G-code
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications as well. See also on Wikipedia's G-code article.
There are a few different ways to prepare G-code for a printer. One method would be to use a slicing program such as Slic3r, Skeinforge or Cura. These programs import a CAD model, slice it into layers, and output the G-code required to print each layer. Slicers are the easiest way to go from a 3D model to a printed part, however the user sacrifices some flexibility when using them. Another option for G-code generation is to use a lower level library like mecode. Libraries like mecode give you precise control over the tool path, and thus are useful if you have a complex print that is not suitable for naive slicing. The final option is to just write the G-code yourself. This may be the best choice if you just need to run a few test lines while calibrating your printer.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years. This particular page is the master page for RepRap. Nowhere in here should the same code be used for two different things; there are always more numbers to use... The rule is: add your new code here, then implement it.
Unfortunately human nature being what it is, the best procedures aren't always followed, so some multiple uses of the same code exist. The rule which should be followed is that later appearances of a code on this page (later than the original use of a code), are deprecated and should be changed, unless there is a good technical reason (like the general G-Code standard) why a later instance should be preferred. Note that the key date is appearance here, not date of implementation.
- 1 Introduction
- 2 Fields
- 3 Case sensitivity
- 4 Quoted strings
- 5 Comments
- 6 Special fields
- 7 Checking
- 8 Buffering
- 9 G-commands
- 9.1 G0 & G1: Move
- 9.2 G2 & G3: Controlled Arc Move
- 9.3 G4: Dwell
- 9.4 G6: Direct Stepper Move
- 9.5 G10: Set tool Offset and/or workplace coordinates and/or tool temperatures
- 9.6 G10: Retract
- 9.7 G11: Unretract
- 9.8 G12: Clean Tool
- 9.9 G17..19: Plane Selection (CNC specific)
- 9.10 G20: Set Units to Inches
- 9.11 G21: Set Units to Millimeters
- 9.12 G22: Firmware Retract
- 9.13 G23: Firmware Recover
- 9.14 G26: Mesh Validation Pattern
- 9.15 G28: Move to Origin (Home)
- 9.16 G29: Detailed Z-Probe
- 9.17 G29.1: Set Z probe head offset
- 9.18 G29.2: Set Z probe head offset calculated from toolhead position
- 9.19 G30: Single Z-Probe
- 9.20 G31: Set or Report Current Probe status
- 9.21 G31: Dock Z Probe sled
- 9.22 G32: Probe Z and calculate Z plane
- 9.23 G32: Undock Z Probe sled
- 9.24 G33: Firmware dependent
- 9.25 G34: Z Stepper Auto-Align
- 9.26 G34: Calculate Delta Height from toolhead position (DELTA)
- 9.27 G38.x Straight Probe (CNC specific)
- 9.28 G40: Compensation Off (CNC specific)
- 9.29 G42: Move to Grid Point
- 9.30 G53..59: Coordinate System Select (CNC specific)
- 9.31 G60: save current position to slot
- 9.32 G61: Apply/restore saved coordinates to the active extruder.
- 9.33 G75: Print temperature interpolation
- 9.34 G76: PINDA probe temperature calibration
- 9.35 G80: Cancel Canned Cycle (CNC specific)
- 9.36 G80: Mesh-based Z probe
- 9.37 G81: Mesh bed leveling status
- 9.38 G82: Single Z probe at current location
- 9.39 G83: Babystep in Z and store to EEPROM
- 9.40 G84: UNDO Babystep Z (move Z axis back)
- 9.41 G85: Pick best babystep
- 9.42 G86: Disable babystep correction after home
- 9.43 G87: Enable babystep correction after home
- 9.44 G88: Reserved
- 9.45 G90: Set to Absolute Positioning
- 9.46 G91: Set to Relative Positioning
- 9.47 G92: Set Position
- 9.48 G93: Feed Rate Mode (Inverse Time Mode) (CNC specific)
- 9.49 G94: Feed Rate Mode (Units per Minute) (CNC specific)
- 9.50 G98: Activate farm mode
- 9.51 G99: Deactivate farm mode
- 9.52 G100: Calibrate floor or rod radius
- 9.53 G130: Set digital potentiometer value
- 9.54 G131: Remove offset
- 9.55 G132: Calibrate endstop offsets
- 9.56 G133: Measure steps to top
- 9.57 G161: Home axes to minimum
- 9.58 G162: Home axes to maximum
- 9.59 G425: Perform auto-calibration with calibration cube
- 10 M-commands
- 10.1 M0: Stop or Unconditional stop
- 10.2 M1: Sleep or Conditional stop
- 10.3 M2: Program End
- 10.4 M3: Spindle On, Clockwise (CNC specific)
- 10.5 M4: Spindle On, Counter-Clockwise (CNC specific)
- 10.6 M5: Spindle Off (CNC specific)
- 10.7 M6: Tool change
- 10.8 M7: Mist Coolant On (CNC specific)
- 10.9 M8: Flood Coolant On (CNC specific)
- 10.10 M9: Coolant Off (CNC specific)
- 10.11 M10: Vacuum On (CNC specific)
- 10.12 M11: Vacuum Off (CNC specific)
- 10.13 M13: Spindle on (clockwise rotation) and coolant on (flood)
- 10.14 M16: Expected Printer Check
- 10.15 M17: Enable/Power all stepper motors
- 10.16 M18: Disable all stepper motors
- 10.17 M20: List SD card
- 10.18 M21: Initialize SD card
- 10.19 M22: Release SD card
- 10.20 M23: Select SD file
- 10.21 M24: Start/resume SD print
- 10.22 M25: Pause SD print
- 10.23 M26: Set SD position
- 10.24 M27: Report SD print status
- 10.25 M28: Begin write to SD card
- 10.26 M29: Stop writing to SD card
- 10.27 M30: Delete a file on the SD card
- 10.28 M31: Output time since last M109 or SD card start to serial
- 10.29 M32: Select file and start SD print
- 10.30 M33: Get the long name for an SD card file or folder
- 10.31 M33: Stop and Close File and save restart.gcode
- 10.32 M34: Set SD file sorting options
- 10.33 M35: Upload firmware NEXTION from SD
- 10.34 M36: Return file information
- 10.35 M37: Simulation mode
- 10.36 M38 Compute SHA1 hash of target file
- 10.37 M39 Report SD card information
- 10.38 M40: Eject
- 10.39 M41: Loop
- 10.40 M42: Switch I/O pin
- 10.41 M43: Stand by on material exhausted
- 10.42 M43: Pin report and debug
- 10.43 M44: Codes debug - report codes available
- 10.44 M44: Reset the bed skew and offset calibration
- 10.45 M45: Bed skew and offset with manual Z up
- 10.46 M46: Show the assigned IP address
- 10.47 M47: Show end stops dialog on the display
- 10.48 M48: Measure Z-Probe repeatability
- 10.49 M49: Set G26 debug flag
- 10.50 M70: Display message
- 10.51 M72: Play a tone or song
- 10.52 M73: Set/Get build percentage
- 10.53 M75: Start the print job timer
- 10.54 M76: Pause the print job timer
- 10.55 M77: Stop the print job timer
- 10.56 M78: Show statistical information about the print jobs
- 10.57 M80: ATX Power On
- 10.58 M81: ATX Power Off
- 10.59 M82: Set extruder to absolute mode
- 10.60 M83: Set extruder to relative mode
- 10.61 M84: Stop idle hold
- 10.62 M85: Set Inactivity Shutdown Timer
- 10.63 M86: Set Safety Timer expiration time
- 10.64 M92: Set axis_steps_per_unit
- 10.65 M93: Send axis_steps_per_unit
- 10.66 M98: Call Macro/Subprogram
- 10.67 M99: Return from Macro/Subprogram
- 10.68 M101: Turn extruder 1 on (Forward), Undo Retraction
- 10.69 M102: Turn extruder 1 on (Reverse)
- 10.70 M103: Turn all extruders off, Extruder Retraction
- 10.71 M104: Set Extruder Temperature
- 10.72 M105: Get Extruder Temperature
- 10.73 M106: Fan On
- 10.74 M107: Fan Off
- 10.75 M108: Cancel Heating
- 10.76 M108: Set Extruder Speed (BFB)
- 10.77 M109: Set Extruder Temperature and Wait
- 10.78 M110: Set Current Line Number
- 10.79 M111: Set Debug Level
- 10.80 M112: Full (Emergency) Stop
- 10.81 M113: Set Extruder PWM
- 10.82 M113: Host Keepalive
- 10.83 M114: Get Current Position
- 10.84 M115: Get Firmware Version and Capabilities
- 10.85 M116: Wait
- 10.86 M117: Get Zero Position
- 10.87 M117: Display Message
- 10.88 M118: Echo message on host
- 10.89 M118: Negotiate Features
- 10.90 M119: Get Endstop Status
- 10.91 M120: Push
- 10.92 M121: Pop
- 10.93 M120: Enable endstop detection
- 10.94 M121: Disable endstop detection
- 10.95 M122: Firmware dependent
- 10.96 M123: Firmware dependent
- 10.97 M124: Firmware dependent
- 10.98 M126: Open Valve
- 10.99 M127: Close Valve
- 10.100 M128: Extruder Pressure PWM
- 10.101 M129: Extruder pressure off
- 10.102 M130: Set PID P value
- 10.103 M131: Set PID I value
- 10.104 M132: Set PID D value
- 10.105 M133: Set PID I limit value
- 10.106 M134: Write PID values to EEPROM
- 10.107 M135: Set PID sample interval
- 10.108 M136: Print PID settings to host
- 10.109 M140: Set Bed Temperature (Fast)
- 10.110 M141: Set Chamber Temperature (Fast)
- 10.111 M142: Firmware dependent
- 10.112 M143: Maximum heater temperature
- 10.113 M144: Bed Standby
- 10.114 M146: Set Chamber Humidity
- 10.115 M149: Set temperature units
- 10.116 M150: Set LED color
- 10.117 M155: Automatically send temperatures
- 10.118 M160: Number of mixed materials
- 10.119 M163: Set weight of mixed material
- 10.120 M164: Store weights
- 10.121 M165: Set multiple mix weights
- 10.122 M190: Wait for bed temperature to reach target temp
- 10.123 M191: Wait for chamber temperature to reach target temp
- 10.124 M200: Set filament diameter
- 10.125 M201: Set max printing acceleration
- 10.126 M202: Set max travel acceleration
- 10.127 M203: Set maximum feedrate
- 10.128 M204: Set default acceleration
- 10.129 M205: Advanced settings
- 10.130 M206: Offset axes
- 10.131 M207: Firmware dependent
- 10.132 M208: Set axis max travel
- 10.133 M208: Set unretract length
- 10.134 M209: Enable automatic retract
- 10.135 M210: Set homing feedrates
- 10.136 M211: Disable/Enable software endstops
- 10.137 M212: Set Bed Level Sensor Offset
- 10.138 M217: Toolchange Parameters
- 10.139 M218: Set Hotend Offset
- 10.140 M220: Set speed factor override percentage
- 10.141 M221: Set extrude factor override percentage
- 10.142 M220: Turn off AUX V1.0.5
- 10.143 M221: Turn on AUX V1.0.5
- 10.144 M222: Set speed of fast XY moves
- 10.145 M223: Set speed of fast Z moves
- 10.146 M224: Enable extruder during fast moves
- 10.147 M225: Disable on extruder during fast moves
- 10.148 M226: G-code Initiated Pause
- 10.149 M226: Wait for pin state
- 10.150 M227: Enable Automatic Reverse and Prime
- 10.151 M228: Disable Automatic Reverse and Prime
- 10.152 M229: Enable Automatic Reverse and Prime
- 10.153 M230: Disable / Enable Wait for Temperature Change
- 10.154 M231: Set OPS parameter
- 10.155 M232: Read and reset max. advance values
- 10.156 M240: Trigger camera
- 10.157 M240: Start conveyor belt motor / Echo off
- 10.158 M241: Stop conveyor belt motor / echo on
- 10.159 M245: Start cooler
- 10.160 M246: Stop cooler
- 10.161 M250: Set LCD contrast
- 10.162 M251: Measure Z steps from homing stop (Delta printers)
- 10.163 M260: i2c Send Data
- 10.164 M261: i2c Request Data
- 10.165 M280: Set servo position
- 10.166 M290: Babystepping
- 10.167 M291: Display message and optionally wait for response
- 10.168 M292: Acknowledge message
- 10.169 M300: Play beep sound
- 10.170 M301: Set PID parameters
- 10.171 M302: Allow cold extrudes
- 10.172 M303: Run PID tuning
- 10.173 M304: Set PID parameters - Bed
- 10.174 M305: Set thermistor and ADC parameters
- 10.175 M306: Set home offset calculated from toolhead position
- 10.176 M307: Set or report heating process parameters
- 10.177 M308: Set or report sensor parameters
- 10.178 M320: Activate autolevel (Repetier)
- 10.179 M321: Deactivate autolevel (Repetier)
- 10.180 M322: Reset autolevel matrix (Repetier)
- 10.181 M323: Distortion correction on/off (Repetier)
- 10.182 M340: Control the servos
- 10.183 M350: Set microstepping mode
- 10.184 M351: Toggle MS1 MS2 pins directly
- 10.185 M355: Turn case lights on/off
- 10.186 M360: Report firmware configuration
- 10.187 SCARA calibration codes (Morgan)
- 10.188 M360: Move to Theta 0 degree position
- 10.189 M361: Move to Theta 90 degree position
- 10.190 M362: Move to Psi 0 degree position
- 10.191 M363: Move to Psi 90 degree position
- 10.192 M364: Move to Psi + Theta 90 degree position
- 10.193 M365: SCARA scaling factor
- 10.194 M366: SCARA convert trim
- 10.195 M370: Morgan manual bed level - clear map
- 10.196 M371: Move to next calibration position
- 10.197 M372: Record calibration value, and move to next position
- 10.198 M373: End bed level calibration mode
- 10.199 M374: Save calibration grid
- 10.200 M375: Display matrix / Load Matrix
- 10.201 M376: Set bed compensation taper
- 10.202 M380: Activate solenoid
- 10.203 M381: Disable all solenoids
- 10.204 M400: Wait for current moves to finish
- 10.205 M401: Lower z-probe
- 10.206 M402: Raise z-probe
- 10.207 M403: Set filament type (material) for particular extruder and notify the MMU
- 10.208 M404: Filament width and nozzle diameter
- 10.209 M405: Filament Sensor on
- 10.210 M406: Filament Sensor off
- 10.211 M407: Display filament diameter
- 10.212 M408: Report JSON-style response
- 10.213 M410: Quick-Stop
- 10.214 M412: Disable Filament Runout Detection
- 10.215 M413: Power-Loss Recovery
- 10.216 M415: Host Rescue
- 10.217 M416: Power loss
- 10.218 M420: Set RGB Colors as PWM (MachineKit)
- 10.219 M420: Leveling On/Off/Fade (Marlin)
- 10.220 M421: Set a Mesh Bed Leveling Z coordinate
- 10.221 M425: Backlash Correction
- 10.222 M450: Report Printer Mode
- 10.223 M451: Select FFF Printer Mode
- 10.224 M452: Select Laser Printer Mode
- 10.225 M453: Select CNC Printer Mode
- 10.226 M460: Define temperature range for thermistor-controlled fan
- 10.227 M470: Create Directory on SD-Card
- 10.228 M471: Rename File/Directory on SD-Card
- 10.229 M486: Cancel Object
- 10.230 M500: Store parameters in non-volatile storage
- 10.231 M501: Read parameters from EEPROM
- 10.232 M502: Restore Default Settings
- 10.233 M503: Report Current Settings
- 10.234 M504: Validate EEPROM
- 10.235 M505: Firmware dependent
- 10.236 M509: Force language selection
- 10.237 M524: Abort SD Printing
- 10.238 M530: Enable printing mode
- 10.239 M531: Set print name
- 10.240 M532: Set print progress
- 10.241 M540: Set MAC address
- 10.242 M540 in Marlin: Enable/Disable "Stop SD Print on Endstop Hit"
- 10.243 M550: Set Name
- 10.244 M551: Set Password
- 10.245 M552: Set IP address, enable/disable network interface
- 10.246 M553: Set Netmask
- 10.247 M554: Set Gateway
- 10.248 M555: Set compatibility
- 10.249 M556: Axis compensation
- 10.250 M557: Set Z probe point or define probing grid
- 10.251 M558: Set Z probe type
- 10.252 M559: Upload configuration file
- 10.253 M560: Upload web page file
- 10.254 M561: Set Identity Transform
- 10.255 M562: Reset temperature fault
- 10.256 M563: Define or remove a tool
- 10.257 M564: Limit axes
- 10.258 M565: Set Z probe offset
- 10.259 M566: Set allowable instantaneous speed change
- 10.260 M567: Set tool mix ratios
- 10.261 M568: Turn off/on tool mix ratios (obsolete)
- 10.262 M569: Stepper driver control
- 10.263 M570: Configure heater fault detection
- 10.264 M571: Set output on extrude
- 10.265 M572: Set or report extruder pressure advance
- 10.266 M573: Report heater PWM
- 10.267 M574: Set endstop configuration
- 10.268 M575: Set serial comms parameters
- 10.269 M577: Wait until endstop is triggered
- 10.270 M578: Fire inkjet bits
- 10.271 M579: Scale Cartesian axes
- 10.272 M580: Select Roland
- 10.273 M581: Configure external trigger
- 10.274 M582: Check external trigger
- 10.275 M584: Set drive mapping
- 10.276 M585: Probe Tool
- 10.277 M586: Configure network protocols
- 10.278 M587: Store WiFi host network in list, or list stored networks
- 10.279 M588: Forget WiFi host network
- 10.280 M589: Configure access point parameters
- 10.281 M590: Report current tool type and index
- 10.282 M591: Configure filament monitoring
- 10.283 M592: Configure nonlinear extrusion
- 10.284 M593: Configure Dynamic Acceleration Adjustment
- 10.285 M594: Enter/Leave Height Following mode
- 10.286 M600: Set line cross section
- 10.287 M600: Filament change pause
- 10.288 M601: Pause print
- 10.289 M602: Resume print
- 10.290 M603: Stop print
- 10.291 M605: Set dual x-carriage movement mode
- 10.292 M650: Set peel move parameters
- 10.293 M651: execute peel move
- 10.294 M665: Set delta configuration
- 10.295 M666: Set delta endstop adjustment
- 10.296 M667: Select CoreXY mode
- 10.297 M668: Set Z-offset compensations polynomial
- 10.298 M669: Set kinematics type and kinematics parameters
- 10.299 M670: Set IO port bit mapping
- 10.300 M671: Define positions of Z leadscrews or bed leveling screws
- 10.301 M672: Program Z probe
- 10.302 M673: Align plane on rotary axis
- 10.303 M674: Set Z to center point
- 10.304 M675: Find center of cavity
- 10.305 M700: Level plate
- 10.306 M701: Load filament
- 10.307 M702: Unload filament
- 10.308 M703: Configure Filament
- 10.309 M710: Erase the EEPROM and reset the board
- 10.310 M750: Enable 3D scanner extension
- 10.311 M751: Register 3D scanner extension over USB
- 10.312 M752: Start 3D scan
- 10.313 M753: Cancel current 3D scanner action
- 10.314 M754: Calibrate 3D scanner
- 10.315 M755: Set alignment mode for 3D scanner
- 10.316 M756: Shutdown 3D scanner
- 10.317 M800: Fire start print procedure
- 10.318 M801: Fire end print procedure
- 10.319 M851: Set Z-Probe Offset
- 10.320 M862: Print checking
- 10.321 M876: Dialog handling
- 10.322 M890 Run User Gcode
- 10.323 M900 Set Linear Advance Scaling Factors
- 10.324 M905: Set local date and time
- 10.325 M906: Set motor currents
- 10.326 M907: Set digital trimpot motor
- 10.327 M908: Control digital trimpot directly
- 10.328 M909: Set microstepping
- 10.329 M910: Set decay mode
- 10.330 M911: Configure auto save on loss of power ("power panic")
- 10.331 M912: Set electronics temperature monitor adjustment
- 10.332 M913: Set motor percentage of normal current
- 10.333 M914: Set/Get Expansion Voltage Level Translator
- 10.334 M915: Configure motor stall detection
- 10.335 M916: Resume print after power failure
- 10.336 M917: Set motor standstill current reduction
- 10.337 M918: Configure direct-connect display
- 10.338 M928: Start SD logging
- 10.339 M929: Start/stop event logging to SD card
- 10.340 M950: Create heater, fan or GPIO/servo device
- 10.341 M951: Set height following mode parameters
- 10.342 M952: Set CAN-FD bus data rate
- 10.343 M953: Change CAN-FD expansion board address
- 10.344 M997: Perform in-application firmware update
- 10.345 M998: Request resend of line
- 10.346 M999: Restart after being stopped by error
- 11 Other commands
- 12 Proposed EEPROM configuration codes
- 13 Replies from the RepRap machine to the host computer
- 14 Proposal for sending multiple lines of G-code
- 15 Alternatives to G-code
Introduction
A typical piece of G-code as sent to a RepRap machine might look like this:
N3 T0*57 N4 G92 E0*67 N5 G28*22 N6 G1 F1500.0*82 N7 G1 X2.0 Y2.0 F3000.0*85 N8 G1 X3.0 Y3.0*33
G-code can also be stored in files on SD cards. A file containing RepRap G-code usually has the extension .g
, .gco
or .gcode
Files for BFB/RapMan have the extension .bfb
G-code stored in file or produced by a slicer might look like this:
G92 E0 G28 G1 F1500 G1 X2.0 Y2.0 F3000 G1 X3.0 Y3.0
Slicers will (optionally?) add G-code scripts to the beginning and end of their output file to perform specified actions before and/or after a print such as z-probing the build-area, heating/cooling the bed and hotend, performing ooze free "nozzle wipe" startup routine, switching system power on/off, and even "ejecting" parts. More info on the Start GCode routines and End GCode routines pages.
To find out which specific G-code(s) are implemented in any given firmware, there are little tables attached to the command descriptions, like this one:
Support | Marlin | RepRapFirmware | Klipper | Prusa | Buddy | Repetier | Smoothie | Druid | MK4duo |
Partial | ??? | ??? | ??? | ??? | Experimental | ??? | ??? | Partial | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | MakerBot | |
??? | No | ??? | Yes | ??? | Yes | Automatic | Yes | ??? |
Here means:
- {{yes}}
- The G-code is fully supported by the firmware.
- {{partial}} or {{experimental}}
- There is some support for the G-code. Often it is required to check out the source code branch for the firmware (usually stored in a different branch) or to flip configuration switches on the mainboard.
- {{automatic}}
- The firmware handles this G-code automatically, so there's no need to send the command. An example is power supply on/off G-code (M80/M81) in the Teacup firmware.
- It is unknown if the firmware supports this G-code. You may want to test this yourself before using it in production.
- {{no}}
- The firmware does not support this G-code.
For the technically-minded, G-code line endings are Unix Line Endings (\n
), but will accept Windows Line Endings (\r\n
), so you should not need to worry about converting between the two, but it is best practice to use Unix Line Endings where possible.
Fields
A RepRap G-code is a list of fields that are separated by white spaces or line breaks. A field can be interpreted as a command, parameter, or for any other special purpose. It consists of one letter directly followed by a number, or can be only a stand-alone letter (Flag). The letter gives information about the meaning of the field (see the list below in this section). Numbers can be integers (128) or fractional numbers (12.42), depending on context. For example, an X coordinate can take integers (X175
) or fractionals (X17.62
), but selecting extruder number 2.76 would make no sense. In this description, the numbers in the fields are represented by nnn
as a placeholder.
In RepRapFirmware, some parameters can be followed by more than one number, with colon used to separate them. Typically this is used to specify extruder parameters, with one value provided per extruder. If only one value is provided where a value is needed for each extruder, then that value is applied to all extruders.
Letter | Meaning |
Gnnn | Standard G-code command, such as move to a point |
Mnnn | RepRap-defined command, such as turn on a cooling fan |
Tnnn | Select tool nnn. In RepRap, a tool is typically associated with a nozzle, which may be fed by one or more extruders. |
Snnn | Command parameter, such as time in seconds; temperatures; voltage to send to a motor |
Pnnn | Command parameter, such as time in milliseconds; proportional (Kp) in PID Tuning |
Xnnn | A X coordinate, usually to move to. This can be an Integer or Fractional number. |
Ynnn | A Y coordinate, usually to move to. This can be an Integer or Fractional number. |
Znnn | A Z coordinate, usually to move to. This can be an Integer or Fractional number. |
U,V,W | Additional axis coordinates (RepRapFirmware) |
Innn | Parameter - X-offset in arc move; integral (Ki) in PID Tuning |
Jnnn | Parameter - Y-offset in arc move |
Dnnn | Parameter - used for diameter; derivative (Kd) in PID Tuning |
Hnnn | Parameter - used for heater number in PID Tuning |
Fnnn | Feedrate in mm per minute. (Speed of print head movement) |
Rnnn | Parameter - used for temperatures |
Qnnn | Parameter - not currently used |
Ennn | Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to consume. |
Nnnn | Line number. Used to request repeat transmission in the case of communications errors. |
*nnn | Checksum. Used to check for communications errors. |
Case sensitivity
The original NIST G-code standard requires gcode interpreters to be case-insensitive, except for characters in comments. However, not all 3D printer firmwares conform to this and some recognise uppercase command letters and parameters only.
- Firmwares that are known to be case-insensitive
- RepRapFirmware version 1.19 and later (except within quoted strings)
- Firmwares that are known to be case-sensitive
- RepRapFirmware version 1.18 and earlier
Quoted strings
In RepRapFirmware, some commands support quoted strings when providing file names and other string parameters. This allows file names, WiFi passwords etc. to contain spaces, semicolons and other characters that would otherwise not be permitted. Double-quote characters are used to delimit the string, and any double-quote character within the string must be repeated.
Unfortunately, many gcode sender programs convert all characters to uppercase and don't provide any means to disable this feature. Therefore, within a quoted-string, the single-quote character is used as a flag to force the following character to lowercase. If you want to include a single quote character in the string, use two single quote characters to represent one single quote character.
Example: to add SSID MYROUTER with password ABCxyz;" 123
to the WiFi network list, use command:
M587 S"MYROUTER" P"ABCxyz;"" 123"
or if you can't send lowercase characters:
M587 S"MYROUTER" P"ABC'X'Y'Z;"" 123"
Comments
G-code comments begin at a semicolon, and end at the end of the line:
N3 T0*57 ; This is a comment N4 G92 E0*67 ; So is this N5 G28*22
Some firmwares also obey the CNC G-code standard, which is to enclose comments in round brackets. Comments of this form must start and end on the same line:
(Home some axes) G28 (here come the axes to be homed) X Y
Comments and white space will be ignored by your RepRap Printer. It's better to strip these out on the host computer before sending the G-code to your printer, as this saves bandwidth.
Special fields
N: Line number
Yes | Yes | ??? | Yes | ??? | Yes | ??? | ??? | Yes | |
??? | Yes | ??? | Yes | Yes | Yes | Yes | Yes | ??? |
- Example
N123
If checking is supported, the RepRap firmware expects line numbers to increase by 1 each line, and if that doesn't happen it is flagged as an error. But you can reset the count using M110
(see below).
*: Checksum
??? | Yes | ??? | Yes | ??? | No | Yes | No | ??? |
Example: *71
The firmware compares the checksum against a locally-computed value. If they differ, it requests a repeat transmission of the line.
Checking
- Example
N123 [...G Code in here...] *71
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
The checksum "cs" for a G-code string "cmd" (including its line number) is computed by exor-ing the bytes in the string up to and not including the * character as follows:
int cs = 0; for(i = 0; cmd[i] != '*' && cmd[i] != NULL; i++) cs = cs ^ cmd[i]; cs &= 0xff; // Defensive programming...
Buffering
Yes | Yes | ??? | ??? | ??? | ??? | ??? | ??? | Yes | |
Yes | ??? | ??? | Yes | ??? | Yes | Yes | Yes | ??? |
Typically, the following moving commands are buffered: G0
-G3
and G28
-G32
. The Teacup Firmware buffers also some setting commands: G20
, G21
, G90
and G91
. All other G
, M
or T
commands are not buffered.
RepRapFirmware also implements an internal queue to ensure that certain codes (like M106) are executed in the right order and not when the last move has been added to the look-ahead queue.
G-commands
G0 & G1: Move
Yes | Yes | ??? | Yes | ??? | Yes | Yes | ??? | Yes | |
Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
G0
: Rapid Move -
G1
: Linear Move
- Usage
- Parameters
- Not all parameters need to be used, but at least one has to be used
Xnnn
The position to move to on the X axisYnnn
The position to move to on the Y axisZnnn
The position to move to on the Z axisEnnn
The amount to extrude between the starting point and ending pointFnnn
The feedrate per minute of the move between the starting point and ending point (if supplied)Hnnn
(RepRapFirmware) Flag to check if an endstop was hit (S1
to check,S0
to ignore,S2
see note, default isS0
)1Snnn
Laser cutter/engraver power. In RepRapFirmware, when not in laser mode S in interpreted the same as H.- Examples
G0 X12 ; move to 12mm on the X axis G0 F1500 ; Set the feedrate to 1500mm/minute G1 X90.6 Y13.8 E22.4 ; Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material
The RepRap firmware spec treats G0
and G1
as the same command, since it's just as efficient as not doing so.2
G1 F1500 ; Set feedrate to 1500mm/m G1 X50 Y25.3 E22.4 ; Move and extrude
In the above example, we first set the feedrate to 1500mm/m, then move to 50mm on X and 25.3mm on Y while extruding 22.4mm of filament between the two points.
G1 F1500 ; Feedrate 1500mm/m G1 X50 Y25.3 E22.4 F3000 ; Accelerate to 3000mm/m
However, in the above example, we set a feedrate of 1500 mm/m, then do the same move, but accelerating to 3000 mm/m. Everything stays synchronized, so extrusion accelerates right along with X and Y movement.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in a way that ensures everything moves smoothly together and the right volume of material is extruded at all points.3
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G0
or G1
to send an E
value that is less than the currently extruded length.
- Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S
parameter in this way, as damage may occur if you assume incorrectly. In RepRapFirmware, using the S1
or S2
parameter on a delta printer causes the XYZ
parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1.
2In the RS274NGC Spec, G0
is Rapid Move, which was used to move between the current point in space and the new point as quickly and efficiently as possible, and G1
is Controlled Move, which was used to move between the current point in space and the new point as precise as possible. In RepRapFirmware, G1 is always a linear move but G0 may not be linear (e.g. on a SCARA machine); however a G0 move will never go below the lower of the initial and final Z height of the move.
4RepRapFirmware provides an additional 'R1' parameter to tell the machine to go back to the coordinates a print was previously paused at. If this parameter is used and the code contains axis letters, an offset will be added to the pause coordinates (e.g. G1 R1 Z5
Yes1 | Yes | ??? | Yes2 | ??? | Yes | Yes | ??? | Yes | |
Yes | Yes | No | No | Yes | Experimental | No | Yes | No |
- Usage
G2 Xnnn Ynnn Innn Jnnn Ennn Fnnn
(Clockwise Arc)G3 Xnnn Ynnn Innn Jnnn Ennn Fnnn
(Counter-Clockwise Arc)- Parameters
Xnnn
The position to move to on the Y axisInnn
The point in X space from the current X position to maintain a constant distance fromJnnn
The point in Y space from the current Y position to maintain a constant distance fromEnnn
The feedrate per minute of the move between the starting point and ending point (if supplied)- Examples
G2 X90.6 Y13.8 I5 J10 E22.4
(Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
G3 X90.6 Y13.8 I5 J10 E22.4
(Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
- Notes
1In Marlin Firmware not implemented for DELTA printers. 2Prusa Firmware implements arcs only in Cartesian XY.
G4: Dwell
Pause the machine for a period of time.
- Parameters
Pnnn
Time to wait, in milliseconds (In Teacup, P0, wait until all previous moves are finished)Snnn
Time to wait, in seconds (Only on Repetier, Marlin, Prusa, Smoothieware, and RepRapFirmware 1.16 and later)- Example
G4 P200
On Marlin, Smoothie and RepRapFirmware, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
No | Use G1 S2 or G1 H2 instead | ??? | No | ??? | No | No | ??? | No | |
No | No | No | No | No | No | No | No | No |
Perform a direct, uninterpolated, and non-kinematic synchronized move of one or more steppers directly. Units may be linear (e.g., mm or inches on DELTA
) or specified in degrees (SCARA). This command is useful for initialization, diagnostics, and calibration, and should be disabled on production equipment. This type of move can be potentially dangerous, especially for deltabots, so implementations should do their best to limit movement to prevent twerking and damaging the carriage assembly.
- Parameters
Annn
Stepper A position or angleBnnn
Stepper B position or angleCnnn
Stepper C position or angleR
Relative move flag- SCARA Examples
G6 A45 ; Move SCARA A stepper to the 45° position G6 B20 R ; Move SCARA B stepper 20° counter-clockwise
- DELTA Example
G6 C10 R ; Move DELTA C carriage up by 10mm
No | Yes | ??? | No | ??? | No | No | ??? | No | |
??? | No | No | No | Yes | No | No | Yes | ??? |
- Usage
G10 Pnnn Xnnn Ynnn Znnn Rnnn Snnn
1- Parameters
Pnnn
Tool numberLnnn
Offset mode (optional)5Xnnn
X offsetYnnn
Y offsetZnnn
Z offset2U,V,W,A,B,Cnnn
other axis offsets4Rnnn
Standby temperature(s) (RepRapFirmware)Snnn
Active temperature(s) (RepRapFirmware)- Examples
G10 P2 X17.8 Y-19.3 Z0.0
(sets the offset for tool 2 to the X, Y, and Z values specified)
G10 P1 R140 S205
(RepRapFirmware only - set standby and active temperatures3 for tool 1)
The precise meaning of the X, Y (and other offset) values is: with no offset this tool is at this position relative to where a tool with offset (0, 0, 0) would be. So if the tool is 10mm to the left of a zero-offset tool the X value would be -10, and so on.
