G-code
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications, too. See also on Wikipedia's G-code article.
There are a few different ways to prepare GCode for a printer. One is to use a slicer like Slic3r, Skeinforge or Cura. These programs take a CAD model, slice it into layers, and output the GCode required for each layer. Slicers are the easiest way to go from a 3D model to a printed part, but the user sacrifices some flexibility when using them. Another option for GCode generation is to use a lower level library like mecode. Libraries like mecode give you precise control over the tool path, and thus are useful if you have a complex print that is not suitable for naive slicing. The final option is to just write the GCode yourself. This may be the best choice if you just need to run a few test lines while calibrating your printer.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years. But this is the master page for RepRap. Nowhere in here should the same code be used for two different things; there are always more numbers to use... The rule is: add your new code here, then implement it.
But human nature being what it is, things aren't always done that way, so some multiple uses of the same code exist. The rule is that later appearances by them on this page than the original use of a code are deprecated and should be changed, unless there is a good technical reason (like the general G-Code standard) why a later instance should be prefered. Note that the key date is appearance here, not date of implementation.
- 1 Introduction
- 2 Fields
- 3 Comments
- 4 Special fields
- 5 Checking
- 6 Buffering
- 7 G-commands
- 7.1 G0 & G1: Move
- 7.2 G2 & G3: Controlled Arc Move
- 7.3 G4: Dwell
- 7.4 G6: Direct Stepper Move
- 7.5 G10: Tool Offset
- 7.6 G10: Retract
- 7.7 G11: Unretract
- 7.8 G17..19: Plane Selection (CNC specific)
- 7.9 G20: Set Units to Inches
- 7.10 G21: Set Units to Millimeters
- 7.11 G22 & G23: Firmware controlled Retract/Precharge
- 7.12 G28: Move to Origin (Home)
- 7.13 G29: Detailed Z-Probe
- 7.14 G29.1: Set Z probe head offset
- 7.15 G29.2: Set Z probe head offset calculated from toolhead position
- 7.16 G30: Single Z-Probe
- 7.17 G31: Set or Report Current Probe status
- 7.18 G31: Dock Z Probe sled
- 7.19 G32: Probe Z and calculate Z plane
- 7.20 G32: Undock Z Probe sled
- 7.21 G33: Measure/List/Adjust Distortion Matrix
- 7.22 G38.x Straight Probe (CNC specific)
- 7.23 G40: Compensation Off (CNC specific)
- 7.24 G54..59: Coordinate System Select (CNC specific)
- 7.25 G60: save current position to slot
- 7.26 G61: Apply/restore saved coordinates to the active extruder.
- 7.27 G80: Cancel Canned Cycle (CNC specific)
- 7.28 G90: Set to Absolute Positioning
- 7.29 G91: Set to Relative Positioning
- 7.30 G92: Set Position
- 7.31 G93: Feed Rate Mode (Inverse Time Mode) (CNC specific)
- 7.32 G94: Feed Rate Mode (Units per Minute) (CNC specific)
- 7.33 G100: Calibrate floor or rod radius
- 7.34 G130: Set digital potentiometer value
- 7.35 G131: Remove offset
- 7.36 G132: Calibrate endstop offsets
- 7.37 G133: Measure steps to top
- 7.38 G161: Home axes to minimum
- 7.39 G162: Home axes to maximum
- 8 M-commands
- 8.1 M0: Stop or Unconditional stop
- 8.2 M1: Sleep or Conditional stop
- 8.3 M2: Program End
- 8.4 M3: Spindle On, Clockwise (CNC specific)
- 8.5 M4: Spindle On, Counter-Clockwise (CNC specific)
- 8.6 M5: Spindle Off (CNC specific)
- 8.7 M6: Tool change
- 8.8 M7: Mist Coolant On (CNC specific)
- 8.9 M8: Flood Coolant On (CNC specific)
- 8.10 M9: Coolant Off (CNC specific)
- 8.11 M10: Vacuum On (CNC specific)
- 8.12 M11: Vacuum Off (CNC specific)
- 8.13 M17: Enable/Power all stepper motors
- 8.14 M18: Disable all stepper motors
- 8.15 M20: List SD card
- 8.16 M21: Initialize SD card
- 8.17 M22: Release SD card
- 8.18 M23: Select SD file
- 8.19 M24: Start/resume SD print
- 8.20 M25: Pause SD print
- 8.21 M26: Set SD position
- 8.22 M27: Report SD print status
- 8.23 M28: Begin write to SD card
- 8.24 M29: Stop writing to SD card
- 8.25 M30: Delete a file on the SD card
- 8.26 M31: Output time since last M109 or SD card start to serial
- 8.27 M32: Select file and start SD print
- 8.28 M33: Get the long name for an SD card file or folder
- 8.29 M33: Stop and Close File and save restart.gcode
- 8.30 M34: Set SD file sorting options
- 8.31 M35: Upload firmware NEXTION from SD
- 8.32 M36: Return file information
- 8.33 M37: Simulation mode
- 8.34 M38 Compute SHA1 hash of target file
- 8.35 M40: Eject
- 8.36 M41: Loop
- 8.37 M42: Switch I/O pin
- 8.38 M43: Stand by on material exhausted
- 8.39 M43: Pin report and debug
- 8.40 M48: Measure Z-Probe repeatability
- 8.41 M70: Display message
- 8.42 M72: Play a tone or song
- 8.43 M73: Set build percentage
- 8.44 M80: ATX Power On
- 8.45 M81: ATX Power Off
- 8.46 M82: Set extruder to absolute mode
- 8.47 M83: Set extruder to relative mode
- 8.48 M84: Stop idle hold
- 8.49 M85: Set inactivity shutdown timer
- 8.50 M92: Set axis_steps_per_unit
- 8.51 M93: Send axis_steps_per_unit
- 8.52 M98: Call Macro/Subprogram
- 8.53 M99: Return from Macro/Subprogram
- 8.54 M98: Get axis_hysteresis_mm
- 8.55 M99: Set axis_hysteresis_mm
- 8.56 M101: Turn extruder 1 on (Forward), Undo Retraction
- 8.57 M102: Turn extruder 1 on (Reverse)
- 8.58 M103: Turn all extruders off, Extruder Retraction
- 8.59 M104: Set Extruder Temperature
- 8.60 M105: Get Extruder Temperature
- 8.61 M106: Fan On
- 8.62 M107: Fan Off
- 8.63 M108: Cancel Heating (Marlin)
- 8.64 M108: Set Extruder Speed (BFB)
- 8.65 M109: Set Extruder Temperature and Wait
- 8.66 M110: Set Current Line Number
- 8.67 M111: Set Debug Level
- 8.68 M112: Emergency Stop
- 8.69 M113: Set Extruder PWM
- 8.70 M114: Get Current Position
- 8.71 M115: Get Firmware Version and Capabilities
- 8.72 M116: Wait
- 8.73 M117: Get Zero Position
- 8.74 M117: Display Message
- 8.75 M118: Negotiate Features
- 8.76 M119: Get Endstop Status
- 8.77 M120: Push
- 8.78 M121: Pop
- 8.79 M120: Enable endstop detection
- 8.80 M121: Disable endstop detection
- 8.81 M122: Diagnose
- 8.82 M123: Tachometer value
- 8.83 M124: Immediate motor stop
- 8.84 M126: Open Valve
- 8.85 M127: Close Valve
- 8.86 M128: Extruder Pressure PWM
- 8.87 M129: Extruder pressure off
- 8.88 M130: Set PID P value
- 8.89 M131: Set PID I value
- 8.90 M132: Set PID D value
- 8.91 M133: Set PID I limit value
- 8.92 M134: Write PID values to EEPROM
- 8.93 M135: Set PID sample interval
- 8.94 M136: Print PID settings to host
- 8.95 M140: Set Bed Temperature (Fast)
- 8.96 M141: Set Chamber Temperature (Fast)
- 8.97 M142: Holding Pressure
- 8.98 M143: Maximum hot-end temperature
- 8.99 M144: Bed Standby
- 8.100 M146: Set Chamber Humidity
- 8.101 M149: Set temperature units
- 8.102 M150: Set display color
- 8.103 M155: Automatically send temperatures
- 8.104 M160: Number of mixed materials
- 8.105 M163: Set weight of mixed material
- 8.106 M164: Store weights
- 8.107 M165: Set multiple mix weights
- 8.108 M190: Wait for bed temperature to reach target temp
- 8.109 M191: Wait for chamber temperature to reach target temp
- 8.110 M200: Set filament diameter
- 8.111 M201: Set max printing acceleration
- 8.112 M202: Set max travel acceleration
- 8.113 M203: Set maximum feedrate
- 8.114 M204: Set default acceleration
- 8.115 M205: Advanced settings
- 8.116 M206: Offset axes
- 8.117 M206 in Repetier: Set eeprom value
- 8.118 M207: Calibrate z axis by detecting z max length
- 8.119 M207: Set retract length
- 8.120 M208: Set axis max travel
- 8.121 M208: Set unretract length
- 8.122 M209: Enable automatic retract
- 8.123 M210: Set homing feedrates
- 8.124 M211: Disable/Enable software endstops
- 8.125 M212: Set Bed Level Sensor Offset
- 8.126 M218: Set Hotend Offset
- 8.127 M220: Set speed factor override percentage
- 8.128 M221: Set extrude factor override percentage
- 8.129 M220: Turn off AUX V1.0.5
- 8.130 M221: Turn on AUX V1.0.5
- 8.131 M222: Set speed of fast XY moves
- 8.132 M223: Set speed of fast Z moves
- 8.133 M224: Enable extruder during fast moves
- 8.134 M225: Disable on extruder during fast moves
- 8.135 M226: Gcode Initiated Pause
- 8.136 M226: Wait for pin state
- 8.137 M227: Enable Automatic Reverse and Prime
- 8.138 M228: Disable Automatic Reverse and Prime
- 8.139 M229: Enable Automatic Reverse and Prime
- 8.140 M230: Disable / Enable Wait for Temperature Change
- 8.141 M231: Set OPS parameter
- 8.142 M232: Read and reset max. advance values
- 8.143 M240: Trigger camera
- 8.144 M240: Start conveyor belt motor / Echo off
- 8.145 M241: Stop conveyor belt motor / echo on
- 8.146 M245: Start cooler
- 8.147 M246: Stop cooler
- 8.148 M250: Set LCD contrast
- 8.149 M251: Measure Z steps from homing stop (Delta printers)
- 8.150 M260: i2c Send Data
- 8.151 M261: i2c Request Data
- 8.152 M280: Set servo position
- 8.153 M300: Play beep sound
- 8.154 M301: Set PID parameters
- 8.155 M302: Allow cold extrudes
- 8.156 M303: Run PID tuning
- 8.157 M304: Set PID parameters - Bed
- 8.158 M305: Set thermistor and ADC parameters
- 8.159 M306: Set home offset calculated from toolhead position
- 8.160 M307: Set or report heating process parameters
- 8.161 M320: Activate autolevel (Repetier)
- 8.162 M321: Deactivate autolevel (Repetier)
- 8.163 M322: Reset autolevel matrix (Repetier)
- 8.164 M323: Distortion correction on/off (Repetier)
- 8.165 M340: Control the servos
- 8.166 M350: Set microstepping mode
- 8.167 M351: Toggle MS1 MS2 pins directly
- 8.168 M355: Turn case lights on/off
- 8.169 M360: Report firmware configuration
- 8.170 SCARA calibration codes (Morgan)
- 8.171 M360: Move to Theta 0 degree position
- 8.172 M361: Move to Theta 90 degree position
- 8.173 M362: Move to Psi 0 degree position
- 8.174 M363: Move to Psi 90 degree position
- 8.175 M364: Move to Psi + Theta 90 degree position
- 8.176 M365: SCARA scaling factor
- 8.177 M366: SCARA convert trim
- 8.178 M370: Morgan manual bed level - clear map
- 8.179 M371: Move to next calibration position
- 8.180 M372: Record calibration value, and move to next position
- 8.181 M373: End bed level calibration mode
- 8.182 M374: Save calibration grid
- 8.183 M375: Display matrix / Load Matrix
- 8.184 M380: Activate solenoid
- 8.185 M381: Disable all solenoids
- 8.186 M400: Wait for current moves to finish
- 8.187 M401: Lower z-probe
- 8.188 M402: Raise z-probe
- 8.189 M404: Filament width and nozzle diameter
- 8.190 M405: Filament Sensor on
- 8.191 M406: Filament Sensor off
- 8.192 M407: Display filament diameter
- 8.193 M408: Report JSON-style response
- 8.194 M420: Set RGB Colors as PWM (MachineKit)
- 8.195 M420: Enable/Disable Mesh Leveling (Marlin)
- 8.196 M421: Set a Mesh Bed Leveling Z coordinate
- 8.197 M450: Report Printer Mode
- 8.198 M451: Select FFF Printer Mode
- 8.199 M452: Select Laser Printer Mode
- 8.200 M453: Select CNC Printer Mode
- 8.201 M460: Define temperature range for thermistor controlled fan
- 8.202 M500: Store parameters in EEPROM
- 8.203 M501: Read parameters from EEPROM
- 8.204 M502: Revert to the default "factory settings."
- 8.205 M503: Print settings
- 8.206 M530: Enable printing mode
- 8.207 M531: Set print name
- 8.208 M532: Set print progress
- 8.209 M540: Enable/Disable "Stop SD Print on Endstop Hit"
- 8.210 M540: Set MAC address
- 8.211 M550: Set Name
- 8.212 M551: Set Password
- 8.213 M552: Set IP address
- 8.214 M553: Set Netmask
- 8.215 M554: Set Gateway
- 8.216 M555: Set compatibility
- 8.217 M556: Axis compensation
- 8.218 M557: Set Z probe point or define probing grid
- 8.219 M558: Set Z probe type
- 8.220 M559: Upload configuration file
- 8.221 M560: Upload web page file
- 8.222 M561: Set Identity Transform
- 8.223 M562: Reset temperature fault
- 8.224 M563: Define or remove a tool
- 8.225 M564: Limit axes
- 8.226 M565: Set Z probe offset
- 8.227 M566: Set allowable instantaneous speed change
- 8.228 M567: Set tool mix ratios
- 8.229 M568: Turn off/on tool mix ratios
- 8.230 M569: Set axis direction and enable values
- 8.231 M570: Configure heater fault detection
- 8.232 M571: Set output on extrude
- 8.233 M572: Set or report extruder pressure advance
- 8.234 M573: Report heater PWM
- 8.235 M574: Set endstop configuration
- 8.236 M575: Set serial comms parameters
- 8.237 M577: Wait until endstop is triggered
- 8.238 M578: Fire inkjet bits
- 8.239 M579: Scale Cartesian axes
- 8.240 M580: Select Roland
- 8.241 M581: Configure external trigger
- 8.242 M582: Check external trigger
- 8.243 M583: Wait for pin
- 8.244 M584: Set drive mapping
- 8.245 M585: Probe Tool
- 8.246 M590: Report current tool type and index
- 8.247 M600: Set line cross section
- 8.248 M600: Filament change pause
- 8.249 M605: Set dual x-carriage movement mode
- 8.250 M665: Set delta configuration
- 8.251 M666: Set delta endstop adjustment
- 8.252 M667: Select CoreXY mode
- 8.253 M668: Set Z-offset compensations polynomial
- 8.254 M700: Level plate
- 8.255 M701: Load filament
- 8.256 M702: Unload filament
- 8.257 M703: Get Board Type
- 8.258 M710: Erase the EEPROM and reset the board
- 8.259 M800: Fire start print procedure
- 8.260 M801: Fire end print procedure
- 8.261 M851: Set Z-Probe Offset
- 8.262 M905: Set local date and time
- 8.263 M906: Set motor currents
- 8.264 M907: Set digital trimpot motor
- 8.265 M908: Control digital trimpot directly
- 8.266 M909: Set microstepping
- 8.267 M910: Set decay mode
- 8.268 M911: Set power monitor threshold voltages
- 8.269 M912: Set electronics temperature monitor adjustment
- 8.270 M913: Set motor percentage of normal current
- 8.271 M928: Start SD logging
- 8.272 M997: Perform in-application firmware update
- 8.273 M998: Request resend of line
- 8.274 M999: Restart after being stopped by error
- 9 Other commands
- 10 Proposed EEPROM configuration codes
- 11 Replies from the RepRap machine to the host computer
- 12 Proposal for sending multiple lines of G-code
- 13 Alternatives to G-code
Introduction
N3 T0*57 N4 G92 E0*67 N5 G28*22 N6 G1 F1500.0*82 N7 G1 X2.0 Y2.0 F3000.0*85 N8 G1 X3.0 Y3.0*33
Gcode can also be stored in files on SD cards. A file containing RepRap Gcode usually has the extension .g, .gco or .gcode. Files for BFB/RapMan have the extension .bfb. Gcode stored in file or produced by a slicer might look like this:
G92 E0 G28 G1 F1500 G1 X2.0 Y2.0 F3000 G1 X3.0 Y3.0
Slicers will (optionally?) add GCode scripts to the beginning and end of their output file to perform specified actions before and/or after a print such as z-probing the build-area, heating/cooling the bed and hotend, performing ooze free "nozzle wipe" startup routine, switching system power on/off, and even "ejecting" parts. More info on the Start GCode routines and End GCode routines pages.
Support | Marlin | RepRapFirmware | Klipper | Prusa | Buddy | Repetier | Smoothie | Druid | MK4duo |
Partial | ??? | ??? | ??? | ??? | Experimental | deprecated | ??? | Partial | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | MakerBot | |
??? | No | ??? | Yes | ??? | Yes | automatic | ??? | ??? |
Here means:
- {{yes}}
- The Gcode is fully supported by the firmware.
- {{partial}} or {{experimental}}
- There is some support for the Gcode. Often it is required to check out the source code branch for the firmware (usually stored in a different branch) or to flip configuration switches on the mainboard.
- automatic
- The firmware handles this Gcode automatically, so there's no need to send the command. An example is power supply on/off Gcode (M80/M81) in the Teacup firmware.
