G-code/kr
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF/FDM processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications, too.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years.
- 1 소개
- 2 RepRap G Code 항
- 3 Comments
- 4 Individual commands
- 4.1 Checking
- 4.2 Buffered G Commands
- 4.3 Unbuffered G commands
- 4.4 Unbuffered M and T commands
- 4.4.1 M0: Stop
- 4.4.2 M1: Sleep
- 4.4.3 M3: Spindle On, Clockwise (CNC specific)
- 4.4.4 M4: Spindle On, Counter-Clockwise (CNC specific)
- 4.4.5 M5: Spindle Off (CNC specific)
- 4.4.6 M7: Mist Coolant On (CNC specific)
- 4.4.7 M8: Flood Coolant On (CNC specific)
- 4.4.8 M9: Coolant Off (CNC specific)
- 4.4.9 M10: Vacuum On (CNC specific)
- 4.4.10 M11: Vacuum Off (CNC specific)
- 4.4.11 M17: Enable/Power all stepper motors
- 4.4.12 M18: Disable all stepper motors
- 4.4.13 M20: List SD card
- 4.4.14 M21: Initialize SD card
- 4.4.15 M22: Release SD card
- 4.4.16 M23: Select SD file
- 4.4.17 M24: Start/resume SD print
- 4.4.18 M25: Pause SD print
- 4.4.19 M26: Set SD position
- 4.4.20 M27: Report SD print status
- 4.4.21 M28: Begin write to SD card
- 4.4.22 M29: Stop writing to SD card
- 4.4.23 M30: Delete a file on the SD card
- 4.4.24 M40: Eject
- 4.4.25 M41: Loop
- 4.4.26 M42: Stop on material exhausted / Switch I/O pin
- 4.4.27 M43: Stand by on material exhausted
- 4.4.28 M80: ATX Power On
- 4.4.29 M81: ATX Power Off
- 4.4.30 M82: set extruder to absolute mode
- 4.4.31 M83: set extruder to relative mode
- 4.4.32 M84: Stop idle hold
- 4.4.33 M92: Set axis_steps_per_unit
- 4.4.34 M98: Get axis_hysteresis_mm
- 4.4.35 M99: Set axis_hysteresis_mm
- 4.4.36 M101 Turn extruder 1 on Forward / Undo Extruder Retraction
- 4.4.37 M102 Turn extruder 1 on Reverse
- 4.4.38 M103 Turn all extruders off / Extruder Retraction
- 4.4.39 M104: Set Extruder Temperature
- 4.4.40 M105: Get Extruder Temperature
- 4.4.41 M106: Fan On
- 4.4.42 M107: Fan Off
- 4.4.43 M108: Set Extruder Speed
- 4.4.44 M109: Set Extruder Temperature and Wait
- 4.4.45 M110: Set Current Line Number
- 4.4.46 M111: Set Debug Level
- 4.4.47 M112: Emergency Stop
- 4.4.48 M113: Set Extruder PWM
- 4.4.49 M114: Get Current Position
- 4.4.50 M115: Get Firmware Version and Capabilities
- 4.4.51 M116: 대기
- 4.4.52 M117: Get Zero Position
- 4.4.53 M117 in Marlin: 메시지 전시
- 4.4.54 M118: Negotiate Features
- 4.4.55 M119: Get Endstop Status
- 4.4.56 M120: Push
- 4.4.57 M121: Pop
- 4.4.58 M122: Diagnose
- 4.4.59 M126: Open Valve
- 4.4.60 M127: Close Valve
- 4.4.61 M128: Extruder Pressure PWM
- 4.4.62 M129: Extruder pressure off
- 4.4.63 M130: Set PID P value
- 4.4.64 M131: Set PID I value
- 4.4.65 M132: Set PID D value
- 4.4.66 M133: Set PID I limit value
- 4.4.67 M134: Write PID values to EEPROM
- 4.4.68 M135: Set PID sample interval
- 4.4.69 M136: Print PID settings to host
- 4.4.70 M140: Bed Temperature (Fast)
- 4.4.71 M141: Chamber Temperature (Fast)
- 4.4.72 M142: Holding Pressure
- 4.4.73 M143: Maximum hot-end temperature
- 4.4.74 M160: Number of mixed materials
- 4.4.75 M190: Wait for bed temperature to reach target temp
- 4.4.76 M200 - Set filament diameter / Get Endstop Status
- 4.4.77 M201 - Set max printing acceleration
- 4.4.78 M202 - Set max travel acceleration
- 4.4.79 M203 - Set maximum feedrate
- 4.4.80 M204 - Set default acceleration
- 4.4.81 M205 - advanced settings
- 4.4.82 M206: set home offset
- 4.4.83 M207: calibrate z axis by detecting z max length
- 4.4.84 M208: set axis max travel
- 4.4.85 M209: enable automatic retract
- 4.4.86 M210: Set homing feedrates
- 4.4.87 M220:set speed factor override percentage
- 4.4.88 M221: set extrude factor override percentage
