G-code
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications as well. See also on Wikipedia's G-code article.
There are a few different ways to prepare GCode for a printer. One method woull be to use a slicing program such as Slic3r, Skeinforge or Cura. These programs import a CAD model, slice it into layers, and output the GCode required to print each layer. Slicers are the easiest way to go from a 3D model to a printed part, however the user sacrifices some flexibility when using them. Another option for GCode generation is to use a lower level library like mecode. Libraries like mecode give you precise control over the tool path, and thus are useful if you have a complex print that is not suitable for naive slicing. The final option is to just write the GCode yourself. This may be the best choice if you just need to run a few test lines while calibrating your printer.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years. This particular page is the master page for RepRap. Nowhere in here should the same code be used for two different things; there are always more numbers to use... The rule is: add your new code here, then implement it.
Unfortunately human nature being what it is, the best procedures aren't always followed, so some multiple uses of the same code exist. The rule which should be followed is that later appearances of a code on this page (later than the original use of a code), are deprecated and should be changed, unless there is a good technical reason (like the general G-Code standard) why a later instance should be preferred. Note that the key date is appearance here, not date of implementation.
- 1 Introduction
- 2 Fields
- 3 Quoted strings
- 4 Comments
- 5 Special fields
- 6 Checking
- 7 Buffering
- 8 G-commands
- 8.1 G0 & G1: Move
- 8.2 G2 & G3: Controlled Arc Move
- 8.3 G4: Dwell
- 8.4 G6: Direct Stepper Move
- 8.5 G10: Tool Offset
- 8.6 G10: Retract
- 8.7 G11: Unretract
- 8.8 G12: Clean Tool
- 8.9 G17..19: Plane Selection (CNC specific)
- 8.10 G20: Set Units to Inches
- 8.11 G21: Set Units to Millimeters
- 8.12 G22 & G23: Firmware controlled Retract/Precharge
- 8.13 G26: Mesh Validation Pattern
- 8.14 G28: Move to Origin (Home)
- 8.15 G29: Detailed Z-Probe
- 8.16 G29.1: Set Z probe head offset
- 8.17 G29.2: Set Z probe head offset calculated from toolhead position
- 8.18 G30: Single Z-Probe
- 8.19 G31: Set or Report Current Probe status
- 8.20 G31: Dock Z Probe sled
- 8.21 G32: Probe Z and calculate Z plane
- 8.22 G32: Undock Z Probe sled
- 8.23 G33: Firmware dependent
- 8.24 G38.x Straight Probe (CNC specific)
- 8.25 G40: Compensation Off (CNC specific)
- 8.26 G42: Move to Grid Point
- 8.27 G54..59: Coordinate System Select (CNC specific)
- 8.28 G60: save current position to slot
- 8.29 G61: Apply/restore saved coordinates to the active extruder.
- 8.30 G80: Cancel Canned Cycle (CNC specific)
- 8.31 G90: Set to Absolute Positioning
- 8.32 G91: Set to Relative Positioning
- 8.33 G92: Set Position
- 8.34 G93: Feed Rate Mode (Inverse Time Mode) (CNC specific)
- 8.35 G94: Feed Rate Mode (Units per Minute) (CNC specific)
- 8.36 G100: Calibrate floor or rod radius
- 8.37 G130: Set digital potentiometer value
- 8.38 G131: Remove offset
- 8.39 G132: Calibrate endstop offsets
- 8.40 G133: Measure steps to top
- 8.41 G161: Home axes to minimum
- 8.42 G162: Home axes to maximum
- 9 M-commands
- 9.1 M0: Stop or Unconditional stop
- 9.2 M1: Sleep or Conditional stop
- 9.3 M2: Program End
- 9.4 M3: Spindle On, Clockwise (CNC specific)
- 9.5 M4: Spindle On, Counter-Clockwise (CNC specific)
- 9.6 M5: Spindle Off (CNC specific)
- 9.7 M6: Tool change
- 9.8 M7: Mist Coolant On (CNC specific)
- 9.9 M8: Flood Coolant On (CNC specific)
- 9.10 M9: Coolant Off (CNC specific)
- 9.11 M10: Vacuum On (CNC specific)
- 9.12 M11: Vacuum Off (CNC specific)
- 9.13 M17: Enable/Power all stepper motors
- 9.14 M18: Disable all stepper motors
- 9.15 M20: List SD card
- 9.16 M21: Initialize SD card
- 9.17 M22: Release SD card
- 9.18 M23: Select SD file
- 9.19 M24: Start/resume SD print
- 9.20 M25: Pause SD print
- 9.21 M26: Set SD position
- 9.22 M27: Report SD print status
- 9.23 M28: Begin write to SD card
- 9.24 M29: Stop writing to SD card
- 9.25 M30: Delete a file on the SD card
- 9.26 M31: Output time since last M109 or SD card start to serial
- 9.27 M32: Select file and start SD print
- 9.28 M33: Get the long name for an SD card file or folder
- 9.29 M33: Stop and Close File and save restart.gcode
- 9.30 M34: Set SD file sorting options
- 9.31 M35: Upload firmware NEXTION from SD
- 9.32 M36: Return file information
- 9.33 M37: Simulation mode
- 9.34 M38 Compute SHA1 hash of target file
- 9.35 M40: Eject
- 9.36 M41: Loop
- 9.37 M42: Switch I/O pin
- 9.38 M43: Stand by on material exhausted
- 9.39 M43: Pin report and debug
- 9.40 M48: Measure Z-Probe repeatability
- 9.41 M70: Display message
- 9.42 M72: Play a tone or song
- 9.43 M73: Set build percentage
- 9.44 M80: ATX Power On
- 9.45 M81: ATX Power Off
- 9.46 M82: Set extruder to absolute mode
- 9.47 M83: Set extruder to relative mode
- 9.48 M84: Stop idle hold
- 9.49 M85: Set inactivity shutdown timer
- 9.50 M92: Set axis_steps_per_unit
- 9.51 M93: Send axis_steps_per_unit
- 9.52 M98: Call Macro/Subprogram
- 9.53 M99: Return from Macro/Subprogram
- 9.54 M98: Get axis_hysteresis_mm
- 9.55 M99: Set axis_hysteresis_mm
- 9.56 M101: Turn extruder 1 on (Forward), Undo Retraction
- 9.57 M102: Turn extruder 1 on (Reverse)
- 9.58 M103: Turn all extruders off, Extruder Retraction
- 9.59 M104: Set Extruder Temperature
- 9.60 M105: Get Extruder Temperature
- 9.61 M106: Fan On
- 9.62 M107: Fan Off
- 9.63 M108: Cancel Heating (Marlin)
- 9.64 M108: Set Extruder Speed (BFB)
- 9.65 M109: Set Extruder Temperature and Wait
- 9.66 M110: Set Current Line Number
- 9.67 M111: Set Debug Level
- 9.68 M112: Emergency Stop
- 9.69 M113: Set Extruder PWM
- 9.70 M114: Get Current Position
- 9.71 M115: Get Firmware Version and Capabilities
- 9.72 M116: Wait
- 9.73 M117: Get Zero Position
- 9.74 M117: Display Message
- 9.75 M118: Echo message on host
- 9.76 M118: Negotiate Features
- 9.77 M119: Get Endstop Status
- 9.78 M120: Push
- 9.79 M121: Pop
- 9.80 M120: Enable endstop detection
- 9.81 M121: Disable endstop detection
- 9.82 M122: Diagnose
- 9.83 M123: Tachometer value
- 9.84 M124: Immediate motor stop
- 9.85 M126: Open Valve
- 9.86 M127: Close Valve
- 9.87 M128: Extruder Pressure PWM
- 9.88 M129: Extruder pressure off
- 9.89 M130: Set PID P value
- 9.90 M131: Set PID I value
- 9.91 M132: Set PID D value
- 9.92 M133: Set PID I limit value
- 9.93 M134: Write PID values to EEPROM
- 9.94 M135: Set PID sample interval
- 9.95 M136: Print PID settings to host
- 9.96 M140: Set Bed Temperature (Fast)
- 9.97 M141: Set Chamber Temperature (Fast)
- 9.98 M142: Holding Pressure
- 9.99 M143: Maximum heater temperature
- 9.100 M144: Bed Standby
- 9.101 M146: Set Chamber Humidity
- 9.102 M149: Set temperature units
- 9.103 M150: Set display color
- 9.104 M155: Automatically send temperatures
- 9.105 M160: Number of mixed materials
- 9.106 M163: Set weight of mixed material
- 9.107 M164: Store weights
- 9.108 M165: Set multiple mix weights
- 9.109 M190: Wait for bed temperature to reach target temp
- 9.110 M191: Wait for chamber temperature to reach target temp
- 9.111 M200: Set filament diameter
- 9.112 M201: Set max printing acceleration
- 9.113 M202: Set max travel acceleration
- 9.114 M203: Set maximum feedrate
- 9.115 M204: Set default acceleration
- 9.116 M205: Advanced settings
- 9.117 M206: Offset axes
- 9.118 M206 in Repetier: Set eeprom value
- 9.119 M207: Calibrate z axis by detecting z max length
- 9.120 M207: Set retract length
- 9.121 M208: Set axis max travel
- 9.122 M208: Set unretract length
- 9.123 M209: Enable automatic retract
- 9.124 M210: Set homing feedrates
- 9.125 M211: Disable/Enable software endstops
- 9.126 M212: Set Bed Level Sensor Offset
- 9.127 M218: Set Hotend Offset
- 9.128 M220: Set speed factor override percentage
- 9.129 M221: Set extrude factor override percentage
- 9.130 M220: Turn off AUX V1.0.5
- 9.131 M221: Turn on AUX V1.0.5
- 9.132 M222: Set speed of fast XY moves
- 9.133 M223: Set speed of fast Z moves
- 9.134 M224: Enable extruder during fast moves
- 9.135 M225: Disable on extruder during fast moves
- 9.136 M226: Gcode Initiated Pause
- 9.137 M226: Wait for pin state
- 9.138 M227: Enable Automatic Reverse and Prime
- 9.139 M228: Disable Automatic Reverse and Prime
- 9.140 M229: Enable Automatic Reverse and Prime
- 9.141 M230: Disable / Enable Wait for Temperature Change
- 9.142 M231: Set OPS parameter
- 9.143 M232: Read and reset max. advance values
- 9.144 M240: Trigger camera
- 9.145 M240: Start conveyor belt motor / Echo off
- 9.146 M241: Stop conveyor belt motor / echo on
- 9.147 M245: Start cooler
- 9.148 M246: Stop cooler
- 9.149 M250: Set LCD contrast
- 9.150 M251: Measure Z steps from homing stop (Delta printers)
- 9.151 M260: i2c Send Data
- 9.152 M261: i2c Request Data
- 9.153 M280: Set servo position
- 9.154 M290: Baby stepping
- 9.155 M291: Display message and optionally wait for response
- 9.156 M292: Acknowledge message
- 9.157 M300: Play beep sound
- 9.158 M301: Set PID parameters
- 9.159 M302: Allow cold extrudes
- 9.160 M303: Run PID tuning
- 9.161 M304: Set PID parameters - Bed
- 9.162 M305: Set thermistor and ADC parameters
- 9.163 M306: Set home offset calculated from toolhead position
- 9.164 M307: Set or report heating process parameters
- 9.165 M320: Activate autolevel (Repetier)
- 9.166 M321: Deactivate autolevel (Repetier)
- 9.167 M322: Reset autolevel matrix (Repetier)
- 9.168 M323: Distortion correction on/off (Repetier)
- 9.169 M340: Control the servos
- 9.170 M350: Set microstepping mode
- 9.171 M351: Toggle MS1 MS2 pins directly
- 9.172 M355: Turn case lights on/off
- 9.173 M360: Report firmware configuration
- 9.174 SCARA calibration codes (Morgan)
- 9.175 M360: Move to Theta 0 degree position
- 9.176 M361: Move to Theta 90 degree position
- 9.177 M362: Move to Psi 0 degree position
- 9.178 M363: Move to Psi 90 degree position
- 9.179 M364: Move to Psi + Theta 90 degree position
- 9.180 M365: SCARA scaling factor
- 9.181 M366: SCARA convert trim
- 9.182 M370: Morgan manual bed level - clear map
- 9.183 M371: Move to next calibration position
- 9.184 M372: Record calibration value, and move to next position
- 9.185 M373: End bed level calibration mode
- 9.186 M374: Save calibration grid
- 9.187 M375: Display matrix / Load Matrix
- 9.188 M376: Set bed compensation taper
- 9.189 M380: Activate solenoid
- 9.190 M381: Disable all solenoids
- 9.191 M400: Wait for current moves to finish
- 9.192 M401: Lower z-probe
- 9.193 M402: Raise z-probe
- 9.194 M404: Filament width and nozzle diameter
- 9.195 M405: Filament Sensor on
- 9.196 M406: Filament Sensor off
- 9.197 M407: Display filament diameter
- 9.198 M408: Report JSON-style response
- 9.199 M420: Set RGB Colors as PWM (MachineKit)
- 9.200 M420: Leveling On/Off/Fade (Marlin)
- 9.201 M421: Set a Mesh Bed Leveling Z coordinate
- 9.202 M450: Report Printer Mode
- 9.203 M451: Select FFF Printer Mode
- 9.204 M452: Select Laser Printer Mode
- 9.205 M453: Select CNC Printer Mode
- 9.206 M460: Define temperature range for thermistor-controlled fan
- 9.207 M500: Store parameters in EEPROM
- 9.208 M501: Read parameters from EEPROM
- 9.209 M502: Revert to the default "factory settings."
- 9.210 M503: Print settings
- 9.211 M530: Enable printing mode
- 9.212 M531: Set print name
- 9.213 M532: Set print progress
- 9.214 M540: Enable/Disable "Stop SD Print on Endstop Hit"
- 9.215 M540: Set MAC address
- 9.216 M550: Set Name
- 9.217 M551: Set Password
- 9.218 M552: Set IP address, enable/disable network interface
- 9.219 M553: Set Netmask
- 9.220 M554: Set Gateway
- 9.221 M555: Set compatibility
- 9.222 M556: Axis compensation
- 9.223 M557: Set Z probe point or define probing grid
- 9.224 M558: Set Z probe type
- 9.225 M559: Upload configuration file
- 9.226 M560: Upload web page file
- 9.227 M561: Set Identity Transform
- 9.228 M562: Reset temperature fault
- 9.229 M563: Define or remove a tool
- 9.230 M564: Limit axes
- 9.231 M565: Set Z probe offset
- 9.232 M566: Set allowable instantaneous speed change
- 9.233 M567: Set tool mix ratios
- 9.234 M568: Turn off/on tool mix ratios
- 9.235 M569: Set axis direction and enable values
- 9.236 M570: Configure heater fault detection
- 9.237 M571: Set output on extrude
- 9.238 M572: Set or report extruder pressure advance
- 9.239 M573: Report heater PWM
- 9.240 M574: Set endstop configuration
- 9.241 M575: Set serial comms parameters
- 9.242 M577: Wait until endstop is triggered
- 9.243 M578: Fire inkjet bits
- 9.244 M579: Scale Cartesian axes
- 9.245 M580: Select Roland
- 9.246 M581: Configure external trigger
- 9.247 M582: Check external trigger
- 9.248 M583: Wait for pin
- 9.249 M584: Set drive mapping
- 9.250 M585: Probe Tool
- 9.251 M586: Configure network protocols
- 9.252 M587: Store WiFi host network in list, or list stored networks
- 9.253 M588: Forget WiFi host network
- 9.254 M589: Configure access point parameters
- 9.255 M590: Report current tool type and index
- 9.256 M591: Configure filament sensing
- 9.257 M600: Set line cross section
- 9.258 M600: Filament change pause
- 9.259 M605: Set dual x-carriage movement mode
- 9.260 M665: Set delta configuration
- 9.261 M666: Set delta endstop adjustment
- 9.262 M667: Select CoreXY mode
- 9.263 M668: Set Z-offset compensations polynomial
- 9.264 M669: Set kinematics type and kinematics parameters
- 9.265 M670: Set IO port bit mapping
- 9.266 M671: Define positions of Z leadscrews or bed levelling screws
- 9.267 M672: Program Z probe
- 9.268 M700: Level plate
- 9.269 M701: Load filament
- 9.270 M702: Unload filament
- 9.271 M703: Get Board Type
- 9.272 M710: Erase the EEPROM and reset the board
- 9.273 M750: Enable 3D scanner extension
- 9.274 M751: Register 3D scanner extension over USB
- 9.275 M752: Start 3D scan
- 9.276 M753: Cancel current 3D scanner action
- 9.277 M754: Calibrate 3D scanner
- 9.278 M755: Set alignment mode for 3D scanner
- 9.279 M756: Shutdown 3D scanner
- 9.280 M800: Fire start print procedure
- 9.281 M801: Fire end print procedure
- 9.282 M851: Set Z-Probe Offset
- 9.283 M900 Set Linear Advance Scaling Factors
- 9.284 M905: Set local date and time
- 9.285 M906: Set motor currents
- 9.286 M907: Set digital trimpot motor
- 9.287 M908: Control digital trimpot directly
- 9.288 M909: Set microstepping
- 9.289 M910: Set decay mode
- 9.290 M911: Enable auto save and set threshold voltages
- 9.291 M912: Set electronics temperature monitor adjustment
- 9.292 M913: Set motor percentage of normal current
- 9.293 M914: Set/Get Expansion Voltage Level Translator
- 9.294 M928: Start SD logging
- 9.295 M929: Start/stop event logging to SD card
- 9.296 M997: Perform in-application firmware update
- 9.297 M998: Request resend of line
- 9.298 M999: Restart after being stopped by error
- 10 Other commands
- 11 Proposed EEPROM configuration codes
- 12 Replies from the RepRap machine to the host computer
- 13 Proposal for sending multiple lines of G-code
- 14 Alternatives to G-code
Introduction
N3 T0*57 N4 G92 E0*67 N5 G28*22 N6 G1 F1500.0*82 N7 G1 X2.0 Y2.0 F3000.0*85 N8 G1 X3.0 Y3.0*33
Gcode can also be stored in files on SD cards. A file containing RepRap Gcode usually has the extension .g
, .gco
or .gcode
Files for BFB/RapMan have the extension .bfb
Gcode stored in file or produced by a slicer might look like this:
G92 E0 G28 G1 F1500 G1 X2.0 Y2.0 F3000 G1 X3.0 Y3.0
Slicers will (optionally?) add GCode scripts to the beginning and end of their output file to perform specified actions before and/or after a print such as z-probing the build-area, heating/cooling the bed and hotend, performing ooze free "nozzle wipe" startup routine, switching system power on/off, and even "ejecting" parts. More info on the Start GCode routines and End GCode routines pages.