- It is unknown if the firmware supports this Gcode. You may want to test this yourself before using it in production.
- {{no}}
- The firmware does not support this Gcode.
- deprecated
- The firmware deprecated this Gcode. The firmware author(s) should amend the deprecated Gcode on this page with workarounds (if needed) and the last supported firmware version that will accept this Gcode.
Fields
A RepRap Gcode is a list of fields that are separated by white spaces or line breaks. A field can be interpreted as a command, parameter, or for any other special purpose. It consists of one letter directly followed by a number, or can be only a stand-alone letter (Flag). The letter gives information about the meaning of the field (see the list below in this section). Numbers can be integers (128) or fractional numbers (12.42), depending on context. For example, an X coordinate can take integers (X175) or fractionals (X17.62), but selecting extruder number 2.76 would make no sense. In this description, the numbers in the fields are represented by nnn as a placeholder.
In RepRapFirmware, some parameters can be followed by more than one number, with colon used to separate them. Typically this is used to specify extruder parameters, with one value provided per extruder. If only one value is provided where a value is needed for each extruder, then that value is applied to all extruders.
Letter | Meaning |
Gnnn | Standard GCode command, such as move to a point |
Mnnn | RepRap-defined command, such as turn on a cooling fan |
Tnnn | Select tool nnn. In RepRap, a tool is typically associated with a nozzle, which may be fed by one or more extruders. |
Snnn | Command parameter, such as time in seconds; temperatures; voltage to send to a motor |
Pnnn | Command parameter, such as time in milliseconds; proportional (Kp) in PID Tuning |
Xnnn | A X coordinate, usually to move to. This can be an Integer or Fractional number. |
Ynnn | A Y coordinate, usually to move to. This can be an Integer or Fractional number. |
Znnn | A Z coordinate, usually to move to. This can be an Integer or Fractional number. |
U,V,W | Additional axis coordinates (RepRapFirmware) |
Innn | Parameter - X-offset in arc move; integral (Ki) in PID Tuning |
Jnnn | Parameter - Y-offset in arc move |
Dnnn | Parameter - used for diameter; derivative (Kd) in PID Tuning |
Hnnn | Parameter - used for heater number in PID Tuning |
Fnnn | Feedrate in mm per minute. (Speed of print head movement) |
Rnnn | Parameter - used for temperatures |
Qnnn | Parameter - not currently used |
Ennn | Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to consume. |
Nnnn | Line number. Used to request repeat transmission in the case of communications errors. |
*nnn | Checksum. Used to check for communications errors. |
Comments
Gcode comments begin at a semicolon, and end at the end of the line:
N3 T0*57 ; This is a comment N4 G92 E0*67 ; So is this N5 G28*22
Special fields
N: Line number
Yes | Yes | ??? | ??? | ??? | Yes | ??? | ??? | Yes | |
? | Yes | ??? | Yes | Yes | Yes | Yes | ??? | ??? |
Example: N123
If checking is supported, the RepRap firmware expects line numbers to increase by 1 each line, and if that doesn't happen it is flagged as an error. But you can reset the count using M110 (see below).
*: Checksum
? | Yes | ??? | Yes | ??? | No | Yes | ??? | ??? |
Example: *71
If checking is supported, the RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
Checking
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
int cs = 0; for(i = 0; cmd[i] != '*' && cmd[i] != NULL; i++) cs = cs ^ cmd[i]; cs &= 0xff; // Defensive programming...
Buffering
Yes | Yes | ??? | ??? | ??? | ??? | ??? | ??? | Yes | |
Yes | ??? | ??? | Yes | ??? | Yes | Yes | ??? | ??? |
RepRapFirmware also implements an internal queue to ensure that certain codes (like M106) are executed in the right order and not when the last move has been added to the look-ahead queue. This feature is not available in RepRapFirmware-dc42.
G-commands
G0 & G1: Move
Yes | Yes | ??? | ??? | ??? | Yes | Yes | ??? | Yes | |
Yes | Yes | Yes | Yes | Yes | Yes | Yes | ??? | Yes |
- G0 : Rapid linear Move
- G1 : Linear Move
- Usage
- G0 Xnnn Ynnn Znnn Ennn Fnnn Snnn
- G1 Xnnn Ynnn Znnn Ennn Fnnn Snnn
- Parameters
- Not all parameters need to be used, but at least one has to be used
- Xnnn The position to move to on the X axis
- Ynnn The position to move to on the Y axis
- Znnn The position to move to on the Z axis
- Ennn The amount to extrude between the starting point and ending point
- Fnnn The feedrate per minute of the move between the starting point and ending point (if supplied)
- Snnn Flag to check if an endstop was hit (S1 to check, S0 to ignore, S2 see note, default is S0)1
- Examples
- G0 X12 (move to 12mm on the X axis)
- G0 F1500 (Set the feedrate to 1500mm/minute)
- G1 X90.6 Y13.8 E22.4 (Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material)
1. G1 F1500 2. G1 X50 Y25.3 E22.4
In the above example, we set the feedrate to 1500mm/minute on line 1, then move to 50mm on the X axis and 25.3mm on the Y axis while extruding 22.4mm of filament between the two points.
1. G1 F1500 2. G1 X50 Y25.3 E22.4 F3000
However, in the above example, we set a feedrate of 1500 mm/minute on line 1, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X and Y movement, so everything stays synchronized.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in such a way that ensures that everything moves smoothly together, and the right volume of material is extruded at all points.3
- Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S parameter in this way, as damage may occur if you assume incorrectly. In RepRapFirmware, using the S1 or S2 parameter on a delta printer causes the XYZ parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1.
4RepRapFirmware provides an additional 'R1' parameter to tell the machine to go back to the coordinates a print was previously paused at. If this parameter is used and the code contains axis letters, an offset will be added to the pause coordinates (e.g. G1 R1 Z5).
Yes1 | No | ??? | ??? | ??? | Yes | Yes | ??? | Yes | |
Yes | Yes | No | No | Yes | Experimental | No | ??? | ??? |
- Usage
- G2 Xnnn Ynnn Innn Jnnn Ennn Fnnn (Clockwise Arc)
- G3 Xnnn Ynnn Innn Jnnn Ennn Fnnn (Counter-Clockwise Arc)
- Parameters
- Innn The point in X space from the current X position to maintain a constant distance from
- Jnnn The point in Y space from the current Y position to maintain a constant distance from
- Examples
- G2 X90.6 Y13.8 I5 J10 E22.4 (Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
- G3 X90.6 Y13.8 I5 J10 E22.4 (Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
- Notes
1In Marlin Firmware not implemented for DELTA and SCARA printers.
G4: Dwell
Pause the machine for a period of time.
- Parameters
- Pnnn Time to wait, in milliseconds
- Snnn Time to wait, in seconds (Only on Repetier, Marlin, Smoothieware, and RepRapFirmware 1.16 and later)
- Example
- G4 P200
On Marlin, Smoothie and RepRapFirmware, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
No | No | ??? | ??? | ??? | No | No | ??? | No | |
No | No | No | No | No | No | No | ??? | No |
Perform a direct, uninterpolated, and non-kinematic synchronized move of one or more steppers directly. Units may be linear (e.g., mm or inches on DELTA
) or specified in degrees (SCARA). This command is useful for initialization, diagnostics, and calibration, and should be disabled on production equipment. This type of move can be potentially dangerous, especially for deltabots, so implementations should do their best to limit movement to prevent twerking and damaging the carriage assembly.
- Parameters
- Annn Stepper A position or angle
- Bnnn Stepper B position or angle
- Cnnn Stepper C position or angle
- R Relative move flag
- SCARA Examples
- G6 A45 ; Move SCARA A stepper to the 45° position
- G6 B20 R ; Move SCARA B stepper 20° counter-clockwise
- DELTA Example
- G6 C10 R ; Move DELTA C carriage up by 10mm
G10: Tool Offset
No | Yes | ??? | ??? | ??? | No | No | ??? | No | |
??? | No | No | No | Yes | No | No | ??? | ??? |
- Usage
- G10 Pnnn Xnnn Ynnn Znnn Rnnn Snnn1
- Parameters
- Pnnn Tool number
- Xnnn X offset
- Ynnn Y offset
- U,V,Wnnn U, V and W axis offsets5
- Znnn Z offset2
- Rnnn Standby temperature(s)
- Snnn Active temperature(s)
- Examples
- G10 P2 X17.8 Y-19.3 Z0.0 (sets the offset for tool (or in older implementations extrude head) 2 to the X, Y, and Z values specified)
- G10 P1 R140 S205 (set standby and active temperatures3 for tool 1)
See also M585.
- Notes
1Marlin uses G10/G11 for executing a retraction/unretraction move. The RepRapPro version of Marlin supports G10 for tool offset. Smoothie uses G10 for retract and G10 Ln for setting workspace coordinates.
2It's usually a bad idea to put a non-zero Z value in as well unless the tools are loaded and unloaded by some sort of tool changer or are on indepedent carriages. When all the tools are in the machine at once they should all be set to the same Z height.
4The NIST G-code standard mentions an additional L parameter, which is ignored (except in smoothie). This command is subject to discussion.
5Tool offsets are applied after any X axis mapping has been performed. Therefore if for example you map X to U in your M563 command to create the tool, you should specify a U offset not an X offset. If you map X to both X and U, you can specify both offsets.
G10: Retract
Yes | dc42,ch | ??? | ??? | ??? | Yes: 0.92 | Yes | ??? | Yes | |
??? | No | No | No | No | No | No | ??? | ??? |
- Parameters
- Snnn retract length (S1 = long retract, S0 = short retract = default) (Repetier only)
- Example
- G10
Retracts filament according to settings of M207 (Marlin, RepRapFirmware) or according to the S value (Repetier).
RepRapFirmware recognizes G10 as a command to set tool offsets and/or temperatures if the P parameter is present, and as a retraction command if it is absent.
G11: Unretract
- Parameters
- Example
- G11
Unretracts/recovers filament according to settings of M208 (Marlin, RepRapFirmware) or according to the S value (Repetier).
No | No | ??? | ??? | ??? | ??? | ??? | ??? | No | |
Yes | ??? | ??? | ??? | Yes | No | ??? | ??? | ??? |
- G17 : XY (default)
- G18 : ZX
- G19 : YZ
Yes | Yes | No | Yes | Yes | No | Yes | ??? | ??? |
- Example
- G20
Yes | Yes | Yes | Yes | Yes | Yes | Yes | ??? | ??? |
- Example
- G21
- Usage
- G22 ; Retract
- G23 ; Unretract/Precharge
Relying on machine's firmware to execute extrusion retract/precharge move, instead of having slicer generating to E axis G1 movement. The retract/precharge length, velocity is handled by the machine firmware.
Yes | Yes | ??? | ??? | ??? | Yes | Yes | ??? | Yes1 | |
- Parameters
- This command can be used without any additional parameters.
- X Flag to go back to the X axis origin
- Y Flag to go back to the Y axis origin
- Z Flag to go back to the Z axis origin
- Examples
G28 ; Home all axes G28 X Z ; Home the X and Z axes
When the firmware receives this command, it quickly moves the specified axes (or all axes if none are given) to the endstops, backs away from each endstop by a short distance, and slowly bumps the endstop again to increase positional accuracy. This process, known as "Homing", is required to determine the position of the print carriage(s). Some firmware may even forbid movement away from endstops and other operations until the axes have been homed.
The X, Y, and Z parameters act only as flags. Any coordinates given are ignored. For example, G28 Z10
results in the same behavior as G28 Z
. Delta printers cannot home individual axes, but must always home all three towers, so the X Y Z parameters are simply ignored on these machines.
Marlin firmware (version 1.1.0 and up) provides an option called Z_SAFE_HOMING
for printers that use a Z probe to home Z instead of an endstop. With this option, the XY axes are homed first, then the carriage moves to a position –usually the middle of the bed– where it can safely probe downward to home Z.
RepRapFirmware uses macro files to home either all axes or individual axes. If all axes are homed, the file homeall.g
is processed. For individual axes the homex.g
, homey.g
, or homez.g
file will be used. On Delta printers, G28 command will always home all three towers by processing the homedelta.g
file, regardless of any X Y Z parameters.
Because the behavior of G28 is unspecified, it is recommended not to automatically include G28 in your ending GCode. On a Cartesian this will result in damaging the printed object. If you need to move the carriage at the completion of a print, use G0 or G1.
- Notes
1 MK4duo has a B parameter that tells the printer to return to the coordinates it was at before homing.
Yes | Yes, 1.17 and later | ??? | ??? | ??? | Yes: 0.91.7 | No, see G32 | ??? | Yes | |
??? | No | No | No | Yes | Yes | No | ??? | ??? |
This command uses a probe to measure the bed height at 3 or more points to determine its tilt and overall flatness. It then enables compensation so that the nozzle will remain parallel to the bed. The printer must be homed with G28 before using this command.
Each firmware behaves differently and depends on the type of bed leveling that's been configured. For example, Marlin 1.0.2 provides 3 different types of automatic bed leveling (probe required) and a manual bed leveling option. See your firmware's documentation for the specific options available.
- Usage
- G29
- G29 Snnn
- Parameters
- Snnn Firmware-dependent behavior
- Pfile.csv Optional file name for bed height map file (RepRapFirmware only)
- Examples
G29 ; Probe the bed and enable compensation G29 S2 ; Special operation - see below
G29 Auto Bed Leveling in Marlin
Marlin 1.0.2 and earlier provides three options for automatic bed leveling:
- The 3-point method probes the bed at three points to produce a matrix, adjusting for a flat but tilted bed.
- The planar grid method (non-Delta) probes a grid pattern to produce a matrix by the "least-squares" method, adjusting for a flat but tilted bed.
- The bilinear grid method (Delta only) probes a grid pattern to produce a mesh, using bilinear interpolation to adjust for an uneven bed.
Marlin 1.1.0 and up allows the bilinear grid (i.e., "mesh") method to be used on all types of machines, not just deltas. This is the recommended method going forward.
G29 Manual Bed Leveling in Marlin
Marlin firmware (version 1.0.2 and up) provides a MESH_BED_LEVELING
feature that can be used to perform bed leveling on machines lacking a probe. This form of bed leveling compensates for uneven Z height across the surface of the bed using a mesh and bilinear interpolation.
- Manual Bed Leveling Usage
G29 S1 ; Move to the first point and wait for a measurement G29 S2 ; Store the current Z, move to the next point G29 S3 Xn Yn Zn.nn ; Modify the Z height of a single point
- Options for the S parameter
- S0 Produces a mesh report
- S1 Start probing mesh points
- S2 Probe the next mesh point
- S3 Xn Yn Zn.nn Manually modify a single point
- S4 Zn.nn Set z offset. Positive away from bed, negative closer to bed.
G29 in Repetier firmware
Repetier firmware since v0.91 supports G29 with the optional Snnn parameter as described below. Useful to simply detect the Z bed angle so you can manually readjust your bed and get it as close to in plane as possible. If you wish to apply automatic software Z plane compensation on Repetier, use G32 instead with firmware 0.92.8 and above.
- S0 Default value. Z bed heights are calculated at the measured points, relative to current Z position before issuing G29.
- S1 Same as S0, except printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issue G28 Z to home to Z maximum position before issuing G29 Snnn for this to work correctly, or the printer height will be invalid.
- S2 Same as S1, except new calculated Z height is also stored to EEPROM.
G29 in RepRapFirmware
RepRapFirmware:
- S0 (default if no S parameter) Probe the bed, save the height map in a file on the SD card, and activate bed compensation. The default folder for the height map file is /sys and the default file name is heightmap.csv.
- S1 Load the height map from file and activate bed compensation. The default folder and filename as for S0.
- S2 Clear bed height map
To define the grid, see M557.
- Example
G29.1 X30 Y20 Z0.5
Example: G29.2 Z0.0
The user would typically place the toolhead at the zero point of the axis and issue the G29.2 command.
G30: Single Z-Probe
??? | No | No | No | Yes | Yes | use G28 & G92 | ??? | ??? |
- Usage
- G30 Pnnn Xnnn Ynnn Znnn Hnnn Snnn
- Parameters
- Pnnn Probe point number
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- Hnnn Height correction
- Snnn Set parameter
- Examples
- G30
- Examples (RepRapFirmware)
- G30 ; Probe the bed at the current XY position. When the probe is triggered, set the Z coordinate to the probe trigger height.
- G30 S-1 ; Probe the bed at the current XY position. When the probe is triggered, do not adjust the Z coordinate.
- G30 P0 X20 Y50 Z-99999 ; Probe the bed at X20 Y50 and save the XY coordinates and the height error as point 0
- G30 P3 X180 Y180 Z-99999 S4 ; Probe the bed at X180 Y180, save the XY coordinates and the height error as point 3 and calculate 4-point compensation or calibration
- G30 P3 X180 Y180 Z-99999 S-1 ; As previous example but just report the height errors
RepRapFirmware supports additional behaviour: if a Pn field is specified the probed X, Y, and Z values are saved as point n on the bed for calculating the offset plane or for performing delta printer calibration. If X, or Y, or Z values are specified (e.g. G30 P1 X20 Y50 Z0.3) then those values are used instead of the machine's current coordinates. A silly Z value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specified (e.g. G30 P1 Z0.3 S) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1 commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup GCode file for automatic execution.
RepRapFirmware uses the value of the S parameter to specify what computation to perform. If the value is -1 then the Z offsets of all the points probed are printed, but no calibration is done. If the value is zero or not present, then this specifies that the number of factors to be calibrated is the same as the number of points probed. Otherwise, the value indicates the number of factors to be calibrated, which must be no greater than the number of points probed. In version 1.09, the number of factors may be 3, 4 or 5 when doing auto bed compensation on a Cartesian or CoreXY printer, and 3, 4, 6 or 7 when doing auto calibration of a Delta printer.
RepRapFirmware supports an optional H parameter, which is a height correction for that probe point. It allows for the Z probe having a trigger height that varies with XY position. The nominal trigger height of the Z probe (e.g. at bed centre) is declared in the Z parameter of the G31 command in the config.g file. When you probe using G30 and the probe triggers, the firmware will assume that the nozzle is at the nominal trigger height plus the value you have in the H parameter.
