G-code
Revision as of 03:58, 28 June 2016 by Dc42 (talk | contribs) (M605: Set dual x-carriage movement mode)
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications, too. See also on Wikipedia's G-code article.
There are a few different ways to prepare GCode for a printer. One is to use a slicer like Slic3r, Skeinforge or Cura. These programs take a CAD model, slice it into layers, and output the GCode required for each layer. Slicers are the easiest way to go from a 3D model to a printed part, but the user sacrifices some flexibility when using them. Another option for GCode generation is to use a lower level library like mecode. Libraries like mecode give you precise control over the tool path, and thus are useful if you have a complex print that is not suitable for naive slicing. The final option is to just write the GCode yourself. This may be the best choice if you just need to run a few test lines while calibrating your printer.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years. But this is the master page for RepRap. Nowhere in here should the same code be used for two different things; there are always more numbers to use... The rule is: add your new code here, then implement it.
But human nature being what it is, things aren't always done that way, so some multiple uses of the same code exist. The rule is that later appearances by them on this page than the original use of a code are deprecated and should be changed, unless there is a good technical reason (like the general G-Code standard) why a later instance should be prefered. Note that the key date is appearance here, not date of implementation.
Introduction
N3 T0*57
N4 G92 E0*67
N5 G28*22
N6 G1 F1500.0*82
N7 G1 X2.0 Y2.0 F3000.0*85
N8 G1 X3.0 Y3.0*33
Gcode can also be stored in files on SD cards. A file containing RepRap Gcode usually has the extension .g, .gco or .gcode. Files for BFB/RapMan have the extension .bfb. Gcode stored in file or produced by a slicer might look like this:
G92 E0
G28
G1 F1500
G1 X2.0 Y2.0 F3000
G1 X3.0 Y3.0
Slicers will (optionally?) add GCode scripts to the beginning and end of their output file to perform specified actions before and/or after a print such as z-probing the build-area, heating/cooling the bed and hotend, performing ooze free "nozzle wipe" startup routine, switching system power on/off, and even "ejecting" parts. More info on the Start GCode routines and End GCode routines pages.
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
Partial ??? ??? ??? ??? Experimental depreciated ??? ???
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
??? No ??? Yes ??? ??? automatic ??? ???
Here means:
{{yes}}
The Gcode is fully supported by the firmware.
{{partial}} or {{experimental}}
There is some support for the Gcode. Often it is required to check out the source code branch for the firmware (usually stored in a different branch) or to flip configuration switches on the mainboard.
automatic
The firmware handles this Gcode automatically, so there's no need to send the command. An example is power supply on/off Gcode (M80/M81) in the Teacup firmware.
It is unknown if the firmware supports this Gcode. You may want to test this yourself before using it in production.
{{no}}
The firmware does not support this Gcode.
depreciated
The firmware depreciated this Gcode. The firmware author(s) should amend the depreciated Gcode on this page with workarounds (if needed) and the last supported firmware version that will accept this Gcode.
Fields
A RepRap Gcode is a list of fields that are separated by white spaces or line breaks. A field can be interpreted as a command, parameter, or for any other special purpose. It consists of one letter directly followed by a number, or can be only a stand-alone letter (Flag). The letter gives information about the meaning of the field (see the list below in this section). Numbers can be integers (128) or fractional numbers (12.42), depending on context. For example, an X coordinate can take integers (X175) or fractionals (X17.62), but selecting extruder number 2.76 would make no sense. In this description, the numbers in the fields are represented by nnn as a placeholder.
In RepRapFirmware, some parameters can be followed by more than one number, with colon used to separate them. Typically this is used to specify extruder parameters, with one value provided per extruder. If only one value is provided where a value is needed for each extruder, then that value is applied to all extruders.
Letter Meaning
Tnnn Select tool nnn. In RepRap, a tool is typically associated with a nozzle, which may be fed by one or more extruders.
Hnnn Parameter - used for heater number in PID Tuning
Ennn Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to consume.
Comments
Gcode comments begin at a semicolon, and end at the end of the line:
N3 T0*57 ; This is a comment
N4 G92 E0*67
; So is this
N5 G28*22
Special fields
N: Line number
Yes Yes ??? ??? ??? Yes ??? ??? ???
 ? Yes ??? Yes Yes Yes Yes ??? ???
Example: N123
If checking is supported, the RepRap firmware expects line numbers to increase by 1 each line, and if that doesn't happen it is flagged as an error. But you can reset the count using M110 (see below).
*: Checksum
 ? Yes ??? Yes ??? ??? Yes ??? ???
Example: *71
If checking is supported, the RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
Checking
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
int cs = 0;
   cs = cs ^ cmd[i];
Buffering
Yes Yes ??? ??? ??? ??? ??? ??? ???
Yes ??? ??? Yes ??? ??? Yes ??? ???
RepRapFirmware also implements an internal queue to ensure that certain codes (like M106) are executed in the right order and not when the last move has been added to the look-ahead queue. This feature is not available in RepRapFirmware-dc42.
G-commands
G0 & G1: Move
Yes Yes ??? ??? ??? Yes Yes ??? ???
Yes Yes Yes Yes Yes Yes Yes ??? Yes
  • G0 : Rapid linear Move
  • G1 : Linear Move
Usage
Parameters
Not all parameters need to be used, but at least one has to be used
Snnn Flag to check if an endstop was hit (S1 to check, S0 to ignore, S2 see note, default is S0)1
Examples
G0 X12 (move to 12mm on the X axis)
G0 F1500 (Set the feedrate to 1500mm/minute)
G1 X90.6 Y13.8 E22.4 (Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material)
1. G1 F1500
2. G1 X50 Y25.3 E22.4
In the above example, we set the feedrate to 1500mm/minute on line 1, then move to 50mm on the X axis and 25.3mm on the Y axis while extruding 22.4mm of filament between the two points.
1. G1 F1500
2. G1 X50 Y25.3 E22.4 F3000
However, in the above example, we set a feedrate of 1500 mm/minute on line 1, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X and Y movement, so everything stays synchronized.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in such a way that ensures that everything moves smoothly together, and the right volume of material is extruded at all points.3
Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S parameter in this way, as damage may occur if you assume incorrectly. In RepRapFirmware, using the S1 or S2 parameter on a delta printer causes the XYZ parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1.
4RepRapFirmware provides an additional 'R1' parameter to tell the machine to go back to the coordinates a print was previously paused at. If this parameter is used and the code contains axis letters, an offset will be added to the pause coordinates (e.g. G1 R1 Z5).
G2 & G3: Controlled Arc Move
Yes1 No ??? ??? ??? Yes Yes ??? ???
Yes Yes No No Yes Experimental No ??? ???
Usage
Parameters
Examples
G2 X90.6 Y13.8 I5 J10 E22.4 (Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
G3 X90.6 Y13.8 I5 J10 E22.4 (Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
Notes
1In Marlin Firmware not implemented for DELTA and SCARA printers.
G4: Dwell
Parameters
Pnnn Time to wait, in milliseconds
Snnn Time to wait, in seconds (Only on Marlin and Smoothie)
Example
G4 P200
On Marlin and Smoothie, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
G10: Tool Offset
No Yes ??? ??? ??? No No ??? ???
??? No No No Yes ??? No ??? ???
Usage
G10 Pnnn Xnnn Ynnn Znnn Rnnn Snnn1
Parameters
Pnnn Tool number
Xnnn X offset
Ynnn Y offset
Znnn Z offset2
Rnnn Standby temperature(s)
Snnn Active temperature(s)
Examples
G10 P2 X17.8 Y-19.3 Z0.0 (sets the offset for tool (or in older implementations extrude head) 2 to the X, Y, and Z values specified)
G10 P1 R140 S205 (set standby and active temperatures3 for tool 1)
Notes
1Marlin uses G10/G11 for executing a retraction/unretraction move. The RepRapPro version of Marlin supports G10 for tool offset. Smoothie uses G10 for retract and G10 Ln for setting workspace coordinates.
2It's usually a bad idea to put a non-zero Z value in as well unless the tools are loaded and unloaded by some sort of tool changer. When all the tools are in the machine at once they should all be set to the same Z height.
4The NIST G-code standard mentions an additional L parameter, which is ignored (except in smoothie). This command is subject to discussion.
G10: Retract
Yes dc42,ch ??? ??? ??? Yes: 0.92 Yes ??? ???
??? No No No No ??? No ??? ???
Parameters
Snnn retract length (S1 = long retract, S0 = short retract = default) (Repetier only)
Example
G10
Retracts filament according to settings of M207 (Marlin, RepRapFirmware) or according to the S value (Repetier).
RepRapFirmware recognizes G10 as a command to set tool offsets and/or temperatures if the P parameter is present, and as a retraction command if it is absent.
G11: Unretract
Parameters
Example
G11
Unretracts/recovers filament according to settings of M208 (Marlin, RepRapFirmware) or according to the S value (Repetier).
G17..19: Plane Selection (CNC specific)
??? No ??? ??? ??? ??? ??? ??? ???
Yes ??? ??? ??? Yes ??? ??? ??? ???
  • G17 : XY (default)
  • G18 : ZX
  • G19 : YZ
G20: Set Units to Inches
No Yes ??? ??? ??? Yes Yes ??? ???
Yes Yes No Yes Yes ??? Yes ??? ???
Example
G20
G21: Set Units to Millimeters
Yes Yes Yes Yes Yes Yes Yes ??? ???
Example
G21
G22 & G23: Firmware controlled Retract/Precharge
No No ??? ??? ??? No No ??? ???
Usage
G22 ; Retract
G23 ; Unretract/Precharge
Relying on machine's firmware to execute extrusion retract/precharge move, instead of having slicer generating to E axis G1 movement. The retract/precharge length, velocity is handled by the machine firmware.
G28: Move to Origin (Home)
Parameters
This command can be used without any additional parameters.
Examples
G28 (Go to origin on all axes)
G28 X Z (Go to origin only on the X and Z axis)
When the RepRap firmware receives this command, it moves all (or the supplied) axis's back to the zero endstops as quickly as it can, then backs off by a millimeter and slowly moves back to the zero endstop activation points to increase position accuracy. This process is also known as "Homing".
If you add coordinates, these coordinates are ignored. For example, G28 Z0.00 results in the same behaviour as G28 Z.
RepRapFirmware runs macro files to home either all axes or an individual one. If all axes are homed, the file homeall.g will be processed, and homex.g, homey.g, or homez.g if individual axes are homed. On a Delta printer, any G28 command will home all three towers by processing the homedelta.g file, regardless of any XYZ letters.
G29: Detailed Z-Probe
Yes No, see G32 ??? ??? ??? Yes: 0.91.7 No, see G32 ??? ???
??? No No No Yes Yes No ??? ???
Probes the bed at 3 or more points and prints a report. The printer must be homed with G28 before G29.
Usage
G29
G29 Snnn
Parameters
Snnn Firmware-dependent behavior
Examples
G29
G29 S2
Notes
Marlin firmware supports G29 with the optional Snnn parameter as described below.
S0 Produce a mesh report as follows
+----> X-axis  1-n
v Y-axis  1-n
S1 Start probing mesh points
S2 Probe the next mesh point
S3 Xn Yn Zn.nn Manually modify a single point
S4 Zn.nn Set z offset. Positive away from bed, negative closer to bed.
Repetier firmware since v0.91 supports G29 with the optional Snnn parameter as described below. Useful to simply detect the Z bed angle so you can manually readjust your bed and get it as close to in plane as possible. If you wish to apply automatic software Z plane compensation on Repetier, use G32 instead with firmware 0.92.8 and above.
S0 Default value. Z bed heights are calculated at the measured points, relative to current Z position before issuing G29.
S1 Same as S0, except printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issue G28 Z to home to Z maximum position before issuing G29 Snnn for this to work correctly, or the printer height will be invalid.
S2 Same as S1, except new calculated Z height is also stored to EEPROM.
