FlexShaftHolder
Revision as of 07:29, 18 October 2013 by DavidCary (talk | contribs) (post-merge cleanup)
FlexShaftHolder
A flexy shaft holder for Mendel.
unknown
This is 600 pixels wide, and on the left.
drzac_mendel.stl STL file STL file you need to print to make a FlexShaftHolder .stl.zip, .stl.bz2 --Bogdan.kecman 201011140622
description
This Flex Shaft milling-toolhead FlexShaftHolder is A flexy shaft holder for Mendel by thingiverse user arhimed (Bogdan Kecman).
This Dremel Holder Flex Shaft milling-toolhead ...
TODO: what mill can be used, what kind of milling does it work for?
development
Developed by Bogdan Kecman after some discussion in the BitsFromBytes forum. (photo of this FlexShaftHolder mounted on a Mendel)
design files