The R
value is the standby temperature in oC that will be used for the tool, and the S
value is its operating temperature. If you don't want the tool to be at a different temperature when not in use, set both values the same. See the T code (select tool) below. In tools with multiple heaters the temperatures for them all are specified thus: R100.0:90.0:20.0 S185.0:200.0:150.0 .
See also M585
- Notes
1Marlin uses G10/G11 for executing a retraction/unretraction move. Smoothie uses G10
for retract and G10 Ln
for setting workspace coordinates. RepRapFirmware interprets a G10 command with no P or L parameter as a retraction command.
2It's usually a bad idea to put a non-zero Z
value in as well unless the tools are loaded and unloaded by some sort of tool changer or are on indepedent carriages. When all the tools are in the machine at once they should all be set to the same Z height.
4Tool offsets are applied after any X axis mapping has been performed. Therefore if for example you map X to U in your M563
command to create the tool, you should specify a U offset not an X offset. If you map X to both X and U, you can specify both offsets.
5L1 (the default) sets the offsets of the current tool relative to the head reference point to the specified values. L2 sets the current workplace coordinate offsets to the specified values. L20 adjusts the current workplace coordinate offsets so that the current tool head position has the specified coordinates.
G10: Retract
Yes | Yes | ??? | Yes | ??? | Yes: 0.92 | Yes | ??? | Yes | |
??? | No | No | No | No | No | No | No | ??? |
- Parameters
Snnn
retract length (S1 = long retract, S0 = short retract = default) (Repetier only)- Example
G10
Retracts filament according to settings of M207
(Marlin, RepRapFirmware) or according to the S
value (Repetier).
RepRapFirmware recognizes G10
as a command to set tool offsets and/or temperatures if the P
parameter is present, and as a retraction command if it is absent.
G11: Unretract
- Parameters
Snnn
G11
Unretracts/recovers filament according to settings of M208
value (Repetier).
G12: Clean Tool
Yes: 1.1.0 | Use a macro instead | ??? | No | ??? | No | No | ??? | Yes | |
??? | No | No | No | No | No | No | No | No |
- Usage
[P<0|1>] [S<count>] [T<count>]
G12 Pnnn Snnn Tnnn
- Parameters
Pnnn
1 Pattern style selectionSnnn
Number of strokes (i.e. back-and-forth movements)Tnnn
Number of repetitions- Examples
G12 ; stroke pattern (default)
To generate a three triangle zig-zag pattern which will be stroked three times time use the following command. G12 P1 S3 T2 ; zig-zag pattern with 2 triangles
- Notes
1In Marlin firmware and Derivatives Mk4duo this is implemented by hard-coded firmware behaviours As defined for variables NOZZLE_CLEAN_STROKES, NOZZLE_CLEAN_START_POINT, NOZZLE_CLEAN_END_POINT and NOZZLE_CLEAN_PARK.
With NOZZLE_CLEAN_PARK enabled, the nozzle will automatically return to the XYZ position after G12 is run.
More on this behaviour is documented inside of the code base.
The use of G12 for tool cleaning clashes with the established use of G12 for circular pocket milling on CNC machines. For this reason, RepRapFirmware does not support G12.
Yes:1.1.4 | No | ??? | No | ??? | ??? | ??? | ??? | No | |
Yes | ??? | ??? | ??? | Yes | No | ??? | Yes | ??? |
G17
: XY (default) -
G18
: ZX -
G19
: YZ
This mode applies to G2
/G3
arc moves. Normal arc moves are in the XY plane, and for most applications that's all you need. For CNC routing it can be useful to do small "digging" moves while making cuts, so to keep the G-code compact it uses G2
/G3
arcs involving the Z plane.
These commands are supported in Marlin 1.1.4 and later with ARC_SUPPORT
and CNC_WORKSPACE_PLANES
enabled.
Yes | Yes | ??? | No | ??? | Yes | Yes | ??? | Yes | |
Yes | Yes | No | Yes | Yes | No | Yes | Yes | No |
- Example
G20
Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | ??? |
- Example
G21
G10 | No | ??? | No | ??? | No | No | ??? | No | |
No | No | No | No | Yes | No | No | No | No |
- Usage
G22 ; Do a retract move
Use this command (along with G23
) to have the firmware to do retraction moves (in contrast to generating an E axis G1
move). The retract length and speed are set in the firmware.
G11 | No | ??? | No | ??? | No | No | ??? | No | |
- Usage
G23 ; Do a recover move
Use this command (along with G22
) to have the firmware to do a recover move. The recover length and speed are set in the firmware.
Yes: 1.1.0 | No | No | No | ??? | No | No | ??? | Yes | |
- Usage
G26 C P O2.25 ; Do a typical test sequence
The G26
Mesh Validation Pattern is designed to be used in conjunction with various Mesh Bed Leveling systems – those that adjust for an uneven —rather than just tilted— bed. The G26
command prints a single layer pattern over the entire print bed, giving a clear indication of how accurately every mesh point is defined. G26
can be used to determine which areas of the mesh are less-than-perfect and how much to adjust each mesh point.
G26
has large feature list, including a built-in test that extrudes material onto the bed. By default this is configured for PLA temperatures and a nozzle size of 0.4mm. (This will be adjustable in an upcoming version of Marlin.)
See the G26_Mesh_Validation_Tool.cpp
file in the Marlin source code for full documentation of the G26
parameter list.
Yes | Yes | Yes | Yes2 | ??? | Yes | Yes | ??? | Yes | |
Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes1 | Yes |
- Parameters
- This command can be used without any additional parameters.
X
Flag to go back to the X axis originY
Flag to go back to the Y axis originZ
Flag to go back to the Z axis origin- Examples
G28 ; Home all axes (On Prusa i3 MK2/s,MK2.5/s,MK3/s it will also perform mesh bed leveling)2 G28 X Z ; Home the X and Z axes
When the firmware receives this command, it quickly moves the specified axes (or all axes if none are given) to the endstops, backs away from each endstop by a short distance, and slowly bumps the endstop again to increase positional accuracy. This process, known as "Homing", is required to determine the position of the print carriage(s). Some firmware may even forbid movement away from endstops and other operations until the axes have been homed.
The X
, Y
, and Z
parameters act only as flags. Any coordinates given are ignored. For example, G28 Z10
results in the same behavior as G28 Z
. Delta printers cannot home individual axes, but must always home all three towers, so the X Y Z
parameters are simply ignored on these machines.
Marlin firmware (version 1.1.0 and later) provides an option called Z_SAFE_HOMING
for printers that use a Z probe to home Z instead of an endstop. With this option, the XY axes are homed first, then the carriage moves to a position –usually the middle of the bed– where it can safely probe downward to home Z.
RepRapFirmware uses macro files to home either all axes or individual axes. If all axes are homed, the file homeall.g
is processed. For individual axes the homex.g
, homey.g
, or homez.g
file will be used. On Delta printers, G28
command will always home all three towers by processing the homedelta.g
file, regardless of any X
Y
Z
parameters.
Because the behavior of G28
is unspecified, it is recommended not to automatically include G28
in your ending G-code. On a Cartesian this will result in damaging the printed object. If you need to move the carriage at the completion of a print, use G0
or G1
- Notes
1 MK4duo has a B
parameter that tells the printer to return to the coordinates it was at before homing.
2 Original Prusa i3 MK2/s, MK2.5/s, MK3/s supports a W
parameter to suppress mesh bed leveling. If W
is omitted, G28 will home only and NOT perform mesh bed leveling.
Original Prusa i3 MK3/s (TMC2130 drivers) supports a C
parameter to calibrate the X and Y home position.
W
Suppress mesh bed leveling (Prusa MK2/s, MK2.5/s and MK3/s only)2C
Calibrate X and Y home position (Prusa MK3/s only)2
Yes | 1.17+ | ??? | G811 | ??? | Yes: 0.91.7 | No: see G32 | ??? | Yes | |
No | No | No | No | Yes | Yes | No | No | ??? |
This command uses a probe to measure the bed height at 3 or more points to determine its tilt and overall flatness. It then enables compensation so that the nozzle will remain parallel to the bed. The printer must be homed with G28
before using this command.
Each firmware behaves differently and depends on the type of bed leveling that's been configured. For example, Marlin 1.0.2 provides 3 different types of automatic bed leveling (probe required) and a manual bed leveling option. See your firmware's documentation for the specific options available.
- Usage
G29
G29 Snnn
- Parameters
Snnn
Firmware-dependent behaviorPfile.csv
Optional file name for bed height map file (RepRapFirmware only)- Examples
G29 ; Probe the bed and enable compensation G29 S2 ; Special operation - see below G29 P1 ; UBL automated probe - see below
G29 Auto Bed Leveling (Marlin - MK4duo)
Marlin 1.0.2 and earlier provides three options for automatic bed leveling:
- The 3-point method probes the bed at three points to produce a matrix, adjusting for a flat but tilted bed.
- The planar grid method (non-Delta) probes a grid pattern to produce a matrix by the "least-squares" method, adjusting for a flat but tilted bed.
- The bilinear grid method (Delta only) probes a grid pattern to produce a mesh, using bilinear interpolation to adjust for an uneven bed.
Marlin 1.1.0 and later allows the bilinear grid (i.e., "mesh") method to be used on all types of machines, not just deltas. This is the recommended leveling method going forward.
Also in Marlin 1.1.0 and later, the PROBE_MANUALLY
option allows all forms of Auto Bed Leveling to be used without a probe. The procedure is similar to that of MESH_BED_LEVELING
(see below). Begin the process with G29
to move the nozzle to the first point. Adjust the Z axis using G1
or your host software. Send G29
again to move to the next point and repeat until all points have been sampled.
- Parameters
P
Set the size of the grid that will be probed (P x P points). Not supported by non-linear delta printer bed leveling. Example:G29 P4
S
Set the XY travel speed between probe points (in units/min)D
Dry-Run mode. Just evaluate the bed Topology - Don't apply or clean the rotation Matrix. Useful to check the topology after a first run of G29.V
Set the verbose level (0-4). Example:G29 V3
T
Generate a Bed Topology Report. Example:G29 P5 T
for a detailed report. This is useful for manual bed leveling and finding flaws in the bed (to assist with part placement). Not supported by non-linear delta printer bed leveling.F
Set the Front limit of the probing gridB
Set the Back limit of the probing gridL
Set the Left limit of the probing gridR
Set the Right limit of the probing grid
- Global Parameters
E
By defaultG29
will engage the Z probe, test the bed, then disengage. IncludeE
orE1
to engage/disengage the Z probe for each sample. (This has no effect for fixed probes.)
G29 Unified Bed Leveling (Marlin - MK4duo)
Marlin firmware (version 1.1.0 and later) includes the AUTO_BED_LEVELING_UBL
option for Unified Bed Leveling. UBL combines mesh leveling, tilted plane adjustment, 3-point leveling, and manual editing tools all together in a single package. To accomplish so much, UBL overloads `G29` with several new parameters and provides an additional G26
Mesh Tuning feature.
See the MarlinFW website for a dedicated Unified Bed Leveling page and complete documentation on `G29` for UBL and `G26` Mesh Validation.
- G29 UBL Parameters (synopsis)
A Activate Activate the Unified Bed Leveling system. (i.e., M420 S1) D Disable Disable the Unified Bed Leveling system. (i.e., M420 S0) B# Business Do Manual Probing in 'Business Card' mode. H# Height Height to raise the nozzle after each Manual Probe of the bed. C Continue Continue, Constant, or Current Location, depending on Phase. E Every Stow the probe after every sampled point. F# Fade Fade leveling compensation gradually, until it ceases at the given height. I# Invalidate Invalidate a specified number of Mesh Points (X and Y). J# Grid Do a grid (planar) leveling of the current Mesh using a grid with n points on a side. K# Kompare Compare (diff) current Mesh with stored Mesh #, replacing current Mesh with the result. L Load Load Mesh from the previously activated location in the EEPROM. L# Load Load Mesh from the specified location in the EEPROM. S Store Store the current Mesh in the Activated area of the EEPROM. Also save all settings. S # Store Store the current Mesh at the specified area in EEPROM, set as the Activated area. S -1 Store Store the current Mesh as a print-out suitable to be fed back into the system. O Map Display the Mesh Map Topology. P0 Phase 0 Zero Mesh Data and turn off the Mesh Compensation System. P1 Phase 1 Invalidate the Mesh and do Automatic Probing to generate new Mesh data. P2 Phase 2 Probe unpopulated areas of the Mesh (those that couldn't be auto-probed). P3 Phase 3 Fill unpopulated Mesh points with a fixed value. No 'C' for "smart fill" extrapolation. P4 Phase 4 Fine tune the Mesh. ** Delta Mesh Compensation requires an LCD panel. ** P5 Phase 5 Find Mean Mesh Height and Standard Deviation. P6 Phase 6 Shift Mesh height. All Mesh points are adjusted by the amount specified with 'C'. Q Test Load specified Test Pattern to help check system operation. R # Repeat Repeat the command the specified number of times. Default: grid points X * Y. T 3-Point Perform a 3-Point Bed Leveling on the current Mesh. U Unlevel Perform a probe of the outer perimeter to assist in physically leveling the bed. W What? Print a report of Unified Bed Leveling stored data. X # The X location for the command Y # The Y location for the command Z Zero Do a single probe to set the Z Height of the nozzle. Z # Zero Raise/lower the entire Mesh to conform with the specified difference (plus zprobe_zoffset).
G29 Manual Bed Leveling (Marlin - MK4duo)
Marlin firmware (version 1.0.2 and later) also provides a MESH_BED_LEVELING
feature that can be used to perform bed leveling on machines lacking a probe. This form of bed leveling compensates for uneven Z height across the surface of the bed using a mesh and bilinear interpolation.
- Manual Bed Leveling Usage
G29 S1 ; Move to the first point and wait for a measurement G29 S2 ; Store the current Z, move to the next point G29 S3 Xn Yn Zn.nn ; Modify the Z height of a single point
- Options for the
S
parameter S0
Produces a mesh reportS1
Start probing mesh pointsS2
Probe the next mesh pointS3 Xn Yn Zn.nn
Manually modify a single pointS4 Zn.nn
Set z offset. Positive away from bed, negative closer to bed.
G29 Auto Bed Leveling (Repetier-Firmware)
Repetier firmware since v0.91 supports G29
with the optional Snnn parameter as described below. Useful to simply detect the Z bed angle so you can manually readjust your bed and get it as close to in plane as possible. If you wish to apply automatic software Z plane compensation on Repetier, use G32
instead with firmware 0.92.8 and above.
S0
Default value. Z bed heights are calculated at the measured points, relative to current Z position before issuingG29
.S1
Same asS0
, except printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issueG28 Z
to home to Z maximum position before issuingG29 Snnn
for this to work correctly, or the printer height will be invalid.S2
Same asS1
, except new calculated Z height is also stored to EEPROM.
G29 Mesh Bed Compensation (RepRapFirmware)
RepRapFirmware:
S0
(default if noS
parameter) Probe the bed, save the height map in a file on the SD card, and activate the height map. The default folder for the height map file is/sys
and the default file name isheightmap.csv
.S1
Load the height map from file and activate bed compensation. The default folder and filename as forS0
.S2
Clear the currently-loaded bed height map
To define the grid, see M557.
- Notes
In Prusa Firmware G29
is not active by default, instead G81 is used.1
M851 | No | ??? | M851 | ??? | No | No | ??? | M851 | |
- Example
G29.1 X30 Y20 Z0.5
No | No | No | No | ??? | No | No | ??? | No | |
- Example
G29.2 Z0.0
The user would typically place the toolhead at the zero point of the axis and issue the G29.2
command.
G30: Single Z-Probe
Yes | Yes | ??? | No2 | ??? | Yes | Yes | ??? | Yes | |
No | No | No | No | Yes | Yes | G28,G92 | No1 | No |
- Usage
- Parameters
Pnnn
Probe point numberXnnn
X coordinateYnnn
Y coordinateZnnn
Z coordinateHnnn
Height correctionSnnn
Set parameter- Example
G30
- Examples (RepRapFirmware)
G30 ; Probe the bed at the current XY position. When the probe is triggered, set the Z coordinate to the probe trigger height. G30 S-1 ; Probe the bed at the current XY position. When the probe is triggered, do not adjust the Z coordinate. G30 P0 X20 Y50 Z-99999 ; Probe the bed at X20 Y50 and save the XY coordinates and the height error as point 0 G30 P3 X180 Y180 Z-99999 S4 ; Probe the bed at X180 Y180, save the XY coordinates and the height error as point 3 and calculate 4-point compensation or calibration G30 P3 X180 Y180 Z-99999 S-1 ; As previous example but just report the height errors
RepRapFirmware supports additional behaviour: if a Pn
field is specified the probed X
, Y
, and Z
values are saved as point n on the bed for calculating the offset plane or for performing delta printer calibration. If X
, Y
, or Z
values are specified (e.g. G30 P1 X20 Y50 Z0.3
) then those values are used instead of the machine's current coordinates. A silly Z
value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specified (e.g. G30 P1 Z0.3 S
) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1
commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup G-code file for automatic execution.
RepRapFirmware uses the value of the S
parameter to specify what computation to perform. If the value is -1 then the Z offsets of all the points probed are printed, but no calibration is done. If the value is zero or not present, then this specifies that the number of factors to be calibrated is the same as the number of points probed. Otherwise, the value indicates the number of factors to be calibrated, which must be no greater than the number of points probed. In version 1.09, the number of factors may be 3, 4 or 5 when doing auto bed compensation on a Cartesian or CoreXY printer, and 3, 4, 6 or 7 when doing auto calibration of a Delta printer.
RepRapFirmware supports an optional H
parameter, which is a height correction for that probe point. It allows for the Z probe having a trigger height that varies with XY position. The nominal trigger height of the Z probe (e.g. at bed centre) is declared in the Z
parameter of the G31
command in the config.g file. When you probe using G30
and the probe triggers, the firmware will assume that the nozzle is at the nominal trigger height plus the value you have in the H
parameter.
1MK4duo Firmware support an optional parameter for Delta.
- Usage
G30 Xnnn Ynnn S Z P
- Parameters
Xnnn
X coordinateYnnn
Y coordinateSn
Stows the probe if 1 (default=1)Zn
<bool> with a non-zero value will apply the result to current delta_heightPn
<bool> with a non-zero value will apply the result to current zprobe_zoffset
- Notes
In Prusa Firmware this G-code is deactivated by default, must be turned on in the source code.2
No | Yes | ??? | No | ??? | Yes: 0.91.7 | Yes | ??? | No | |
No | No | No | No | No | No | No | No | ??? |
- Usage
- Parameters
Pnnn
Trigger valueXnnn
Probe X offset1Ynnn
Probe Y offset1Znnn
Trigger Z heightCnnn
Temperature coefficient2Snnn
Calibration temperature2Tnnn
(RepRapFirmware 1.17 and later) Z probe type to which these parameters apply, defaults to the current Z probe type as defined byM558 P
parameter- Examples
G31 P500 Z2.6 G31 X16.0 Y1.5
When used on its own this reports whether the Z probe is triggered, or gives the Z probe value in some units if the probe generates height values. If combined with a Z and P field (example: G31 P312 Z0.7
) this will set the Z height to 0.7mm when the Z-probe value reaches 312 when a G28 Z0
(zero Z axis) command is sent. The machine will then move a further -0.7mm in Z to place itself at Z = 0. This allows non-contact measuring probes to approach but not touch the bed, and for the gap left to be allowed for. If the probe is a touch probe and generates a simple 0/1 off/on signal, then G31 Z0.7
will tell the RepRap machine that it is at a height of 0.7mm when the probe is triggered.
In RepRapFirmware, separate G31
parameters may be defined for different probe types (i.e. 0+4 for switches, 1+2 for IR probes and 3 for alternative sensors). To specify which probe you are setting parameters for, send a M558 command to select the probe type before sending the G31
command, or use the T
parameter.
In Repetier, G31
supports no parameters and simply prints the high/low status of the Z probe.
- Notes
1X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) can be specified in RepRapFirmware. This allows you to calculate your probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset.
2In RepRapFirmware, additional parameters 'S' (bed temperature in oC at which the specified Z
parameter is correct, default is current bed temperature) and 'C' (temperature coefficient of Z
parameter in mm/oC, default zero) can be set for the alternative (ultrasonic) sensor. This is useful for probes that are affected by temperature. This facility is deprecated and likely to be removed in a future version of RepRapFirmware.
Yes | No | No | No1 | ??? | No | No | ??? | Yes | |
No | No | No | No | No | Yes | No | No | No |
- Notes
In Prusa Firmware this G-code is deactivated by default, must be turned on in the source code.1
G29 | Yes | No | G29 | ??? | 0.92.8+ | Yes | ??? | No | |
- Usage
G32 ; Probe and calculate G32 Snnn ; Each firmware has its own parameters G32 Snnn Pnnn ; Refer to their specific documentation
This command is implemented as a more sophisticated form of bed leveling (which uses a transformation matrix or motorized correction. Smoothieware uses this code instead of `G29`.
Each firmware behaves differently. For example, Repetier firmware allows for motorized rotation of the bed whilst ReprapFirmware probes the bed with a transformation matrix.
Probe and calculate in Reprapfirmware
RepRapFirmware executes macro file bed.g
in response to the G31 command. The bed.g
file is typically used to probe the bed and then perform delta calibration if the printer is a delta, or to perform individual leadscrew adjustment to level the bed if the printer has multiple independently-controlled Z motors, or to advise the user on how much to adjust each bed levelling adjustment screw.
Probe and calculate in Repetier firmware
This command probes the bed at 3 or more pre-defined points and implements bed leveling compensation by either moving the A axis during printing (as with regular bed leveling, G29
) or by tilting the bed with motors.
- Parameters
Snnn
Bed leveling methodPnnn
Bed correction method
The values for Snnn and Pnnn are as follows:
S0
This method measures at the 3 probe points and creates a plane through these points. If you have a really planar bed this gives the optimum result. The 3 points must not be in one line and have a long distance to increase numerical stability.S1
This measures a grid. Probe point 1 is the origin and points 2 and 3 span a grid. We measure BED_LEVELING_GRID_SIZE points in each direction and compute a regression plane through all points. This gives a good overall plane if you have small bumps measuring inaccuracies.S2
Bending correcting 4 point measurement. This is for cantilevered beds that have the rotation axis not at the side but inside the bed. Here we can assume no bending on the axis and a symmetric bending to both sides of the axis. So probe points 2 and 3 build the symmetric axis and point 1 is mirrored to 1m across the axis. Using the symmetry we then remove the bending from 1 and use that as plane.P0
Use a rotation matrix. This will make z axis go up/down while moving in x/y direction to compensate the tilt. For multiple extruders make sure the height match the tilt of the bed or one will scratch. This is the default.P1
Motorized correction. This method needs a bed that is fixed on 3 points from which 2 have a motor to change the height. The positions are defined in firmware by BED_MOTOR_1_X, BED_MOTOR_1_Y, BED_MOTOR_2_X, BED_MOTOR_2_Y, BED_MOTOR_3_X, BED_MOTOR_3_Y Motor 2 and 3 are the one driven by motor driver 0 and 1. These can be extra motors like Felix Pro 1 uses them or a system with 3 z axis where motors can be controlled individually like the Sparkcube does. This method requires a Z max endstop.
- Notes
G33: Measure/List/Adjust Distortion Matrix (Repetier - Redeem)
No | No | No | No | ??? | 0.92.8+ | No | ??? | No | |
- Usage
G33
G33 Lnnn
G33 Rnnn
G33 Xnnn Ynnn Znnn
- Parameters
L0
List distortion matrix in a reportR0
Reset distortion matrixX[pos] Y[pos] Z[zCorrection]
Set correction for nearest point- Examples
G33 G33 R0
When used with no parameters, G33
will measure a grid of points and store the distortion dips and valleys in the bed surface, and then enable software distortion correction for the first few or several layers. The values will be stored in EEPROM if enabled in firmware. You must previously have G28
homed, and your Z minimum/maximum height must be set correctly for this to work. Use the optional parameters to list, reset or modify the distortion settings. Distortion correction behavior can be later turned on or off by code M323
G33: Delta Auto Calibration (Marlin 1.1.x - MK4duo)
Yes | Use G32 | ??? | No | ??? | No | No | ??? | Yes | |
End-stops and tower angle corrections are normalized (P0);
Performs a 1-4-7 point calibration of delta height (P1), end-stops, delta radius (P2) and tower angle corrections (P>=3) by a least squares iteration process based on the displacement method.
- Usage
G33
G33 Pn T Cx.xx Fn Vn E
- Parameters
Pn
Number of probe points: n*n (n= 0-10), when P is omitted the default set in Configuration.h is used.T
Do not calibrate tower angle corrections (if used with P>=3); do not use the probe points near the towers, but the probe points opposite to the towers (if used with P=2)Cx.xx
Force the iterations to stop when a standard deviation from the zero plane less then x.xx mm is achieved; when C is omitted the iterations go on until the best possible standard deviation is reached.Fn
Force to run at least n iterations (n=1-30) and take the best resultVn
Verbose level: (n=0-3) 0 = dry run without calibration; 1(default) = settings at start and end; 2 = settings at all iterations; 3 = settings and probe resultsE
Engage the probe for each point- Examples
G33 : calibrates with the default settings. G33 Auto Calibrate Checking... AC .Height:297.77 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 .Tower angle : Tx:+0.00 Ty:+0.00 Tz:+0.00 Iteration : 01 std dev:0.306 Iteration : 02 std dev:0.049 Iteration : 03 std dev:0.033 Iteration : 04 std dev:0.031 Calibration OK rolling back. .Height:297.69 Ex:-0.10 Ey:-0.12 Ez:+0.00 Radius:100.91 .Tower angle : Tx:-0.03 Ty:+0.25 Tz:+0.00 Save with M500 and/or copy to Configuration.h
G33 P6 V0 : probes 36 points in dry run mode. G33 Auto Calibrate Checking... AC (DRY-RUN) .Height:297.77 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 .Tower angle : Tx:+0.00 Ty:+0.00 Tz:+0.00 . c:+0.03 x:+0.32 y:+0.34 z:+0.41 . yz:+0.37 zx:+0.32 xy:+0.17 End DRY-RUN std dev:0.306
G33 P4 C0.05 T : probes 16 points and stops when a standard deviation of 0.05mm is reached; calibrates delta height, endstops and delta radius, leaves the tower angle corrections unaltered. G33 Auto Calibrate Checking... AC .Height:297.78 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 Iteration : 01 std dev:0.317 Iteration : 02 std dev:0.059 Calibration OK std dev:0.042 .Height:297.66 Ex:-0.17 Ey:-0.13 Ez:+0.00 Radius:100.91 Save with M500 and/or copy to Configuration.h
G33 P2 : probes center and tower positions and calibrates delta height, endstops and delta radius. G33 Auto Calibrate Checking... AC .Height:297.78 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 Iteration : 01 std dev:0.374 Iteration : 02 std dev:0.054 Iteration : 03 std dev:0.007 Calibration OK rolling back. .Height:297.68 Ex:-0.14 Ey:-0.14 Ez:+0.00 Radius:101.23 Save with M500 and/or copy to Configuration.h
G33 P1 : probes the center and calibrates the delta height only. G33 Auto Calibrate Checking... AC .Height:261.40 Offset:+0.30 Calibration OK std dev:0.000 .Height:261.58 Offset:+0.10 Save with M500 and/or copy to Configuration.h
note: Height = delta height; Ex, Ey, Ez = end-stop corrections; Radius = delta radius; Tx, Ty, Tz = tower angular corrections; c, x, y, z, yz, zx, xy = probe results at center, towers and opposite to towers; std dev = standard deviation of the probe results towards the zero plane.
G34: Z Stepper Auto-Align
Yes | No | No | No | ??? | No | No | ??? | No | |
Use multiple Z steppers and a probe to align Z axis connection points. See M422
for other options.
- Example
G34 I3 T0.8 A1.5 ; 3 iterations, Target Accuracy 0.8, Amplification 1.5
G34: Calculate Delta Height from toolhead position (DELTA)
No | No | No | No | ??? | No | No | ??? | Yes | |
- Example
G34
The user would typically place the toolhead at the zero point of the axis and issue the G34
command.
This value can be saved to EEPROM using the M500
command.
1.1.0+ | 3.0+ | ??? | No | ??? | ??? | Yes | ??? | Yes | |
Yes | No | No | No | No | No | No | No | No |
2.0.0+ | 3.0+ | ??? | No | ??? | ??? | ??? | ??? | No | |
Yes | No | No | No | Yes | No | No | Yes | No |
G40
turns off cutter compensation. If tool compensation was on the next move must be a linear move and longer than the tool diameter. It is OK to turn compensation off when it is already off.
http://www.linuxcnc.org/docs/2.5/html/gcode/tool_compensation.html
G42: Move to Grid Point
1.1.2+ | No | No | No | ??? | No | No | ??? | Yes | |
G42
does a fast move in XY to any of the intersection points in the bed calibration grid. This is useful during calibration to align the nozzle or probe.
- Parameters
Inn
Grid X index (zero-based). If omitted, the nearest latitude.Jnn
Grid Y index (zero-based). If omitted, the nearest longitude.P
Probe flag. Moves the probe to the grid point (instead of the nozzle).Fnnn
Feedrate (mm/m)- Example
G42 I3 J4 P F3000 ; Move the probe to grid coordinate 3, 4
G53..59: Coordinate System Select (CNC specific)
2.0.0+ | 1.21+ | No | No | ??? | No | Yes | ??? | No | |
Not all builds of RepRapFirmware support these commands. For those that do (e.g. Duet WiFi/Ethernet and Duet 3), from firmware version 2.02 the workplace coordinate offsets are included in the data saved to config-override.g by the M500 command.
G60: save current position to slot
No | 1.21+ | No | No | ??? | No | No | ??? | Yes | |
- Usage
G60 Snn
- Parameters
Snn
<nn> specifies memory slot # (0-based) to save into (default 0)
Implementation in RepRapFirmware:
- Slots 0, 1 and 2 are available from RepRapFirmware 1.21, also slots 4 and 5 in RRF 2.02. When a print is paused the coordinates are saved to slot 1 automatically, and at the start of a tool change the coordinates are saved to slot 2 automatically. Use G0 or G1 with the R0, R1 or R2 parameter to move the current tool to a saved position.
G61: Apply/restore saved coordinates to the active extruder.
No | Use G0 or G1 with R parameter | ??? | No | ??? | ??? | ??? | ??? | Yes | |
??? | ??? | ??? | ??? | ??? | ??? | ??? | Yes | ??? |
- Usage
G61 Xnnn Ynnn Znnn Ennn Fnnn Snn
- Parameters
Xnnn
X coordinateYnnn
Y coordinateZnnn
Z coordinateEnnn
E coordinateFnnn
F Set FeedrateSnn
S specifies memory slot # (0-based)
G75: Print temperature interpolation
No | No | No | Yes | ??? | No | No | ??? | No | |
Show/print PINDA temperature interpolating.
- Usage
G75
G76: PINDA probe temperature calibration
This G-code is used to calibrate the temperature drift of the PINDA (inductive Sensor).
The PINDAv2 sensor has a built-in thermistor which has the advantage that the calibration can be done once for all materials.
The Original i3 Prusa MK2/s uses PINDAv1 and this calibration improves the temperature drift, but not as good as the PINDAv2.
- Usage
G76
- Example
G76 echo PINDA probe calibration start echo start temperature: 35.0° echo ... echo PINDA temperature -- Z shift (mm): 0.---
No | No | ??? | No | ??? | ??? | ??? | ??? | No | |
Yes | ??? | ??? | ??? | ??? | No | ??? | No | ??? |
G80: Mesh-based Z probe
Default 3x3 grid can be changed on MK2.5/s and MK3/s to 7x7 grid.
- Parameters
N
Number of mesh points on x axis. Default is 3. Valid values are 3 and 7.R
Probe retries. Default 3 max. 10V
Verbosity level 1=low, 10=mid, 20=high.It can be only used if firmware has been compiled with SUPPORT_VERBOSITY active.
Using the following parameters enables additional "manual" bed leveling correction. Valid values are -100 microns to 100 microns.
L
Left Bed Level correct value in um.R
Right Bed Level correct value in um.F
Front Bed Level correct value in um.B
Back Bed Level correct value in um.
G81: Mesh bed leveling status
Prints mesh bed leveling status and bed profile if activated.
- Usage
G81
- Notes
Equivalent to G29 T in Marlin.
G82: Single Z probe at current location
No | No | No | Yes1 | ??? | No | No | ??? | No | |
WARNING! USE WITH CAUTION! If you'll try to probe where is no leveling pad, nasty things can happen!
- Usage
G82
- Notes
G83: Babystep in Z and store to EEPROM
- Usage
G83
- Notes
G84: UNDO Babystep Z (move Z axis back)
No | No | No | Yes 1 | ??? | No | No | ??? | No | |
- Usage
G84
- Notes
G85: Pick best babystep
- Usage
G85
- Notes
G86: Disable babystep correction after home
This G-code will be performed at the start of a calibration script.
- Usage
G86
G87: Enable babystep correction after home
This G-code will be performed at the end of a calibration script.
- Usage
G87
G88: Reserved
- Usage
G88
- Notes
Yes | Yes | Yes | Yes | ??? | Yes | Yes | ??? | Yes | |
- Example
G90
Yes | Yes | No | Yes | Yes | Yes | Yes | Yes | Yes |
- Example
G91
All coordinates from now on are relative to the last position. Note: RepRapFirmware latest revision firmware uses M83
to set the extruder to relative mode: extrusion is NOT set to relative by ReprapFirmware on G91
: only X,Y and Z are set to relative. By contrast, Marlin (for example) DOES also set extrusion to relative on a G91
command, as well as setting X, Y and Z.
G92: Set Position
- Parameters
Xnnn
new X axis positionYnnn
new Y axis positionZnnn
new Z axis positionEnnn
new extruder position- Example
G92 X10 E90
A G92
without coordinates will reset all axes to zero on some firmware. This does not apply to RepRapFirmware.