G29.1: Set Z probe head offset
Example: G29.1 X30 Y20 Z0.5
G29.2: Set Z probe head offset calculated from toolhead position
Example: G29.2 Z0.0
The user would typically place the toolhead at the zero point of the axis and issue the G29.2 command.
G30: Single Z-Probe
Usage
Parameters
Pnnn Probe point number
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
Hnnn Height correction1
Snnn Set parameter
Examples
G30
G30 P1 X20 Y50 Z0.3
G30 P3 X180 Y180 Z-99999 S1
In its simplest form probes bed at current XY location. If G30 without parameters is called in RepRapFirmware, the bed is not probed, but the current Z value will be used as trigger height and the 'H' value (if specified) will be omitted.
Some implementations allow more general behaviour: if a Pn field is specified the probed X, Y, and Z values are saved as point n on the bed for calculating the offset plane. Generally n is 0, 1, or 2. If X, or Y, or Z values are specified (e.g. G30 P1 X20 Y50 Z0.3) then those values are used instead of the machine's current coordinates. A silly Z value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specified (e.g. G30 P1 Z0.3 S) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1 commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup GCode file for automatic execution.
RepRapFirmware uses the value of the S parameter to specify what computation to perform. If the value is -1 then the Z offsets of all the points probed are printed, but no calibration is done. If the value is zero or not present, then this specified that the number of factors to be calibrated is the same as the number of points probed. Otherwise, the value indicates the number of factors to be calibrated, which must be no greater than the number of points probed. Currently (as of version 1.09), the number of factors may be 3, 4 or 5 when doing auto bed compensation on a Cartesian or CoreXY printer, and 3, 4, 6 or 7 when doing auto calibration of a Delta printer.
Notes
1Recent RepRapFirmware versions support an optional H parameter, which is a height correction to be added to the trigger height set by the G31 Z parameter. It allows for the Z probe having a trigger height that varies with XY position.
G31: Set or Report Current Probe status
No Yes ??? ??? ??? Yes: 0.91.7 Yes ??? ???
Usage
Parameters
Pnnn Trigger value
Xnnn Probe X offset1
Ynnn Probe Y offset1
Znnn Trigger Z height
Cnnn Temperature coefficient2
Snnn Calibration temperature2
Examples
G31 P500 Z2.6
G31 X16.0 Y1.5
In RepRapFirmware, separate G31 parameters may be defined for different probe types (i.e. 0+4 for switches, 1+2 for IR probes and 3 for alternative sensors). To specify which probe you are setting parameters for, send a M558 command to select the probe type before sending the G31 command.
In Repetier, G31 supports no parameters and simply prints the high/low status of the Z probe.
Notes
1X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) can be specified in RepRapFirmware. This allows you to calculate your M557 probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset. It also provides more accurate bed compensation.
2In RepRapFirmware, additional parameters 'S' (bed temperature in oC at which the specified Z parameter is correct, default is current bed temperature) and 'C' (temperature coefficient of Z parameter in mm/oC, default zero) can be set for the alternative (ultrasonic) sensor. This is useful for probes that are affected by temperature.
G31: Dock Z Probe sled
Yes No ??? ??? ??? ??? No ??? ???
No: See G29 Yes ??? ??? ??? Yes: 0.92.8 Yes ??? ???
Usage
G32
G32 Snnn
Parameters
Snnn Store transformation matrix after probing1
Examples
G32
G32 S2
Probes the bed at 3 or more pre-defined points (see M557) and updates transformation matrix for bed leveling compensation.
RepRapFirmware executes macro file bed.g if present instead of using the M557 coordinates.
Notes
1Currently only Repetier firmware v0.92.8 and higher have working support for an optional Snnn parameter. The numeric value sets the behavior that occurs immediately after point probe and transformation matrix calculation:
S0 Default value. Transformation matrix is updated in RAM but is not stored to EEPROM. Z bed height not calculated.
S1 Transformation matrix is updated in RAM but is not stored to EEPROM. Printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issue G28 to home to Z maximum position before issuing G32 Snnn for this to work correctly, or the printer height will be invalid.
S2 Same as S1, except transformation matrix and Z max heights are also stored to EEPROM.
S3 Transformation matrix is stored to EEPROM. Z bed height not calculated.
G32: Undock Z Probe sled
G33: Measure/List/Adjust Distortion Matrix
No No ??? ??? ??? Yes: v0.92.8 No ??? ???
??? No No No No Yes No ??? ???
Usage
G33
G33 Lnnn
G33 Rnnn
G33 Xnnn Ynnn Znnn
Parameters
L0 List distortion matrix in a report
R0 Reset distortion matrix
X<pos> Y<pos> Z<zCorrection> Set correction for nearest point
Examples
G33
G33 R0
When used with no parameters, G33 will measure a grid of points and store the distortion dips and valleys in the bed surface, and then enable software distortion correction for the first few or several layers. The values will be stored in EEPROM if enabled in firmware. You must previously have G28 homed, and your Z minimum/maximum height must be set correctly for this to work. Use the optional parameters to list, reset or modify the distortion settings. Distortion correction behavior can be later turned on or off by code M323.
??? No ??? ??? ??? ??? Yes ??? ???
Yes ??? ??? ??? ??? ??? ??? ??? ???
G40 turn cutter compensation off. If tool compensation was on the next move must be a linear move and longer than the tool diameter. It is OK to turn compensation off when it is already off.
G54..59: Coordinate System Select (CNC specific)
Example: G90
Yes Yes No Yes Yes Yes Yes ??? Yes
Example: G91
All coordinates from now on are relative to the last position. Note: RepRapFirmware latest revision firmware uses M83 to set the extruder to relative mode: extrusion is NOT set to relative by ReprapFirmware on G91: only X,Y and Z are set to relative. By contrast, Marlin (for example) DOES also set extrusion to relative on a G91 command, as well as setting X, Y and Z.
G92: Set Position
Parameters
Xnnn new X axis position
Ynnn new Y axis position
Znnn new Z axis position
Ennn new extruder position
Example
G92 X10 E90
G92.x: Reset Coordinate System Offsets (CNC specific)
  • G92.1 - reset axis offsets to zero and set parameters 5211 - 5219 to zero. (X Y Z A B C U V W)
  • G92.2 - reset axis offsets to zero.
G93 is Inverse Time Mode. In inverse time feed rate mode, an F word means the move should be completed in (one divided by the F number) minutes. For example, if the F number is 2.0, the move should be completed in half a minute.
When the inverse time feed rate mode is active, an F word must appear on every line which has a G1, G2, or G3 motion, and an F word on a line that does not have G1, G2, or G3 is ignored. Being in inverse time feed rate mode does not affect G0 (rapid move) motions.
No No ??? ??? ??? Yes: 0.92 No ??? ???
Parameters
X Flag to set floor for X axis
Y Flag to set floor for Y axis
Z Flag to set floor for Z axis
Rnnn Radius to add
Examples
G100 X Y Z (set floor for argument passed in. Number ignored and may be absent.)
G100 R5 (Add 5 to radius. Adjust to be above floor if necessary)
G100 R0 (Set radius based on current z measurement. Moves all axes to zero)
??? No No No No ??? No ??? Yes
Example: G130 X10 Y18 Z15 A20 B12
G131: Remove offset
No No ??? ??? ??? Yes: 0.91 No ??? ???
G133: Measure steps to top
G161: Home axes to minimum
??? No No No No ??? Yes ??? Yes
Parameters
Example
G161 X Y Z F1800
Instruct the machine to home the specified axes to their minimum position. Similar to G28, which decides on its own in which direction to search endstops.
G162: Home axes to maximum
Parameters
Example
G162 X Y Z F1800
M-commands
Yes Yes ??? ??? ??? No No ??? ???
Yes No No Yes Yes ??? Yes ??? ???
Parameters
Pnnn Time to wait, in milliseconds1
Snnn Time to wait, in seconds2
Example
M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller, although this step is not mandatory on RepRapFirmware. See also M1, M112.
RepRapFirmware executes macro file stop.g before everything is turned off. Apart from that, RepRapFirmware (v1.09n-ch) accepts an extra 'H' parameter, whose value must be non-zero, to keep all heaters active. This is what Duet Web Control v1.07 sends to cancel a paused print.
Notes
1Not available in RepRapFirmware, but as a work-around G4 can be run before M0.
2Only available on Marlin.
M1: Sleep or Conditional stop
Yes No No No No ??? ??? ??? ???
Example
M1
If Marlin is emulated in RepRapFirmware, this does the same as M25 if the code was read from a serial or Telnet connection, else the macro file sleep.g is run before all heaters and drives are turned off.
M2: Program End
No No ??? ??? ??? No ??? ??? ???
Yes No No No No ??? Yes ??? Yes
Example: M2
Yes No No No No ??? Yes ??? ???
Parameters
Snnn Spindle RPM
Example
M3 S4000
RepRapFirmware interprets this code only if a Roland mill has been configured.
In Repetier-Firmware in laser mode you need S0..255 to set laser intensity. Normally you use S255 to turn it on full power for moves. Laser will only fire during G1/2/3 moves and in laser mode (M452).
No No ??? ??? ??? Yes No ??? ???
Yes No No No No ??? No ??? ???
Example: M4 S4000
No No ??? ??? ??? Yes Yes ??? ???
Example: M5
The spindle is turned off.
M6: Tool change
??? No No No No ??? Yes ??? ???
Example: M6
Yes No No No No ??? use M106 ??? ???
Example: M7
Example: M8
Example: M9
M10: Vacuum On (CNC specific)
??? No No No No ??? use M106 ??? ???
Example: M10
Example: M11
Yes No ??? ??? ??? No Yes ??? ???
??? No No No No Yes (automatic) ??? ???
Example: M17
call M84 Yes ??? ??? ??? No Yes ??? ???
??? No No No No Yes use M2 ??? Yes
Parameters
This command can be used without any additional parameters.1
X X axis
Y Y axis
Z Z axis
E Extruder drive(s)2
Examples
M18
M18 X E0
Notes
2RepRapFirmware allows stepper motors to be disabled selectively. For example, M18 X E0:2 will disable the X, extruder 0 and extruder 2 motors.
M20: List SD card
??? Yes No No No ??? Yes ??? ???
Parameters
Snnn Output style1
Pnnn Directory to list2
Examples
M20
M20 P/gcodes/subdir S2
ok
SQUARE.G
SQCOM.G
ZCARRI~2.GCO
CARRIA~1.GCO
On Marlin, a file list response is usually encapsulated. Standard configurations of RepRapFirmware mimic this style in emulation mode:
Begin file list:
SQUARE.G
ZCARRI~2.GCO
End file list
ok
GCode files:
"Traffic cone.g","frog.gcode","calibration piece.g"
Note that some firmwares list file names in upper case, but - when sent to the M23 command (below) they must be in lower case. Teacup and RepRapFirmware have no such trouble and accept both. Besides, RepRapFirmware always returns long filenames in the case in which they are stored.
Notes
1This parameter is only supported by RepRapFirmware and defaults to the /gcodes directory, which would be whatever directory printable gcode files are normally stored in on other firmware.
2If the S2 parameter is used on RepRapFirmware, then the file list is returned in JSON format as a single array called "files" with each name that corresponds to a subdirectory preceded by an asterisk, and the directory is returned in variable "dir".
M21: Initialize SD card
Yes No ??? ??? ??? Yes Yes ??? ???
??? Yes No No No No Yes ??? ???
Example: M21
The SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
M22: Release SD card
Yes No ??? ??? ??? Yes No ??? ???
Example: M22
SD card is released, so further (accidental) attempts to read from it are guaranteed to fail. Helpful, but not mandatory before removing the card physically.
M23: Select SD file
Example
M23 filename.gco
M24: Start/resume SD print
Example
M24
The machine prints from the file selected with the M23 command. If the print was previously paused with M25, printing is resumed from that point. To restart a file from the beginning, use M23 to reset it, then M24.
When this command is used to resume a print that was paused, RepRapFirmware runs macro file resume.g prior to resuming the print.