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
Partial | ??? | Experimental | deprecated | ??? | ??? | Partial | ??? | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
??? | No | ??? | Yes | ??? | Yes | automatic | ??? |
Here means:
- {{yes}}
- The Gcode is fully supported by the firmware.
- {{partial}} or {{experimental}}
- There is some support for the Gcode. Often it is required to check out the source code branch for the firmware (usually stored in a different branch) or to flip configuration switches on the mainboard.
- automatic
- The firmware handles this Gcode automatically, so there's no need to send the command. An example is power supply on/off Gcode (M80/M81) in the Teacup firmware.
- It is unknown if the firmware supports this Gcode. You may want to test this yourself before using it in production.
- {{no}}
- The firmware does not support this Gcode.
- deprecated
- The firmware deprecated this Gcode. The firmware author(s) should amend the deprecated Gcode on this page with workarounds (if needed) and the last supported firmware version that will accept this Gcode.
For the technically minded, Gcode line endings are Unix Line Endings (\n
), but will accept Windows Line Endings (\r\n
), so you should not need to worry about converting between the two, but it is best practice to use Unix Line Endings where possible.
Fields
A RepRap Gcode is a list of fields that are separated by white spaces or line breaks. A field can be interpreted as a command, parameter, or for any other special purpose. It consists of one letter directly followed by a number, or can be only a stand-alone letter (Flag). The letter gives information about the meaning of the field (see the list below in this section). Numbers can be integers (128) or fractional numbers (12.42), depending on context. For example, an X coordinate can take integers (X175
) or fractionals (X17.62
), but selecting extruder number 2.76 would make no sense. In this description, the numbers in the fields are represented by nnn
as a placeholder.
In RepRapFirmware, some parameters can be followed by more than one number, with colon used to separate them. Typically this is used to specify extruder parameters, with one value provided per extruder. If only one value is provided where a value is needed for each extruder, then that value is applied to all extruders.
Letter | Meaning |
Gnnn | Standard GCode command, such as move to a point |
Mnnn | RepRap-defined command, such as turn on a cooling fan |
Tnnn | Select tool nnn. In RepRap, a tool is typically associated with a nozzle, which may be fed by one or more extruders. |
Snnn | Command parameter, such as time in seconds; temperatures; voltage to send to a motor |
Pnnn | Command parameter, such as time in milliseconds; proportional (Kp) in PID Tuning |
Xnnn | A X coordinate, usually to move to. This can be an Integer or Fractional number. |
Ynnn | A Y coordinate, usually to move to. This can be an Integer or Fractional number. |
Znnn | A Z coordinate, usually to move to. This can be an Integer or Fractional number. |
U,V,W | Additional axis coordinates (RepRapFirmware) |
Innn | Parameter - X-offset in arc move; integral (Ki) in PID Tuning |
Jnnn | Parameter - Y-offset in arc move |
Dnnn | Parameter - used for diameter; derivative (Kd) in PID Tuning |
Hnnn | Parameter - used for heater number in PID Tuning |
Fnnn | Feedrate in mm per minute. (Speed of print head movement) |
Rnnn | Parameter - used for temperatures |
Qnnn | Parameter - not currently used |
Ennn | Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to consume. |
Nnnn | Line number. Used to request repeat transmission in the case of communications errors. |
*nnn | Checksum. Used to check for communications errors. |
Quoted strings
In RepRapFirmware, some commands support quoted strings when providing file names and other string parameters. This allows file names, WiFi passwords etc. to contain spaces, semicolons and other characters that would otherwise not be permitted. Double-quote characters are used to delimit the string, and any double-quote character within the string must be repeated.
Unfortunately, many gcode sender programs convert all characters to uppercase and don't provide any means to disable this feature. Therefore, within a quoted-string, the single-quote character is used as a flag to force the following character to lowercase. If you want to include a single quote character in the string, use two single quote characters to represent one single quote character.
Example: to add SSID MYROUTER with password ABCxyz;" 123
to the WiFi network list, use command:
M587 S"MYROUTER" P"ABCxyz;"" 123"
or if you can't send lowercase characters:
M587 S"MYROUTER" P"ABC'X'Y'Z;"" 123"
Comments
Gcode comments begin at a semicolon, and end at the end of the line:
N3 T0*57 ; This is a comment N4 G92 E0*67 ; So is this N5 G28*22
Special fields
N: Line number
Yes | Yes | Yes | ??? | ??? | ??? | Yes | ??? | |
? | Yes | ??? | Yes | Yes | Yes | Yes | ??? |
- Example
N123
If checking is supported, the RepRap firmware expects line numbers to increase by 1 each line, and if that doesn't happen it is flagged as an error. But you can reset the count using M110
(see below).
*: Checksum
? | Yes | ??? | Yes | ??? | No | Yes | ??? |
Example: *71
The firmware compares the checksum against a locally-computed value. If they differ, it requests a repeat transmission of the line.
Checking
- Example
N123 [...G Code in here...] *71
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
int cs = 0; for(i = 0; cmd[i] != '*' && cmd[i] != NULL; i++) cs = cs ^ cmd[i]; cs &= 0xff; // Defensive programming...
Buffering
Yes | Yes | ??? | ??? | ??? | ??? | Yes | ??? | |
Yes | ??? | ??? | Yes | ??? | Yes | Yes | ??? |
Typically, the following moving commands are buffered: G0
-G3
and G28
-G32
. The Teacup Firmware buffers also some setting commands: G20
, G21
, G90
and G91
. All other G
, M
or T
commands are not buffered.
RepRapFirmware also implements an internal queue to ensure that certain codes (like M106) are executed in the right order and not when the last move has been added to the look-ahead queue.
G-commands
G0 & G1: Move
Yes | Yes | Yes | Yes | ??? | ??? | Yes | Yes | |
Yes | Yes | Yes | Yes | Yes | Yes | Yes | ??? |
G0
: Rapid linear Move -
G1
: Linear Move
- Usage
- Parameters
- Not all parameters need to be used, but at least one has to be used
Xnnn
The position to move to on the X axisYnnn
The position to move to on the Y axisZnnn
The position to move to on the Z axisEnnn
The amount to extrude between the starting point and ending pointFnnn
The feedrate per minute of the move between the starting point and ending point (if supplied)Snnn
Flag to check if an endstop was hit (S1
to check,S0
to ignore,S2
see note, default isS0
)1- Examples
G0 X12 ; move to 12mm on the X axis G0 F1500 ; Set the feedrate to 1500mm/minute G1 X90.6 Y13.8 E22.4 ; Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material
The RepRap firmware spec treats G0
and G1
as the same command, since it's just as efficient as not doing so.2
G1 F1500 ; Set feedrate to 1500mm/m G1 X50 Y25.3 E22.4 ; Move and extrude
In the above example, we first set the feedrate to 1500mm/m, then move to 50mm on X and 25.3mm on Y while extruding 22.4mm of filament between the two points.
G1 F1500 ; Feedrate 1500mm/m G1 X50 Y25.3 E22.4 F3000 ; Accelerate to 3000mm/m
However, in the above example, we set a feedrate of 1500 mm/m, then do the same move, but accelerating to 3000 mm/m. Everything stays synchronized, so extrusion accelerates right along with X and Y movement.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in a way that ensures everything moves smoothly together and the right volume of material is extruded at all points.3
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G0
or G1
to send an E
value that is less than the currently extruded length.
- Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S
parameter in this way, as damage may occur if you assume incorrectly. In RepRapFirmware, using the S1
or S2
parameter on a delta printer causes the XYZ
parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1.
2In the RS274NGC Spec, G0
is Rapid Move, which was used to move between the current point in space and the new point as quickly and efficiently as possible, and G1
is Controlled Move, which was used to move between the current point in space and the new point as precise as possible.
4RepRapFirmware provides an additional 'R1' parameter to tell the machine to go back to the coordinates a print was previously paused at. If this parameter is used and the code contains axis letters, an offset will be added to the pause coordinates (e.g. G1 R1 Z5
Yes1 | No | Yes | Yes | ??? | ??? | Yes | ??? | |
Yes | Yes | No | No | Yes | Experimental | No | ??? |
- Usage
G2 Xnnn Ynnn Innn Jnnn Ennn Fnnn
(Clockwise Arc)G3 Xnnn Ynnn Innn Jnnn Ennn Fnnn
(Counter-Clockwise Arc)- Parameters
Xnnn
The position to move to on the Y axisInnn
The point in X space from the current X position to maintain a constant distance fromJnnn
The point in Y space from the current Y position to maintain a constant distance fromEnnn
The feedrate per minute of the move between the starting point and ending point (if supplied)- Examples
G2 X90.6 Y13.8 I5 J10 E22.4
(Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
G3 X90.6 Y13.8 I5 J10 E22.4
(Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
- Notes
1In Marlin Firmware not implemented for DELTA and SCARA printers.
G4: Dwell
Pause the machine for a period of time.
- Parameters
Pnnn
Time to wait, in milliseconds (In Teacup, P0, wait until all previous moves are finished)Snnn
Time to wait, in seconds (Only on Repetier, Marlin, Smoothieware, and RepRapFirmware 1.16 and later)- Example
G4 P200
On Marlin, Smoothie and RepRapFirmware, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
No | Use G1 S2 | No | No | ??? | ??? | No | No | |
No | No | No | No | No | No | No | ??? |
Perform a direct, uninterpolated, and non-kinematic synchronized move of one or more steppers directly. Units may be linear (e.g., mm or inches on DELTA
) or specified in degrees (SCARA). This command is useful for initialization, diagnostics, and calibration, and should be disabled on production equipment. This type of move can be potentially dangerous, especially for deltabots, so implementations should do their best to limit movement to prevent twerking and damaging the carriage assembly.
- Parameters
Annn
Stepper A position or angleBnnn
Stepper B position or angleCnnn
Stepper C position or angleR
Relative move flag- SCARA Examples
G6 A45 ; Move SCARA A stepper to the 45° position G6 B20 R ; Move SCARA B stepper 20° counter-clockwise
- DELTA Example
G6 C10 R ; Move DELTA C carriage up by 10mm
G10: Tool Offset
No | Yes | No | No | ??? | ??? | No | ??? | |
??? | No | No | No | Yes | No | No | ??? |
- Usage
G10 Pnnn Xnnn Ynnn Znnn Rnnn Snnn
1- Parameters
Pnnn
Tool numberXnnn
X offsetYnnn
Y offsetU,V,Wnnn
U, V and W axis offsets5Znnn
Z offset2Rnnn
Standby temperature(s)Snnn
Active temperature(s)- Examples
G10 P2 X17.8 Y-19.3 Z0.0
(sets the offset for tool (or in older implementations extrude head) 2 to the X, Y, and Z values specified)
G10 P1 R140 S205
(set standby and active temperatures3 for tool 1)
The precise meaning of the X, Y (and other offset) values is: with no offset this tool is at this position relative to where a tool with offset (0, 0, 0) would be. So if the tool is 10mm to the left of a zero-offset tool the X value would be -10, and so on.
The R
value is the standby temperature in oC that will be used for the tool, and the S
value is its operating temperature. If you don't want the tool to be at a different temperature when not in use, set both values the same. See the T code (select tool) below. In tools with multiple heaters the temperatures for them all are specified thus: R100.0:90.0:20.0 S185.0:200.0:150.0 .
See also M585
- Notes
1Marlin uses G10/G11 for executing a retraction/unretraction move. The RepRapPro version of Marlin supports G10
for tool offset. Smoothie uses G10
for retract and G10 Ln
for setting workspace coordinates.
2It's usually a bad idea to put a non-zero Z
value in as well unless the tools are loaded and unloaded by some sort of tool changer or are on indepedent carriages. When all the tools are in the machine at once they should all be set to the same Z height.
4The NIST G-code standard mentions an additional L
parameter, which is ignored (except in smoothie). This command is subject to discussion.
5Tool offsets are applied after any X axis mapping has been performed. Therefore if for example you map X to U in your M563
command to create the tool, you should specify a U offset not an X offset. If you map X to both X and U, you can specify both offsets.
G10: Retract
Yes | dc42,ch | Yes: 0.92 | Yes | ??? | ??? | Yes | ??? | |
??? | No | No | No | No | No | No | ??? |
- Parameters
Snnn
retract length (S1 = long retract, S0 = short retract = default) (Repetier only)- Example
G10
Retracts filament according to settings of M207
(Marlin, RepRapFirmware) or according to the S
value (Repetier).
RepRapFirmware recognizes G10
as a command to set tool offsets and/or temperatures if the P
parameter is present, and as a retraction command if it is absent.
G11: Unretract
- Parameters
Snnn
G11
Unretracts/recovers filament according to settings of M208
value (Repetier).
G12: Clean Tool
Yes: 1.1.0 | via macro feature | No | No | ??? | ??? | Yes | ??? | |
- Usage
[P<0|1>] [S<count>] [T<count>]
G12 Pnnn Snnn Tnnn
- Parameters
Pnnn
1 Pattern style selectionSnnn
Number of strokes (i.e. back-and-forth movements)Tnnn
Number of repetitions- Examples
G12 ; stroke pattern (default)
To generate a three triangle zig-zag pattern which will be stroked three times time use the following command. G12 P1 S3 T2 ; zig-zag pattern with 2 triangles
- Notes
1In Marlin firmware and Derivatives Mk4duo this is implemented by hard-coded firmware behaviours As defined for variables NOZZLE_CLEAN_STROKES, NOZZLE_CLEAN_START_POINT, NOZZLE_CLEAN_END_POINT and NOZZLE_CLEAN_PARK.
With NOZZLE_CLEAN_PARK enabled, the nozzle will automatically return to the XYZ position after G12 is run.
More on this behaviour is documented inside of the code base.
Yes:1.1.4 | No | ??? | ??? | ??? | ??? | No | ??? | |
Yes | ??? | ??? | ??? | Yes | No | ??? | ??? |
G17
: XY (default) -
G18
: ZX -
G19
: YZ
This mode applies to G2
/G3
arc moves. Normal arc moves are in the XY plane, and for most applications that's all you need. For CNC routing it can be useful to do small "digging" moves while making cuts, so to keep the G-code compact it uses G2
/G3
arcs involving the Z plane.
These commands are supported in Marlin 1.1.4 and up with ARC_SUPPORT
and CNC_WORKSPACE_PLANES
enabled.
Yes | Yes | Yes | Yes | ??? | ??? | Yes | ??? | |
Yes | Yes | No | Yes | Yes | No | Yes | ??? |
- Example
G20
- Example
G21
No | No | No | No | ??? | ??? | No | ??? | |
- Usage
G22 ; Retract
G23 ; Unretract/Precharge
Relying on machine's firmware to execute extrusion retract/precharge move, instead of having slicer generating to E axis G1
movement. The retract/precharge length, velocity is handled by the machine firmware.
Yes: 1.1.0 | No | No | No | ??? | ??? | No | No | |
- Usage
G26 C P O2.25 ; Do a typical test sequence
The G26
Mesh Validation Pattern is designed to be used in conjunction with various Mesh Bed Leveling systems – those that adjust for an uneven —rather than just tilted— bed. The G26
command prints a single layer pattern over the entire print bed, giving a clear indication of how accurately every mesh point is defined. G26
can be used to determine which areas of the mesh are less-than-perfect and how much to adjust each mesh point.
G26
has large feature list, including a built-in test that extrudes material onto the bed. By default this is configured for PLA temperatures and a nozzle size of 0.4mm. (This will be adjustable in an upcoming version of Marlin.)
See the G26_Mesh_Validation_Tool.cpp
file in the Marlin source code for full documentation of the G26
parameter list.
Yes | Yes | Yes | Yes | ??? | ??? | Yes1 | Yes | |
- Parameters
- This command can be used without any additional parameters.