1MK4duo Firmware support an optional parameter for Autocalibration Delta.
- Usage
- G30 Xnnn Ynnn Znnn Annn E R I D T S U
- Parameters
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- Annn A Autocalibration width nnn precision
- E Adjust Endstop
- R Adjust Endstop & Delta Radius
- I Adjust Tower
- D Adjust Diagonal Rod
- T Adjust Tower Radius
- Sn Stows the probe if 1 (default=1)
- Un <bool> with a non-zero value will apply the result to current zprobe_zoffset
No | Yes | ??? | ??? | ??? | Yes: 0.91.7 | Yes | ??? | No | |
- Usage
- G31 Pnnn Xnnn Ynnn Znnn Cnnn Snnn
- Parameters
- Pnnn Trigger value
- Xnnn Probe X offset1
- Ynnn Probe Y offset1
- Znnn Trigger Z height
- Cnnn Temperature coefficient2
- Snnn Calibration temperature2
- Examples
- G31 P500 Z2.6
- G31 X16.0 Y1.5
In RepRapFirmware, separate G31 parameters may be defined for different probe types (i.e. 0+4 for switches, 1+2 for IR probes and 3 for alternative sensors). To specify which probe you are setting parameters for, send a M558 command to select the probe type before sending the G31 command.
In Repetier, G31 supports no parameters and simply prints the high/low status of the Z probe.
- Notes
1X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) can be specified in RepRapFirmware. This allows you to calculate your M557 probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset. It also provides more accurate bed compensation.
2In RepRapFirmware, additional parameters 'S' (bed temperature in oC at which the specified Z parameter is correct, default is current bed temperature) and 'C' (temperature coefficient of Z parameter in mm/oC, default zero) can be set for the alternative (ultrasonic) sensor. This is useful for probes that are affected by temperature.
Yes | No | ??? | ??? | ??? | ??? | No | ??? | Yes | |
??? | No | No | No | No | Yes | No | ??? | ??? |
No: See G29 | Yes | ??? | ??? | ??? | Yes: 0.92.8 | Yes | ??? | No | |
- Usage
- G32
- G32 Snnn
- Parameters
- Snnn Store transformation matrix after probing1
- Examples
- G32
- G32 S2
Probes the bed at 3 or more pre-defined points (see M557) and updates transformation matrix for bed leveling compensation.
RepRapFirmware executes macro file bed.g if present instead of using the M557 coordinates.
- Notes
1Currently only Repetier firmware v0.92.8 and higher have working support for an optional Snnn parameter. The numeric value sets the behavior that occurs immediately after point probe and transformation matrix calculation:
- S0 Default value. Transformation matrix is updated in RAM but is not stored to EEPROM. Z bed height not calculated.
- S1 Transformation matrix is updated in RAM but is not stored to EEPROM. Printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issue G28 to home to Z maximum position before issuing G32 Snnn for this to work correctly, or the printer height will be invalid.
- S2 Same as S1, except transformation matrix and Z max heights are also stored to EEPROM.
- S3 Transformation matrix is stored to EEPROM. Z bed height not calculated.
No | No | ??? | ??? | ??? | Yes: v0.92.8 | No | ??? | No | |
- Usage
- G33
- G33 Lnnn
- G33 Rnnn
- G33 Xnnn Ynnn Znnn
- Parameters
- L0 List distortion matrix in a report
- R0 Reset distortion matrix
- X<pos> Y<pos> Z<zCorrection> Set correction for nearest point
- Examples
- G33
- G33 R0
When used with no parameters, G33 will measure a grid of points and store the distortion dips and valleys in the bed surface, and then enable software distortion correction for the first few or several layers. The values will be stored in EEPROM if enabled in firmware. You must previously have G28 homed, and your Z minimum/maximum height must be set correctly for this to work. Use the optional parameters to list, reset or modify the distortion settings. Distortion correction behavior can be later turned on or off by code M323.
Yes: 1.1.0 | No | ??? | ??? | ??? | ??? | Yes | ??? | No | |
Yes | ??? | ??? | ??? | ??? | No | ??? | ??? | ??? |
??? | No | ??? | ??? | ??? | ??? | ??? | ??? | No | |
G40 turn cutter compensation off. If tool compensation was on the next move must be a linear move and longer than the tool diameter. It is OK to turn compensation off when it is already off.
??? | No | ??? | ??? | ??? | ??? | Yes | ??? | No | |
??? | ??? | ??? | ??? | ??? | ??? | ??? | ??? | Yes | |
- Usage
- G60 Snn
- Parameters
- Snn <nn> specifies memory slot # (0-based) to save into (default 0)
- Usage
- G61 Xnnn Ynnn Znnn Ennn Fnnn Snn
- Parameters
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- Ennn E coordinate
- Fnnn F Set Feedrate
- Snn S specifies memory slot # (0-based)
Example: G90
Yes | Yes | No | Yes | Yes | Yes | Yes | ??? | Yes |
Example: G91
All coordinates from now on are relative to the last position. Note: RepRapFirmware latest revision firmware uses M83 to set the extruder to relative mode: extrusion is NOT set to relative by ReprapFirmware on G91: only X,Y and Z are set to relative. By contrast, Marlin (for example) DOES also set extrusion to relative on a G91 command, as well as setting X, Y and Z.
G92: Set Position
- Parameters
- Xnnn new X axis position
- Ynnn new Y axis position
- Znnn new Z axis position
- Ennn new extruder position
- Example
- G92 X10 E90
G92.x: Reset Coordinate System Offsets (CNC specific)
- G92.1 - reset axis offsets to zero and set parameters 5211 - 5219 to zero. (X Y Z A B C U V W)
- G92.2 - reset axis offsets to zero.
G93 is Inverse Time Mode. In inverse time feed rate mode, an F word means the move should be completed in (one divided by the F number) minutes. For example, if the F number is 2.0, the move should be completed in half a minute.
When the inverse time feed rate mode is active, an F word must appear on every line which has a G1, G2, or G3 motion, and an F word on a line that does not have G1, G2, or G3 is ignored. Being in inverse time feed rate mode does not affect G0 (rapid move) motions.
No | No | ??? | ??? | ??? | Yes: 0.92 | No | ??? | No | |
- Parameters
- X Flag to set floor for X axis
- Y Flag to set floor for Y axis
- Z Flag to set floor for Z axis
- Rnnn Radius to add
- Examples
- G100 X Y Z (set floor for argument passed in. Number ignored and may be absent.)
- G100 R5 (Add 5 to radius. Adjust to be above floor if necessary)
- G100 R0 (Set radius based on current z measurement. Moves all axes to zero)
??? | No | No | No | No | No | No | ??? | Yes |
Example: G130 X10 Y18 Z15 A20 B12
G131: Remove offset
No | No | ??? | ??? | ??? | Yes: 0.91 | No | ??? | No | |
??? | No | No | No | No | No | Yes | ??? | Yes |
- Parameters
- X Flag to home the X axis to its minimum position
- Y Flag to home the Y axis to its minimum position
- Z Flag to home the Z axis to its minimum position
- Fnnn Desired feedrate for this command
- Example
- G161 X Y Z F1800
Instruct the machine to home the specified axes to their minimum position. Similar to G28, which decides on its own in which direction to search endstops.
- Parameters
- X Flag to home the X axis to its maximum position
- Y Flag to home the Y axis to its maximum position
- Z Flag to home the Z axis to its maximum position
- Example
- G162 X Y Z F1800
M-commands
Yes | Yes | ??? | ??? | ??? | No | No | ??? | Yes | |
Yes | No | No | Yes | Yes | No | Yes | ??? | ??? |
- Parameters
- Pnnn Time to wait, in milliseconds1
- Snnn Time to wait, in seconds2
- Example
- M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller, although this step is not mandatory on RepRapFirmware. See also M1, M112.
RepRapFirmware executes macro file stop.g before everything is turned off. Apart from that, RepRapFirmware (v1.09n-ch) accepts an extra 'H' parameter, whose value must be non-zero, to keep all heaters active. This is what Duet Web Control v1.07 sends to cancel a paused print.
- Notes
1Not available in RepRapFirmware, but as a work-around G4 can be run before M0.
2Only available on Marlin.
Yes | No | No | No | No | No | ??? | ??? | ??? |
- Example
- M1
If Marlin is emulated in RepRapFirmware, this does the same as M25 if the code was read from a serial or Telnet connection, else the macro file sleep.g is run before all heaters and drives are turned off.
M2: Program End
No | No | ??? | ??? | ??? | No | ??? | ??? | No | |
Yes | No | No | No | No | No | Yes | ??? | Yes |
Example: M2
No | Yes | ??? | ??? | ??? | Yes | Yes | ??? | No | |
Yes | No | No | No | No | No | Yes | ??? | ??? |
- Parameters
- Snnn Spindle RPM
- Example
- M3 S4000
RepRapFirmware interprets this code only if a Roland mill has been configured.
In Repetier-Firmware in laser mode you need S0..255 to set laser intensity. Normally you use S255 to turn it on full power for moves. Laser will only fire during G1/2/3 moves and in laser mode (M452).
No | No | ??? | ??? | ??? | Yes | No | ??? | No | |
Yes | No | No | No | No | No | No | ??? | ??? |
Example: M4 S4000
No | No | ??? | ??? | ??? | Yes | Yes | ??? | No | |
Example: M5
The spindle is turned off.
M6: Tool change
??? | No | No | No | No | No | Yes | ??? | ??? |
Example: M6
Yes | No | No | No | No | No | use M106 | ??? | ??? |
Example: M7
Example: M8
Example: M9
??? | No | No | No | No | No | use M106 | ??? | ??? |
Example: M10
Example: M11
Yes | No | ??? | ??? | ??? | No | Yes | ??? | Yes | |
??? | No | No | No | No | Yes | (automatic) | ??? | ??? |
Example: M17
call M84 | Yes | ??? | ??? | ??? | No | Yes | ??? | call M84 | |
??? | No | No | No | No | Yes | use M2 | ??? | Yes |
- Parameters
- This command can be used without any additional parameters.1
- X X axis
- Y Y axis
- Z Z axis
- E Extruder drive(s)2
- Examples
- M18
- M18 X E0
- Notes
2RepRapFirmware allows stepper motors to be disabled selectively. For example, M18 X E0:2 will disable the X, extruder 0 and extruder 2 motors.
M20: List SD card
??? | Yes | No | No | No | No | Yes | ??? | ??? |
- Parameters
- Snnn Output style1
- Pnnn Directory to list2
- Examples
- M20
- M20 S2 P/gcodes/subdir
ok SQUARE.G SQCOM.G ZCARRI~2.GCO CARRIA~1.GCO
On Marlin, a file list response is usually encapsulated. Standard configurations of RepRapFirmware mimic this style in emulation mode:
Begin file list: SQUARE.G ZCARRI~2.GCO End file list ok
GCode files: "Traffic cone.g","frog.gcode","calibration piece.g"
Note that some firmwares list file names in upper case, but - when sent to the M23 command (below) they must be in lower case. Teacup and RepRapFirmware have no such trouble and accept both. RepRapFirmware always returns long filenames in the case in which they are stored.
- Notes
1If the S2 parameter is used on RepRapFirmware, then the file list is returned in JSON format as a single array called "files" with each name that corresponds to a subdirectory preceded by an asterisk, and the directory is returned in variable "dir". Example:
M20 S2 P/gcodes {"dir":"\/gcodes","files":["4-piece-1-2-3-4.gcode","Hinged_Box.gcode","Hollow_Dodecahedron_190.gcode","*Calibration pieces"]}
2This parameter is only supported by RepRapFirmware and defaults to the 0:/gcodes directory, which is the directory that printable gcode files are normally stored in.
- Parameters
- Pnnn SD card number (RepRapFirmware only, default 0)
- Examples
- M21
- M21 P1
The specified SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
Yes | Yes | ??? | ??? | ??? | Yes | No | ??? | Yes | |
- Parameters
- Examples
- M22
- M22 P1
The specified SD card is released, so further (accidental) attempts to read from it are guaranteed to fail. Helpful, but not mandatory before removing the card physically.
M23: Select SD file
- Example
- M23 filename.gco
??? | Yes | No | No | No | Yes | Yes | ??? | ??? |
- Example
- M24
The machine prints from the file selected with the M23 command. If the print was previously paused with M25, printing is resumed from that point. To restart a file from the beginning, use M23 to reset it, then M24.
When this command is used to resume a print that was paused, RepRapFirmware runs macro file resume.g prior to resuming the print.
M25: Pause SD print
- Example
- M25
The machine pauses printing at the current position within the file. To resume printing, use M24. Do not use this code to pause the print in a G-code file, use M226 instead.
Prior to pausing, RepRapFirmware runs macro file pause.g. This allows the head to be moved away from the print, filament to be retracted, etc.
Yes | Yes | ??? | ??? | ??? | Yes | aborts | ??? | Yes | |
??? | Yes | No | No | No | No | No | ??? | ??? |
- Parameters
- Snnn File position in bytes
- Example
- M26
- Example
- M27
Report SD print status.
Marlin and recent forks of RepRapFirmware report the number of bytes processed in this format, which can be processed by Pronterface:
SD printing byte 2134/235422
Not SD printing.
- Example
- M28 filename.gco
- Example
- M29 filename.gco
Yes | Yes | No | No | No | No | No | ??? | ??? |
Example: M30 filename.gco
filename.gco is deleted.
M30 in grbl
M30 exchange pallet shuttles and end the program. Pressing cycle start will start the program at the beginning of the file.
Yes | No | ??? | ??? | ??? | No | No | ??? | Yes | |
- Example
- M31
The response looks like:
echo:54 min, 38 sec
Yes | Yes | ??? | ??? | ??? | No | Yes | ??? | No | |
- Example
- M32 filename.gco
It can be used when printing from SD card and does the same as M23 and M24.
Yes | No | ??? | ??? | ??? | No | No | ??? | No | |
Stop the printing from SD and save all position in restart.gcode for restart printing in future
??? | No | No | No | No | No | No | ??? | No |
- Example
- M36 filename.gco
If the file name parameter is not supplied and a file on the SD card is currently being printed, then information for that file is returned including additional field "fileName". This feature is used by the web interface and by PanelDue, so that if a connection is made when a file is already being printed, the name and other information about that file can be shown.
M37 S1 enters simulation mode. All G and M codes will not be acted on, but the time they take to execute will be calculated.
M37 S0 leaves simulation mode.
Used to compute a hash of a file on the SD card. Examples:
M37 gcodes/myfile.g
Cannot find file
M37 www/reprap.htm
91199139dbfadac15a18cfb962dfd4853db83999
Returns a hexadecimal string which is the SHA1 of the file. If the file cannot be found, then the string "Cannot find file" is returned instead.
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
- When you press the reset button,
- When the build material runs out (if your RepRap is set up to detect this), and
- When there's an error (such as a heater failure).
M42: Switch I/O pin
??? | Yes | No | No | No | No | No | ??? | No |
- Parameters
- Pnnn Pin number
- Snnn Pin value
- Example
- M42 P7 S255
In RepRapFirmware, the S field may be in the range 0..1 or 0..255. The pin reference is an internal firmware reference named "digital pin", see Duet pinout. It maps on different connector pins depending the hardware. On Duet 0.6 and 0.8.5 hardware using pre-1.16 firmware, the supported pin numbers and their names on the expansion connector are:
P | Name | Expansion Port Pin |
16 | TXD1 | 11 |
17 | RXD1 | 12 |
18 | TXD0 | 13 |
19 | RXD0 | 14 |
20 | TWD1 | 35 |
21 | TWCK1 | 36 |
23 | PA14 | 10 |
36 | PC4 | 18 |
52 | AD14 | 41 |
67 | PB16 | 32 |
In firmware 1.16, the pin numbering has changed.
60 | PA10/RXD0 | 14 |
61 | PA11/TXD0 | 13 |
62 | PA12/RXD1 | 12 |
63 | PA13/TXD1 | 11 |
64 | PA14/RTS1 | 10 |
65 | PB12/TWD1 | 35 |
66 | PB13/TWCK1 | 36 |
67 | PB16/DAC1* | 32 |
68 | PB21/AD14 | 41 |
69 | PC4 | 18 |
- Also used as CS signal on external SD card socket
P | Signal Name | Expansion Connector Label |
60 | CS5 | CS5 |
61 | CS6 | E3_STOP |
62 | CS7 | E4_STOP |
63 | CS8 | E5_STOP |
See Using servos and controlling unused I/O pins for all pin definitions.
Pre-1.16 example:
M42 P20 S1 ;set the connector pin 35 to high.
See also M583.
Example: M43
- Usage
- M43 En Pnnn Wn In
- Parameters
- En Enable / disable background endstop monitoring
- Pnnn Pin to read or watch. If omitted, read/watch all pins
- Wn bool watch pins -reporting changes- until reset, click, or M108
- In bool Flag to ignore pin protection
- Parameters
- Pnnn number of points
- Xnnn position on the X axis
- Ynnn position on the Y axis
- Vnnn verbosity
- E engage
- Lnnn legs of travel
As with G29, the E flag causes the probe to stow after each probe.
M70: Display message
see M117 | see M117 | ??? | ??? | ??? | No | ??? | ??? | see M117 | |
??? | No | No | No | No | see M117 | No | ??? | Yes |
Example:
M70 P200 Message
Instruct the machine to display a message on its interface LCD. P is the time to display message for.
M72: Play a tone or song
see M300 | see M300 | ??? | ??? | ??? | No | No | ??? | see M300 | |
Example: M72 P2
M73: Set build percentage
Example: M73 P50
Instruct the machine that the build has progressed to the specified percentage. The machine is expected to display this on it's interface board. If the percentage is exactly 0, then a Build Start Notification is sent. If the percentage is exactly 100, then a Build End notification is sent.
M80: ATX Power On
??? | Yes | No | No | No | No | automatic | ??? | ??? |
- Example
- M80
Note: some firmwares, like Teacup, handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off
M81: ATX Power Off
??? | Yes | No | No | No | Yes | automatic | ??? | ??? |
- Example
- M81
For redeem, adding 'P' will quit the daemon (redeem). Adding parameter 'R' will restart the daemon.
