Full Graphic Smart Controller Hacks
Revision as of 01:01, 12 November 2014 by Silly105 (talk | contribs) (Created page with "When using the RepRapDiscount Full Graphic Smart Controller, there are some possible hacks to modify the display. = Display of just one extruder = (''THIS APPLIES TO MARL...")
(THIS APPLIES TO MARLIN V1.0.0-RC2! Other versions may require a different approach.)
To remove the second and third extruder display from the info screen, two files have to be modified:
DOGMbitmaps.h
In this file some lines have to be changed in the variables "status_screen0_bmp" and "status_screen1_bmp":
const unsigned char status_screen0_bmp[] PROGMEM = { //AVR-GCC, WinAVR
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xE0,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xE0,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x63,0x0C,0x60,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x47,0x0E,0x20,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4F,0x0F,0x20,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5F,0x0F,0xA0,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5E,0x07,0xA0,
0x7F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x04,0x00,0x40,0x60,0x20, // changed
0xFB,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x82,0x00,0x40,0xF0,0x20, // changed
0xF3,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x82,0x00,0x40,0xF0,0x20, // changed
0xEB,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x04,0x00,0x40,0x60,0x20, // changed
0x7B,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x08,0x00,0x5E,0x07,0xA0, // changed
0x7B,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x04,0x10,0x00,0x5F,0x0F,0xA0, // changed
0xFB,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x04,0x10,0x00,0x4F,0x0F,0x20, // changed
0xFB,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x08,0x00,0x47,0x0E,0x20, // changed
0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x04,0x00,0x63,0x0C,0x60, // changed
0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xE0, // changed
0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0x80,0x7F,0xFF,0xE0, // changed
0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0x80,0x00,0x00,0x00  // changed
const unsigned char status_screen1_bmp[] PROGMEM = { //AVR-GCC, WinAVR
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x61,0xF8,0x60,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0xF8,0x20,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0xF0,0x20,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x60,0x20,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x58,0x01,0xA0,
0x7F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x04,0x00,0x5C,0x63,0xA0, // changed
0xFB,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x82,0x00,0x5E,0xF7,0xA0, // changed
0xF3,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x82,0x00,0x5E,0xF7,0xA0, // changed
0xEB,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x04,0x00,0x5C,0x63,0xA0, // changed
0x7B,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x08,0x00,0x58,0x01,0xA0, // changed
0x7B,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x04,0x10,0x00,0x40,0x60,0x20, // changed
0xFB,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x04,0x10,0x00,0x40,0xF0,0x20, // changed
0xFB,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x08,0x00,0x41,0xF8,0x20, // changed
0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x04,0x00,0x61,0xF8,0x60, // changed
dogm_lcd_implementation.h
In this file, you first have to find the lines
u8g.setPrintPos(31,27);
u8g.print("---");
replace them by
u8g.print("   ");
Now find the lines
u8g.setPrintPos(55,27);
u8g.print("---");
replace them by
u8g.print("   ");
That's it, no more unessesary exdruders on that info screen.
Modified info screen
