G-code
- 1 Introduction
- 2 RepRap G Code Fields
- 3 Comments
- 4 Individual commands
- 4.1 Checking
- 4.2 Buffered G Commands
- 4.3 Unbuffered G commands
- 4.4 Unbuffered M and T commands
- 4.4.1 M0: Stop
- 4.4.2 M1: Sleep
- 4.4.3 M17: Enable/Power all stepper motors
- 4.4.4 M18: Disable all stepper motors
- 4.4.5 M20: List SD card
- 4.4.6 M21: Initialize SD card
- 4.4.7 M22: Release SD card
- 4.4.8 M23: Select SD file
- 4.4.9 M24: Start/resume SD print
- 4.4.10 M25: Pause SD print
- 4.4.11 M26: Set SD position
- 4.4.12 M27: Report SD print status
- 4.4.13 M28: Begin write to SD card
- 4.4.14 M29: Stop writing to SD card
- 4.4.15 M40: Eject
- 4.4.16 M41: Loop
- 4.4.17 M42: Stop on material exhausted / Switch I/O pin
- 4.4.18 M43: Stand by on material exhausted
- 4.4.19 M80: ATX Power On
- 4.4.20 M81: ATX Power Off
- 4.4.21 M82: set extruder to absolute mode
- 4.4.22 M83: set extruder to relative mode
- 4.4.23 M84: Stop idle hold
- 4.4.24 M92: Set axis_steps_per_unit
- 4.4.25 M98: Get axis_hysteresis_mm
- 4.4.26 M99: Set axis_hysteresis_mm
- 4.4.27 M101 Turn extruder 1 on Forward / Undo Extruder Retraction
- 4.4.28 M102 Turn extruder 1 on Reverse
- 4.4.29 M103 Turn all extruders off / Extruder Retraction
- 4.4.30 M104: Set Extruder Temperature
- 4.4.31 M105: Get Extruder Temperature
- 4.4.32 M106: Fan On
- 4.4.33 M107: Fan Off
- 4.4.34 M108: Set Extruder Speed
- 4.4.35 M109: Set Extruder Temperature and Wait
- 4.4.36 M110: Set Current Line Number
- 4.4.37 M111: Set Debug Level
- 4.4.38 M112: Emergency Stop
- 4.4.39 M113: Set Extruder PWM
- 4.4.40 M114: Get Current Position
- 4.4.41 M115: Get Firmware Version and Capabilities
- 4.4.42 M116: Wait
- 4.4.43 M117: Get Zero Position
- 4.4.44 M118: Negotiate Features
- 4.4.45 M119: Get Endstop Status
- 4.4.46 M126: Open Valve
- 4.4.47 M127: Close Valve
- 4.4.48 M128: Extruder Pressure PWM
- 4.4.49 M129: Extruder pressure off
- 4.4.50 M130: Set PID P value
- 4.4.51 M131: Set PID I value
- 4.4.52 M132: Set PID D value
- 4.4.53 M133: Set PID I limit value
- 4.4.54 M134: Write PID values to EEPROM
- 4.4.55 M135: Set heater output
- 4.4.56 M136: Print PID settings to host
- 4.4.57 M140: Bed Temperature (Fast)
- 4.4.58 M141: Chamber Temperature (Fast)
- 4.4.59 M142: Holding Pressure
- 4.4.60 M143: Maximum hot-end temperature
- 4.4.61 M160: Number of mixed materials
- 4.4.62 M190: Wait for bed temperature to reach target temp
- 4.4.63 M200 - Set filament diameter / Get Endstop Status
- 4.4.64 M201 - Set max printing acceleration
- 4.4.65 M202 - Set max travel acceleration
- 4.4.66 M203 - Set maximum feedrate
- 4.4.67 M204 - Set default acceleration
- 4.4.68 M205 - advanced settings
- 4.4.69 M206: set home offset
- 4.4.70 M207: calibrate z axis by detecting z max length
- 4.4.71 M208: set axis max travel
- 4.4.72 M209: enable automatic retract
- 4.4.73 M220:set speed factor override percentage
- 4.4.74 M221: set extrude factor override percentage
- 4.4.75 M226: Gcode Initiated Pause
- 4.4.76 M227: Enable Automatic Reverse and Prime
- 4.4.77 M228: Disable Automatic Reverse and Prime
- 4.4.78 M229: Enable Automatic Reverse and Prime
- 4.4.79 M230: Disable / Enable Wait for Temperature Change
- 4.4.80 M240: Start conveyor belt motor / Echo off
- 4.4.81 M241: Stop conveyor belt motor / echo on
- 4.4.82 M245: Start cooler
- 4.4.83 M246: Stop cooler
- 4.4.84 M300: Play beep sound
- 4.4.85 T: Select Tool
- 5 Proposed EEPROM configuration codes
- 6 Replies from the RepRap machine to the host computer
- 7 Proposal for sending multiple lines of G-code
Introduction
This page describes the G Codes that the RepRap firmware uses and how they work.