M25: Pause SD print
Example
M25
The machine pauses printing at the current position within the file. To resume printing, use M24. Do not use this code to pause the print in a G-code file, use M226 instead.
Prior to pausing, RepRapFirmware runs macro file pause.g. This allows the head to be moved away from the print, filament to be retracted, etc.
M26: Set SD position
Yes Yes ??? ??? ??? Yes aborts ??? ???
??? Yes No No No ??? No ??? ???
Parameters
Snnn File position in bytes
Example
M26
M27: Report SD print status
Example
M27
Report SD print status.
Marlin and recent forks of RepRapFirmware report the number of bytes processed in this format, which can be processed by Pronterface:
SD printing byte 2134/235422
Not SD printing.
M28: Begin write to SD card
Example
M28 filename.gco
M29: Stop writing to SD card
Yes Yes ??? ??? ??? Yes No ??? ???
Example
M29 filename.gco
Yes Yes No No No ??? No ??? ???
Example: M30 filename.gco
filename.gco is deleted.
M30 in grbl
M30 exchange pallet shuttles and end the program. Pressing cycle start will start the program at the beginning of the file.
Yes No ??? ??? ??? No No ??? ???
Example
M31
The response looks like:
 echo:54 min, 38 sec
Yes Yes ??? ??? ??? No Yes ??? ???
Example
M32 filename.gco
It can be used when printing from SD card and does the same as M23 and M24.
M36: Return file information
??? No No No No No No ??? No
Example
M36 filename.gco
If the file name parameter is not supplied and a file on the SD card is currently being printed, then information for that file is returned including additional field "fileName". This feature is used by the web interface and by PanelDue, so that if a connection is made when a file is already being printed, the name and other information about that file can be shown.
M37: Simulation mode
No dc42 ??? ??? ??? No No ??? ???
M37 S1 enters simulation mode. All G and M codes will not be acted on, but the time they take to execute will be calculated.
M37 S0 leaves simulation mode.
M38 Compute SHA1 hash of target file
No ch fork ??? ??? ??? No No ??? ???
Used to compute a hash of a file on the SD card. Examples:
M37 gcodes/myfile.g
Cannot find file
M37 www/reprap.htm
91199139dbfadac15a18cfb962dfd4853db83999
Returns a hexadecimal string which is the SHA1 of the file. If the file cannot be found, then the string "Cannot find file" is returned instead.
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
M42: Switch I/O pin
??? Yes No No No No No ??? No
Parameters
Pnnn Pin number
Snnn Pin value
Example
M42 P7 S255
In RepRapFirmware, only 1 and 0 are supported for the S field. On Duet hardware, the supported pin numbers and their names on the expansion connector are:
16 TXD1, 17 RXD1, 18 TXD0, 19 RXD0, 20 TWD1, 21 TWCK1, 23 RTS1, 36 PC4_PWML1, 52 AD14, 66 AD13, 67 PB16.
See also M583.
Example: M43
Parameters
Pnnn number of points
Xnnn position on the X axis
Ynnn position on the Y axis
Vnnn verbosity
E engage
Lnnn legs of travel
As with G29, the E flag causes the probe to stow after each probe.
M70: Display message
see M117 see M117 ??? ??? ??? No ??? ??? ???
Example: M70 P200 Message
Instruct the machine to display a message on it's interface LCD. P is the time to display message for.
M72: Play a tone or song
see M300 see M300 ??? ??? ??? No No ??? ???
Example: M72 P2
M73: Set build percentage
Example: M73 P50
Instruct the machine that the build has progressed to the specified percentage. The machine is expected to display this on it's interface board. If the percentage is exactly 0, then a Build Start Notification is sent. If the percentage is exactly 100, then a Build End notification is sent.
M80: ATX Power On
??? Yes No No No ??? automatic ??? ???
Example
M80
Note: some firmwares, like Teacup, handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off
M81: ATX Power Off
??? Yes No No No Yes automatic ??? ???
Example
M81
For redeem, adding 'P' will quit the daemon (redeem). Adding parameter 'R' will restart the daemon.
Example
M82
Example
M83
M84: Stop idle hold
Parameters
Innn Reset flags1
Example
M84
On Marlin, Repetier and RepRapFirmware, M84 can also be used to configure or disable the idle timeout. For example, "M84 S10" will idle the stepper motors after 10 seconds of inactivity. "M84 S0" will disable idle timeout; steppers will remain powered up regardless of activity.
Notes
1RepRapFirmware-dc42 and other firmware may not support this parameter.
M85: Set inactivity shutdown timer
Example: M85 S30
M92: Set axis_steps_per_unit
Parameters
Xnnn Steps per unit for the X drive
Ynnn Steps per unit for the Y drive
Znnn Steps per unit for the Z drive
Ennn Steps per unit for the extruder drive(s)
Examples
M92 X87.489 Y87.489 Z87.489
M92 E420:420
Allows programming of steps per unit (usually mm) for motor drives. These values are reset to firmware defaults on power on, unless saved to EEPROM if available (M500 in Marlin) or in the configuration file (config.g in RepRapFirmware). Very useful for calibration.
M93: Send axis_steps_per_unit
No No ??? ??? ??? ??? No ??? ???
M98: Call Macro/Subprogram
Parameters
Pnnn Macro filename
Example
M98 Pmymacro.g
Runs the macro in the file mymacro.g. In conventional G Codes for CNC machines the P parameter normally refers to a line number in the program itself (P2000 would run the Macro starting at line O2000, say). For RepRap, which almost always has some sort of mass storage device inbuilt, it simply refers to the name of a GCode file that is executed by the G98 call. That GCode file does not need to end with an M99 (return) as the end-of-file automatically causes a return. Macro calls cannot usually be nested or be recursive; i.e. you can't call a macro from a macro, although RepRapFirmware explicitly supports this.
RepRapFirmware also allows the filename to include a path to a subdirectory. For relative paths, the default folder is /sys, but some implementations may check the /macros directory too. Absolute file paths are supported on RepRapFirmware as well.
Example
M99
Returns from an M98 call.
M98: Get axis_hysteresis_mm
Example: M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Example: M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
??? No Yes No No ??? Yes ??? ???
in Teacup firmware: If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
in BFB/RapMan firmware: Turn extruder on (forward/filament in).
in other firmwares: Deprecated. Regarding filament retraction, see M227, M228, M229.
??? No Yes No No ??? No ??? ???
In other firmwares: Deprecated.
In Teacup firmware: If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
In other firmwares: Deprecated. Regarding extruder retraction, see M227, M228, M229.
??? Yes Yes Yes Yes Yes Yes ??? Yes
Parameters
Snnn Target temperature
Example
M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). Duet-dc42 and other firmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command applies to. See also M109.
M104 in Teacup Firmware
Example: M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100 °C.
??? Yes No Yes No Yes Yes ??? Yes
Parameters
Rnnn Response sequence number1
Snnn Response type1
Examples
M105
M105 S2
ok T:201 B:117
M105 X0
Notes
1These parameters are only supported by RepRapFirmware, which returns a JSON-formatted response if parameter S2 or S3 is specified. Additionally, parameter Rnn may be provided, where nn is the sequence number of the most recent G-code response that the client has already received. M105 S2 is equivalent to M408 S0, and M105 S3 is equivalent to M408 S2. Usage of these forms of M105 is deprecated, please use M408 instead.
M106: Fan On
??? Yes Yes Yes Yes ??? Yes ??? ???
Parameters
Pnnn Fan number (optional, defaults to 0)2
Snnn Fan speed (0 to 255)
Innn Invert signal1
Fnnn Set fan PWM frequency, in Hz1
Hnn:nn:nn... Select heaters monitored when in thermostatic mode1
Rnnn Restore fan speed to the value it has when the print was paused1
Tnnn Set thermostatic mode trigger temperature1
Examples
M106 S127
M106 P1 I1 S871
M106 P1 T45 H1:21
The first example turns on the default cooling fan at half speed. The second one inverts the cooling fan signal of the second fan and sets its value to 1/3 of its maximum. The third one sets the second fan to a thermostatic fan for heaters 1 and 2 (e.g. the extruder heaters in a dual-nozzle machine) such that the fan will be on when either hot end is at or above 45C.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off. In some implementations like RepRapFirmware the PWM value may alternatively be specified as a real fraction: M106 S0.7.
Notes
2Marlin only supports fan 0, all values above 0 will be interpreted as 0
M106 in RepRapFirmware
RepRapFirmware supports an optional 'I' parameter, whose value must be greater than zero to invert the cooling fan output signal. This makes the cooling fan output suitable for feeding the PWM input of a 4-wire fan via a diode. If the parameter is present and zero or negative, the output is not inverted. If the parameter is not present, the inverted/non-inverted state remains unchanged. The default at power up is not inverted.
If the optional 'R' parameter is specified, the fan value when the print was last paused will be set. If the 'S' parameter is passed along with 'R', the firmware will not reset the last-known fan value. This may be useful for tool change macro files.
The T and H parameters allow a fan to be configured to operate in thermostatic mode, for example to use one of the fan channels to control the hot end fan. In this mode the fan will be fully on when the temperature of any of the heaters listed in the H parameter is at or above the trigger temperature set by the T parameter, and off otherwise. Thermostatic mode can be disabled using parameter H-1.
M106 in Teacup Firmware
Example: M106 P2 S255
Note well: The ambiguous text in the note above needs to be reworded by someone who knows the actual functioning. Below is my interpretation based on language use, not practical experience or code inspection.
Note: If M104 is (or becomes) active on a heater (or other device) with a feedback sensor it will correct any M106 initiated control output value change in the time it takes for the PID (of other feedback) loop to adjust it back to minimum error. It may not be easy to observe a change in the temperature (process value) due to this brief change in the control value
M107: Fan Off
??? Yes Yes Yes Yes ??? No ??? ???
Deprecated in Teacup firmware and in RepRapFirmware. Use M106 S0 instead.
M108: Set Extruder Speed
Sets speed of extruder motor. (Deprecated in FiveD firmware, see M113)
??? Yes No Yes Yes Yes not needed ??? Yes
Parameters
Example
M109 S215
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port), RepRapFirmware
Example: M109 S185
RepRapFirmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command refers to (see below).
M109 in Sprinter (4pi port)
Example: M109 S185 R240 //sets extruder temperature to 185 and waits for the temperature to be between 185 - 240.
M109 in MakerBot
Example: M109 S70 T0
M110: Set Current Line Number
??? No No Yes No ??? not needed ??? ???
Parameters
Nnnn Line number
Example
M110 N123
M111: Set Debug Level
??? No No Yes No ??? Debug ??? ???
Parameters
Pnnn Debug module1
Snnn Debug on/off
Examples
M111 S6
M111 P1 S1
Notes
M111 in RepRapFirmware
RepRapFirmware allows debugging to be set for each module. If the optional 'P' parameter is not specified, debugging will be enabled for all modules. For a complete list of all modules, refer to the Module enumeration in RepRapFirmware.h of the fork you are using.
M111 in Repetier
#define DEBUG_ECHO (1<<0)
#define DEBUG_INFO (1<<1)
#define DEBUG_ERRORS (1<<2)
M112: Emergency Stop
??? No No Yes No ??? Yes ??? ???
Example
M112
M113: Set Extruder PWM
??? No No Yes No ??? No ??? ???
Example: M113
M113 S0.7
M114: Get Current Position
??? Yes No Yes No ??? Yes ??? Yes
Example
M114
??? Yes No Yes No Yes Yes ??? No
Parameters
Pnnn Electronics type1
Examples
M115
M115 P2
sample data from firmware:
Notes
1This parameter is supported only in RepRapFirmware and can be used tell the firmware about the hardware on which it is running. If the P parameter is present then the integer argument specifies the hardware being used. The following are currently supported:
M115 P0   Automatic board type selection if supported, or default if not
M115 P1   Duet 0.6
M115 P2   Duet 0.7
M115 P3   Duet 0.85
M116: Wait
No Yes ??? ??? ??? Yes No ??? ???