- Example
- M82
- Example
- M83
M84: Stop idle hold
- Parameters
- Innn Reset flags1
- Example
- M84
On Marlin, Repetier and RepRapFirmware, M84 can also be used to configure or disable the idle timeout. For example, "M84 S10" will idle the stepper motors after 10 seconds of inactivity. "M84 S0" will disable idle timeout; steppers will remain powered up regardless of activity.
- Notes
1RepRapFirmware-dc42 and other firmware may not support this parameter.
M85: Set inactivity shutdown timer
Yes | No | ??? | ??? | ??? | Yes | No | ??? | Yes | |
Example: M85 S30
M92: Set axis_steps_per_unit
??? | Yes | No | No | No | Yes | No | ??? | ??? |
- Parameters
- Xnnn Steps per unit for the X drive
- Ynnn Steps per unit for the Y drive
- Znnn Steps per unit for the Z drive
- Ennn Steps per unit for the extruder drive(s)
- Examples
- M92 X87.489 Y87.489 Z87.489
- M92 E420:420
Allows programming of steps per unit (usually mm) for motor drives. These values are reset to firmware defaults on power on, unless saved to EEPROM if available (M500 in Marlin) or in the configuration file (config.g in RepRapFirmware). Very useful for calibration.
RepRapFirmware will report the current steps/mm if you send M92 without any parameters.
M93: Send axis_steps_per_unit
No | Use M92 | ??? | ??? | ??? | ??? | No | ??? | No | |
M98: Call Macro/Subprogram
- Parameters
- Pnnn Macro filename
- Example
- M98 Pmymacro.g
Runs the macro in the file mymacro.g. In conventional G Codes for CNC machines the P parameter normally refers to a line number in the program itself (P2000 would run the Macro starting at line O2000, say). For RepRap, which almost always has some sort of mass storage device inbuilt, it simply refers to the name of a GCode file that is executed by the G98 call. That GCode file does not need to end with an M99 (return) as the end-of-file automatically causes a return. Macro calls cannot usually be nested or be recursive; i.e. you can't call a macro from a macro, although RepRapFirmware explicitly supports this.
RepRapFirmware also allows the filename to include a path to a subdirectory. For relative paths, the default folder is /sys, but some implementations may check the /macros directory too. Absolute file paths are supported on RepRapFirmware as well.
- Example
- M99
Returns from an M98 call.
M98: Get axis_hysteresis_mm
Example: M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Example: M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
??? | No | Yes | No | No | No | Yes | ??? | ??? |
in Teacup firmware: If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
in BFB/RapMan firmware: Turn extruder on (forward/filament in).
in other firmwares: Deprecated. Regarding filament retraction, see M227, M228, M229.
??? | No | Yes | No | No | No | No | ??? | ??? |
In other firmwares: Deprecated.
In Teacup firmware: If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
In other firmwares: Deprecated. Regarding extruder retraction, see M227, M228, M229.
??? | Yes | Yes | Yes | Yes | Yes | Yes | ??? | Yes |
- Parameters
- Snnn Target temperature
- Example
- M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). Duet-dc42 and other firmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command applies to. See also M109.
M104 in Teacup Firmware
Example: M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100 °C.
??? | Yes | No | Yes | No | Yes | Yes | ??? | Yes |
- Parameters
- Rnnn Response sequence number1
- Snnn Response type1
- Examples
- M105
- M105 S2
ok T:201 B:117
M105 X0 ==> 11:05:48.910 : T:23.61 /0 @:0 T0:23.61 /0 @0:0 RAW0:3922 T1:23.89 /0 @1:0 RAW1:3920
- Notes
1These parameters are only supported by RepRapFirmware, which returns a JSON-formatted response if parameter S2 or S3 is specified. Additionally, parameter Rnn may be provided, where nn is the sequence number of the most recent G-code response that the client has already received. M105 S2 is equivalent to M408 S0, and M105 S3 is equivalent to M408 S2. Usage of these forms of M105 is deprecated, please use M408 instead.
M106: Fan On
??? | Yes | Yes | Yes | Yes | Yes | Yes | ??? | ??? |
- Parameters
- Pnnn Fan number (optional, defaults to 0)2
- Snnn Fan speed (0 to 255; RepRapFirmware also accepts 0.0 to 1.0))
- Extra Parameters
- Innn Invert signal, or disable fan1
- Fnnn Set fan PWM frequency, in Hz1
- Lnnn Set minimum fan speed (0 to 255 or 0.0 to 1.0)1
- Bnnn Blip time - fan will be run at full PWM for this number of seconds when started from standstill1
- Hnn:nn:nn... Select heaters monitored when in thermostatic mode1
- Rnnn Restore fan speed to the value it has when the print was paused1
- Tnnn Set thermostatic mode trigger temperature1
- Examples
- M106 S127
- M106 P1 I1 S871
- M106 P1 T45 H1:21
- M106 P2 B0.1 L0.051
The first example turns on the default cooling fan at half speed. The second one inverts the cooling fan signal of the second fan and sets its value to 1/3 of its maximum. The third one sets the second fan to a thermostatic fan for heaters 1 and 2 (e.g. the extruder heaters in a dual-nozzle machine) such that the fan will be on when either hot end is at or above 45C.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off. In some implementations like RepRapFirmware the PWM value may alternatively be specified as a real fraction: M106 S0.7.
- Notes
2Marlin only supports fan 0, all values above 0 will be interpreted as 0
M106 in RepRapFirmware
If an S parameter is provided but no other parameter is present, then the speeds of the print cooling fans associated with the current tool will be set (see the F parameter in the M563 command). If no tool is active then the speed of Fan 0 will be set. Either way, the speed is remembered so that it can be recalled using the R2 parameter (see below).
If no S parameter is given but the R1 parameter is used, the fan speed when the print was last paused will be set. If the R2 parameter is used, then the speeds of the print cooling fans associated with the current tool will be set to the remembered value (see above).
The T and H parameters allow a fan to be configured to operate in thermostatic mode, for example to use one of the fan channels to control the hot end fan. In this mode the fan will be fully on when the temperature of any of the heaters listed in the H parameter is at or above the trigger temperature set by the T parameter, and off otherwise. Thermostatic mode can be disabled using parameter H-1.
The B parameter sets the time for which the fan will be operated at full PWM when started from cold, to allow low fan speeds t be used. A value of 0.1 seconds is usually sufficient.
The L parameter defines the minimum PWM value that is usable with this fan. If a lower value is commanded that is not zero, it will be rounded up to this value.
The I parameter causes the fan output signal to be inverted if its value is greater than zero. This makes the cooling fan output suitable for feeding the PWM input of a 4-wire fan via a diode. If the parameter is present and zero, the output is not inverted. If the I parameter is negative then in RRF 1.16 and later the fan is disabled, which frees up the pin for use as a general purpose I/O pin that can be controlled using M42.
M106 in Teacup Firmware
Example: M106 P2 S255
Note well: The ambiguous text in the note above needs to be reworded by someone who knows the actual functioning. Below is my interpretation based on language use, not practical experience or code inspection.
Note: If M104 is (or becomes) active on a heater (or other device) with a feedback sensor it will correct any M106 initiated control output value change in the time it takes for the PID (of other feedback) loop to adjust it back to minimum error. It may not be easy to observe a change in the temperature (process value) due to this brief change in the control value
M107: Fan Off
Support | Marlin | RepRapFirmware | Klipper | Prusa | Buddy | Repetier | Smoothie | Druid | MK4duo |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | MakerBot | |
??? | Yes | Yes | Yes | Yes | Yes | No | ??? | ??? |
Deprecated in Teacup firmware and in RepRapFirmware. Use M106 S0 instead.
M108: Cancel Heating (Marlin)
Breaks out of an M109 or M190 wait-for-temperature loop, continuing the print job. Use this command with caution! If cold extrusion prevention is enabled (see M302) and the temperature is too low, this will start "printing" without extrusion. If cold extrusion prevention is disabled and the hot-end temperature is too low, the extruder may jam.
This command was introduced in Marlin 1.1.0. As with other emergency commands [e.g., M112] this requires the host to leave space in the command buffer, or the command won't be executed until later.
M108: Set Extruder Speed (BFB)
Sets speed of extruder motor. (Deprecated in FiveD firmware, see M113)
??? | Yes | No | Yes | Yes | Yes | not needed | ??? | Yes |
- Parameters
- Snnn minimum target temperature, waits until heating
- Rnnn maximum target temperature, waits until cooling (Sprinter)
- Rnnn accurate target temperature, waits until heating and cooling (Marlin)
- Example
- M109 S215
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port), RepRapFirmware
Example: M109 S185
RepRapFirmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command refers to (see below).
M109 in Sprinter (4pi port)
Example: M109 S185 R240 //sets extruder temperature to 185 and waits for the temperature to be between 185 - 240.
M109 in MakerBot
Example: M109 S70 T0
M110: Set Current Line Number
??? | No | No | Yes | No | Yes | not needed | ??? | ??? |
- Parameters
- Nnnn Line number
- Example
- M110 N123
M111: Set Debug Level
??? | No | No | Yes | No | Yes | Debug | ??? | ??? |
- Parameters
- Pnnn Debug module1
- Snnn Debug on/off
- Examples
- M111 S6
- M111 P1 S1
- Notes
M111 in RepRapFirmware
RepRapFirmware allows debugging to be set for each module. If the optional 'P' parameter is not specified, debugging will be enabled for all modules. For a list of modules, send M111 S1 P15.
M111 in Repetier
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2) #define DEBUG_DRYRUN (1<<3) // repetier-firmware #define DEBUG_COMMUNICATION (1<<4) // repetier-firmware
M112: Emergency Stop
??? | No | No | Yes | No | Yes | Yes | ??? | ??? |
- Example
- M112
M113: Set Extruder PWM
??? | No | No | Yes | No | No | No | ??? | ??? |
Example: M113
M113 S0.7
M114: Get Current Position
- Example
- M114
??? | Yes | No | Yes | No | Yes | Yes | ??? | No |
- Parameters
- Pnnn Electronics type1
- Examples
- M115
- M115 P2
sample data from firmware:
- Notes
1This parameter is supported only in RepRapFirmware and can be used tell the firmware about the hardware on which it is running. If the P parameter is present then the integer argument specifies the hardware being used. The following are currently supported:
M115 P0 Automatic board type selection if supported, or default if not M115 P1 Duet 0.6 M115 P2 Duet 0.7 M115 P3 Duet 0.85
M116: Wait
No | Yes | ??? | ??? | ??? | Yes | No | ??? | No | |
??? | No | No | Yes | No | Yes | Yes | ??? | Yes |
- Parameters
- Pnnn Tool number
- Hnnn Heater number
- Cnnn Chamber number
- Examples
- M116
- M116 P1
Wait for all temperatures and other slowly-changing variables to arrive at their set values if no parameters are specified. See also M109.
- Notes
M117: Get Zero Position
??? | No | No | Yes | No | No | No | ??? | see M70 |
Example: M117
M117: Display Message
Yes | Yes | ??? | ??? | ??? | Yes | Yes | ??? | Yes | |
??? | No | No | No | No | Yes | No | ??? | No |
- Example
- M117 Hello World
M118: Negotiate Features
Example: M118 P42
M119: Get Endstop Status
- Example
- M119
In redeem, M119 can also be used to invert end stops.
- Example
- M119 X1 1
This will invert end stop X1 (Inverted means switch is connected in Normally Open state (NO))
M120: Push
No | Yes | ??? | ??? | ??? | No | Yes | ??? | No | |
- Example
- M120
- Current feedrate, and
- Whether moves (and separately extrusion) are relative or absolute
- Current feedrate
- Extruder positions
M121: Pop
- Example
- M121
M122: Diagnose
- Example
- M122
M123: Tachometer value
No | No | ??? | ??? | ??? | No | No | ??? | No | |
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
??? | No | No | Yes | No | No | No | ??? | Yes |
Example: M126 P500
M126 in MakerBot
Example: M126 T0
M127: Close Valve
Example: M127 P400
M127 in MakerBot
Example: M127 T0
M128: Extruder Pressure PWM
Example: M128 S255
M129: Extruder pressure off
Example: M129 P100
M130: Set PID P value
see M301 | No | ??? | ??? | ??? | No | see M301 | ??? | see M301 | |
??? | No | No | No | No | see M301 | Yes | ??? | ??? |
- Parameters
- Pnnn heater number
- Snnn proportional (Kp)
- Example
- M130 P0 S8.0 ; Sets heater 0 P factor to 8.0
M131: Set PID I value
- Parameters
- Snnn integral (Ki)
- Example
- M131 P1 S0.5 ; Sets heater 1 I factor to 0.5
M132: Set PID D value
see M301 | see M301 | ??? | ??? | ??? | No | See M301 | ??? | see M301 | |
??? | No | No | No | No | see M301 | Yes | ??? | Yes |
- Parameters
- Snnn derivative (Kd)
- Example
- M132 P0 S24 ; Sets heater 0 D factor to 24.0
M132 in MakerBot
Example: M132 X Y Z A B
M133: Set PID I limit value
see M301 | No | ??? | ??? | ??? | No | No | ??? | see M301 | |
- Parameters
- Snnn integral limit (Ki)
- Example
- M133 P1 S264 ; Sets heater 1 I limit value to 264
M133 in MakerBot
Example: M133 T0 P500
Instruct the machine to wait for the toolhead to reach its target temperature. T is the extruder to wait for. P if present, sets the time limit.
No | see M500 | ??? | ??? | ??? | No | No: See M504 | ??? | No | |
Example: M134
M134 in MakerBot
Example: M134 T0 P500
M135: Set PID sample interval
No | Yes | ??? | ??? | ??? | No | No | ??? | No | |
- Parameters
- Snnn Heat sample time in seconds
- Example
- M135 S300
M135 in MakerBot
Example: M135 T0
No | see M301 | ??? | ??? | ??? | No | No | ??? | No | |
??? | No | No | No | No | No | Debug | ??? | ??? |
Example: M136 P1 # print heater 0 PID parameters to host
??? | Yes | No | Yes | Yes | Yes | Yes | ??? | Yes |
- Parameters
- Hnnn Heater number1
- Example
- M140 S55
RepRapFirmware allows the bed heater to be switched off if the absolute negative temperature (-273.15) is passed as target temperature. In this case the current bed temperature is not affected1:
M140 S-273.15
??? | No | No | No | Yes | No | uses M104 | ??? | ??? |
- Parameters
- Examples
- M141 S30
- M141 H0
- Notes
M142: Holding Pressure
??? | No | No | No | No | No | No | ??? | ??? |
Example: M142 S1
M143: Maximum hot-end temperature
Example: M143 S275
Set the maximum temperature of the hot-end to 275°C.
Default value is 300°C prior to RepRapFirmware version 1.13 and 262°C from 1.13 onwards.
M144: Bed Standby
- Example
- M144
M146: Set Chamber Humidity
- Parameters
- Rnnn Relative humidity in percent
- Example
- M146 R60
M149: Set temperature units
- Parameters
- C Flag to treat temperature as degrees Celsius
- K Flag to treat temperature as Kelvin
- Example
- M149 K
M150: Set display color
- Parameters
- Rnnn red
- Unnn green
- Bnnn blue
- Example
- M150 R255 U128 B192
Set BlinkM Color via I2C. Range for values: 0-255
M155: Automatically send temperatures
Yes: 1.1.0 | No | ??? | ??? | ??? | Yes | No | ??? | Yes | |
- Parameters
- Snnn enable sending temperatures = 1, disable = 0
- Example
- M155 S1
Hosts normally monitor printer temperatures by sending a M105 every x seconds. This not only adds traffic, but also only works while printer is not blocked by waiting commands. So frequency more depends on frequency you can send new commands and creates extra traffic. As a solution, firmware can be told to automatically send temperatures every second. This function is disabled by default for best compatibility with existing hosts. To indicate the availability of this function, M115 should add a extra line
Cap:AUTOREPORT_TEMP:1
so hosts know about the presence of the function.
Example: M160 S4
M160 S4 G1 X90.6 Y13.8 E2.24:2.24:2.24:15.89 G1 X70.6 E0:0:0:42.4 G1 E42.4:0:0:0
Yes: RC7 | Use M567 | ??? | ??? | ??? | Yes: 0.92 | No | ??? | No | |
- Parameters
- Snnn extruder number
- Pnnn weight
M164: Store weights
Yes: RC7 | No | ??? | ??? | ??? | Yes: 0.92 | No | ??? | No | |
- Parameters
- Snnn virtual extruder number
- Pnnn store to eeprom (P0 = no, P1 = yes)
M165: Set multiple mix weights
Yes: RC7 | No | ??? | ??? | ??? | No: | No | ??? | No | |
- Parameters ABCDHI
- A A[factor] Mix factor for extruder stepper 1
- B B[factor] Mix factor for extruder stepper 2
- C C[factor] Mix factor for extruder stepper 3
- D D[factor] Mix factor for extruder stepper 4
- H H[factor] Mix factor for extruder stepper 5
- I I[factor] Mix factor for extruder stepper 6
- Set multiple mix factors for a mixing extruder.
- Factors that are left out will be set to 0.
- All factors together must add up to 1.0.
??? | Yes | No | No | Yes | Yes | No: See M116 | ??? | ??? |
- Parameters
- Example
- M190 S60
No | see M301 C1 | ??? | ??? | ??? | No | No | ??? | No | |
??? | No | No | No | Yes | No | No | ??? | ??? |
Example: M191 P60
M200: Set filament diameter
Yes | see M404 | ??? | ??? | ??? | Yes | Yes | ??? | Yes | |
M200 D0 or M200 D1.128 ; reset E multiplier to 1, since sqrt(1/pi)*2=1.128
- Parameters
- Xnnn Acceleration for X axis
- Ynnn Acceleration for Y axis
- Znnn Acceleration for Z axis
- Ennn Acceleration for extruder drives
- Example
- M201 X1000 Y1000 Z100 E2000
RepRapFirmware expects these values to be in mm/s².
