FoldaRap Buyers Guide
This project was for myself, as I need/want a RepRap that's easy to carry around and for the challenge of making a folding 3d-printer. But I believe in open-source and sharing and all the revolution behind that. Thus I try to well document it, in case others want to make one; to acknowledge all the things we own to those who went before, and to encourage those who come after to do the same.
On a more long-term view, I didn't planned to create a company out of it, I hoped to see it grow on itself in the wild, just by indicating how to source it, because I have more fun in designing stuff than marketing it. Nonetheless I may try to sell few beta-test kits (bulk ordering is good for prices), eventually via a crowdfunding campaign or by request, maybe with the help of my hackerspace. Just for the experience of it and to say I can push a project to that point :D (edit : Done !, again, and it finally gave birth to Open Edge)
(almost all the projects I did during my design studies could have done something, but I never found the time for that and they ended sleeping in their drawing books which is sad; while now I have taken the habit to publish everything, even an old one sometimes).
"Ideas are like living things and breed happily in an open-source context" as I like to think ^^ (on the same spirit I like this comment from User:Adrianbowyer)
Bill Of Material (BOM)
Total end cost for 1 machine : ~500-600€ when you include all taxes and shipping costs. I suggest you to make group orders with friends and always try to source locally, or now for almost the same price I can make a kit for you.
Hardware
5 20x20mm beam 6mm slot 200mm - Motedis or see Aluminium profile 6 20x20mm beam 6mm slot 300mm 54 M4 T-nut for 6mm slot - Motedis
54 m4x8 round head bolt - Fix'n Vis Round Head Bolt 4 m5 nylon nut / Z-rod (4) [1] 3 m3 nylock nut / bed leveling (3) nylock nut 15 m3 nut / hinges (2), bed (3), Y-belt-clamp (2), extruder (2), plug (2), psu (4) - Fix'n Vis Nuts 14 m3x8 bolt / Z-motors (4), Y-motor (2), psu (2), male plug (2), board-mount (2), hotend (2) - Fix'n Vis Bolts 8 m3x10 bolt / hotend (4), y-belt-clamp (2), extruder (2) 1 m3x16 bolt / extruder (1) 4 m3x20 bolt / hinges (2), Y-idler (1), extruder (1) 5 m3x25 bolt / hotend-holder (2), fan-holder (1), (extruder 1), z-endstop (1) 4 m3x30 bolt / x-slider (4) 3 m3x30 countersunk bolt / bed (3) 2 m3x35 / extruder (2) 2 230mm threaded rod m5 - Fix'n Vis
2 extruder spring - RS751483 or see Springs 3 bed spring - RS 751455 or RS 751607 1m spiral wrapping band for tidying the wires - RS227874 7 6,35mm ferule - Radiospare to crimp the cable for the plug and the switch
2 5mm to 5mm flexible coupling 3 linear bearing, LM6UU or if you can Igus RJMP-01-06 - See Bearing 2 300mm smooth rod 6mm - (can be salvaged from usual scanners and printers) or see Smooth rod 5 603zz bearings / X-slider (2), Y-idler (2), extruder-idler (1) - See Bearing 1 250mm T2.5 belt 5mm wide - RepRapWorld or see Belts_and_Pulleys 1 600mm T2.5 belt 5-6mm wide 2 T2.5 pulleys - Belts_and_Pulleys 330mm PTFE Tubing for bowden extruder (2mm inner diam. and 3mm outer) - See Bowden 2 Pneumatic fittings for 3mm tubing, with M5 thread - See Bowden or emakershop / I'm using the MA12-03-M5 but others can work 1 direct drive gear - Maritime-models (see Drive-gear) 1 roll of kapton - See Kapton Tape#Vendors 20 zip-ties
Electronic
5 nema14 stepper motors - [2] 3 miniature microswitch endstop 20mm - [3] 1 standard male plug IEC C13 C14 - RS 5392045 1 standard female cable - EU/C13 - UK RS6266739 / US RS7316163 1 big blue switch - RS 5287858 1 RepRappro Hotend - emaker 1 40x40mm heatsink - RS 6744769 to make a more compact hotend 1-2 small fan (40 x 40 x 10 mm), for the hotend (can be bought with one) and the extruder motor - RepRapWorld or see Fan 1 100k thermistors - Mouser 1m of 18AWG wire (200mm red, 200m black, 150mm green) for the switch/plug/psu - Read also WiresAndConnectors 10m of 26AWG (3.6m red, 3.2m green, 2.0m blue) for the sensors and fans
1 Minitronic board [4] 1 USB cable A to B [5] 1 12V power supply : 5A (cold bed) or 10A or [6] (for heated bed)
or
1 Azteeg_X1 board - [7] + 4 drivers 1 usb to mini-usb cable - [8] 1 12V power supply : 10A
or
1 Rumba + 6 stepper drivers 1 usb to mini-usb cable 1 12V power supply : 20A (RS 7066316 100*150*35mm)
Heated-Bed
For the aluminium heated bed add :
1 aluminium bed plate (4mm thick)
1 kapton film heater - Open Edge
or
1 100k thermistors - Mouser 2 ferule 0,5mm² 1 peltier element 12708 (40x40mm is enough) - ebay
Laser cut parts
See the github repo and eMakerShop, you can have them from Ponoko or ThingiBOX too
The bed can also be made of acrylic in case of a non-heated bed.
Printed parts (total : 21)
See also the github repo
Other
Padded suitcase
- EU : http://www.abylon.fr/145-valise-olycase-500.html
- FR : http://www.vexi.fr/valises-plastique/etanches
- US : http://www.amazon.com/Nanuk-Case-Cubed-Foam-Black/dp/B003JH7ZU4/
Maintenance
- 0.3mm drill bit [9] (or 0.5mm, depending of the nozzle)
How to replicate a FoldaRap !
If you can print your own parts it will take ~400gr and 22h at ~30% infill.
Material
The parts that act as sliders on the aluminium extrusions (x-slider, z-sliders) will work better if printed in PLA or other low friction plastic. You can print the other parts in ABS or what you want.
Recommended settings
- Nozzle diameter of reference : 0,5 mm
- Layer height : 0,25mm
- Infill : 30-35% hexagonal/honeycomb
- It is advised to have a well calibrated machine (+/- 0.05mm on measured parts) : http://forums.reprap.org/read.php?282,159683
I recorded this little video where I'm playing with some parts freshly printed, to show what to expect about the tight tolerances.
<videoflash>rRXyc5I8yfo</videoflash>
The part that slide under it's own weight (16gr) have been slided back and forth a few time.
Fully assembled machines
Not yet.
Partial or complete kit
Webshops
- Paoparts (out of stock)
Printed parts
- Spares 3d on eMakerShop (1.1)
- 3d Andy on eMakerShop (1.1 + geared extruder) (sold out)
Misc.
- A draft BOM is on Kitbom
- My spreadsheet is roughly the same as the following lists but a little outdated.
FoldaRapMendel Bom
1 underplate
6 300 mm 6 400 mm
50 M4x8 8 M4x12 (hinges) 2 M4x16 (hinges)