X
Flag to go back to the X axis originY
Flag to go back to the Y axis originZ
Flag to go back to the Z axis origin- Examples
G28 ; Home all axes G28 X Z ; Home the X and Z axes
When the firmware receives this command, it quickly moves the specified axes (or all axes if none are given) to the endstops, backs away from each endstop by a short distance, and slowly bumps the endstop again to increase positional accuracy. This process, known as "Homing", is required to determine the position of the print carriage(s). Some firmware may even forbid movement away from endstops and other operations until the axes have been homed.
The X
, Y
, and Z
parameters act only as flags. Any coordinates given are ignored. For example, G28 Z10
results in the same behavior as G28 Z
. Delta printers cannot home individual axes, but must always home all three towers, so the X Y Z
parameters are simply ignored on these machines.
Marlin firmware (version 1.1.0 and up) provides an option called Z_SAFE_HOMING
for printers that use a Z probe to home Z instead of an endstop. With this option, the XY axes are homed first, then the carriage moves to a position –usually the middle of the bed– where it can safely probe downward to home Z.
RepRapFirmware uses macro files to home either all axes or individual axes. If all axes are homed, the file homeall.g
is processed. For individual axes the homex.g
, homey.g
, or homez.g
file will be used. On Delta printers, G28
command will always home all three towers by processing the homedelta.g
file, regardless of any X
Y
Z
parameters.
Because the behavior of G28
is unspecified, it is recommended not to automatically include G28
in your ending GCode. On a Cartesian this will result in damaging the printed object. If you need to move the carriage at the completion of a print, use G0
or G1
- Notes
1 MK4duo has a B
parameter that tells the printer to return to the coordinates it was at before homing.
Yes | Yes, 1.17 and later | Yes: 0.91.7 | No, see G32 | ??? | ??? | Yes | ??? | |
??? | No | No | No | Yes | Yes | No | ??? |
This command uses a probe to measure the bed height at 3 or more points to determine its tilt and overall flatness. It then enables compensation so that the nozzle will remain parallel to the bed. The printer must be homed with G28
before using this command.
Each firmware behaves differently and depends on the type of bed leveling that's been configured. For example, Marlin 1.0.2 provides 3 different types of automatic bed leveling (probe required) and a manual bed leveling option. See your firmware's documentation for the specific options available.
- Usage
G29
G29 Snnn
- Parameters
Snnn
Firmware-dependent behaviorPfile.csv
Optional file name for bed height map file (RepRapFirmware only)- Examples
G29 ; Probe the bed and enable compensation G29 S2 ; Special operation - see below G29 P1 ; UBL automated probe - see below
G29 Auto Bed Leveling (Marlin)
Marlin 1.0.2 and earlier provides three options for automatic bed leveling:
- The 3-point method probes the bed at three points to produce a matrix, adjusting for a flat but tilted bed.
- The planar grid method (non-Delta) probes a grid pattern to produce a matrix by the "least-squares" method, adjusting for a flat but tilted bed.
- The bilinear grid method (Delta only) probes a grid pattern to produce a mesh, using bilinear interpolation to adjust for an uneven bed.
Marlin 1.1.0 and up allows the bilinear grid (i.e., "mesh") method to be used on all types of machines, not just deltas. This is the recommended leveling method going forward.
Also in Marlin 1.1.0 and up, the PROBE_MANUALLY
option allows all forms of Auto Bed Leveling to be used without a probe. The procedure is similar to that of MESH_BED_LEVELING
(see below). Begin the process with G29
to move the nozzle to the first point. Adjust the Z axis using G1
or your host software. Send G29
again to move to the next point and repeat until all points have been sampled.
- Parameters
P
Set the size of the grid that will be probed (P x P points). Not supported by non-linear delta printer bed leveling. Example:G29 P4
S
Set the XY travel speed between probe points (in units/min)D
Dry-Run mode. Just evaluate the bed Topology - Don't apply or clean the rotation Matrix. Useful to check the topology after a first run of G29.V
Set the verbose level (0-4). Example:G29 V3
T
Generate a Bed Topology Report. Example:G29 P5 T
for a detailed report. This is useful for manual bed leveling and finding flaws in the bed (to assist with part placement). Not supported by non-linear delta printer bed leveling.F
Set the Front limit of the probing gridB
Set the Back limit of the probing gridL
Set the Left limit of the probing gridR
Set the Right limit of the probing grid
- Global Parameters
E
By defaultG29
will engage the Z probe, test the bed, then disengage. IncludeE
orE1
to engage/disengage the Z probe for each sample. (This has no effect for fixed probes.)
G29 Unified Bed Leveling (Marlin)
Marlin firmware (version 1.1.0 and up) includes the AUTO_BED_LEVELING_UBL
option for Unified Bed Leveling. UBL combines mesh leveling, tilted plane adjustment, 3-point leveling, and manual editing tools all together in a single package. To accomplish so much, UBL overloads `G29` with several new parameters and provides an additional G26
Mesh Tuning feature.
See the MarlinFW website for a dedicated Unified Bed Leveling page and complete documentation on `G29` for UBL and `G26` Mesh Validation.
- G29 UBL Parameters (synopsis)
A Activate Activate the Unified Bed Leveling system. (i.e., M420 S1) D Disable Disable the Unified Bed Leveling system. (i.e., M420 S0) B# Business Do Manual Probing in 'Business Card' mode. H# Height Height to raise the nozzle after each Manual Probe of the bed. C Continue Continue, Constant, or Current Location, depending on Phase. E Every Stow the probe after every sampled point. F# Fade Fade leveling compensation gradually, until it ceases at the given height. I# Invalidate Invalidate a specified number of Mesh Points (X and Y). J# Grid Do a grid (planar) leveling of the current Mesh using a grid with n points on a side. K# Kompare Compare (diff) current Mesh with stored Mesh #, replacing current Mesh with the result. L Load Load Mesh from the previously activated location in the EEPROM. L# Load Load Mesh from the specified location in the EEPROM. S Store Store the current Mesh in the Activated area of the EEPROM. Also save all settings. S # Store Store the current Mesh at the specified area in EEPROM, set as the Activated area. S -1 Store Store the current Mesh as a print-out suitable to be fed back into the system. O Map Display the Mesh Map Topology. P0 Phase 0 Zero Mesh Data and turn off the Mesh Compensation System. P1 Phase 1 Invalidate the Mesh and do Automatic Probing to generate new Mesh data. P2 Phase 2 Probe unpopulated areas of the Mesh (those that couldn't be auto-probed). P3 Phase 3 Fill unpopulated Mesh points with a fixed value. No 'C' for "smart fill" extrapolation. P4 Phase 4 Fine tune the Mesh. ** Delta Mesh Compensation requires an LCD panel. ** P5 Phase 5 Find Mean Mesh Height and Standard Deviation. P6 Phase 6 Shift Mesh height. All Mesh points are adjusted by the amount specified with 'C'. Q Test Load specified Test Pattern to help check system operation. R # Repeat Repeat the command the specified number of times. Default: grid points X * Y. T 3-Point Perform a 3-Point Bed Leveling on the current Mesh. U Unlevel Perform a probe of the outer perimeter to assist in physically leveling the bed. W What? Print a report of Unified Bed Leveling stored data. X # The X location for the command Y # The Y location for the command Z Zero Do a single probe to set the Z Height of the nozzle. Z # Zero Raise/lower the entire Mesh to conform with the specified difference (plus zprobe_zoffset).
G29 Manual Bed Leveling (Marlin)
Marlin firmware (version 1.0.2 and up) also provides a MESH_BED_LEVELING
feature that can be used to perform bed leveling on machines lacking a probe. This form of bed leveling compensates for uneven Z height across the surface of the bed using a mesh and bilinear interpolation.
- Manual Bed Leveling Usage
G29 S1 ; Move to the first point and wait for a measurement G29 S2 ; Store the current Z, move to the next point G29 S3 Xn Yn Zn.nn ; Modify the Z height of a single point
- Options for the
S
parameter S0
Produces a mesh reportS1
Start probing mesh pointsS2
Probe the next mesh pointS3 Xn Yn Zn.nn
Manually modify a single pointS4 Zn.nn
Set z offset. Positive away from bed, negative closer to bed.
G29 Auto Bed Leveling (Repetier-Firmware)
Repetier firmware since v0.91 supports G29
with the optional Snnn parameter as described below. Useful to simply detect the Z bed angle so you can manually readjust your bed and get it as close to in plane as possible. If you wish to apply automatic software Z plane compensation on Repetier, use G32
instead with firmware 0.92.8 and above.
S0
Default value. Z bed heights are calculated at the measured points, relative to current Z position before issuingG29
.S1
Same asS0
, except printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issueG28 Z
to home to Z maximum position before issuingG29 Snnn
for this to work correctly, or the printer height will be invalid.S2
Same asS1
, except new calculated Z height is also stored to EEPROM.
G29 Auto Bed Leveling (RepRapFirmware)
RepRapFirmware:
S0
(default if noS
parameter) Probe the bed, save the height map in a file on the SD card, and activate bed compensation. The default folder for the height map file is/sys
and the default file name isheightmap.csv
.S1
Load the height map from file and activate bed compensation. The default folder and filename as forS0
.S2
Clear bed height map
To define the grid, see M557.
- Example
G29.1 X30 Y20 Z0.5
- Example
G29.2 Z0.0
The user would typically place the toolhead at the zero point of the axis and issue the G29.2
command.
G30: Single Z-Probe
Yes | Yes | Yes | Yes | ??? | ??? | Yes1 | ??? | |
??? | No | No | No | Yes | Yes | use G28 & G92 | ??? |
- Usage
- Parameters
Pnnn
Probe point numberXnnn
X coordinateYnnn
Y coordinateZnnn
Z coordinateHnnn
Height correctionSnnn
Set parameter- Example
G30
- Examples (RepRapFirmware)
G30 ; Probe the bed at the current XY position. When the probe is triggered, set the Z coordinate to the probe trigger height. G30 S-1 ; Probe the bed at the current XY position. When the probe is triggered, do not adjust the Z coordinate. G30 P0 X20 Y50 Z-99999 ; Probe the bed at X20 Y50 and save the XY coordinates and the height error as point 0 G30 P3 X180 Y180 Z-99999 S4 ; Probe the bed at X180 Y180, save the XY coordinates and the height error as point 3 and calculate 4-point compensation or calibration G30 P3 X180 Y180 Z-99999 S-1 ; As previous example but just report the height errors
RepRapFirmware supports additional behaviour: if a Pn
field is specified the probed X
, Y
, and Z
values are saved as point n on the bed for calculating the offset plane or for performing delta printer calibration. If X
, Y
, or Z
values are specified (e.g. G30 P1 X20 Y50 Z0.3
) then those values are used instead of the machine's current coordinates. A silly Z
value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specified (e.g. G30 P1 Z0.3 S
) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1
commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup GCode file for automatic execution.
RepRapFirmware uses the value of the S
parameter to specify what computation to perform. If the value is -1 then the Z offsets of all the points probed are printed, but no calibration is done. If the value is zero or not present, then this specifies that the number of factors to be calibrated is the same as the number of points probed. Otherwise, the value indicates the number of factors to be calibrated, which must be no greater than the number of points probed. In version 1.09, the number of factors may be 3, 4 or 5 when doing auto bed compensation on a Cartesian or CoreXY printer, and 3, 4, 6 or 7 when doing auto calibration of a Delta printer.
RepRapFirmware supports an optional H
parameter, which is a height correction for that probe point. It allows for the Z probe having a trigger height that varies with XY position. The nominal trigger height of the Z probe (e.g. at bed centre) is declared in the Z
parameter of the G31
command in the config.g file. When you probe using G30
and the probe triggers, the firmware will assume that the nozzle is at the nominal trigger height plus the value you have in the H
parameter.
1MK4duo Firmware support an optional parameter for Autocalibration Delta.
- Usage
G30 Xnnn Ynnn Znnn Annn E R I D T S U
- Parameters
Xnnn
X coordinateYnnn
Y coordinateZnnn
Z coordinateAnnn
A Autocalibration width nnn precisionE
Adjust EndstopR
Adjust Endstop & Delta RadiusI
Adjust TowerD
Adjust Diagonal RodT
Adjust Tower RadiusSn
Stows the probe if 1 (default=1)Un
<bool> with a non-zero value will apply the result to current zprobe_zoffset
No | Yes | Yes: 0.91.7 | Yes | ??? | ??? | No | ??? | |
- Usage
- Parameters
Pnnn
Trigger valueXnnn
Probe X offset1Ynnn
Probe Y offset1Znnn
Trigger Z heightCnnn
Temperature coefficient2Snnn
Calibration temperature2Tnnn
(RepRapFirmware 1.17 and later) Z probe type to which these parameters apply, defaults to the current Z probe type as defined byM558 P
parameter- Examples
G31 P500 Z2.6 G31 X16.0 Y1.5
When used on its own this reports whether the Z probe is triggered, or gives the Z probe value in some units if the probe generates height values. If combined with a Z and P field (example: G31 P312 Z0.7
) this will set the Z height to 0.7mm when the Z-probe value reaches 312 when a G28 Z0
(zero Z axis) command is sent. The machine will then move a further -0.7mm in Z to place itself at Z = 0. This allows non-contact measuring probes to approach but not touch the bed, and for the gap left to be allowed for. If the probe is a touch probe and generates a simple 0/1 off/on signal, then G31 Z0.7
will tell the RepRap machine that it is at a height of 0.7mm when the probe is triggered.
In RepRapFirmware, separate G31
parameters may be defined for different probe types (i.e. 0+4 for switches, 1+2 for IR probes and 3 for alternative sensors). To specify which probe you are setting parameters for, send a M558 command to select the probe type before sending the G31
command, or use the T
parameter.
In Repetier, G31
supports no parameters and simply prints the high/low status of the Z probe.
- Notes
1X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) can be specified in RepRapFirmware. This allows you to calculate your probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset.
2In RepRapFirmware, additional parameters 'S' (bed temperature in oC at which the specified Z
parameter is correct, default is current bed temperature) and 'C' (temperature coefficient of Z
parameter in mm/oC, default zero) can be set for the alternative (ultrasonic) sensor. This is useful for probes that are affected by temperature. This facility is deprecated and likely to be removed in a future version of RepRapFirmware.
Yes | No | ??? | No | ??? | ??? | Yes | ??? | |
??? | No | No | No | No | Yes | No | ??? |
No: See G29 | Yes | Yes: 0.92.8 | Yes | ??? | ??? | No | ??? | |
- Usage
G32 ; Probe and calculate G32 Snnn ; Each firmware has its own parameters G32 Snnn Pnnn ; Refer to their specific documentation
This command is implemented as a more sophisticated form of bed leveling (which uses a transformation matrix or motorized correction. Smoothieware uses this code instead of `G29`.
Each firmware behaves differently. For example, Repetier firmware allows for motorized rotation of the bed whilst ReprapFirmware probes the bed with a transformation matrix.
Probe and calculate in Reprapfirmware
This command probes the bed at 3 or more pre-defined points (see M557) and updates transformation matrix for bed leveling compensation.
- Parameters
Snnn
Store transformation matrix after probing1- Examples
G32 G32 S2
RepRapFirmware executes macro file bed.g
if present instead of using the M557 coordinates.
- Notes
1Currently only Repetier firmware v0.92.8 and higher have working support for an optional Snnn parameter. The numeric value sets the behavior that occurs immediately after point probe and transformation matrix calculation. These are the values for Reprapfirmware:
S0
Default value. Transformation matrix is updated in RAM but is not stored to EEPROM. Z bed height not calculated.S1
Transformation matrix is updated in RAM but is not stored to EEPROM. Printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issueG28
to home to Z maximum position before issuingG32 Snnn
Same as S1, except transformation matrix and Z max heights are also stored to EEPROM.S3
Transformation matrix is stored to EEPROM. Z bed height not calculated.
Probe and calculate in Repetier firmware
This command probes the bed at 3 or more pre-defined points and implements bed leveling compensation by either moving the A axis during printing (as with regular bed leveling, G29
) or by tilting the bed with motors.
- Parameters
Snnn
Bed leveling methodPnnn
Bed correction method
The values for Snnn and Pnnn are as follows:
S0
This method measures at the 3 probe points and creates a plane through these points. If you have a really planar bed this gives the optimum result. The 3 points must not be in one line and have a long distance to increase numerical stability.S1
This measures a grid. Probe point 1 is the origin and points 2 and 3 span a grid. We measure BED_LEVELING_GRID_SIZE points in each direction and compute a regression plane through all points. This gives a good overall plane if you have small bumps measuring inaccuracies.S2
Bending correcting 4 point measurement. This is for cantilevered beds that have the rotation axis not at the side but inside the bed. Here we can assume no bending on the axis and a symmetric bending to both sides of the axis. So probe points 2 and 3 build the symmetric axis and point 1 is mirrored to 1m across the axis. Using the symmetry we then remove the bending from 1 and use that as plane.P0
Use a rotation matrix. This will make z axis go up/down while moving in x/y direction to compensate the tilt. For multiple extruders make sure the height match the tilt of the bed or one will scratch. This is the default.P1
Motorized correction. This method needs a bed that is fixed on 3 points from which 2 have a motor to change the height. The positions are defined in firmware by BED_MOTOR_1_X, BED_MOTOR_1_Y, BED_MOTOR_2_X, BED_MOTOR_2_Y, BED_MOTOR_3_X, BED_MOTOR_3_Y Motor 2 and 3 are the one driven by motor driver 0 and 1. These can be extra motors like Felix Pro 1 uses them or a system with 3 z axis where motors can be controlled individually like the Sparkcube does. This method requires a Z max endstop.
