDA) { -// serial_writestr_P(PSTR("\n{DDA:CA end_c:")); serwrite_uint32(dda->end_c >> 8); -// serial_writestr_P(PSTR(", n:")); serwrite_int32(dda->n); -// serial_writestr_P(PSTR(", md:")); serwrite_uint32(move_duration); -// serial_writestr_P(PSTR(", ssq:")); serwrite_uint32(ssq); -// serial_writestr_P(PSTR(", esq:")); serwrite_uint32(esq); -// serial_writestr_P(PSTR(", dsq:")); serwrite_int32(dsq); -// serial_writestr_P(PSTR(", msbssq:")); serwrite_uint8(msb_ssq); -// serial_writestr_P(PSTR(", msbtot:")); serwrite_uint8(msb_tot); -// serial_writestr_P(PSTR("}\n")); - sersendf_P(PSTR("\n{DDA:CA end_c:%lu, n:%ld, md:%lu, ssq:%lu, esq:%lu, dsq:%lu, msbssq:%u, msbtot:%u}\n"), dda->end_c >> 8, dda->n, move_duration, ssq, esq, dsq, msb_ssq, msb_tot); - } - - dda->accel = 1; - } - else - dda->accel = 0; + dda->c = ACCELERATION_STEEPNESS << 8; + dda->c_min = (move_duration / target->F) << 8; + dda->n = 1; + dda->ramp_state = RAMP_UP; + #else + dda->c = (move_duration / target->F) << 8; + #endif } if (debug_flags & DEBUG_DDA) @@ -424,22 +362,36 @@ void dda_step(DDA *dda) { sei(); #endif - // linear acceleration magic, courtesy of http://www.embedded.com/columns/technicalinsights/56800129?printable=true - if (dda->accel) { - if ( - ((dda->n > 0) && (dda->c > dda->end_c)) || - ((dda->n < 0) && (dda->c < dda->end_c)) - ) { - dda->c = (int32_t) dda->c - ((int32_t) (dda->c * 2) / dda->n); - dda->n += 4; - setTimer(dda->c >> 8); + #ifdef ACCELERATION_RAMPING + // - algorithm courtesy of http://www.embedded.com/columns/technicalinsights/56800129?printable=true + // - for simplicity, taking even/uneven number of steps into account dropped + // - number of steps moved is always accurate, speed might be one step off + switch (dda->ramp_state) { + case RAMP_UP: + case RAMP_MAX: + if (dda->step_no >= dda->ramp_steps) { + // RAMP_UP: time to decelerate before reaching maximum speed + // RAMP_MAX: time to decelerate + dda->ramp_state = RAMP_DOWN; + dda->n = -((int32_t)2) - dda->n; } - else if (dda->c != dda->end_c) { - dda->c = dda->end_c; - setTimer(dda->c >> 8); + if (dda->ramp_state == RAMP_MAX) + break; + case RAMP_DOWN: + dda->n += 4; + // be careful of signedness! + dda->c = (int32_t)dda->c - ((int32_t)(dda->c * 2) / dda->n); + if (dda->c <= dda->c_min) { + // maximum speed reached + dda->c = dda->c_min; + dda->ramp_state = RAMP_MAX; + dda->ramp_steps = dda->total_steps - dda->step_no; } - // else we are already at target speed + setTimer(dda->c >> 8); + break; } + dda->step_no++; + #endif if (step_option) { // we stepped, reset timeout diff --git a/mendel/dda.h b/mendel/dda.h index d775b70..9c250ed 100644 --- a/mendel/dda.h +++ b/mendel/dda.h @@ -7,6 +7,16 @@ #include "machine.h" /* + enums +*/ +// wether we accelerate, run at full speed, break down, etc. +typedef enum { + RAMP_UP, + RAMP_MAX, + RAMP_DOWN +} ramp_state_t; + +/* types */ @@ -25,18 +35,17 @@ typedef struct { TARGET endpoint; // status fields - uint8_t nullmove :1; - uint8_t live :1; - uint8_t accel :1; + uint8_t nullmove :1; + uint8_t live :1; // wait for temperature to stabilise flag uint8_t waitfor_temp :1; // directions - uint8_t x_direction :1; - uint8_t y_direction :1; - uint8_t z_direction :1; - uint8_t e_direction :1; + uint8_t x_direction :1; + uint8_t y_direction :1; + uint8_t z_direction :1; + uint8_t e_direction :1; // distances uint32_t x_delta; @@ -52,11 +61,20 @@ typedef struct { // total number of steps: set to max(x_delta, y_delta, z_delta, e_delta) uint32_t total_steps; - - // linear acceleration variables: c and end_c are 24.8 fixed point timer values, n is the tracking variable + // 24.8 fixed point timer value, initial speed uint32_t c; - uint32_t end_c; + + #ifdef ACCELERATION_RAMPING + // start of down-ramp, intitalized with total_steps / 2 + uint32_t ramp_steps; + // counts actual steps done + uint32_t step_no; + // 24.8 fixed point timer value, maximum speed + uint32_t c_min; + // tracking variable int32_t n; + ramp_state_t ramp_state; + #endif } DDA; /* diff --git a/mendel/gcode.c b/mendel/gcode.c index 5030ccb..5258ec2 100644 --- a/mendel/gcode.c +++ b/mendel/gcode.c @@ -694,8 +694,6 @@ void process_gcode_command(GCODE_COMMAND *gcmd) { serwrite_int32(movebuffer[mb_tail].endpoint.E); serial_writestr_P(PSTR(",F:")); serwrite_int32(movebuffer[mb_tail].endpoint.F); - serial_writestr_P(PSTR(",c:")); - serwrite_uint32(movebuffer[mb_tail].end_c); serial_writestr_P(PSTR("}\n")); print_queue(); diff --git a/mendel/machine.h b/mendel/machine.h index 067391e..b4d38d9 100644 --- a/mendel/machine.h +++ b/mendel/machine.h @@ -32,6 +32,14 @@ #define SEARCH_FEEDRATE_Z 50 #define SEARCH_FEEDRATE_E 50 +// acceleration and deceleration ramping +// undefine this for disabling the feature +#define ACCELERATION_RAMPING +// how fast to accelerate +// smaller values give quicker acceleration +// valid range = 1 to 8,000,000; 500,000 is a good starting point +#define ACCELERATION_STEEPNESS 500000 + // extruder settings #define TEMP_HYSTERESIS 20 #define TEMP_RESIDENCY_TIME 60 --