- 4.4.89 M226: Gcode Initiated Pause
- 4.4.90 M227: Enable Automatic Reverse and Prime
- 4.4.91 M228: Disable Automatic Reverse and Prime
- 4.4.92 M229: Enable Automatic Reverse and Prime
- 4.4.93 M230: Disable / Enable Wait for Temperature Change
- 4.4.94 M240: Start conveyor belt motor / Echo off
- 4.4.95 M241: Stop conveyor belt motor / echo on
- 4.4.96 M245: Start cooler
- 4.4.97 M246: Stop cooler
- 4.4.98 M300: Play beep sound
- 4.4.99 M301: Set PID parameters - Hot End
- 4.4.100 M302: Allow cold extrudes
- 4.4.101 M303: Run PID tuning
- 4.4.102 M304: Set PID parameters - Bed
- 4.4.103 M400: Wait for current moves to finish
- 4.4.104 M420: Set RGB Colors as PWM
- 4.4.105 M550: Set Name
- 4.4.106 M551: Set Password
- 4.4.107 M552: Set IP address
- 4.4.108 M553: Set Netmask
- 4.4.109 M554: Set Gateway
- 4.4.110 M555: Set compatibility
- 4.4.111 M556: Axis compensation
- 4.4.112 M557: Set Z probe point
- 4.4.113 M558: Set Z probe type
- 4.4.114 M559: Upload configuration file
- 4.4.115 M560: Upload web page file
- 4.4.116 M561: Set Identity Transform
- 4.4.117 M906: Set motor currents
- 4.4.118 M998: Request resend of line
- 4.4.119 M999: Restart after being stopped by error
- 4.4.120 T: Select Tool
- 5 Proposed SCARA calibration codes (Morgan)
- 5.1 M360 : Move to Theta 0 degree position
- 5.2 M361 : Move to Theta 90 degree position
- 5.3 M362 : Move to Psi 0 degree position
- 5.4 M363 : Move to Psi 90 degree position
- 5.5 M364 : Move to Psi + Theta 90 degree position
- 5.6 M365 : SCARA scaling factor
- 5.7 M370 : Morgan manual bed level - clear map
- 5.8 M371 : Move to next calibration position
- 5.9 M372 : Record calibration value, and move to next position
- 5.10 M373 : End bed level calibration mode
- 5.11 M375 : Display matrix
- 6 Proposed EEPROM configuration codes
- 7 Replies from the RepRap machine to the host computer
- 8 Proposal for sending multiple lines of G-code
- 9 Alternatives to G-code
소개
전형적인 RepRap 프로그램으로 전송되는 GCode의 조각은 다음과 같다:
N3 T0*57 N4 G92 E0*67 N5 G28*22 N6 G1 F1500.0*82 N7 G1 X2.0 Y2.0 F3000.0*85 N8 G1 X3.0 Y3.0*33
위의(그리고 그 이상의) 심볼과 숫자에 대한 의미가 아래에 설명되어 있다. 어떠한 펌웨어에 구현된 특정 GCode를 찾기 위한 명령어를 기술한 다음과 같은 작은 테이블이 있다:
Support | FiveD | Teacup | Sprinter | Marlin | Repetier |
yes | automatic | yes | yes | experimental |
이 의미는 :
- yes
- 완전 지원
- experimental
- 몇몇은 지원. 이 경우는 종종 기본적이거나 중요한 설정이 바뀌지 않았는지 소스 코드 브랜치를 확인할 필요가 있다.
- automatic
- 펌웨어가 이 항목(feature)을 자동으로 핸들링하기 때문에 명령어를 전송할 필요가 없다; 당신은 이 특징을 신경쓸 필요가 없다. 예를 들어 Teacup 펌웨어에서 전원공급기 on/off(M80/M81) 같은 것이 있다.
- no
- 펌웨어가 이 항목을 지원하지 않는다.
기술적으로 보기 위해, 매 줄의 끝은 <nl>가 첨부되고 선택적으로 <cr>도 첨부된다. 따라서 Unix 라인 종료 기능은 Windows에서처럼 잘 이루어진다.
RepRap G Code 항
이 절은 글자가 앞에 나오는 항에 대해 설명한다. 각 항에 숫자는 nnn으로 표현한다. 숫자는 문맥에 따라 정수로 쓰이거나 소수점을 포함할 수 있다.예를 들어 X좌표는 정수 (X175) 또는 소수(X17.62)를 사용할 수 있지만 압출기 번호 2.76은 아무 의미가 없습니다.
글자 | 의미 |
Gnnn | 어떤 점으로 이동하라는 것과 같은 표준 GCode 명령. |
Mnnn | RepRap에 의해 정의된 명령. 예를 들면 쿨링 팬 회전. |
Tnnn | 도구 nnn 선택. RepRap에서 도구는 압출기. |
Snnn | 파라미터 명령. 예를 들어 모터로 보내는 전압. |
Pnnn | 파라미터 명령. 밀리초 동안의 time |
Xnnn | 이동을 위해 사용하는 X 좌표. |
Ynnn | 이동을 위해 사용하는 Y 좌표. |
Znnn | 이동을 위해 사용하는 Z 좌표. |
Innn | 파라미터. 현재는 사용하지 않음. |
Jnnn | 파라미터. 현재는 사용하지 않음. |
Fnnn | 1분당 Feedrate. (프린트 헤드의 움직임 스피드) |
Rnnn | 파라미터 - 온도에 사용 |
Qnnn | Parameter - not currently used |
Ennn | 압출형의 길이 mm. 이것은 정확히 X, Y, Z 와 같지만 필라멘트를 압출하는 길이이다. |
Nnnn | 선 번호. 통신 오류시 재전송 요청을 위해 사용. |
*nnn | 체크섬 : 통신 오류를 체크하는데 사용. |
Comments
G Code comments:
N3 T0*57 ;This is a comment N4 G92 E0*67 ; So is this N5 G28*22
Will be ignored by RepRap, as will blank lines. But it's better to strip these out in the host computer before the lines are sent. This saves bandwidth.