The list of what can be done is extensible. But check this page first, and add your extension here first before you implement it.
A typical piece of GCode as sent to a RepRap machine might look like this:
N3 T0*57 N4 G92 E0*67 N5 G28*22 N6 G1 F1500.0*82 N7 G1 X2.0 Y2.0 F3000.0*85 N8 G1 X3.0 Y3.0*33
To find out which specific gcode/s are implemented in any given firmware, there are little tables attached to the command descriptions, like this one:
Support | FiveD | Teacup | Sprinter | Marlin | Repetier |
yes | automatic | yes | yes | experimental |
Here means:
- yes
- Fully supported.
- experimental
- There is some support. Often it's required to check out a source code branch other than the default or to flip certain configuration switches.
- automatic
- The firmware handles this feature automatically, so there's no need to send the command; you get the feature regardless. An example is power supply on/off (M80/M81) in Teacup firmware.
- no
- The firmware doesn't support this feature.
For the technically minded, the end of line is marked by a <nl> and optionally a <cr>. So, Unix line endings work as well as Windows ones.
This section explains the letter-preceded fields. The numbers in the fields are represented by nnn. Numbers can be integers, or can contain a decimal point, depending on context. For example an X coordinate can be integer (X175) or fractional (X17.62), whereas trying to select extruder number 2.76 would make no sense.
Letter | Meaning |
Gnnn | Standard GCode command, such as move to a point |
Mnnn | RepRap-defined command, such as turn on a cooling fan |
Tnnn | Select tool nnn. In RepRap, tools are extruders |
Snnn | Command parameter, such as the voltage to send to a motor |
Pnnn | Command parameter, such as a time in milliseconds |
Xnnn | An X coordinate, usually to move to |
Ynnn | A Y coordinate, usually to move to |
Znnn | A Z coordinate, usually to move to |
Innn | Parameter - not currently used |
Jnnn | Parameter - not currently used |
Fnnn | Feedrate in mm per minute. (Speed of print head movement) |
Rnnn | Parameter - used for temperatures |
Qnnn | Parameter - not currently used |
Ennn | Length of extrudate in mm. This is exactly like X, Y and Z, but for the length of filament to extrude. |
Nnnn | Line number. Used to request repeat transmission in the case of communications errors. |
*nnn | Checksum. Used to check for communications errors. |
Comments
G Code comments:
N3 T0*57 ;This is a comment N4 G92 E0*67 ; So is this N5 G28*22
Will be ignored by RepRap, as will blank lines. But it's better to strip these out in the host computer before the lines are sent. This saves bandwidth.
Individual commands
Checking
N and *
These are the line number and the checksum. The RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
int cs = 0; for(i = 0; cmd[i] != '*' && cmd[i] != NULL; i++) cs = cs ^ cmd[i]; cs &= 0xff; // Defensive programming...