??? | ??? | No | No | No | ??? | No | ??? | ??? |
M203: Set maximum feedrate
- Parameters
- Xnnn Maximum feedrate for X axis
- Ynnn Maximum feedrate for Y axis
- Znnn Maximum feedrate for Z axis
- Ennn Maximum feedrate for extruder drives
- Example
- M203 X6000 Y6000 Z300 E10000
Sets the maximum feedrates that your machine can do in mm/min (Marlin uses mm/sec).
M203 Repetier
Set temperture monitor to Sx.
Yes | No | ??? | ??? | ??? | Yes | Yes | ??? | Yes | |
??? | Yes | No | No | No | ??? | No | ??? | ??? |
P = Printing moves
The command "M204 P800 T3000 R9000" set the acceleration for printing movements to 800mm/s^2, for travels to 3000mm/s^2 and for retracts to 9000mm/s^2.
M204 Repetier
M204 X[Kp] Y[Ki] Z[Kd] -
M205: Advanced settings
Yes | see M566 | ??? | ??? | ??? | Yes | Yes | ??? | Yes | |
Sprinter and Marlin:
- minimum travel speed S=while printing T=travel only, B=minimum segment time X= maximum xy jerk, Z=maximum Z jerk, E=maximum E jerk
Sprinter / Marlin Example:
- M205 X30 Z5 ; Set X/Y Jerk to 30mms, Z jerk to 5mms
Smoothieware uses a different algorithm: [1]
- X<xy junction deviation> Z<z junction deviation> S<minimum planner speed>, Z junction deviation only applies to z only moves, 0 disables junction deviation for Z, -1 uses global junction deviation
Smoothie example:
- M205 X0.05 ; set X/Y Junction Deviation
M205 Repetier
Output EEPROM settings.
M206: Offset axes
Yes | Yes | ??? | ??? | ??? | No | Yes | ??? | Yes | |
- Parameters
- Xnnn X axis offset
- Ynnn Y axis offset
- Znnn Z axis offset
- Example
- M206 X10.0 Y10.0 Z-0.4
M206 in Repetier: Set eeprom value
Example: M206 T3 P39 X19.9
Set Jerk to 19.9
No | No | ??? | ??? | ??? | ??? | No | ??? | No | |
Example: M207
M207: Set retract length
- Parameters
- Snnn positive length to retract, in mm
- Rnnn positive or negative additional length to un-retract, in mm (RepRapFirmware only)
- Fnnn retraction feedrate, in mm/min
- Tnnn feedrate for un-retraction if different from retraction, mm/min (RepRapFirmware 1.16 and later only)
- Znnn additional zlift/hop
- Example
- M207 S4.0 F2400 Z0.075
Sets the retract length used by the G10 and G11 commands, stays in mm regardless of M200 setting
M208: Set axis max travel
- Parameters
- Snnn Whether to set the axis minimum1
- Xnnn X axis limit
- Ynnn Y axis limit
- Znnn Z axis limit
- Example
- M208 X250 Y210 Z180
RepRapPro's version of Marlin uses M208 this way. Send M503 to see the current values. On Marlin, the value can be saved to EEPROM using the M500 command.
- Notes
1With RepRapFirmware on a Cartesian printer, you can also use this command to specify software limits for axis travel in the negative direction, by adding parameter S1. The axis limits you set are also the positions assumed when an endstop is triggered.
M208 X200 Y200 Z90; set axis maxima M208 X-5 Y0 Z0 S1 ; set axis minimum
M208: Set unretract length
Yes | See M207 | ??? | ??? | ??? | No | Yes | ??? | Yes | |
- Parameters
- Snnn positive length surplus to the M207 Snnn, in mm
- Fnnn feedrate, in mm/sec
Example: M209 S1
M210: Set homing feedrates
Example: M210 X1000 Y1500
No | Use M564 | ??? | ??? | ??? | No | No | ??? | No | |
Example: M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example: M211 X0 S1
Enables X min endstop
Example: M211
Yes* | Use G31 | ??? | ??? | ??? | No | No | ??? | Yes | |
Example: M212 Z-0.2
M218: Set Hotend Offset
Yes | Use G10 | ??? | ??? | ??? | No | No | ??? | Yes | |
Example: M218 T1 X50 Y0.5
- Parameters
- Snnn Speed factor override percentage (0..100 or higher)
- Example
- M220 S80
- Parameters
- Snnn Extrude factor override percentage (0..100 or higher), default 100%
- Dnnn Extruder drive number (RepRapFirmware only), default 0
- Example
- M221 S70
- M221 S95 D1
Sets extrude factor override percentage. In the case of RepRapFirmware, sets the extrusion factor percentage for the specified extruder drive only.
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
??? | No | Yes | No | Yes | No | No | ??? | ??? |
- Example
- M226
M226: Wait for pin state
Yes | see M577 | ??? | ??? | ??? | Yes | No | ??? | Yes | |
- Parameters
- Pnnn pin number
- Snnn pin state
- Example
- M226 P2 S1
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
M231: Set OPS parameter
M231 S[OPS_MODE] X[Min_Distance] Y[Retract] Z[Backslash] F[ReatrctMove]
M240: Trigger camera
Example: M240
Triggers a camera to take a photograph. (Add to your per-layer GCode.)
??? | No | No | No | No | No | Debug: Echo off | ??? | ??? |
Example: M240
??? | No | No | No | No | No | Debug: Echo on | ??? | ??? |
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
M250: Set LCD contrast
Example: M250 C20
M251 S0 - Reset, S1 - Print, S2 - Store to Z length (also EEPROM if enabled)
(This is a Repetier-Firmware only feature)
M260: i2c Send Data
Yes: 1.1.0 | No | ??? | ??? | ??? | No | No | ??? | Yes | |
Buffer and send data over the i2c bus. Use A to set the address from 0-127. Add up to 32 bytes to the buffer with each B. Send and reset the buffer with S.
- Examples
M260 A5 B65 S ; Send 'A' to Address 5 now M260 A0 ; Set address to 0 (broadcast) M260 B77 ; M M260 B97 ; a M260 B114 ; r M260 B108 ; l M260 B105 ; i M260 B110 ; n M260 S1 ; Send the current buffer
M261: i2c Request Data
Request data from an i2c slave device. This command simply relays the received data to the host.
- Example
M261 A99 B5 ; Request 5 bytes from Address 99
Both M260 and M261 are commands demonstrating use of the i2c bus (TWIBus class) in Marlin Firmware. Developers and vendors can make Marlin an i2c master device by enabling EXPERIMENTAL_I2CBUS
, and Marlin can act as a slave device by setting I2C_SLAVE_ADDRESS
from 8-127. This class can be used to divide up processing responsibilities between multiple instances of Marlin running on multiple boards. For example, one board might control a Z axis with 4 independent steppers to create a self-leveling system, or a second board could drive the graphical display while the first board handles printing.
M280: Set servo position
Yes | 1.16 and later | ??? | ??? | ??? | Use M340 | No | ??? | Yes | |
??? | No | No | No | Yes | Yes | No | ??? | ??? |
Set servo position absolute.
- Parameters
- Pnnn Servo index
- Snnn Angle or microseconds
- I1 Invert polarity (RepRapFirmware only)
- Example
- M280 P1 S50
Marlin and RepRapFirmware treat S values below 200 as angles, and 200 or greater as the pulse width in microseconds.
In RepRapFirmware, the servo index is the same as the pin number for the M42 command. See https://duet3d.com/wiki/Using_servos_and_controlling_unused_I/O_pins for details.
RepRapFirmware supports the optional I1 parameter, which if present causes the polarity of the servo pulses to be inverted compared to normal for that output pin. The I parameter is not remembered between M280 commands (unlike the I parameter in M106 commands), so if you need inverted polarity then you must include I1 in every M280 command you send.
M300: Play beep sound
??? | No | No | No | Yes | No | No | ??? | Yes |
- Parameters
- Snnn frequency in Hz
- Pnnn duration in milliseconds
- Example
- M300 S300 P1000
If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
M301: Set PID parameters
??? | Yes | No | No | No | Yes | No: See M13[0-3]) | ??? | ??? |
- Parameters
- Hnnn heater number (Smoothie uses 'S', Redeem uses 'E')
- Pnnn proportional (Kp)
- Innn integral (Ki)
- Dnnn derivative (Kd)
- Examples
- M301 H1 P1 I2 D3 ; Marlin
- M301 H1 P1 I2 D3 T0.2 B20 W127 S0.8 ; RepRapFirmware (v1.09 onwards), Duet-dc42
- M301 S0 P30 I10 D10 ; Smoothie
- M301 E0 P30 I10 D10 ; Redeem (E = Extruder, -1=Bed, 0=E, 1=H, 2=A, 3=B, 4=C, default = 0)
Marlin
Hot end only; see M304 for bed PID. H is the heater number, default 1 (i.e. first extruder heater).
H: Is the heater number, and is compulsory. H0 is the bed, H1 is the first hot end, H2 the second etc.
P: Interprets a negative P term as indicating that bang-bang control should be used instead of PID (not recommended for the hot end, but OK for the bed heater).
I: Integral value
D: Derivative value
T: Is the approximate additional PWM (on a scale of 0 to 255) needed to maintain temperature, per degree C above room temperature. Used to preset the I-accumulator when switching from heater fully on/off to PID.
S: PWM scaling factor, to allow for variation in heater power and supply voltage. Is designed to allow a correction to be made for a change in heater power and/or power supply voltage without having to change all the other parameters. For example, an S factor of 0.8 means that the final output of the PID controller should be scaled to 0.8 times the standard value, which would compensate for a heater that is 25% more powerful than the standard one or a supply voltage that is 12.5% higher than standard.
W: Wind-up. Sets the maximum value of I-term, must be high enough to reach 245C for ABS printing.
B: PID Band. Errors larger than this cause heater to be on or off.
An example using all of these would be:
- M301 H1 P20 I0.5 D100 T0.4 S1 W180 B30
Smoothie
S0 is 0 for the hotend, and 1 for the bed, other numbers may apply to your configuration, depending on the order in which you declare temperature control modules.
Other implementations
W: Wind-up. Sets the maximum value of I-term, so it does not overwhelm other PID values, and the heater stays on. (Check firmware support - Sprinter, Marlin?) Example:
- M301 W125
Teacup
M302: Allow cold extrudes
Yes | Yes1 | ??? | ??? | ??? | Yes: 0.92 | No | ??? | Yes | |
- Parameters
- Snnn Cold extrude minimum temperature
- Pnnn Cold extrude allow state (RepRapFirmware)
- Examples (RepRapFirmwre)
- M302 ; Report current state
- M302 P1 ; Allow cold extrusion
- Examples (Others)
- M302 S0 ; Allow extrusion at any temperature
- M302 S170 ; Allow extrusion above 170
This tells the printer to allow movement of the extruder motor above a certain temperature, or if disabled, to allow extruder movement when the hotend is below a safe printing temperature.
- Notes
1RepRapFirmware uses the P[0|1] parameter instead of S[temperature], and for M302 with no parameters it will report the current cold extrusion state.
M303: Run PID tuning
Yes | 1.15 and later | ??? | ??? | ??? | Yes | Yes | ??? | Yes | |
Hot end usage:
M303 S<temperature> C<cycles>
Bed usage (repetier, not sure whether cycles work here):
M303 P1 S<temperature>
Bed usage (others):
Example:
M303 C8 S175
M303 E0 S190
In RepRapFirmware, this command computes the process model parameters (see M307), which are in turn used to calculate the PID constants. H is the heater number, P is the PWM to use (default 0.5), and S is the maximum allowable temperature (default 225). Tuning is performed asynchronously. Run M303 with no parameters to see the current tuning state or the last tuning result. Example:
M303 H1 P0.4 S240 ; tune heater 1 using 40% PWM, quit if temperature exceeds 240C
- Notes
In Marlin Firmware you can add the U1 parameter to apply the PID results to current settings upon completion.
Yes | Yes | ??? | ??? | ??? | ??? | see M301 | ??? | Yes | |
- Parameters
- Examples
- M304 P1 I2 D3 ; set kP=3, kI=2, kD=3
- M304 P1 I2 D3 T0.7 B20 W127 ; RepRapFirmware
- M304 ; Report parameters
Sets Proportional, Integral and Derivative values for bed. RepRapFirmware interprets a negative P term as indicating that bang-bang control should be used instead of PID. In RepRapFirmware, this command is identical to M301 except that the H parameter (heater number) defaults to zero.
Example: M304 H1 B4200 R4800 T100000
No | Yes | ??? | ??? | ??? | ??? | Yes | ??? | No | |
- Parameters
- Pnnn Heater number
- Tnnn Thermistor resistance at 25oC
- Bnnn Beta value, or the reciprocal of the Steinhart-Hart thermistor model B coefficient
- Cnnn Steinhart-Hart C coefficient (RepRapFirmware 1.17 and later), default 0
- Rnnn Series resistor value
- Lnnn ADC low offset
- Hnnn ADC high offset
- Xnnn Heater ADC channel, or thermocouple or PT100 adapter channel, defaults to the same value as the P parameter
- Example
- M305 P1 T100000 R1000 B4200
Sets the parameters for temperature measurement. The example above tells the firmware that for heater 1 (P parameter: 0 = heated bed, 1 = first extruder) the thermistor 25C resistance (T parameter) is 100Kohms, the thermistor series resistance (R parameter) is 1Kohms, the thermistor beta (B parameter) is 4200. All parameters other than P are optional. If only the P parameter is given, the existing values are displayed.
RepRapFirmware also supports ADC gain and offset correction and a thermistor selection facility. Example:
M305 P1 T100000 R1000 B4200 H14 L-11 X2
The H correction affects the reading at high ADC input voltages, so it has the greatest effect at low temperatures. The L correction affects the reading at low input voltages, which correspond to high temperatures.
The X parameter tells the firmware to use the thermistor input corresponding to a different heating channel. RepRapFirmware also allow an external SPI thermocouple interface (such as the MAX31855) or PT100 interface (MAX31865) to be configured. Thermocouple channels are numbered from 100 and PT100 channels from 200.
In the above example, the ADC high end correction (H parameter) is 14, the ADC low end correction (L parameter) is -11, and thermistor input #2 is used to measure the temperature of heater #1.
M306: Set home offset calculated from toolhead position
No | No | ??? | ??? | ??? | ??? | Yes | ??? | No | |
Example: M306 Z0
Implemented in Smoothieware
M307: Set or report heating process parameters
No | 1.15 and later | ??? | ??? | ??? | No | No | ??? | No | |
- Parameters
- Hn Heater number (0 is usually the bed heater)
- Annn gAin, expressed as ultimate temperature rise obtained in degC divided by the PWM fraction. For example, if G=180 then at 50% PWM the ultimate temperature rise would be 90C.
- Cnnn dominant time Constant of the heating process in seconds
- Dnnn Dead time in seconds
- Two additional parameters help control the heating process
- Bn selects Bang-bang control instead of PID if non-zero. Default at power-up is 0 for extruder heaters, 1 for the bed heater.
- Snnn maximum PWM to be used used with this heater on a scale of 0 to 1. Default 1.0.
- Examples
- M307 H0 ; report the process parameters for heater 0
- M307 H1 A346.2 C140 D5.3 B0 S0.8 ; set process parameters for heater 1, use PID, and limit heater 1 PWM to 80%
Each heater and its corresponding load may be approximated as a first order process with dead time, which is characterised by the gain, time constant and dead time parameters. The model can used to calculate optimum PID parameters (including using different values for the heating or cooling phase and the steady state phase), to better detect heater faults, and to calculate feed-forward terms to better respond to changes in the load. Normally these model parameters are found by auto tuning - see M303.
RepRapFirmware 1.16 and later allow the PID controller for a heater to be disabled by setting the A, C and D parameters to -1. This frees up the corresponding heater control pin for use as a general purpose I/O pin.
M320: Activate autolevel (Repetier)
No | No | ??? | ??? | ??? | Yes | No | ??? | No | |
- Usage
- M320
- M320 S1
- Parameters
- Snnn if greater than 0, activate and store persistently in EEPROM
- Examples
- M320 (temporarily activate auto leveling)
- M320 S1 (permanently activate auto leveling)
Parameter Snnn is optional.
(Repetier only)
M321: Deactivate autolevel (Repetier)
- Usage
- M321
- M321 S1
- Parameters
- Snnn if greater than 0, deactivate and store persistently in EEPROM
- Examples
- M321 (temporarily deactivate auto leveling)
- M321 S1 (permanently deactivate auto leveling)
(Repetier only)
M322: Reset autolevel matrix (Repetier)
- Usage
- M322
- M322 S1
- Parameters
- Snnn if greater than 0, also reset the matrix values saved EEPROM
- Examples
- M322 (temporarily reset auto level matrix)
- M322 S1 (permanently reset auto level matrix)
(Repetier only)
M323: Distortion correction on/off (Repetier)
- Usage
- M323
- M323 Snnn
- M323 Snnn Pnnn
- Parameters
- Snnn 0 (disable correction) or 1 (enable correction)
- Pnnn 1 (store correction state persistently in EEPROM)
- Examples
- M323 (Show if distortion correction is enabled)
- M323 S0 (Disable distortion correction temporarily)
- M323 S1 P1 (Enable distortion correction permanently)
(Repetier only) Controls distortion correction feature after having set it up using G33.
M340: Control the servos
M350: Set microstepping mode
Yes | Yes | ??? | ??? | ??? | Yes | No | ??? | Yes | |
??? | No | No | No | No | Yes | No | ??? | ??? |
Sets microstepping mode.
Warning: Steps per unit remains unchanged; except that in RepRapFirmware the steps/mm will be adjusted automatically.
- Usage
- M350 Snn Xnn Ynn Znn Enn Bnn
- Parameters
- Not all parameters need to be used, but at least one should be used. As with other commands, RepRapFirmware reports the current settings if no parameters are used.
