G-code
- 1 Introduction
- 2 RepRap G Code Fields
- 3 Individual commands
- 3.1 Checking
- 3.2 Buffered G Commands
- 3.3 Unbuffered G commands
- 3.4 Unbuffered M and T commands
- 3.4.1 M0: Stop
- 3.4.2 M104: Set Extruder Temperature
- 3.4.3 M105: Get Extruder Temperature
- 3.4.4 M106: Fan On
- 3.4.5 M107: Fan Off
- 3.4.6 M108: Set Extruder Speed
- 3.4.7 M109: Set Extruder Temperature
- 3.4.8 M110: Set Current Line Number
- 3.4.9 M111: Set Debug Level
- 3.4.10 M112: Emergency Stop
- 3.4.11 M113: Set Extruder PWM
- 3.4.12 M114: Get Current Position
- 3.4.13 M115: Set Build Base Temperature (Fast)
- 3.4.14 M116: Wait
- 3.4.15 M126: Open Valve
- 3.4.16 M127: Close Valve
- 3.4.17 T: Select Tool
- 3.5 RepRap G-Code Summary Table
Introduction
This page describes the G Codes that the RepRap firmware uses and how they work.
The list of what can be done is extensible. But check this page first, and add your extension here first before you implement it.
A typical piece of GCode as sent to a RepRap machine might look like this:
N3 T0 *86 N4 G92 E0 *102 N5 G28 *13 N6 G1 F1500.0 *117 N7 G1 X2.0 Y2.0 F3000.0 *71 N8 G1 X3.0 Y3.0 *39
This section explains the letter-preceded fields. The numbers in the fields are represented by nnn. Numbers can be integers, or can contain a decimal point, depending on context. For example an X coordinate can be integer (X175) or fractional (X17.62), whereas trying to select extruder number 2.76 would make no sense.
Letter | Meaning |
Gnnn | Standard GCode command, such as move to a point |
Mnnn | RepRap-defined command, such as turn on a cooling fan |
Tnnn | Select tool nnn. In RepRap, tools are extruders |
Snnn | Command parameter, such as the voltage to send to a motor |
Pnnn | Command parameter, such as a time in milliseconds |
Xnnn | An X coordinate, usually to move to |
Ynnn | A Y coordinate, usually to move to |
Znnn | A Z coordinate, usually to move to |
Innn | Parameter - not currently used |
Jnnn | Parameter - not currently used |
Fnnn | Feedrate in mm per minute. |
Rnnn | Parameter - not currently used |
Qnnn | Parameter - not currently used |
Ennn | Length of extrudate in mm. This is exactly like X, Y and Z, but for the length of filament to extrude. |
Nnnn | Line number. Used to request repeat transmission in the case of communications errors. |
*nnn | Checksum. Used to check for communications errors. |
Individual commands
Checking
N and *
These are the line number and the checksum. The RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
The checksum, cs, for a GCode, cmd, (including its line number) is computed as follows:
int cs = 0; for(int i = 0; i < cmd.length(); i++) cs = cs ^ cmd.charAt(i); cs &= 0xff; // Defensive programming...
Buffered G Commands
The RepRap firmware stores these commands in a ring buffer internally for execution. This means that there is no (appreciable) delay while a command is acknowledged and the next transmitted. In turn, this means that sequences of line segments can be plotted without a dwell between one and the next. As soon as one of these buffered commands is received it is acknowledged and stored locally. If the local buffer is full, then the acknowledgment is delayed until space for storage in the buffer is available. This is how flow control is achieved.
G0: Rapid move
Example: G0 X12
In this case move rapidly to X = 12 mm. In fact, the RepRap firmware uses exactly the same code for rapid as it uses for controlled moves (see G1 below), as - for the RepRap machine - this is just as efficient as not doing so. (The distinction comes from some old machine tools that used to move faster if the axes were not driven in a straight line. For them G0 allowed any movement in space to get to the destination as fast as possible.)
G1: Controlled move
Example: G1 X90.6 Y13.8 E22.4
Go in a straight line from the current (X, Y) point to the point (90.6, 13.8), extruding material as the move happens from the current extruded length to a length of 22.4 mm.
RepRap does subtle things with feedrates. Thus:
G1 F1500 G1 X90.6 Y13.8 E22.4
Will set a feedrate of 1500 mm/minute, then do the move described above at that feedrate. But
G1 F1500 G1 X90.6 Y13.8 E22.4 F3000
Will set a feedrate of 1500 mm/minute, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X, Y movement so everything stays synchronized.
RepRap thus treats feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over accelerations and decelerations in a way that ensures that everything moves together and the right volume of material is extruded at all points.