??? No No Yes No Yes Yes ??? Yes
Parameters
Pnnn Tool number
Hnnn Heater number
Cnnn Chamber number
Examples
M116
M116 P1
Wait for all temperatures and other slowly-changing variables to arrive at their set values if no parameters are specified. See also M109.
Notes
M117: Get Zero Position
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
??? No No Yes No ??? No ??? see M70
Example: M117
M117: Display Message
??? No No No No Yes No ??? No
Example
M117 Hello World
M118: Negotiate Features
Example: M118 P42
M119: Get Endstop Status
??? Yes No No No Yes Yes ??? ???
Example
M119
In redeem, M119 can also be used to invert end stops.
Example
M119 X1 1
This will invert end stop X1 (Inverted means switch is connected in Normally Open state (NO))
M120: Push
No Yes ??? ??? ??? No Yes ??? ???
??? No No No No No No ??? ???
Example
M120
  1. Current feedrate, and
  1. Current feedrate
  2. Extruder positions
M121: Pop
Example
M121
M122: Diagnose
Example
M122
M123: Tachometer value
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
??? No No Yes No ??? No ??? Yes
Example: M126 P500
M126 in MakerBot
Example: M126 T0
M127: Close Valve
Example: M127 P400
M127 in MakerBot
Example: M127 T0
M128: Extruder Pressure PWM
??? No ??? ??? ??? No No ??? ???
Example: M128 S255
M129: Extruder pressure off
Example: M129 P100
M130: Set PID P value
see M301 No ??? ??? ??? No No: See M301 ??? ???
Parameters
Pnnn heater number
Snnn proportional (Kp)
Example
M130 P0 S8.0  ; Sets heater 0 P factor to 8.0
M131: Set PID I value
Parameters
Pnnn heater number
Snnn integral (Ki)
Example
M131 P1 S0.5  ; Sets heater 1 I factor to 0.5
M132: Set PID D value
see M301 see M301 ??? ??? ??? No No: See M301 ??? ???
Parameters
Pnnn heater number
Snnn derivative (Kd)
Example
M132 P0 S24  ; Sets heater 0 D factor to 24.0
M132 in MakerBot
Example: M132 X Y Z A B
M133: Set PID I limit value
see M301 No ??? ??? ??? No No ??? ???
Parameters
Pnnn heater number
Snnn integral limit (Ki)
Example
M133 P1 S264  ; Sets heater 1 I limit value to 264
M133 in MakerBot
Example: M133 T0 P500
Instruct the machine to wait for the toolhead to reach its target temperature. T is the extruder to wait for. P if present, sets the time limit.
No see M500 ??? ??? ??? No No: See M504 ??? ???
Example: M134
M134 in MakerBot
Example: M134 T0 P500
M135: Set PID sample interval
Parameters
Snnn Heat sample time in seconds
Example
M135 S300
M135 in MakerBot
Example: M135 T0
No see M301 ??? ??? ??? No No ??? ???
??? No No No No ??? Debug ??? ???
Example: M136 P1 # print heater 0 PID parameters to host
Yes Yes ??? ??? ??? Yes Yes ??? ???
??? Yes No Yes Yes ??? Yes ??? Yes
Parameters
Hnnn Heater number1
Example
M140 S55
RepRapFirmware allows the bed heater to be switched off if the absolute negative temperature (-273.15) is passed as target temperature. In this case the current bed temperature is not affected1:
M140 S-273.15
??? No No No Yes ??? uses M104 ??? ???
Parameters
Hnnn Heater number1
Examples
M141 S30
M141 H0
Notes
M142: Holding Pressure
Example: M142 S1
M143: Maximum hot-end temperature
No ch,dc42 ??? ??? ??? No No ??? ???
Example: M143 S275
Set the maximum temperature of the hot-end to 275°C.
Default value is 300°C.
M144: Stand By Your Bed
Example
M144
M146: Set Chamber Humidity
Parameters
Example
M146 R60
M149: Set temperature units
Parameters
Example
M149 K
M150: Set display color
Parameters
Rnnn red
Unnn green
Bnnn blue
Example
M150 R255 U128 B192
Set BlinkM Color via I2C. Range for values: 0-255
Example: M160 S4
M160 S4
G1 X70.6 E0:0:0:42.4
G1 E42.4:0:0:0
Parameters
Snnn extruder number
Pnnn weight
M164: Store weights
Parameters
Snnn virtual extruder number
??? Yes No No Yes ??? No: See M116 ??? ???
Parameters
Example
M190 S60
No see M301 C1 ??? ??? ??? No No ??? ???
Example: M191 P60
M200: Set filament diameter
Yes see M404 ??? ??? ??? Yes Yes ??? ???
M200 D0 or M200 D1.128 ; reset E multiplier to 1, since sqrt(1/pi)*2=1.128
Parameters
Xnnn Acceleration for X axis
Ynnn Acceleration for Y axis
Znnn Acceleration for Z axis
Ennn Acceleration for extruder drives
Example
M201 X1000 Y1000 Z100 E2000
RepRapFirmware expects these values to be in mm/s².
??? ??? No No No ??? No ??? ???
M203: Set maximum feedrate
Parameters
Xnnn Maximum feedrate for X axis
Ynnn Maximum feedrate for Y axis
Znnn Maximum feedrate for Z axis
Ennn Maximum feedrate for extruder drives
Example
M203 X6000 Y6000 Z300 E10000
Sets the maximum feedrates that your machine can do in mm/min (Marlin uses mm/sec).
M203 Repetier
Set temperture monitor to Sx.
P = Printing moves
The command "M204 P800 T3000 R9000" set the acceleration for printing movements to 800mm/s^2, for travels to 3000mm/s^2 and for retracts to 9000mm/s^2.
M204 Repetier
M204 X[Kp] Y[Ki] Z[Kd] -
M205: Advanced settings
Yes see M566 ??? ??? ??? Yes Yes ??? ???
Sprinter and Marlin:
Sprinter / Marlin Example:
M205 X30 Z5 ; Set X/Y Jerk to 30mms, Z jerk to 5mms
Smoothieware uses a different algorithm: [1]
X<xy junction deviation> Z<z junction deviation> S<minimum planner speed>, Z junction deviation only applies to z only moves, 0 disables junction deviation for Z, -1 uses global junction deviation
Smoothie example:
M205 X0.05  ; set X/Y Junction Deviation
M205 Repetier
Output EEPROM settings.
M206:
M206 Marlin, Sprinter, Smoothie, RepRapFirmware - Set home offset
Parameters
Xnnn X axis offset
Ynnn Y axis offset
Znnn Z axis offset
Example
M206 X10.0 Y10.0 Z-0.4
M206 Repetier - Set eeprom value
Example: M206 T3 P39 X19.9
Set Jerk to 19.9
??? No No No No ??? No ??? ???
Example: M207
M207: Set retract length
Yes dc42,ch ??? ??? ??? No Yes ??? ???
Parameters
Rnnn positive additional length to un-retract, in mm (RepRapFirmware only)
Fnnn feedrate, in mm/min
Znnn additional zlift/hop
Example
M207 S4.0 F2400 Z0.075
Sets the retract length used by the G10 and G11 commands, stays in mm regardless of M200 setting
M208: Set axis max travel
No Yes ??? ??? ??? No No ??? ???
Parameters
Snnn Whether to set the axis minimum1
Xnnn X axis limit
Ynnn Y axis limit
Znnn Z axis limit
Example
M208 X250 Y210 Z180
RepRapPro's version of Marlin uses M208 this way. Send M503 to see the current values. On Marlin, the value can be saved to EEPROM using the M500 command.
Notes
1With RepRapFirmware on a Cartesian printer, you can also use this command to specify software limits for axis travel in the negative direction, by adding parameter S1. The axis limits you set are also the positions assumed when an endstop is triggered.
M208 X200 Y200 Z90; set axis maxima
M208 X-5 Y0 Z0 S1 ; set axis minimum
M208: Set unretract length
Yes See M207 ??? ??? ??? No Yes ??? ???
Parameters
Fnnn feedrate, in mm/sec
??? No No No No ??? No ??? No
Example: M209 S1
M210: Set homing feedrates
Example: M210 X1000 Y1500
No No ??? ??? ??? No No ??? ???
Example: M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example: M211 X0 S1
Enables X min endstop
Example: M211
Yes* No ??? ??? ??? No No ??? ???
Example: M212 Z-0.2
M218: Set Hotend Offset
Example: M218 T1 X50 Y0.5
Parameters
Snnn Speed factor override percentage (0..100 or higher)
Example
M220 S80
Parameters
Snnn Extrude factor override percentage (0..100 or higher)
Example
M221 S70
Sets extrude factor override percentage.
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
??? No Yes No Yes ??? No ??? ???
Example
M226
M226: Wait for pin state
Yes see M577 ??? ??? ??? Yes No ??? ???
Parameters
Pnnn pin number
Snnn pin state
Example
M226 P2 S1
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
M231: Set OPS parameter
M231 S[OPS_MODE] X[Min_Distance] Y[Retract] Z[Backslash] F[ReatrctMove]
M240: Trigger camera
Example: M240
Triggers a camera to take a photograph. (Add to your per-layer GCode.)
??? No No No No ??? Debug: Echo off ??? ???
Example: M240
??? No No No No ??? Debug: Echo on ??? ???
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
M250: Set LCD contrast
Example: M250 C20
M251 S0 - Reset, S1 - Print, S2 - Store to Z length (also EEPROM if enabled)
(This is a Repetier-Firmware only feature)
M280: Set servo position
??? No No No Yes ??? No ??? ???
(Marlin, Repetier M340)
Set servo position absolute. P: servo index, S: angle or microseconds (Marlin)
M300: Play beep sound
??? No No No Yes ??? No ??? Yes
Parameters
Snnn frequency in Hz
Pnnn duration in milliseconds
Example
M300 S300 P1000
If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
M301: Set PID parameters
??? Yes No No No ??? No: See M13[0-3]) ??? ???
Parameters
Hnnn heater number (Smoothie uses 'S')
Pnnn proportional (Kp)
Innn integral (Ki)
Dnnn derivative (Kd)
Examples
M301 H1 P1 I2 D3 ; Marlin
M301 H1 P1 I2 D3 T0.2 B20 W127 S0.8 ; RepRapFirmware (v1.09 onwards), Duet-dc42
M301 S0 P30 I10 D10 ; Smoothie
Marlin
Hot end only; see M304 for bed PID. H is the heater number, default 1 (i.e. first extruder heater).
H: Is the heater number, and is compulsory. H0 is the bed, H1 is the first hot end, H2 the second etc.
P: Interprets a negative P term as indicating that bang-bang control should be used instead of PID (not recommended for the hot end, but OK for the bed heater).
I: Integral value
D: Derivative value
T: Is the approximate additional PWM (on a scale of 0 to 255) needed to maintain temperature, per degree C above room temperature. Used to preset the I-accumulator when switching from heater fully on/off to PID.
S: PWM scaling factor, to allow for variation in heater power and supply voltage. Is designed to allow a correction to be made for a change in heater power and/or power supply voltage without having to change all the other parameters. For example, an S factor of 0.8 means that the final output of the PID controller should be scaled to 0.8 times the standard value, which would compensate for a heater that is 25% more powerful than the standard one or a supply voltage that is 12.5% higher than standard.
W: Wind-up. Sets the maximum value of I-term, must be high enough to reach 245C for ABS printing.
B: PID Band. Errors larger than this cause heater to be on or off.
An example using all of these would be:
M301 H1 P20 I0.5 D100 T0.4 S1 W180 B30
Smoothie
S0 is 0 for the hotend, and 1 for the bed, other numbers may apply to your configuration, depending on the order in which you declare temperature control modules.
