FuseBox
Description | An affordable aluminum-framed CoreXY printer.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
FuseBox is a low-cost CoreXY 3D printer that uses an aluminum extrusion frame.
Goal
To design an affordable and accessible 3D printer using CoreXY kinematics that offers high speed and quality.
Features
- Aluminum structure based on Misumi 1515 extrusions and printed brackets
- Uses a stacked variant of CoreXY that eliminates belt crossing
- Total materials cost under $350
- 210x175x200mm build area (200x200x200 for heated bed versions)
- Capable of 0.05mm layer height and 150+ mm/s printing
- Mostly RepRappable parts and easily hackable/upgradeable
- Relatively low amount of filament needed for plastic components
- Provision for direct and Bowden extruder setups (currently only Bowden is supported in latest version)
- Low moving mass—all motors stationary except extruder motor in direct-drive version
- Portable—all hardware and electronics (except for filament spool) are integrated within the frame
- No specialized tools or equipment necessary for assembly (accessible)
Bill of Materials
Printed Parts
A zip file containing all the printed parts can be found here: File:FuseBox Printed Parts.zip
Other Parts
Item | Quantity | Note | |
1515 Extrusion 390mm | 4 | ||
1515 Extrusion 330mm | 2 | ||
1515 Extrusion 345mm | 4 | ||
1515 Extrusion 300mm | 2 | ||
1515 Extrusion 250mm | 2 | ||
1515 Extrusion 152mm | 1 | ||
1515 Extrusion 386mm | 2 | Optional but highly recommended for greater rigidity | |
M3x6mm Bolt | 150 | Rough estimate, will update with accurate numbers | |
M3x10mm Bolt | 6 | ||
M3x25mm Bolt | 4 | ||
M3 Nut | 150 | Rough estimate, will update with accurate numbers | |
M5x25mm Bolt | 6 | ||
M5 Locknut | 6 | ||
625 Bearing | 9 | ||
250mm M8 Threaded Rod | 1 | ||
300mm M8 Smooth Rod | 6 | ||
LM8UU Linear Bearing | 4 | ||
LM8LUU Linear Bearing | 4 | ||
5mm to 8mm Flex Coupler | 1 | ||
2mm Pitch GT2 Belt 3m | 1 | ||
20 Tooth GT2 Pulley | 2 | ||
Bed Leveling Springs | 4 | ||
RAMPS 1.4 | 1 | ||
Arduino Mega | 1 | ||
NEMA-17 Stepper Motors | 4 | Tested with 76 oz-in steppers | |
12V LED Power Supply | 1 | Tested with a 30A supply, 20A should work | |
40mm 12V Fan | 2 | ||
MK8 Drive Gear | 1 | ||
Medium Binder Clip | 2 | Remove handles to use as extruder idler tensioners | |
E3D Lite6 Hotend | 1 | ||
8"x10"x 0.125" Glass Sheet | 1 | Used as a cheap and rigid PLA printbed; heated bed available | |
PCB Heatbed | 1 | ||
Mechanical Endstop | 3 | ||
Stick-on Furniture Feet | 4 | Optional |
Development
Version 1.0
Initial variant. Uses a non-intersecting CoreXY design to eliminate belt crossing issues.
Issues
- Z-axis issues—slight wobble and linear bearing binding
- Slight rigidity issues caused by weak corner joints
- Extruder grip issues leading to inconsistent extrusion
- Untidy wiring
Todo
- Endstop integration (possibly with inductive z-probe)
- Cooling fan addition to improve bridging and top speed for small parts
- Bowden option for lower moving mass (will retain direct extruder for flexible materials)
- Diagonal aluminum braces on sides
- Reduce clearances for additional build area
Version 1.1
Changes'
- New compact extruder design with more solid hot end mount and fan duct addition
- Bowden extruder carriage designed; cold end still in development
- 608 bearing idler replaced by a 625 idler
- XY-gantry made more compact, resulting in ~18mm increase in maximum z-axis height
- Z axis changes: bar spacing reduced, additional reinforcement for z-nut crosspiece
Issues
- Slight z-wobble
- Rigidity
- 625 Idler breakage problem
Todo
- Additional bracing
1.1B
Uses a bowden extruder and replaces Aluhotend V6 with an E3D-Lite6. New idler design improves strength and extrusion consistency.
Version 1.2
Changes
- New Y Bar attachments using 1 bolt each
- Integrates bowden extruder and print fan
- Larger corner braces
- Cross braces on sides
- Added option for 30mm hotend cooling fan
- 10mm additional x-axis travel
Issues
- Minor bed shake (worse at higher z-heights)
Version 1.2h
Currently in process of building and testing
Changes
- Heated bed support
- Wider z-rod spacing to accommodate heated bed
- Additional z-axis bracing
- Adjustable z-endstop
- Additional y-axis travel
- Replaced corner brackets with flat plates on lower x-axis
Todo
- Inductive autolevel probe?
Videos
<videoflash>I3xibPxbO2s</videoflash> <videoflash>qRtPtuInjQw</videoflash> <videoflash>7nx2nsnKOrY</videoflash>