G33: Measure/List/Adjust Distortion Matrix (Repetier - Redeem)
No | No | Yes: v0.92.8 | No | ??? | ??? | No | ??? | |
- Usage
G33
G33 Lnnn
G33 Rnnn
G33 Xnnn Ynnn Znnn
- Parameters
L0
List distortion matrix in a reportR0
Reset distortion matrixX[pos] Y[pos] Z[zCorrection]
Set correction for nearest point- Examples
G33 G33 R0
When used with no parameters, G33
will measure a grid of points and store the distortion dips and valleys in the bed surface, and then enable software distortion correction for the first few or several layers. The values will be stored in EEPROM if enabled in firmware. You must previously have G28
homed, and your Z minimum/maximum height must be set correctly for this to work. Use the optional parameters to list, reset or modify the distortion settings. Distortion correction behavior can be later turned on or off by code M323
G33: Delta Auto Calibration (Marlin 1.1.x)
Yes | No | No | No | ??? | ??? | No | No | |
Performs a 1-4-7 point calibration of delta height (P1), endstops, delta radius (P2) and tower angle corrections (P>=3) by an iteration process based on the least squares method.
- Usage
G33
G33 Pn Tb Cx.xx Fn Vn Eb
- Parameters
Pn
Number of probe points: n*n (n=0-7), when P is omitted the default set in Configuration.h is usedT0
Do not calibrate tower angle corrections (if used with P>=3); do not use the probe points near the towers, but the probe points opposite to the towers (if used with P=2); when T is omitted it defaults to T1Cx.xx
Force the iterations to stop when a standard deviation from the zero plane less then x.xx mm is achieved; when C is omitted the iterations go on until the best possible standard deviation is reached.Fn
Force to run at least n iterations (n=1-30) and take the best resultVn
Verbose level: (n=0-2) 0 = dry run without calibration; 1(default) = settings ; 2 = settings and probe resultsE1
Engage the probe for each point, when E is omitted it defaults to E0- Examples
G33 : calibrates with the default settings. G33 Auto Calibrate Checking... AC .Height:297.77 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 .Tower angle : Tx:+0.00 Ty:+0.00 Tz:+0.00 Iteration : 01 std dev:0.306 .Height:297.65 Ex:-0.15 Ey:-0.14 Ez:+0.00 Radius:100.77 .Tower angle : Tx:-0.02 Ty:+0.11 Tz:+0.00 Iteration : 02 std dev:0.049 .Height:297.67 Ex:-0.12 Ey:-0.12 Ez:+0.00 Radius:100.87 .Tower angle : Tx:-0.03 Ty:+0.20 Tz:+0.00 Iteration : 03 std dev:0.033 .Height:297.69 Ex:-0.10 Ey:-0.12 Ez:+0.00 Radius:100.91 .Tower angle : Tx:-0.03 Ty:+0.25 Tz:+0.00 Iteration : 04 std dev:0.031 .Height:297.69 Ex:-0.07 Ey:-0.11 Ez:+0.00 Radius:100.92 .Tower angle : Tx:-0.03 Ty:+0.30 Tz:+0.00 Calibration OK rolling back. .Height:297.69 Ex:-0.10 Ey:-0.12 Ez:+0.00 Radius:100.91 .Tower angle : Tx:-0.03 Ty:+0.25 Tz:+0.00 Save with M500 and/or copy to Configuration.h
G33 P6 V0 : probes 36 points in dry run mode. G33 Auto Calibrate Checking... AC (DRY-RUN) .Height:297.77 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 .Tower angle : Tx:+0.00 Ty:+0.00 Tz:+0.00 . c:+0.03 x:+0.32 y:+0.34 z:+0.41 . yz:+0.37 zx:+0.32 xy:+0.17 End DRY-RUN std dev:0.306
G33 P4 C0.05 T0 : probes 16 points and stops when a standard deviation of 0.05mm is reached; calibrates delta height, endstops and delta radius, leaves the tower angle corrections unaltered. G33 Auto Calibrate Checking... AC .Height:297.78 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 Iteration : 01 std dev:0.317 .Height:297.65 Ex:-0.15 Ey:-0.16 Ez:+0.00 Radius:100.80 Iteration : 02 std dev:0.059 .Height:297.66 Ex:-0.17 Ey:-0.13 Ez:+0.00 Radius:100.91 Calibration OK std dev:0.042 .Height:297.66 Ex:-0.17 Ey:-0.13 Ez:+0.00 Radius:100.91 Save with M500 and/or copy to Configuration.h
G33 P2 : probes center and tower positions and calibrates delta height, endstops and delta radius. G33 Auto Calibrate Checking... AC .Height:297.78 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 Iteration : 01 std dev:0.374 .Height:297.68 Ex:-0.14 Ey:-0.15 Ez:+0.00 Radius:101.09 Iteration : 02 std dev:0.054 .Height:297.68 Ex:-0.14 Ey:-0.14 Ez:+0.00 Radius:101.23 Iteration : 03 std dev:0.007 .Height:297.69 Ex:-0.13 Ey:-0.14 Ez:+0.00 Radius:100.92 Calibration OK rolling back. .Height:297.68 Ex:-0.14 Ey:-0.14 Ez:+0.00 Radius:101.23 Save with M500 and/or copy to Configuration.h
G33 P1 : probes the center and sets the delta height only. G33 Auto Calibrate Checking... AC .Height:295.00 Calibration OK .Height:297.78 Save with M500 and/or copy to Configuration.h
note: Height = delta height; Ex, Ey, Ez = end-stop corrections; Radius = delta radius; Tx, Ty, Tz = tower angular corrections; c, x, y, z, yz, zx, xy = probe results at center, towers and opposite to towers; std dev = standard deviation of the probe results towards the zero plane.
Yes: 1.1.0 | No | ??? | Yes | ??? | ??? | No | ??? | |
Yes | ??? | ??? | ??? | ??? | No | ??? | ??? |
??? | No | ??? | ??? | ??? | ??? | No | ??? | |
No | No | ??? | No | ??? | ??? | No | ??? | |
G40
turns off cutter compensation. If tool compensation was on the next move must be a linear move and longer than the tool diameter. It is OK to turn compensation off when it is already off.
Yes: 1.1.2 | No | No | No | ??? | ??? | No | No | |
G42
does a fast move in XY to any of the intersection points in the bed calibration grid. This is useful during calibration to align the nozzle or probe.
- Parameters
Inn
Grid X index (zero-based). If omitted, the nearest latitude.Jnn
Grid Y index (zero-based). If omitted, the nearest longitude.P
Probe flag. Moves the probe to the grid point (instead of the nozzle).Fnnn
Feedrate (mm/m)- Example
G42 I3 J4 P F3000 ; Move the probe to grid coordinate 3, 4
No | No | ??? | Yes | ??? | ??? | No | ??? | |
??? | ??? | ??? | ??? | ??? | ??? | Yes | ??? | |
- Usage
G60 Snn
- Parameters
Snn
<nn> specifies memory slot # (0-based) to save into (default 0)
- Usage
G61 Xnnn Ynnn Znnn Ennn Fnnn Snn
- Parameters
Xnnn
X coordinateYnnn
Y coordinateZnnn
Z coordinateEnnn
E coordinateFnnn
F Set FeedrateSnn
S specifies memory slot # (0-based)
- Example
G90
Yes | Yes | No | Yes | Yes | Yes | Yes | ??? |
- Example
G91
All coordinates from now on are relative to the last position. Note: RepRapFirmware latest revision firmware uses M83
to set the extruder to relative mode: extrusion is NOT set to relative by ReprapFirmware on G91
: only X,Y and Z are set to relative. By contrast, Marlin (for example) DOES also set extrusion to relative on a G91
command, as well as setting X, Y and Z.
G92: Set Position
- Parameters
Xnnn
new X axis positionYnnn
new Y axis positionZnnn
new Z axis positionEnnn
new extruder position- Example
G92 X10 E90
A G92
without coordinates will reset all axes to zero.
G92.x: Reset Coordinate System Offsets (CNC specific)
??? | No | ??? | Yes | ??? | ??? | No | ??? | |
G92.1
- reset axis offsets to zero and set parameters 5211 - 5219 to zero. (X Y Z A B C U V W) -
G92.2
- reset axis offsets to zero.
G93 is Inverse Time Mode. In inverse time feed rate mode, an F word means the move should be completed in (one divided by the F number) minutes. For example, if the F number is 2.0, the move should be completed in half a minute.
When the inverse time feed rate mode is active, an F word must appear on every line which has a G1
, G2
, or G3
motion, and an F word on a line that does not have G1
, G2
, or G3
is ignored. Being in inverse time feed rate mode does not affect G0
(rapid move) motions.
No | No | Yes: 0.92 | No | ??? | ??? | No | ??? | |
- Parameters
X
Flag to set floor for X axisY
Flag to set floor for Y axisZ
Flag to set floor for Z axisRnnn
Radius to add- Examples
G100 X Y Z ; set floor for argument passed in. Number ignored and may be absent. G100 R5 ; Add 5 to radius. Adjust to be above floor if necessary G100 R0 ; Set radius based on current z measurement. Moves all axes to zero
No | No | No | No | ??? | ??? | No | Yes | |
- Example
G130 X10 Y18 Z15 A20 B12
G131: Remove offset
No | No | Yes: 0.91 | No | ??? | ??? | No | ??? | |
G133: Measure steps to top
G161: Home axes to minimum
??? | No | No | No | No | No | Yes | ??? |
- Parameters
X
Flag to home the X axis to its minimum positionY
Flag to home the Y axis to its minimum positionZ
Flag to home the Z axis to its minimum positionFnnn
Desired feedrate for this command- Example
G161 X Y Z F1800
Instruct the machine to home the specified axes to their minimum position. Similar to G28
, which decides on its own in which direction to search endstops.
G162: Home axes to maximum
- Parameters
X
Flag to home the X axis to its maximum positionY
Flag to home the Y axis to its maximum positionZ
Flag to home the Z axis to its maximum positionFnnn
G162 X Y Z F1800
M-commands
Yes | Yes | No | No | ??? | ??? | Yes | ??? | |
Yes | No | No | Yes | Yes | No | Yes | ??? |
- Parameters
Pnnn
Time to wait, in milliseconds1Snnn
Time to wait, in seconds2- Example
M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller, although this step is not mandatory on RepRapFirmware. See also M1
, M112
RepRapFirmware executes macro file stop.g
before everything is turned off. Apart from that, RepRapFirmware (v1.09n-ch) accepts an extra 'H' parameter, whose value must be non-zero, to keep all heaters active. This is what Duet Web Control v1.07 sends to cancel a paused print.
- Notes
1Not available in RepRapFirmware, but as a work-around G4
can be run before M0
2Only available on Marlin.
M1: Sleep or Conditional stop
Yes | No | No | No | No | No | ??? | ??? |
- Example
M1
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can still be sent G and M codes, the first of which will wake it up again. See also M0
, M112
The Marlin Firmware does the same as M0
If Marlin is emulated in RepRapFirmware, this does the same as M25 if the code was read from a serial or Telnet connection, else the macro file sleep.g
is run before all heaters and drives are turned off.
M2: Program End
No | No | No | ??? | ??? | ??? | No | Yes | |
Yes | No | No | No | No | No | Yes | ??? |
- Example
M2
Teacup firmware does the same as M84
No | Yes | Yes | Yes | ??? | ??? | No | ??? | |
- Parameters
Snnn
Spindle RPM- Example
M3 S4000
Teacup firmware turn extruder on (same as M101
RepRapFirmware interprets this code only if a Roland mill has been configured.
In Repetier-Firmware in laser mode you need S0
..S255
to set laser intensity. Normally you use S255
to turn it on full power for moves. Laser will only fire during G1
/G2
/G3
moves and in laser mode (M452
No | No | Yes | No | ??? | ??? | No | ??? | |
Yes | No | No | No | No | No | No | ??? |
- Example
M4 S4000
No | No | Yes | Yes | ??? | ??? | No | ??? | |
- Example
M5
The spindle is turned off.
Teacup firmware turn extruder off (same as M103
M6: Tool change
No | No | No | ??? | ??? | ??? | No | ??? | |
- Example
M6
Yes | No | No | No | No | No | use M106 | ??? |
- Example
M7
Teacup firmware turn on the fan, and set fan speed (same as M106
- Example
M8
- Example
M9
M10: Vacuum On (CNC specific)
??? | No | No | No | No | No | use M106 | ??? |
- Example
M10
- Example
M11
Yes | No | No | Yes | ??? | ??? | Yes | ??? | |
??? | No | No | No | No | Yes | (automatic) | ??? |
- Example
M17
call M84 | Yes | No | Yes | ??? | ??? | call M84 | Yes | |
??? | No | No | No | No | Yes | use M2 | ??? |
- Parameters
- This command can be used without any additional parameters.1
X
X axisY
Y axisZ
Z axisE
Extruder drive(s)2- Examples
M18 M18 X E0
- Notes
2RepRapFirmware allows stepper motors to be disabled selectively. For example, M18 X E0:2
will disable the X, extruder 0 and extruder 2 motors.
M20: List SD card
??? | Yes | No | No | No | No | Yes | ??? |
- Parameters
Snnn
Output style1Pnnn
Directory to list2- Examples
M20 M20 S2 P/gcodes/subdir
ok SQUARE.G SQCOM.G ZCARRI~2.GCO CARRIA~1.GCO
On Marlin, a file list response is usually encapsulated. Standard configurations of RepRapFirmware mimic this style in emulation mode:
Begin file list: SQUARE.G ZCARRI~2.GCO End file list ok
GCode files: "Traffic cone.g","frog.gcode","calibration piece.g"
Note that some firmwares list file names in upper case, but - when sent to the M23
command (below) they must be in lower case. Teacup and RepRapFirmware have no such trouble and accept both. RepRapFirmware always returns long filenames in the case in which they are stored.
- Notes
1If the S2 parameter is used on RepRapFirmware, then the file list is returned in JSON format as a single array called "files" with each name that corresponds to a subdirectory preceded by an asterisk, and the directory is returned in variable "dir".
- Example
M20 S2 P/gcodes {"dir":"\/gcodes","files":["4-piece-1-2-3-4.gcode","Hinged_Box.gcode","Hollow_Dodecahedron_190.gcode","*Calibration pieces"]}
2This parameter is only supported by RepRapFirmware and defaults to the 0:/gcodes directory, which is the directory that printable gcode files are normally stored in.
M21: Initialize SD card
- Parameters
Pnnn
SD card number (RepRapFirmware only, default 0)- Examples
M21 M21 P1
The specified SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
M22: Release SD card
Yes | Yes | Yes | No | ??? | ??? | Yes | ??? | |
- Parameters
Pnnn
M22 M22 P1
The specified SD card is released, so further (accidental) attempts to read from it are guaranteed to fail. Helpful, but not mandatory before removing the card physically.
M23: Select SD file
- Example
M23 filename.gco
M24: Start/resume SD print
??? | Yes | No | No | No | Yes | Yes | ??? |
- Example
M24
The machine prints from the file selected with the M23
command. If the print was previously paused with M25
, printing is resumed from that point. To restart a file from the beginning, use M23
to reset it, then M24
When this command is used to resume a print that was paused, RepRapFirmware runs macro file resume.g
prior to resuming the print.
M25: Pause SD print
- Example
M25
The machine pauses printing at the current position within the file. To resume printing, use M24. Do not use this code to pause the print in a G-code file, use M226 instead.
Prior to pausing, RepRapFirmware runs macro file pause.g
. This allows the head to be moved away from the print, filament to be retracted, etc.
M26: Set SD position
Yes | Yes | Yes | aborts | ??? | ??? | Yes | ??? | |
??? | Yes | No | No | No | No | No | ??? |
- Parameters
Snnn
File position in bytes- Example
M26
M27: Report SD print status
- Example
M27
Report SD print status.
Marlin and recent forks of RepRapFirmware report the number of bytes processed in this format, which can be processed by Pronterface:
SD printing byte 2134/235422
Not SD printing.
M28: Begin write to SD card
- Example
M28 filename.gco
M29: Stop writing to SD card
- Example
M29 filename.gco
File opened by M28
command is closed, and all subsequent commands sent to the machine are executed as normal.
Yes | Yes | No | No | No | No | No | ??? |
- Example
> M30 filename.gco > filename.gco is deleted.
M30 in grbl
M30 exchange pallet shuttles and end the program. Pressing cycle start will start the program at the beginning of the file.
M31: Output time since last M109
or SD card start to serial
Yes | No | No | No | ??? | ??? | Yes | ??? | |
- Example
M31
The response looks like:
echo:54 min, 38 sec
Yes | Yes | No | Yes | ??? | ??? | No | ??? | |
- Example
M32 filename.gco
It can be used when printing from SD card and does the same as M23
and M24
Yes | No | No | No | ??? | ??? | No | ??? | |
M33: Stop and Close File and save restart.gcode
Stop the printing from SD and save all position in restart.gcode for restart printing in future
M35: Upload firmware NEXTION from SD
M36: Return file information
No | Yes | No | No | ??? | ??? | No | No | |
- Example
M36 filename.gco
If the file name parameter is not supplied and a file on the SD card is currently being printed, then information for that file is returned including additional field "fileName". This feature is used by the web interface and by PanelDue, so that if a connection is made when a file is already being printed, the name and other information about that file can be shown.