- Snn Set stepping mode for all drivers (not supported by RepRapFirmware)
- Xnn Set stepping mode for the X axis
- Ynn Set stepping mode for the Y axis
- Znn Set stepping mode for the Z axis
- Enn Set stepping mode for Extruder 0 (for RepRapFirmware use Enn:nn:nn etc. for multiple extruders)
- Bnn Set stepping mode for Extruder 1 (not supported by RepRapFirmware, see above)
- Inn Enable (nn=1) or disable (nn=0) microstep interpolation mode for the specified drivers, if they support it (RepRapFirmware only)
- Modes (nn)
- 1 = full step
- 2 = half step
- 4 = quarter step
- 8 = 1/8 step
- 16 = 1/16 step
- 64 = 1/64 step
- 128 = 1/128 step
- 256 = 1/256 step
- Examples
- M350 S16 (reset all drivers to the default 1/16 micro-stepping - not supported by RepRapFirmware)
- M350 Z1 (set the Z-axis' driver to use full steps)
- M350 E4 B4 (set both extruders to use quarter steps - Marlin/Repetier)
- M350 E4:4:4 (set extruders 0-2 to use quarter steps - RepRapFirmware)
Yes | No | ??? | ??? | ??? | No | No | ??? | Yes | |
Example: M351
M355: Turn case lights on/off
No | No | ??? | ??? | ??? | Yes: 0.92.2 | No | ??? | No | |
??? | No | No | No | No | No | use M106 | ??? | ??? |
- Examples
- M355 S1 ; Enable lights
- M355 S0 ; Disable lights
- M355 ; Report status
Every call or change over LCD menu sends a state change for connected hosting software like
Case lights on Case lights off No case lights
- Target
- Example
- M360
- Response
Config:Baudrate:250000 Config:InputBuffer:127 Config:NumExtruder:2 Config:MixingExtruder:0 Config:HeatedBed:0 Config:SDCard:1 Config:Fan:1 Config:LCD:1 Config:SoftwarePowerSwitch:1 Config:XHomeDir:-1 Config:YHomeDir:-1 Config:ZHomeDir:-1 Config:SupportG10G11:1 Config:SupportLocalFilamentchange:1 Config:CaseLights:0 Config:ZProbe:1 Config:Autolevel:0 Config:EEPROM:1 Config:PrintlineCache:24 Config:JerkXY:30.00 Config:JerkZ:0.30 Config:RetractionLength:3.00 Config:RetractionLongLength:13.00 Config:RetractionSpeed:40.00 Config:RetractionZLift:0.00 Config:RetractionUndoExtraLength:0.00 Config:RetractionUndoExtraLongLength:0.00 Config:RetractionUndoSpeed:0.00 Config:XMin:0.00 Config:YMin:0.00 Config:ZMin:0.00 Config:XMax:250.00 Config:YMax:150.00 Config:ZMax:90.00 Config:XSize:250.00 Config:YSize:150.00 Config:ZSize:90.00 Config:XPrintAccel:250.00 Config:YPrintAccel:250.00 Config:ZPrintAccel:100.00 Config:XTravelAccel:250.00 Config:YTravelAccel:250.00 Config:ZTravelAccel:100.00 Config:PrinterType:Cartesian Config:MaxBedTemp:120 Config:Extr.1:Jerk:50.00 Config:Extr.1:MaxSpeed:100.00 Config:Extr.1:Acceleration:10000.00 Config:Extr.1:Diameter:0.00 Config:Extr.1:MaxTemp:220 Config:Extr.2:Jerk:50.00 Config:Extr.2:MaxSpeed:100.00 Config:Extr.2:Acceleration:10000.00 Config:Extr.2:Diameter:0.00 Config:Extr.2:MaxTemp:220
Partial | No | ??? | ??? | ??? | No | Yes | ??? | Partial | |
??? | No | No | No | No | ??? | No | ??? | ??? |
Experimental | No | ??? | ??? | ??? | No | Yes | ??? | Experimental | |
Smoothieware: M364 P0 will accept the current position as 90deg between arms. The offset is stored as a trim offset (M666) and no further user interaction is required except to save all changes via M500
M365: SCARA scaling factor
M366: SCARA convert trim
No | No | ??? | ??? | ??? | No | Yes | ??? | No | |
- Usage
- M370
- M370 X<divisions> Y<divisions>
M374: Save calibration grid
Saves the calibration grid. (Smoothieware)
- Usage
- M374
- M374 <file extension> Z
Without parameters safes the grid into the default grid file that gets loaded at boot Parameter specifies the extension of the grid file - useful for special grid files such as for a special print surface like a removable print plate. Addition of Z will additionally save the M206 Z homing offset into the grid file
Display the bed level calibration matrix (Marlin) Load Grid matrix file (Smoothieware)
- Usage
- M375
- M375 <file extension>
M380: Activate solenoid
Yes | No | ??? | ??? | ??? | ??? | No | ??? | Yes | |
Example: M380
M381: Disable all solenoids
Example: M381
??? | Yes | No | No | Yes | ??? | use G4 | ??? | ??? |
- Example
- M400
Finishes all current moves and and thus clears the buffer. That's identical to G4 P0
M401: Lower z-probe
Example: M401
Lower z-probe if present.
M402: Raise z-probe
Example: M402
Raise z-probe if present.
Yes | Yes | ??? | ??? | ??? | No | No | ??? | Yes | |
- Parameters
- Nnnn Filament width (in mm)
- Dnnn Nozzle diameter (in mm)1
- Examples
- M404 N1.75
- M404 N3.0 D1.0
Enter the nominal filament width (3mm, 1.75mm) or will display nominal filament width without parameters.
- Notes
1While Marlin only accepts the 'N' parameter, RepRapFirmware further allows to specify the nozzle diameter (in mm) via the 'D 'parameter. This value is used to properly detect the first layer height when files are parsed or a new print is being started.
M405: Filament Sensor on
Example: M405
M406: Filament Sensor off
Example: M406
{{firmware Support | fived=style="background:#F99;vertical-align:middle;text-align:center;" class="table-no"|No | teacup=style="background:#F99;vertical-align:middle;text-align:center;" class="table-no"|No | sprinter=style="background:#F99;vertical-align:middle;text-align:center;" class="table-no"|No | marlin=style="background:#9F9;vertical-align:middle;text-align:center;" class="table-yes"|Yes | repetier=style="background:#F99;vertical-align:middle;text-align:center;" class="table-no"|No | smoothie=style="background:#F99;vertical-align:middle;text-align:center;" class="table-no"|No | bfb=style="background:#F99;vertical-align:middle;text-align:center;" class="table-no"|No | machinekit=style="background:#F99;vertical-align:middle;text-align:center;" class="table-no"|No | reprapfirmware=style="background:#9F9;vertical-align:middle;text-align:center;" class="table-yes"|Yes | mk4duo={{yes} }}
- Example
- M407
Displays measured filament diameter. In RepRapFirmware, M407 does the same as M404.
- Parameters
- Snnn Response type
- Rnnn Response sequence number
- Example
- M408 S0
Report a JSON-style response by specifying the desired type using the 'S' parameter.
The following response types are supported:
- Type 0 is a short-form response, similar to the response used by older versions of the web interface.
- Type 1 is like type 0 except that static values are also included.
- Type 2 is similar to the response provided by the web server for Duet Web Control.
- Type 3 is an extended version of type 2 which includes some additional parameters that aren't expected to change very frequently.
- Type 4 is an extended version of type 2 which may be used to poll for current printer statistics.
- Type 5 reports the current machine configuration.
Here is an example of a typical type 0 response:
{"status":"I","heaters":[25.0,29.0,28.3],"active":[-273.1,0.0,0.0],"standby":[-273.1,0.0,0.0],"hstat":[0,2,1],"pos":[-11.00,0.00,0.00],"extr":[0.0,0.0], "sfactor":100.00, "efactor":[100.00,100.00],"tool":1,"probe":"535","fanPercent":[75.0,0.0],"fanRPM":0,"homed":[0,0,0],"fraction_printed":0.572}
The response is set as a single line with a newline character at the end. The meaning of the fields is:
status: I=idle, P=printing from SD card, S=stopped (i.e. needs a reset), C=running config file, A=paused, D=pausing, R=resuming, B=busy (running a macro) heaters: current heater temperatures, numbered as per the machine (typically, heater 0 is the bed) active: active temperatures of the heaters standby: standby temperatures of the heaters hstat: status of the heaters, 0=off, 1=standby, 2=active, 3=fault pos: the X, Y and Z positions of the current tool (if a tool is selected), or the print head reference point if no tool is selected extr: the positions of the extruders sfactor: the current speed factor (see M220 command) efactor: the current extrusion factors (see M221 command) tool: the selected tool number. A negative number typically means no tool selected. probe: the Z-probe reading fanPercent: the speeds of the controllable fans, in percent of maximum fanRPM: the cooling fan RPM homed: the homed status of the X, Y and Z axes (or towers on a delta). 0=axis has not been homed so position is not reliable, 1=axis has been homed so position is reliable. fraction_printed: the fraction of the file currently being printed that has been read and at least partially processed. message: the message to be displayed on the screen (only present if there is a message to display) timesLeft: an array of the estimated remaining print times (in seconds) calculated by different methods. These are currently based on the proportion of the file read, the proportion of the total filament consumed, and the proportion of the total layers already printed. Only present if a print from SD card is in progress. seq: the sequence number of the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater than that. resp: the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater.
The type 1 response comprises these fields plus some additional ones that do not generally change and therefore do not need to be fetched as often. The extra fields include:
myName: the name of the printer geometry: one of "cartesian", "delta", "corexy, "corexz" etc.
For a more detailed comparison of type 2 - 5, see RepRap_Firmware_Status_responses.
PanelDue currently uses only M408 S0 and M408 S1.
M420: Set RGB Colors as PWM (MachineKit)
??? | No | No | No | Yes | ??? | No | ??? | ??? |
Example: M420 R255 E255 B255
In marlin, is also: M420 - Enable/Disable Mesh Leveling (with current values) S1=enable S0=disable
M420: Enable/Disable Mesh Leveling (Marlin)
Example: M420 S1
Enable/Disable Mesh Leveling (with current stored mesh). S1=enable S0=disable
M421: Set a Mesh Bed Leveling Z coordinate
M421 - Set a single Z coordinate in the Mesh Leveling grid. X<index> Y<index> Z<offset in mm>
M450: Report Printer Mode
Usage: M450
Example: M450 Output: PrinterMode:FFF
Printers can be used for different task by exchanging the toolhead. Depending on the tool, a different behavior of some commands can be expected. This command reports the current working mode. Possible answers are:
- PrinterMode:FFF
- PrinterMode:Laser
- PrinterMode:CNC
M451: Select FFF Printer Mode
- Usage
- M451
- Example
- M451
- Output
- PrinterMode:FFF
Switches to FFF mode for filament printing.
M452: Select Laser Printer Mode
- Usage
- M452
- Example
- M452
- Output
- PrinterMode:Laser
Switches to laser mode. This mode enables handling of a laser pin and makes sure that the laser is only activated during G1 moves if laser was enabled or E is increasing. G0 moves should never enable the laser. M3/M5 can be used to enable/disable the laser for moves.
M453: Select CNC Printer Mode
- Usage
- M453
- Example
- M453
- Output
- PrinterMode:CNC
Switches to CNC mode. In this mode M3/M4/M5 control the pins defined for the milling device.
M460: Define temperature range for thermistor controlled fan
Support | Marlin | RepRapFirmware | Klipper | Prusa | Buddy | Repetier | Smoothie | Druid | MK4duo |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | MakerBot | |
- Usage
- M460 X<minTemp> Y<maxTemp>
- Example
- M460 X50 Y60
If the firmware has a thermistor controlled fan defined, you can set at which temperature the fan starts and from which temperature on it should run with maximum speed.
M500: Store parameters in EEPROM
Yes | Yes | ??? | ??? | ??? | Yes | ??? | ??? | Yes | |
- Example
- M500
Save current parameters to EEPROM.
M501: Read parameters from EEPROM
- Parameters
- Snnn Enable auto-save (only RepRapFirmware)
- Example
- M501
Set the active parameters to those stored in the EEPROM. This is useful to revert parameters after experimenting with them.
RepRapFirmware allows "S1" to be passed, which forces parameters to be automatically saved to EEPROM when they are changed.
M502: Revert to the default "factory settings."
- Example
- M502
This command resets all tunable parameters to their default values, as set in the firmware. This doesn't reset any parameters stored in the EEPROM, so it must be followed with M500 if you want to do that.
M503: Print settings
Yes | Yes | ??? | ??? | ??? | ??? | ??? | ??? | Yes | |
- Example
- M503
This command asks the firmware to reply with the current print settings stored in EEPROM. The reply output includes the G-Code commands to produce each setting. For example, the Steps Per Unit values are displayed as an M92 command.
RepRapFirmware outputs the content of the configuration file, but note that it may be truncated if it is too long.
M530: Enable printing mode
No | No | ??? | ??? | ??? | Yes | ??? | ??? | Yes | |
- Example
M530 S1 L270
This command tells the firmware that a print has started (S1) or ended (S0). The L parameter sets the number of layers. L0 denotes unknown layer count. This enables the firmware to switch into a special print display mode to show print progress. Firmware should indicate the presence of this feature by responding to M115 with an additional line:
Cap:PROGRESS:1
M531: Set print name
- Example
M531 Demo Model
Sets the name of the currently printed object. Should follow M530 S1 for correct display.
M532: Set print progress
- Example
- M532 X23.7 L56
Sets the print progress (X = 0..100) and currently printed layer (L). Should be send every 0.1% progress change on every layer change.
M540: Enable/Disable "Stop SD Print on Endstop Hit"
- Parameters
- Snnn state, S1=enable, S0=disable
- Example
- M540 S1
M540: Set MAC address
- Parameters
- Pnnn The MAC address
- Examples
- M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED
- M540 PDE:AD:BE:EF:CA:FE
All devices running on the same network shall all have different MAC addresses. For your printers, changing the last digit is sufficient.
M550: Set Name
- Parameters
- Pnnn Machine name
- Example
- M550 PGodzilla
M551: Set Password
- Parameters
- Pnnn Password
- Example
- M551 Pmy-very-secret-word
Note for RepRapFirmware: If the specified password differs from the default one (i.e. reprap), the user will be asked to enter it when a connection is established via HTTP or Telnet. For FTP, the password must always be passed explicitly.
M552: Set IP address
- Parameters
- Pnnn IP address
- Snnn Enable networking (optional)
- Rnnn HTTP port (default 80)
- Example
- M552 P192.168.1.14
Sets the IP address of the RepRap machine to (in this case) 192.168.1.14. A restart may be required before the new IP address is used. If no 'P' field is specified, this echoes the existing IP address configured. If S0 is added thus: M552 S0 P192.168.1.14 networking is disabled. If you set the address M552 P0.0.0.0 the RepRap machine will try to obtain its IP address from the network's DHCP server, whereupon it will appear on the network with an address something like http://godzilla.home, where godzilla is the name set by the M550 command (see above). The precise URL incorporating that name will depend on the conventions of your network.
Recent RepRapFirmware versions allow the IP configuration to be changed without a restart.
M553: Set Netmask
- Parameters
- Pnnn Net mask
- Example
- M553 P255.255.255.0
Sets the network mask of the RepRap machine to (in this case) 255.255.255.0. A restart may be required before the new network mask is used. If no 'P' field is specified, this echoes the existing network mask configured.
M554: Set Gateway
- Parameters
- Pnnn Gateway
- Example
- M554 P192.168.1.1
Sets the Gateway IP address of the RepRap machine to (in this case) 192.168.1.1. A restart may be required before the new gateway IP address is used. If no 'P' field is specified, this echoes the existing Gateway IP address configured.
M555: Set compatibility
- Parameters
- Pnnn Emulation type
- Example
- M555 P1
For firmware that can do it, the firmware is set to a mode where its input and (especially) output behaves exactly like other established firmware. The value of the 'P' argument is:
P value | Firmware |
0 | Native (i.e. whatever the firmware actually is) |
1 | RepRap_Firmware |
2 | Marlin |
3 | Teacup |
4 | Sprinter |
5 | Repetier |
M556: Axis compensation
- Parameters
- Snnn Height of the measured distances
- Xnnn Deviation in X direction
- Ynnn Deviation in Y direction
- Znnn Deviation in Z direction
- Example
- M556 S100 X0.7 Y-0.2 Z0.6
M557: Set Z probe point or define probing grid
- Parameters to define G32 probe points (Cartesian/CoreXY printer only)
- Pnnn Probe point number
- Xnnn X coordinate
- Ynnn Y coordinate
- Example
- M557 P1 X30 Y40.5
- Parameters to define G29 probe grid (all values in mm)
- Xaaa:bbb Minimum and maximum X coordinates to probe
- Yaaa:bbb Minimum and maximum Y coordinates to probe
- R Radius to probe
- S Probing interval
- Examples
- M557 X0:200 Y0:220 S20
- M557 R150 S15
Set the points at which the bed will be probed to compensate for its plane being slightly out of horizontal.
The first form defines the points for for G32 bed probing. The P value is the index of the point (indices start at 0) and the X and Y values are the position to move extruder 0 to to probe the bed. An implementation should allow a minimum of three points (P0, P1 and P2). This just records the point coordinates; it does not actually do the probing. See G32.
The second form defines the grid for G29 bed probing. For Cartesian printers, specify minimum and maximum X and Y values to probe and the probing interval. For Delta printers, specify the probing radius. There is a firmware-dependent maximum number of probe points supported, which may be as low as 100.