G92.x: Reset Coordinate System Offsets (CNC specific)
1.1.6+ | No | No | No | ??? | No | Yes | ??? | No | |
- Usage
G92.1
- Reset axis offsets (and parameters 5211-5219) to zero. (X Y Z A B C U V W
)G92.2
- Reset axis offsets to zero
Yes | ??? | ??? | ??? | ??? | No | ??? | Yes | ??? |
G93 is Inverse Time Mode. In inverse time feed rate mode, an F word means the move should be completed in (one divided by the F number) minutes. For example, if the F number is 2.0, the move should be completed in half a minute.
When the inverse time feed rate mode is active, an F word must appear on every line which has a G1
, G2
, or G3
motion, and an F word on a line that does not have G1
, G2
, or G3
is ignored. Being in inverse time feed rate mode does not affect G0
(rapid move) motions.
??? | No | ??? | ??? | ??? | ??? | ??? | ??? | No | |
G98: Activate farm mode
Enable Prusa-specific Farm functions and g-code.
- Usage
G98
- Notes
Set of internal Prusa commands
PRUSA [ Ping | PRN | FAN | fn | thx | uvlo | fsensor_recover | MMURES | RESET | fv | M28 | SN | Fir | Rev | Lang | Lz | Beat | FR ]
- Parameters
Ping
PRN
Prints revision of the printer.FAN
Prints fan details.fn
Prints farm number.thx
uvlo
Resets UVLO aka Power Panic and continues SD print.fsensor_recover
Filament sensor recover - restore print and continue.MMURES
Reset MMU.Reset
Resets Printer.fv
??? get file version. ???M28
M28 write to SD.SN
Get serial number from 32U2 processor. Typical format of S/N is:CZPX0917X003XC13518Fir
Prints firmware version.Rev
Prints filament size, elelectronics, nozzle type.Lang
Reset the language.Lz
??? maybe resets Live Z values to 0 ???Beat
Kick farm link timer.FR
Full factory reset.nozzle set 'diameter'
Set nozzle diameter.nozzle D'diameter'
Check nozzle diameter.nozzle
Print nozzle diameter
G99: Deactivate farm mode
- Usage
G99
No | No | No | No | ??? | 0.92+ | No | ??? | No | |
- Parameters
X
Flag to set floor for X axisY
Flag to set floor for Y axisZ
Flag to set floor for Z axisRnnn
Radius to add- Examples
G100 X Y Z ; set floor for argument passed in. Number ignored and may be absent. G100 R5 ; Add 5 to radius. Adjust to be above floor if necessary G100 R0 ; Set radius based on current z measurement. Moves all axes to zero
No | No | No | No | No | No | No | No | Yes |
- Example
G130 X10 Y18 Z15 A20 B12
G131: Remove offset
No | No | No | No | ??? | 0.91+ | No | ??? | No | |
G133: Measure steps to top
G161: Home axes to minimum
No | No | No | No | No | No | Yes | No | Yes |
- Parameters
X
Flag to home the X axis to its minimum positionY
Flag to home the Y axis to its minimum positionZ
Flag to home the Z axis to its minimum positionFnnn
Desired feedrate for this command- Example
G161 X Y Z F1800
Instruct the machine to home the specified axes to their minimum position. Similar to G28
, which decides on its own in which direction to search endstops.
G162: Home axes to maximum
- Parameters
X
Flag to home the X axis to its maximum positionY
Flag to home the Y axis to its maximum positionZ
Flag to home the Z axis to its maximum positionFnnn
G162 X Y Z F1800
G425: Perform auto-calibration with calibration cube
2.0.0+ | No | No | No | ??? | No | No | ??? | No | |
This performs an automatic calibration of backlash, positional errors and nozzle offset by touching the nozzle on the sides of a bed mounted, electrically conductive cube, washer or bolt.
- Parameters
B
Perform calibration of backlash only.Tnnn
Perform calibration of toolhead only.V
Probe cube and print position, error, backlash and hotend offset.Unnn
Uncertainty, how far to start probe away from the cube (mm)
- Examples (Marlin)
G425 ; Perform full calibration sequence T1 ; Switch to second nozzle G425 V ; Validate by showing report for T1 T0 ; Switch to second nozzle G425 V ; Validate by showing report for T0
M-commands
Yes | Yes | No | Yes3 | ??? | No | No | ??? | Yes | |
Yes | No | No | Yes | Yes | No | Yes | Yes | No |
- Parameters
Pnnn
Time to wait, in milliseconds1Snnn
Time to wait, in seconds2- Example
M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller, although this step is not mandatory on RepRapFirmware. See also M1
, M112
RepRapFirmware executes cancel.g if this file is present, if the print is paused and if the axes are homed. Otherwise stop.g is run and the drives are put into idle mode. Also the heaters are turned off if no 'H1' parameter is specified.
- Notes
1Not available in RepRapFirmware, but as a work-around G4
can be run before M0
2Only available on Marlin and Prusa Firmware.
3"Wait for user ..." is shown on LCD in Prusa Firmware.
M1: Sleep or Conditional stop
Yes | Yes | Yes | Yes | ??? | No | No | ??? | Yes | |
Yes | No | No | No | No | No | No | Yes | No |
- Example
M1
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can still be sent G and M codes, the first of which will wake it up again. See also M0
, M112
The Marlin and Prusa Firmware do the same as M0
If Marlin is emulated in RepRapFirmware, this does the same as M25 if the code was read from a serial or Telnet connection, else the macro file sleep.g
is run before all heaters and drives are turned off.
M2: Program End
Yes | No | No | No | No | No | Yes | Yes | Yes |
- Example
M2
Teacup firmware does the same as M84
Yes | Yes | No | No | ??? | Yes | Yes | ??? | No | |
Yes | No | No | No | No | No | Yes | Yes | No |
- Parameters
Snnn
Spindle RPM- Example
M3 S4000
Teacup firmware turn extruder on (same as M101
RepRapFirmware interprets this code only if in CNC mode (M453
), in laser mode (M452
) or a Roland mill has been configured.
In Repetier-Firmware in laser mode you need S0
..S255
to set laser intensity. Normally you use S255
to turn it on full power for moves. Laser will only fire during G1
/G2
/G3
moves and in laser mode (M452
Support | Marlin | RepRapFirmware | Klipper | Prusa | Buddy | Repetier | Smoothie | Druid | MK4duo |
Yes | No | No | No | ??? | Yes | No | ??? | No | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | MakerBot | |
- Example
M4 S4000
Yes | Yes | ??? | No | ??? | Yes | Yes | ??? | No | |
Yes | No | No | No | No | No | Yes | Yes | ??? |
- Example
M5
The spindle is turned off.
Teacup firmware turn extruder off (same as M103
M6: Tool change
No | No | ??? | No | ??? | No | ??? | ??? | No | |
??? | No | No | No | No | No | Yes | Yes | ??? |
- Example
M6
No | No | ??? | No | ??? | No | No | ??? | No | |
Yes | No | No | No | No | No | Yes: Use M106 | Yes | ??? |
- Example
M7
Teacup firmware turn on the fan, and set fan speed (same as M106
- Example
M8
- Example
M9
M10: Vacuum On (CNC specific)
??? | No | No | No | No | No | Yes: Use M106 | Yes | ??? |
- Example
M10
- Example
M11
M13: Spindle on (clockwise rotation) and coolant on (flood)
No | ??? | ??? | No | ??? | ??? | ??? | ??? | ??? | |
This one M-code does the work of both M03 and M08. It is not unusual for specific machine models to have such combined commands, which make for shorter, more quickly written programs.
- Example
M13
M16: Expected Printer Check
(2.0+) | No | ??? | No | ??? | No | No | ??? | Yes | |
Do a case-sensitive comparison between the string argument and the configured MACHINE_NAME
. If the machine name doesn't match, halt the printer so that a reset is required. This safety feature is meant to prevent G-code sliced for a specific machine from being used on any other machine. In Marlin this feature is enabled with EXPECTED_PRINTER_CHECK
- Example
M16 Cookie Monster
Yes | No | ??? | Yes | ??? | No | Yes | ??? | Yes | |
??? | No | No | No | No | Yes | (automatic) | No | ??? |
- Parameters
- This command can be used without any additional parameters.1
X
X axisY
Y axisZ
Z axisE
All extruders
- Example
M17 M17 X E0
Powers on stepper motors.
- Notes
1Ability to specify axes was added to Marlin 2.0 and may not be available on other firmware implementations.
M84 | Yes | ??? | M843 | ??? | No | Yes | ??? | Yes | |
??? | No | No | No | No | Yes | Yes: Use M2 | No | Yes |
- Parameters
- This command can be used without any additional parameters.13
X
X axisY
Y axisZ
Z axisE
Extruder drive(s)2S
Seconds3- Examples
M18 M18 X E0
On Marlin, M18
is a synonym of M84
, so it can also be used to configure or disable the idle timeout.
- Examples
M18 S10 ; Idle steppers after 10 seconds of inactivity M18 S0 ; Disable idle timeout
- Notes
2RepRapFirmware allows stepper motors to be disabled selectively. For example, M18 X E0:2
will disable the X, extruder 0 and extruder 2 motors.
3In Prusa Firmware this command can be used to set the stepper inactivity timeout (`S`) or to disable steppers (`X`,`Y`,`Z`,`E`)
M20: List SD card
??? | Yes | No | No | No | No | Yes | No | ??? |
- Parameters
Snnn
Output style1Pnnn
Directory to list2- Examples
M20 M20 S2 P/gcodes/subdir
ok SQUARE.G SQCOM.G ZCARRI~2.GCO CARRIA~1.GCO
On Marlin, a file list response is usually encapsulated. Standard configurations of RepRapFirmware mimic this style in emulation mode:
Begin file list: SQUARE.G ZCARRI~2.GCO End file list ok
G-code files: "Traffic cone.g","frog.gcode","calibration piece.g"
Note that some firmwares list file names in upper case, but - when sent to the M23
command (below) they must be in lower case. Teacup and RepRapFirmware have no such trouble and accept both. RepRapFirmware always returns long filenames in the case in which they are stored.
- Notes
1If the S2 parameter is used on RepRapFirmware, then the file list is returned in JSON format as a single array called "files" with each name that corresponds to a subdirectory preceded by an asterisk, and the directory is returned in variable "dir".
- Example
M20 S2 P/gcodes {"dir":"\/gcodes","files":["4-piece-1-2-3-4.gcode","Hinged_Box.gcode","Hollow_Dodecahedron_190.gcode","*Calibration pieces"]}
2This parameter is only supported by RepRapFirmware and defaults to the 0:/gcodes directory, which is the directory that printable gcode files are normally stored in.
M21: Initialize SD card
- Parameters
Pnnn
SD card number (RepRapFirmware only, default 0)- Examples
M21 M21 P1
The specified SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
M22: Release SD card
Yes | Yes | ??? | Yes | ??? | Yes | No | ??? | Yes | |
- Parameters
Pnnn
M22 M22 P1
The specified SD card is released, so further (accidental) attempts to read from it are guaranteed to fail. Helpful, but not mandatory before removing the card physically.
M23: Select SD file
- Example
M23 filename.gco
M24: Start/resume SD print
No | Yes | No | No | No | Yes | Yes | No | No |
- Example
M24
The machine prints from the file selected with the M23
command. If the print was previously paused with M25
, printing is resumed from that point. To restart a file from the beginning, use M23
to reset it, then M24
When this command is used to resume a print that was paused, RepRapFirmware runs macro file resume.g
prior to resuming the print.
M25: Pause SD print
- Example
M25
The machine pauses printing at the current position within the file. To resume printing, use M24. Do not use this code to pause the print in a G-code file, use M226 instead.
Prior to pausing, RepRapFirmware runs macro file pause.g
. This allows the head to be moved away from the print, filament to be retracted, etc.
RepRapFirmware 1.20 and later also save the current state of the print to file /sys/resurrect.g. This is so that if the printer is turned off after pausing, the print can subsequently be resumed.
M26: Set SD position
Yes | Yes | ??? | Yes | ??? | Yes | aborts | ??? | Yes | |
??? | Yes | No | No | No | No | No | No | ??? |
- Parameters
Snnn
File position from start of file in bytesPnnn
(Optional, RepRapFirmware only) Proportion of the first move to be skipped, default 0.0, must be less than 1.0- Example
- M26 S49315
Set the file offset in bytes from the start of the SD card file selected by M23. The offset must correspond to the start of a G-code command.
M27: Report SD print status
- Parameters
- C Report the open file's name and long name (Marlin 1.1.9 and up)
- Sn Set the auto-report interval (Marlin 1.1.9 and up)
- Example
M27
Report SD print status.
Marlin and RepRapFirmware report the number of bytes processed in this format, which can be processed by Pronterface:
SD printing byte 2134/235422
Not SD printing.
In Marlin 1.1.9 and up M27 C
reports the open file's DOS 8.3 name and long filename, if any.
- Example
M27 C
Current file: filena~1.gco Filenagotcha.gcode
In Marlin 1.1.9 and up M27 Sn
sets the auto-report interval. This requires the AUTO_REPORT_SD_STATUS
configuration option to be enabled. Marlin reports this capability in M115
as Cap: AUTO_REPORT_SD_STATUS 1
when this option is available.
- Example
M27 S2 ; Report the SD card status every 2 seconds
M28: Begin write to SD card
- Example
M28 filename.gco
M29: Stop writing to SD card
Yes | Yes | ??? | No1 | ??? | Yes | No | ??? | Yes | |
- Example
M29 filename.gco
File opened by M28
command is closed, and all subsequent commands sent to the machine are executed as normal.
- Notes
1Prusa firmware accepts this code but currently has no effect.
Yes | Yes | ??? | Yes | ??? | Yes | Yes | ??? | Yes | |
Yes | Yes | No | No | No | No | No | No | ??? |
- Example
> M30 filename.gco > filename.gco is deleted.
M30: Program Stop
Yes | No | No | No | No | No | No | Yes | ??? |
- For Yaskawa and in grbl - Same as M2 in Yaskawa G-code
- Example
M30 ; Exchange pallet shuttles and end the program. Pressing cycle start will start the program at the beginning of the file.
M31: Output time since last M109
or SD card start to serial
Yes | No | ??? | Yes | ??? | No | No | ??? | Yes | |
- Example
M31
The response looks like:
echo:54 min, 38 sec
Yes | Yes | ??? | Yes | ??? | No | Yes | ??? | Yes | |
- Example
M32 filename.gco
It can be used when printing from SD card and does the same as M23
and M24
Yes | Not required | ??? | No | ??? | No | No | ??? | No | |
M33: Stop and Close File and save restart.gcode
No | No: Use M25 | ??? | No | ??? | ??? | ??? | ??? | Yes | |
??? | ??? | ??? | ??? | ??? | ??? | ??? | No | ??? |
Stop the printing from SD and save all position in restart.gcode for restart printing in future
Yes | No | ??? | No | ??? | No | No | ??? | Yes | |
M35: Upload firmware NEXTION from SD
No | ??? | ??? | No | ??? | ??? | ??? | ??? | Yes | |
M36: Return file information
- Example
M36 filename.gco
{"err":0,"size":436831,"lastModified":"2017-09-21T16:58:07","height":5.20,"firstLayerHeight":0.20,"layerHeight":0.20,"printTime":660,"simulatedTime":1586,"filament":[1280.7],"generatedBy":"Simplify3D(R) Version 4.0.0"}
The "err" field is zero if successful, nonzero if the file was not found or an error occurred while processing it. The "size" field should always be present if the operation was successful. The presence or absence of other fields depends on whether the corresponding values could be found by reading the file. The "filament" field is an array of the filament lengths required from each spool. The size is in bytes, the times are in seconds, all other values are in mm. 'printTime' is the printing time estimated by the slicer, 'simulationTime' is the time measured when the print was simulated by the firmware. The fields may appear in any order, and additional fields may be present.
If the file name parameter is not supplied and a file on the SD card is currently being printed, then information for that file is returned including additional field "fileName". This feature is used by the web interface and by PanelDue, so that if a connection is made when a file is already being printed, the name and other information about that file can be shown.
M37: Simulation mode
- Parameters
- S1 Enter simulation mode
- S0 Leave simulation mode
- P"filename" (optional) Simulate printing a file from SD card
- Examples
- M37 S1
- M37 P"MyModel.g"
M37 S1 enters simulation mode. All G and M codes will not be acted on, but the time they would take to execute will be calculated.
M37 S0 leaves simulation mode and prints the total time taken by simulated moves since entering simulation mode.
M37 P"filename" enters simulation mode, prints the specified file, exits simulation mode, reports the print time, and appends it to the G-code file as a comment for later retrieval.
M38 Compute SHA1 hash of target file
Used to compute a hash of a file on the SD card. Examples:
> M38 gcodes/myfile.g > Cannot find file > M38 www/reprap.htm > 91199139dbfadac15a18cfb962dfd4853db83999
Returns a hexadecimal string which is the SHA1 of the file. If the file cannot be found, then the string "Cannot find file" is returned instead.
M39 Report SD card information
No | Yes: 1.20.1 and later | ??? | No | ??? | No | No | ??? | Yes | |
- Parameters
- Pn SD slot number, default 0
- Sn Response format. S0 returns a plain text response, S2 returns a response in JSON format.
- Examples
- M39 ; report information for SD card 0 in plain text format
- M39 P1 S2 ; report information for SD card 1 in JSON format
This command returns information about the SD card in the specified slot in the requested format. At least the following is returned:
- Whether or not a usable card is present in the slot
- The capacity of the card in bytes (if a card is present)
- The amount of free space on the card in bytes (if a card is present)
The JSON response has the following format (more fields may be added in future):
{"SDinfo":{"slot":0,"present":1,"capacity":4294967296,"free":2147485184,"speed":20971520,"clsize":32768}}
The capacity, free space and cluster size are in bytes, and the interface speed is in bytes/second.
M40: Eject
If your RepRap machine can eject the parts it has built off the bed, this command executes the eject cycle. This usually involves cooling the bed and then performing a sequence of movements that remove the printed parts from it. The X, Y and Z position of the machine at the end of this cycle are undefined (though they can be found out using the M114
command, q.v.).
See also M240
and M241
below.
M41: Loop
- Example
M41
- When you press the reset button,
- When the build material runs out (if your RepRap is set up to detect this), and
- When there's an error (such as a heater failure).
M42: Switch I/O pin
??? | Yes | No | No | No | No | No | No | No |
- Parameters
Pnnn
Pin numberSnnn
Pin value- Example
M42 P7 S255
M42 switches a general purpose I/O pin. Use M42 Px Sy
to set pin x to value y, when omitting Px the LEDPIN will be used.
In RepRapFirmware, the S field may be in the range 0..1 or 0..255. The pin reference is an internal firmware reference named "digital pin", see Duet pinout. It maps on different connector pins depending the hardware. On Duet 0.6 and 0.8.5 hardware using pre-1.16 firmware, the supported pin numbers and their names on the expansion connector are:
P | Name | Expansion Port Pin |
16 | TXD1 | 11 |
17 | RXD1 | 12 |
18 | TXD0 | 13 |
19 | RXD0 | 14 |
20 | TWD1 | 35 |
21 | TWCK1 | 36 |
23 | PA14 | 10 |
36 | PC4 | 18 |
52 | AD14 | 41 |
67 | PB16 | 32 |
In firmware 1.16, the pin numbering has changed.
60 | PA10/RXD0 | 14 |
61 | PA11/TXD0 | 13 |
62 | PA12/RXD1 | 12 |
63 | PA13/TXD1 | 11 |
64 | PA14/RTS1 | 10 |
65 | PB12/TWD1 | 35 |
66 | PB13/TWCK1 | 36 |
67 | PB16/DAC1* | 32 |
68 | PB21/AD14 | 41 |
69 | PC4 | 18 |
- Also used as CS signal on external SD card socket
P | Signal Name | Expansion Connector Label | Expansion Pin |
60 | CS5 | CS5 | 50 |
61 | CS6 | E3_STOP | 9 |
62 | CS7 | E4_STOP | 14 |
63 | CS8 | E5_STOP | 19 |
See Using servos and controlling unused I/O pins for all pin definitions.
Pre-1.16 example:
M42 P20 S1 ;set the connector pin 35 to high.
See also M583
- Example
M43
M43: Pin report and debug
- Usage
M43 En Pnnn Wn In
- Parameters
En
Enable / disable background endstop monitoringPnnn
Pin to read or watch. If omitted, read/watch all pinsWn
bool watch pins -reporting changes- until reset, click, orM108
In
bool Flag to ignore pin protection
- Note
- You must have
PINS_DEBUGGING
uncommented in yourConfiguration_adv.h
file for M43 to work.
M44: Codes debug - report codes available
??? | ??? | ??? | ??? | ??? | ??? | ??? | ??? | Yes | |
In MK4duo must have ability FASTER_GCODE_EXECUTE for this function.
- Parameters
In
G-code listJn
M-code list
M44: Reset the bed skew and offset calibration
??? | ??? | ??? | Yes | ??? | ??? | ??? | ??? | ??? | |
Resets the bed skew and offset calibration on Prusa i3 MK2/s,MK2.5/s,MK3/s.
M45: Bed skew and offset with manual Z up
Runs the xyz calibration on Prusa i3 MK2/s,MK2.5/s,MK3/s.
- Parameters
Vnn
Verbosity level 1, 10 and 20 (low, mid, high). Only when SUPPORT_VERBOSITY is defined. This parameter is optional.
M46: Show the assigned IP address
Reports the assigned IP address of a Toshiba FlashAir on Prusa i3 MK2/s,MK2.5/s,MK3/s. At this moment it is deactivated.
M47: Show end stops dialog on the display
Show end stops dialog on the display on Prusa i3 MK2/s,MK2.5/s,MK3/s.
Yes | No | ??? | Yes1 | ??? | No | No | ??? | Yes | |
No | No | No | No | No | No | No | No | No |
- Parameters
Pnnn
number of pointsXnnn
position on the X axisYnnn
position on the Y axisVnnn
verbosityE
engageLnnn
legs of travelS
schizoid
As with G29
, the E flag causes the probe to stow after each probe.
The S flag will result is a random sized, 5 pointed star, being traced (X and Y axis) between each sample. Usually a user will get worse repeat-ability numbers with S specified because the X axis and Y axis movements will add to the machine's positioning errors.
- Prusa specific 1
This function assumes the bed has been homed. Specifically, that a G28 command as been issued prior to invoking the M48 Z-Probe repeatability measurement function. Any information generated by a prior G29 Bed leveling command will be lost and need to be regenerated.
The number of samples will default to 10 if not specified. You can use upper or lower case letters for any of the options EXCEPT n. n must be in lower case because Marlin uses a capital N for its communication protocol and will get horribly confused if you send it a capital N.
- Usage
M48 nAA Xnnnn Ynnnn Vn Lnn
- Parameters
nAA
number(AA) of samples, default=10 (valid values between 4 and 50)Xnnn
X position for samplesYnnn
Y position for samplesVn
Verbosity level 1-4 (low to highest)Lnn
Legs of travel 1-15
M49: Set G26 debug flag
- Usage
- M49 S1 ; Enable G26 verbose debug output
M70: Display message
M117 | M117 | No | No | ??? | M117 | M117 | ??? | No | |
No | No | No | No | No | M117 | No | M117 | Yes |
- Example
M70 P200 Message
Display a message on the LCD. P
is the time to display message for.
M72: Play a tone or song
M300 | M300 | No | M300 | ??? | No | No | ??? | No | |
No | No | No | No | No | No | No | No: See M300 | Yes |
- Example
M72 P2
M73: Set/Get build percentage
- Example
M73 P50
Tell the firmware the current build progress percentage. The machine is expected to display this on its display. If the percentage is exactly 0 a "Build Start" notification is sent to the host. If the percentage is exactly 100 a "Build End" notification is sent to the host.
Use "M73" by itself to get a report of the current print progress.
- Prusa specific1
Prusa firmware just shows percent done and time remaining.
- Usage
M73 P R Q S
- Parameters
P
Percent in normal modeR
Time remaining in normal modeQ
Percent in silent modeS
Time remaining in silent mode- Examples
M73 echo NORMAL MODE: Percent done: ---%; print time remaining in mins: -----" echo SILENT MODE: Percent done: ---%; print time remaining in mins: -----"
M75: Start the print job timer
Yes | No | No | No | ??? | No | No | ??? | Yes | |
M76: Pause the print job timer
M77: Stop the print job timer
M78: Show statistical information about the print jobs
M80: ATX Power On
Yes | Yes | ??? | Yes1 | ??? | Yes | No | ??? | Yes | |
No | Yes | No | No | No | No | automatic | No | ??? |
- Examples
M80 ; Turn on the power supply M80 S ; Report power supply state (Marlin 1.1.1)
- Notes
- Marlin requires the
POWER_SUPPLY
configuration option to be set to a non-zero value to enableM80
. - Some firmwares (e.g., Teacup) handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off.
- Prusa requires
defined (PS_ON_PIN)
andPS_ON_PIN
must be set.1
M81: ATX Power Off
No | Yes | No | No | No | Yes | automatic | No | ??? |
- Parameters
- P quit the daemon (redeem only)
- R restart the daemon (redeem only)
- Sn n=0 turn power off immediately (default), n=1 turn power off when all thermostatic fans have turned off (RepRapFirmware 1.20 and later only)
- Examples
- M81 ; turn power off immediately
- M81 S1 ; turn power off when everything has cooled down (RepRapFirmware)
Turns off the ATX power supply. Counterpart to M80
- Notes
- Prusa requires
defined (PS_ON_PIN)
andPS_ON_PIN
must be set to Power off.1
??? | Yes | No | No | No | No | Yes | Yes | ??? |
- Example
M82
This is the default in repetier and for Yaskawa controllers.
- Example
M83
Note that the Ultimaker 3 will revert back to absolute extrusion after each tool change.
M84: Stop idle hold
Yes | Yes | ??? | Yes2 | ??? | Yes | Yes | ??? | Yes | |
??? | Yes | No | No | No | Yes | Yes | No | ??? |
- Parameters
Innn
Reset flags1- Example
M84
On Marlin, Repetier and RepRapFirmware, M84
can also be used to configure or disable the idle timeout. For example, "M84 S10" will idle the stepper motors after 10 seconds of inactivity. "M84 S0" will disable idle timeout; steppers will remain powered up regardless of activity.
For Yaskawa systems M84 is not applicable due to servo motors not producing the annoying noises.
- Notes
1RepRapFirmware-dc42 and other firmware may not support this parameter.
2Prusa firmware uses M84
similar to G-code#M18:_Disable_all_stepper_motors
- Prusa Usage
M84 E S X Y Z
- Prusa Parameters
- This command can be used without any additional parameters.2
E
Extruder drive(s)2S
SecondsX
X axisY
Y axisZ
Z axis
M85: Set Inactivity Shutdown Timer
Yes | No | ??? | Yes | ??? | Yes | No | ??? | Yes | |
- Example
M85 S30
Set Inactivity Shutdown Timer with parameter S<seconds>. "M85 S0" will disable the inactivity shutdown time (default)
M86: Set Safety Timer expiration time
No | No | ??? | Yes | ??? | No | No | ??? | No | |
- Usage
M86 Snnnn
- Parameters
S
Seconds
Similar to M85
but applies to the "safety timer" in Prusa Firmware.
Sets the safety timer expiration time in seconds. M86 S0 will disable safety timer.
When safety timer expires, heatbed and nozzle target temperatures are set to zero.
M92: Set axis_steps_per_unit
??? | Yes | No | No | No | Yes | No | No | ??? |
- Parameters
Xnnn
Steps per unit for the X driveYnnn
Steps per unit for the Y driveZnnn
Steps per unit for the Z driveEnnn
Steps per unit for the extruder drive(s)Snnn
Defines in which microstepping the above steps per unit are given. If omitted it will use the microstepping currently set by M350.1- Examples
M92 X87.489 Y87.489 Z87.489 M92 E420:420
Allows programming of steps per unit (usually mm) for motor drives. These values are reset to firmware defaults on power on, unless saved to EEPROM if available (M500
in Marlin) or in the configuration file (config.g in RepRapFirmware). Very useful for calibration.
RepRapFirmware will report the current steps/mm if you send M92
without any parameters.
For Yaskawa systems M92/M93 is not applicable due to use of servo motors.
- Notes
1 Only available in RepRapFirmware >=2.03
M93: Send axis_steps_per_unit
No | Use M92 | ??? | ??? | ??? | ??? | No | ??? | No | |
M98: Call Macro/Subprogram
No | Yes | ??? | No | ??? | No | No | ??? | No | |
??? | No | No | No | No | No | No | Yes | No |
- Parameters
Pnnn
Macro filename- Example
M98 Pmymacro.g
Runs the macro in the file mymacro.g. In conventional G Codes for CNC machines the P
parameter normally refers to a line number in the program itself (P2000 would run the Macro starting at line O2000, say). For RepRap, which almost always has some sort of mass storage device inbuilt, it simply refers to the name of a G-code file that is executed by the G98
call. That G-code file does not need to end with an M99
(return) as the end-of-file automatically causes a return. RepRapFirmware supports nested macro calls up to a depth of 5.
Certain machine parameters are saved at the start of the macro call and restored at the end. For RepRapFirmware these are: axis movement relative/absolute mode, extruder movement absolute/relative mode, feed rate.
RepRapFirmware also allows the filename to include a path to a subdirectory. For relative paths, the default folder is /sys, but some implementations may check the /macros directory too. Absolute file paths are supported on RepRapFirmware too.
- Example
M99
Returns from an M98
call.
No | Yes: 1.17c and later | ??? | No | ??? | No | No | ??? | No | |
??? | No | Yes | No | No | No | Yes | No | ??? |
In Teacup firmware:
If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103
In BFB/RapMan: Turn extruder on (forward/filament in).
In RepRapFirmware: undo filament retraction. The length and speed are set by the M207
command. RepRapFirmware supports this command for compatibility with Simplify3D.
In other firmwares:
Deprecated. Regarding filament retraction, see G10
, G11
, M207
, M208
, M227
, M228
, M229
??? | No | Yes | No | No | No | No | No | ??? |
In other firmwares: Deprecated.
In Teacup firmware:
If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101
In RepRapFirmware: retract filament. The length and speed are set by the M207
In other firmwares: Deprecated. Regarding filament retraction, see G10
, G11
, M207
, M208
, M227
, M228
, M229
??? | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
- Parameters
Snnn
Target temperatureRnnn
Idle temperature (Only MK4duo)
- Example
M104 S190 M104 S190 R170
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). See also M109.
See also using G10. Deprecation of M104
is subject to discussion. --Traumflug 11:33, 19 July 2012 (UTC)
M104 in Marlin Firmware
See Marlin Wiki. In Marlin Firmware, using M104
with no parameters will turn off the heater for the current extruder. This is also the case for M104 S
without a number after the S
parameter.
M104 in Teacup Firmware
In Teacup Firmware, M104
can be additionally used to handle all devices using a temperature sensor. It supports the additional P
parameter, which is a zero-based index into the list of sensors in config.h. For devices without a temp sensor, see M106.
- Example
M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100°C.
M104 in Duet-dc42
Duet-dc42 and other firmware also supports the optional T
parameter (as generated by slic3r) to specify which tool the command applies to.
Yes | Yes | ??? | Yes1 | ??? | Yes | Yes | ??? | Yes | |
??? | Yes | No | Yes | No | Yes | Yes | No | Yes |
- Parameters
Rnnn
Response sequence number1Snnn
Response type1- Examples
M105 M105 S2
Request the temperature of the current extruder, the build base and the build chamber in degrees Celsius. The temperatures are returned to the host computer. For example, the line sent to the host in response to this command can look like:
ok T:201 B:117 ok T:201 /202 B:117 /120 ok T:201 /202 B:117 /120 C:49.3 /50 ok T:201 /202 T0:110 /110 T1:23 /0 B:117 /120 C:49.3 /50 ok T0:110 /110 T1:23 /0 B:117 /120 ok T:20.2 /0.0 B:19.1 /0.0 T0:20.2 /0.0 @:0 B@:0 P:19.8 A:26.4
The parameters mean the following:
- T, T0, ..., Tn - extruder temperature. In a single extruder setup, only T will be reported. Some firmware variants will report no T0 in multi extruder setups - in that case T is to be considered the temperature of the first tool. Otherwise, T should be considered the temperature of the currently selected tool (which will be repeated in one of the Tn entries)
- B - bed temperature
- C - chamber temperature
- @ - Hotend power (Prusa only)1
- B@ - Bed power (Prusa only)1
- P - PINDAv2 actual (Prusa MK2.5/s MK3/s only)1
- A - Ambient actual (Prusa MK3/s only)1
A temperature report will usually include actual and target temperature for all available heaters, with the format being "actual/target" or - for some firmware variants - "actual /target". During a blocking heatup some firmware variants only report the temperature tuple for the heater that is currently in blocking heatup state.
Note that temperatures can be reported as integers or floats. There sadly are a lot of interpretations of how an M105 response should look like across firmware variants, making parsing them potentially tricky.
Expansion/generalization of M105
to be considered using S1 parameter as noted in Pronterface I/O Monitor
In Repetier and MK4duo you can add X0 (X1 MK4duo) to get raw values as well:
M105 X0 ==> 11:05:48.910 : T:23.61 /0 @:0 T0:23.61 /0 @0:0 RAW0:3922 T1:23.89 /0 @1:0 RAW1:3920
- Notes
1These parameters are only supported by RepRapFirmware, which returns a JSON-formatted response if parameter S2 or S3 is specified. Additionally, parameter Rnn may be provided, where nn is the sequence number of the most recent G-code response that the client has already received. M105 S2
is equivalent to M408 S0
, and M105 S3
is equivalent to M408 S2.
Usage of these forms of M105
is deprecated, please use M408
instead.