Other implementations
W: Wind-up. Sets the maximum value of I-term, so it does not overwhelm other PID values, and the heater stays on. (Check firmware support - Sprinter, Marlin?) Example:
M301 W125
Teacup
M302: Allow cold extrudes
Yes Yes ??? ??? ??? Yes: 0.92 No ??? ???
Parameters
Pnnn Cold extrude state1
Examples
M302
M302 P1
This tells the printer to allow movement of the extruder motor, when the hotend is not at printing temperature
Notes
1When using RepRapFirmware, running M302 will only report the current cold extrusion state. To allow or deny cold extrudes/retracts, run either "M302 P1" or "M302 P0".
M303: Run PID tuning
Hot end usage:
M303 S<temperature> C<cycles>
Bed usage (repetier, not sure whether cycles work here):
M303 P1 S<temperature>
Bed usage (others):
Example:
M303 C8 S175
M303 E0 S190
Yes Yes ??? ??? ??? ??? see M301 ??? ???
Parameters
Innn integral (Ki)
Examples
M304 P1 I2 D3 ; set kP=3, kI=2, kD=3
M301 P1 I2 D3 T0.7 H0 B20 W127 ; RepRapFirmware
M304  ; Report parameters
Sets Proportional, Integral and Derivative values for bed. RepRapFirmware interprets a negative P term as indicating that bang-bag control should be used instead of PID. In RepRapFirmware, this command is identical to M301 except that the H parameter (heater number) defaults to zero.
Example: M304 H1 B4200 R4800 T100000
No Yes ??? ??? ??? ??? Yes ??? ???
Parameters
Pnnn Heater number
Tnnn Thermistor resistance at 25oC
Bnnn Beta value
Rnnn Series resistor value
Lnnn ADC low offset
Hnnn ADC high offset
Xnnn Heater ADC channel
Example
M305 P1 T100000 R1000 B4200
Sets the parameters for temperature measurement. Supported by RepRapFirmware from 0.78c, and Duet-dc42 firmware.
The example above tells the firmware that for heater 1 (P parameter: 0 = heated bed, 1 = first extruder) the thermistor 25C resistance (T parameter) is 100Kohms, the thermistor series resistance (R parameter) is 1Kohms, the thermistor beta (B parameter) is 4200. All parameters other than P are optional. If only the P parameter is given, the existing values are displayed.
RepRapFirmware also supports an ADC correction functionality and a thermistor selection facility. Example:
M305 P1 T100000 R1000 B4200 H14 L-11 X2
New versions of RepRapFirmware also allow an external SPI thermocouple (such as the MAX31855) to be configured. The first MAX31855 ADC channel is currently set to 100, the second one to 101 etc.
Here the ADC high end correction (H parameter) is 14, the ADC low end correction (L parameter) is -11, and thermistor input #2 is used to measure the temperature of heater #1.
M306: set home offset calculated from toolhead position
No No ??? ??? ??? ??? Yes ??? ???
Example: M306 Z0
Implemented in Smoothieware
M320: Activate autolevel (Repetier)
Usage
M320
M320 S1
Parameters
Snnn if greater than 0, activate and store persistently in EEPROM
Examples
M320 (temporarily activate auto leveling)
M320 S1 (permanently activate auto leveling)
Parameter Snnn is optional.
(Repetier only)
M321: Deactivate autolevel (Repetier)
Usage
M321
M321 S1
Parameters
Snnn if greater than 0, deactivate and store persistently in EEPROM
Examples
M321 (temporarily deactivate auto leveling)
M321 S1 (permanently deactivate auto leveling)
(Repetier only)
M322: Reset autolevel matrix (Repetier)
Usage
M322
M322 S1
Parameters
Snnn if greater than 0, also reset the matrix values saved EEPROM
Examples
M322 (temporarily reset auto level matrix)
M322 S1 (permanently reset auto level matrix)
(Repetier only)
M323: Distortion correction on/off (Repetier)
Usage
M323
M323 Snnn
M323 Snnn Pnnn
Parameters
Snnn 0 (disable correction) or 1 (enable correction)
Pnnn 1 (store correction state persistently in EEPROM)
Examples
M323 (Show if distortion correction is enabled)
M323 S0 (Disable distortion correction temporarily)
M323 S1 P1 (Enable distortion correction permanently)
(Repetier only) Controls distortion correction feature after having set it up using G33.
M340: Control the servos
M350: Set microstepping mode
Sets microstepping mode.
Warning: Steps per unit remains unchanged; except that in RepRapFirmware the steps/mm will be adjusted automatically.
Usage
M350 Snn Xnn Ynn Znn Enn Bnn
Parameters
Not all parameters need to be used, but at least one should be used. As with other commands, RepRapFirmware reports the current settings if no parameters are used.
Snn Set stepping mode for all drivers (not supported by RepRapFirmware)
Xnn Set stepping mode for the X axis
Ynn Set stepping mode for the Y axis
Znn Set stepping mode for the Z axis
Enn Set stepping mode for Extruder 0 (for RepRapFirmware use Enn:nn:nn etc. for multiple extruders)
Bnn Set stepping mode for Extruder 1 (not supported by RepRapFirmware, see above)
Inn Enable (nn=1) or disable (nn=0) microstep interpolation mode for the specified drivers, if they support it (RepRapFirmware only)
Modes (nn)
1 = full step
2 = half step
4 = quarter step
8 = 1/8 step
16 = 1/16 step
64 = 1/64 step
128 = 1/128 step
256 = 1/256 step
Examples
M350 S16 (reset all drivers to the default 1/16 micro-stepping - not supported by RepRapFirmware)
M350 Z1 (set the Z-axis' driver to use full steps)
M350 E4 B4 (set both extruders to use quarter steps - Marlin/Repetier)
M350 E4:4:4 (set extruders 0-2 to use quarter steps - RepRapFirmware)
Example: M351
M355: Turn case lights on/off
No No ??? ??? ??? Yes: 0.92.2 No ??? ???
Examples
M355 S1 ; Enable lights
M355 S0 ; Disable lights
M355 ; Report status
Every call or change over LCD menu sends a state change for connected hosting software like
Case lights on
Case lights off
No case lights
Target
Example
M360
Response
Config:Baudrate:250000
Config:InputBuffer:127
Config:NumExtruder:2
Config:MixingExtruder:0
Config:HeatedBed:0
Config:SDCard:1
Config:Fan:1
Config:LCD:1
Config:SoftwarePowerSwitch:1
Config:XHomeDir:-1
Config:YHomeDir:-1
Config:ZHomeDir:-1
Config:SupportG10G11:1
Config:CaseLights:0
Config:ZProbe:1
Config:Autolevel:0
Config:EEPROM:1
Config:PrintlineCache:24
Config:JerkXY:30.00
Config:JerkZ:0.30
Config:RetractionLength:3.00
Config:RetractionSpeed:40.00
Config:RetractionZLift:0.00
Config:XMin:0.00
Config:YMin:0.00
Config:ZMin:0.00
Config:XMax:250.00
Config:YMax:150.00
Config:ZMax:90.00
Config:XSize:250.00
Config:YSize:150.00
Config:ZSize:90.00
Config:XPrintAccel:250.00
Config:YPrintAccel:250.00
Config:ZPrintAccel:100.00
Config:XTravelAccel:250.00
Config:YTravelAccel:250.00
Config:ZTravelAccel:100.00
Config:PrinterType:Cartesian
Config:MaxBedTemp:120
Config:Extr.1:Jerk:50.00
Config:Extr.1:MaxSpeed:100.00
Config:Extr.1:Diameter:0.00
Config:Extr.1:MaxTemp:220
Config:Extr.2:Jerk:50.00
Config:Extr.2:MaxSpeed:100.00
Config:Extr.2:Diameter:0.00
Config:Extr.2:MaxTemp:220
Partial No ??? ??? ??? No Yes ??? ???
Experimental No ??? ??? ??? No Yes ??? ???
Smoothieware: M364 P0 will accept the current position as 90deg between arms. The offset is stored as a trim offset (M666) and no further user interaction is required except to save all changes via M500
M365: SCARA scaling factor
M366: SCARA convert trim
No No ??? ??? ??? No Yes ??? ???
Usage
M370
M370 X<divisions> Y<divisions>
M374: Save calibration grid
Saves the calibration grid. (Smoothieware)
Usage
M374
M374 <file extension> Z
Without parameters safes the grid into the default grid file that gets loaded at boot Parameter specifies the extension of the grid file - useful for special grid files such as for a special print surface like a removable print plate. Addition of Z will additionally save the M206 Z homing offset into the grid file
Display the bed level calibration matrix (Marlin) Load Grid matrix file (Smoothieware)
Usage
M375
M375 <file extension>
M380: Activate solenoid
Yes No ??? ??? ??? ??? No ??? ???
Example: M380
M381: Disable all solenoids
Example: M381
??? Yes No No Yes ??? No ??? ???
Example
M400
M401: Lower z-probe
Example: M401
Lower z-probe if present.
M402: Raise z-probe
Example: M402
Raise z-probe if present.
Yes Yes ??? ??? ??? No No ??? ???
Parameters
Nnnn Filament width (in mm)
Dnnn Nozzle diameter (in mm)1
Examples
M404 N1.75
M404 N3.0 D1.0
Enter the nominal filament width (3mm, 1.75mm) or will display nominal filament width without parameters.
Notes
1While Marlin only accepts the 'N' parameter, RepRapFirmware further allows to specify the nozzle diameter (in mm) via the 'D 'parameter. This value is used to properly detect the first layer height when files are parsed or a new print is being started.
M405: Filament Sensor on
Yes No ??? ??? ??? No No ??? ???
Example: M405
M406: Filament Sensor off
Example: M406
Example
M407
Displays measured filament diameter. In RepRapFirmware, M407 does the same as M404.
Parameters
Snnn Response type
Example
M408 S0
Report a JSON-style response by specifying the desired type using the 'S' parameter.
The following response types are supported:
  • Type 0 is a short-form response, similar to the response used by older versions of the web interface.
  • Type 1 is like type 0 except that static values are also included.
  • Type 2 is similar to the response provided by the web server for Duet Web Control.
  • Type 3 is an extended version of type 2 which includes some additional parameters that aren't expected to change very frequently.
  • Type 4 is an extended version of type 2 which may be used to poll for current printer statistics.
  • Type 5 reports the current machine configuration.
Here is an example of a typical type 0 response:
{"status":"I","heaters":[25.0,29.0,28.3],"active":[-273.1,0.0,0.0],"standby":[-273.1,0.0,0.0],"hstat":[0,2,1],"pos":[-11.00,0.00,0.00],"extr":[0.0,0.0],
 "sfactor":100.00, "efactor":[100.00,100.00],"tool":1,"probe":"535","fanPercent":[75.0,0.0],"fanRPM":0,"homed":[0,0,0],"fraction_printed":0.572}
The response is set as a single line with a newline character at the end. The meaning of the fields is:
status:  I=idle, P=printing from SD card, S=stopped (i.e. needs a reset), C=running config file, A=paused, D=pausing, R=resuming, B=busy (running a macro)
hstat:   status of the heaters, 0=off, 1=standby, 2=active, 3=fault
pos:     the X, Y and Z positions of the current tool (if a tool is selected), or the print head reference point if no tool is selected
efactor: the current extrusion factors (see M221 command)
tool:    the selected tool number. A negative number typically means no tool selected.
probe:   the Z-probe reading
fanPercent: the speeds of the controllable fans, in percent of maximum
fanRPM:  the cooling fan RPM
homed:   the homed status of the X, Y and Z axes (or towers on a delta). 0=axis has not been homed so position is not reliable, 1=axis has been homed so position is reliable.
timesLeft: an array of the estimated remaining print times (in seconds) calculated by different methods. These are currently based on the proportion of the file read,
           the proportion of the total filament consumed, and the proportion of the total layers already printed. Only present if a print from SD card is in progress.
seq:     the sequence number of the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater than that.
resp:    the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater.