M558: Set Z probe type
- Parameters
- Pnnn Z probe type
- Xnnn Use probe for X axis
- Ynnn Use probe for Y axis
- Znnn Use probe for Z axis
- Fnnn Feed rate (i.e. probing speed)1
- Hnnn Dive height1
- Innn Invert (I1) or do not invert (I0) the Z probe reading (RepRapFirmware 1.16 and later)
- Tnnn Travel speed to probe points1
- Snnn Extra parameter for experimentation (1)
- Rnnn Extra parameter for experimentation (2)2
- Example
- M558 P0 X1 Y0 Z1
A Z probe may be a switch, an IR proximity sensor, or some other device. This selects which to use. P0 indicates that no Z probe is present. P1 gives an unmodulated IR probe, or any other probe type that emulates an unmodulated IR probe (probe output is an analog signal that rises with decreasing nozzle height above the bed). If there is a control signal to the probe, it is driven high when the probe type is P1. P2 specifies a modulated IR probe, where the modulation is commanded directly by the main board firmware using the control signal to the probe. P3 selects an alternative Z probe by driving the control signal to the probe low. P4 selects a switch for bed probing (on the Duet, this must be connected to the E0 endstop pins). P5 (from DC42 1.14) selects a switch (normally closed) for bed probing between In and Gnd pins of the Z-probe connector (Duet 0.8.5 and Duet WiFi).
The X, Y and Z parameters specify whether each axis uses the Z probe for homing or not. If the parameter is nonzero, the Z probe is used for homing that axis. if the parameter is zero, the endstop switch for that axis is used for homing instead. See also G31 and G32.
Recent versions of RepRapFirmware support an additional parameter H. This specifies the dive height (default 3mm) from which probing is done in response to a G30 command when the P parameter is present, or a G32 command.
- Notes
1These parameters are only supported by recent RepRapFirmware versions and should be specified in mm/min.
2This parameter used to specify the Z probe channel in RepRapFirmware, but it has been superceded by the functionality of "M115 Px". With older firmware versions and a Duet 0.7/0.85, this parameter should be 1.
- Example
- M559
M560: Upload web page file
- Example
- M560
<!-- **EoF** -->. Clearly that string cannot exist in the body of the file, but can be put on the end to facilitate this process. This should not be too serious a restriction...
M561: Set Identity Transform
No | Yes | ??? | ??? | ??? | No | Yes | ??? | No | |
- Example
- M561
M562: Reset temperature fault
- Parameters
- Example
- M562 P2
M563: Define or remove a tool
- Parameters
- Pnnn Tool number
- Dnnn Extruder drive(s)
- Hnnn Heater(s)
- Fnnn Fan(s) to map fan 0 to (RepRapFirmware 1.16 and later)
- Xnnn Axis or axes to map X movement to (RepRapFirmware 1.16 and later)
- Example
- M563 P0 D0:2:3 H1:3 ; create a tool using extruder drives 0, 2 and 3 and heaters 1 and 3
- M563 P1 D1 H2 X3 ; create a tool using extruder drive 1 and heater 2 with X movement mapped to the U axis
- M563 P2 D0:1 H1:2 X0:3 F0:2 ; create a tool using extruder drives 0 and 1, heaters 1 and 2, with X movement mapped to both X and U axes and fan 0 mapped to fan 0 and fan 2
Tools are usually (though not necessarily) extruders. The 'P' field specifies the tool number. Tool numbers can have any positive integer value and 0. The 'D' field specifies the drive(s) used by the tool - in the first example drives 0, 2 and 3. Drive 0 is the first drive in the machine after the movement drives (usually X, Y and Z). If there is no 'D' field the tool has no drives. The 'H' field specifies the tool's heaters - in the first example heaters 1 and 3. Heater 0 is usually the hot bed (if any) so the first extruder heater is usually 1. If there is no H field the tool has no heaters.
Tools are driven using multiple values in the 'E' field of G1 commands, each controlling the corresponding drive in the 'D' field above, as follows:
G1 X90.6 Y13.8 E2.24:2.24:15.89 G1 X70.6 E0:0:42.4
The first line moves straight to the point (90.6, 13.8) extruding a total of 2.24mm of filament from both drives 0 and 2 and 15.98mm of filament from drive 3. The second line moves back 20mm in X extruding 42.4mm of filament from drive 3.
Alternatively, if the slicer does not support generating G1 commands with multiple values for the extrusion amount, the M567 command can be used to define a tool mix ratio.
The X mapping option is used to create tools on machines with multiple independent X carriages. The additional carriages are set up as axes U, V etc. (see M584) and the X mapping option in M563 defines which carriage or carriages are used.
RepRapFirmware supports an additional form of the M563 command. The command:
M563 S1
means add 1 (the value of the S parameter) to all tool numbers found in the remainder of the current input stream (e.g. the current file if the command is read from a file on the SD card), or until a new M563 command of this form is executed. The purpose of this is to provide compatibility between systems in which tool numbers start at 1, and programs such as slic3r that assume tools are numbered from zero.
Recent versions of RepRapFirmware allow the deletion of existing tools if M563 is called in this way:
M563 P1 D-1 H-1
M564: Limit axes
No | Yes | ??? | ??? | ??? | No | No | ??? | No | |
- Parameters
- Snnn Limit movement within axis boundaries
- Example
- M564 S0
Allow moves outside the print volume, or not. If the S parameter is 0, then you can send G codes to drive the RepRap outside its normal working volume, and it will attempt to do so. User beware... If you set the S parameter to 1 then the RepRap will not think outside the box. The default behaviour is S = 1.
M565: Set Z probe offset
No | see G31 | ??? | ??? | ??? | No | Yes | ??? | No | |
Example: M565 X3 Y4.5 Z-2.37
Set the offset from the extruder tip to the probe position. The X, Y and Z values are the delta between the extruder and the actual trigger position of the probe. If the probe trigger point is below the extruder (typical) the Z offset will be negative. This just records the point offset; it does not actually do the probing. See G32.
- Parameters
- Xnnn Maximum instantaneous speed change of the X axis (mm/min)
- Ynnn Maximum instantaneous speed change of the Y axis
- Znnn Maximum instantaneous speed change of the Z axis
- Ennn Maximum instantaneous speed change of the extruder drives
- Example
- M566 X20 Y20 Z2 E10
Sets the maximum allowable speed change (sometimes called 'jerk speed') of each motor when changing direction.
The model files and gcode files used by repraps generally render circles and other curves shapes as a sequence of straight line segments. If the motors were not allowed any instantaneous speed change, they would have to come to a stop at the junction between each pair of line segments. By allowing a certain amount of instantaneous speed change, printing speed can be maintained when the angle between the two line segments is small enough.
If you set these X and Y values too low, then the printer will be slow at printing curves. If they are too high then the printer may be noisy when cornering and you may suffer ringing and other print artefacts, or even missed steps.
On very old versions of RepRapFirmware (prior to 1.09), these were also the minimum speeds of each axis.
M567: Set tool mix ratios
- Parameters
- Pnnn Tool number
- Ennn Mix ratios
- Example
- M567 P2 E0.1:0.2:0.1:0.6
This example sets the mix ratio for tool 2 (the P value). When mixing is then turned on (see M568), only single E values need to be sent on a G1 command (any extra E values will be ignored, but are not illegal):
G1 X20 E1.3
See also M568.
- Parameters
- Pnnn Tool number
- Snnn Whether mix ratios should be activated
- Example
- M568 P2 S0
G1 X20 E0.2:0.4:0.166:0.3
The off state is the default.
M569: Set axis direction and enable values
- Parameters
- Pnnn Motor driver number
- Snnn Direction of movement of the motor(s) attached to this driver: 0 = backwards, 1 = forwards
- Rnnn Driver enable polarity: 0 = active low, 1 = active high (default 0)
- Tnnn Minimum driver step pulse width and interval in microseconds1
- Example
- M569 P0 S1
Set the control value for the drive specified by P that sends it forwards to the given value in the S field. After sending the example, sending a 1 to X (drive 0) will make it go forwards, sending a 0 will make it go backwards. Obviously to be used with extreme caution...
- Notes
1RepRapFirmware 1.14 and later support the T parameter, to allow the step pulse width and interval to be lengthened for those drivers that need it. If no T parameter is given, then the step pulse width and interval are guaranteed to be suitable for the on-board drivers. Currently, RepRapFirmware only remembers the highest T parameter seen in any M569 command, and applies that value to all drivers for which any nonzero T parameter was specified.
Some versions of RepRapFirmware prior to 1.14 also provide XYZ and E parameters to allow the mapping from axes and extruders to stepper driver numbers to be changed. From 1.14 onward, this functionality is provided by M584 instead.
M570: Configure heater fault detection
- Parameters for RepRapFirmware 1.14 and earlier
- Snnn Heater timeout (in seconds)
- Example
- M570 S120
After a heater has been switched on, wait 120 seconds for it to get close to the set temperature. If it takes longer than this, raise a heater fault.
- Parameters for RepRapFirmware 1.15e and later
- Hnnn Heater number
- Pnnn Time in seconds for which a temperature anomaly must persist on this heater before raising a heater fault (default 5 seconds)
- Tnnn Permitted temperature excursion from the setpoint for this heater (default 10C)
- Example
- M570 H1 P4 T15
Warning! Heating fault detection is provided to reduce the risk of starting a fire if a dangerous fault occurs, for example if the heater cartridge or thermistor falls out of the heater block. You should not increase the detection time or permitted temperature excursion without good reason, because doing so will reduce the protection.
M571: Set output on extrude
- Parameters
- Snnn Output value
- Example
- M571 S0.5
This turns the controlled fan 0 output on whenever extrusion is being done, and turns it off when the extrusion is finished. The output could control a fan or a stirrer or anything else that needs to work just when extrusion is happening. The S parameter sets the value of the PWM to the output. 0.0 is off; 1.0 is fully on. It also can be used to control a laser beam.
M572: Set or report extruder pressure advance
No | dc42, ch, dn | ??? | ??? | ??? | No | No | ??? | No | |
- Parameters
- Dnnn Extruder number
- Snnn Pressure advance amount (in seconds)
- Example
- M572 D0 S0.1
This sets the pressure advance coefficient (S parameter) for the specified extruder (D parameter). Supported by RepRapFirmware-dc42, -ch and -dn.
Pressure advance causes the extruder drive position to be advanced or retarded during printing moves by an additional amount proportional to the rate of extrusion. At the end of a move when the extrusion rate is decreasing, this may result in the extruder drive moving backwards (i.e. retracting). Therefore, if you enable this feature, you may need to reduce the amount of retraction you use in your slicing program to avoid over-retraction.
With Bowden extruders, an S value between 0.1 and 0.2 usually gives the best print quality.
Older versions of RepRapFirmware used the P parameter to specify the drive number, instead of using D to specify the extruder number.
M573: Report heater PWM
- Parameters
- Example
- M573 P1
This gives a running average (usually taken over about five seconds) of the PWM to the heater specified by the P field. If you know the voltage of the supply and the resistance of the heater this allows you to work out the power going to the heater. Scale: 0 to 1.
- Parameters
- Xnnn Switch type for X axis
- Ynnn Switch type for Y axis
- Znnn Switch type for Z axis
- E Select extruder endstops to define active high or low (RepRapFirmware 1.16 and earlier only)
- Snnn Logic level
- Example
- M574 X1 Y2 Z0 S1 ; X endstop at low end, Y endstop at high end, no Z endstop, all active high
This defines the type of endstop switch or opto sensor that the printer has for each axis: 0 = none, 1 = low end, 2 = high end. The optional S parameter defines whether the endstop input is active high (S1, the default) or low (S0). A normally-closed endstop switch wired in the usual way produces an active high output (S1).
This is intended for use with boards that provide a single endstop input for each axis that may be used for either a high or a low end endstop, such as the Duet. On delta printers, the XYZ parameters refer to the towers and the endstops should normally all be high end (i.e. at the top of the towers).
In RepRapFirmware 1.16 and earlier, the M574 command with E parameter is used to specify whether a Z probe connected to the E0 endstop input produces an active high (S1) or active low (S0) output. In RepRapFirmware 1.17 and later, use the I parameter of the M558 command instead.
- Parameters
- Pnnn Serial channel number
- Bnnn Baud rate
- Snnn Whether checksums should be used
- Example
- M575 P1 B57600 S1
This sets the communications parameters of the serial comms channel specified by the P parameter. P0 specifies the main serial interface (typically a USB port, or serial-over-USB), while P1 specifies an auxiliary serial port (for example, the port used to connect a PanelDue). The B parameter is the required baud rate (this parameter is typically ignored if the port is a true USB port). The S parameter is a bitmap of features. The lowest bit, if set, specifies that only commands that include a valid checksum should be accepted from this comms channel.
M577: Wait until endstop is triggered
??? | No | No | No | No | ??? | No | ??? | No |
- Parameters
- Snnn Desired endstop level
- Xnnn Select X axis endstop
- Ynnn Select Y axis endstop
- Znnn Select Z axis endstop
- Ennn Select extruder drive endstop
- Example
- M577 E0 S1
Wait for an endstop switch to be pressed. The example above will wait until the first extruder endstop is triggered.
The following trigger types may be used using the 'S' parameter:
0: Endstop not hit 1: Low endstop hit 2: High endstop hit 3: Near endstop (only Z probe)
M578: Fire inkjet bits
- Parameters
- Pnnn Inkjet head number
- Snnn Bit pattern
- Example
- M578 P3 S5
This fires inkjet head 3 (the P field) using the bit pattern specified by the S field. The example shown would fire bits 101. If the P parameter is ommitted inkjet 0 is assumed.
This is a version of the M700 command used by the Inkshield, but unfortunately M700 is already taken so cannot be used for that in the standard.
M579: Scale Cartesian axes
- Parameters
- Xnnn Scale factor for X axis
- Ynnn Scale factor for Y axis
- Znnn Scale factor for Z axis
- Example
- M579 X1.0127 Y0.998
On a Cartesian RepRap you can get prints exactly the right size by tweaking the axis steps/mm using the M92 G Code above. But this does not work so easily for Delta and other RepRaps for which there is cross-talk between the axes. This command allows you to adjust the X, Y, and Z axis scales directly. So, if you print a part for which the Y length should be 100mm and measure it and find that it is 100.3mm long then you set Y0.997 (= 100/100.3).
M580: Select Roland
- Parameters
- Rnnn Whether Roland mode should be activated
- Pnnn Initial text to send to the Roland controller
- Example
- M580 R1 PVS4;!VZ2;!MC1;
This is not really anything to do with RepRap, but it is convenient. The little Roland mills are very widely available in hackerspaces and maker groups, but annoyingly they don't speak G Codes. As all RepRap firmware includes a G-Code interpreter, it is often easy to add functions to convert G Codes to Roland RML language. M580 selects a Roland device for output if the R field is 1, and returns to native mode if the R field is 0. The optional P string is sent to the Roland if R is 1. It is permissible to call this repeatedly with R set to 1 and different strings in the P field to communicate directly with a Roland.
M581: Configure external trigger
No | dc42 | ??? | ??? | ??? | No | No | ??? | No | |
- Parameters
- Tnn Logical trigger number to associate the endstop input(s) with, from zero up to a firmware-specific maximum (e.g. 9 for RepRapFirmware)
- X, Y, Z, E Selects endstop input(s) to monitor
- P Reserved, may be used in future to allow general I/O pins to cause triggers
- S Whether trigger occurs on a rising edge of that input (S1, default), falling edge (S0), or ignores that input (S-1). By default, all triggers ignore all inputs.
- C Condition: whether to trigger at any time (C0, default) or only when printing a file from SD card (C1)
- Example
- M581 E1:2 S1 T2 C1 ; invoke trigger 2 when a rising edge is detected on the E1 or E2 endstop input and a file is being printed from SD card
When M581 is executed, if the T parameter is present but the other parameters are omitted, the trigger inputs and edge polarities for that trigger number are reported. Otherwise, the specified inputs and their polarities are added to the conditions that cause that trigger. Using S-1 with no X Y Z or E parameters sets the trigger back to ignoring all inputs.
In RepRapFirmware, trigger number 0 causes an emergency stop as if M112 had been received. Trigger number 1 causes the print to be paused as if M25 had been received. Any trigger number # greater then 1 causes the macro file sys/trigger#.g to be executed. Polling for further trigger conditions is suspended until the trigger macro file has been completed. RepRapFirmware does not wait for all queued moves to be completed before executing the macro, so you may wish to use the M400 command at the start of your macro file. If several triggers are pending, the one with the lowest trigger number takes priority.
M582: Check external trigger
- Parameters
- T Trigger number to poll
- Example
- M582 T2 ; check levels of inputs that give rise to trigger #2
Triggers set up by the M581 command are normally activated only when the specified inputs change state. This command provides a way of causing the trigger to be executed if the input is at a certain level. For each of the inputs associated with the trigger, the trigger condition will be checked as if the input had just changed from the opposite state to the current state.
For example, if you use M581 to support an out-of-filament sensor, then M582 allows you to check for out-of-filament just before starting a print.
M583: Wait for pin
No | {soon} | ??? | ??? | ??? | No | No | ??? | No | |
- Parameters
- Pnnn Pin number
- Sn State to wait for (0 or 1) or analogue tolerance
- Rnnn Analogue value to wait for (between 0.0 and 1.0)
- Example
- M583 P5 S0 ; Wait for Pin 5 to become 0
This allows you, for example, to turn on a DC motor (see the M42 command) then wait until a switch connected to Pin Pnnn gives the value Sn.
If the R field is present, then the system waits until the value on analogue Pnnn is reached. In this case the S value is used as a tolerance, so M583 P8 R0.7 S0.01 would wait until the analogue value on Pin 8 was between 0.69 and 0.71.
M584: Set drive mapping
No | Version 1.14 and later | ??? | ??? | ??? | No | No | ??? | No | |
- Parameters
- Xnnn Driver number(s) for X motor(s)
- Ynnn Driver number(s) for Y motor(s)
- Znnn Driver number(s) for Y motor(s)
- U,V,Wnnn Driver number(s) for additional axes U, V and W (RepRapFirmware 1.16 and later)
- Ennn Driver number(s) for E motor(s)
- Snnn Special functions (to be defined)
- Example
- M584 X0 Y1 Z2:3 E4:5:6 ; Driver 0 controls the X motor, 1 controls the Y motor, 2 and 3 control the Z motors, 4 and 5 control the E motors
Assigning a drive using M584 does not remove its old assignment. Therefore, if you assign a drive that defaults to being an extruder drive, you should also assign the extruder drives explicitly as in the above example. Failure to do so may result in unexpected behaviour.
You can use M584 to create additional axes - for example, to represent additional carriages on a machine with multiple independent X carriages. You should not create axis W unless you also create axis V, and you should not create axis V unless you also create axis U.