M106: Fan On
??? | Yes | Yes | Yes | Yes | Yes | Yes | Yes | ??? |
- Parameters
Pnnn
Fan number (optional, defaults to 0)2Snnn
Fan speed (0 to 255; RepRapFirmware also accepts 0.0 to 1.0))- Extra Parameters
Innn
Invert signal, or disable fan1 3Fnnn
Set fan PWM frequency, in Hz1 3Lnnn
Set minimum fan speed (0 to 255 or 0.0 to 1.0)1 3Xnnn
Set maximum fan speed (0 to 255 or 0.0 to 1.0)1 3Bnnn
Blip time - fan will be run at full PWM for this number of seconds when started from standstill1Hnn:nn:nn...
Select heaters monitored when in thermostatic mode1 3Rnnn
Restore fan speed to the value it has when the print was paused1Tnnn
Set thermostatic mode trigger temperatureCnnn
Set custom name (RRF > 2.01 only)1- Example
M106 S127
M106 P1 I1 S87 M106 P1 T45 H1:2 M106 P2 B0.1 L0.05
The first example turns on the default cooling fan at half speed. The second one inverts the cooling fan signal of the second fan and sets its value to 1/3 of its maximum. The third one sets the second fan to a thermostatic fan for heaters 1 and 2 (e.g. the extruder heaters in a dual-nozzle machine) such that the fan will be on when either hot end is at or above 45C.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0
turns the fan off. In some implementations like RepRapFirmware the PWM value may alternatively be specified as a real fraction: M106 S0.7
- Notes
2Marlin 1.0 to 1.1.6 only supports a single fan. Marlin 1.1.7 and up supports up to 3 fans.
3These parameters are only available in MK4duo.
M106 in RepRapFirmware
If an S
parameter is provided but no other parameter is present, then the speeds of the print cooling fans associated with the current tool will be set (see the F
parameter in the M563
command). If no tool is active then the speed of Fan 0 will be set. Either way, the speed is remembered so that it can be recalled using the R2
parameter (see below).
If no S
parameter is given but the R1 parameter is used, the fan speed when the print was last paused will be set. If the R2
parameter is used, then the speeds of the print cooling fans associated with the current tool will be set to the remembered value (see above).
The T
and H
parameters allow a fan to be configured to operate in thermostatic mode, for example to use one of the fan channels to control the hot end fan. In this mode the fan will be fully on when the temperature of any of the heaters listed in the H
parameter is at or above the trigger temperature set by the T
parameter, and off otherwise. Thermostatic mode can be disabled using parameter H-1.
The B
parameter sets the time for which the fan will be operated at full PWM when started from cold, to allow low fan speeds t be used. A value of 0.1 seconds is usually sufficient.
The L
parameter defines the minimum PWM value that is usable with this fan. If a lower value is commanded that is not zero, it will be rounded up to this value.
The X
parameter defines the maximum PWM value that is allowed for this fan. If a higher value is commanded, it will be rounded down to this value.
The I
parameter causes the fan output signal to be inverted if its value is greater than zero. This makes the cooling fan output suitable for feeding the PWM input of a 4-wire fan via a diode. If the parameter is present and zero, the output is not inverted. If the I
parameter is negative then in RRF 1.16 and later the fan is disabled, which frees up the pin for use as a general purpose I/O pin that can be controlled using M42
M106 in Teacup Firmware
Additionally to the above, Teacup Firmware uses M106
to control general devices. It supports the additional P
parameter, which is an zero-based index into the list of heaters/devices in config.h.
- Example
M106 P2 S255
Note: When turning on a temperature sensor equipped heater with M106
and M104
at the same time, temperature control will override the value given in M106
quickly.
Note well: The ambiguous text in the note above needs to be reworded by someone who knows the actual functioning. Below is my interpretation based on language use, not practical experience or code inspection.
Note: If M104
is (or becomes) active on a heater (or other device) with a feedback sensor it will correct any M106
initiated control output value change in the time it takes for the PID (of other feedback) loop to adjust it back to minimum error. It may not be easy to observe a change in the temperature (process value) due to this brief change in the control value
M107: Fan Off
??? | Yes | Yes | Yes | Yes | Yes | No | Yes | ??? |
Deprecated in Teacup firmware and in RepRapFirmware. Use M106 S0
instead.
M108: Cancel Heating
Yes | Yes | ??? | ??? | ??? | No | No | ??? | Yes | |
Breaks out of an M109
or M190
wait-for-temperature loop, continuing the print job. Use this command with caution! If cold extrusion prevention is enabled (see M302
) and the temperature is too low, this will start "printing" without extrusion. If cold extrusion prevention is disabled and the hot-end temperature is too low, the extruder may jam.
This command was introduced in Marlin 1.1.0. As with other emergency commands [e.g., M112
] this requires the host to leave space in the command buffer, or the command won't be executed until later.
Recent versions of Marlin introduce EMERGENCY_PARSER
, which overcomes the buffer limitation by watching the incoming serial stream. Commands M108, M112, M410, and M876 can all be intercepted by the emergency parser, so it is recommended to enable this feature.
M108: Set Extruder Speed (BFB)
Sets speed of extruder motor.
(Deprecated in FiveD firmware, see M113
??? | Yes | No | Yes | Yes | Yes | not needed | Yes | Yes |
- Parameters
Snnn
minimum target temperature, waits until heatingRnnn
maximum target temperature, waits until cooling (Sprinter)Rnnn
accurate target temperature, waits until heating and cooling (Marlin and MK4duo)- Example
M109 S215
M109 in Teacup
M109 in Marlin, MK4duo, Sprinter (ATmega port), RepRapFirmware, Prusa
- Example
M109 S185
RepRapFirmware also supports the optional T
parameter (as generated by slic3r) to specify which tool the command refers to (see below).
M109 in Sprinter (4pi port)
Parameters: S
(optional), set target temperature value. If not specified, waits for the temperature set by M104. R
(optional), sets target temperature range maximum value.
- Example
M109 S185 R240 ; set extruder temperature to 185 and wait for the temperature to be between 185 - 240.
If you have multiple extruders, use T
or P
parameter to specify which extruder you want to set/wait.
M109 in MakerBot
- Example
M109 S70 T0
M110: Set Current Line Number
??? | No | No | Yes | No | Yes | not needed | No | ??? |
- Parameters
Nnnn
Line number- Example
M110 N123
M111: Set Debug Level
Yes | Yes | ??? | No2 | ??? | Yes | No | ??? | Yes | |
??? | No | No | Yes | No | Yes | Debug | No | ??? |
- Parameters
Pnnn
Debug module1Snnn
Debug on/off- Examples
M111 S6 M111 P1 S1
- Notes
2Prusa fimrware use D-codes/commands for debugging.
M111 in RepRapFirmware
RepRapFirmware allows debugging to be set for each module. If the optional 'P' parameter is not specified, debugging will be enabled for all modules. For a list of modules, send M111 S1 P15
M111 in Repetier
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2) #define DEBUG_DRYRUN (1<<3) // repetier-firmware #define DEBUG_COMMUNICATION (1<<4) // repetier-firmware
For firmware that supports ethernet and web interfaces M111 S9
will turn web debug information on without changing any other debug settings, and M111 S8
will turn it off. Web debugging usually means that HTTP requests will be echoed to the USB interface, as will the responses.
M112: Full (Emergency) Stop
??? | No | No | Yes | No | Yes | Yes | No | ??? |
- Example
M112
Any moves in progress are immediately terminated, then RepRap shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M0
and M1
Please note while many systems termed this an Emergency Stop, this terminology is regulated in many regions with specific requirements behind its use. Marlin 2.0.x has renamed this to Full Stop. RepRapFirmware has indicated an intention to make a similar change as well. This stop function is NOT implemented in a Category 0 or 1 stop fashion or with fail-safe hardware compliying with PLd or better. The function as implemented is a category 2 software stop with no redundancies.
M113: Set Extruder PWM
??? | No | No | Yes | No | No | No | No | ??? |
- Example
M113
M113 S0.7
it causes the PWM to be set to the S
value (70% in this instance). M113 S0
turns the extruder off, until an M113
command other than M113 S0
is sent.
M113: Host Keepalive
1.1.9+ | No | ??? | Yes | ??? | No | No | ??? | Yes | |
??? | No | No | No | No | No | No | No | ??? |
During some lengthy processes, such as G29, Marlin may appear to the host to have “gone away.” The “host keepalive” feature will send messages to the host when Marlin is busy or waiting for user response so the host won’t try to reconnect.
- Usage
M113 Snnn
- Parameters
Snnn
keepalive interval to set- Examples
M113 S2
M114: Get Current Position
- Example
M114
Yes | Yes | ??? | Yes2 | ??? | Yes | No | ??? | Yes | |
??? | Yes | No | Yes | No | Yes | Yes | No | No |
- Parameters
Pnnn
Electronics type1V
Report the Prusa version number2Unnnnnn
Check the firmware version provided2- Examples
M115 M115 P2
sample data from firmware:
This M115
code is inconsistently implemented, and should not be relied upon to exist, or output correctly in all cases. An initial implementation was committed to svn for the FiveD Reprap firmware on 11 Oct 2010. Work to more formally define protocol versions is currently (October 2010) being discussed. See M115_Keywords for one draft set of keywords and their meanings. See the M408
command for a more comprehensive report on machine capabilities supported by RepRapFirmware.
- Notes
1This parameter is supported only in RepRapFirmware and can be used tell the firmware about the hardware on which it is running. If the P
parameter is present then the integer argument specifies the hardware being used. The following are currently supported:
M115 P0 Automatic board type selection if supported, or default if not M115 P1 Duet 0.6 M115 P2 Duet 0.7 M115 P3 Duet 0.85
2These parameters are only supported in Prusa Firmware. Parameter Unnnnnn
will check the firmware version provided. If the firmware version provided by the U code is higher than the currently running firmware, it will pause the print for 30s and ask the user to upgrade the firmware.
sample data M115
FIRMWARE_NAME:Prusa-Firmware 3.8.1 based on Marlin FIRMWARE_URL:https://github.com/prusa3d/Prusa-Firmware PROTOCOL_VERSION:1.0 MACHINE_TYPE:Prusa i3 MK3S EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
sample data M115 V
3.8.1
sample data on display for 30s or user interactionM115 U3.8.2-RC1
New firmware version availible: 3.8.2-RC1 Please upgrade.
M116: Wait
No | Yes | ??? | No | ??? | Yes | No | ??? | Yes | |
??? | No | No | Yes | No | Yes | Yes | No | Yes |
- Parameters
Pnnn
Tool numberHnnn
Heater numberCnnn
Chamber number- Examples
M116 M116 P1
Wait for all temperatures and other slowly-changing variables to arrive at their set values if no parameters are specified. See also M109
- Notes
M117: Get Zero Position
??? | No | No | Yes | No | No | No | No | No: See M70 |
- Example
M117
M117: Display Message
??? | No | No | No | No | Yes | No | No | No |
- Example
M117 Hello World
- Notes
In Prusa Firmware it is also used to display internal messages on LCD.1
M118: Echo message on host
1.1.4+ | No | ??? | ??? | ??? | No | No | ??? | Yes | |
Use this code to print a visible message to the host console, preceded by 'echo:'.
- Example
M118 Color changing to blue
M118: Negotiate Features
- Example
M118 P42
This M-code is for future proofing. NO firmware or hostware supports this at the moment. It is used in conjunction with M115
's FEATURES keyword.
M119: Get Endstop Status
- Example
M119
In redeem, M119
can also be used to invert end stops.
- Example
M119 X1 1
This will invert end stop X1 (Inverted means switch is connected in Normally Open state (NO))
M120: Push
No | Yes | ??? | No | ??? | No | Yes | ??? | No | |
- Example
M120
- Current feedrate, and
- Whether moves (and separately extrusion) are relative or absolute
- Current feedrate
- Extruder positions
M121: Pop
- Example
M121
Yes | No | ??? | M121 | ??? | No | No | ??? | Yes | |
Yes | No | ??? | M120 | ??? | No | No | ??? | Yes | |
M122: Firmware dependent
M122: Diagnose (RepRapFirmware)
- Example
M122
Sending an M122
causes the RepRap to transmit diagnostic information, for example via a USB serial link.
M122: Set Software Endstop (MK4duo)
No | No | ??? | No | ??? | No | No | ??? | Yes | |
Disabled or Enabled Software Endstop M122 S<0/1>
M122: Debug L6470 drivers (Marlin)
Yes | No | ??? | No | ??? | No | No | ??? | No | |
Get diagnostic info about all L6470 stepper drivers.
- Example
M122
M123: Firmware dependent
M123: Tachometer value (RepRap)
Sending an M123
causes the RepRap to transmit filament tachometer values from all extruders.
M123: Endstop Logic (MK4duo)
- Parameters
Xn
X LogicYn
Y LogicZn
Z LogicIn
X2 LogicJn
Y2 LogicKn
Z2 LogicPn
Probe LogicDn
Door Logic
- Examples
M123 ; Print Status M123 X1 Y1 Z0 P0
M124: Firmware dependent
M124: Immediate motor stop
Immediately stops all motors.
M124: Set Endstop Pullup
- Parameters
Xn
X Pullup on/offYn
Y Pullup on/offZn
Z Pullup on/offIn
X2 Pullup on/offJn
Y2 Pullup on/offKn
Z2 Pullup on/offPn
Probe Pullup on/offDn
Door Pullup on/off
- Examples
M124 ; Print Status M124 X1 Y1 Z0 P0
M126: Open Valve
Yes | No | ??? | ??? | ??? | No | No | ??? | Yes | |
??? | No | No | Yes | No | No | No | No | Yes |
- Example
M126 P500
M126 in MakerBot
- Example
M126 T0
M127: Close Valve
- Example
M127 P400
M127 in MakerBot
- Example
M127 T0
M128: Extruder Pressure PWM
- Example
M128 S255
PWM value to control internal extruder pressure. S255
is full pressure.
M129: Extruder pressure off
- Example
M129 P100
M130: Set PID P value
M301 | M301 | ??? | M301 | ??? | No | M301 | ??? | No | |
No | No | No | No | No | M301 | Yes | M301 | No |
- Parameters
Pnnn
heater numberSnnn
proportional (Kp)- Example
M130 P0 S8.0 ; Sets heater 0 P factor to 8.0
M131: Set PID I value
- Parameters
Pnnn
heater numberSnnn
integral (Ki)- Example
M131 P1 S0.5 ; Sets heater 1 I factor to 0.5
M132: Set PID D value
No | No | No | No | No | M301 | Yes | M301 | Yes |
- Parameters
Pnnn
heater numberSnnn
derivative (Kd)- Example
M132 P0 S24 ; Sets heater 0 D factor to 24.0
M132 in MakerBot
- Example
M132 X Y Z A B
M133: Set PID I limit value
M301 | M301 | ??? | M301 | ??? | No | No | ??? | No | |
- Parameters
Pnnn
heater numberSnnn
integral limit (Ki)- Example
M133 P1 S264 ; Sets heater 1 I limit value to 264
M133 in MakerBot
Wait for the toolhead to reach its target temperature.
- Parameters
Tnn
: Extruder to wait forPnn
: Time limit, in seconds
- Example
M133 T0 P500 ; Wait for Tool 0 to reach target. Fail after 8:20.
No | No: See M500 | ??? | No | ??? | No | No: See M504 | ??? | No | |
??? | No | No | No | No | No | Yes | No | Yes |
- Example
M134
M134 in MakerBot
- Example
M134 T0 P500
M135: Set PID sample interval
??? | No | No | No | No | No | No | No | Yes |
- Parameters
Snnn
Heat sample time in seconds- Example
M135 S300
M135 in MakerBot
- Example
M135 T0
No | M301 | ??? | No | ??? | No | No | ??? | No | |
No | No | No | No | No | No | Debug | No | ??? |
- Example
M136 P1 ; print heater 0 PID parameters to host
??? | Yes | No | Yes | Yes | Yes | Yes | Yes | Yes |
- Parameters
Pnnn
Bed heater index1Hnnn
Heater number1Tnnn
Tool number2Snnn
Active/Target temperatureRnnn
Standby temperature1 2- Example
M140 S55
Set the temperature of the build bed to 55oC and return control to the host immediately (i.e. before that temperature has been reached by the bed).
- Notes
1 These parameters are only supported in RepRapFirmware. RepRapFirmware allows the bed heater to be switched off if the absolute negative temperature (-273.15) is passed as target temperature. In this case the current bed temperature is not affected:
M140 S-273.15
2 These parameters are only supported in MK4duo for Idle temperature
M140 S60 R30 M140 T1 S60 R30
There is an optional R field that sets the bed standby temperature:
M140 S65 R40
Yes | Yes | ??? | No | ??? | No | No | ??? | Yes | |
??? | No | No | No | Yes | No | uses M104 | No | ??? |
- Parameters
Pnnn
Chamber index1Hnnn
Heater number1Tnnn
Tool number2Snnn
Standby temperature1 2- Examples
M141 S30 M141 H0
- Notes
1 These parameters are only supported in RepRapFirmware and work just like in M140.
2 These parameters are only supported in MK4duo and work just like in M140.
M142: Firmware dependent
M142: Holding Pressure
- Example
M142 S1
M142: Set Cooler Temperature (Fast)
- Parameters
Tnnn
Tool numberSnnn
Standby temperature- Examples
M142 S60 M142 S60 R30 M141 T1 S60 R30
Set the temperature of the cooler
M143: Maximum heater temperature
- Parameters
H
Heater number (RepRapFirmware 1.17 and later, default 1 which is normally the first hot end)S
Maximum temperature- Examples
M143 S275 ; set the maximum temperature of the hot-end to 275°C M143 H0 S125 ; set the maximum bed temperature to 125C
The default maximum temperature for all heaters was 300°C prior to RepRapFirmware version 1.13, and 262°C from 1.13 onwards. From RepRapFirmware 1.17 onwards, the default maximum temperatures are 262C for extruders and 125C for the bed.
When the temperature of the heater exceeds this value, countermeasures will be taken.
M144: Bed Standby
- Parameters
- Pnn Bed heater number, default 0
- Sn 0 = set bed heater to standby (default), 1 = set bad heater active
- Example
M144
Switch the bed heater to its standby temperature. M140 S1
turns it back to its active temperature.
M146: Set Chamber Humidity
- Parameters
Rnnn
Relative humidity in percent- Example
M146 R60
M149: Set temperature units
- Parameters
C
Flag to treat temperature as degrees CelsiusK
Flag to treat temperature as Kelvin- Example
M149 K
It affects the S
or R
values in the codes M104
, M109
, M140
, M141
, M143
, M190
and G10.
The default is M149 C
M150: Set LED color
Yes | See below | ??? | No1 | ??? | No | No | ??? | Yes | |
- Parameters
Rnnn
Red componentUnnn
Green componentBnnn
Blue componentWnnn
White component (Marlin)Pnnn
Brightness (0-255) (Marlin)P
Set full brightness (Marlin)Snnn
Number of individual LEDs to set, default 1 (RepRapFirmware)- Example
M150 R255 U128 B192
Set BlinkM, Neopixel, and/or other LED light color and intensity with RGBW component values from 0 to 255. Some LCD controllers use this interface for a backlight. Firmware may override the set color to indicate the current printer status.
RepRapFirmware uses this command to control DotStar LED strips on controllers that provide a connector for this purpose.
- Notes
In Prusa Firmware this G-code is deactivated by default, must be turned on in the source code.1
M155: Automatically send temperatures
1.1.0+ | No | ??? | Yes | ??? | Yes | No | ??? | Yes | |
- Parameters
Snnn
enable sending temperatures = 1, disable = 0- Example
M155 S1
Hosts normally monitor printer temperatures by sending M105
every couple of seconds. This not only adds serial traffic but it will fail whenever the command queue is full. M155
addresses these problems by telling the firmware to automatically report temperatures at regular intervals. This behavior is disabled by default for best compatibility with existing hosts. If the firmware supports M155
the output of M115
will report the AUTOREPORT_TEMP
capability:
Cap:AUTOREPORT_TEMP:1
- Example
M160 S4
This command has been superseded by the tool definition command M563
(see below).
M160 S4 G1 X90.6 Y13.8 E2.24:2.24:2.24:15.89 G1 X70.6 E0:0:0:42.4 G1 E42.4:0:0:0
Support | Marlin | RepRapFirmware | Klipper | Prusa | Buddy | Repetier | Smoothie | Druid | MK4duo |
1.1.0+ | M567 | ??? | No | ??? | 0.92+ | No | ??? | Yes | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | MakerBot | |
- Parameters
Snnn
extruder numberPnnn
weight
See Repetier Color Mixing for more informations.
M164: Store weights
1.1.0+ | No | ??? | No | ??? | 0.92 | No | ??? | Yes | |
- Parameters
Snnn
virtual extruder numberPnnn
store to eeprom (P0 = no, P1 = yes)
M165: Set multiple mix weights
1.1.0+ | M567 | ??? | No | ??? | No: | No | ??? | Yes | |
- Parameters
A B C D H I
A[factor]
Mix factor for extruder stepper 1B[factor]
Mix factor for extruder stepper 2C[factor]
Mix factor for extruder stepper 3D[factor]
Mix factor for extruder stepper 4H[factor]
Mix factor for extruder stepper 5I[factor]
Mix factor for extruder stepper 6
- Set multiple mix factors for a mixing extruder.
- Factors that are left out will be set to 0.
- All factors together must add up to 1.0.
??? | Yes | No | No | Yes | Yes | M116 | Yes | ??? |
- Parameters
Snnn
accurate target temperature, waits until heating and cooling (Marlin and Prusa)- Example
M190 S60
Wait for the bed temperature to reach 60 degrees, printing out the temperatures once per second.
2.0.0+ | 1.17+ | ??? | No | ??? | No | No | ??? | Yes | |
No | No | No | No | Yes | No | No | No | No |
- Example
M191 S60
- Parameters
Snnn
accurate target temperature, waits until heating and cooling (Marlin)
M200: Set filament diameter
Yes | 1.19+ | ??? | Yes | ??? | Yes | Yes | ??? | Yes | |
RepRapFirmware:
- Parameters
- Daaa:bbb:ccc... Sets filament diameter to aaa for extruder 0, bbb for extruder 1 and so on. If any of aaa, bbb etc. are zero then volumetric extrusion is disabled for that extruder.
- Daaa Sets filament diameter (or disables volumetric extrusion) for all extruders
- Examples
- M200 D0 ; disable volumetric extrusion on all extruders
- M200 D1.75 ; set al extruder filament diameters to 1.75mm
- M200 D1.75:3.0:1.75 ; set extruder 0 to 1.75mm, extruder 1 to 3.0mm and all remaining extruders to 1.75mm
Volumetric extrusion is an option you can set in some slicers whereby all extrusion amounts are specified in mm3 (cubic millimetres) of filament instead of mm of filament. This makes the gcode independent of the filament diameter, potentially allowing the same gcode to run on different printers. The purpose of the M200 command is to inform the firmware that the gcode input files have been sliced for volumetric extrusion, and to provide the filament diameter so that the firmware can adjust the requested extrusion amount accordingly.
Sending M200 without parameters reports the current volumetric extrusion state and (where appropriate) filament diameter for each extruder.
Note that if you use slicer-commanded retraction, the retraction amounts must be specified in mm3 too. If instead you use firmware retraction, then the firmware retraction amounts specified using the M207 command are still interpreted as mm.
Other firmwares:
M200 Dm.mmm
sets the filament diameter to m.mmm millimeters. It is used with 'volumetric calibration' and G-code generated for an ideal 1.128mm diameter filament, which has a volume of 1mm^3 per millimeter. The intention is to be able to generate filament-independent g-code. (See Triffid_Hunter's_Calibration_Guide#Optional:_Switch_to_volumetric_E_units and http://wooden-mendel.blogspot.com/2011/09/volumetric-stage-two.html for more information.)
M200 D0
or M200 D1.128
; reset E multiplier to 1, since sqrt(1 / pi) * 2 = 1.128
No | Yes | No | No | No | Yes | No | No | No |
- Parameters
Xnnn
Acceleration for X axisYnnn
Acceleration for Y axisZnnn
Acceleration for Z axisEnnn
Acceleration for extruder drives- Example
M201 X1000 Y1000 Z100 E2000
RepRapFirmware expects these values to be in mm/s².
No | Yes | No | No | No | No | No | No | No |
Set max travel acceleration in units/s^2 for travel moves (M202 X1000 Y1000
). Unused in Marlin!!
M203: Set maximum feedrate
- Parameters
Xnnn
Maximum feedrate for X axisYnnn
Maximum feedrate for Y axisZnnn
Maximum feedrate for Z axisEnnn
Maximum feedrate for extruder drives- Example
M203 X6000 Y6000 Z300 E10000
Sets the maximum feedrates that your machine can do in mm/min (Marlin uses mm/sec).
M203: Set temperature monitor
No | No | ??? | No | ??? | Yes | No | ??? | No | |
Set temperature monitor to Sx
. Repetier Firmware only.
Yes | 1.18+ | ??? | Yes | ??? | Yes | Yes | ??? | Yes | |
- Parameters (RepRapFimware)
Pnnn
Acceleration for printing movesTnnn
Acceleration for travel moves- Example
M204 P500 T2000
Use M201
to set per-axis accelerations and extruder accelerations. RepRapFirmware applies the M204
accelerations to the move as a whole, and also applies the limits set by M201
to each axis and extruder.
- Parameters (MK4duo)
Pnnn
Acceleration for printing movesVnnn
Acceleration for travel movesRnnn
Acceleration for Retraction for Tools with T code- Example
M204 P500 V2000 T0 R5000
Other firmwares:
S normal moves T filament only moves (M204 S3000 T7000) im mm/sec^2 also sets minimum segment time in ms (B20000) to prevent buffer underruns and M20
minimum feedrate
Marlin notes: After Mar11-2015, the M204
options have changed in Marlin:
P = Printing moves
The command M204 P800 T3000 R9000
sets the acceleration for printing movements to 800mm/s^2, for travels to 3000mm/s^2 and for retracts to 9000mm/s^2.
M204 Repetier
- Usage
M204 X[Kp] Y[Ki] Z[Kd]
M205: Advanced settings
Yes | M566 | ??? | Yes | ??? | Yes | Yes | ??? | Yes | |
- Sprinter / Marlin
- Minimum travel speed =
S[printing]
T[travel]
B[min segment time] X[max XY jerk] Z[max Z jerk] E[max E jerk]
- Sprinter / Marlin Example
M205 X30 Z5 ; Set X/Y Jerk to 30mm/s, Z jerk to 5mm/s
Smoothieware uses a different algorithm: [1]
- X[xy junction deviation] Z[z junction deviation] S[minimum planner speed].
- Z junction deviation only applies to z only moves
- 0 disables junction deviation for Z
- -1 uses global junction deviation
- Smoothie example
M205 X0.05 ; set X/Y Junction Deviation
M205: EEPROM Report
Output EEPROM settings. Repetier Firmware only.
M206: Offset axes
- Parameters
Xnnn
X axis offsetYnnn
Y axis offsetZnnn
Z axis offset- Example
M206 X10.0 Y10.0 Z-0.4
The values specified are added to the endstop position when the axes are referenced. The same can be achieved with a G92
right after homing (G28
, G161
With Marlin firmware, this value can be saved to EEPROM using the M500
command.
A similar command is G10
, aligning these two is subject to discussion.
In builds of RepRapFirmware that support CNC workplace coordinates, using this command is equivalent to using G10 L2 P1 to set the coordinate offsets for workplace 1.
M206: Set EEPROM value
Set a Repetier Firmware EEPROM value.
- Parameters
T[type]
Value typeP[pos]
Value position[S(long)]
An integer value[X(float)]
A float value
- Example
M206 T3 P39 X19.9 ; Set Jerk to 19.9
M207: Firmware dependent
M207: Set retract length
No | No | No | No | Yes | No | No | Yes | ??? |
- Parameters
Snnn
positive length to retract, in mmRnnn
positive or negative additional length to un-retract, in mm (RepRapFirmware only)Fnnn
retraction feedrate, in mm/minTnnn
feedrate for un-retraction if different from retraction, mm/min (RepRapFirmware 1.16 and later only)Znnn
additional zlift/hop- Example
M207 S4.0 F2400 Z0.075
Set the retract length used by the G10
and G11
commands. Units are in mm regardless of M200
setting.
Machinekit uses different parameters and speed units for M207
. Use P
to set retract length in mm. Use Q
to set retract velocity in mm/s. For firmware retraction Machinekit uses G22
and G23
in place of G10
and G11
M207: Calibrate Z axis with Z max endstop
No | Use G1 S3 ... | ??? | No | ??? | No | No | ??? | No | |
- Example
M207
M207: Set jerk without saving to EEPROM
No | M566 | ??? | No | ??? | Yes | No | ??? | No | |
No | ??? | No | ??? | No | No | ??? | No | No |
Repetier Firmware only. Change the maximum instantaneous speed change ("jerk") values, but don't store the change in EEPROM.
Since Repetier 0.91 December 2013 [2] (if not earlier)
- Parameters
Xnnn
Temporarily set XY jerk in mm/sZnnn
Temporarily set Z jerk in mm/sEnnn
Temporarily set Extruder jerk in mm/s
- Example
M207 X10 ; Change the X/Y Jerk to 10mm/s
M208: Set axis max travel
- Parameters
Snnn
0 = set axis maximum (default), 1 = set axis minimumXnnn
X axis limitYnnn
Y axis limitZnnn
Z axis limit- Example
- M208 X200 Y200 Z90 ; set axis maxima
- M208 X-5 Y0 Z0 S1 ; set axis minima
The values specified set the software limits for axis travel in the specified direction. The axis limits you set are also the positions assumed when an endstop is triggered.
M208: Set unretract length
Yes | Use M207 | ??? | Yes | ??? | No | Yes | ??? | Yes | |
- Parameters
Snnn
positive length surplus to theM207 Snnn
, in mmFnnn
feedrate, in mm/sec
??? | No | No | No | No | No | No | No | No |
- Example
M209 S1
This boolean value S 1=true or 0=false enables automatic retract detect if the slicer did not support G10
/G11
: every normal extrude-only move will be classified as retract depending on the direction.
M210: Set homing feedrates
No | No | ??? | No | ??? | No | No | ??? | No | |
- Example
M210 X1000 Y1500
No | Use M564 | ??? | No | ??? | No | No | ??? | No | |
- Example
M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
- Example
M211 X0 S1
Enables X min endstop
- Example
M211
Partial* | Use G31 | ??? | No | ??? | No | No | ??? | No | |
- Example
M212 Z-0.2
PrintrBot suggests that the user make minor (0.1-0.2) adjustments between attempts and immediately executes M500
& M501
after setting this.
M217: Toolchange Parameters
If arguments are given, sets tool-change retract and prime length (mm), prime feedrate (mm/m), retract feedrate (mm/m), and park position/raise (mm) or Z raise (mm): S<length> P<prime_speed> R<retract_speed> X<xpos> Y<ypos> Z<zraise>. XY arguments require SINGLENOZZLE_SWAP_PARK. If no arguments are given, reports current values. Currently used to set the SINGLENOZZLE
tool-change options in Marlin 2.0 and up. May be extended for other tool-changing systems in the future.
M218: Set Hotend Offset
Yes | Use G10 | ??? | Yes1 | ??? | No | No | ??? | Yes | |
- Example
M218 T1 X50 Y0.5
- Notes
In Prusa Firmware this G-code is only active if EXTRUDERS
is higher then 1 in the source code. On Original i3 Prusa MK2/s MK2.5/s MK3/s it is not active.1
Yes | Yes | ??? | Yes | ??? | Yes | Yes | ??? | Yes | |
- Parameters
Snnn
Speed factor override percentage (0..100 or higher)- Example
M220 S80
- Parameters
Snnn
Extrude factor override percentage (0..100 or higher), default 100%Dnnn
Extruder drive number (RepRapFirmware only), default 0Tnnn
Extruder drive number (Prusa Firmware only), default 0 if not set.1- Example
M221 S70 M221 S95 D1 M221 S85 T1
Sets extrude factor override percentage. In the case of RepRapFirmware and Prusa Firmware, sets the extrusion factor percentage for the specified extruder drive only.
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: G-code Initiated Pause
??? | No | Yes | No | Yes | No | No | No | ??? |
- Example
M226
Initiates a pause in the same way as if the pause button is pressed. That is, program execution is stopped and the printer waits for user interaction. This matches the behaviour of M1
in the NIST RS274NGC G-code standard and M0
in Marlin firmware.
M226: Wait for pin state
Yes | see M577 | ??? | Yes | ??? | Yes | No | ??? | Yes | |
- Parameters
Pnnn
pin numberSnnn
pin state- Example
M226 P2 S1
- Example
M227 P1600 S1600
P and S are steps.
"Reverse and Prime" means, the extruder filament is retracted some distance when not in use and pushed forward the same amount before going into use again. This shall help to prevent drooling of the extruder nozzle. Teacup firmware implements this with M101
/M103
- Example
M228
See also M227
- Example
M229 P1.0 S1.0
P
and S
are extruder screw rotations. See also M227
- Example
M230 S1
S1
Disable wait for temperature change
S0
Enable wait for temperature change
M231: Set OPS parameter
M231 S[OPS_MODE] X[Min_Distance] Y[Retract] Z[Backslash] F[RetractMove]
M240: Trigger camera
Yes | No | ??? | No1 | ??? | No | No | ??? | Yes | |
- Example
M240
Triggers a camera to take a photograph. (Add to your per-layer G-code.)
- Notes
??? | No | No | No | No | No | Debug: Echo off | No | ??? |
- Example
M240
??? | No | No | No | No | No | Debug: Echo on | No | ??? |
- Example
M241
M245: Start cooler
No | Use M106 | ??? | No | ??? | No | No | ??? | No | |
- Example
M245
M246: Stop cooler
- Example
M246
M250: Set LCD contrast
Yes | No | ??? | Yes | ??? | No | No | ??? | Yes | |
- Example
M250 C20
- Examples
M251 S0 ; Reset M251 S1 ; Print M251 S2 ; Store to Z length (also EEPROM if enabled)
(This is a Repetier-Firmware only feature.)
