Folgertech Prusa i3 2020
Revision as of 04:09, 18 January 2016 by Therippa (talk | contribs) (Created page with "# Folgertech Prusa i3 2020 Welcome to the RepRap wiki page! This will serve as a one-stop knowledge base for everything we've worked out on the RepRap Folgertech 2020 Forum ...")
  1. Folgertech Prusa i3 2020
Welcome to the RepRap wiki page! This will serve as a one-stop knowledge base for everything we've worked out on the RepRap Folgertech 2020 Forum Thread (the wiki software won't let me make external links because it doesn't trust me) and various other places.
  • RepRap wiki admins and others - this is a work in progress, please don't delete :)*
    1. Topics
  • [Build Tip & Tricks](#buildtips)
  • [Folgertech Build Manual Erros & Errata](#builderrors)
  • [Marlin Firmware Upgrade](#marlin)
  • [Basic Upgrades](#basic)
- Raising the Z-axis motors - Moving the X-endstop to the left, and why you should do it - Leadscrews - LCD Screens - Adjustable belt tensioners - Better Hotends
  • [Advanced Upgrades](#advanced)
- V-slot Y-axis - V-slot X-axis
  • [All About Autolevel](#autolevel)
- The basics - Easy optocoupler circuit - Options: Servo, BLTouch, Inductive
    1. <a name="buildtips"></a>Build Tips & Tricks
    1. <a name="builderrors"></a>Folgertech Build Manual Errors & Errata
  • Disclaimer for bad boards, wrong screws, etc*
  • We need to address the X-endstop problems here, and probably recommend putting it on the left*
    1. <a name="marlin"></a>Marlin Firmware Upgrade
The version of Marlin that Folgertech has put together is pretty outdated. It does not include a lot of new features (like autolevel) and bug fixes. It is recommended that you upgrade to this version (the wiki software won't let me make external links because it doesn't trust me), which is the latest release version of Marlin with the Folgertech configuration settings merged in. Please note that you will need to make some changes to your printer to get this working correctly/properly (unless you moved your X-endstop to the left side):
  • Move your X-endstop connection on your RAMPS board one set of pins over, to position 6
  • In your host software, change X-endstop setting to MAX
    1. <a name="basic"></a>Basic Upgrades
      1. Raising the Z-axis motors
This is a simple print upgrade that will recover some height lost by the Z-axis motors being mounted directly on the top rail. Print these raisers (the wiki software won't let me make external links because it doesn't trust me) to gain about 40mm of print height.
    1. <a name="advanced"></a>Advanced Upgrades
    1. <a name="autolevel"></a>All About Autolevel