M585: Probe Tool
No | Template:Soon | ??? | ??? | ??? | No | No | ??? | No | |
In machines with a tool probe this probes the currently selected tool against it and corrects the offsets set by the G10 command (q.v.).
- Parameter; one of
- Xnnn
- Y-nnn
- Znnn
Where the absolute value of nnn is the radius of the tool plus the radius of the probe in that direction. So M585 X1.5 will set the X offset of a 1mm diameter tool against a 2mm diameter probe, etc. If the value of nnn is positive the tool is moved in the positive direction towards the probe until it touches. If it is negative, the tool moves the other way.
So the process should be:
- Set the values as closely as known in the G10 command.
- Move to a position slightly offset from the probe then execute M585s in X, Y and Z in the tool selection macro to set them precisely.
After this, the G10 command on its own can be used to report the values.
M590: Report current tool type and index
No | No | ??? | ??? | ??? | No | No | ??? | No | |
No | No | No | No | No | No | No | ??? | No |
Report the current tool type, which may be "Extruder," "Picker," "Laser," "Foam Cutter," "Milling," or any others implemented by the machine. Also report the tool index, such as "0x01" for the second extruder.
- Example
- M590
- echo: Extruder 0x00
M600: Set line cross section
No | No | ??? | ??? | ??? | ??? | ??? | ??? | No | |
Example: M600 P0.061
Sets the cross section for a line to extrude in velocity extrusion mode. When the extruder is enabled and movement is executed the amount of extruded filament will be calculated to match the specified line cross section.
M600: Filament change pause
Yes | Use macro files instead | ??? | ??? | ??? | ??? | ??? | ??? | Yes | |
Example: M600
Pause for filament change X[pos] Y[pos] Z[relative lift] E[initial retract] L[later retract distance for removal].
Yes | Use M563 | ??? | ??? | ??? | ??? | No | ??? | Yes | |
Example: M605 S1
Sets the dual x-carriage movement mode: S<mode> [ X<duplication x-offset> R<duplication temp offset> ].
M605 S0: Full control mode. The slicer has full control over x-carriage movement M605 S1: Auto-park mode. The inactive head will auto park/unpark without slicer involvement M605 S2 [Xnnn] [Rmmm]: Duplication mode. The second extruder will duplicate the first with nnn millimeters x-offset and an optional differential hotend temperature of mmm degrees. E.g., with "M605 S2 X100 R2" the second extruder will duplicate the first with a spacing of 100mm in the x direction and 2 degrees hotter.
M665: Set delta configuration
Yes | Yes | ??? | ??? | ??? | No | Yes | ??? | Yes | |
- Parameters
- Lnnn Diagonal rod length
- Rnnn Delta radius
- Snnn Segments per second1
- Bnnn Safe printing radius2
- Hnnn Nozzle height above the bed when homed after allowing for endstop corrections2
- Xnnn X tower position correction3
- Ynnn Y tower position correction3
- Znnn Z tower position correction3
- Examples
- M665 L250 R160 S200 (Marlin)
- M665 L250 R160 B80 H240 X0 Y0 Z0 (RepRapFirmware)
Set the delta calibration variables.
- I don't think it's a good idea to have two different implementations for the same G-code, and I also question the practical value of specifying the print bed radius when defining a delta configuration, since many delta printers use a square or rectangular print bed. So perhaps we should stick to the Marlin-defined command as the definition for this command, and use a different command or set of commands to define print bed shape and size. --AndrewBCN (talk) 23:10, 31 January 2015 (PST)
- The implementations are not different, they have the same L and R parameters, but each has additional parameters that are not relevant to the other implementation. I'm not against defining a new Gcode to define bed size and shape; however, you can already define the limits of a rectangular print area using M208. Even when a delta printer has a square bed, the printable area is not square. It is usually taken to be circular, although it is in reality more complicated. My purpose in adding the B parameter was to make it easy to define a radius outside which movement will not normally be attempted. I have changed "bed radius" to "safe printing radius" in the text to help clarify this. --dc42
- Notes
1Only supported on Marlin.
2Only supported in RepRapFirmware.
3X, Y and Z tower angular offsets from the ideal (i.e. equilateral triangle) positions, in degrees, measured anti-clockwise looking down on the printer.
Yes | Yes | ??? | ??? | ??? | Yes | Yes | ??? | Yes | |
- Parameters
- Xnnn X axis endstop adjustment
- Ynnn Y axis endstop adjustment
- Znnn Z axis endstop adjustment
- Annn X bed tilt in percent1
- Bnnn Y bed tilt in percent1
- Example
- M666 X-0.1 Y+0.2 Z0
In RepRapFirmware and Repetier, positive endstop adjustments move the head closer to the bed when it is near the corresponding tower. In Marlin and Smoothieware, negative endstop corrections move the head closer to the bed when it is near the corresponding tower.
In Marlin, only negative endstop corrections are allowed.
In Repetier the endstop corrections are expressed in motor steps. In other firmwares they are expressed in mm.
1RepRapFirmware 1.16 and later.
M667: Select CoreXY mode
- Parameters
- Snnn CoreXY mode
- Xnnn X axis scale factor
- Ynnn Y axis scale factor
- Znnn Z axis scale factor
- Example
- M667 S1
M667 S0 selects Cartesian mode (unless the printer is configured as a delta using the M665 command). Forward motion of the X motor moves the head in the +X direction. Similarly for the Y motor and Y axis, and the Z motor and Z axis. This is the default state of the firmware on power up.
M667 S1 selects CoreXY mode. Forward movement of the X motor moves the head in the +X and +Y directions. Forward movement of the Y motor moves the head in the -X and +Y directions.
M667 S2 selects CoreXZ mode. Forward movement of the X motor moves the head in the +X and +Z directions. Forward movement of the Z motor moves the head in the -X and +Z directions.
M667 S3 selects CoreYZ mode. Forward movement of the Y motor moves the head in the +Y and +Z directions. Forward movement of the Z motor moves the head in the -Y and +Z directions.
Additional parameters X, Y and Z may be given to specify factors to scale the motor movements by for the corresponding axes. For example, to specify a CoreXZ machine in which the Z axis moves 1/3 of the distance of the X axis for the same motor movement, use M667 S2 Z3. The default scaling factor after power up is 1.0 for all axes.
To change the motor directions, see the M569 command.
M668: Set Z-offset compensations polynomial
No | dc42-cmm | ??? | ??? | ??? | No | No | ??? | No | |
Polynomial compensation is an experimental method to compensate for geometric distortion of a delta machine Z-plane. After the bed is compensated with the set of G30 points, there remains error. This method fits a 6th degree polynomial with independent origins for each order to the residual error data (using a simulated annealing technique on the host). The polynomial is communicated and controlled through M668. Because the polynomial takes many floating point operations to compute each point, the firmware builds a grid of values, and used bi-linear interpolation to adjust the actual Z-axis offset error estimate.
For the polynomial used, 40 parameters are specified. The I parameter allows the coefficients to be loaded a few at a time, which limits the size of the G-code string. The index starts with 1, not with 0.
M668 Ix S[list of values] sets the polynomial parameters starting at index x, if index present and != 0.
M668 R recomputes the grid based on the current parameters.
M668 P[0|1] turns off or on the polynomial compensation.
Typical use would be:
M668 I1 S4.882E-17:0.0 M668 I3 ... ... M668 R P1
Which sets the list, computes the interpolation grid, and then enables compensation.
M700: Level plate
bq | No | ??? | ??? | ??? | No | No | ??? | bq | |
Example: M700
M701: Load filament
1 only in bq-Marlin Firmware
Example: M701
M702: Unload filament
Example: M702
M703: Get Board Type
Example: M703
M710: Erase the EEPROM and reset the board
Example: M710
M800: Fire start print procedure
Example: M800
M801: Fire end print procedure
Example: M801
M851: Set Z-Probe Offset
Yes | Use G31 | ??? | ??? | ??? | ??? | ??? | ??? | Yes | |
Sets the Z-probe Z offset. This offset is used to determine the actual Z position of the nozzle when using a probe to home Z with G28. This value may also be used by G29 to apply correction to the Z position.
This value represents the distance from nozzle to the bed surface at the point where the probe is triggered. This value will be negative for typical switch probes, inductive probes, and setups where the nozzle makes a circuit with a raised metal contact. This setting will be greater than zero on machines where the nozzle itself is used as the probe, pressing down on the bed to press a switch. (This is a common setup on delta machines.)
This setting is saved in the EEPROM by M500 and restored by M501. The default (as reset by M502) is set by the Z_PROBE_OFFSET_FROM_EXTRUDER setting in Configuration.h.
Note that in Marlin 1.1.0 and up M851 sets the value literally as given, while Marlin 1.0.2 negates the absolute value.
The examples below will set the Z-probe Z offset to -4mm (below the nozzle):
M851 in Marlin 1.0.2
M851 Z4 ; Set the Z probe offset to -4
M851 in Marlin 1.1.0
M851 Z-4 ; Set the Z probe offset to -4
M905: Set local date and time
No | coming soon | ??? | ??? | ??? | No | No | ??? | No | |
??? | No | No | No | No | No | No | ??? | ??? |
- Parameters
- Pnnn Current date in the format YYYY-MM-DD
- Snnn Current time in the format HH:MM:SS
- Example
- M905 P2016-10-26 S00:23:12
Updates the machine's local date and time or reports them if no parameters are specified. The time should be specified in 24-hours format as in "13:45" instead of 1:45PM.
M906: Set motor currents
No | Yes | ??? | ??? | ??? | No | M907? | ??? | No | |
- Parameters
- Xnnn X drive motor current
- Ynnn Y drive motor current
- Znnn Z drive motor current
- Ennn E drive(s) motor current(s)
- Innn Motor current idle factor (0..100)1
- H1 Set/Get Motor currents used for the downward Z-probe homing movement 2
- Example
- M906 X300 Y500 Z200 E350:350
- Notes
1RepRapFirmware supports an additional I parameter. This is the percentage of normal that the motor currents should be reduced to when the printer becomes idle but the motors have not been switched off. The default value is 30%.
2RepRapFirmware, DC42 version, cmm sub-version supports "H1", which sets the XYZ motor currents used during Z-probing temporarily to different (typically lower) value. If "H1" is specified, the homing current is set, otherwise it operates normally. The homing current should be specified after the main current is set. The actual motor current is not changed until the next Z-probe operation. Lower motor currents reduce vibration during Z-probe motions.
Yes | Use M906 | ??? | ??? | ??? | Yes | Yes | ??? | Yes | |
Set digital trimpot motor current using axis codes (X, Y, Z, E, B, S). In Repetier, it sets the current in Percent. In Redeem, it sets the current in A (where M906 does in mA).
Yes | No | ??? | ??? | ??? | Yes: 0.92 | No | ??? | Yes | |
M908 P<pin> S<current>
M909: Set microstepping
Use M350 | Use M350 | ??? | ??? | ??? | Use M350 | No | ??? | Use M350 | |
Example:
M909 X3 Y5 Z2 E3
Set the microstepping value for each of the steppers. In Redeem this is implemented as powers of 2 so…
M909 X2 ; set microstepping on X-axis to 2^2 = 4 M909 Y3 ; set microstepping on Y-axis to 2^3 = 8 etc.
M910: Set decay mode
Example:
M910 X3 Y5 Z2 E3
Set the decay mode for each stepper controller The decay mode controls how the current is reduced and recycled by the H-bridge in the stepper motor controller. It varies how the implementations are done in silicone between controllers. Typically you have an on phase where the current flows in the target current, then an off phase where the current is reversed and then a slow decay phase where the current is recycled.
M911: Set power monitor threshold voltages
- Parameters
- Pnnn Power monitor channel, default 0
- Snnn Undervoltage threshold
- Tnnn Overvoltage threshold
Example:
M911 P0 S20 T27.5
Sets the minimum supply voltage for which correct operation of the printer mechanics is guaranteed and stepper motor positions are guaranteed to be held for all enabled drivers, and/or the maximum safe voltage above which sensitive parts of the machine should be shut down. M911 with no parameters or with just the P parameter reports the current thresholds.
M912: Set electronics temperature monitor adjustment
- Parameters
- Pnnn Temperature monitor channel, default 0
- Snnn Value to be added to the temperature reading in degC
Example:
M912 P0 S10.5
Many microcontrollers used to control 3D printers have built-in temperature monitors, but they normally need to be calibrated for temperature reading offset. The S parameter specifies the value that should be added to the raw temperature reading to provide a more accurate result.
M913: Set motor percentage of normal current
- Parameters
- X, Y, Z, E Percentage of normal current to use for the specified axis or extruder motor(s)
Example:
M913 X50 Y50 Z50 ; set X Y Z motors to 50% of their normal current M913 E30:30 ; set extruders 0 and 1 to 30% of their normal current
This allows motor currents to be set to a specified percentage of their normal values as set by M906. It can be used (for example) to reduce motor current during course homing, to make homing quieter or to reduce the risk of damage to endstops, and to reduce current while loading filament to guard against the possibility of feeding too much filament. Use M913 again with the appropriate parameters set to 100 to restore the normal currents.
M928: Start SD logging
Example:
M928 filename.g
Stop SD logging with M29.
M997: Perform in-application firmware update
??? | No | No | No | No | No | No | ??? | No |
- Parameters
- Snnn Firmware module number(s), default 0
- Example
- M997 S0:1 - update firmware modules 0 and 1
This command triggers a firmware update if the necessary files are present on the SD card. In RepRapFirmware on the Duet series, module numbers are as follows:
0 - main firmware, filename sys/RepRapFirmware.bin (Duet) or sys/DuetWiFiFirmware (Duet WiFi). File sys/iap.bin (Duet) or sys/iap4e.bin (Duet WiFi) must also be present.
1 - web server firmware, filename sys/DuetWiFiServer.bin
2 - web server file system, filename sys/DuetWebControl.bin
3 - put the WiFi module into bootloader mode, so that firmware can be uploaded directly via its serial port
M998: Request resend of line
No | Yes | ??? | ??? | ??? | No | No | ??? | ??? | |
- Parameters
- Pnnn Line number
- Example
- M998 P34
Request a resend of line 34. In some implementations the input-handling code overwrites the incoming G Code with this when it detects, for example, a checksum error. Then it leaves it up to the GCode interpreter to request the resend.
- Parameters
- This command can be used without any additional parameters.
- Pnnn Reset flags1
- Example
- M999
Restarts the firmware using a software reset.
- Notes
1The dc42 fork of RepRapFirmware not only resets the board but also puts the board into firmware upload mode if parameter PERASE is present.
Other commands
G: List all G-codes
??? | ??? | ??? | ??? | ??? | Yes | ??? | ??? | ??? |
Example: G
This lists all implemeted G-codes in the firmware with description and sends it back to the host.
M: List all M-codes
Example: M
This lists all implemeted M-codes in the firmware with description and sends it back to the host.
T: Select Tool
??? | No | ??? | Yes | ??? | Yes | Yes | ??? | ??? |
- Parameters
- Tool number
- Example
- T1
The sequence followed is:
- Set the current tool to its standby temperatures specified by G10 (see above),
- Set the new tool to its operating temperatures specified by G10 and wait for all temperatures to stabilise,
- Apply any X, Y, Z offset for the new tool specified by G10,
- Use the new tool.
Selecting a non-existent tool (100, say) just does Step 1 above1. That is to say it leaves all tools in their standby state. You can, of course, use the G10 command beforehand to set that standby temperature to anything you like.
Some implementations (e.g. RepRapFirmware) allow you to specify tool-change G Code macros2. There are normally three specified (any of which can contain no commands if desired) that execute in this order:
- Actions to do with the old tool before it is released - macro name: tfreeN.g where N is the tool number;
- (Old tool is released);
- Actions to do with the new tool before it is selected - macro name: tpreN.g where N is the tool number;
- (New tool is selected); and
- Actions to do with the new tool after it is selected - macro name: tpostN.g where N is the tool number.
With such implementations there is no wait for temperature stabilisation. That can be achieved by an M116 in any of the macros, of course.
After a reset tools will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0, M1 and M112 commands turn them all off. You can, of course, turn them all off with the M1 command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
- Notes
1 For RepRapFirmware, selecting a non-existent tool also removes any X/Y/Z offset applied for the old tool.
2 Under special circumstances, the execution of those macro files may not be desired. RepRapFirmware 109p-ch allows the 'S0' parameter to be passed to prevent the execution of tool change macro files.
Marlin uses codes M500-M503 to manipulate EEPROM values.
xx can be one of:
ok
rs
On the latest version of Pronterface and soon Octoprint a special comment of the form:
// action:command
is allowed to be sent from the firmware, the command can currently be pause, resume or disconnect which will execute those commands on the host. As this is also a comment other hosts will just ignore these commands.
ok
start
Exceptions:
1. Marlin 1.0.0 Gen6 Firmware does not follow the two character rule. 'rs' is actually 'Resend' and '!!' is 'Error'. Example Lines:
- Error: Line Number is not current line + 1. Last Line: 7
- Resend: 8
- Writing to File: print.gco
- Done saving file.
- File opened:print.gco Size:22992
- File selected
2. The dc42 fork of RepRapFirmware responds to some commands with a reply string in JSON format, terminated by a newline. This allows later firmware revisions to include additional information without confusing clients (e.g. PanelDue) that do not expect it, and to make responses self-describing so that the client will not be confused if responses are delayed or lost. The commands affected are:
- M105 S2
- M105 S3
- M20 S2
- M36
- M408
Problem to solve
When using Marlin firmware or emulating Marlin, each line of G-code sent from the host to the controller is answered with an ok before the next line can be sent without locking communications up. This slows down communication and limits the number of commands that can be sent per second to the printer controller, as the USB stack on the host and the serial interface driver on the Arduino add their own latencies (up to 10 milliseconds). This is not a problem for other controller electronics using native USB such as the Duet, because the standard serial-over-USB drivers provide flow control, so the host software can be configured so as not to wait for the ok.
Alternatives to G-code
- Main article: Firmware/Alternative#alternatives to G-code