M260: i2c Send Data
1.1.0+ | 1.21+ | ??? | No | ??? | No | No | ??? | Yes | |
Buffer and send data over the i2c bus. Use A
to set the address from 0-127. Add up to 32 bytes to the buffer with each B
. Send and reset the buffer with S
- Parameters (Marlin, MK4duo)
- Ann I2C address
- Bnn Byte to buffer or send
- S If present, sends the bytes that have been buffered
- Examples
M260 A5 B65 S ; Send 'A' to Address 5 now M260 A0 ; Set address to 0 (broadcast) M260 B77 ; M M260 B97 ; a M260 B114 ; r M260 B108 ; l M260 B105 ; i M260 B110 ; n M260 S1 ; Send the current buffer
- Parameters (RepRapFirmware)
- Ann I2C address
- Bnn:nn:nn... Bytes to send
- Snn Number of bytes to receive (optional, RepRapFirmware 2.02RC4 and later)
- Examples
M260 A5 B65 ; Send 'A' to address 5 M260 A"0x7F" B65 ; Send 'A' to address 7F (hex) M260 A0 B82:101:112:82:97:112 ; Send 'RepRap' to address 0
RepRapFirmware does not use the S parameter, instead the address and all the bytes to send are specified in a single command.
M261: i2c Request Data
Request data from an i2c slave device. This command simply relays the received data to the host.
- Parameters
- Ann I2C address
- Bnn How many bytes to request
- Example
M261 A99 B5 ; Request 5 bytes from Address 99
Both M260
and M261
are commands demonstrating use of the i2c bus (TWIBus class) in Marlin Firmware. Developers and vendors can make Marlin an i2c master device by enabling EXPERIMENTAL_I2CBUS
, and Marlin can act as a slave device by setting I2C_SLAVE_ADDRESS
from 8-127. This class can be used to divide up processing responsibilities between multiple instances of Marlin running on multiple boards. For example, one board might control a Z axis with 4 independent steppers to create a self-leveling system, or a second board could drive the graphical display while the first board handles printing.
M280: Set servo position
Yes | 1.16+ | ??? | No1 | ??? | Use M340 | No | ??? | Yes | |
??? | No | No | No | Yes | Yes | No | No | ??? |
Set servo position absolute.
- Parameters
Pnnn
Servo indexSnnn
Angle or microsecondsI1
Invert polarity (RepRapFirmware only)- Example
M280 P1 S50
Marlin and RepRapFirmware treat S
values below 200 as angles, and 200 or greater as the pulse width in microseconds.
In RepRapFirmware, the servo index is the same as the pin number for the M42
command. See https://duet3d.com/wiki/Using_servos_and_controlling_unused_I/O_pins for details.
RepRapFirmware supports the optional I1 parameter, which if present causes the polarity of the servo pulses to be inverted compared to normal for that output pin. The I
parameter is not remembered between M280
commands (unlike the I
parameter in M106
commands), so if you need inverted polarity then you must include I1 in every M280
command you send.
P | Name | Expansion Port Pin |
Use M307 H# A-1 C-1 D-1 before using these pins | ||
3 | PC23_PWML6 | 21 |
4 | PC22_PWML5 | 22 |
5 | PC21_PWML4 | 23 |
On the Duet 0.6, pin 18 is controlled by heater 2. On the 0.8.5, pin 18 is controlled by heater 6, but is also shared with fan1. In order to use this pin, the fan must be disabled (M106 P1 I-1
). See Using servos and controlling unused I/O pins
- Notes
M290: Babystepping
1.1.7+ | 1.18+ | ??? | No | ??? | Yes | No | ??? | Yes | |
Snnn
Amount to baby step in mm. Positive values raise the head, negative values lower it.Znnn
Synonym for S (RepRapFirmware 1.21 and later)Rn
(Optional, RepRapFirmware 1.21 and later) R1 = relative (add to any existing babystep amount, the default), R0 = absolute (set babystepping offset to the specified amount)- Examples
M290 S0.05 ; babystep the head up 0.05mm M290 R0 S0 ; clear babystepping (RepRapFirmware 1.21 and later only)
- Parameters (Repetier)
Znnn
Amount to baby step in mm. Positive values raise the head, negative values lower it.- Examples
- Additional Parameters (Marlin 1.1.7 and later)
Xnnn
Amount to babystep X in current units. (RequiresBABYSTEP_XY
)Ynnn
Amount to babystep Y in current units. (RequiresBABYSTEP_XY
)Znnn
Amount to babystep Z in current units. Synonym for 'S
' parameter.- Example
M290 X0.2 Z0.05 ; Babystep X by 0.2mm, Z by 0.05mm
This command tells the printer to move the axis (or axes) transparently to the motion system. This is like physically moving the axes by force, but much nicer to the machine.
In RepRapFirmware M290
with no parameters reports the accumulated baby stepping offset. Marlin doesn't track accumulated babysteps.
In RepRapFirmware 1.19 and earlier, the babystepping offset is reset to zero when the printer is homed or the bed is probed. In RepRapFirmware 1.21 and later, homing and bed probing don't reset babystepping, but you can reset it explicitly using M290 R0 S0.
Note: If the BABYSTEP_ZPROBE_OFFSET
option is used in Marlin, this command also affects the Z probe offset (as set by M851
) and that offset will be saved to EEPROM.
M291: Display message and optionally wait for response
No | 1.19+ | ??? | No | ??? | No | No | ??? | No | |
- Parameters
P"message"
The message to display, which must be enclosed in double quotation marks. If the message itself contains a double quotation mark, use two double quotation marks to represent it.R"message"
Optional title for the message box. Must be enclosed in double quotation marks too.Sn
Message box mode (defaults to 1)Tn
Timeout in seconds, only legal for S=0 and S=1. The message will be cancelled after this amount of time, if the user does not cancel it before then. A zero or negative value means that the message does not time out (it may still be cancelled by the user if it has a Close button). In RepRapFirmware, the default timeout for messages that do not require acknowledgement is 10 seconds.Zn
0 = no special action, 1 = display Z jog buttons alongside the message to allow the user to adjust the height of the print head- Examples
M291 P"Please do something and press OK when done" S2 M291 P"This message will be closed after 10 seconds" T10
This command provides a more flexible alternative to M117, in particular messages that time out, messages that suspend execution until the user acknowledges them, and messages that allow the user to adjust the height of the print head before acknowledging them.
Allowed message box modes include:
0. No buttons are displayed (non-blocking) 1. Only "Close" is displayed (non-blocking) 2. Only "OK" is displayed (blocking, send M292 to resume the execution) 3. "OK" and "Cancel" are displayed (blocking, send M292 to resume the execution or M292 P1 to cancel the operation in progress)
The combination S0 T0 is not permitted, because that would generate a message box with no close button and that never times out, which would lock up the user interface.
Duet Web Control 2.0.3 and later supports HTML in the message body.
M292: Acknowledge message
- Parameters
Pn
Whether the current operation shall be cancelled. Only legal if M291 was called with S=3 (optional)
This command is sent by the user interface when the user acknowledges a message that was displayed because of a M291 command with parameter S=2 or S=3.
M300: Play beep sound
Yes | Yes | ??? | Yes1 | ??? | Yes | No | ??? | Yes | |
??? | No | No | No | Yes | No | No | No | Yes |
- Parameters
Snnn
frequency in HzPnnn
duration in milliseconds- Example
M300 S300 P1000
If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
- Notes
In Prusa Firmware the defaults are 100Hz and 1000ms, so that M300
without parameters will beep for a second.
M301: Set PID parameters
??? | Yes | No | No | No | Yes | See M130-M133 | No | ??? |
- Parameters
Hnnn
heater number (Smoothie uses 'S', Redeem uses 'E')Pnnn
proportional (Kp)Innn
integral (Ki)Dnnn
derivative (Kd)- Examples
M301 H1 P1 I2 D3 ; Marlin, RepRapFirmware M301 S0 P30 I10 D10 ; Smoothie M301 E0 P30 I10 D10 ; Redeem (E = Extruder, -1=Bed, 0=E, 1=H, 2=A, 3=B, 4=C, default = 0)
MK4duo
H[heaters] H = 0-5 Hotend, H = -1 BED, H = -2 CHAMBER, H = -3 COOLER
Marlin
Hot end only; see M304
for bed PID. H is the heater number, default 1 (i.e. first extruder heater).
RepRapFirmware 1.15 onwards
In RepRapFirmware 1.15 and later the M301 is supported as described above, but it is not normally used. Instead the heater model is defined by M307 or found by auto tuning, and the firmware calculates the PID parameters from the model. An M301 command can be used in config.g after the M307 command for that heater to override the firmware-computed PID parameters.
RepRapFirmware 1.09 to 1.14 inclusive
H
Is the heater number, and is compulsory. H0 is the bed, H1 is the first hot end, H2 the second etc. -
P
Interprets a negative P term as indicating that bang-bang control should be used instead of PID (not recommended for the hot end, but OK for the bed heater). -
I
Integral value -
D
Derivative value -
T
Is the approximate additional PWM (on a scale of 0 to 255) needed to maintain temperature, per degree C above room temperature. Used to preset the I-accumulator when switching from heater fully on/off to PID. -
S
PWM scaling factor, to allow for variation in heater power and supply voltage. Is designed to allow a correction to be made for a change in heater power and/or power supply voltage without having to change all the other parameters. For example, an S factor of 0.8 means that the final output of the PID controller should be scaled to 0.8 times the standard value, which would compensate for a heater that is 25% more powerful than the standard one or a supply voltage that is 12.5% higher than standard. -
W
Wind-up. Sets the maximum value of I-term, must be high enough to reach 245C for ABS printing. -
B
PID Band. Errors larger than this cause heater to be on or off.
An example using all of these would be:
M301 H1 P20 I0.5 D100 T0.4 S1 W180 B30
Smoothie
S0
is 0 for the hotend, and 1 for the bed, other numbers may apply to your configuration, depending on the order in which you declare temperature control modules.
Other implementations
W: Wind-up. Sets the maximum value of I-term, so it does not overwhelm other PID values, and the heater stays on. (Check firmware support - Sprinter, Marlin?)
- Example
M301 W125
Teacup
See M130
, M131
, M132
, M133
for Teacup's codes for setting the PID parameters.
M302: Allow cold extrudes
Yes | Yes1 | ??? | Yes | ??? | 0.92+ | No | ??? | Yes | |
- Parameters
Snnn
Cold extrude minimum temperature (also in RepRapFirmware 2.02 and later)Pnnn
Cold extrude allow state (RepRapFirmware)Rnnn
Cold retraction minimum temperature (RepRapFirmware 2.02 and later)
- Examples (RepRapFirmwre)
M302 ; Report current state M302 P1 ; Allow cold extrusion M302 S120 R110 ; Allow extrusion starting from 120°C and retractions already from 110°C
- Examples (Others)
M302 S0 ; Allow extrusion at any temperature M302 S170 ; Allow extrusion above 170
This tells the printer to allow movement of the extruder motor above a certain temperature, or if disabled, to allow extruder movement when the hotend is below a safe printing temperature.
- Notes
1RepRapFirmware uses the P[0|1]
parameter instead of S[temperature]
, and for M302
with no parameters it will report the current cold extrusion state.
M303: Run PID tuning
Yes | 1.15+ | ??? | Yes | ??? | Yes | Yes | ??? | Yes | |
??? | Yes | No | No | No | Yes | No | No | ??? |
Hot end usage:
M303 S<temperature> C<cycles>
Bed usage (repetier, not sure whether cycles work here):
M303 P1 S<temperature>
Bed usage (others):
- Example
M303 C8 S175
Smoothie's syntax, where E0
is the first temperature control module (usually the hot end) and E1
is the second temperature control module (usually the bed):
M303 E0 S190
In RepRapFirmware, this command computes the process model parameters (see M307
), which are in turn used to calculate the PID constants. H is the heater number, P is the PWM to use (default 0.5), and S is the maximum allowable temperature (default 225). Tuning is performed asynchronously. Run M303
with no parameters to see the current tuning state or the last tuning result.
- Example
M303 H1 P0.4 S240 ; tune heater 1 using 40% PWM, quit if temperature exceeds 240C
- Notes
In Marlin Firmware you can add the U1
parameter to apply the PID results to current settings upon completion.
Yes | Yes | ??? | Yes | ??? | ??? | M301 | ??? | M301 | |
??? | No | No | No | No | No | No | ??? | ??? |
- Parameters
Pnnn
integral (Ki)Dnnn
M304 P1 I2 D3 ; set kP=3, kI=2, kD=3 M304 P1 I2 D3 T0.7 B20 W127 ; RepRapFirmware M304 ; Report parameters
Sets Proportional, Integral and Derivative values for bed. RepRapFirmware interprets a negative P term as indicating that bang-bang control should be used instead of PID. In RepRapFirmware, this command is identical to M301
except that the H
parameter (heater number) defaults to zero.
In the RepRapPro version of Marlin ( https://github.com/reprappro/Marlin ) M304
is used to set thermistor values (as M305
is in later firmwares). RRP Marlin calculates temperatures on the fly, rather than using a temperature table. M304
Sets the parameters for temperature measurement.
- Example
M304 H1 B4200 R4800 T100000
This tells the firmware that for heater 1 (H
parameter: 0 = heated bed, H = first extruder), the thermistor beta (B
parameter) is 4200, the thermistor series resistance (R
parameter) is 4.8Kohms, the thermistor 25C resistance (T
parameter) is 100Kohms. All parameters other than H are optional. If only the H
parameter is given, the currently-used values are displayed. They are also displayed within the response to M503
No | Yes | ??? | No | ??? | ??? | Yes | ??? | Yes | |
No | No | No | No | No | No | No | No | ??? |
- Parameters
Pnnn
Heater number, or virtual heater numberS"name"
Heater name (optional, RepRapFirmware only)Tnnn
(for thermistor sensors) Thermistor resistance at 25oCT"c"
(for MAX31856-based thermocouple sensors) The thermistor type letter, default KBnnn
Beta value, or the reciprocal of the Steinhart-Hart thermistor model B coefficientCnnn
Steinhart-Hart C coefficient (MK4duo and RepRapFirmware 1.17 and later), default 0Rnnn
Series resistor valueLnnn
ADC low offset correction, default 0Hnnn
ADC high offset correction, default 0Xnnn
Heater ADC channel, or thermocouple or PT100 or current loop adapter channel, defaults to the same value as theP
parameterFnn
(where nn is 50 or 60) If the sensor interface uses a MAX31856 thermocouple chip or MAX31865 PT100 chip, this is the local mains frequency. Readings will be timed to optimise rejection of interference at this frequency.- Example
M305 P1 T100000 R1000 B4200
Sets the parameters for temperature measurement. The example above tells the firmware that for heater 1 (P
parameter: 0 = heated bed, 1 = first extruder) the thermistor 25C resistance (T
parameter) is 100Kohms, the thermistor series resistance (R
parameter) is 1Kohms, the thermistor beta (B
parameter) is 4200. All parameters other than P are optional. If only the P
parameter is given, the existing values are displayed.
- Example
M305 P1 T100000 R1000 B4200 H14 L-11 X2
The H correction affects the reading at high ADC input voltages, so it has the greatest effect at low temperatures. The L correction affects the reading at low input voltages, which correspond to high temperatures.
The X
parameter tells the firmware to use the thermistor input corresponding to a different heating channel. RepRapFirmware also allow an external SPI thermocouple interface (such as the MAX31855) or PT100 interface (MAX31865) to be configured. MAX31855 thermocouple channels are numbered from 100, MAX31856 thermocouple channels are numbered from 150, PT100 channels from 200 and current loop channels from 300. Channel 1000 is the CPU temperature indication, 1001 is the temperature of the hottest stepper motor driver on the main board, and 1001 is the temperature of the hottest drivers on the expansion board.
In the above example, the ADC high end correction (H
parameter) is 14, the ADC low end correction (L
parameter) is -11, and thermistor input #2 is used to measure the temperature of heater #1.
M306: Set home offset calculated from toolhead position
No | No | ??? | No | ??? | No | Yes | ??? | No | |
No | No | No | No | No | No | No | No | No |
- Example
M306 Z0
The user would typically place the toolhead at the zero point of the axis and issue the M306
command.
This value can be saved to EEPROM using the M500
command (as M206
value).
Implemented in Smoothieware
M307: Set or report heating process parameters
No | 1.15+ | ??? | No | ??? | No | No | ??? | No | |
- Parameters
Hn
Heater number (0 is usually the bed heater)Annn
gAin, expressed as ultimate temperature rise obtained in degC divided by the PWM fraction. For example, if G=180 then at 50% PWM the ultimate temperature rise would be 90C.Cnnn
dominant time Constant of the heating process in secondsDnnn
Dead time in seconds- Four optional additional parameters help control the heating process
Fnnn
PWM frequency to use (not supported in RepRapFirmware 3, use M950 instead).Bn
selects Bang-bang control instead of PID if non-zero. Default at power-up is 0 for extruder heaters, 1 for bed and chamber heaters.Snnn
maximum PWM to be used used with this heater on a scale of 0 to 1. Default 1.0.Vnnn
VIN supply voltage at which the A parameter was calibrated (RepRapFirmware 1.20 and later). This allows the PID controller to compensate for changes in supply voltage. A value of zero (the default) disables compensation for changes in supply voltage.- Examples
M307 H0 ; report the process parameters for heater 0 M307 H1 A346.2 C140 D5.3 B0 S0.8 V23.8 ; set process parameters for heater 1, use PID, and limit heater 1 PWM to 80%
Each heater and its corresponding load may be approximated as a first order process with dead time, which is characterised by the gain, time constant and dead time parameters. The model can used to calculate optimum PID parameters, using different values for the heating or cooling phase and the steady state phase. It is also used to better detect heater faults. In future it may be used to calculate feed-forward terms to better respond to changes in the load. Normally these model parameters are found by auto tuning - see M303
RepRapFirmware 1.16 and later allow the PID controller for a heater to be disabled by setting the A
, C
, and D
parameters to -1. This frees up the corresponding heater control pin for use as a general purpose I/O pin to use with the M42 or M280 command. In RepRapFirmware 3, M950 should be used to free up the pin instead.
M308: Set or report sensor parameters
No | 3.0+ | ??? | No | ??? | No | No | ??? | No | |
- Common Parameters
Sn
Sensor numberP"pin_name"
The name of the control board pin that this sensor uses. For thermistors it is the thermistor input pin name. For sensors connected to the SPI bus it is the name of the output pin used as the chip select.Y"sensor_type"
The sensor and interface type, e.g. "thermistor", "pt1000", "rtdmax31865", "max31855", "max31856", "linear-analog", "dht22-temp", "dht22-humidity", "current-loop-pyro"A"name"
Sensor name (optional), displayed in the web interface- Additional parameters for thermistors
Tnnn
(for thermistor sensors) Thermistor resistance at 25oCBnnn
Steinhart-Hart C coefficient, default 0Rnnn
ADC low offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)Hnnn
ADC high offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)- Additional parameters for PT1000 sensors
Rnnn
ADC high offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)- Additional parameters for MAX31856-based thermocouple sensors
T"c"
The thermistor type letter, default KFnn
(where nn is 50 or 60) The local mains frequency. Readings will be timed to optimise rejection of interference at this frequency.- Additional parameters for MAX31865-based PT100 sensors
Rnnn
Series resistor valueFnn
(where nn is 50 or 60) The local mains frequency. Readings will be timed to optimise rejection of interference at this frequency.- Additional parameters for linear analog sensors
Fn
F0 = unfiltered (fast response), F1 = filtered (slower response, but noise reduced and ADC oversampling used to increase resolution)Lnnn
The temperature or other value when the ADC output is zeroHnnn
The temperature or other value when the ADC output is full scale
This code replaces M305 in RepRapFirmware 3. In earlier versions of RepRapFirmware, sensors only existed in combination with heaters, which necessitated the concept of a "virtual heater" to represent a sensor with no associated heater (e.g. MCU temperature sensor). RepRapFirmware 3 allows sensors to be defined independently of heaters. The association between heaters and sensors is defined using M950.
M308 can be used in the following ways:
M308 Snn Y"type" P"pin" [other parameters] ; delete sensor nn if it exists, create a new one with default settings, and configure it using the other parameters M308 Snn ; report the settings of sensor nn M308 A"name" ; report the settings of the first sensor named "name" M308 Snn [any other parameters except Y] ; amend the settings of sensor nn
Sensor type names obey the same rules as pin names, i.e. case is not significant, neither are hyphen and underscore characters.
M320: Activate autolevel (Repetier)
- Usage
M320
M320 S1
- Parameters
Snnn
if greater than 0, activate and store persistently in EEPROM- Examples
M320 ; temporarily activate auto leveling M320 S1 ; permanently activate auto leveling
Parameter Snnn
is optional.
(Repetier only)
M321: Deactivate autolevel (Repetier)
- Usage
M321
M321 S1
- Parameters
Snnn
if greater than 0, deactivate and store persistently in EEPROM- Examples
M321 ; temporarily deactivate auto leveling M321 S1 ; permanently deactivate auto leveling
Parameter Snnn
is optional.
(Repetier only)
M322: Reset autolevel matrix (Repetier)
- Usage
M322
M322 S1
- Parameters
Snnn
if greater than 0, also reset the matrix values saved EEPROM- Examples
M322 ; temporarily reset auto level matrix M322 S1 ; permanently reset auto level matrix
Parameter Snnn
is optional.
(Repetier only)
M323: Distortion correction on/off (Repetier)
- Usage
M323
M323 Snnn
M323 Snnn Pnnn
- Parameters
Snnn
0 (disable correction) or 1 (enable correction)Pnnn
1 (store correction state persistently in EEPROM)- Examples
M323 ; Show if distortion correction is enabled M323 S0 ; Disable distortion correction temporarily M323 S1 P1 ; Enable distortion correction permanently
(Repetier only)
Controls distortion correction feature after having set it up using G33.
M340: Control the servos
M350: Set microstepping mode
Yes | Yes | ??? | Yes | ??? | Yes | No | ??? | Yes | |
No | No | No | No | No | Yes | No | No | No |
Sets microstepping mode.
Warning: Steps per unit remains unchanged; except that in RepRapFirmware the steps/mm will be adjusted automatically.
- Usage
M350 Snn Xnn Ynn Znn Enn Bnn
- Parameters
- Not all parameters need to be used, but at least one should be used. As with other commands, RepRapFirmware reports the current settings if no parameters are used.
Snn
Set stepping mode for all drivers (not supported by RepRapFirmware)Xnn
Set stepping mode for the X axisYnn
Set stepping mode for the Y axisZnn
Set stepping mode for the Z axisEnn
Set stepping mode for Extruder 0 (for RepRapFirmware useEnn:nn:nn
etc. for multiple extruders)Bnn
Set stepping mode for Extruder 1 (not supported by RepRapFirmware, see above)Inn
Enable (nn=1) or disable (nn=0) microstep interpolation mode for the specified drivers, if they support it (RepRapFirmware only)- Modes (nn)
- 1 = full step
- 2 = half step
- 4 = quarter step
- 8 = 1/8 step
- 16 = 1/16 step
- 64 = 1/64 step
- 128 = 1/128 step
- 256 = 1/256 step
- Examples
M350 S16 ; reset all drivers to the default 1/16 micro-stepping - not supported by RepRapFirmware M350 Z1 ; set the Z-axis' driver to use full steps M350 E4 B4 ; set both extruders to use quarter steps - Marlin/Repetier M350 E4:4:4 ; set extruders 0-2 to use quarter steps - RepRapFirmware
Yes | No | ??? | No | ??? | No | No | ??? | Yes | |
- Example
M351
M355: Turn case lights on/off
1.1.0+ | No | ??? | No | ??? | 0.92.2+ | No | ??? | No | |
No | No | No | No | No | No | use M106 | No | ??? |
- Examples
M355 S1 ; Enable lights M355 S0 ; Disable lights M355 ; Report status
Every call or change over LCD menu sends a state change for connected hosting software like:
Case lights on Case lights off No case lights
M503 | No | ??? | M503 | ??? | 0.92.2+ | No | ??? | No | |
- Target
- Example
M360
- Response
Config:Baudrate:250000 Config:InputBuffer:127 Config:NumExtruder:2 Config:MixingExtruder:0 Config:HeatedBed:0 Config:SDCard:1 Config:Fan:1 Config:LCD:1 Config:SoftwarePowerSwitch:1 Config:XHomeDir:-1 Config:YHomeDir:-1 Config:ZHomeDir:-1 Config:SupportG10G11:1 Config:SupportLocalFilamentchange:1 Config:CaseLights:0 Config:ZProbe:1 Config:Autolevel:0 Config:EEPROM:1 Config:PrintlineCache:24 Config:JerkXY:30.00 Config:JerkZ:0.30 Config:RetractionLength:3.00 Config:RetractionLongLength:13.00 Config:RetractionSpeed:40.00 Config:RetractionZLift:0.00 Config:RetractionUndoExtraLength:0.00 Config:RetractionUndoExtraLongLength:0.00 Config:RetractionUndoSpeed:0.00 Config:XMin:0.00 Config:YMin:0.00 Config:ZMin:0.00 Config:XMax:250.00 Config:YMax:150.00 Config:ZMax:90.00 Config:XSize:250.00 Config:YSize:150.00 Config:ZSize:90.00 Config:XPrintAccel:250.00 Config:YPrintAccel:250.00 Config:ZPrintAccel:100.00 Config:XTravelAccel:250.00 Config:YTravelAccel:250.00 Config:ZTravelAccel:100.00 Config:PrinterType:Cartesian Config:MaxBedTemp:120 Config:Extr.1:Jerk:50.00 Config:Extr.1:MaxSpeed:100.00 Config:Extr.1:Acceleration:10000.00 Config:Extr.1:Diameter:0.00 Config:Extr.1:MaxTemp:220 Config:Extr.2:Jerk:50.00 Config:Extr.2:MaxSpeed:100.00 Config:Extr.2:Acceleration:10000.00 Config:Extr.2:Diameter:0.00 Config:Extr.2:MaxTemp:220
Partial | No | ??? | No | ??? | No | Yes | ??? | Partial | |
No | No | No | No | No | ??? | No | ??? | No |
Yes | No | ??? | No | ??? | No | Yes | ??? | Experimental | |
No | No | No | No | No | No | No | ??? | No |
The arms move into a position where the Theta steering arm is parallel to the top platform edge. The user then calibrates the position by moving the arms with the jog buttons in software like pronterface until it is perfectly parallel. Using M114
will then display the calibration offset that can then be programmed into the unit using M206
(Home offset) X represents Theta.
Smoothieware: M360 P0
will take the current position as parallel to the platform edge, and store the offset in the homing trim offset (M666) No further user interaction is needed.
Theta move to 90 degrees with platform edge. User calibrates by using jog arms to place exactly 90 degrees. Steps per degree can then be read out by using M114
, and programmed using M92
. X represents Theta. Program Y (Psi) to the same value initially. Remember to repeat M360
after adjusting steps per degree.
will accept the current position as 90deg to platform edge. New steps per angle is calculated and entered into memory (M92) No further user interaction is required, except to redo M360
Move arms to form a 90 degree angle between the inner and outer Psi arms. Calibrate by moving until angle is exactly 90 degree. Read out with M114
, and calibrate value into Home offset M206
. Psi is represented by Y.
Smoothieware: M364 P0
will accept the current position as 90deg between arms. The offset is stored as a trim offset (M666) and no further user interaction is required except to save all changes via M500
M365: SCARA scaling factor
Yes | Use M579 | ??? | No | ??? | No | Yes | ??? | Experimental | |
M366: SCARA convert trim
No | Use M557 | ??? | No | ??? | No | Yes | ??? | No | |
- Usage
M370
M370 X[divisions] Y[divisions]
Without parameters is defaults to X5 Y5
(25 calibration points)
When specifying parameters, uneven numbers are recommended.
No | No | No | No | No | ??? | No | No | No |
M374: Save calibration grid
No | 1.17+ | ??? | No | ??? | No | Yes | ??? | No | |
Saves the calibration grid.
- Parameters
extension
(Smoothieware only) Extension of the grid filePfilename
(RepRapFirmware only) Name of the file to save toZ
(Smoothieware only) Also save theM206
Z homing offset into the grid file- Usage (Smoothieware)
M374 M374 <file extension> Z
- Usage (RepRapFirmware)
M374 M374 PMyAlternateHeightMap.csv
In Smoothieware, without parameters this saves the grid into the default grid file that gets loaded at boot. The optional parameter specifies the extension of the grid file - useful for special grid files such as for a special print surface like a removable print plate. Addition of Z will additionally save the M206 Z
homing offset into the grid file.
In RepRapFirmware, this saves the grid parameters and height map into the specified file, or the default file heightmap.csv
if no filename was specified. To load the height map automatically at startup, use command M375
in the config.g file.
Displays the bed level calibration matrix (Marlin), or loads the grid matrix file (Smoothieware and RepRapFirmware)
- Parameters
extension
(Smoothieware only)Pfilename
(RepRapFirmware only)- Usage
M375 M375 [file extension] ; (Smoothieware only) M375 PMyAlternateHeightMap.csv ; (RepRapFirmware only)
Without parameters loads default grid, and with specified extension or specified filename attempts to load the specified grid. If not available will not modify the current grid. In Smoothieware, if Z was saved with the grid file, it will load the saved Z with the grid.
M376: Set bed compensation taper
M420Z | 1.17+ | ??? | No | ??? | No | Yes | ??? | No | |
- Parameters
Hnnn
Height (mm) over which to taper off the bed compensation- Example
M376 H10
This command specifies that bed compensation should be tapered off over the specified height, so that no bed compensation is applied at and above that height. If H is zero or negative then no tapering is applied, so compensation is performed throughout the entire print.
If the firmware does not adjust the extrusion amount to compensate for the changing layer height while tapering is being applied, you will get under- or over-extrusion. Using a large taper height will reduce this effect. For example, if the taper height is 50 times the largest bed height error, then under- or over-extrusion will be limited to 2%.
M380: Activate solenoid
Yes | No | ??? | No | ??? | ??? | No | ??? | Yes | |
- Example
M380
M381: Disable all solenoids
- Example
M381
??? | Yes | No | No | Yes | ??? | use G4 | No | ??? |
- Example
M400
Finishes all current moves and and thus clears the buffer. That's identical to G4 P0
for Teacup printers.
M401: Lower z-probe
Yes | 1.17+ | ??? | No | ??? | ??? | No | ??? | Yes | |
- Example
M401
Lower z-probe if present. In RepRapFirmware this runs macro file sys/deployprobe.g.
M402: Raise z-probe
- Example
M402
Raise z-probe if present. In RepRapFirmware this runs macro file sys/retractprobe.g.
M403: Set filament type (material) for particular extruder and notify the MMU
??? | ??? | ??? | Yes | ??? | ??? | ??? | ??? | ??? | |
- Parameters
E
Extruder numberF
Filament type
Currently three different materials are needed (default, flex and PVA).
And storing this information for different load/unload profiles etc. in the future firmware does not have to wait for "ok" from MMU.
- Parameters
Nnnn
Filament width (in mm)Dnnn
Nozzle diameter (in mm)1- Examples
M404 N1.75 M404 N3.0 D1.0
Enter the nominal filament width (3mm, 1.75mm) or will display nominal filament width without parameters.
- Notes
1While Marlin only accepts the 'N' parameter, RepRapFirmware further allows to specify the nozzle diameter (in mm) via the 'D 'parameter. This value is used to properly detect the first layer height when files are parsed or a new print is being started.
M405: Filament Sensor on
Yes | Use M591 | ??? | No | ??? | No | No | ??? | Yes | |
- Example
M405
M406: Filament Sensor off
- Example
M406
Yes | Yes | ??? | Yes | ??? | No | No | ??? | Yes | |
- Example
M407
Displays measured filament diameter. In RepRapFirmware, M407
does the same as M404
No | Yes | ??? | No | ??? | No | No | ??? | Yes | |
- Parameters
Snnn
Response typeRnnn
Response sequence number- Example
M408 S0
Report a JSON-style response by specifying the desired type using the 'S' parameter.
The following response types are supported:
- Type 0 is a short-form response, similar to the response used by older versions of the web interface.
- Type 1 is like type 0 except that static values are also included.
- Type 2 is similar to the response provided by the web server for Duet Web Control.
- Type 3 is an extended version of type 2 which includes some additional parameters that aren't expected to change very frequently.
- Type 4 is an extended version of type 2 which may be used to poll for current printer statistics.
- Type 5 reports the current machine configuration.
Here is an example of a typical type 0 response:
{"status":"I","heaters":[25.0,29.0,28.3],"active":[-273.1,0.0,0.0],"standby":[-273.1,0.0,0.0],"hstat":[0,2,1],"pos":[-11.00,0.00,0.00],"extr":[0.0,0.0], "sfactor":100.00, "efactor":[100.00,100.00],"tool":1,"probe":"535","fanPercent":[75.0,0.0],"fanRPM":0,"homed":[0,0,0],"fraction_printed":0.572}
The response is set as a single line with a newline character at the end. The meaning of the fields is:
status: I=idle, P=printing from SD card, S=stopped (i.e. needs a reset), C=running config file (i.e starting up), A=paused, D=pausing, R=resuming from a pause, B=busy (e.g. running a macro), F=performing firmware update heaters: current heater temperatures, numbered as per the machine (typically, heater 0 is the bed) active: active temperatures of the heaters standby: standby temperatures of the heaters hstat: status of the heaters, 0=off, 1=standby, 2=active, 3=heater fault. Heater 0 is normally the bed heater, heaters 1, 2.. are the extruder heaters. pos: the X, Y and Z (and U, V, W if present) axis positions of the current tool (if a tool is selected), or of the print head reference point if no tool is selected extr: the positions of the extruders sfactor: the current speed factor (seeM220
command) efactor: the current extrusion factors (seeM221
command), one value per extruder tool: the selected tool number. A negative number typically means no tool selected. probe: the Z-probe reading fanPercent: the speeds of the controllable fans, in percent of maximum fanRPM: the print cooling fan RPM homed: the homed status of the X, Y and Z axes (and U, V, W if they exist), or towers on a delta. 0=axis has not been homed so position is not reliable, 1=axis has been homed so position is reliable. fraction_printed: the fraction of the file currently being printed that has been read and at least partially processed. message: the message to be displayed on the screen (only present if there is a message to display) timesLeft: an array of the estimated remaining print times (in seconds) calculated by different methods. These are currently based on the proportion of the file read, the proportion of the total filament consumed, and the proportion of the total layers already printed. Only present if a print from SD card is in progress. seq: the sequence number of the most recent non-trivial G-code response or error message. Only present if theR
parameter was provided and the current sequence number is greater than that. resp: the most recent non-trivial G-code response or error message. Only present if theR
parameter was provided and the current sequence number is greater.
