FlatPack
Revision as of 12:27, 8 April 2010 by DavidCary (talk | contribs) (yet another FlatPack RepRap)
A FlatPack RepStrap or FlatPack RepRap is analogous to flat pack furniture. Some characteristics common to all three are:
  • Most of the parts are effectively 2D shapes cut out of flat materials. (Rather than arbitrary-cross section Extruded Aluminum or the thick, complicated 3D shapes that can be produced by a rapid prototype printer).
  • Since most parts are flat, they are easy to stack and pack into a relatively small box, making it easier to store and deliver.
  • It requires only simple tools to assemble.
one of the Mendel parts that is easy to make on a RepStrap, but hard to make with simple tools.
A FlatPack RepStrap -- such as PonokoRepRap or LeCorb or RapMan or CupCake or CupCakeStrap -- is designed to make the same thick, complicated 3D shapes that the RepRaps can make -- for example, all the reprapped parts needed to build a Mendel. However, a FlatPack RepStrap is unable to make parts identical to the parts that went into it. Since cutting such 2D shapes is relatively easy with *other* simple tools, however, this is no great loss -- and it makes FlatPack RepStrap a useful RepStrap pathway to start from simple tools and end up with capability of producing thick, complicated 3D shapes that can only be produced by a rapid prototype printer.
It appears that it takes fewer parts and is therefore faster to assemble an adequately stiff outer frame out of a few large flat sheets than out of a bunch of studding (allthread) and nuts and angle braces.
A FlatPack RepRap -- such as most Builders/LaserCut RepStraps designs -- is a machine that designed to both be assembled out of such parts, and then cut flat materials into parts identical to the parts that went into it. (A FlatPack RepRap does not necessarily have the ability to make thick, complicated 3D shapes like other rapid prototype printers, but that seems like a useful ability to have, and it apparently only requires swapping out the head).
A CNC Router is one machine that can cut such shapes out of flat materials.
A Laser Cutter is a very different kind of machine that can cut such shapes (Laser Cut Mendel Pulleys) out of flat materials.
... what other kinds of tools can cut such shapes out of flat materials? ...
... mention something about Flatpack PourStrap ...
