FlexShaftHolder
Revision as of 08:12, 18 October 2013 by DavidCary (talk | contribs) (move all text from Flex Shaft milling-toolhead)
FlexShaftHolder
Description | A flexy shaft holder for Mendel.
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
This page has been flagged as containing duplicate material that Flex Shaft milling-toolhead also attempts to cover.
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
FILE ID# | TYPE | DESCRIPTION | AVAILABLE FORMATS | CREATED/RESERVED BY |
drzac_mendel.stl | STL file | STL file you need to print to make a FlexShaftHolder | .stl.zip, .stl.bz2 | --Bogdan.kecman 201011140622 |
description
This Flex Shaft milling-toolhead FlexShaftHolder is A flexy shaft holder for Mendel by thingiverse user arhimed (Bogdan Kecman).
development
Developed by Bogdan Kecman after some discussion in the BitsFromBytes forum. (photo of this FlexShaftHolder mounted on a Mendel)
design files
This page has been flagged as containing duplicate material that FlexShaftHolder also attempts to cover.
description
TODO (missing).
This Dremel Holder Flex Shaft milling-toolhead ...
other milling toolheads for different mills and cartesian bots.
history
TODO: who designed this head, when, where can it be found, what mill can be used, what kind of milling does it work for?
Getting Started
Please use the Example page.