The type 1 response comprises these fields plus some additional ones that do not generally change and therefore do not need to be fetched as often. The extra fields include:
myName: the name of the printer firmwareName: the name of the firmware, e.g. "RepRapFirmware", "Smoothieware" or "Repetier" geometry: one of "cartesian", "delta", "corexy, "corexz" etc. axes: the number of axes volumes: the number of SD card slots available numTools: the number of available tools numbered contiguously starting from 0
For a more detailed comparison of type 2 - 5, see RepRap_Firmware_Status_responses.
PanelDue currently uses only M408 S0
and M408 S1
M410: Quick-Stop
1.1.0-RC2+ | Use M112 | ??? | No | ??? | No | No | ??? | Yes | |
This command does a quick stop of all stepper motors and aborts all moves in the planner. This command is only intended for emergency situations, and due to the instant stop the actual stepper positions may be shifted. Note that if `EMERGENCY_PARSER` is disabled, the response may be delayed while the command buffer is being queued. If a print job is in progress, it will continue, so it is important to suspend the print job before using this command.
M412: Disable Filament Runout Detection
2.0+ | Use M591 | ??? | No | ??? | No | No | ??? | No | |
Enable or disable filament runout detection. When filament sensors are enabled, the firmware responds to a filament runout by running the configured G-code (usually M600
Filament Change). When filament runout detection is disabled, no action will be taken on filament runout.
Usage: M412 S[on|off]
If no 'S' parameter if given, this command reports the current state of filament runout detection.
- Examples
M412 S1
Enable filament runout detectionM412 S0
Disable filament runout detectionM412
Report the current filament runout detection state
M413: Power-Loss Recovery
2.0+ | Use M911 | ??? | No | ??? | No | No | ??? | No | |
Enable or disable the Power-loss Recovery feature. When this feature is enabled, the state of the current print job (SD card only) will be saved to a file on the SD card. If the machine crashes or a power outage occurs, the firmware will present an option to Resume the interrupted print job. In Marlin 2.0 the POWER_LOSS_RECOVERY
option must be enabled.
This feature operates without a power-loss detection circuit by writing to the recovery file periodically (e.g., once per layer), or if a POWER_LOSS_PIN
is configured then it will write the recovery info only when a power-loss is detected. The latter option is preferred, since constant writing to the SD card can shorten its life, and the print will be resumed where it was interrupted rather than repeating the last layer. (Future implementations may allow use of the EEPROM or the on-board SD card.)
Usage: M413 S[on|off]
If no 'S' parameter if given, this command reports the current state of Power-loss Recovery.
- Examples
M413 S1
Enable power-loss recoveryM413 S0
Disable power-loss recoveryM413
Report the current power-loss recovery state
M415: Host Rescue
The host rescue G-code is essential to enabling host software to recover from a lost connection or power loss. With this solution the firmware stores the last received coordinate and current position in EEPROM. Once the host reconnects, the firmware reports this recovery information. From the last-received coordinate the host can determine the last line that was processed. Firmware should move the extruder to a parking position if commands stop arriving during an active print job (with heaters still on). Once the host starts sending new commands the firmware should restore the last position. Host and firmware developers can work together to optimize this solution.
If the firmware supports this solution it should announce it with the capability:
Cap:HOST_RESCUE:1
- Examples
M415 S1
Enable host rescue systemM415 S0
Disable host rescue systemM415 Z[zpos]
Set Z position as if homedM415
Report rescue state
Every call to M415 reports the state. Answers are
RESCUE_STATE: OFF
Nothing stored. Print finished.
RESCUE_STATE: LX:121.97 LY:143.33 LZ:3.30 LE:1.84 LT:0 X:0.00 Y:240.00 Z:13.30 E:1.84
Print was interrupted. Coordinates with leading L are last received positions, LT is active extruder. Normal coordinates are current position and can be omitted, if the move did not finish due to power loss.
On a power loss the firmware should respond with POWERLOSS_DETECTED
as early as possible to give host time to flush log as it is likely host will also go down very soon.
Support is available in Repetier-Firmware 1.0.4 or higher. Repetier-Server 0.91.0 is the first to use this concept and can be used to validate implementation.
M416: Power loss
??? | No | No | No | No | ??? | No | No | ??? |
Host tells firmware that it will loose power. This is the solution in case a connected host has a power loss detection and firmware does not. Firmware should return
the message POWERLOSS_DETECTED
and do whatever firmware is supposed to do in that case. In combination with host rescue it should store positions, disable heaters, go to park position.
M420: Set RGB Colors as PWM (MachineKit)
Support | Marlin | RepRapFirmware | Klipper | Prusa | Buddy | Repetier | Smoothie | Druid | MK4duo |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | MakerBot | |
??? | No | No | No | Yes | ??? | No | No | ??? |
Usage: M420 R[Red PWM (0-255)] E[Green PWM (0-255)] B[Blue PWM (0-255)]
- Example
M420 R255 E255 B255
Set the color of your RGB LEDs that are connected to PWM-enabled pins. Note, the Green color is controlled by the E
value instead of the G value due to the G code being a primary code that cannot be overridden.
In Marlin M420
is Enable/Disable Mesh Leveling (with current values) S1=enable S0=disable
M420: Leveling On/Off/Fade (Marlin)
Yes | Use G29 and M376 | ??? | ??? | ??? | No | No | ??? | Yes | |
Enable/Disable Bed Leveling (using the current stored grid or mesh).
- Usage
M420 S[bool] Z[float]
- Examples
M420 S1 ; Enable compensation using current grid/mesh M420 Z10 ; Gradually reduce compensation until Z=10
Marlin 1.1.0 adds the Z
parameter to set the "fade" height. This requires the ENABLE_LEVELING_FADE_HEIGHT
option.
When the Z
fade height value is set non-zero, bed compensation will gradually reduce up to the given height, and cease completely above that height.
M421: Set a Mesh Bed Leveling Z coordinate
Yes | No | ??? | ??? | ??? | No | No | ??? | No | |
Set a single Z coordinate in the Mesh, Bilinear or UBL Leveling grid. Requires MESH_BED_LEVELING
or AUTO_BED_LEVELING_BILINEAR
or AUTO_BED_LEVELING_UBL
I & J are the index for the X and Y axis respectively.
- Usage
M421 I[index] J[index] Z[float]
to set an absolute value to a mesh point
or
M421 I[index] J[index] Q[float]
to offset a mesh point by a specified value
M425: Backlash Correction
2.0.x+ | No | ??? | No | ??? | No | No | ??? | No | |
- Parameters
Fnnn
Enable/disable/fade-out backlash correction (0.0 = none to 1.0 = 100%)Snnn
Distance over which backlash correction is spread1 (mm)Xnnn
Set the backlash distance on X (mm; 0 to disable)Ynnn
Set the backlash distance on Y (mm; 0 to disable)Znnn
Set the backlash distance on Z (mm; 0 to disable)X
Use measured value for backlash on X (if available)Y
Use measured value for backlash on Y (if available)Z
Use measured value for backlash on Z (if available)
- Examples (Marlin)
M425 ; Report current state M425 Z ; Use measured value of backlash on Z M425 F1 S3 ; Full backlash compensation while smoothing over 3mm. M425 F0.5 S0.0 ; Compensate for 50% of the backlash with no smoothing M425 X0.1 Y0.2 Z0.3 ; Set backlash to specific values for all axis
- Notes
1 In Marlin, backlash compensation works by adding extra steps to one or more segments after a motor direction reversal. With smoothing off, this can cause blemishes on the print. Enabling smoothing will cause those extra steps to be spread over multiple segments, minimizing artifacts.
M450: Report Printer Mode
No | 1.20+ | ??? | No | ??? | Yes | No | ??? | No | |
- Usage
M450
- Example
> M450 > PrinterMode:FFF
Printers can be used for different task by exchanging the toolhead. Depending on the tool, a different behavior of some commands can be expected. This command reports the current working mode. Possible answers are:
- PrinterMode:FFF
- PrinterMode:Laser
- PrinterMode:CNC
M451: Select FFF Printer Mode
- Usage
M451
- Example
> M451 > PrinterMode:FFF
Switches to FFF mode for filament printing.
M452: Select Laser Printer Mode
- Usage
M452
- Example
> M452 > PrinterMode:Laser
Switches to laser mode. This mode enables handling of a laser pin and makes sure that the laser is only activated during G1
moves if laser was enabled or E is increasing. G0
moves should never enable the laser. M3
/M5
can be used to enable/disable the laser for moves.
M453: Select CNC Printer Mode
- Usage
M453
- Parameters (RepRapFirmware only)
- Snnn (optional) Spindle index, defaults to 0. Duet 2 supports 4 spindles max
- Pfff:rrr Logical pin numbers used to drive the spindle motor in clockwise and counterclockwise directions. Omit the ":rrr" part if the spindle turns clockwise only.
- In Invert (I1) or don't invert (I0, default) the output polarity
- Rnnn Spindle RPM that is achieved at full PWM. Used to convert the S parameter in M3 and M4 commands to a PWM value.
- Fnnn (optional) The PWM frequency to use
- Tnnn (optional) Assign spindle to a tool allowing better control in DWC
- Example
> M453 > PrinterMode:CNC
Switches to CNC mode. In this mode M3
/M4
/M5
control the pins defined for the milling device.
Notes for RepRapFirmware: By default, no output is assigned to the spindle motor. Logical pin numbers for the P parameters are as defined for the M42 and M208 commands. If you wish to assign a heater or fan output to control the spindle motor as in the above example, you must first disable the corresponding heater (see M307) or fan (see M106).
M460: Define temperature range for thermistor-controlled fan
No | Use M106 | ??? | No | ??? | Yes | No | ??? | No | |
- Usage
M460 X[minTemp] Y[maxTemp]
- Example
M460 X50 Y60
If the firmware has a thermistor controlled fan defined, you can set at which temperature the fan starts and from which temperature on it should run with maximum speed.
M470: Create Directory on SD-Card
No | Yes:2.03 | ??? | No | ??? | No | No | ??? | No | |
- Parameters
P"name"
Name of directory to create
- Usage
M470 P"directory/to/create"
- Example
M470 P"/sys/config.d"
This will create a new directory on the SD-Card. If not otherwise specified the default root should be the first/internal SD-Card.
M471: Rename File/Directory on SD-Card
- Parameters
S"name"
Name of existing file/directoryT"name"
New name of file/directoryDnnn
Setting this to 1 will delete an existing file that matches the T parameter value
- Usage
M471 S"source/name" T"dest/name" D1
- Example
M471 S"/sys/config-override.g" T"/sys/config-override.g.bak"
Rename or move a file or directory. Using the D parameter can delete a file with the target name. Renaming or moving across directories is possible though not from one SD-Card to another.
M486: Cancel Object
Yes | No | ??? | No | ??? | No | No | ??? | No | |
The M486
G-code provides an interface to identify objects on the print bed and cancel them. Basic usage: Use M486 T
to tell the firmware how many objects there are, so it can provide an LCD interface. (Otherwise the firmware counts them up in the first layer.) In every layer of your G-code, you must preface each object's layer slice with M486 S[index]
to indicate which object is being printed. The index should be zero-based. To cancel the first object, use M486 P0
; to cancel the 5th object use M486 P4
; and so on. The "current" object is canceled with M486 C
G-codes associated with the canceled objects are no longer printed. Firmware supports this feature by ignoring G0-G3/G5 moves in XYZ while updating F and keeping the E coordinate up-to-date without extruding.
Slicers should number purge towers and other global features with a negative index (or other flag) to distinguish them from regular print objects, since it is important to preserve color changes, purge towers, and brims.
Host software (such as OctoPrint) may be able to cancel individual objects through a plugin, and in this case they should not use M486 P to cancel objects (although doing so should cause no harm).
- Usage
M486 T12 ; Total of 12 objects (otherwise the firmware must count) M486 S3 ; Indicate that the 4th object is starting now M486 S-1 ; Indicate a non-object, purge tower, or other global feature M486 P10 ; Cancel object with index 10 (the 11th object) M486 U2 ; Un-cancel object with index 2 (the 3rd object) M486 C ; Cancel the current object (use with care!)
M500: Store parameters in non-volatile storage
Yes | Yes | ??? | Yes | ??? | Yes | Yes | ??? | No | |
No | Yes | No | No | No | No | No | No | No |
- Example
M500
Save current parameters to EEPROM, SD card or other non-volatile storage.
In Redeem any parameters set through G/M-codes which is different than what is read from the config files, are stored back to the local config. For instance setting stepper current and microstepping through M906
and M907
followed by M500
will update /etc/redeem/local.cfg.
M501: Read parameters from EEPROM
Yes | Yes | ??? | Yes | ??? | Yes | ??? | ??? | Yes | |
No | Yes | No | No | No | ??? | No | No | No |
- Parameters
Snnn
Enable auto-save (only RepRapFirmware)
- Example
M501
Set the active parameters to those stored in the EEPROM, SD card or other non-volatile storage. This is useful to revert parameters after experimenting with them.
RepRapFirmware versions prior to 1.17 allows "S1" to be passed, which forces parameters to be automatically saved to EEPROM when they are changed.
In RepRapFirmware 1.17 and later, the parameters are saved in file sys/config-override.g on the SD card.
M502: Restore Default Settings
??? | Yes | No | No | No | ??? | No | No | ??? |
- Example
M502
This command resets all tunable parameters to their default values, as set in the firmware's configuration files. This doesn't reset any parameters stored in the EEPROM, so it must be followed with M500
to reboot with default settings.
M503: Report Current Settings
Yes | Yes | ??? | Yes | ??? | ??? | ??? | ??? | Yes | |
No | Yes | No | No | No | ??? | No | No | ??? |
- Examples
M503 ; Output current settings M503 S0 ; Settings as G-code only (Marlin 1.1)
This command asks the firmware to reply with the current print settings as set in memory. Settings will differ from EEPROM contents if changed since the last load / save. The reply output includes the G-Code commands to produce each setting. For example, Steps-Per-Unit values are displayed as an M92
command.
RepRapFirmware outputs the content of the configuration file, but note that it may be truncated if it is too long.
M504: Validate EEPROM
1.1.9+ | Not needed | ??? | No | ??? | No | No | ??? | Yes | |
- Examples
M504 ; Check EEPROM
This command checks the contents of EEPROM for correct version, size, and checksum and reports the result.
M505: Firmware dependent
M505: Clear EEPROM and RESET Printer
No | No | ??? | No | ??? | No | No | ??? | Yes | |
This command erase all EEPROM and reset the board.
M505: Set configuration file folder
- Parameters
- P"name" ; name of folder, default path is /sys/ if it is a relative path
- Example
- M505 P"experimental" ; change config file path from /sys/ to /sys/experimental/
Following this command, files that would normally be fetched from /sys/ (for example, homing files and system macro files in RepRapFirmware) are fetched from the specified folder instead. Any such files that are already being executed will continue to run.
This command can be used to allow multiple configurations to be maintained easily. In RepRapFirmware the file /sys/config/g can contain just these two lines:
M505 P"config1" M98 P"config.g"
The first line changes the config file folder to /sys/config1 and the second one executes file config.g in that folder. To select an alternative configuration, only the first line needs to be edited.
M509: Force language selection
Resets the language to English. Only on Original Prusa i3 MK2.5/s and MK3/s with multiple languages.
M524: Abort SD Printing
2.0.0+ | Use M25 then M0 | ??? | No | ??? | No | ??? | ??? | No | |
- Example
M524
If an SD print is in progress, this command aborts the print, just as if you had selected "Stop print" from the LCD menu.
M530: Enable printing mode
No | No | ??? | No | ??? | Yes | ??? | ??? | Yes | |
No | No | No | No | No | ??? | No | No1 | No |
- Example
M530 S1 L270
This command tells the firmware that a print has started (S1
) or ended (S0
). The L
parameter sets the number of layers. L0
denotes unknown layer count. This enables the firmware to switch into a special print display mode to show print progress. Firmware should indicate the presence of this feature by responding to M115
with an additional line:
Cap:PROGRESS:1
- Notes
1In MK4duo this command starts print counters for statistics. It also turns off a 30-minute timer for the heaters. If the timer reaches 30, turn off all the heaters.
M531: Set print name
- Example
M531 Demo Model
Sets the name of the currently printed object. Should follow M530 S1
for correct display.
M532: Set print progress
M73 | No | ??? | No | ??? | Yes | ??? | ??? | Yes | |
- Example
M532 X23.7 L56
Sets the print progress (X = 0..100) and currently printed layer (L). Should be send every 0.1% progress change on every layer change.
M540: Set MAC address
No | Yes | ??? | No | ??? | No | No | ??? | No | |
- Parameters
Pnnn
The MAC address- Examples
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED M540 PDE:AD:BE:EF:CA:FE
All devices running on the same network shall all have different MAC addresses. For your printers, changing the last digit is sufficient.
This command is only needed when using older electronics that doesn't provide a unique MAC address, for example Duet 0.6 and Duet 0.8.5.
M540 in Marlin: Enable/Disable "Stop SD Print on Endstop Hit"
- Parameters
Snnn
state, S1=enable, S0=disable- Example
M540 S1
- Notes
In Prusa Firmware this G-code is deactivated by default, must be turned on in the source code.1
M550: Set Name
- Parameters
Pnnn
Machine name- Example
M550 PGodzilla
M551: Set Password
- Parameters
Pnnn
Password- Example
M551 Pmy-very-secret-word
Note for RepRapFirmware: If the specified password differs from the default one (i.e. reprap), the user will be asked to enter it when a connection is established via HTTP or Telnet. For FTP, the password must always be passed explicitly.
M552: Set IP address, enable/disable network interface
- Parameters
Pnnn
IP address, 0.0.0.0 means acquire an IP address using DHCPSnnn
(optional) -1 = reset network interface, 0 = disable networking, 1 = enable networking as a client, 2 = enable networking as an access point (WiFi-enabled electronics only)Rnnn
(optional, RepRapFirmware 1.17 and earlier only) HTTP port, default 80- Example
M552 P192.168.1.14
Sets the IP address of the machine to (in this case) 192.168.1.14. If the S
parameter is not present then the enable/disable state of the network interface is not changed.
In RepRapFirmware 1.18 and later the HTTP port address is set using the M586
command, so the R
parameter of this command is no longer supported.
M552 with no parameters reports the current network state and IP address.
M553: Set Netmask
- Parameters
Pnnn
Net mask- Example
M553 P255.255.255.0
Sets the network mask of the RepRap machine to (in this case) 255.255.255.0. A restart may be required before the new network mask is used. If no 'P' field is specified, this echoes the existing network mask configured.
Recent RepRapFirmware versions allow the IP configuration to be changed without a restart.
M554: Set Gateway
- Parameters
Pnnn
Gateway- Example
M554 P192.168.1.1
Sets the Gateway IP address of the RepRap machine to (in this case) 192.168.1.1. A restart may be required before the new gateway IP address is used. If no 'P' field is specified, this echoes the existing Gateway IP address configured.
M555: Set compatibility
- Parameters
Pnnn
Emulation type- Example
M555 P1
For firmware that can do it, the firmware is set to a mode where its input and (especially) output behaves exactly like other established firmware. The value of the 'P' argument is:
P value | Firmware |
0 | Native (i.e. whatever the firmware actually is) |
1 | RepRapFirmware |
2 | Marlin |
3 | Teacup |
4 | Sprinter |
5 | Repetier |
6 | Marlin with changes for nanoDLP |
M556: Axis compensation
- Parameters
Snnn
Height of the measured distancesXnnn
Deviation in X directionYnnn
Deviation in Y directionZnnn
Deviation in Z direction- Example
M556 S100 X0.7 Y-0.2 Z0.6
Though with care and adjustment a RepRap can be set up with its axes at right-angles to each other within the accuracy of the machine, who wants to bother with care and adjustment when the problem
can be solved by software? This tells software the tangents of the angles between the axes of the machine obtained by printing then measuring a test part. The S
parameter (100 here) is the length of a triangle along each axis in mm. The X, Y and Z figures are the number of millimeters of the short side of the triangle that represents how out of true a pair of axes is. The X figure is the error between X and Y, the Y figure is the error between Y and Z, and the Z figure is the error between X and Z. Positive values indicate that the angle between the axis pair is obtuse, negative acute.
M557: Set Z probe point or define probing grid
No | Yes | ??? | No | ??? | No | Yes | ??? | Yes | |
- Parameters to define
G32
probe points (Cartesian/CoreXY printers only, no longer supported in RepRapFirmware) Pnnn
Probe point numberXnnn
X coordinateYnnn
Y coordinate- Example
M557 P1 X30 Y40.5
G29
probe grid (all values in mm) Xaaa:bbb
Minimum and maximum X coordinates to probeYaaa:bbb
Minimum and maximum Y coordinates to probeRnnn
Radius to probeSnn
orSxx:yy
Probe point spacingPnn
orPxx:yy
Number of probe points in each direction (RepRapFirmware 2.02 and later) - use instead of specifying the spacing- Examples
M557 X0:200 Y0:220 S20 M557 R150 S15
Set the points at which the bed will be probed to compensate for its plane being slightly out of horizontal.
The first form defines the points for for G32
bed probing. The P
value is the index of the point (indices start at 0) and the X
and Y
values are the position to move extruder 0 to to probe the bed. An implementation should allow a minimum of three points (P0, P1 and P2). This just records the point coordinates; it does not actually do the probing. See G32. Defining the probe points in this way is no longer supported by RepRapFirmware, you should define them in a bed.g file instead.
The second form defines the grid for G29
bed probing. For Cartesian printers, specify minimum and maximum X
and Y
values to probe and the probing interval. For Delta printers, specify the probing radius. If you define both, the probing area will be the intersection of the rectangular area and the circle. There is a firmware-dependent maximum number of probe points supported, which may be as low as 100.
M558: Set Z probe type
- Parameters
Pnnn
Z probe typeFnnn
Feed rate (i.e. probing speed, mm/min)Hnnn
Dive height (mm)Innn
Invert (I1) or do not invert (I0) the Z probe reading (RepRapFirmware 1.16 and later)Rnnn
Z probe recovery time after triggering, default zero (seconds) (RepRapFirmware 1.17 and later)1Tnnn
Travel speed to and between probe points (mm/min)Annn
Maximum number of times to probe each point, default 1 (RepRapFirmware 1.21 and later)Snnn
Tolerance when probing multiple times, default 0.03 (RepRapFirmware 1.21 and later)Bn
B1 turns off all heaters during probing moves and during the probe recovery time (RepRapFirmware 1.21 and later)- Obsolete parameters
Xnnn
If nonzero, use probe for homing X axis (RepRapFirmware 1.19 and earlier only)Ynnn
If nonzero, use probe for homing Y axis (RepRapFirmware 1.19 and earlier only)Znnn
If nonzero, use probe for homing Z axis (RepRapFirmware 1.19 and earlier only)- Example
M558 P1 F500 T5000 H3
A Z probe may be a switch, an IR proximity sensor, or some other device. This selects which to use:
- P0 indicates that no Z probe is present
- P1 indicates an unmodulated IR probe, or any other probe type that emulates an unmodulated IR probe (probe output is an analog signal that rises with decreasing nozzle height above the bed). If there is a control signal to the probe, it is driven high when the probe type is P1
- P2 specifies a modulated IR probe, where the modulation is commanded directly by the main board firmware using the control signal to the probe
- P3 selects an alternative Z probe similar to P1 but the control signal to the probe low
- P4 selects a switch for bed probing (on the Duet, this must be connected to the E0 endstop pins)
- P5 (from RepRapFirmware 1.14) selects a switch or a digital output device to the In pin of the Z-probe connector
- P6 is as P4 but the switch is connected to and alternative connector (on the Duet series, the E1 endstop connector)
- P7 is as P4 but the switch is connected to and alternative connector (on the Duet series, the Z endstop connector)
- P8 is as P5 but the signal is unfiltered for faster response
- P9 is as P5 but the probe is deployed and retracted at every probe point. This is intended for BLTouch.
Related codes: G29, G30, G31, G32, M401, M402.
- Example
M559
If the RepRap supports it, this uploads a file that is run on re-boot to configure the machine. This file usually is a special G Code file. After sending M559
, the file should be sent, ending with an M29
(q.v.).
M560: Upload web page file
- Example
M560For RepRaps that have web support and that can be driven by a web browser, this uploads the file that is the control page for the RepRap. After sending
M560
the file (usually an HTML file) should be sent, terminated by the string <!-- **EoF** -->. Clearly that string cannot exist in the body of the file, but can be put on the end to facilitate this process. This should not be too serious a restriction...
M561: Set Identity Transform
No | Yes | ??? | No | ??? | No | Yes | ??? | No | |
??? | No | No | No | No | Yes | No | No | ??? |
- Example
M561
M562: Reset temperature fault
- Parameters
Pnnn
Heater number- Example
M562 P2
Later versions of RepRapFirmware support M562 without the P parameter, which will reset all heater faults.
M563: Define or remove a tool
- Parameters
Pnnn
Tool numberS"name"
Tool name (optional)Dnnn
Extruder drive(s)Hnnn
Heater(s)Fnnn
Fan(s) to map the print cooling fan to (RepRapFirmware 1.16 and later)Xnnn
Axis or axes to map X movement to (RepRapFirmware 1.16 and later)Ynnn
Axis or axes to map Y movement toLnnn
Drive to use for filament mapping. By default RRF will use the first and only extruder drive if this parameter is not specified (supported by RRF >= 2.02)- Examples
M563 P0 D0:2:3 H1:3 ; create a tool using extruder drives 0, 2 and 3 and heaters 1 and 3 M563 P1 D1 H2 X3 ; create a tool using extruder drive 1 and heater 2 with X movement mapped to the U axis M563 P2 D0:1 H1:2 X0:3 F0:2 ; create a tool using extruder drives 0 and 1, heaters 1 and 2, ; with X movement mapped to both X and U axes and fan 0 mapped to fan 0 and fan 2 M563 P3 D0 H1 S"Chocolate extruder" ; create a named tool using extruder drive 0 and heater 1
Tools are usually (though not necessarily) extruders. The 'P' field specifies the tool number. Tool numbers can have any positive integer value and 0. The 'D' field specifies the drive(s) used by the tool - in the first example drives 0, 2 and 3. Drive 0 is the first drive in the machine after the movement drives (usually X, Y and Z). If there is no 'D' field the tool has no drives. The 'H' field specifies the tool's heaters - in the first example heaters 1 and 3. Heater 0 is usually the hot bed (if any) so the first extruder heater is usually 1. If there is no H field the tool has no heaters.
Tools are driven using multiple values in the 'E' field of G1
commands, each controlling the corresponding drive in the 'D' field above, as follows:
G1 X90.6 Y13.8 E2.24:2.24:15.89 G1 X70.6 E0:0:42.4
The first line moves straight to the point (90.6, 13.8) extruding a total of 2.24mm of filament from both drives 0 and 2 and 15.98mm of filament from drive 3. The second line moves back 20mm in X extruding 42.4mm of filament from drive 3.
Alternatively, if the slicer does not support generating G1
commands with multiple values for the extrusion amount, the M567
command can be used to define a tool mix ratio.
Normally an M563
command is immediately followed by a G10
command to set the tool's offsets and temperatures.
The X mapping option is used to create tools on machines with multiple independent X carriages. The additional carriages are set up as axes U, V etc. (see M584
) and the X mapping option in M563
defines which carriage or carriages are used.
If you use the M563
command with a P
value for a tool that has already been defined, that tool is redefined using the new values you provide.
RepRapFirmware supports an additional form of the M563
command. The command:
M563 S1
means add 1 (the value of the S
parameter) to all tool numbers found in the remainder of the current input stream (e.g. the current file if the command is read from a file on the SD card), or until a new M563
command of this form is executed. The purpose of this is to provide compatibility between systems in which tool numbers start at 1, and programs such as slic3r that assume tools are numbered from zero.
Recent versions of RepRapFirmware allow the deletion of existing tools if M563
is called in this way:
M563 P1 D-1 H-1
M564: Limit axes
- Parameters
Hnnn
H1 = forbid movement of axes that have not been homed, H0 = allow movement of axes that have not been homed (RepRapFirmware 1.21 and later)Snnn
S1 = limit movement within axis boundaries, S0 = allow movement outside boundaries- Example
- M564 S0 H0
Allow moves outside the print volume and before homing, or not. If the S parameter is 0, then you can send G codes to drive the RepRap outside its normal working volume, and it will attempt to do so. Likewise if the H parameter is 0 you can move the head or bed along axes that have not been homed. The default behaviour is S1 H1. On some types of printer (e.g. Delta and SCARA), movement before homing is prohibited regardless of the H parameter.
M565: Set Z probe offset
No | use G31 | ??? | No | ??? | No | Yes | ??? | No | |
- Example
M565 X3 Y4.5 Z-2.37
Set the offset from the extruder tip to the probe position. The X
, Y
, and Z
values are the delta between the extruder and the actual trigger position of the probe. If the probe trigger point is below the extruder (typical) the Z offset will be negative. This just records the point offset; it does not actually do the probing. See G32
- Parameters
Xnnn
Maximum instantaneous speed change of the X axis (mm/min)Ynnn
Maximum instantaneous speed change of the Y axisZnnn
Maximum instantaneous speed change of the Z axisEnnn
Maximum instantaneous speed change of the extruder drives- Example
M566 X20 Y20 Z2 E10
Sets the maximum allowable speed change (sometimes called 'jerk speed') of each motor when changing direction.
The model files and gcode files used by repraps generally render circles and other curves shapes as a sequence of straight line segments. If the motors were not allowed any instantaneous speed change, they would have to come to a stop at the junction between each pair of line segments. By allowing a certain amount of instantaneous speed change, printing speed can be maintained when the angle between the two line segments is small enough.
If you set these X
and Y
values too low, then the printer will be slow at printing curves. If they are too high then the printer may be noisy when cornering and you may suffer ringing and other print artefacts, or even missed steps.
On very old versions of RepRapFirmware (prior to 1.09), these were also the minimum speeds of each axis.
M567: Set tool mix ratios
- Parameters
Pnnn
Tool numberEnnn
Mix ratios- Example
M567 P2 E0.1:0.2:0.1:0.6
This example sets the mix ratio for tool 2 (the P
value). When mixing is then turned on (see M568
), only single E
values need to be sent on a G1
command (any extra E
values will be ignored, but are not illegal):
G1 X20 E1.3
See also M568
M568: Turn off/on tool mix ratios (obsolete)
This command is obsolete. When using a tool defined as a mixing extruder, RepRapFirmware applies the mix ratio defined by M567 whenever only one E parameter is provided in G1 commands. When multiple colon-separated E values are provided in the G1 command, they will be used as the individual amounts to extrude.
M569: Stepper driver control
- Parameters
Pnn
Motor driver numberSn
Direction of movement of the motor(s) attached to this driver: 0 = backwards, 1 = forwards (default 1)Rn
Driver enable polarity: 0 = active low, 1 = active high (default 0)Tnn
Minimum driver step pulse width and interval in microseconds (RepRapFirmware 1.14 and later)Taa:bb:cc:dd
Minimum driver step pulse width, step pulse interval, direction-to-step setup time and step-to-direction hold time, in microseconds (RepRapFirmware 1.21 and later)Dnn
Stepper driver mode (RepRapFirmware 2.0 and later): 0=constant off time, 1=random off time, 2=spread cycle, 3=stealthChopFnn
(firmware 2.02 and later) Off-time in the chopper control register, 1 to 15Bnn
(firmware 2.02 and later) Blanking time (tbl) in the chopper control register, 0 to 3. See the TMC driver datasheet.Yaa:bb
orYaa:bb:cc
(firmware 2.02 and later) Hysteresis start, end and decrement values in the chopper control register. See the TMC driver datasheet for the meaning.Cnnn
Custom chopper control register value (RepRapFirmware 2.0 and later). Do not change this value without having a good understanding of the stepper driver driver chip!Hnn
(firmware 2.02 and later) t_high parameter for those stepper driver chips that support it (e.g. TMC2208, 2224). Send M569 P# (where # is the driver number) with no additional parameters to see how this translates into mm/sec. See also the V parameter.Vnnn
(firmware 2.02 and later) tpwmthrs parameter for those stepper driver chips that support it (e.g. TMC2208, 2224). This is the interval in clock cycles between 1/256 microsteps below which the drivers will switch from stealthChop to to spreadCycle mode. Only applies when the driver is configured in stealthChop mode. Typical value are from 100 (high speed) to 4000 (low speed). Send M569 P# (where # is the driver number) with no additional parameters to see how this translates into axis speed in mm/sec.- Example
M569 P0 S0 ; reverse the direction of the motor attached to driver 0 M569 P5 R1 T2.5:2.5:5:0 ; driver 5 requires an active high enable, 2.5us minimum step pulse, 2.5us minimum step interval, 5us DIR setup time and no hold time
- Notes
All parameters except P are optional. For any parameter that is not provided, the corresponding value will not be changed.
The T parameters are intended for use with external stepper drivers. Currently, RepRapFirmware only remembers the highest T
parameters seen in any M569 command, and applies those values to all drivers for which any nonzero T
parameters were specified.
The modes (D parameter) supported by various stepper driver chips are:
- TMC2130: modes 0,1,2,3
- TMC2660: modes 0,1,2
- TMC2208/2224: modes 2,3 (mode 3 is stealthChop 2)
Some versions of RepRapFirmware prior to 1.14 also provided X
, Y
, Z
and E
parameters to allow the mapping from axes and extruders to stepper driver numbers to be changed. From 1.14 onward, this functionality is provided by M584 instead.