The type 1 response comprises these fields plus some additional ones that do not generally change and therefore do not need to be fetched as often. The extra fields include:
For a more detailed comparison of type 2 - 5, see Proposed_RepRap_Duet_Status_Responses.
PanelDue currently uses only M408 S0 and M408 S1.
M420: Set RGB Colors as PWM and is also Enable/Disable Mesh Bed Leveling
Example: M420 R255 E255 B255
In marlin, is also: M420 - Enable/Disable Mesh Leveling (with current values) S1=enable S0=disable
M421: Set a Mesh Bed Leveling Z coordinate
M421 - Set a single Z coordinate in the Mesh Leveling grid. X<index> Y<index> Z<offset in mm>
M450: Report Printer Mode
No No ??? ??? ??? Yes No ??? ???
Usage: M450
Example: M450 Output: PrinterMode:FFF
Printers can be used for different task by exchanging the toolhead. Depending on the tool, a different behavior of some commands can be expected. This command reports the current working mode. Possible answers are:
PrinterMode:FFF
PrinterMode:Laser
PrinterMode:CNC
M451: Select FFF Printer Mode
Usage
M451
Example
M451
Output
PrinterMode:FFF
Switches to FFF mode for filament printing.
M452: Select Laser Printer Mode
Usage
M452
Example
M452
Output
PrinterMode:Laser
Switches to laser mode. This mode enables handling of a laser pin and makes sure that the laser is only activated during G1 moves if laser was enabled or E is increasing. G0 moves should never enable the laser. M3/M5 can be used to enable/disable the laser for moves.
M453: Select CNC Printer Mode
Usage
M453
Example
M453
Output
PrinterMode:CNC
Switches to CNC mode. In this mode M3/M4/M5 control the pins defined for the milling device.
M460: Define temperature range for thermistor controlled fan
Usage
M460 X<minTemp> Y<maxTemp>
Example
M460 X50 Y60
If the firmware has a thermistor controlled fan defined, you can set at which temperature the fan starts and from which temperature on it should run with maximum speed.
M500: Store parameters in EEPROM
Yes Yes ??? ??? ??? Yes ??? ??? ???
??? Yes No No No ??? No ??? ???
Example
M500
Save current parameters to EEPROM.
M501: Read parameters from EEPROM
Parameters
Snnn Enable auto-save (only RepRapFirmware)
Example
M501
Set the active parameters to those stored in the EEPROM. This is useful to revert parameters after experimenting with them.
RepRapFirmware allows "S1" to be passed, which forces parameters to be automatically saved to EEPROM when they are changed.
M502: Revert to the default "factory settings."
Example
M502
This command resets all tunable parameters to their default values, as set in the firmware. This doesn't reset any parameters stored in the EEPROM, so it must be followed with M500 if you want to do that.
M503: Print settings
Yes Yes ??? ??? ??? ??? ??? ??? ???
Example
M503
This command asks the firmware to reply with the current print settings stored in EEPROM. The reply output includes the G-Code commands to produce each setting. For example, the Steps Per Unit values are displayed as an M92 command.
RepRapFirmware outputs the content of the configuration file, but note that it may be truncated if it is too long.
M540: Enable/Disable "Stop SD Print on Endstop Hit"
Parameters
Snnn state, S1=enable, S0=disable
Example
M540 S1
M540: Set MAC address
Parameters
Pnnn The MAC address
Examples
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED
M540 PDE:AD:BE:EF:CA:FE
All devices running on the same network shall all have different MAC addresses. For your printers, changing the last digit is sufficient.
M550: Set Name
Parameters
Pnnn Machine name
Example
M550 PGodzilla
M551: Set Password
Parameters
Pnnn Password
Example
M551 Pmy-very-secret-word
Note for RepRapFirmware: If the specified password differs from the default one (i.e. reprap), the user will be asked to enter it when a connection is established via HTTP or Telnet. For FTP, the password must always be passed explicitly.
M552: Set IP address
Parameters
Pnnn IP address
Snnn Enable networking (optional)
Rnnn HTTP port (default 80)
Example
M552 P192.168.1.14
Sets the IP address of the RepRap machine to (in this case) 192.168.1.14. A restart may be required before the new IP address is used. If no 'P' field is specified, this echoes the existing IP address configured. If S0 is added thus: M552 S0 P192.168.1.14 networking is disabled. If you set the address M552 P0.0.0.0 the RepRap machine will try to obtain its IP address from the network's DHCP server, whereupon it will appear on the network with an address something like http://godzilla.home, where godzilla is the name set by the M550 command (see above). The precise URL incorporating that name will depend on the conventions of your network.
Recent RepRapFirmware versions allow the IP configuration to be changed without a restart.
M553: Set Netmask
Parameters
Pnnn Net mask
Example
M553 P255.255.255.0
Sets the network mask of the RepRap machine to (in this case) 255.255.255.0. A restart may be required before the new network mask is used. If no 'P' field is specified, this echoes the existing network mask configured.
M554: Set Gateway
Parameters
Pnnn Gateway
Example
M554 P192.168.1.1
Sets the Gateway IP address of the RepRap machine to (in this case) 192.168.1.1. A restart may be required before the new gateway IP address is used. If no 'P' field is specified, this echoes the existing Gateway IP address configured.
M555: Set compatibility
Parameters
Pnnn Emulation type
Example
M555 P1
For firmware that can do it, the firmware is set to a mode where its input and (especially) output behaves exactly like other established firmware. The value of the 'P' argument is:
P value Firmware
1 RepRap_Firmware
2 Marlin
3 Teacup
4 Sprinter
5 Repetier
M556: Axis compensation
Parameters
Snnn Height of the measured distances
Xnnn Deviation in X direction
Ynnn Deviation in Y direction
Znnn Deviation in Z direction
Example
M556 S100 X0.7 Y-0.2 Z0.6
Imaging denoting how to determine the S parameter for Gcode M556
M557: Set Z probe point
Parameters
Pnnn Probe point number
Xnnn X coordinate
Ynnn Y coordinate
Example
M557 P1 X30 Y40.5
M558: Set Z probe type
Parameters
Pnnn Z probe type
Xnnn Use probe for X axis
Ynnn Use probe for Y axis
Znnn Use probe for Z axis
Hnnn Dive height1
Fnnn Feed rate (i.e. probing speed)1
Tnnn Travel speed to probe points1
Snnn Extra parameter for experimentation (1)
Rnnn Extra parameter for experimentation (2)2
Example
M558 P0 X1 Y0 Z1
A Z probe may be a switch, an IR proximity sensor, or some other device. This selects which to use. P0 indicates that no Z probe is present. P1 gives an unmodulated IR probe, or any other probe type that emulates an unmodulated IR probe (probe output is an analog signal that rises with decreasing nozzle height above the bed). If there is a control signal to the probe, it is driven high when the probe type is P1. P2 specifies a modulated IR probe, where the modulation is commanded directly by the main board firmware using the control signal to the probe. P3 selects an alternative Z probe by driving the control signal to the probe low. P4 selects a switch for bed probing (on the Duet, this must be connected to the E0 endstop pins).
The X, Y and Z parameters specify whether each axis uses the Z probe for homing or not. If the parameter is nonzero, the Z probe is used for homing that axis. if the parameter is zero, the endstop switch for that axis is used for homing instead. See also G31 and G32.
Recent versions of RepRapFirmware support an additional parameter H. This specifies the dive height (default 3mm) from which probing is done in response to a G30 command when the P parameter is present, or a G32 command.
Notes
1These parameters are only supported by recent RepRapFirmware versions and should be specified in mm/min.
2This parameter used to specify the Z probe channel in RepRapFirmware, but it has been superceded by the functionality of "M115 Px". With older firmware versions and a Duet 0.7/0.85, this parameter should be 1.
Example
M559
M560: Upload web page file
Example
M560
<!-- **EoF** -->
M561: Set Identity Transform
Example
M561
M562: Reset temperature fault
Parameters
Pnnn Heater number
Example
M562 P2
M563: Define or remove a tool
Parameters
Pnnn Tool number
Dnnn Extruder drive(s)
Hnnn Heater(s)
Example
M563 P0 D0:2:3 H1:3
Tools are usually (though not necessarily) extruders. The 'P' field specifies the tool number. Tool numbers can have any positive integer value and 0. The 'D' field specifies the drive(s) used by the tool - in this case drives 0, 2 and 3. Drive 0 is the first drive in the machine after the movement drives (usually X, Y and Z). If there is no 'D' field the tool has no drives. The 'H' field specifies the tool's heaters - in this case heaters 1 and 3. Heater 0 is usually the hot bed (if any) so the first extruder heater is usually 1. If there is no H field the tool has no heaters.
Tools are driven using multiple values in the 'E' field of G1 commands, each controlling the corresponding drive in the 'D' field above, as follows:
G1 X90.6 Y13.8 E2.24:2.24:15.89
G1 X70.6 E0:0:42.4
The first line moves straight to the point (90.6, 13.8) extruding a total of 2.24mm of filament from both drives 0 and 2 and 15.98mm of filament from drive 3.
The second line moves back 20mm in X extruding 42.4mm of filament from drive 3.
Alternatively, if the slicer does not support generating G1 commands with multiple values for the extrusion amount, the M567 command can be used to define a tool mix ratio.
RepRapFirmware supports an additional form of the M563 command. The command:
M563 S1
means add 1 (the value of the S parameter) to all tool numbers found in the remainder of the current input stream (e.g. the current file if the command is read from a file on the SD card), or until a new M563 command of this form is executed. The purpose of this is to provide compatibility between systems in which tool numbers start at 1, and programs such as slic3r that assume tools are numbered from zero.
Recent versions of RepRapFirmware allow the deletion of existing tools if M563 is called in this way:
M563 P1 D-1 H-1
M564: Limit axes
Parameters
Snnn Limit movement within axis boundaries
Example
M564 S0
Allow moves outside the print volume, or not. If the S parameter is 0, then you can send G codes to drive the RepRap outside its normal working volume, and it will attempt to do so. User beware... If you set the S parameter to 1 then the RepRap will not think outside the box. The default behaviour is S = 1.
M565: Set Z probe offset
No see G31 ??? ??? ??? No Yes ??? ???
Example: M565 X3 Y4.5 Z-2.37
Set the offset from the extruder tip to the probe position. The X, Y and Z values are the delta between the extruder and the actual trigger position of the probe. If the probe trigger point is below the extruder (typical) the Z offset will be negative. This just records the point offset; it does not actually do the probing. See G32.
Parameters
Xnnn Maximum instantaneous speed change of the X axis
Ynnn Maximum instantaneous speed change of the Y axis
Znnn Maximum instantaneous speed change of the Z axis
Ennn Maximum instantaneous speed change of the extruder drives
Example
M566 X20 Y20 Z2 E10
Work around an algorithm limitation of some firmwares, which can't calculate step timings for a standing start. Teacup Firmware and Smoothieware don't have this limitation, so M566 is obsolete there.
M566 sets the speeds in mm/minute that axes can do from a standing start. If an accelerating algorithm starts a move with a zero velocity on other firmwares and then accelerates from that, it can give problems when the zero initial velocity is used to calculate a timestep between stepper pulses at the beginning: the timestep ends up being infinite... So these systems have initial small velocities to start at. This sets them.
Recent versions of RepRapFirmware don't have the limitation, but instead they use this parameter to determine the maximum allowable speed change of each motor when cornering.
M567: Set tool mix ratios
Parameters
Pnnn Tool number
Ennn Mix ratios
Example
M567 P2 E0.1:0.2:0.1:0.6
This example sets the mix ratio for tool 2 (the P value). When mixing is then turned on (see M568), only single E values need to be sent on a G1 command (any extra E values will be ignored, but are not illegal):
G1 X20 E1.3
See also M568.
Parameters
Pnnn Tool number
Snnn Whether mix ratios should be activated
Example
M568 P2 S0
G1 X20 E0.2:0.4:0.166:0.3
The off state is the default.