M37: Simulation mode
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
M37 S1
enters simulation mode. All G and M codes will not be acted on, but the time they take to execute will be calculated.
M37 S0
leaves simulation mode.
M37
with no S
parameter prints the time taken by the simulation, from the time it was first entered using M37 S1
, up to the current point (if simulation mode is still active) or the point that the simulation was ended (if simulation mode is no longer active).
M38 Compute SHA1 hash of target file
Used to compute a hash of a file on the SD card. Examples:
> M38 gcodes/myfile.g > Cannot find file > M38 www/reprap.htm > 91199139dbfadac15a18cfb962dfd4853db83999
Returns a hexadecimal string which is the SHA1 of the file. If the file cannot be found, then the string "Cannot find file" is returned instead.
M40: Eject
If your RepRap machine can eject the parts it has built off the bed, this command executes the eject cycle. This usually involves cooling the bed and then performing a sequence of movements that remove the printed parts from it. The X, Y and Z position of the machine at the end of this cycle are undefined (though they can be found out using the M114
command, q.v.).
See also M240
and M241
below.
M41: Loop
- Example
M41
- When you press the reset button,
- When the build material runs out (if your RepRap is set up to detect this), and
- When there's an error (such as a heater failure).
M42: Switch I/O pin
Yes | Yes | Yes | No | ??? | ??? | Yes | No | |
- Parameters
Pnnn
Pin numberSnnn
Pin value- Example
M42 P7 S255
M42 switches a general purpose I/O pin. Use M42 Px Sy
to set pin x to value y, when omitting Px the LEDPIN will be used.
In RepRapFirmware, the S field may be in the range 0..1 or 0..255. The pin reference is an internal firmware reference named "digital pin", see Duet pinout. It maps on different connector pins depending the hardware. On Duet 0.6 and 0.8.5 hardware using pre-1.16 firmware, the supported pin numbers and their names on the expansion connector are:
P | Name | Expansion Port Pin |
16 | TXD1 | 11 |
17 | RXD1 | 12 |
18 | TXD0 | 13 |
19 | RXD0 | 14 |
20 | TWD1 | 35 |
21 | TWCK1 | 36 |
23 | PA14 | 10 |
36 | PC4 | 18 |
52 | AD14 | 41 |
67 | PB16 | 32 |
In firmware 1.16, the pin numbering has changed.
60 | PA10/RXD0 | 14 |
61 | PA11/TXD0 | 13 |
62 | PA12/RXD1 | 12 |
63 | PA13/TXD1 | 11 |
64 | PA14/RTS1 | 10 |
65 | PB12/TWD1 | 35 |
66 | PB13/TWCK1 | 36 |
67 | PB16/DAC1* | 32 |
68 | PB21/AD14 | 41 |
69 | PC4 | 18 |
- Also used as CS signal on external SD card socket
P | Signal Name | Expansion Connector Label | Expansion Pin |
60 | CS5 | CS5 | 50 |
61 | CS6 | E3_STOP | 9 |
62 | CS7 | E4_STOP | 14 |
63 | CS8 | E5_STOP | 19 |
See Using servos and controlling unused I/O pins for all pin definitions.
Pre-1.16 example:
M42 P20 S1 ;set the connector pin 35 to high.
See also M583
- Example
M43
M43: Pin report and debug
- Usage
M43 En Pnnn Wn In
- Parameters
En
Enable / disable background endstop monitoringPnnn
Pin to read or watch. If omitted, read/watch all pinsWn
bool watch pins -reporting changes- until reset, click, orM108
In
bool Flag to ignore pin protection
- Note
- You must have
PINS_DEBUGGING
uncommented in yourConfiguration_adv.h
file for M43 to work.
- Parameters
Pnnn
number of pointsXnnn
position on the X axisYnnn
position on the Y axisVnnn
verbosityE
engageLnnn
legs of travelS
schizoid
As with G29
, the E flag causes the probe to stow after each probe.
The S flag will result is a random sized, 5 pointed star, being traced (X and Y axis) between each sample. Usually a user will get worse repeat-ability numbers with S specified because the X axis and Y axis movements will add to the machine's positioning errors.
M70: Display message
see M117 | see M117 | see M117 | see M117 | ??? | ??? | see M117 | Yes | |
??? | No | No | No | No | see M117 | No | ??? |
- Example
M70 P200 Message
Instruct the machine to display a message on its interface LCD. P
is the time to display message for.
M72: Play a tone or song
see M300 | see M300 | No | No | ??? | ??? | see M300 | Yes | |
- Example
M72 P2
M73: Set build percentage
- Example
M73 P50
Instruct the machine that the build has progressed to the specified percentage. The machine is expected to display this on it's interface board. If the percentage is exactly 0, then a Build Start Notification is sent. If the percentage is exactly 100, then a Build End notification is sent.
M80: ATX Power On
??? | Yes | No | No | No | No | automatic | ??? |
- Examples
M80 ; Turn on the power supply M80 S ; Report power supply state (Marlin 1.1.1)
- Notes
- Marlin requires the
POWER_SUPPLY
configuration option to be set to a non-zero value to enableM80
. - Some firmwares (e.g., Teacup) handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off.
M81: ATX Power Off
??? | Yes | No | No | No | Yes | automatic | ??? |
- Example
M81
Turns off the ATX power supply. Counterpart to M80
For redeem, adding 'P' will quit the daemon (redeem). Adding parameter 'R' will restart the daemon.
- Example
M82
- Example
M83
M84: Stop idle hold
- Parameters
Innn
Reset flags1- Example
M84
On Marlin, Repetier and RepRapFirmware, M84
can also be used to configure or disable the idle timeout. For example, "M84 S10" will idle the stepper motors after 10 seconds of inactivity. "M84 S0" will disable idle timeout; steppers will remain powered up regardless of activity.
- Notes
1RepRapFirmware-dc42 and other firmware may not support this parameter.
M85: Set inactivity shutdown timer
Yes | No | Yes | No | ??? | ??? | Yes | ??? | |
- Example
M85 S30
M92: Set axis_steps_per_unit
??? | Yes | No | No | No | Yes | No | ??? |
- Parameters
Xnnn
Steps per unit for the X driveYnnn
Steps per unit for the Y driveZnnn
Steps per unit for the Z driveEnnn
Steps per unit for the extruder drive(s)- Examples
M92 X87.489 Y87.489 Z87.489 M92 E420:420
Allows programming of steps per unit (usually mm) for motor drives. These values are reset to firmware defaults on power on, unless saved to EEPROM if available (M500
in Marlin) or in the configuration file (config.g in RepRapFirmware). Very useful for calibration.
RepRapFirmware will report the current steps/mm if you send M92
without any parameters.
M93: Send axis_steps_per_unit
No | Use M92 | ??? | No | ??? | ??? | No | ??? | |
M98: Call Macro/Subprogram
- Parameters
Pnnn
Macro filename- Example
M98 Pmymacro.g
Runs the macro in the file mymacro.g. In conventional G Codes for CNC machines the P
parameter normally refers to a line number in the program itself (P2000 would run the Macro starting at line O2000, say). For RepRap, which almost always has some sort of mass storage device inbuilt, it simply refers to the name of a GCode file that is executed by the G98
call. That GCode file does not need to end with an M99
(return) as the end-of-file automatically causes a return. Macro calls cannot usually be nested or be recursive; i.e. you can't call a macro from a macro, although RepRapFirmware explicitly supports this.
RepRapFirmware also allows the filename to include a path to a subdirectory. For relative paths, the default folder is /sys, but some implementations may check the /macros directory too. Absolute file paths are supported on RepRapFirmware as well.
- Example
M99
Returns from an M98
call.
M98: Get axis_hysteresis_mm
Deprecated - clashes with the G Code standard M98
above
- Example
M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Deprecated - clashes with the G Code standard M99
above
- Example
M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
No | 1.17c and later | No | No | ??? | ??? | No | ??? | |
??? | No | Yes | No | No | No | Yes | ??? |
in Teacup firmware:
If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103
in BFB/RapMan: Turn extruder on (forward/filament in).
in RepRapFirmware: undo filament retraction. The length and speed are set by the M207
command. RepRapFirmware supports this command for compatibility with Simplify3D.
in other firmwares:
Deprecated. Regarding filament retraction, see G10
, G11
, M207
, M208
, M227
, M228
, M229
??? | No | Yes | No | No | No | No | ??? |
In other firmwares: Deprecated.
In Teacup firmware:
If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101
In RepRapFirmware: retract filament. The length and speed are set by the M207
in other firmwares: Deprecated. Regarding filament retraction, see G10
, G11
, M207
, M208
, M227
, M228
, M229
Yes | Yes | Yes | Yes | ??? | ??? | Yes | Yes | |
??? | Yes | Yes | Yes | Yes | Yes | Yes | ??? |
- Parameters
Snnn
Target temperature- Example
M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). Duet-dc42 and other firmware also supports the optional T
parameter (as generated by slic3r) to specify which tool the command applies to. See also M109
This is deprecated because temperatures should be set using the G10
and T
commands (q.v.).
M104 in Teacup Firmware
In Teacup Firmware, M104
can be additionally used to handle all devices using a temperature sensor. It supports the additional P
parameter, which is a zero-based index into the list of sensors in config.h. For devices without a temp sensor, see M106.
- Example
M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100°C.
??? | Yes | No | Yes | No | Yes | Yes | ??? |
- Parameters
Rnnn
Response sequence number1Snnn
Response type1- Examples
M105 M105 S2
ok T:201 B:117
Expansion/generalization of M105
to be considered using S1 parameter as noted in Pronterface I/O Monitor
M105 X0 ==> 11:05:48.910 : T:23.61 /0 @:0 T0:23.61 /0 @0:0 RAW0:3922 T1:23.89 /0 @1:0 RAW1:3920
- Notes
1These parameters are only supported by RepRapFirmware, which returns a JSON-formatted response if parameter S2 or S3 is specified. Additionally, parameter Rnn may be provided, where nn is the sequence number of the most recent G-code response that the client has already received. M105 S2
is equivalent to M408 S0
, and M105 S3
is equivalent to M408 S2.
Usage of these forms of M105
is deprecated, please use M408
instead.
M106: Fan On
- Parameters
Pnnn
Fan number (optional, defaults to 0)2Snnn
Fan speed (0 to 255; RepRapFirmware also accepts 0.0 to 1.0))- Extra Parameters
Innn
Invert signal, or disable fan1Fnnn
Set fan PWM frequency, in Hz1Lnnn
Set minimum fan speed (0 to 255 or 0.0 to 1.0)1Bnnn
Blip time - fan will be run at full PWM for this number of seconds when started from standstill1Hnn:nn:nn...
Select heaters monitored when in thermostatic mode1Rnnn
Restore fan speed to the value it has when the print was paused1Tnnn
Set thermostatic mode trigger temperature1- Example
M106 S127
M106 P1 I1 S87 M106 P1 T45 H1:2 M106 P2 B0.1 L0.05
The first example turns on the default cooling fan at half speed. The second one inverts the cooling fan signal of the second fan and sets its value to 1/3 of its maximum. The third one sets the second fan to a thermostatic fan for heaters 1 and 2 (e.g. the extruder heaters in a dual-nozzle machine) such that the fan will be on when either hot end is at or above 45C.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0
turns the fan off. In some implementations like RepRapFirmware the PWM value may alternatively be specified as a real fraction: M106 S0.7
- Notes
2Marlin only supports fan 0, all values above 0 will be interpreted as 0
M106 in RepRapFirmware
If an S
parameter is provided but no other parameter is present, then the speeds of the print cooling fans associated with the current tool will be set (see the F
parameter in the M563
command). If no tool is active then the speed of Fan 0 will be set. Either way, the speed is remembered so that it can be recalled using the R2
parameter (see below).
If no S
parameter is given but the R1 parameter is used, the fan speed when the print was last paused will be set. If the R2
parameter is used, then the speeds of the print cooling fans associated with the current tool will be set to the remembered value (see above).
The T
and H
parameters allow a fan to be configured to operate in thermostatic mode, for example to use one of the fan channels to control the hot end fan. In this mode the fan will be fully on when the temperature of any of the heaters listed in the H
parameter is at or above the trigger temperature set by the T
parameter, and off otherwise. Thermostatic mode can be disabled using parameter H-1.
The B
parameter sets the time for which the fan will be operated at full PWM when started from cold, to allow low fan speeds t be used. A value of 0.1 seconds is usually sufficient.
The L
parameter defines the minimum PWM value that is usable with this fan. If a lower value is commanded that is not zero, it will be rounded up to this value.
The I
parameter causes the fan output signal to be inverted if its value is greater than zero. This makes the cooling fan output suitable for feeding the PWM input of a 4-wire fan via a diode. If the parameter is present and zero, the output is not inverted. If the I
parameter is negative then in RRF 1.16 and later the fan is disabled, which frees up the pin for use as a general purpose I/O pin that can be controlled using M42
M106 in Teacup Firmware
Additionally to the above, Teacup Firmware uses M106
to control general devices. It supports the additional P
parameter, which is an zero-based index into the list of heaters/devices in config.h.
- Example
M106 P2 S255
Note: When turning on a temperature sensor equipped heater with M106
and M104
at the same time, temperature control will override the value given in M106
quickly.
Note well: The ambiguous text in the note above needs to be reworded by someone who knows the actual functioning. Below is my interpretation based on language use, not practical experience or code inspection.
Note: If M104
is (or becomes) active on a heater (or other device) with a feedback sensor it will correct any M106
initiated control output value change in the time it takes for the PID (of other feedback) loop to adjust it back to minimum error. It may not be easy to observe a change in the temperature (process value) due to this brief change in the control value
M107: Fan Off
Yes | Yes | Yes | Yes | ??? | ??? | Yes | ??? | |
??? | Yes | Yes | Yes | Yes | Yes | No | ??? |
Deprecated in Teacup firmware and in RepRapFirmware. Use M106 S0
instead.
M108: Cancel Heating (Marlin)
Breaks out of an M109
or M190
wait-for-temperature loop, continuing the print job. Use this command with caution! If cold extrusion prevention is enabled (see M302
) and the temperature is too low, this will start "printing" without extrusion. If cold extrusion prevention is disabled and the hot-end temperature is too low, the extruder may jam.
This command was introduced in Marlin 1.1.0. As with other emergency commands [e.g., M112
] this requires the host to leave space in the command buffer, or the command won't be executed until later.
M108: Set Extruder Speed (BFB)
No | No | No | No | ??? | ??? | No | ??? | |
Sets speed of extruder motor.
(Deprecated in FiveD firmware, see M113
??? | Yes | No | Yes | Yes | Yes | not needed | ??? |
- Parameters
Snnn
minimum target temperature, waits until heatingRnnn
maximum target temperature, waits until cooling (Sprinter)Rnnn
accurate target temperature, waits until heating and cooling (Marlin)- Example
M109 S215
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port), RepRapFirmware
- Example
M109 S185
RepRapFirmware also supports the optional T
parameter (as generated by slic3r) to specify which tool the command refers to (see below).
M109 in Sprinter (4pi port)
Parameters: S
(optional), set target temperature value. If not specified, waits for the temperature set by M104. R
(optional), sets target temperature range maximum value.
- Example
M109 S185 R240 ; set extruder temperature to 185 and wait for the temperature to be between 185 - 240.
If you have multiple extruders, use T
or P
parameter to specify which extruder you want to set/wait.
M109 in MakerBot
- Example
M109 S70 T0
M110: Set Current Line Number
??? | No | No | Yes | No | Yes | not needed | ??? |
- Parameters
Nnnn
Line number- Example
M110 N123
M111: Set Debug Level
??? | No | No | Yes | No | Yes | Debug | ??? |
- Parameters
Pnnn
Debug module1Snnn
Debug on/off- Examples
M111 S6 M111 P1 S1
- Notes
M111 in RepRapFirmware
RepRapFirmware allows debugging to be set for each module. If the optional 'P' parameter is not specified, debugging will be enabled for all modules. For a list of modules, send M111 S1 P15
M111 in Repetier
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2) #define DEBUG_DRYRUN (1<<3) // repetier-firmware #define DEBUG_COMMUNICATION (1<<4) // repetier-firmware
For firmware that supports ethernet and web interfaces M111 S9
will turn web debug information on without changing any other debug settings, and M111 S8
will turn it off. Web debugging usually means that HTTP requests will be echoed to the USB interface, as will the responses.
M112: Emergency Stop
??? | No | No | Yes | No | Yes | Yes | ??? |
- Example
M112
Any moves in progress are immediately terminated, then RepRap shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M0
and M1
M113: Set Extruder PWM
??? | No | No | Yes | No | No | No | ??? |
- Example
M113
M113 S0.7
it causes the PWM to be set to the S
value (70% in this instance). M113 S0
turns the extruder off, until an M113
command other than M113 S0
is sent.