Buffered G Commands
The RepRap firmware stores these commands in a ring buffer internally for execution. This means that there is no (appreciable) delay while a command is acknowledged and the next transmitted. In turn, this means that sequences of line segments can be plotted without a dwell between one and the next. As soon as one of these buffered commands is received it is acknowledged and stored locally. If the local buffer is full, then the acknowledgment is delayed until space for storage in the buffer is available. This is how flow control is achieved.
G0: Rapid move
??? | yes | yes | yes | yes |
Example: G0 X12
In this case move rapidly to X = 12 mm. In fact, the RepRap firmware uses exactly the same code for rapid as it uses for controlled moves (see G1 below), as - for the RepRap machine - this is just as efficient as not doing so. (The distinction comes from some old machine tools that used to move faster if the axes were not driven in a straight line. For them G0 allowed any movement in space to get to the destination as fast as possible.)
G1: Controlled move
yes | yes | yes | yes | yes |
Example: G1 X90.6 Y13.8 E22.4
Go in a straight line from the current (X, Y) point to the point (90.6, 13.8), extruding material as the move happens from the current extruded length to a length of 22.4 mm.
RepRap does subtle things with feedrates. Thus:
G1 F1500 G1 X90.6 Y13.8 E22.4
Will set a feedrate of 1500 mm/minute, then do the move described above at that feedrate. But
G1 F1500 G1 X90.6 Y13.8 E22.4 F3000
Will set a feedrate of 1500 mm/minute, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X, Y movement so everything stays synchronized.
RepRap thus treats feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over accelerations and decelerations in a way that ensures that everything moves together and the right volume of material is extruded at all points.
Note: not every firmware implements this, e.g. the current Marlin will use the new feedrate from the beginning of the move and not change it.
The first example shows how to get a constant-speed movement. The second how to accelerate or decelerate. Thus
G1 F1500 G1 X90.6 Y13.8 E22.4 F3000 G1 X80 Y20 E36 F1500
Will do the first movement accelerating as before, and the second decelerating from 3000 mm/minute back to 1500 mm/minute.
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G1 to send an E value that is less than the currently extruded length.
G28: Move to Origin
Example: G28
This causes the RepRap machine to move back to its X, Y and Z zero endstops, a process known as "homing". It does so accelerating, so as to get there fast. But when it arrives it backs off by 1 mm in each direction slowly, then moves back slowly to the stop. This ensures more accurate positioning.
If you add coordinates, then just the axes with coordinates specified will be zeroed. Thus
G28 X0 Y72.3
will zero the X and Y axes, but not Z. The actual coordinate values are ignored.
G29-G32: Bed probing
G29 Detailed Z-Probe
probes the bed at 3 points.
G30 Single Z Probe
probes bed at current XY location.
G31 Report Current Probe status
reports whether Z probe is triggered.
G32 Probe Z and calibrate with FPU
probes the bed at 3 points and updates transformation matrix for bed leveling compensation.
The following commands are not buffered. When one is received it is stored, but it is not acknowledged to the host until the buffer is exhausted and then the command has been executed. Thus the host will pause at one of these commands until it has been done. Short pauses between these commands and any that might follow them do not affect the performance of the machine.
Teacup Firmware buffers G20, G21, G90 and G91.
G4: Dwell
Example: G4 P200
G10: Head Offset
Example: G10 P3 X17.8 Y-19.3 Z0.0 R140 S205
This sets the offset for extrude head 3 (from the P3) to the X and Y values specified. You can put a non-zero Z value in as well, but this is usually a bad idea unless the heads are loaded and unloaded by some sort of head changer. When all the heads are in the machine at once they should all be set to the same Z height.
Remember that any parameter that you don't specify will automatically be set to the last value for that parameter. That usually means that you want explicitly to set Z0.0.
The R value is the standby temperature in oC that will be used for the tool, and the S value is its operating temperature. If you don't want the head to be at a different temperature when not in use, set both values the same. See the T code (select tool) below.