M569: Set axis direction and enable values
Parameters
Pnnn Drive number
Snnn Whether the drive should move forwards
Rnnn Drive enable polarity (default 0)1
Xnnn Map drive to X axis2
Ynnn Map drive to Y axis2
Znnn Map drive to Z axis2
Ennn Map drive to extruder drive2
Example
M569 P0 S1
Set the control value for the drive specified by P that sends it forwards to the given value in the S field. After sending the example, sending a 1 to X (drive 0) will make it go forwards, sending a 0 will make it go backwards. Obviously to be used with extreme caution...
Notes
1The 'R' parameter is not supported by all firmware, but in the dcnewman fork of RepRapFirmware and versions 1.09i and later of the dc42 fork, this sets the enable value -- logic level -- for the drive specified by P to the given value in the R field. Allowed 'R' values are 0 or 1. With the following example, drive 2 is enabled by sending an enable value of 0. Sending an enable value of 1 will disable the drive.
M569 P2 R0
You can use any combination of S XYZE and R parameters in a single M569 command. Values not provided are left unchanged.
2Some versions of RepRapFirmware up to and including version 1.13 allow drives to be remapped using this command. For example:
M569 P0 X0
Assigns driver 0 to control the X0 motor. In place of X0 you can use Y0 Z0 E0 E1 E2 etc. to assign the driver to the corresponding motor. Currently, only one driver can be allocated to each axis or extruder. From version 1.14 onward, use the M584 command to map drives to drivers instead.
M570: Set heater timeout
Parameters
Snnn Heater timeout (in seconds)
Example
M570 S120
After a heater has been switched on, wait 120 seconds for it to get close to the set temperature. If it takes longer than this, flag a heater fault.
M571: Set output on extrude
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
Parameters
Snnn Output value
Example
M571 S0.5
This turns the controlled fan 0 output on whenever extrusion is being done, and turns it off when the extrusion is finished. The output could control a fan or a stirrer or anything else that needs to work just when extrusion is happening. The S parameter sets the value of the PWM to the output. 0.0 is off; 1.0 is fully on. It also can be used to control a laser beam.
M572: Set or report extruder pressure advance
No dc42, ch, dn ??? ??? ??? No No ??? ???
Parameters
Dnnn Extruder number
Snnn Pressure advance amount (in seconds)
Example
M572 D0 S0.1
This sets the pressure advance coefficient (S parameter) for the specified extruder (D parameter). Supported by RepRapFirmware-dc42, -ch and -dn.
Pressure advance causes the extruder drive position to be advanced or retarded during printing moves by an additional amount proportional to the rate of extrusion. At the end of a move when the extrusion rate is decreasing, this may result in the extruder drive moving backwards (i.e. retracting). Therefore, if you enable this feature, you may need to reduce the amount of retraction you use in your slicing program to avoid over-retraction.
With Bowden extruders, an S value between 0.1 and 0.2 usually gives the best print quality.
Older versions of RepRapFirmware used the P parameter to specify the drive number, instead of using D to specify the extruder number.
M573: Report heater PWM
Parameters
Pnnn Heater number
Example
M573 P1
This gives a running average (usually taken over about five seconds) of the PWM to the heater specified by the P field. If you know the voltage of the supply and the resistance of the heater this allows you to work out the power going to the heater. Scale: 0 to 1.
Parameters
Xnnn Switch type for X axis
Ynnn Switch type for Y axis
Znnn Switch type for Z axis
Snnn Logic level
Example
M574 X1 Y2 Z0 S1
This defines the type of endstop switch or opto sensor that the printer has for each axis: 0 = none, 1 = low end, 2 = high end. The optional S parameter defines whether the endstop input is active high (S1, the default) or low (S0). Intended for use with boards that provide a single endstop input for each axis that may be used for either a high or a low end endstop, such as the Duet. Supported by RepRapFirmware. On delta printers, the XYZ parameters refer to the towers and the endstops should normally all be high end.
Parameters
Pnnn Serial channel number
Bnnn Baud rate
Snnn Whether checksums should be used
Example
M575 P1 B57600 S1
This sets the communications parameters of the serial comms channel specified by the P parameter. P0 specifies the main serial interface (typically a USB port, or serial-over-USB), while P1 specifies an auxiliary serial port (for example, the port used to connect a PanelDue). The B parameter is the required baud rate (this parameter is typically ignored if the port is a true USB port). The S parameter is a bitmap of features. The lowest bit, if set, specifies that only commands that include a valid checksum should be accepted from this comms channel.
M577: Wait until endstop is triggered
Parameters
Snnn Desired endstop level
Xnnn Select X axis endstop
Ynnn Select Y axis endstop
Znnn Select Z axis endstop
Ennn Select extruder drive endstop
Example
M577 E0 S1
Wait for an endstop switch to be pressed. The example above will wait until the first extruder endstop is triggered.
The following trigger types may be used using the 'S' parameter:
0: Endstop not hit 1: Low endstop hit 2: High endstop hit 3: Near endstop (only Z probe)
M578: Fire inkjet bits
Parameters
Pnnn Inkjet head number
Snnn Bit pattern
Example
M578 P3 S5
This fires inkjet head 3 (the P field) using the bit pattern specified by the S field. The example shown would fire bits 101. If the P parameter is ommitted inkjet 0 is assumed.
This is a version of the M700 command used by the Inkshield, but unfortunately M700 is already taken so cannot be used for that in the standard.
M579: Scale Cartesian axes
Parameters
Xnnn Scale factor for X axis
Ynnn Scale factor for Y axis
Znnn Scale factor for Z axis
Example
M579 X1.0127 Y0.998
On a Cartesian RepRap you can get prints exactly the right size by tweaking the axis steps/mm using the M92 G Code above. But this does not work so easily for Delta and other RepRaps for which there is cross-talk between the axes. This command allows you to adjust the X, Y, and Z axis scales directly. So, if you print a part for which the Y length should be 100mm and measure it and find that it is 100.3mm long then you set Y0.997 (= 100/100.3).
M580: Select Roland
Parameters
Rnnn Whether Roland mode should be activated
Pnnn Initial text to send to the Roland controller
Example
M580 R1 PVS4;!VZ2;!MC1;
This is not really anything to do with RepRap, but it is convenient. The little Roland mills are very widely available in hackerspaces and maker groups, but annoyingly they don't speak G Codes. As all RepRap firmware includes a G-Code interpreter, it is often easy to add functions to convert G Codes to Roland RML language. M580 selects a Roland device for output if the R field is 1, and returns to native mode if the R field is 0. The optional P string is sent to the Roland if R is 1. It is permissible to call this repeatedly with R set to 1 and different strings in the P field to communicate directly with a Roland.
M581: Configure external trigger
No dc42 ??? ??? ??? No No ??? ???
Parameters
Tnn Logical trigger number to associate the endstop input(s) with, from zero up to a firmware-specific maximum (e.g. 9 for RepRapFirmware)
X, Y, Z, E Selects endstop input(s) to monitor
P Reserved, may be used in future to allow general I/O pins to cause triggers
S Whether trigger occurs on a rising edge of that input (S1, default), falling edge (S0), or ignores that input (S-1). By default, all triggers ignore all inputs.
C Whether to trigger at any time (C0, default) or only when prointing a file from SD card (C1)
Example
M581 E1:2 S1 T2 C1  ; invoke trigger 2 when a rising edge is detected on the E1 or E2 endstop input and a file is being printed from SD card
When M581 is executed, if the T parameter is present but the other parameters are omitted, the trigger inputs and edge polarities for that trigger number are reported. Otherwise, the specified inputs and their polarities are added to the conditions that cause that trigger. Using S-1 with no X Y Z or E parameters sets the trigger back to ignoring all inputs.
In RepRapFirmware, trigger number 0 causes an emergency stop as if M999 had been received. Trigger number 1 causes the print to be paused as if M25 had been received. Any trigger number # greater then 1 causes the macro file sys/trigger#.g to be executed. Polling for further trigger conditions is suspended until the trigger macro file has been completed. RepRapFirmware does not wait for all queued moves to be completed before executing the macro, so you may wish to use the M400 command at the start of your macro file. If several triggers are pending, the one with the lowest trigger number takes priority.
M582: Check external trigger
Parameters
T Trigger number to poll
Example
M582 T2 ; check levels of inputs that give rise to trigger #2
Triggers set up by the M581 command are normally activated only when the specified inputs change state. This command provides a way of causing the trigger to be executed if the input is at a certain level. For each of the inputs associated with the trigger, the trigger condition will be checked as if the input had just changed from the opposite state to the current state.
For example, if you use M581 to support an out-of-filament sensor, then M582 allows you to check for out-of-filament just before starting a print.
M583: Wait for pin
No {soon} ??? ??? ??? No No ??? ???
Parameters
Pnnn Pin number
Sn State to wait for (0 or 1) or analogue tolerance
Rnnn Analogue value to wait for (between 0.0 and 1.0)
Example
M583 P5 S0 ; Wait for Pin 5 to become 0
This allows you, for example, to turn on a DC motor (see the M42 command) then wait until a switch connected to Pin Pnnn gives the value Sn.
If the R field is present, then the system waits until the value on analogue Pnnn is reached. In this case the S value is used as a tolerance, so M583 P8 R0.7 S0.01 would wait until the analogue value on Pin 8 was between 0.69 and 0.71.
M584: Set drive mapping
No Version 1.14 and later ??? ??? ??? No No ??? ???
Parameters
Xnnn Driver number(s) for X motor(s)
Ynnn Driver number(s) for Y motor(s)
Znnn Driver number(s) for Y motor(s)
Ennn Driver number(s) for E motor(s)
Snnn Special functions (to be defined, e.g. multiple independent X carriages, or Z motors driven independently for bed levelling)
Example
M584 X0 Y1 Z2:3 E4:5:6 ; Driver 0 controls the X motor, 1 controls the Y motor, 2 and 3 control the Z motors, 4 and 5 control the E motors
M600: Set line cross section
No No ??? ??? ??? ??? ??? ??? ???
Example: M600 P0.061
Sets the cross section for a line to extrude in velocity extrusion mode. When the extruder is enabled and movement is executed the amount of extruded filament will be calculated to match the specified line cross section.
M600: Filament change pause
Yes Use macro files instead ??? ??? ??? ??? ??? ??? ???
Example: M600
Pause for filament change X[pos] Y[pos] Z[relative lift] E[initial retract] L[later retract distance for removal].
Yes See M584 ??? ??? ??? ??? No ??? ???
Example: M605 S1
Sets the dual x-carriage movement mode: S<mode> [ X<duplication x-offset> R<duplication temp offset> ].
M605 S0: Full control mode. The slicer has full control over x-carriage movement M605 S1: Auto-park mode. The inactive head will auto park/unpark without slicer involvement M605 S2 [Xnnn] [Rmmm]: Duplication mode. The second extruder will duplicate the first with nnn millimeters x-offset and an optional differential hotend temperature of mmm degrees. E.g., with "M605 S2 X100 R2" the second extruder will duplicate the first with a spacing of 100mm in the x direction and 2 degrees hotter.
M665: Set delta configuration
Yes Yes ??? ??? ??? No Yes ??? ???
Parameters
Lnnn Diagonal rod length
Rnnn Delta radius
Snnn Segments per second1
Bnnn Safe printing radius2
Hnnn Nozzle height above the bed when homed after allowing for endstop corrections2
Xnnn X tower position correction3
Ynnn Y tower position correction3
Znnn Z tower position correction3
Examples
M665 L250 R160 S200 (Marlin)
M665 L250 R160 B80 H240 X0 Y0 Z0 (RepRapFirmware)
Set the delta calibration variables.