M114: Get Current Position
- Example
M114
- Parameters
Pnnn
Electronics type1- Examples
M115 M115 P2
sample data from firmware:
This M115
code is inconsistently implemented, and should not be relied upon to exist, or output correctly in all cases. An initial implementation was committed to svn for the FiveD Reprap firmware on 11 Oct 2010. Work to more formally define protocol versions is currently (October 2010) being discussed. See M115_Keywords for one draft set of keywords and their meanings. See the M408
command for a more comprehensive report on machine capabilities supported by RepRapFirmware.
- Notes
1This parameter is supported only in RepRapFirmware and can be used tell the firmware about the hardware on which it is running. If the P
parameter is present then the integer argument specifies the hardware being used. The following are currently supported:
M115 P0 Automatic board type selection if supported, or default if not M115 P1 Duet 0.6 M115 P2 Duet 0.7 M115 P3 Duet 0.85
M116: Wait
No | Yes | Yes | No | ??? | ??? | No | Yes | |
- Parameters
Pnnn
Tool numberHnnn
Heater numberCnnn
Chamber number- Examples
M116 M116 P1
Wait for all temperatures and other slowly-changing variables to arrive at their set values if no parameters are specified. See also M109
- Notes
M117: Get Zero Position
No | No | No | No | ??? | ??? | No | see M70 | |
- Example
M117
M117: Display Message
Yes | Yes | Yes | Yes | ??? | ??? | Yes | No | |
- Example
M117 Hello World
M118: Echo message on host
Yes:1.1.4 | No | No | No | ??? | ??? | No | ??? | |
??? | No | No | No | No | No | No | ??? |
Use this code to print a visible message to the host console, preceded by 'echo:'.
- Example
M118 Color changing to blue
M118: Negotiate Features
- Example
M118 P42
This M-code is for future proofing. NO firmware or hostware supports this at the moment. It is used in conjunction with M115
's FEATURES keyword.
M119: Get Endstop Status
- Example
M119
In redeem, M119
can also be used to invert end stops.
- Example
M119 X1 1
This will invert end stop X1 (Inverted means switch is connected in Normally Open state (NO))
M120: Push
No | Yes | No | Yes | ??? | ??? | No | ??? | |
- Example
M120
- Current feedrate, and
- Whether moves (and separately extrusion) are relative or absolute
- Current feedrate
- Extruder positions
M121: Pop
- Example
M121
M122: Diagnose
No | Yes | No | No | ??? | ??? | No | ??? | |
- Example
M122
Sending an M122
causes the RepRap to transmit diagnostic information, for eaxmple via a USB serial link.
M123: Tachometer value
Sending an M123
causes the RepRap to transmit filament tachometer values from all extruders.
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
Yes | No | No | No | ??? | ??? | Yes | Yes | |
- Example
M126 P500
M126 in MakerBot
- Example
M126 T0
M127: Close Valve
- Example
M127 P400
M127 in MakerBot
- Example
M127 T0
M128: Extruder Pressure PWM
- Example
M128 S255
PWM value to control internal extruder pressure. S255
is full pressure.
M129: Extruder pressure off
- Example
M129 P100
M130: Set PID P value
see M301 | No | No | see M301 | ??? | ??? | see M301 | ??? | |
??? | No | No | No | No | see M301 | Yes | ??? |
- Parameters
Pnnn
heater numberSnnn
proportional (Kp)- Example
M130 P0 S8.0 ; Sets heater 0 P factor to 8.0
M131: Set PID I value
- Parameters
Pnnn
heater numberSnnn
integral (Ki)- Example
M131 P1 S0.5 ; Sets heater 1 I factor to 0.5
M132: Set PID D value
see M301 | see M301 | No | See M301 | ??? | ??? | see M301 | Yes | |
- Parameters
Pnnn
heater numberSnnn
derivative (Kd)- Example
M132 P0 S24 ; Sets heater 0 D factor to 24.0
M132 in MakerBot
- Example
M132 X Y Z A B
M133: Set PID I limit value
see M301 | No | No | No | ??? | ??? | see M301 | Yes | |
- Parameters
Pnnn
heater numberSnnn
integral limit (Ki)- Example
M133 P1 S264 ; Sets heater 1 I limit value to 264
M133 in MakerBot
- Example
M133 T0 P500
Instruct the machine to wait for the toolhead to reach its target temperature. T is the extruder to wait for. P if present, sets the time limit.
No | see M500 | No | See M504 | ??? | ??? | No | Yes | |
- Example
M134
M134 in MakerBot
- Example
M134 T0 P500
M135: Set PID sample interval
No | Yes | No | No | ??? | ??? | No | Yes | |
- Parameters
Snnn
Heat sample time in seconds- Example
M135 S300
M135 in MakerBot
- Example
M135 T0
No | see M301 | No | No | ??? | ??? | No | ??? | |
??? | No | No | No | No | No | Debug | ??? |
- Example
M136 P1 ; print heater 0 PID parameters to host
??? | Yes | No | Yes | Yes | Yes | Yes | ??? |
- Parameters
Snnn
Target temperatureHnnn
Heater number1- Example
M140 S55
Set the temperature of the build bed to 55oC and return control to the host immediately (i.e. before that temperature has been reached by the bed). There is an optional R field that sets the bed standby temperature: M140 S65 R40
RepRapFirmware allows the bed heater to be switched off if the absolute negative temperature (-273.15) is passed as target temperature. In this case the current bed temperature is not affected1:
M140 S-273.15
No | Yes | No | No | ??? | ??? | Yes | ??? | |
??? | No | No | No | Yes | No | uses M104 | ??? |
- Parameters
Snnn
Heater number1- Examples
M141 S30 M141 H0
- Notes
M142: Holding Pressure
- Example
M142 S1
M143: Maximum heater temperature
- Parameters
H
Heater number (RepRapFirmware 1.17 and later, default 1 which is normally the first hot end)S
Maximum temperature- Examples
M143 S275 ; set the maximum temperature of the hot-end to 275°C M143 H0 S125 ; set the maximum bed temperature to 125C
The default maximum temperature for all heaters was 300°C prior to RepRapFirmware version 1.13, and 262°C from 1.13 onwards. From RepRapFirmware 1.17 onwards, the default maximum temperatures are 262C for extruders and 125C for the bed.
When the temperature of the heater exceeds this value, countermeasures will be taken.
M144: Bed Standby
- Example
M144
Switch the bed to its standby temperature. M140
turns it back to its active temperature; no need for any arguments for that use of M140
M146: Set Chamber Humidity
- Parameters
Rnnn
Relative humidity in percent- Example
M146 R60
M149: Set temperature units
- Parameters
C
Flag to treat temperature as degrees CelsiusK
Flag to treat temperature as Kelvin- Example
M149 K
It affects the S
or R
values in the codes M104
, M109
, M140
, M141
, M143
, M190
and G10.
The default is M149 C
M150: Set display color
- Parameters
Rnnn
redUnnn
greenBnnn
blue- Example
M150 R255 U128 B192
Set BlinkM Color via I2C. Range for values: 0-255
M155: Automatically send temperatures
Yes: 1.1.0 | No | Yes | No | ??? | ??? | Yes | ??? | |
- Parameters
Snnn
enable sending temperatures = 1, disable = 0- Example
M155 S1
Hosts normally monitor printer temperatures by sending M105
every x seconds. This not only adds traffic, but also only works while printer is not blocked by waiting commands. So frequency more depends on frequency you can send new commands and creates extra traffic. As a solution, firmware can be told to automatically send temperatures every second. This function is disabled by default for best compatibility with existing hosts. To indicate the availability of this function, M115
will add an extra line:
Cap:AUTOREPORT_TEMP:1
so hosts know about the presence of the function.
- Example
M160 S4
This command has been superseded by the tool definition command M563
(see below).
M160 S4 G1 X90.6 Y13.8 E2.24:2.24:2.24:15.89 G1 X70.6 E0:0:0:42.4 G1 E42.4:0:0:0
Yes: RC7 | Use M567 | Yes: 0.92 | No | ??? | ??? | No | ??? | |
- Parameters
Snnn
extruder numberPnnn
weight
See Repetier Color Mixing for more informations.
M164: Store weights
Yes: RC7 | No | Yes: 0.92 | No | ??? | ??? | No | ??? | |
- Parameters
Snnn
virtual extruder numberPnnn
store to eeprom (P0 = no, P1 = yes)
M165: Set multiple mix weights
Yes: RC7 | No | No: | No | ??? | ??? | No | ??? | |
- Parameters
A B C D H I
A[factor]
Mix factor for extruder stepper 1B[factor]
Mix factor for extruder stepper 2C[factor]
Mix factor for extruder stepper 3D[factor]
Mix factor for extruder stepper 4H[factor]
Mix factor for extruder stepper 5I[factor]
Mix factor for extruder stepper 6
- Set multiple mix factors for a mixing extruder.
- Factors that are left out will be set to 0.
- All factors together must add up to 1.0.
??? | Yes | No | No | Yes | Yes | See M116 | ??? |
- Parameters
Snnn
M190 S60
No | 1.17 and later | No | No | ??? | ??? | Yes | ??? | |
??? | No | No | No | Yes | No | No | ??? |
- Example
M191 P60
In MK4duo:
- Parameters
Snnn
M191 S60
M200: Set filament diameter
Yes | 1.19 and later | Yes | Yes | ??? | ??? | Yes | ??? | |
RepRapFirmware:
- Parameters
- Daaa:bbb:ccc... Sets filament diameter to aaa for extruder 0, bbb for extruder 1 and so on. If any of aaa, bbb etc. are zero then volumetric extrusion is disabled for that extruder.
- Daaa Sets filament diameter (or disables volumetric extrusion) for all extruders
- Examples
- M200 D0 ; disable volumetric extrusion on all extruders
- M200 D1.75 ; set al extruder filament diameters to 1.75mm
- M200 D1.75:3.0:1.75 ; set extruder 0 to 1.75mm, extruder 1 to 3.0mm and all remaining extruders to 1.75mm
Volumetric extrusion is an option you can set in some slicers whereby all extrusion amounts are specified in mm3 (cubic millimetres) of filament instead of mm of filament. This makes the gcode independent of the filament diameter, potentially allowing the same gcode to run on different printers. The purpose of the M200 command is to inform the firmware that the gcode input files have been sliced for volumetric extrusion, and to provide the filament diameter so that the firmware can adjust the requested extrusion amount accordingly.
Sending M200 without parameters reports the current volumetric extrusion state and (where appropriate) filament diameter for each extruder.
Note that if you use slicer-commanded retraction, the retraction amounts must be specified in mm3 too. If instead you use firmware retraction, then the firmware retraction amounts specified using the M207 command are still interpreted as mm.
Other firmwares:
M200 Dm.mmm
sets the filament diameter to m.mmm millimeters. It is used with 'volumetric calibration' and G-code generated for an ideal 1.128mm diameter filament, which has a volume of 1mm^3 per millimeter. The intention is to be able to generate filament-independent g-code. (See Triffid_Hunter's_Calibration_Guide#Optional:_Switch_to_volumetric_E_units and http://wooden-mendel.blogspot.com/2011/09/volumetric-stage-two.html for more information.)
M200 D0
or M200 D1.128
; reset E multiplier to 1, since sqrt(1 / pi) * 2 = 1.128
- Parameters
Xnnn
Acceleration for X axisYnnn
Acceleration for Y axisZnnn
Acceleration for Z axisEnnn
Acceleration for extruder drives- Example
M201 X1000 Y1000 Z100 E2000
RepRapFirmware expects these values to be in mm/s².
??? | ??? | No | No | No | ??? | No | ??? |
Set max travel acceleration in units/s^2 for travel moves (M202 X1000 Y1000
). Unused in Marlin!!
M203: Set maximum feedrate
- Parameters
Xnnn
Maximum feedrate for X axisYnnn
Maximum feedrate for Y axisZnnn
Maximum feedrate for Z axisEnnn
Maximum feedrate for extruder drives- Example
M203 X6000 Y6000 Z300 E10000
Sets the maximum feedrates that your machine can do in mm/min (Marlin uses mm/sec).
M203 Repetier
Set temperature monitor to Sx
Yes | 1.18 and later | Yes | Yes | ??? | ??? | Yes | ??? | |
??? | Yes | No | No | No | ??? | No | ??? |
- Parameters (RepRapFimware)
Pnnn
Acceleration for printing movesTnnn
Acceleration for travel moves- Example
M204 P500 T2000
Use M201
to set per-axis accelerations and extruder accelerations. RepRapFirmware applies the M204
accelerations to the move as a whole, and also applies the limits set by M201
to each axis and extruder.
Other firmwares:
S normal moves T filament only moves (M204 S3000 T7000) im mm/sec^2 also sets minimum segment time in ms (B20000) to prevent buffer underruns and M20
minimum feedrate
Marlin notes: After Mar11-2015, the M204
options have changed in Marlin:
P = Printing moves
The command M204 P800 T3000 R9000
sets the acceleration for printing movements to 800mm/s^2, for travels to 3000mm/s^2 and for retracts to 9000mm/s^2.
M204 Repetier
- Usage
M204 X[Kp] Y[Ki] Z[Kd]
M205: Advanced settings
Yes | Use M566 | Yes | Yes | ??? | ??? | Yes | ??? | |
- Sprinter / Marlin
- Minimum travel speed =
S[printing]
T[travel]
B[min segment time] X[max XY jerk] Z[max Z jerk] E[max E jerk]
- Sprinter / Marlin Example
M205 X30 Z5 ; Set X/Y Jerk to 30mm/s, Z jerk to 5mm/s
Smoothieware uses a different algorithm: [1]
- X[xy junction deviation] Z[z junction deviation] S[minimum planner speed].
- Z junction deviation only applies to z only moves
- 0 disables junction deviation for Z
- -1 uses global junction deviation
- Smoothie example
M205 X0.05 ; set X/Y Junction Deviation
M205 Repetier
Output EEPROM settings.
M206: Offset axes
Yes | Yes | No | Yes | ??? | ??? | Yes | ??? | |
- Parameters
Xnnn
X axis offsetYnnn
Y axis offsetZnnn
Z axis offset- Example
M206 X10.0 Y10.0 Z-0.4
The values specified are added to the endstop position when the axes are referenced. The same can be achieved with a G92
right after homing (G28
, G161
With Marlin firmware, this value can be saved to EEPROM using the M500
command.
A similar command is G10
, aligning these two is subject to discussion.
M206 in Repetier: Set eeprom value
- Example
M206 T3 P39 X19.9
Set Jerk to 19.9
No | No | ??? | No | ??? | ??? | No | ??? | |
- Example
M207
M207: Set retract length
- Parameters
Snnn
positive length to retract, in mmRnnn
positive or negative additional length to un-retract, in mm (RepRapFirmware only)Fnnn
retraction feedrate, in mm/minTnnn
feedrate for un-retraction if different from retraction, mm/min (RepRapFirmware 1.16 and later only)Znnn
additional zlift/hop- Example
M207 S4.0 F2400 Z0.075
Sets the retract length used by the G10
and G11
commands, stays in mm regardless of M200
setting
M208: Set axis max travel
- Parameters
Snnn
Whether to set the axis minimum1Xnnn
X axis limitYnnn
Y axis limitZnnn
Z axis limit- Example
M208 X250 Y210 Z180
RepRapPro's version of Marlin uses M208
this way. Send M503
to see the current values. On Marlin, the value can be saved to EEPROM using the M500
command.
- Notes
1With RepRapFirmware on a Cartesian printer, you can also use this command to specify software limits for axis travel in the negative direction, by adding parameter S1. The axis limits you set are also the positions assumed when an endstop is triggered.
M208 X200 Y200 Z90; set axis maxima M208 X-5 Y0 Z0 S1 ; set axis minimum
M208: Set unretract length
Yes | See M207 | No | Yes | ??? | ??? | Yes | ??? | |
- Parameters
Snnn
positive length surplus to theM207 Snnn
, in mmFnnn
feedrate, in mm/sec
Yes | No | Yes | No | ??? | ??? | Yes | No | |
- Example
M209 S1
This boolean value S 1=true or 0=false enables automatic retract detect if the slicer did not support G10
/G11
: every normal extrude-only move will be classified as retract depending on the direction.
M210: Set homing feedrates
- Example
M210 X1000 Y1500
No | Use M564 | No | No | ??? | ??? | No | ??? | |
- Example
M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
- Example
M211 X0 S1
Enables X min endstop
- Example
M211
Yes* | Use G31 | No | No | ??? | ??? | Yes | ??? | |
- Example
M212 Z-0.2
PrintrBot suggests that the user make minor (0.1-0.2) adjustments between attempts and immediately executes M500
& M501
after setting this.
M218: Set Hotend Offset
Yes | Use G10 | No | No | ??? | ??? | Yes | ??? | |
- Example
M218 T1 X50 Y0.5
- Parameters
Snnn
Speed factor override percentage (0..100 or higher)- Example
M220 S80
- Parameters
Snnn
Extrude factor override percentage (0..100 or higher), default 100%Dnnn
Extruder drive number (RepRapFirmware only), default 0- Example
M221 S70 M221 S95 D1
Sets extrude factor override percentage. In the case of RepRapFirmware, sets the extrusion factor percentage for the specified extruder drive only.
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
??? | No | Yes | No | Yes | No | No | ??? |
- Example
M226
Initiates a pause in the same way as if the pause button is pressed. That is, program execution is stopped and the printer waits for user interaction. This matches the behaviour of M1
in the NIST RS274NGC G-code standard and M0
in Marlin firmware.