The NIST G-code standard mentions an additional L parameter, which is ignored.
This command is subject to discussion.
G20: Set Units to Inches
Example: G20
G21: Set Units to Millimeters
Example: G21
Example: G90
Example: G91
G92: Set Position
Example: G92 X10 E90
M0: Stop
Example: M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M1, M112.
M1: Sleep
Example: M1
Example: M17
Example: M18
- Is this not the same as M84? -- MrAlvin 05:53, 20 September 2012 (UTC)
M20: List SD card
Example: M20
ok Files: {SQUARE.G,SQCOM.G,}
Example: M21
The SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
Example: M22
M23: Select SD file
Example: M23 filename.gco
Example: M24
M25: Pause SD print
Example: M25
Example: M26
Example: M27
Report SD print status.
Example: M28 filename.gco
Example: M29 filename.gco
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
- When you press the reset button,
- When the build material runs out (if your RepRap is set up to detect this), and
- When there's an error (such as a heater failure).
M42 in ???
Example: M42
If your RepRap can detect when its material runs out, this decides the behaviour when that happens. The X and Y axes are zeroed (but not Z), and then the machine shuts all motors and heaters off. You have to press reset to reactivate the machine. In other words, it parks itself and then executes an M0 command (q.v.).
M42 in Marlin/Sprinter
Example: M42 P7 S255
M42 switches a general purpose I/O pin.
M42 in Teacup
Teacup firmware doesn't implement M42 and switches general purpose devices like a heater, with M104.
Example: M43
M80: ATX Power On
Example: M80
Note: some firmwares, like Teacup, handle power on/off automatically, so this is redundant there.
M81: ATX Power Off
Example: M81
Example: M82
makes the extruder interpret extrusion as absolute positions.
Example: M83
makes the extruder interpret extrusion values as relative positions.
M84: Stop idle hold
Example: M84
Example: M92 X<newsteps> Sprinter and Marlin
Example: M98
Proposed for Marlin
Example: M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
M101 in Teacup firmware
If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
M101 in other firmwares
Deprecated. Regarding filament retraction, see M227, M228, M229.
Deprecated.
M103 in Teacup firmware
If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
M103 in other firmwares
Deprecated. Regarding extruder retraction, see M227, M228, M229.
Example: M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). See also M109.
Example: M105
Request the temperature of the current extruder and the build base in degrees Celsius. The temperatures are returned to the host computer. For example, the line sent to the host in response to this command looks like
ok T:201 B:117
M106: Fan On
Example: M106 S127
Turn on the cooling fan at half speed. Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off.
M107: Fan Off
Deprecated. Use M106 S0 instead.
Sets speed of extruder motor. (Deprecated in current firmware, see M113)
Parameters (Sprinter 4pi): S (optional), set target temperature value. If not specified, waits for the temperature set by M104. R (optional), sets target temperature range maximum value.
Example: M109 S185 R240 //sets extruder temperature to 185 and waits for the temperature to be between 185 - 240.
Some firmwares consider this command as deprecated, and use M104, followed by an M116, instead.
??? | ??? | yes | yes | ??? |
Example: M110 N123
no-op |
Example: M111 S6
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2)
Example: M253
Debug |
Example: M112
Example: M113
M113 S0.7
Example: M114
Example: M115
sample data from firmware:
M116: Wait
Example: M116
Example: M117
Example: M118 P42
M200 instead | yes |
Example: M119
Returns the current state of the configured X,Y,Z endstops. Should take into account any 'inverted endstop' settings, so one can confirm that the machine is interpreting the endstops correctly.