The first example shows how to get a constant-speed movement. The second how to accelerate or decelerate. Thus
G1 F1500 G1 X90.6 Y13.8 E22.4 F3000 G1 X80 Y20 E36 F1500
Will do the first movement accelerating as before, and the second decelerating from 3000 mm/minute back to 1500 mm/minute.
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G1 to send an E value that is less than the currently extruded length.
G28: Move to Origin
Example: G28
This causes the RepRap machine to move back to its X, Y and Z zero endstops. It does so accelerating, so as to get there fast. But when it arrives it backs off by 1 mm in each direction slowly, then moves back slowly to the stop. This ensures more accurate positioning.
If you add coordinates, then just the axes with coordinates specified will be zeroed. Thus
G28 X0 Y72.3
will zero the X and Y axes, but not Z. The actual coordinate values are ignored.
The following commands are not buffered. When one is received it is stored, but it is not acknowledged to the host until the buffer is exhausted and then the command has been executed. Thus the host will pause at one of these commands until it has been done. Short pauses between these commands and any that might follow them do not affect the performance of the machine.
G4: Dwell
Example: G4 P200
G20: Set Units to Inches
Example: G20
G21: Set Units to Millimeters
Example: G21
Example: G90
Example: G91
G92: Set Position
Example: G92 X10 E90
M0: Stop
Example: M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M112.
Example: M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). See also M109.
Example: M105
Request the temperature of the current extruder and the build base in degrees Celsius. The temperatures are returned to the host computer.
M106: Fan On
Example: M106
Turn on the cooling fan (if any).
M107: Fan Off
Example: M107
Turn off the cooling fan (if any).
Sets speed of extruder motor. (Deprecated in current firmware, see M113)
Example: M109 S190
Set the temperature of the current extruder to 190oC and wait for it to reach that value before sending an acknowledgment to the host. In fact the RepRap firmware waits a while after the temperature has been reached for the extruder to stabilise - typically about 40 seconds. This can be changed by a parameter in the firmware configuration file when the firmware is compiled. See also M104 and M116.
Example: N123 M110
Example: M111 S6
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2)
Example: M112
Any moves in progress are immediately terminated, then RepRap shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M0.
Example: M113
M113 S0.7
Example: M114
Example: M115 S55
Set the temperature of the build base to 55oC and return control to the host immediately (i.e. before that temperature has been reached by the base).
M116: Wait
Example: M116
M126: Open Valve
Example: M126 P500
M127: Close Valve
Example: M127 P400
T: Select Tool
Example: T1
Select extruder number 1 to build with. Extruder numbering starts at 0.
Command | Class | Buffered? | Parameters | Action |
G0 | G | Y | Xnnn Ynnn Znnn Ennn Fnnn | Rapid move to position specified by parameters |
G1 | G | Y | Xnnn Ynnn Znnn Ennn Fnnn | Controlled move to position specified by parameters |
G4 | G | N | Pnnn | Delay for a period of nnn milliseconds |
G20 | G | N | none | Set distance units for motion and position values to inches |
G21 | G | N | none | Set distance units for motion and position values to millimeters (default) |
G28 | G | Y | Xnnn Ynnn Znnn | Move to origin (on specified axes only, if X/Y/Z parameters are present) |
G90 | G | N | none | Set absolute positioning (for subsequent motion commands) (default) |
G91 | G | N | none | Set relative positioning (for subsequent motion commands) |
G92 | G | N | Xnnn Ynnn Znnn | Define current absolute position |
M0 | M | N | none | Stop (after completing any buffered commands) |
M104 | M | N | Snnn | Set current extruder temperature (in Celsius) to value of parameter, and return |
M105 | M | N | none | Request current extruder and base temperatures (in Celsius) |
M106 | M | N | none | Set cooling fan off |
M107 | M | N | none | Set cooling fan on |
M108 | M | N | Snnn | Set extruder motor speed (DEPRECATED) |
M109 | M | N | Snnn | Set extruder temperature (in Celsius), and wait for it |
M110 | M | N | none | Set current line number to Nxxx value preceeding command |
M111 | M | N | Snnn | Set debug level bitfield to value of parameter (default 6) |
M112 | M | N | none | Emergency stop (stop immediately, discarding any buffered commands) |
M113 | M | N | Snnn | Set Extruder PWM (to value defined by pot, or to parameter value if present) |
M114 | M | N | none | Get Current Position (return current X, Y, Z and E values) |
M115 | M | N | Snnn | Set Build Base temperature (in Celsius) to value of parameter, and return |
M116 | M | N | none | Wait for all temperature and slow-changing variables to reach set values |
M126 | M | N | Pnnn | Open Valve and wait for nnn milliseconds for it to open |
M127 | M | N | Pnnn | Close Valve and wait for nnn milliseconds for it to close |
Tn | T | N | none | Select Tool n (T0 selects tool 0) (default extruder is 0) |