M570: Configure heater fault detection
- Parameters for RepRapFirmware 1.14 and earlier
Snnn
Heater timeout (in seconds)- Example
M570 S120
After a heater has been switched on, wait 120 seconds for it to get close to the set temperature. If it takes longer than this, raise a heater fault.
- Parameters for RepRapFirmware 1.15e and later
Hnnn
Heater numberPnnn
Time in seconds for which a temperature anomaly must persist on this heater before raising a heater fault (default 5 seconds)Tnnn
Permitted temperature excursion from the setpoint for this heater (default 10C)Snnn
Time in seconds after a heater fault is raised after which the print will be abandoned, default 10 minutes (RepRapFirmware 1.20 and later)- Example
M570 H1 P4 T15
Warning! Heating fault detection is provided to reduce the risk of starting a fire if a dangerous fault occurs, for example if the heater cartridge or thermistor falls out of the heater block. You should not increase the detection time or permitted temperature excursion without good reason, because doing so will reduce the protection.
M571: Set output on extrude
- Parameters
Snnn
Output valueFnnn
Output PWM frequency (RepRapFirmware 1.17 and later)Pnnn
Logical pin number (RepRapFirmware 1.17 and later), defaults to the FAN0 output untilM571
with aP
parameter has been seen- Example
M571 P3 F200 M571 S0.5
This turns the controlled pin output on whenever extrusion is being done, and turns it off when the extrusion is finished. The output could control a fan or a stirrer or anything else that needs to work just when extrusion is happening. It also can be used to control a laser beam. The S
parameter sets the value of the PWM to the output. 0.0 is off; 1.0 is fully on.
In RepRapFirmware 1.17 and later you can use the P
parameter to change the pin used and you can also set the PWM frequency. Pin numbers are the same as in the M42 and M280
commands. The pin you specify must not be in use for anything else, so if it is normally used as a heater you must disable the heater first using M307
, or if it is used for a fan you must disable the fan using M106 with the I-1 parameter.
M572: Set or report extruder pressure advance
No | No | No | No | No | No | No | No | No |
- Parameters
Dnnn
Extruder numberSnnn
Pressure advance amount (in seconds)- Example
M572 D0 S0.1
This sets the pressure advance coefficient (S
parameter) for the specified extruder (D
parameter). Supported by RepRapFirmware-dc42, -ch and -dn.
Pressure advance causes the extruder drive position to be advanced or retarded during printing moves by an additional amount proportional to the rate of extrusion. At the end of a move when the extrusion rate is decreasing, this may result in the extruder drive moving backwards (i.e. retracting). Therefore, if you enable this feature, you may need to reduce the amount of retraction you use in your slicing program to avoid over-retraction.
With Bowden extruders, an S
value between 0.1 and 0.2 usually gives the best print quality.
Older versions of RepRapFirmware used the P
parameter to specify the drive number, instead of using D to specify the extruder number.
M573: Report heater PWM
- Parameters
Pnnn
M573 P1
This gives a running average (usually taken over about five seconds) of the PWM to the heater specified by the P field. If you know the voltage of the supply and the resistance of the heater this allows you to work out the power going to the heater. Scale: 0 to 1.
- Parameters
- Xnnn Switch position for X axis
- Ynnn Switch position for Y axis
- Znnn Switch position for Z axis
- Snnn Endstop type: 0 = active low endstop input, 1 = active high endstop input, 2 = Z probe, 3 = motor load detection
- Example
- M574 X1 Y2 Z0 S1 ; X endstop at low end, Y endstop at high end, no Z endstop, all active high
This defines the position of endstop sensor that the printer has for each axis: 0 = none, 1 = low end, 2 = high end. The optional S parameter defines whether the endstop input is active high (S1, the default), low (S0), or the axes listed use the Z probe for homing that axis (S2), or motor stall detection (S3). A normally-closed endstop switch wired in the usual way produces an active high output (S1). If different axes use different types of endstop sensing, you can use more than one M574 command.
On delta printers the XYZ parameters refer to the towers, and the endstops should normally all be high end (i.e. at the top of the towers).
The S2 and S3 options are supported in RepRapFirmware 1.20 and later.
In RepRapFirmware 1.16 and earlier, the M574 command with E parameter was used to specify whether a Z probe connected to the E0 endstop input produces an active high (S1) or active low (S0) output. In RepRapFirmware 1.17 and later, use the I parameter of the M558 command instead.
2.0+ | Yes | ??? | No | ??? | No | No | ??? | No | |
No | No | No | No | No | No | No | No | ??? |
- Parameters
Pnnn
Serial channel numberBnnn
Baud rateSnnn
Whether checksums should be used- Example
M575 P1 B57600 S1
This sets the communications parameters of the serial comms channel specified by the P
parameter. P0
specifies the main serial interface (typically a USB port, or serial-over-USB), while P1
specifies an auxiliary serial port (for example, the port used to connect a PanelDue). The B
parameter is the required baud rate (this parameter is typically ignored if the port is a true USB port). The S
parameter is a bitmap of features. The lowest bit, if set, specifies that only commands that include a valid checksum should be accepted from this comms channel.
M577: Wait until endstop is triggered
??? | No | No | No | No | ??? | No | No | No |
- Parameters
Snnn
Desired endstop levelXnnn
Select X axis endstopYnnn
Select Y axis endstopZnnn
Select Z axis endstopEnnn
Select extruder drive endstop- Example
M577 E0 S1
Wait for an endstop switch to be pressed. The example above will wait until the first extruder endstop is triggered.
The following trigger types may be used using the 'S' parameter:
0: Endstop not hit 1: Low endstop hit 2: High endstop hit 3: Near endstop (only Z probe)
M578: Fire inkjet bits
- Parameters
Pnnn
Inkjet head numberSnnn
Bit pattern- Example
M578 P3 S5
This fires inkjet head 3 (the P field) using the bit pattern specified by the S field. The example shown would fire bits 101. If the P
parameter is ommitted inkjet 0 is assumed.
This is a version of the M700 command used by the Inkshield, but unfortunately M700 is already taken so cannot be used for that in the standard.
M579: Scale Cartesian axes
- Parameters
Xnnn
Scale factor for X axisYnnn
Scale factor for Y axisZnnn
Scale factor for Z axis- Example
M579 X1.0127 Y0.998
On a Cartesian RepRap you can get prints exactly the right size by tweaking the axis steps/mm using the M92 G Code above. But this does not work so easily for Delta and other RepRaps for which there is cross-talk between the axes. This command allows you to adjust the X, Y, and Z axis scales directly. So, if you print a part for which the Y length should be 100mm and measure it and find that it is 100.3mm long then you set Y0.997 (= 100/100.3).
M580: Select Roland
- Parameters
Rnnn
Whether Roland mode should be activatedPnnn
Initial text to send to the Roland controller- Example
M580 R1 PVS4;!VZ2;!MC1;
This is not really anything to do with RepRap, but it is convenient. The little Roland mills are very widely available in hackerspaces and maker groups, but annoyingly they don't speak G Codes. As all RepRap firmware includes a G-Code interpreter, it is often easy to add functions to convert G Codes to Roland RML language. M580 selects a Roland device for output if the R field is 1, and returns to native mode if the R
field is 0. The optional P
string is sent to the Roland if R
is 1. It is permissible to call this repeatedly with R
set to 1 and different strings in the P
field to communicate directly with a Roland.
M581: Configure external trigger
- Parameters
Tnn
Logical trigger number to associate the endstop input(s) with, from zero up to a firmware-specific maximum (e.g. 9 for RepRapFirmware)X, Y, Z, E
Selects endstop input(s) to monitorP
Reserved, may be used in future to allow general I/O pins to cause triggersS
Whether trigger occurs on a rising edge of that input (S1, default), falling edge (S0), or ignores that input (S-1). By default, all triggers ignore all inputs.C
Condition: whether to trigger at any time (C0, default) or only when printing a file from SD card (C1)- Example
M581 E1:2 S1 T2 C1 ; invoke trigger 2 when a rising edge is detected on the E1 or E2 endstop input and a file is being printed from SD card
When M581
is executed, if the T
parameter is present but the other parameters are omitted, the trigger inputs and edge polarities for that trigger number are reported. Otherwise, the specified inputs and their polarities are added to the conditions that cause that trigger. Using S-1
with no X
, Y
, Z
or E
parameters sets the trigger back to ignoring all inputs.
In RepRapFirmware, trigger number 0 causes a full (emergency) stop as if M112
had been received. Trigger number 1 causes the print to be paused as if M25
had been received. Any trigger number # greater then 1 causes the macro file sys/trigger#.g
to be executed. Polling for further trigger conditions is suspended until the trigger macro file has been completed. RepRapFirmware does not wait for all queued moves to be completed before executing the macro, so you may wish to use the M400
command at the start of your macro file. If several triggers are pending, the one with the lowest trigger number takes priority.
M582: Check external trigger
- Parameters
- T Trigger number to poll
- Example
M582 T2 ; check levels of inputs that give rise to trigger #2
Triggers set up by the M581 command are normally activated only when the specified inputs change state. This command provides a way of causing the trigger to be executed if the input is at a certain level. For each of the inputs associated with the trigger, the trigger condition will be checked as if the input had just changed from the opposite state to the current state.
For example, if you use M581 to support an out-of-filament sensor, then M582 allows you to check for out-of-filament just before starting a print.
M584: Set drive mapping
No | 1.14+ | ??? | No | ??? | No | No | ??? | No | |
- Parameters
Xnnn
Driver number(s) for X motor(s)Ynnn
Driver number(s) for Y motor(s)Znnn
Driver number(s) for Z motor(s)U,V,W, A, B, Cnnn
Driver number(s) for additional axes U, V, W, A, B and C (UVW RepRapFirmware 1.16 and later; ABC RepRapFirmware 1.19 and later)Ennn
Driver number(s) for E motor(s)Pnnn
Number of visible axes, defaults to the total number of axes configured.- Example
- M584 X0 Y1 Z2:3 E4:5:6 ; Driver 0 controls the X motor, 1 controls Y, 2 and 3 control Z motors, 4 and 5 control E motors
Assigning a drive using M584
does not remove its old assignment. Therefore, if you assign a drive that defaults to being an extruder drive, you should also assign the extruder drives explicitly as in the above example. Failure to do so may result in unexpected behaviour.
You can use M584
to create additional axes - for example, to represent additional carriages on a machine with multiple independent X carriages. Additional axes must be created in the order UVWABC. You can hide some of the last axes you create using the P parameter. Hidden axes have no homing buttons or jog controls in the user interface.
On the Duet WiFi and Duet Ethernet, if you configure multiple drivers for an axis, either all of them must be TMC2660 drivers on the Duet or a Duet expansion board, or none of them must be. This is to facilitate dynamic microstepping and other features of the TMC2660.
M585: Probe Tool
No | 1.20+ | ??? | No | ??? | No | No | ??? | No | |
In machines with a tool probe this probes the currently selected tool against it and corrects the offsets set by the G10 command (q.v.).
- Parameter must be only one of
Xnnn
Y-nnn
Znnn
Where the absolute value of nnn
is the radius of the tool plus the radius of the probe in that direction. So M585 X1.5
will set the X offset of a 1mm diameter tool against a 2mm diameter probe, etc. If the value of nnn
is positive the tool is moved in the positive direction towards the probe until it touches. If it is negative, the tool moves the other way.
So the process should be:
- Set the values as closely as known in the
G10
command. - Move to a position slightly offset from the probe then execute
M585
s in X, Y and Z in the tool selection macro to set them precisely.
After this, the G10
command on its own can be used to report the values.
M586: Configure network protocols
No | 1.18+ | ??? | No | ??? | No | No | ??? | No | |
- Parameters
Pnn
Protocol: 0 = HTTP or HTTPS, 1 = FTP or SFTP, 2 = Telnet or SSH (which of the two choices depends on theT
parameter)Snn
0 = disable this protocol, 1 = enable this protocolRnn
TCP port number to use for the specified protocol. Ignored unless S = 1. If this parameter is not provided then the default port for that protocol and TLS setting is used.Tnn
0 = don't use TLS, 1 = use TLS. Ignored unlessS
= 1. If this parameter is not provided, then TLS will be used if the firmware supports it and a security certificate has been configured. IfT1
is given but the firmware does not support TLS or no certificate is available, then the protocol will not be enabled and an error message will be returned.
M586 with no S
parameter reports the current support for the available protocols.
RepRapFirmware 1.18 and later enable only HTTP (or HTTPS if supported) protocol by default. If you wish to enable FTP and/or Telnet, enable them using this command once or twice in config.g.
M587: Store WiFi host network in list, or list stored networks
No | 1.19+ | ??? | No | ??? | No | No | ??? | No | |
- Parameters
Sccc
Network SSIDPccc
Network passwordInn.nn.nn.nn
(optional) IP address to use when connected to this network. If zero or not specified then an IP address will be acquired via DHCP.Jnn.nn.nn.nn
(optional) Gateway IP address to use when connected to this network.Knn.nn.nn.nn
(optional) Netmask to use when connected to this network
If a password or SSID includes space or semicolon characters then it must be enclosed in double quotation marks. For security, do not use this command in the config.g file, or if you do then remove it after running it once so that the network password is not visible in the file.
M587
with no parameters lists all stored SSIDs, but not the stored passwords.
M588: Forget WiFi host network
- Parameters
Sccc
SSID to remove from the networks list
The specified SSID will be removed from the networks list and the associated password cleared out of EEPROM. If the SSID is given as * then all stored networks will be forgotten.
M589: Configure access point parameters
- Parameters
Sccc
The SSID that the WiFi interface should use when it is commanded to run as an access pointPccc
The WiFi passwordInn.nn.nn.nn
The IP address to use
Note: WPA2 security will be used by default.
M590: Report current tool type and index
No | No | ??? | No | ??? | No | No | ??? | No | |
Report the current tool type, which may be "Extruder," "Picker," "Laser," "Foam Cutter," "Milling," or any others implemented by the machine. Also report the tool index, such as "0x01" for the second extruder.
- Example
> M590 > echo: Extruder 0x00
M591: Configure filament monitoring
No | 1.21+ | ??? | No | ??? | No | No | ??? | No | |
This configures filament sensing for the specified extruder. The sensor may be a simple filament presence detector, or a device that measures movement of filament, or both. The action on detecting a filament error is firmware-dependent, but would typically be to run a macro and/or to pause the print and display a message.
- Parameters
- Cnn Which input the filament sensor is connected to. On Duet electronics: 0=X endstop input, 1=Y endstop input, 2=Z endstop input, 3=E0 endstop input etc.
- Dnn Extruder drive number (0, 1, 2...),
- Pnn Type of sensor: 0=none, 1=simple sensor (low signal when filament present), 2=simple sensor (high signal when filament present), 3=Duet3D rotating magnet sensor, 4=Duet3D rotating magnet sensor with microswitch, :Snn S0 = disable filament monitoring, S1 = enable filament monitoring. Calibration data may be collected while printing even when filament monitoring is disabled.
5=Duet3D laser filament monitor, 6=Duet3D laser filament monitor with microswitch, 7=pulse-generating sensor
- Additional parameters for Duet3D laser filament monitor
- Raa:bb Allow the filament movement reported by the sensor to be between aa% and bb% of the commanded values; if it is outside these values and filament monitoring is enabled, the print will be paused
- Enn minimum extrusion length before a commanded/measured comparison is done, default 3mm
- Additional parameters for Duet3D rotating magnet filament monitor
- Lnn Filament movement per complete rotation of the sense wheel, in mm
- R, E As for Duet3D laser filament monitor
- Additional parameters for a pulse generating filament monitor
- Lnn Filament movement per pulse in mm
- Examples
- M591 D0 C3 P5 S1 R70:130 L24.8 E6.0 ; Duet3D laser sensor for extruder drive 0 is connected to E0 endstop input, 24.8mm/rev, 70% to 130% tolerance, 6mm detection length
- M591 D1 ; display filament sensor parameters for extruder drive 1
Note: RepRapFirmware 1.19 and 1.20 also supported filament monitors via M591, but some of the parameters were different.
M592: Configure nonlinear extrusion
No | 1.20.1+ | ??? | No | ??? | No | No | ??? | No | |
- Parameters
- Annn A coefficient in the extrusion formula, default zero
- Bnnn B coefficient in the extrusion formula, default zero
- Lnnn Upper limit of the nonlinear extrusion compensation, default 0.2
- T nnn Reserved for future use, for the temperature at which these values are valid
- Example
- M592 D0 A0.01 B0.0005 ; set parameters for extruder drive 0
- M592 D0 ; report parameters for drive 0
Most extruder drives use toothed shafts to grip the filament and drive it through the hot end. As the extrusion speed increases, so does the back pressure from the hot end, and the increased back pressure causes the amount of filament extruded per step taken by the extruder stepper motor to reduce. This may be because at high back pressures, each tooth compresses and skates over the surface of the filament for longer before it manages to bite. See forum post http://forums.reprap.org/read.php?262,802277 and the graph at http://forums.reprap.org/file.php?262,file=100851,filename=graph.JPG for an example.
Nonlinear extrusion compensates for this effect. The amount of extrusion requested is multiplied by (1 + MIN(L, A*v + B*v^2)) where v is the requested extrusion speed (calculated from the actual speed at which the move will take place) in mm/sec.
Nonlinear extrusion is not applied to extruder-only movements such as retractions and filament loading.
M593: Configure Dynamic Acceleration Adjustment
No | 2.02+ | ??? | No | ??? | No | No | ??? | No | |
- Parameters
- Fnnn Frequency of ringing to cancel in Hz. Zero or negative values disable the feature.
- Example
- M593 F40.5
This is an experimental feature of RepRapFirmware. By default, Dynamic Acceleration Adjustment (DAA) is disabled. If it is enabled, then acceleration and deceleration rates will be adjusted separately per-move to cancel out ringing at the specified frequency. Any acceleration values set using M204 will be saved but ignored until DAA is disabled, but acceleration limits set by M201 will still be honoured.
DAA is most useful to avoid exciting low-frequency ringing, for which S-curve acceleration is ineffective and may make the ringing worse. High-frequency ringing is better countered by using S-curve acceleration.
To measure the ringing frequency, take a print that exhibits ringing on the perimeters (for example a cube), preferably printed single-wall or external-perimeters-first. Divide the speed at which the outer perimeter was printed (in mm/sec) by the distance between adjacent ringing peaks (in mm), measured away from the corner so that the head has reached the full printing speed.
Cartesian and CoreXY printers will typically have different frequencies of ringing for the X and Y axes. In this case it is is usually best to aim to cancel the lower ringing frequency, because the higher frequency will be less strongly excited. If the frequencies are not much different, in a moving-bed cartesian printer you could reduce the higher ringing frequency by adding mass to that axis. Note that X axis ringing causes artefacts predominantly on the Y face of the test cube, and vice versa.
M594: Enter/Leave Height Following mode
No | 3.0+ | ??? | No | ??? | No | No | ??? | No | |
- Parameters
- Pn P1 = enter height following mode, P0 = leave height following mode
Height following mode allows the Z position of the tool to be controlled by a PID controller using feedback from a sensor. See also M951.
If a movement command (e.g. G1) explicitly mentions the Z axis while height following mode is active, existing moves in the pipeline will be allowed to complete and the machine allowed to come to a standstill. Then height following mode will be terminated and the new move executed.
M600: Set line cross section
No | No | ??? | No | ??? | ??? | ??? | ??? | No | |
- Example
M600 P0.061
Sets the cross section for a line to extrude in velocity extrusion mode. When the extruder is enabled and movement is executed the amount of extruded filament will be calculated to match the specified line cross section.
M600: Filament change pause
Yes | 2.02RC3+ | ??? | Yes1 | ??? | ??? | Yes | ??? | Yes | |
Pause for filament change.
- Parameters
X[pos]
Y[pos]
Z[relative lift]
E[initial retract]
L[later retract distance for removal]
AUTO
Automatically (only Prusa Firmware with MMU connected)1
- Example
M600
In SmoothieWare:
The variable "after_suspend_gcode" is run after M600
For example:
after_suspend_gcode G91_G0E-5_G0Z10_G90_G0X-50Y-50 # gcode to run after suspend, retract then get head out of way
In RepRapFirmware, M600 causes macro file filament-change.g to be run if it exists, otherwise it falls back to pause.g. The parameters in the M600 command are ignored.
- Notes
In Prusa Firmware this command is also used when the Filament Runout Sensor triggers. To prevent filament blobs it will raise to 25mm if it has been triggered blow 25mm layer height. Default are X=211, Y=0, Z=2mm, E=-2, L=-801
M601: Pause print
??? | ??? | ??? | Yes | ??? | ??? | ??? | ??? | ??? | |
Pauses print on Prusa i3 MK2/s,MK2.5/s,MK3/s.
M602: Resume print
Resumes print on Prusa i3 MK2/s,MK2.5/s,MK3/s.
M603: Stop print
Stops print on Prusa i3 MK2/s,MK2.5/s,MK3/s.
Yes | Use M563 | ??? | No | ??? | ??? | No | ??? | Yes | |
Set Dual X-Carriage movement mode.
- Parameters
S[mode]
Mode (see below)X[duplication x-offset]
Optional X offset for Mode 2R[duplication temp offset]
Optional temperature difference for Mode 2
- Example
M605 S1 ; Set mode to auto-park
M605 S0
: Full control mode. The slicer has full control over x-carriage movement
M605 S1
: Auto-park mode. The inactive head will auto park/unpark without slicer involvement
M605 S2 [Xnnn] [Rmmm]
: Duplication mode. The second extruder will duplicate the first with nnn millimeters x-offset and an optional differential hotend temperature of mmm
degrees. E.g., with "M605 S2 X100 R2
" the second extruder will duplicate the first with a spacing of 100mm in the x direction and 2 degrees hotter.
RepRapFirmware does not implement M605 because it supports dual carriage mode, duplication mode, auto park, different temperatures etc. using the M563 tool definition command and the tool change macro files.
M650: Set peel move parameters
No | 2.02+ | ??? | No | ??? | No | ??? | ??? | ??? | |
No | ??? | ??? | ??? | ??? | No | ??? | ??? | ??? |
This command is sent by nanoDLP to set the parameters for the peel move used after curing a layer. RepRapFirmware ignores it.
M651: execute peel move
This command is sent by nanoDLP to execute a peel move after curing a layer. RepRapFirmware executes macro /sys/peel-move.g in response to this command.
M665: Set delta configuration
Yes | Yes | ??? | No | ??? | No | Yes | ??? | Yes | |
- Parameters
Lnnn
Diagonal rod lengthRnnn
Delta radiusSnnn
Segments per second1Bnnn
Safe probing radius2,3Hnnn
Delta height defined as nozzle height above the bed when homed after allowing for endstop corrections 2Xnnn
X tower position correction2,4Ynnn
Y tower position correction2,4Znnn
Z tower position correction2,4- Examples
M665 L250 R160 S200 ; (Marlin) M665 L250 R160 B80 H240 X0 Y0 Z0 ; (RepRapFirmware and Marlin 1.1.0)
Set the delta calibration variables. (See the discussion page for notes on this implementation.)
- Notes
1Only supported on Marlin.
2Only supported in RepRapFirmware and Marlin 1.1.0.
3 In Marlin 1.1.0 sets the radius on which the probe points are taken for the delta auto calibration routine G33 as well as for the manual LCD calibration menu.
4X, Y and Z tower angular offsets from the ideal (i.e. equilateral triangle) positions, in degrees, measured anti-clockwise looking down on the printer. In Marlin 1.1.0 X,Y and Z tower angular offsets will be rotated so the Z tower angular offset is zero.
Yes | Yes | ??? | No | ??? | Yes | Yes | ??? | Yes | |
- Parameters
Xnnn
X axis endstop adjustmentYnnn
Y axis endstop adjustmentZnnn
Z axis endstop adjustmentAnnn
X bed tilt in percent1Bnnn
Y bed tilt in percent1- Example
M666 X-0.1 Y+0.2 Z0
In RepRapFirmware and Repetier, positive endstop adjustments move the head closer to the bed when it is near the corresponding tower. In Marlin and Smoothieware, negative endstop corrections move the head closer to the bed when it is near the corresponding tower.
In Marlin, only negative endstop corrections are allowed. From version 1.1.0 onward positive endstops are allowed to be entered but the endstops will be normalized to zero or negative and the residue will be subtracted from the delta height defined in M665.
In Repetier the endstop corrections are expressed in motor steps. In other firmwares they are expressed in mm.
1RepRapFirmware 1.16 and later.
M667: Select CoreXY mode
No | Yes | ??? | No | ??? | No | No | ??? | Yes | |
- Parameters
Snnn
CoreXY modeXnnn
X axis scale factorYnnn
Y axis scale factorZnnn
Z axis scale factor- Example
M667 S1
M667 S0
selects Cartesian mode (unless the printer is configured as a delta using the M665
command). Forward motion of the X motor moves the head in the +X direction. Similarly for the Y motor and Y axis, and the Z motor and Z axis. This is the default state of the firmware on power up.
M667 S1
selects CoreXY mode. Forward movement of the X motor moves the head in the +X and +Y directions. Forward movement of the Y motor moves the head in the -X and +Y directions.
M667 S2
selects CoreXZ mode. Forward movement of the X motor moves the head in the +X and +Z directions. Forward movement of the Z motor moves the head in the -X and +Z directions.
Additional parameters X, Y and Z may be given to specify factors to scale the motor movements by for the corresponding axes. For example, to specify a CoreXZ machine in which the Z axis moves 1/3 of the distance of the X axis for the same motor movement, use M667 S2 Z3. The default scaling factor after power up is 1.0 for all axes.
To change the motor directions, see the M569 command.
M668: Set Z-offset compensations polynomial
Support | Marlin | RepRapFirmware | Klipper | Prusa | Buddy | Repetier | Smoothie | Druid | MK4duo |
No | dc42-cmm | ??? | No | ??? | No | No | ??? | No | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | MakerBot | |
Polynomial compensation is an experimental method to compensate for geometric distortion of a delta machine Z-plane. After the bed is compensated with the set of G30 points, there remains error. This method fits a 6th degree polynomial with independent origins for each order to the residual error data (using a simulated annealing technique on the host). The polynomial is communicated and controlled through M668
. Because the polynomial takes many floating point operations to compute each point, the firmware builds a grid of values, and used bi-linear interpolation to adjust the actual Z-axis offset error estimate.
For the polynomial used, 40 parameters are specified. The I
parameter allows the coefficients to be loaded a few at a time, which limits the size of the G-code string. The index starts with 1, not with 0.
M668 Ix S[list of values]
sets the polynomial parameters starting at index x, if index present and != 0.
M668 R
recomputes the grid based on the current parameters.
M668 P[0|1]
turns off or on the polynomial compensation.
- Typical usage
M668 I1 S4.882E-17:0.0 M668 I3 ... ... M668 R P1
Which sets the list, computes the interpolation grid, and then enables compensation.
M669: Set kinematics type and kinematics parameters
- Parameters
- Knnn Kinematics type: 0 = Cartesian, 1 = CoreXY, 2 = CoreXZ, 3 = linear delta, 4 = serial SCARA, 5 = CoreXYU, 6 = Hangprinter, 7 = polar, 8 = CoreXYUV, 9 = linear delta + Z axis, 10 = rotary delta
Selects the specified kinematics, then uses the other parameters to configure it. If the K parameter is missing then the other parameters are used to update the configuration data for the current kinematics. If no parameters are given then the current kinematics and configuration parameters are reported
- Parameters for serial SCARA kinematics
- Pnnn Proximal arm length (mm)
- Dnnn Distal arm length (mm)
- Annn:nnn Proximal arm joint movement minimum and maximum angles, in degrees anticlockwise seen from above relative to the X axis
- Bnnn:nnn Proximal-to-distal arm joint movement minimum and maximum angles, in degrees anticlockwise seen from above relative to both arms in line
- Cnnn:nnn:nnn Crosstalk factors. The first component is the proximal motor steps to equivalent distal steps factor, the second is the proximal motor steps to equivalent Z motor steps factor, and the third component is the distal motor steps to equivalent Z motor steps factor.
- Snnn Segments per second if smooth XY motion is approximated by means of segmentation
- Tnnn Minimum segment length (mm) if smooth XY motion is approximated by means of segmentation
- Xnnn X offset of bed origin from proximal joint
- Ynnn Y offset of bed origin from proximal joint
- Examples
M669 K4 P300 D250 A-90:90 B-135:135 C0:0:0 S200 X300 Y0
The minimum and maximum arm angles are also the arm angles assumed by the firmware when the homing switches are triggered. The P, D, A and B parameters are mandatory. The C and F parameters default to zero, and the segmentation parameters default to firmware-dependent values.
- Parameters for Polar kinematics
- Raaa:bbb Minimum and maximum radius in mm. If only one value it given it will be used as the maximum radius, and the minimum radius will be assumed to be zero.
- Hnnn Radius in mm at which the homing switch is triggered during a homing move. If this parameter is not present, the homing switch is assumed to trigger at the minimum radius.
- Fnnn Maximum turntable speed in degrees per second
- Annn Maximum turntable acceleration in degrees per second per second
M670: Set IO port bit mapping
- Parameters
- Pnn:nn:nn... List of logical port numbers that bits 0, 1, 2... control
- Tnnn port switching time advance in milliseconds
RepRapFirmware 1.19 and later provides an optional P parameter on the G1 command to allow I/O ports to be set to specified states for the duration of the move. The argument to the P parameter is a bitmap giving the required state of each port. The M669 command specifies the mapping between the bits of that argument and logical port numbers. Optionally, the T parameter can be used to advance the I/O port switching a short time before the corresponding move begins.
M671: Define positions of Z leadscrews or bed leveling screws
M422 | 1.19+ | ??? | No | ??? | No | No | ??? | No | |
- Parameters
- Xnn:nn:nn... List of between 2 and 4 X coordinates of the leadscrews that drive the Z axis or the bed leveling screws
- Ynn:nn:nn... List of between 2 and 4 Y coordinates of the leadscrews that drive the Z axis or the bed leveling screws
- Snn Maximum correction to apply to each leadscrew in mm (optional, default 1.0)
- Pnnn Pitch of the bed leveling screws (not used when bed leveling using independently-driven leadscrews). Defaults to 0.5mm which is correct for M3 bed leveling screws.
- Example
- M671 X-15.0:100.0:215.0 Y220.0:-20.0:220.0 ; Z leadscrews are at (-15,220), (100,-20) and (215,220)
Informs the firmware of the positions of the leadscrews used to raise/lower the bed or gantry. The numbers of X and Y coordinates must both be equal to the number of drivers used for the Z axis (see the M584 command). This allows the firmware to perform bed leveling by adjusting the leadscrew motors individually after bed probing.
For machines without multiple independently-driven Z leadscrews, this command can be used to define the positions of the bed leveling screws instead. Then bed probing can be used to calculate and display the adjustment required to each screw to level the bed. The thread pitch (P parameter) is used to translate the height adjustment needed to the number of turns of the leveling screws.
M672: Program Z probe
- Parameters
- Snn:nn:nn... Sequence of 8-bit unsigned values to send to the currently-selected Z probe
- Example
- M671 S50:205
This command is for sending configuration data to programmable Z probes such as the Duet3D delta effector. The specified command bytes are sent to the probe. The Duet3D probe stores the configuration data in non-volatile memory, so there is no need to send this command every time the probe is used.
M673: Align plane on rotary axis
- Parameters
- U,V,W,A,B,C Rotary axis letter on which the plane is mounted
- Pnnn Factor to multiply the correction angle (degrees) with (defaults to 1)
- Example
- M673 A
This code is intended to align a plane that is mounted on a rotary axis. To make use of this code it is required to take two probe points via G30 P first. Supported in RepRapFirmware 2.02 and later.
M674: Set Z to center point
No | TBD | ??? | No | ??? | No | No | ??? | No | |
This code is intended to determine the Z center point of a stash that is mounted on a rotary axis. This code is yet to be implemented.
M675: Find center of cavity
- Parameters
- X,Y,Z Axis to probe on
- Fnnnn Probing feedrate
- Rnnn Distance to move away from the lower endstop before the next probing move starts
- Example
- M675 X R2 F1200
This code is intended to find the center of a cavity that can be measured using the configured axis endstop. If using a Z probe for this purpose, make sure the endstop type for the corresponding axis is updated before this code is run. Once this code starts, RepRapFirmware will move to the lower end looking for an endstop to be triggered. Once it is triggered, the lower position is saved and the axis maximum is probed. As soon as both triggers have been hit, the center point is calculated and the machine moves to the calculated point.
M700: Level plate
No | M671,G32 | ??? | No | ??? | No | No | ??? | No | |
No | No | No | No | No | No | No | ??? | No |
- Example
M700
M701: Load filament
Yes | 1.19+ | ??? | Yes | ??? | No | No | ??? | Yes | |
Initiate a filament load. This command can be used without any additional parameters.
- Parameters
Snn
Filament to load (RepRapFirmware)Tnn
Tool to load (Marlin)Lnn
Length to use for load (Marlin)Znn
Z raise to perform (Marlin)
- With no parameters
- RepRapFirmware will report the name of the loaded filament (if any).
- Marlin Firmware initiates a Filament Load.
- Examples
M701 M701 S"PLA" ; Only in RepRapFirmware M701 T0 ; Only in Marlin.
RepRapFirmware 1.19 and later implement a filament management mechanism to load and unload different materials. This code may be used to load a material for the active tool, however be aware that this code will work only for tools that have exactly one extruder assigned. When called RepRapFirmware will...
- Run the macro file "load.g" in the subdirectory of the given material (e.g. /filaments/PLA/load.g)
- Change the filament name of the associated tool, so it can be reported back to Duet Web Control
M702: Unload filament
Initiate a filament unload. This command can be used without any additional parameters. In contrast to M701
this code is intended to unload the previously loaded filament from the selected tool.
- Parameters
Tnn
Tool to load (Marlin)Unn
Length to use for unload (Marlin)Znn
In response to M702
RepRapFirmware will do the following:
- Run the macro file "unload.g" in the subdirectory of the given material (e.g.