M126: Open Valve
Example: M126 P500
M127: Close Valve
Example: M127 P400
Example: M128 S255
Example: M129 P100
Example: M130 P 0 S 8.0 # Sets heater 0 P factor to 8.0
yes |
Example: M130 P 1 S 0.5 # Sets heater 1 I factor to 0.5
yes |
Example: M130 P 0 S 24 # Sets heater 0 D factor to 24.0
yes |
Example: M130 P 1 S 264 # Sets heater 0 I limit value to 264
yes |
Example: M134
yes |
Example: M135 P 0 S128 # sets Heater 0 to a PWM output of 128
yes |
Example: M136 P1 # print heater 0 PID parameters to host
Debug |
Example: M140 S55
Set the temperature of the build bed to 55oC and return control to the host immediately (i.e. before that temperature has been reached by the bed).
Example: M141 S30
Example: M142 S1
Example: M143 S275
Example: M160 S4
When N >= 2, then the E field that controls extrusion requires N+1 values separated by spaces after it like this:
M160 S4 G1 X90.6 Y13.8 E22.4 0.1 0.1 0.1 0.7 G1 X70.6 E42.4 0.0 0.0 0.0 1.0 G1 E42.4 1.0 0.0 0.0 0.0
The second line moves straight to the point (90.6, 13.8) extruding 22.4mm of filament. The mix ratio at the end of the move is 0.1:0.1:0.1:0.7.
The third line moves back 20mm in X extruding 20mm of filament. The mix varies linearly from 0.1:0.1:0.1:0.7 to 0:0:0:1 as the move is made.
The fourth line has no physical effect, but sets the mix proportions for the start of the next move to 1:0:0:0.
Example: M190 S60
endstop status | dia |
M200 reports the endstop status on Teacup firmware.
M200 sets the filament diameter on other firmware.
Question: what does a firmware do with filament diameter? Has this an effect on how much an E command moves the extruder motor? --Traumflug 11:34, 14 October 2012 (UTC)
in units/s^2 for print moves (M201 X1000 Y1000)
that your machine can sustain (M203 X200 Y200 Z300 E10000) in mm/sec
Note: this should be in units/minute, just like the F code.
Example: M206 X10.0 Y10.0 Z-0.4
Example: M207
Example: M208 X250 Y210 Z180
Example: M209 S1
Example: M220 S80
S<factor in percent>- set speed factor override percentage
Example: M221 S70
S<factor in percent>- set extrude factor override percentage
Example: M226
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
Example: M240
Example: M240
Debug: Echo off |
Example: M241
Example: M240
Debug: Echo on |
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
Usage: M300 S<frequency Hz> P<duration ms>
Example: M300 S300 P1000
T: Select Tool
Example: T1
Select extruder number 1 to build with.
The sequence followed is:
- Set the current extruder to its standby temperature specified by G10 (see above),
- Apply any offset for the new extruder specified by G10,
- Set the new tool to its operating temperature specified by G10 and wait till it gets there,
- Use the new extruder.
Selecting a non-existent tool (100, say) just does Step 1. above. That is to say it leaves all tools in their standby state. You can, of course, use the G10 command beforehand to set that standby temperature to anything you like.
Note that you may wish to move to a parking position before executing a T command in order to allow the new extruder to reach temperature while not in contact with the print.
If the Z value changes in the offsets and the head moves up, then the Z move is made before the X and Y moves. If Z moves down, X and Y are done first.
After a reset extruders will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0, M1 and M112 commands turn them all off. You can, of course, turn them all off with the M1 command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
Extruder numbering starts at 0.
Marlin uses these codes to manipulate EEPROM values.
M500: stores paramters in EEPROM
M501: reads parameters from EEPROM
If you need to reset them after you changed them temporarily
M502: reverts to the default "factory settings".
You still need to store them in EEPROM afterwards if you want to.
M503: Print settings
xx can be one of:
ok
rs
ok
start
Problem to solve
Each line of G-code sent from the host to the controller is answered with an ok before the next line can be sent without locking communcations up. This makes operations very slow, as the usual USB-TTL converters and probably also the host's operating system drivers come with substantial latency, often 10 milliseconds.
For more details on this proposal, and some suggested solutions, and comments please see GCODE_buffer_multiline_proposal