M226: Wait for pin state
Yes | see M577 | Yes | No | ??? | ??? | Yes | ??? | |
- Parameters
Pnnn
pin numberSnnn
pin state- Example
M226 P2 S1
- Example
M227 P1600 S1600
P and S are steps.
"Reverse and Prime" means, the extruder filament is retracted some distance when not in use and pushed forward the same amount before going into use again. This shall help to prevent drooling of the extruder nozzle. Teacup firmware implements this with M101
/M103
- Example
M228
See also M227
- Example
M229 P1.0 S1.0
P
and S
are extruder screw rotations. See also M227
- Example
M230 S1
S1
Disable wait for temperature change
S0
Enable wait for temperature change
M231: Set OPS parameter
M231 S[OPS_MODE] X[Min_Distance] Y[Retract] Z[Backslash] F[RetractMove]
M240: Trigger camera
- Example
M240
Triggers a camera to take a photograph. (Add to your per-layer GCode.)
??? | No | No | No | No | No | Debug: Echo off | ??? |
- Example
M240
??? | No | No | No | No | No | Debug: Echo on | ??? |
- Example
M241
M245: Start cooler
- Example
M245
M246: Stop cooler
- Example
M246
M250: Set LCD contrast
Yes | No | No | No | ??? | ??? | Yes | No | |
- Example
M250 C20
- Examples
M251 S0 ; Reset M251 S1 ; Print M251 S2 ; Store to Z length (also EEPROM if enabled)
(This is a Repetier-Firmware only feature.)
M260: i2c Send Data
Yes: 1.1.0 | No | No | No | ??? | ??? | Yes | No | |
Buffer and send data over the i2c bus. Use A
to set the address from 0-127. Add up to 32 bytes to the buffer with each B
. Send and reset the buffer with S
- Examples
M260 A5 B65 S ; Send 'A' to Address 5 now M260 A0 ; Set address to 0 (broadcast) M260 B77 ; M M260 B97 ; a M260 B114 ; r M260 B108 ; l M260 B105 ; i M260 B110 ; n M260 S1 ; Send the current buffer
M261: i2c Request Data
Request data from an i2c slave device. This command simply relays the received data to the host.
- Example
M261 A99 B5 ; Request 5 bytes from Address 99
Both M260
and M261
are commands demonstrating use of the i2c bus (TWIBus class) in Marlin Firmware. Developers and vendors can make Marlin an i2c master device by enabling EXPERIMENTAL_I2CBUS
, and Marlin can act as a slave device by setting I2C_SLAVE_ADDRESS
from 8-127. This class can be used to divide up processing responsibilities between multiple instances of Marlin running on multiple boards. For example, one board might control a Z axis with 4 independent steppers to create a self-leveling system, or a second board could drive the graphical display while the first board handles printing.
M280: Set servo position
Yes | 1.16 and later | Use M340 | No | ??? | ??? | Yes | ??? | |
??? | No | No | No | Yes | Yes | No | ??? |
Set servo position absolute.
- Parameters
Pnnn
Servo indexSnnn
Angle or microsecondsI1
Invert polarity (RepRapFirmware only)- Example
M280 P1 S50
Marlin and RepRapFirmware treat S
values below 200 as angles, and 200 or greater as the pulse width in microseconds.
In RepRapFirmware, the servo index is the same as the pin number for the M42
command. See https://duet3d.com/wiki/Using_servos_and_controlling_unused_I/O_pins for details.
RepRapFirmware supports the optional I1 parameter, which if present causes the polarity of the servo pulses to be inverted compared to normal for that output pin. The I
parameter is not remembered between M280
commands (unlike the I
parameter in M106
commands), so if you need inverted polarity then you must include I1 in every M280
command you send.
Use M307 H# A-1 C-1 D-1 before using these pins | ||
3 | PC23_PWML6 | 21 |
4 | PC22_PWML5 | 22 |
5 | PC21_PWML4 | 23 |
On the Duet 0.6, pin 18 is controlled by heater 2. On the 0.8.5, pin 18 is controlled by heater 6, but is also shared with fan1. In order to use this pin, the fan must be disabled (M106 P1 I-1). See Using servos and controlling unused I/O pins
M290: Baby stepping
No | 1.18 and later | No | No | ??? | ??? | No | No | |
- Parameters
Snnn
Amount to baby step in mm. Positive values raise the head, negative values lower it.- Example
M290 S0.05
This command tells the printer to apply the specified additional offset to the Z coordinate for all future moves, and to apply the offset to moves that have already been queued if this case be done. Baby stepping is cumulative, for example after M290 S0.1
followed by M290 S-0.02
, an offset of 0.08mm is used.
M290 with no parameters reports the accumulated baby stepping offset.
The baby stepping offset is reset to zero when the printer is homed or the bed is probed.
M291: Display message and optionally wait for response
No | 1.19 and later | No | No | ??? | ??? | No | No | |
- Parameters
P"message"
The message to display, which must be enclosed in double quotation marks. If the message itself contains a double quotation mark, use two double quotation marks to represent it.R"message"
Optional title for the message box. Must be enclosed in double quotation marks too.Sn
Message box mode (defaults to 1)Tn
Timeout in seconds, only legal for S=0 and S=1. The message will be cancelled after this amount of time, if the user does not cancel it before then. A zero or negative value means that the message does not time out (it may still be cancelled by the user). In RepRapFirmware, the default timeout for messages that do not require acknowledgement is 10 seconds.Zn
0 = no special action, 1 = display Z jog buttons alongside the message to allow the user to adjust the height of the print head- Examples
M291 P"Please do something and press OK when done" S2 M291 P"This message will be closed after 10 seconds" T10
This command provides a more flexible alternative to M117, in particular messages that time out, messages that suspend execution until the user acknowledges them, and messages that allow the user to adjust the height of the print head before acknowledging them.
Allowed message box modes include:
0. No buttons are displayed (non-blocking) 1. Only "Close" is displayed (non-blocking) 2. Only "OK" is displayed (blocking, send M292 to resume the execution) 3. "OK" and "Cancel" are displayed (blocking, send M292 to resume the execution or M292 P1 to cancel the operation in progress)
M292: Acknowledge message
- Parameters
Pn
Whether the current operation shall be cancelled. Only legal if M291 was called with S=3 (optional)
This command is sent by the user interface when the user acknowledges a message that was displayed because of a M291 command with parameter S=2 or S=3.
M300: Play beep sound
Yes | Yes | Yes | No | ??? | ??? | Yes | Yes | |
- Parameters
Snnn
frequency in HzPnnn
duration in milliseconds- Example
M300 S300 P1000
If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
M301: Set PID parameters
??? | Yes | No | No | No | Yes | See M130-M133 | ??? |
- Parameters
Hnnn
heater number (Smoothie uses 'S', Redeem uses 'E')Pnnn
proportional (Kp)Innn
integral (Ki)Dnnn
derivative (Kd)- Examples
M301 H1 P1 I2 D3 ; Marlin M301 H1 P1 I2 D3 T0.2 B20 W127 S0.8 ; RepRapFirmware (v1.09 onwards), Duet-dc42 M301 S0 P30 I10 D10 ; Smoothie M301 E0 P30 I10 D10 ; Redeem (E = Extruder, -1=Bed, 0=E, 1=H, 2=A, 3=B, 4=C, default = 0)
Marlin
Hot end only; see M304
for bed PID. H is the heater number, default 1 (i.e. first extruder heater).
H
Is the heater number, and is compulsory. H0 is the bed, H1 is the first hot end, H2 the second etc. -
P
Interprets a negative P term as indicating that bang-bang control should be used instead of PID (not recommended for the hot end, but OK for the bed heater). -
I
Integral value -
D
Derivative value -
T
Is the approximate additional PWM (on a scale of 0 to 255) needed to maintain temperature, per degree C above room temperature. Used to preset the I-accumulator when switching from heater fully on/off to PID. -
S
PWM scaling factor, to allow for variation in heater power and supply voltage. Is designed to allow a correction to be made for a change in heater power and/or power supply voltage without having to change all the other parameters. For example, an S factor of 0.8 means that the final output of the PID controller should be scaled to 0.8 times the standard value, which would compensate for a heater that is 25% more powerful than the standard one or a supply voltage that is 12.5% higher than standard. -
W
Wind-up. Sets the maximum value of I-term, must be high enough to reach 245C for ABS printing. -
B
PID Band. Errors larger than this cause heater to be on or off.
An example using all of these would be:
M301 H1 P20 I0.5 D100 T0.4 S1 W180 B30
Smoothie
S0<code> is 0 for the hotend, and 1 for the bed, other numbers may apply to your configuration, depending on the order in which you declare temperature control modules.
Other implementations
W: Wind-up. Sets the maximum value of I-term, so it does not overwhelm other PID values, and the heater stays on. (Check firmware support - Sprinter, Marlin?)
- Example
M301 W125
Teacup
See <code>M130, M131
, M132
, M133
for Teacup's codes for setting the PID parameters.
M302: Allow cold extrudes
Yes | Yes1 | Yes: 0.92 | No | ??? | ??? | Yes | ??? | |
- Parameters
Snnn
Cold extrude minimum temperaturePnnn
Cold extrude allow state (RepRapFirmware)
- Examples (RepRapFirmwre)
M302 ; Report current state M302 P1 ; Allow cold extrusion
- Examples (Others)
M302 S0 ; Allow extrusion at any temperature M302 S170 ; Allow extrusion above 170
This tells the printer to allow movement of the extruder motor above a certain temperature, or if disabled, to allow extruder movement when the hotend is below a safe printing temperature.
- Notes
1RepRapFirmware uses the P[0|1]
parameter instead of S[temperature]
, and for M302
with no parameters it will report the current cold extrusion state.
M303: Run PID tuning
Yes | 1.15 and later | Yes | Yes | ??? | ??? | Yes | ??? | |
Hot end usage:
M303 S<temperature> C<cycles>
Bed usage (repetier, not sure whether cycles work here):
M303 P1 S<temperature>
Bed usage (others):
- Example
M303 C8 S175
Smoothie's syntax, where E0
is the first temperature control module (usually the hot end) and E1
is the second temperature control module (usually the bed):
M303 E0 S190
In RepRapFirmware, this command computes the process model parameters (see M307
), which are in turn used to calculate the PID constants. H is the heater number, P is the PWM to use (default 0.5), and S is the maximum allowable temperature (default 225). Tuning is performed asynchronously. Run M303
with no parameters to see the current tuning state or the last tuning result.
- Example
M303 H1 P0.4 S240 ; tune heater 1 using 40% PWM, quit if temperature exceeds 240C
- Notes
In Marlin Firmware you can add the U1
parameter to apply the PID results to current settings upon completion.
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
Yes | Yes | ??? | see M301 | ??? | ??? | Yes | ??? | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
- Parameters
Pnnn
integral (Ki)Dnnn
M304 P1 I2 D3 ; set kP=3, kI=2, kD=3 M304 P1 I2 D3 T0.7 B20 W127 ; RepRapFirmware M304 ; Report parameters
Sets Proportional, Integral and Derivative values for bed. RepRapFirmware interprets a negative P term as indicating that bang-bang control should be used instead of PID. In RepRapFirmware, this command is identical to M301
except that the H
parameter (heater number) defaults to zero.
In the RepRapPro version of Marlin ( https://github.com/reprappro/Marlin ) M304
is used to set thermistor values (as M305
is in later firmwares). RRP Marlin calculates temperatures on the fly, rather than using a temperature table. M304
Sets the parameters for temperature measurement.
- Example
M304 H1 B4200 R4800 T100000
This tells the firmware that for heater 1 (H
parameter: 0 = heated bed, H = first extruder), the thermistor beta (B
parameter) is 4200, the thermistor series resistance (R
parameter) is 4.8Kohms, the thermistor 25C resistance (T
parameter) is 100Kohms. All parameters other than H are optional. If only the H
parameter is given, the currently-used values are displayed. They are also displayed within the response to M503
No | Yes | ??? | Yes | ??? | ??? | No | ??? | |
- Parameters
Pnnn
Heater number, or virtual heater numberS"name"
Heater name (optional, RepRapFirmware only)Tnnn
(for thermistor sensors) Thermistor resistance at 25oCT"c"
(for MAX31856-based thermocouple sensors) The thermistor type letter, default KBnnn
Beta value, or the reciprocal of the Steinhart-Hart thermistor model B coefficientCnnn
Steinhart-Hart C coefficient (RepRapFirmware 1.17 and later), default 0Rnnn
Series resistor valueLnnn
ADC low offset correction, default 0Hnnn
ADC high offset correction, default 0Xnnn
Heater ADC channel, or thermocouple or PT100 or current loop adapter channel, defaults to the same value as theP
parameterFnn
(where nn is 50 or 60) If the sensor interface uses a MAX31856 thermocouple chip or MAX31865 PT100 chip, this is the local mains frequency. Readings will be timed to optimise rejection of interference at this frequency.- Example
M305 P1 T100000 R1000 B4200
Sets the parameters for temperature measurement. The example above tells the firmware that for heater 1 (P
parameter: 0 = heated bed, 1 = first extruder) the thermistor 25C resistance (T
parameter) is 100Kohms, the thermistor series resistance (R
parameter) is 1Kohms, the thermistor beta (B
parameter) is 4200. All parameters other than P are optional. If only the P
parameter is given, the existing values are displayed.
- Example
M305 P1 T100000 R1000 B4200 H14 L-11 X2
The H correction affects the reading at high ADC input voltages, so it has the greatest effect at low temperatures. The L correction affects the reading at low input voltages, which correspond to high temperatures.
The X
parameter tells the firmware to use the thermistor input corresponding to a different heating channel. RepRapFirmware also allow an external SPI thermocouple interface (such as the MAX31855) or PT100 interface (MAX31865) to be configured. MAX31855 thermocouple channels are numbered from 100, MAX31856 thermocouple channels are numbered from 150, PT100 channels from 200 and current loop channels from 300. Channel 1000 is the CPU temperature indication, 1001 is the temperature of the hottest stepper motor driver on the main board, and 1001 is the temperature of the hottest drivers on the expansion board.
In the above example, the ADC high end correction (H
parameter) is 14, the ADC low end correction (L
parameter) is -11, and thermistor input #2 is used to measure the temperature of heater #1.
M306: Set home offset calculated from toolhead position
No | No | ??? | Yes | ??? | ??? | No | ??? | |
- Example
M306 Z0
The user would typically place the toolhead at the zero point of the axis and issue the M306
command.
This value can be saved to EEPROM using the M500
command (as M206
value).
Implemented in Smoothieware
M307: Set or report heating process parameters
No | 1.15 and later | No | No | ??? | ??? | No | ??? | |
- Parameters
Hn
Heater number (0 is usually the bed heater)Annn
gAin, expressed as ultimate temperature rise obtained in degC divided by the PWM fraction. For example, if G=180 then at 50% PWM the ultimate temperature rise would be 90C.Cnnn
dominant time Constant of the heating process in secondsDnnn
Dead time in seconds- Two additional parameters help control the heating process
Bn
selects Bang-bang control instead of PID if non-zero. Default at power-up is 0 for extruder heaters, 1 for the bed heater.Snnn
maximum PWM to be used used with this heater on a scale of 0 to 1. Default 1.0.- Examples
M307 H0 ; report the process parameters for heater 0 M307 H1 A346.2 C140 D5.3 B0 S0.8 ; set process parameters for heater 1, use PID, and limit heater 1 PWM to 80%
Each heater and its corresponding load may be approximated as a first order process with dead time, which is characterised by the gain, time constant and dead time parameters. The model can used to calculate optimum PID parameters (including using different values for the heating or cooling phase and the steady state phase), to better detect heater faults, and to calculate feed-forward terms to better respond to changes in the load. Normally these model parameters are found by auto tuning - see M303
RepRapFirmware 1.16 and later allow the PID controller for a heater to be disabled by setting the A
, C
, and D
parameters to -1. This frees up the corresponding heater control pin for use as a general purpose I/O pin.
M320: Activate autolevel (Repetier)
No | No | Yes | No | ??? | ??? | No | ??? | |
- Usage
M320
M320 S1
- Parameters
Snnn
if greater than 0, activate and store persistently in EEPROM- Examples
M320 ; temporarily activate auto leveling M320 S1 ; permanently activate auto leveling
Parameter Snnn
is optional.
(Repetier only)
M321: Deactivate autolevel (Repetier)
- Usage
M321
M321 S1
- Parameters
Snnn
if greater than 0, deactivate and store persistently in EEPROM- Examples
M321 ; temporarily deactivate auto leveling M321 S1 ; permanently deactivate auto leveling
Parameter Snnn
is optional.
(Repetier only)
M322: Reset autolevel matrix (Repetier)
- Usage
M322
M322 S1
- Parameters
Snnn
if greater than 0, also reset the matrix values saved EEPROM- Examples
M322 ; temporarily reset auto level matrix M322 S1 ; permanently reset auto level matrix
Parameter Snnn
is optional.
(Repetier only)
M323: Distortion correction on/off (Repetier)
- Usage
M323
M323 Snnn
M323 Snnn Pnnn
- Parameters
Snnn
0 (disable correction) or 1 (enable correction)Pnnn
1 (store correction state persistently in EEPROM)- Examples
M323 ; Show if distortion correction is enabled M323 S0 ; Disable distortion correction temporarily M323 S1 P1 ; Enable distortion correction permanently
(Repetier only)
Controls distortion correction feature after having set it up using G33.