I don't think it's a good idea to have two different implementations for the same G-code, and I also question the practical value of specifying the print bed radius when defining a delta configuration, since many delta printers use a square or rectangular print bed. So perhaps we should stick to the Marlin-defined command as the definition for this command, and use a different command or set of commands to define print bed shape and size. --AndrewBCN (talk) 23:10, 31 January 2015 (PST)
The implementations are not different, they have the same L and R parameters, but each has additional parameters that are not relevant to the other implementation. I'm not against defining a new Gcode to define bed size and shape; however, you can already define the limits of a rectangular print area using M208. Even when a delta printer has a square bed, the printable area is not square. It is usually taken to be circular, although it is in reality more complicated. My purpose in adding the B parameter was to make it easy to define a radius outside which movement will not normally be attempted. I have changed "bed radius" to "safe printing radius" in the text to help clarify this. --dc42
Notes
1Only supported on Marlin.
2Only supported in RepRapFirmware.
3X, Y and Z tower angular offsets from the ideal (i.e. equilateral triangle) positions, in degrees, measured anti-clockwise looking down on the printer.
Yes Yes ??? ??? ??? Yes Yes ??? ???
Parameters
Xnnn X axis endstop adjustment
Ynnn Y axis endstop adjustment
Znnn Z axis endstop adjustment
Example
M666 X-0.1 Y+0.2 Z0
In RepRapFirmware and Repetier, positive endstop adjustments move the head closer to the bed when it is near the corresponding tower. In Marlin and Smoothieware, negative endstop corrections move the head closer to the bed when it is near the corresponding tower.
In Marlin, only negative endstop corrections are allowed.
In Repetier the endstop corrections are expressed in motor steps. In other firmwares they are expressed in mm.
M667: Select CoreXY mode
Parameters
Snnn CoreXY mode
Xnnn X axis scale factor
Ynnn Y axis scale factor
Znnn Z axis scale factor
Example
M667 S1
M667 S0 selects Cartesian mode (unless the printer is configured as a delta using the M665 command). Forward motion of the X motor moves the head in the +X direction. Similarly for the Y motor and Y axis, and the Z motor and Z axis. This is the default state of the firmware on power up.
M667 S1 selects CoreXY mode. Forward movement of the X motor moves the head in the +X and +Y directions. Forward movement of the Y motor moves the head in the -X and +Y directions.
M667 S2 selects CoreXZ mode. Forward movement of the X motor moves the head in the +X and +Z directions. Forward movement of the Z motor moves the head in the -X and +Z directions.
M667 S3 selects CoreYZ mode. Forward movement of the Y motor moves the head in the +Y and +Z directions. Forward movement of the Z motor moves the head in the -Y and +Z directions.
Additional parameters X, Y and Z may be given to specify factors to scale the motor movements by for the corresponding axes. For example, to specify a CoreXZ machine in which the Z axis moves 1/3 of the distance of the X axis for the same motor movement, use M667 S2 Z3. The default scaling factor after power up is 1.0 for all axes.
To change the motor directions, see the M569 command.
M668: Set Z-offset compensations polynomial
No dc42-cmm ??? ??? ??? No No ??? ???
Polynomial compensation is an experimental method to compensate for geometric distortion of a delta machine Z-plane. After the bed is compensated with the set of G30 points, there remains error. This method fits a 6th degree polynomial with independent origins for each order to the residual error data (using a simulated annealing technique on the host). The polynomial is communicated and controlled through M668. Because the polynomial takes many floating point operations to compute each point, the firmware builds a grid of values, and used bi-linear interpolation to adjust the actual Z-axis offset error estimate.
For the polynomial used, 40 parameters are specified. The I parameter allows the coefficients to be loaded a few at a time, which limits the size of the G-code string. The index starts with 1, not with 0.
M668 Ix S[list of values] sets the polynomial parameters starting at index x, if index present and != 0.
M668 R recomputes the grid based on the current parameters.
M668 P[0|1] turns off or on the polynomial compensation.
Typical use would be:
M668 I1 S4.882E-17:0.0 M668 I3 ... ... M668 R P1
Which sets the list, computes the interpolation grid, and then enables compensation.
M700: Level plate
bq No ??? ??? ??? No No ??? ???
??? No No No No ??? No ??? ???
Example: M700
M701: Load filament
1 only in bq-Marlin Firmware
Example: M701
M702: Unload filament
Example: M702
M851: Set Z-Probe Offset
Yes No ??? ??? ??? ??? ??? ??? ???
Sets the Z-Probe Offset saved in the EEPROM and this setting also works like M206 as well and this has priority over the z probe offset you set in marlin configuration.h setting
Example: M851 Z-4
The example above will set the z-probe offset EEPROM setting to -4mm below the nozzle and enables the nozzle travel 4mm lower than the probe triggered position. It is however, a good idea to keep the setting inside your configuration.h as well for your own future reference.
This command appears on pronterface after marlin dev 1.1.0, it is unknown that this command can be used on marlin 1.0.0
M906: Set motor currents
No Yes ??? ??? ??? No M907? ??? ???
??? No No No No Yes No ??? ???
Parameters
Xnnn X drive motor current
Ynnn Y drive motor current
Znnn Z drive motor current
Ennn E drive(s) motor current(s)
Innn Motor current idle factor (0..100)1
H1 Set/Get Motor currents used for the downward Z-probe homing movement 2
Example
M906 X300 Y500 Z200 E350:350
Notes
1RepRapFirmware supports an additional I parameter. This is the percentage of normal that the motor currents should be reduced to when the printer becomes idle but the motors have not been switched off. The default value is 30%.
2RepRapFirmware, DC42 version, cmm sub-version supports "H1", which sets the XYZ motor currents used during Z-probing temporarily to different (typically lower) value. If "H1" is specified, the homing current is set, otherwise it operates normally. The homing current should be specified after the main current is set. The actual motor current is not changed until the next Z-probe operation. Lower motor currents reduce vibration during Z-probe motions.
Yes Use M906 ??? ??? ??? Yes Yes ??? ???
Set digital trimpot motor current using axis codes (X, Y, Z, E, B, S). In Repetier, it sets the current in Percent. In Redeem, it sets the current in A (where M906 does in mA).
Yes No ??? ??? ??? Yes: 0.92 No ??? ???
M908 P<pin> S<current>
M909: Set microstepping
Use M350 Use M350 ??? ??? ??? Use M350 No ??? ???
Example: M909 X3 Y5 Z2 E3
Set the microstepping value for each of the steppers. In Redeem this is implemented as 2^value, so
M909 X2 sets microstepping on X-axis to 2^2 = 4,
M909 Y3 sets microstepping on Y-axis to 2^3 = 8 etc.
M910: Set decay mode
No No ??? ??? ??? No No ??? ???
Example: M910 X3 Y5 Z2 E3
Set the decay mode for each stepper controller The decay mode controls how the current is reduced and recycled by the H-bridge in the stepper motor controller. It varies how the implementations are done in silicone between controllers. Typically you have an on phase where the current flows in the target current, then an off phase where the current is reversed and then a slow decay phase where the current is recycled.
M911: Set power monitor threshold voltages
No Yes ??? ??? ??? No No ??? ???
??? No No No No No No ??? ???
Parameters
Pnnn Power monitor channel, default 0
Snnn Undervoltage threshold
Tnnn Overvoltage threshold
Example
M911 P0 S20 T27.5
Sets the minimum supply voltage for which correct operation of the printer mechanics is guaranteed and stepper motor positions are guaranteed to be held for all enabled drivers, and/or the maximum safe voltage above which sensitive parts of the machine should be shut down. M911 with no parameters or with just the P parameter reports the current thresholds.
M912: Set electronics temperature monitor adjustment
Parameters
Pnnn Temperature monitor channel, default 0
Snnn Value to be added to the temperature reading in degC
Example
M911 P0 S10.5
Many microcontrollers used to control 3D printers have built-in temperature monitors, but they normally need to be calibrated for temperature reading offset. The S parameter specifies the value that should be added to the raw temperature reading to provide a more accurate result.
M928: Start SD logging
Example: M928 filename.g
Ended by M29.
M997: Perform in-application firmware update
??? No No No No No No ??? No
Parameters
Snnn Firmware module number(s), default 0
Example
M997 S0:1 - update firmware modules 0 and 1
This command triggers a firmware update if the necessary files are present on the SD card. In RepRapFirmware on the Duet series, module numbers are as follows:
0 - main firmware, filename sys/RepRapFirmware.bin (Duet) or sys/DuetWiFiFirmware (Duet WiFi). File sys/iap.bin (Duet) or sys/iap4e.bin (Duet WiFi) must also be present.
1 - web server firmware, filename sys/DuetWiFiServer.bin
2 - web server file system, filename sys/DuetWebControl.bin
3 - put the WiFi module into bootloader mode, so that firmware can be uploaded directly via its serial port
M998: Request resend of line
Parameters
Pnnn Line number
Example
M998 P34
Request a resend of line 34. In some implementations the input-handling code overwrites the incoming G Code with this when it detects, for example, a checksum error. Then it leaves it up to the GCode interpreter to request the resend.
Parameters
This command can be used without any additional parameters.
Pnnn Reset flags1
Example
M999
Restarts the firmware using a software reset.
Notes
1The dc42 fork of RepRapFirmware not only resets the board but also puts the board into firmware upload mode if parameter PERASE is present.
Other commands
G: List all G-codes
??? No ??? ??? ??? ??? ??? ??? ???
??? ??? ??? ??? ??? Yes ??? ??? ???
Example: G
This lists all implemeted G-codes in the firmware with description and sends it back to the host.
M: List all M-codes
Example: M
This lists all implemeted M-codes in the firmware with description and sends it back to the host.
T: Select Tool
??? No ??? Yes ??? Yes Yes ??? ???
Parameters
Tool number
Example
T1
The sequence followed is:
  4. Use the new tool.
Selecting a non-existent tool (100, say) just does Step 1 above1. That is to say it leaves all tools in their standby state. You can, of course, use the G10 command beforehand to set that standby temperature to anything you like.
Some implementations (e.g. RepRapFirmware) allow you to specify tool-change G Code macros2. There are normally three specified (any of which can contain no commands if desired) that execute in this order:
  2. (Old tool is released);
With such implementations there is no wait for temperature stabilisation. That can be achieved by an M116 in any of the macros, of course.
After a reset tools will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0, M1 and M112 commands turn them all off. You can, of course, turn them all off with the M1 command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
Notes
1 For RepRapFirmware, selecting a non-existent tool also removes any X/Y/Z offset applied for the old tool.
2 Under special circumstances, the execution of those macro files may not be desired. RepRapFirmware 109p-ch allows the 'S0' parameter to be passed to prevent the execution of tool change macro files.
Marlin uses codes M500-M503 to manipulate EEPROM values.
xx can be one of:
ok
rs
On the latest version of Pronterface and soon Octoprint a special comment of the form:
// action:command
is allowed to be sent from the firmware, the command can currently be pause, resume or disconnect which will execute those commands on the host. As this is also a comment other hosts will just ignore these commands.
ok
start
Exceptions:
1. Marlin 1.0.0 Gen6 Firmware does not follow the two character rule. 'rs' is actually 'Resend' and '!!' is 'Error'. Example Lines:
  • Error: Line Number is not current line + 1. Last Line: 7
  • Resend: 8
  • Writing to File: print.gco
  • Done saving file.
  • File selected
2. The dc42 fork of RepRapFirmware responds to some commands with a reply string in JSON format, terminated by a newline. This allows later firmware revisions to include additional information without confusing clients (e.g. PanelDue) that do not expect it, and to make responses self-describing so that the client will not be confused if responses are delayed or lost. The commands affected are:
  • M105 S2
  • M105 S3
  • M20 S2
  • M36
  • M408
Problem to solve
When using Marlin firmware or emulating Marlin, each line of G-code sent from the host to the controller is answered with an ok before the next line can be sent without locking communications up. This slows down communication and limits the number of commands that can be sent per second to the printer controller, as the USB stack on the host and the serial interface driver on the Arduino add their own latencies (up to 10 milliseconds). This is not a problem for other controller electronics using native USB such as the Duet, because the standard serial-over-USB drivers provide flow control, so the host software can be configured so as not to wait for the ok.
Alternatives to G-code