/filaments/PLA/unload.g
) - Change the filament name of the current tool, so it can be reported back to Duet Web Control
- Examples
M702 ; Unload filament as previously configured M702 U420 Z2 ; Unload 420mm (Marlin) with a Z raise of 2mm
M703: Configure Filament
- In RepRapFirmware this code is used to apply the configuration of a previously loaded filament (see M701). All it does is run
/filaments/<loaded filament>/config.g
which may contain codes to set parameters like extrusion factor, retraction distances and temperatures. If no filament is assigned to the current tool, this code will not generate a warning.
If the filaments feature is used, it is recommended to put this code into tpost*.g
to ensure the right filament parameters are set. Supported in RepRapFirmware 2.02 and newer.
M710: Erase the EEPROM and reset the board
No | M999 | ??? | No | ??? | No | No | ??? | No | |
This command only exists in a defunct bq fork of Marlin Firmware.
- Example
M710
M750: Enable 3D scanner extension
- Example
M750
This code may be used as an OEM extension to enable scanner functionality in the firmware. After a regular start of RepRapFirmware, the 3D scan extension is disabled by default, but if additional scanner components are attached, this code may be used to enable certain OEM functions.
M751: Register 3D scanner extension over USB
- Example
M751
When a 3D scanner board is attached to the USB port, this code is used to turn on communication between the 3D printing and the scanner board. If the USB connection is removed while the 3D scanner configuration is active, the firmware will disable it again and restore the default communication parameters.
M752: Start 3D scan
- Parameters
Snnn
: Length/degrees of the scanRnnn
: Resolution (new in RRF 2.0) [optional, defaults to 100]Nnnn
: Scanner mode (new in RRF 2.0) [optional, 0=Linear (default), 1=Rotary]Pnnn
: Filename for the scan- Example
M752 S300 Pmyscan
Instruct the attached 3D scanner to initiate a new 3D scan and to upload it to the board's SD card (i.e. in the "scans" directory). Before the SCAN command is sent to the scanner, the macro file "scan_pre.g" is executed and when the scan has finished, the macro file "scan_post.g" is run. Be aware that both files must exist to avoid error messages.
M753: Cancel current 3D scanner action
- Example
M753
Instruct the attached 3D scanner to cancel the current operation. Cancelling uploads is not supported.
M754: Calibrate 3D scanner
- Parameters
- Nnnn Calibration mode (0=linear [default], 1=rotary)
- Example
M754
Calibrates the attached 3D scanner. Before the calibration is performed by the external scanner, "calibrate_pre.g" is run and when it is complete, "calibrate_post.g" is executed.
M755: Set alignment mode for 3D scanner
- Parameters
Pnnn
Whether to turn on (> 0) or off (<= 0) the alignment feature- Examples
M755 P1 M755 P0
Sends the ALIGN ON/OFF command the attached 3D scanner. Some devices turn on a laser when this command is received. If the 'P' parameter is missing, equal to, or less than 0, the alignment feature is turned off. Depending on whether the alignment is turned on or off, either align_on.g or align_off.g is executed before the ALIGN command is sent to the scanner.
M756: Shutdown 3D scanner
- Example
M756
Sends the SHUTDOWN command the attached 3D scanner.
M800: Fire start print procedure
bq | No | ??? | ??? | ??? | No | No | ??? | No | |
1 only in bq-Marlin Firmware
- Example
M800
M801: Fire end print procedure
bq | No | ??? | ??? | ??? | No | No | ??? | bq | |
- Example
M801
M851: Set Z-Probe Offset
Yes | 2.02RC5 and later, or use G31 | ??? | Yes | ??? | ??? | ??? | ??? | Yes | |
??? | ??? | ??? | ??? | ??? | ??? | ??? | No | ??? |
Sets the Z-probe Z offset. This offset is used to determine the actual Z position of the nozzle when using a probe to home Z with G28. This value may also be used by G29 to apply correction to the Z position.
This value represents the distance from nozzle to the bed surface at the point where the probe is triggered. This value will be negative for typical switch probes, inductive probes, and setups where the nozzle makes a circuit with a raised metal contact. This setting will be greater than zero on machines where the nozzle itself is used as the probe, pressing down on the bed to press a switch. (This is a common setup on delta machines.)
This setting is saved in the EEPROM by M500 and restored by M501
. The default (as reset by M502) is set by the Z_PROBE_OFFSET_FROM_EXTRUDER setting in Configuration.h.
Note that in Marlin 1.1.0 and later M851
sets the value literally as given, while Marlin 1.0.2 negates the absolute value.
The examples below will set the Z-probe Z offset to -4mm (below the nozzle):
M851 in Marlin 1.0.2
M851 Z4 ; Set the Z probe offset to -4
M851 in Marlin 1.1.0
M851 Z-4 ; Set the Z probe offset to -4
M851 in Marlin 2.0.0
M851 X-22 Y3 Z-4 ; Set the probe XYZ offsets
M851 in MK4duo 4.3.25
M851 X2 Y-5 Z-4 ; Set the probe offset to X=2, Y=-5 and Z=-4
M851 in RepRapFirmware 2.02RC5 and later
M851 Znn is implemented for backwards compatibility with other firmwares. It sets the Z probe trigger in the same way as G31 Z-nn (note the sign reversal). It also flags the Z-probe G31 parameters as to be saved in config-override.g if the M500 command is used.
M860 Wait for Probe Temperature
No | No | ??? | Yes | ??? | No | No | ??? | No | |
- Parameters
Snnnn
Target temperature
- Notes
In Prusa Firmware this command will wait for the PINDA thermistor to reach a target temperature.
M861 Set Probe Thermal Compensation
- Parameters
Print current EEPROM offset values!
Set factory default valuesZ
Set all values to 0 (effectively disabling PINDA temperature compensation)S
MicrostepsI
Table index
- Example
M861 ?
Results
PINDA cal status: 1 index, temp, ustep, um n/a, 35, 0, 0.00 0, 40, 0, 0.00 1, 45, 0, 0.00 2, 50, 0, 0.00 3, 55, 0, 0.00 4, 60, 0, 0.00
- Notes
In Prusa Firmware this command will set / read the PINDA temperature compensation offsets.
M862: Print checking
Checks the parameters of the printer and gcode and performs compatibility check
M862.1: Check nozzle diameter
- Parameters
Pnnnn
nnnn = Nozzle diameter 0.25 /0.40 /0.60Q
Current nozzle diameter
When run with P<> argument, the check is performed against the input value. When run with Q argument, the current value is shown.
- Example messages
warn
Printer nozzle diameter differs from the G-code. Continue?strict
Printer nozzle diameter differs from the G-code. Please check the value in settings. Print cancelled.
M862.2: Check model code
- Parameters
Pnnnn
nnnn = Prusa modelQ
Current model
Accepted printer type identifiers and their numeric counterparts:
- MK1 (100) - MK2 (200) - MK2MM (201) - MK2S (202) - MK2SMM (203) - MK2.5 (250) - MK2.5MMU2 (20250) - MK2.5S (252) - MK2.5SMMU2S (20252) - MK3 (300) - MK3MMU2 (20300) - MK3S (302) - MK3SMMU2S (20302)
- Example messages
warn
G-code sliced for a different printer type. Continue?strict
G-code sliced for a different printer type. Please re-slice the model again. Print cancelled.
M862.3: Model name
- Parameters
P"nnnn"
nnnn = Prusa model nameQ
Current model name
It accepts text identifiers of printer types too. The syntax of M862.3 is (note the quotes around the type):
M862.3 P "MK3S"
- Example messages
warn
M862.4: Firmware version
- Parameters
Pnnnn
nnnn = Prusa firmware versionQ
Current firmware version
- Example messages
warn
G-code sliced for a newer firmware. Continue?strict
G-code sliced for a newer firmware. Please update the firmware. Print cancelled.
M862.5: Gcode level
- Parameters
Pnnnn
nnnn = Gcode level 0 = none, 1 = warn, 2= strictQ
Current Gcode level
- Example messages
warn
G-code sliced for a different level. Continue?strict
G-code sliced for a different level. Please re-slice the model again. Print cancelled.
M876: Dialog handling
Yes | No | ??? | ??? | ??? | No | No | ??? | Yes | |
- Parameters
Pnnn
signal support for dialog creation on the host = 1, disable = 0Snnn
select dialog option nnn (0 based)- Example
M876 P1 M876 S1
M876 S<n>
allows selecting an option of a prompt on a connected host created by the firmware through the corresponding action commands, see G-code#Action_commands. The S parameter is the 0-based index of the chosen option - 0 for the first option provided by the firmware, 1 for the second and so on.
Example: A prompt with three options defined via the firmware and completed by the host by selecting the second option ("Home X/Y and pause print")
<<< //action:prompt_begin Filament runout detected. Please choose how to proceed: <<< //action:prompt_choice Swap filament <<< //action:prompt_choice Home X/Y and pause print <<< //action:prompt_choice Abort print <<< //action:prompt_show >>> M876 S1
To indicate the availability of this function, M115
will add an extra line:
Cap:PROMPT_SUPPORT:1
so hosts know about the presence of the function.
M890 Run User Gcode
No | No | ??? | No | ??? | No | No | ??? | Yes | |
- Parameters
Snnn
select 1 - 5 User Gcode defined in configuration.- Example
M890 S2 ; Start User Gcode 2
M900 Set Linear Advance Scaling Factors
1.1.0 | use M572 | ??? | Yes | ??? | No | No | ??? | Yes | |
No | No | No | No | No | No | No | Yes | No |
Sets the advance extrusion factors for Linear Advance. If any of the R
, W
, H
, or D
parameters are set to zero the ratio will be computed dynamically during printing.
- Parameters
K[factor]
Advance K factorR[ratio]
Set ratio directly (overrides WH/D)W[width]
H[height]
D[diam]
Set ratio from WH/D- Examples
M900 K0.7 W0.4 H0.1 D1.75 ; Set K and WH/D ratio M900 R0.025 ; Set the WH/D ratio directly M900 R0 ; Set to "auto ratio"
Requires enabling the LIN_ADVANCE
feature in Marlin 1.1.
The K factor in the M900 command supported by early versions of Marlin is related to the S factor in the long-established M572 command supported by RepRapFirmware by the following formula:
K = S * extruder_steps_per_mm
More recent versions of Marlin appear to have removed the steps/mm dependency, so now K = S.
M905: Set local date and time
No | 1.16+ | ??? | No | ??? | No | No | ??? | No | |
- Parameters
Pnnn
Current date in the format YYYY-MM-DDSnnn
Current time in the format HH:MM:SS- Example
M905 P2016-10-26 S00:23:12
Updates the machine's local date and time or reports them if no parameters are specified. The time should be specified in 24-hours format as in "13:45" instead of 1:45PM.
M906: Set motor currents
No | Yes | ??? | No | ??? | No | M907? | ??? | No | |
- Parameters
Xnnn
X drive motor currentYnnn
Y drive motor currentZnnn
Z drive motor currentEnnn
E drive(s) motor current(s)Innn
Motor idle current in percent (0..100)- Example
M906 X300 Y500 Z200 E350:350
Sets the currents to send to the stepper motors for each axis. The values are the peak current per phase in milliamps.
The I
parameter is the percentage of normal that the motor currents should be reduced to when the printer becomes idle but the motors have not been switched off. The default value is 30%. On delta printers in particular you may need to increase it to e.g. 60% to prevent the carriages from dropping when the current is reduced to the idle value.
Yes | Use M906 | ??? | Yes | ??? | Yes | Yes | ??? | Yes | |
Set digital trimpot motor current using axis codes (X
, Y
, Z
, E
, B
, S
). In Repetier, it sets the current in Percent. In Redeem, it sets the current in Amps (whereas M906
uses milliamps).
Yes | No | ??? | No1 | ??? | Yes: 0.92 | No | ??? | Yes | |
??? | No | No | No | No | ??? | No | No | ??? |
M908 P<pin> S<current>
- Notes
In Prusa Firmware this G-code is deactivated by default, must be turned on in the source code.1
M909: Set microstepping
Use M350 | Use M350 | ??? | ??? | ??? | Use M350 | No | ??? | Use M350 | |
??? | No | No | No | No | Yes | No | ??? | ??? |
- Example
M909 X3 Y5 Z2 E3
Set the microstepping value for each of the steppers. In Redeem this is implemented as powers of 2 so…
M909 X2 ; set microstepping on X-axis to 2^2 = 4 M909 Y3 ; set microstepping on Y-axis to 2^3 = 8 etc.
M910: Set decay mode
No | Use M569 | ??? | No | ??? | No | No | ??? | No | |
- Example
M910 X3 Y5 Z2 E3
Set the decay mode for each stepper controller The decay mode controls how the current is reduced and recycled by the H-bridge in the stepper motor controller. It varies how the implementations are done in silicone between controllers. Typically you have an on phase where the current flows in the target current, then an off phase where the current is reversed and then a slow decay phase where the current is recycled.
M911: Configure auto save on loss of power ("power panic")
??? | No | No | No | No | No | No | No | ??? |
- Parameters
Saaa
Auto save threshold in volts. The print will be stopped automatically and resume parameters saved if the voltage falls below this value. Set to around 1V to 2V lower than the voltage that appears at the Duet VIN terminals at full load. A negative or zero value disables auto save.Raaa
Resume threshold in volts. Must be greater than the auto save voltage. Set to a high value to disable auto resume.P"command string"
G-Code commands to run when the print is stopped.- Example
- M911 S19.8 R22.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
When the supply voltage falls below the auto save threshold while a print from SD card is in progress, all heaters will be turned off, printing will be stopped immediately (probably in the middle of a move), the position saved, and the specified command string executed. You should typically do the following in the command string:
- If possible, use M913 to reduce the motor current in order to conserve power. For example, on most printers except deltas you can probably set the X and Y motor currents to zero.
- Retract a little filament and raise the head a little. Ideally the retraction should happen first, but depending on the power reserve when low voltage is detected, it may be best to do both simultaneously.
M911 with no parameters displays the current enable/disable state, and the threshold voltages if enabled.
Note: RepRapFirmware 1.19 used different parameters. You are recommended to upgrade to version 1.20 or later if you wish to use this "power panic" functionality.
M912: Set electronics temperature monitor adjustment
No | Yes | ??? | No | ??? | No | No | ??? | No | |
- Parameters
Pnnn
Temperature monitor channel, default 0Snnn
Value to be added to the temperature reading in degC
- Example
M912 P0 S10.5
Many microcontrollers used to control 3D printers have built-in temperature monitors, but they normally need to be calibrated for temperature reading offset. The S
parameter specifies the value that should be added to the raw temperature reading to provide a more accurate result.
M913: Set motor percentage of normal current
- Parameters
X, Y, Z, E
Percentage of normal current to use for the specified axis or extruder motor(s)
- Example
M913 X50 Y50 Z50 ; set X Y Z motors to 50% of their normal current M913 E30:30 ; set extruders 0 and 1 to 30% of their normal current
This allows motor currents to be set to a specified percentage of their normal values as set by M906
. It can be used (for example) to reduce motor current during course homing, to make homing quieter or to reduce the risk of damage to endstops, to reduce motor current when using sensorless endstops (motor stall detection), and to reduce current while loading filament to guard against the possibility of feeding too much filament. Use M913
again with the appropriate parameters set to 100 to restore the normal currents.
M914: Set/Get Expansion Voltage Level Translator
No | Alligator build only | ??? | No | ??? | No | No | ??? | No | |
- Parameters
S
Expansion voltage signal level, must be 3 or 5
- Example
M914 S5 ; set expansion signal level to 5V M913 ; report expansion signal voltage level
M915: Configure motor stall detection
- Parameters
- Pnnn:nnn:... Drive number(s) to configure
- X,Y,Z,U,V,W,A,B,C Axes to configure (alternative to using the P parameter)
- Snnn Stall detection threshold (-64 to +63, values below -10 not recommended)
- Fn Stall detection filter mode, 1 = filtered (one reading per 4 full steps), 0 = unfiltered (default, 1 reading per full step)
- Hnnn (optional) Minimum motor full steps per second for stall detection to be considered reliable, default 200
- Tnnn (optional) Coolstep control register, 16-bit unsigned integer
- Rn Action to take on detecting a stall from any of these drivers: 0 = no action (default), 1 = just log it, 2 = pause print, 3 = pause print, execute macro file /sys/rehome.g, and resume print
- Examples
- M915 P0:2:3 S10 F1 R0
- M915 X Y S5 R2
This sets the stall detection parameters and optionally the low-load current reduction parameters for TMC2660, TMC2130 or similar driver chips. Use either the P parameter to specify which driver number(s) you want to configure, or the axis names of the axes that those motors drive (the parameters will then be applied to all the drivers associated with any of those axes).
If any of the S, F, T and R parameters are absent, the previous values for those parameters associated with the specified drivers will continue to be used. If all the parameters are absent, the existing settings for the specified drives will be reported.
See the Trinamic TMC2660 and TMC2130 datasheets for more information about the operation and limitations of motor stall detection.
M916: Resume print after power failure
- Parameters
- none
- Example
- M916
If the last print was not completed and resume information has been saved (either because the print was paused or because of a power failure), then the heater temperatures, tool selection, head position, mix ratio, mesh bed compensation height map etc. are restored from the saved values and printing is resumed.
RepRapFirmware also requires macro file /sys/resurrect-prologue.g to be present on the SD card before you can use M915. This file is executed after the heater temperatures have been set, but before waiting for them to reach the assigned temperatures. You should put commands in this file to home the printer as best as you can without disturbing the print on the bed. To wait for the heaters to reach operating temperature first, use command M116 at the start of the file.
M917: Set motor standstill current reduction
- Parameters
- X,Y,Z,E Percentage of normal current to use when the motor is standing still or moving slowly, default 100
- Example
- M917 X70 Y70 Z80 E70:70
Some motor drivers (e.g. TMC2660) allow higher motor currents to be used while the motor is moving than when it is at standstill. This command sets the percentage of the current set by M906 that is to be used when the motor is stationary but not idle, or moving very slowly.
Standstill current reduction is not the same as idle current reduction. The standstill current must be high enough to produce accurate motion at low speeds; whereas the idle current (set using the I parameter in the M906 command) needs only to be high enough to hold the motor position sufficiently so that when the current is restored to normal, the position is the same as it was before the current was reduced to idle.
M918: Configure direct-connect display
This command is used to tell RepRapFirmware about a directly-connected dumb LCD or similar display.
- Parameters
- P Directly-connected display type: 0 = none (default), 1 = 128x64 pixel mono graphics display using ST7920 controller
- E The number of pulses generated by the rotary encoder per detent. Typical values are 2 and 4. Negative values (e.g. -2 and -4) reverse the encoder direction.
- Example
- M918 P1 E2
M928: Start SD logging
- Example
M928 filename.g
Stop SD logging with M29
M929: Start/stop event logging to SD card
- Parameters
- P"filename" The name of the file to log to. Only used if the S1 parameter is used. A default filename will be used if this parameter is missing.
- Sn S1 = start logging, S0 = stop logging
- Example
- M929 P"eventlog.txt" S1 ; start logging to file eventlog.txt
- M929 S0 ; stop logging
When event logging is enabled, important events such as power up, start/finish printing, most error messages and (if possible) power down will be logged to the SD card. Each log entry is a single line of text, starting with the date and time if available, or the elapsed time since power up if not. If the log file already exists, new log entries will be appended to the existing file.
M950: Create heater, fan or GPIO/servo device
- Parameters
- Hnn Heater number
- Fnn Fan number
- Pnn or Snn GPIO or Servo number (the only difference is the default PWM frequency)
- C"name" Pin name(s) and optional inversion status. Pin name "nil" frees up the pin. A leading '!' character inverts the output. A leading '^' character enables the pullup resistor. The '^' and '!' characters may be placed in either order.
- Qnn PWM frequency in Hz (optional)
- Tnn Temperature sensor number, required only when creating a heater [not yet implemented]. See M308.
- Examples
- M950 H1 C"out1" Q100 T1 ; create heater 1
- M950 H2 C"nil" ; disable heater 2 and free up the associated pin
- M950 F3 C"heater2" Q100 ; Fan 3 is connected to heater 2 pin, PWM at 100Hz
- M950 P0 C"exp.heater3" ; create GPIO port 0 attached to heater 3 pin on expansion connector
- M950 F2 C"!fan2+^pb6" ; Fan 2 uses the Fan2 output, but we are using a PWM fan so the output needs to be inverted, also we are using PB6 as a tacho input with pullup resistor enabled
M950 is used to create heaters, fans and GPIO ports and to assign pins to them. Each M950 command assigns a pin or pins to a single device. So every M950 command must have exactly one of the H, F, P or S parameters.
If a M950 command has C and/or Q parameters, then the pin allocation and/or frequency of the existing device will be configured accordingly. Otherwise, the current configuration will be reported.
M951: Set height following mode parameters
- Parameters
- Snn or Hnn Sensor number
- Pnn.n Proportional factor, in mm per sensor unit
- Inn.n Integral factor, in mm per sensor unit per second
- Dnn.n Derivative factor, in mm per rate of change of sensor units (change in sensor unit per second)
- Fnn.n (optional) Sample and correction frequency (Hz), default 5Hz
- Znn.n:nn.n Minimum and maximum permitted Z values
Height following mode allows the Z position of the tool to be controlled by a PID controller using feedback from a sensor. See also M594.
If commanding the motors to increase Z causes the sensor value to increase, then all of P, I and D must be positive. If commanding the motors to increase Z causes the sensor value to decrease, then all of P, I and D must be negative.
M952: Set CAN-FD bus data rate
- Parameters
- Sn.n Requested bit rate in Mbits/second. Ignored if it is lower than the bit rate for the negotiation phase.
- T0.n Fraction of the bit time between the bit start and the sample point (optional)
- J0.n Maximum jump time as a fraction of the bit time (optional)
- C0.n Transmitter delay compensation time in nanoseconds (optional)
- Example
- M952 S4.0 T0.6 J0.2
This command allows the bandwidth of the CAN bus to be optimised, by increasing the data rate during transmission of CAN-FD data packets by means of the BRS (bit rate switch) feature. The maximum speed supported by CAN-FD is 8Mbits/sec but the practical limit depends on the cable length, cable quality, number of devices on the bus and CAN interface hardware used. The rate specified will be rounded down to the nearest achievable rate.
M953: Change CAN-FD expansion board address
- Parameters
- Bn Existing CAN address of expansion board to be changed, 1 to 125.
- Sn New CAN address of that expansion board, 1 to 125.
- Example
- M953 B120 S11 ; change the CAN address of expansion board 101 to 11
Some CAN-connected expansion boards are too small to carry address selection switches. Such boards default to a standard address, which can be changed using this command.
M997: Perform in-application firmware update
??? | No | No | No | No | No | No | No | No |
- Parameters
Snnn
Firmware module number(s), default 0Bnnn
Expansion board address, default 0 (i.e. main controller board)- Example
M997 S0:1 ; update firmware modules 0 and 1 on the main controller board M997 B3 ; update firmware module 0 on the expansion board with address 3
This command triggers a firmware update if the necessary files are present on the SD card. In RepRapFirmware on the Duet series, module numbers are as follows:
0 - main firmware. The firmware filename depends on the controller electronics, e.g.sys/RepRapFirmware.bin (Duet 06/085), sys/Duet2CombinedFirmware (Duet WiFi/Ethernet), sys/DuetMaestroFirmware.bin (Duet Maestro). File sys/iap.bin (Duet), sys/iap4e.bin (Duet WiFi/Ethernet) or sys/iap4s.bin (Duet Maestro) must also be present.
1 - web server firmware, filename sys/DuetWiFiServer.bin
2 - (Duet WiFi running RepRapFirmware 1.18 and earlier only) web server file system, filename sys/DuetWebControl.bin
3 - put the WiFi module into bootloader mode so that firmware can be uploaded directly via its serial port
M998: Request resend of line
No | Yes | ??? | No | ??? | No | No | ??? | ??? | |
??? | No | No | No | No | ??? | No | ??? | ??? |
- Parameters
Pnnn
Line number- Example
M998 P34
Request a resend of line 34. In some implementations the input-handling code overwrites the incoming G Code with this when it detects, for example, a checksum error. Then it leaves it up to the G-code interpreter to request the resend.
No | No | No | No | No | No | No | No | No |
- Parameters
- This command can be used without any additional parameters.
Pnnn
Reset flags1- Example
M999
Restarts the firmware using a software reset.
- Notes
1The dc42 fork of RepRapFirmware not only resets the board but also puts the board into firmware upload mode if parameter PERASE is present.
Other commands
G: List all G-codes
No | No | No | No | No | Yes | No | No | No |
- Example
G
Print a list of all implemented G-codes in the firmware with description to the host.
(Note: this has been implemented in Redeem, and so is only a proposal.)
M: List all M-codes
- Example
M
Print a list of all implemented M-codes in the firmware with description to the host.
T: Select Tool
Yes | Yes | ??? | Yes | ??? | Yes | Yes | ??? | Yes | |
No | No | No | Yes | No | Yes | Yes | Yes | No |
- Parameters
Pnnn
: Bitmap of all the macros to be run (only RRF 1.17b or later)- Tool number
- Example
T1
The sequence followed is:
- Set the current tool to its standby temperatures specified by
G10
(see above), - Set the new tool to its operating temperatures specified by
G10
and wait for all temperatures to stabilise, - Apply any X, Y, Z offset for the new tool specified by
G10
, - Use the new tool.
Selecting a non-existent tool (100, say) just does Step 1 above1. That is to say it leaves all tools in their standby state. You can, of course, use the G10
command beforehand to set that standby temperature to anything you like.
Some firmware (Such as Prusa i3 Printers with MMU) also support the Tx
(recommended) and T?
(depricated)2 commands to prompt the user to select a tool (or a filament in the case of the MultiMaterial Unit) on the printer's menu. Then the Tc
command actually loads the selected filament.
Some implementations (e.g. RepRapFirmware) allow you to specify tool-change G Code macros3. There are normally three specified (any of which can contain no commands if desired) that execute in this order:
- Actions to do with the old tool before it is released - macro name:
tfreeN.g
where N is the tool number; - (Old tool is released);
- Actions to do with the new tool before it is selected - macro name:
tpreN.g
where N is the tool number; - (New tool is selected); and
- Actions to do with the new tool after it is selected - macro name:
tpostN.g
where N is the tool number.
With such implementations there is no wait for temperature stabilisation. That can be achieved by an M116
in any of the macros, of course. However be aware that recent RepRapFirmware versions does NOT run any tool change macros if the axes are not homed.
After a reset tools will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0
, M1
, and M112
commands turn them all off. You can, of course, turn them all off with the M1
command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
Tool numbering may start at 0 or 1, depending on the implementation. Some implementations (those that use the M563
command to define tools) allow the user to specify tool numbers, so with them you can have tools 17, 99 and 203 if you want. Negative numbers are not allowed.
- Notes
1 For RepRapFirmware, selecting a non-existent tool also removes any X/Y/Z offset applied for the old tool.
2 T?
was the original form of the command, but it was changed to Tx
when it was realized that the question mark character caused problems when printing through octoprint. This change was implemented in Prusa firmware 3.5.0.
3 Under special circumstances, the execution of those macro files may not be desired. RepRapFirmware 1.17b or later supports an optional P
parameter to specify which macros shall be run. If it is abscent then all of the macros above will be run, else you can pass a bitmap of all the macros to be executed. The bitmap of this value consists of tfree=1, tpre=2 and tpost=4.
Marlin uses codes M500
-M503
to manipulate EEPROM values.
RepRapFirmware uses the config-override.g file on the SD card instead of EEPROM. M500 saves certain values to that file, M501 re-loads them, and M502 loads the values from config.g, ignoring config-override.g.
Teacup uses codes M130
-M136
to set, read, and save some parameters.
All communication is in printable ASCII characters.
Messages sent back to the host computer are terminated by a newline.
The basic protocol responses look like this:
xx
can be one of:
ok
- The RepRap machine is ready to receive the next line from the host. -
rs
orResend
- There was a communication error and the RepRap machine is requesting a resend of the line in question. The line is specified either asN<linenumber>
orN:<linenumber>
. Examples:Resend: 123
,Resend: N123
,rs:123
orError:
orfatal:
(Repetier Firmware) - There was an error. Common communication errors such aschecksum mismatch, Last Line: <number>
orWrong checksum
,No Checksum with line number, Last Line: <number>
orMissing checksum
,Line Number is not Last Line Number+1, Last Line: <number>
orexpected line <number1> got <number2>
are recoverable and should immediately be followed by a resend. Other non-fatal errors commonly includeUnknown command: "<command>"
and several SD related errors such asCannot open subdir <dir>
,SD init fail
,volume.init failed
,openRoot failed
,workDir open failed
,open failed, File: <name>
,error writing to file
,Cannot enter subdir: <dir>
andSD read error
. Any other errors indicate a hardware fault that will make the RepRap machine shut down immediately after it has sent this message. They should be considered fatal by hosts. -
wait
- The RepRap machine's command buffers are empty and it is waiting for the next line from the host. -
busy:<reason>
- The RepRap machine is busy for some reason and currently cannot receive or process commands through the serial interface from a connected host. Possible reasons are: `processing` (the RepRap machine is busy with processing some lengthy command, like homing, heatup or auto leveling),paused for user
(the RepRap machine is paused and awaiting an action by the user via its built in controller unit, e.g. clicking the button),paused for input
(the RepRap machine is paused and waiting for input from the user via its built in controller unit, e.g. selecting a menu option). Examples:busy: processing
,busy: paused for user
The T: and B: values are the temperature of the currently-selected extruder
and the bed respectively, and are only sent in response to M105
. If such temperatures don't exist (for example for an extruder that works at room temperature and doesn't have a sensor) then a value below absolute zero (-273oC) is returned.
C: means that coordinates follow. Those are the X: Y: etc values. These are only
sent in response to M114
and M117
ok
start
once to the host before sending anything else. This should not be replaced or augmented
by version numbers and the like. M115
(see above) requests those.
Originally, every line sent by RepRap to the host computer except the start line was supposed to have a two-character prefix (one of ok
, rs
or //
). The machine should never send a line without such a prefix. These days, firmwares generally do not adhere to this rule and thus it should be considered obsolete.
Example of a communication error with resend request
are lines sent from the host to the RepRap machine, <<<
are lines sent from the RepRap machine to the host.
>>> N66555 G1 X131.338 Y133.349 E0.0091*91 <<< ok >>> N66556 G1 X131.574 Y133.428 E0.0046*92 <<< Error:checksum mismatch, Last Line: 66555 <<< Resend: 66556 <<< ok >>> N66556 G1 X131.574 Y133.428 E0.0046*92 <<< ok
Action commands
On the current versions of Pronterface and OctoPrint a special comment of the form:
// action:<command>
is allowed to be sent from the firmware.
As this is also a comment other hosts will just ignore these commands.
Supported commands currently are:
- pause: Instructs the host to pause the print job
- resume: Instructs the host to resume the print job
- disconnect: Instructs the host to disconnect from the printer
- cancel: Instructs the host to abort the current job
- out_of_filament T<extruder_id>: Tells host that filament for extruder extruder_id is run out or jammed. Host should issue a pause and can offer better help to user with this. For backward compatibility it should be followed by the pause action.
Additional commands supported by a subset of hosts:
- paused: Instructs the host that a print job under control of the printer was paused. (support: OctoPrint 1.3.9+)
- resumed: Instructs the host that a print job under control of the printer was resumed. (support: OctoPrint 1.3.9+)
- prompt_begin <message>: Starts the definition of a prompt dialog. <message> is the message to display to the user. (support: OctoPrint 1.3.9+ w/ enabled Action Command Prompt support plugin)
- prompt_choice <text>: Defines a dialog choice with the associated <text>. (support: OctoPrint 1.3.9+ w/ enabled Action Command Prompt support plugin)
- prompt_button <text>: Same as prompt_choice. (support: OctoPrint 1.3.9+ w/ enabled Action Command Prompt support plugin)
- prompt_show: Tells the host to prompt the user with the defined dialog. (support: OctoPrint 1.3.9+ w/ enabled Action Command Prompt support plugin)
- prompt_end: Tells the host to close the dialog (e.g. the user made the choice through the printer directly instead of through the host). (support: OctoPrint 1.3.9+ w/ enabled Action Command Prompt support plugin)
- probe_rewipe: Displays dialog indicating G29 Probing is Retrying. (support: Lulzbot Cura 3.6+)
- probe_failed: Cancels print job and displays dialog indicating G29 Probing failed (support: Lulzbot Cura 3.6+)
A host can select a dialog option and finish the dialog via M876 Snnn: G-Code#M876:_Dialog_handling. It can signal support for dialogs via M876 P1.
For a more detailed example of the dialog functionality enabled through the prompt_* set of action commands, see OctoPrint's documentation.
Further notes
1. Marlin 1.0.0 Gen6 Firmware does not follow the two character rule. 'rs' is actually 'Resend' and '!!' is 'Error'. Example Lines:
- Error: Line Number is not current line + 1. Last Line: 7
- Resend: 8
- Writing to File: print.gco
- Done saving file.
- File opened:print.gco Size:22992
- File selected
2. RepRapFirmware responds to some commands with a reply string in JSON format, terminated by a newline. This allows later firmware revisions to include additional information without confusing clients (e.g. PanelDue) that do not expect it, and to make responses self-describing so that the client will not be confused if responses are delayed or lost. The commands affected are:
M105 S2
(now deprecated in favour of M408) -
M105 S3
M20 S2
M36
M408
Problem to solve
When using Marlin firmware or emulating Marlin, each line of G-code sent from the host to the controller is answered with an ok
before the next line can be sent without locking communications up. This slows down communication and limits the number of commands that can be sent per second to the printer controller, as the USB stack on the host and the serial interface driver on the Arduino add their own latencies (up to 10 milliseconds). This is not a problem for other controller electronics using native USB such as the Duet, because the standard serial-over-USB drivers provide flow control, so the host software can be configured so as not to wait for the ok
Alternatives to G-code
- Main article: Firmware/Alternative#alternatives to G-code
