FoldaRap power-supplies
Revision as of 20:18, 27 December 2014 by Glenn (talk | contribs) (+ Category:Foldable RepRap)
>>Back to Y-motor or Underplate section
120W "led" (FoldaRap 1.1 and 2)
120W ledproject power supply.jpgFoldaRap underplate psu-120w.jpgFoldaRap2 underplate psu-120w.jpg
Low Profile 120W (FoldaRap 1.1 and 2)
The 120W power supply is a generic power supply, but with a low profile (34mm).
  • Power supply to male plug : 1 green wire 18WG of 15cm, one end with ferule, the other end just stripped
  • Switch to power supply : 1 red and 1 black wire 18AWG of 15cm, one end with ferule, the other end just stripped
  • Switch to male plug : 1 red wire of 6cm, 1 black of 9cm 18AWG, both ends with ferule
  • board to power supply : 8 cm red/black wires
Low Profile 240W (FoldaRap 1)
The 240W power supply is a TXH240 [1]. It was replaced by a 120W power supply after we realized the first one was a little overkill (and costly, the 120W is ten times cheaper).
  • Power supply to male plug : 1 green wire 18WG of 35cm, one end with ferule, the other end just stripped
  • Switch to power supply : 1 red and 1 black wire 18AWG of 35cm, one end with ferule, the other end just stripped
<videoflash>_tXWGjJq0zM|320|240</videoflash>
  • Bolt the PSU on the plate, with a washer between the psu and the plate