M340: Control the servos
M350: Set microstepping mode
Yes | Yes | Yes | No | ??? | ??? | Yes | ??? | |
??? | No | No | No | No | Yes | No | ??? |
Sets microstepping mode.
Warning: Steps per unit remains unchanged; except that in RepRapFirmware the steps/mm will be adjusted automatically.
- Usage
M350 Snn Xnn Ynn Znn Enn Bnn
- Parameters
- Not all parameters need to be used, but at least one should be used. As with other commands, RepRapFirmware reports the current settings if no parameters are used.
Snn
Set stepping mode for all drivers (not supported by RepRapFirmware)Xnn
Set stepping mode for the X axisYnn
Set stepping mode for the Y axisZnn
Set stepping mode for the Z axisEnn
Set stepping mode for Extruder 0 (for RepRapFirmware useEnn:nn:nn
etc. for multiple extruders)Bnn
Set stepping mode for Extruder 1 (not supported by RepRapFirmware, see above)Inn
Enable (nn=1) or disable (nn=0) microstep interpolation mode for the specified drivers, if they support it (RepRapFirmware only)- Modes (nn)
- 1 = full step
- 2 = half step
- 4 = quarter step
- 8 = 1/8 step
- 16 = 1/16 step
- 64 = 1/64 step
- 128 = 1/128 step
- 256 = 1/256 step
- Examples
M350 S16 ; reset all drivers to the default 1/16 micro-stepping - not supported by RepRapFirmware M350 Z1 ; set the Z-axis' driver to use full steps M350 E4 B4 ; set both extruders to use quarter steps - Marlin/Repetier M350 E4:4:4 ; set extruders 0-2 to use quarter steps - RepRapFirmware
Yes | No | No | No | ??? | ??? | Yes | ??? | |
- Example
M351
M355: Turn case lights on/off
Yes: 1.1.0 | No | Yes: 0.92.2 | No | ??? | ??? | No | ??? | |
??? | No | No | No | No | No | use M106 | ??? |
- Examples
M355 S1 ; Enable lights M355 S0 ; Disable lights M355 ; Report status
Every call or change over LCD menu sends a state change for connected hosting software like:
Case lights on Case lights off No case lights
No | No | Yes: 0.92.2 | No | ??? | ??? | No | ??? | |
- Target
- Example
M360
- Response
Config:Baudrate:250000 Config:InputBuffer:127 Config:NumExtruder:2 Config:MixingExtruder:0 Config:HeatedBed:0 Config:SDCard:1 Config:Fan:1 Config:LCD:1 Config:SoftwarePowerSwitch:1 Config:XHomeDir:-1 Config:YHomeDir:-1 Config:ZHomeDir:-1 Config:SupportG10G11:1 Config:SupportLocalFilamentchange:1 Config:CaseLights:0 Config:ZProbe:1 Config:Autolevel:0 Config:EEPROM:1 Config:PrintlineCache:24 Config:JerkXY:30.00 Config:JerkZ:0.30 Config:RetractionLength:3.00 Config:RetractionLongLength:13.00 Config:RetractionSpeed:40.00 Config:RetractionZLift:0.00 Config:RetractionUndoExtraLength:0.00 Config:RetractionUndoExtraLongLength:0.00 Config:RetractionUndoSpeed:0.00 Config:XMin:0.00 Config:YMin:0.00 Config:ZMin:0.00 Config:XMax:250.00 Config:YMax:150.00 Config:ZMax:90.00 Config:XSize:250.00 Config:YSize:150.00 Config:ZSize:90.00 Config:XPrintAccel:250.00 Config:YPrintAccel:250.00 Config:ZPrintAccel:100.00 Config:XTravelAccel:250.00 Config:YTravelAccel:250.00 Config:ZTravelAccel:100.00 Config:PrinterType:Cartesian Config:MaxBedTemp:120 Config:Extr.1:Jerk:50.00 Config:Extr.1:MaxSpeed:100.00 Config:Extr.1:Acceleration:10000.00 Config:Extr.1:Diameter:0.00 Config:Extr.1:MaxTemp:220 Config:Extr.2:Jerk:50.00 Config:Extr.2:MaxSpeed:100.00 Config:Extr.2:Acceleration:10000.00 Config:Extr.2:Diameter:0.00 Config:Extr.2:MaxTemp:220
Partial | No | No | Yes | ??? | ??? | Partial | ??? | |
??? | No | No | No | No | ??? | No | ??? |
Experimental | No | No | Yes | ??? | ??? | Experimental | ??? | |
The arms move into a position where the Theta steering arm is parallel to the top platform edge. The user then calibrates the position by moving the arms with the jog buttons in software like pronterface until it is perfectly parallel. Using M114
will then display the calibration offset that can then be programmed into the unit using M206
(Home offset) X represents Theta.
Smoothieware: M360 P0
will take the current position as parallel to the platform edge, and store the offset in the homing trim offset (M666) No further user interaction is needed.
Theta move to 90 degrees with platform edge. User calibrates by using jog arms to place exactly 90 degrees. Steps per degree can then be read out by using M114
, and programmed using M92
. X represents Theta. Program Y (Psi) to the same value initially. Remember to repeat M360
after adjusting steps per degree.
will accept the current position as 90deg to platform edge. New steps per angle is calculated and entered into memory (M92) No further user interaction is required, except to redo M360
Move arms to form a 90 degree angle between the inner and outer Psi arms. Calibrate by moving until angle is exactly 90 degree. Read out with M114
, and calibrate value into Home offset M206
. Psi is represented by Y.
Smoothieware: M364 P0
will accept the current position as 90deg between arms. The offset is stored as a trim offset (M666) and no further user interaction is required except to save all changes via M500
M365: SCARA scaling factor
M366: SCARA convert trim
No | No | No | Yes | ??? | ??? | No | ??? | |
No | Use M557 | No | Yes | ??? | ??? | No | ??? | |
- Usage
M370
M370 X[divisions] Y[divisions]
Without parameters is defaults to X5 Y5
(25 calibration points)
When specifying parameters, uneven numbers are recommended.
M374: Save calibration grid
No | 1.17 and later | No | Yes | ??? | ??? | No | ??? | |
Saves the calibration grid.
- Parameters
extension
(Smoothieware only) Extension of the grid filePfilename
(RepRapFirmware only) Name of the file to save toZ
(Smoothieware only) Also save theM206
Z homing offset into the grid file- Usage (Smoothieware)
M374 M374 <file extension> Z
- Usage (RepRapFirmware)
M374 M374 PMyAlternateHeightMap.csv
In Smoothieware, without parameters this saves the grid into the default grid file that gets loaded at boot. The optional parameter specifies the extension of the grid file - useful for special grid files such as for a special print surface like a removable print plate. Addition of Z will additionally save the M206 Z
homing offset into the grid file.
In RepRapFirmware, this saves the grid parameters and height map into the specified file, or the default file heightmap.csv
if no filename was specified. To load the height map automatically at startup, use command M375
in the config.g file.
Displays the bed level calibration matrix (Marlin), or loads the grid matrix file (Smoothieware and RepRapFirmware)
- Parameters
extension
(Smoothieware only)Pfilename
(RepRapFirmware only)- Usage
M375 M375 [file extension] ; (Smoothieware only) M375 PMyAlternateHeightMap.csv ; (RepRapFirmware only)
Without parameters loads default grid, and with specified extension or specified filename attempts to load the specified grid. If not available will not modify the current grid. In Smoothieware, if Z was saved with the grid file, it will load the saved Z with the grid.
M376: Set bed compensation taper
- Parameters
Hnnn
Height (mm) over which to taper off the bed compensation- Example
M376 H10
This command specifies that bed compensation should be tapered off over the specified height, so that no bed compensation is applied at and above that height. If H is zero or negative then no tapering is applied, so compensation is performed throughout the entire print.
If the firmware does not adjust the extrusion amount to compensate for the changing layer height while tapering is being applied, you will get under- or over-extrusion. Using a large taper height will reduce this effect. For example, if the taper height is 50 times the largest bed height error, then under- or over-extrusion will be limited to 2%.
M380: Activate solenoid
Yes | No | ??? | No | ??? | ??? | Yes | ??? | |
- Example
M380
M381: Disable all solenoids
- Example
M381
??? | Yes | No | No | Yes | ??? | use G4 | ??? |
- Example
M400
Finishes all current moves and and thus clears the buffer. That's identical to G4 P0
M401: Lower z-probe
Yes | 1.17 and later | ??? | No | ??? | ??? | Yes | ??? | |
- Example
M401
Lower z-probe if present. In RepRapFirmware this runs macro file sys/deployprobe.g.
M402: Raise z-probe
- Example
M402
Raise z-probe if present. In RepRapFirmware this runs macro file sys/retractprobe.g.
Yes | Yes | No | No | ??? | ??? | Yes | ??? | |
- Parameters
Nnnn
Filament width (in mm)Dnnn
Nozzle diameter (in mm)1- Examples
M404 N1.75 M404 N3.0 D1.0
Enter the nominal filament width (3mm, 1.75mm) or will display nominal filament width without parameters.
- Notes
1While Marlin only accepts the 'N' parameter, RepRapFirmware further allows to specify the nozzle diameter (in mm) via the 'D 'parameter. This value is used to properly detect the first layer height when files are parsed or a new print is being started.
M405: Filament Sensor on
- Example
M405
M406: Filament Sensor off
- Example
M406
- Example
M407
Displays measured filament diameter. In RepRapFirmware, M407
does the same as M404
- Parameters
Snnn
Response typeRnnn
Response sequence number- Example
M408 S0
Report a JSON-style response by specifying the desired type using the 'S' parameter.
The following response types are supported:
- Type 0 is a short-form response, similar to the response used by older versions of the web interface.
- Type 1 is like type 0 except that static values are also included.
- Type 2 is similar to the response provided by the web server for Duet Web Control.
- Type 3 is an extended version of type 2 which includes some additional parameters that aren't expected to change very frequently.
- Type 4 is an extended version of type 2 which may be used to poll for current printer statistics.
- Type 5 reports the current machine configuration.
Here is an example of a typical type 0 response:
{"status":"I","heaters":[25.0,29.0,28.3],"active":[-273.1,0.0,0.0],"standby":[-273.1,0.0,0.0],"hstat":[0,2,1],"pos":[-11.00,0.00,0.00],"extr":[0.0,0.0], "sfactor":100.00, "efactor":[100.00,100.00],"tool":1,"probe":"535","fanPercent":[75.0,0.0],"fanRPM":0,"homed":[0,0,0],"fraction_printed":0.572}
The response is set as a single line with a newline character at the end. The meaning of the fields is:
status: I=idle, P=printing from SD card, S=stopped (i.e. needs a reset), C=running config file (i.e starting up), A=paused, D=pausing, R=resuming from a pause, B=busy (e.g. running a macro), F=performing firmware update heaters: current heater temperatures, numbered as per the machine (typically, heater 0 is the bed) active: active temperatures of the heaters standby: standby temperatures of the heaters hstat: status of the heaters, 0=off, 1=standby, 2=active, 3=heater fault. Heater 0 is normally the bed heater, heaters 1, 2.. are the extruder heaters. pos: the X, Y and Z (and U, V, W if present) axis positions of the current tool (if a tool is selected), or of the print head reference point if no tool is selected extr: the positions of the extruders sfactor: the current speed factor (seeM220
command) efactor: the current extrusion factors (seeM221
command), one value per extruder tool: the selected tool number. A negative number typically means no tool selected. probe: the Z-probe reading fanPercent: the speeds of the controllable fans, in percent of maximum fanRPM: the print cooling fan RPM homed: the homed status of the X, Y and Z axes (and U, V, W if they exist), or towers on a delta. 0=axis has not been homed so position is not reliable, 1=axis has been homed so position is reliable. fraction_printed: the fraction of the file currently being printed that has been read and at least partially processed. message: the message to be displayed on the screen (only present if there is a message to display) timesLeft: an array of the estimated remaining print times (in seconds) calculated by different methods. These are currently based on the proportion of the file read, the proportion of the total filament consumed, and the proportion of the total layers already printed. Only present if a print from SD card is in progress. seq: the sequence number of the most recent non-trivial G-code response or error message. Only present if theR
parameter was provided and the current sequence number is greater than that. resp: the most recent non-trivial G-code response or error message. Only present if theR
parameter was provided and the current sequence number is greater.
The type 1 response comprises these fields plus some additional ones that do not generally change and therefore do not need to be fetched as often. The extra fields include:
myName: the name of the printer firmwareName: the name of the firmware, e.g. "RepRapFirmware", "Smoothieware" or "Repetier" geometry: one of "cartesian", "delta", "corexy, "corexz" etc. axes: the number of axes volumes: the number of SD card slots available numTools: the number of available tools numbered contiguously starting from 0
For a more detailed comparison of type 2 - 5, see RepRap_Firmware_Status_responses.
PanelDue currently uses only M408 S0
and M408 S1
M420: Set RGB Colors as PWM (MachineKit)
No | No | No | No | ??? | ??? | No | ??? | |
??? | No | No | No | Yes | ??? | No | ??? |
Usage: M420 R[Red PWM (0-255)] E[Green PWM (0-255)] B[Blue PWM (0-255)]
- Example
M420 R255 E255 B255
Set the color of your RGB LEDs that are connected to PWM-enabled pins. Note, the Green color is controlled by the <code>E value instead of the G value due to the G code being a primary code that cannot be overridden.
In Marlin M420
is Enable/Disable Mesh Leveling (with current values) S1=enable S0=disable
M420: Leveling On/Off/Fade (Marlin)
Enable/Disable Bed Leveling (using the current stored grid or mesh).
- Usage
M420 S[bool] Z[float]
- Examples
M420 S1 ; Enable compensation using current grid/mesh M420 Z10 ; Gradually reduce compensation until Z=10
Marlin 1.1.0 adds the Z
parameter to set the "fade" height. This requires the ENABLE_LEVELING_FADE_HEIGHT
option.
When the Z
fade height value is set non-zero, bed compensation will gradually reduce up to the given height, and cease completely above that height.
M421: Set a Mesh Bed Leveling Z coordinate
Yes | No | No | No | ??? | ??? | No | No | |
No | No | No | No | No | No | No | ??? |
Set a single Z coordinate in the Mesh, Bilinear or UBL Leveling grid. Requires MESH_BED_LEVELING
or AUTO_BED_LEVELING_BILINEAR
or AUTO_BED_LEVELING_UBL
I & J are the index for the X and Y axis respectively.
- Usage
M421 I[index] J[index] Z[float]
to set an absolute value to a mesh point
or
M421 I[index] J[index] Q[float]
to offset a mesh point by a specified value
M450: Report Printer Mode
No | 1.20 and later | Yes | No | ??? | ??? | No | ??? | |
- Usage
M450
- Example
> M450 > PrinterMode:FFF
Printers can be used for different task by exchanging the toolhead. Depending on the tool, a different behavior of some commands can be expected. This command reports the current working mode. Possible answers are:
- PrinterMode:FFF
- PrinterMode:Laser
- PrinterMode:CNC
M451: Select FFF Printer Mode
- Usage
M451
- Example
> M451 > PrinterMode:FFF
Switches to FFF mode for filament printing.
M452: Select Laser Printer Mode
- Usage
M452
- Example
> M452 > PrinterMode:Laser
Switches to laser mode. This mode enables handling of a laser pin and makes sure that the laser is only activated during G1
moves if laser was enabled or E is increasing. G0
moves should never enable the laser. M3
/M5
can be used to enable/disable the laser for moves.
M453: Select CNC Printer Mode
- Usage
M453
- Example
> M453 > PrinterMode:CNC
Switches to CNC mode. In this mode M3
/M4
/M5
control the pins defined for the milling device.
M460: Define temperature range for thermistor-controlled fan
No | Use M106 | Yes | No | ??? | ??? | No | ??? | |
- Usage
M460 X[minTemp] Y[maxTemp]
- Example
M460 X50 Y60
If the firmware has a thermistor controlled fan defined, you can set at which temperature the fan starts and from which temperature on it should run with maximum speed.
M500: Store parameters in EEPROM
Yes | Yes | Yes | Yes | ??? | ??? | Yes | ??? | |
- Example
M500
Save current parameters to EEPROM.
In Redeem any parameters set through G/M-codes which is different than what is read from the config files, are stored back to the local config. For instance setting stepper current and microstepping through M906
and M907
followed by M500
will update /etc/redeem/local.cfg.
M501: Read parameters from EEPROM
Yes | Yes | Yes | ??? | ??? | ??? | Yes | ??? | |
- Parameters
Snnn
Enable auto-save (only RepRapFirmware)
- Example
M501
Set the active parameters to those stored in the EEPROM. This is useful to revert parameters after experimenting with them.
RepRapFirmware versions prior to 1.17 allows "S1" to be passed, which forces parameters to be automatically saved to EEPROM when they are changed.
In RepRapFirmware 1.17 and later, the parameters are saved in file sys/config-override.g on the SD card.
M502: Revert to the default "factory settings."
- Example
M502
This command resets all tunable parameters to their default values, as set in the firmware. This doesn't reset any parameters stored in the EEPROM, so it must be followed with M500
if you want to do that.