Individual commands
Checking
N and *
These are the line number and the checksum. The RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
int cs = 0; for(i = 0; cmd[i] != '*' && cmd[i] != NULL; i++) cs = cs ^ cmd[i]; cs &= 0xff; // Defensive programming...
Buffered G Commands
The RepRap firmware stores these commands in a ring buffer internally for execution. This means that there is no (appreciable) delay while a command is acknowledged and the next transmitted. In turn, this means that sequences of line segments can be plotted without a dwell between one and the next. As soon as one of these buffered commands is received it is acknowledged and stored locally. If the local buffer is full, then the acknowledgment is delayed until space for storage in the buffer is available. This is how flow control is achieved.
G0: Rapid move
??? | yes | yes | yes | yes |
Example: G0 X12
In this case move rapidly to X = 12 mm. In fact, the RepRap firmware uses exactly the same code for rapid as it uses for controlled moves (see G1 below), as - for the RepRap machine - this is just as efficient as not doing so. (The distinction comes from some old machine tools that used to move faster if the axes were not driven in a straight line. For them G0 allowed any movement in space to get to the destination as fast as possible.)
G1: Controlled move
yes | yes | yes | yes | yes |
Example: G1 X90.6 Y13.8 E22.4
Go in a straight line from the current (X, Y) point to the point (90.6, 13.8), extruding material as the move happens from the current extruded length to a length of 22.4 mm.
RepRap does subtle things with feedrates. Thus:
G1 F1500 G1 X90.6 Y13.8 E22.4
Will set a feedrate of 1500 mm/minute, then do the move described above at that feedrate. But
G1 F1500 G1 X90.6 Y13.8 E22.4 F3000
Will set a feedrate of 1500 mm/minute, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X, Y movement so everything stays synchronized.
RepRap thus treats feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over accelerations and decelerations in a way that ensures that everything moves together and the right volume of material is extruded at all points.
Note: not every firmware implements this, e.g. the current Marlin will use the new feedrate from the beginning of the move and not change it.
The first example shows how to get a constant-speed movement. The second how to accelerate or decelerate. Thus
G1 F1500 G1 X90.6 Y13.8 E22.4 F3000 G1 X80 Y20 E36 F1500
Will do the first movement accelerating as before, and the second decelerating from 3000 mm/minute back to 1500 mm/minute.
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G1 to send an E value that is less than the currently extruded length.
G28: Move to Origin
Example: G28
This causes the RepRap machine to move back to its X, Y and Z zero endstops, a process known as "homing". It does so accelerating, so as to get there fast. But when it arrives it backs off by 1 mm in each direction slowly, then moves back slowly to the stop. This ensures more accurate positioning.
If you add coordinates, then just the axes with coordinates specified will be zeroed. Thus
G28 X0 Y72.3
will zero the X and Y axes, but not Z. The actual coordinate values are ignored.
G29-G32: Bed probing
G29 Detailed Z-Probe
probes the bed at 3 points.
G30 Single Z Probe
Some implementations allow more general behaviour: if a Pn field is specified the probed X, Y, and Z values are saved as point n on the bed for calculating the offset plane. Generally n is 0, 1, or 2. If X, or Y, or Z values are specified (e.g. G30 P1 X20 Y50 Z0.3) then those values are used instead of the machine's current coordinates. A silly Z value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specfied (e.g. G30 P1 Z0.3 S) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1 commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup GCode file for automatic execution.
G31 Report Current Probe status
G32 Probe Z and calculate Z plane
probes the bed at 3 pre-defined points (see M557) and updates transformation matrix for bed leveling compensation.
The following commands are not buffered. When one is received it is stored, but it is not acknowledged to the host until the buffer is exhausted and then the command has been executed. Thus the host will pause at one of these commands until it has been done. Short pauses between these commands and any that might follow them do not affect the performance of the machine.
Teacup Firmware buffers G20, G21, G90 and G91.
G4: Dwell
Example: G4 P200
G10: Head Offset
Example: G10 P3 X17.8 Y-19.3 Z0.0 R140 S205
This sets the offset for extrude head 3 (from the P3) to the X and Y values specified. You can put a non-zero Z value in as well, but this is usually a bad idea unless the heads are loaded and unloaded by some sort of head changer. When all the heads are in the machine at once they should all be set to the same Z height.
Remember that any parameter that you don't specify will automatically be set to the last value for that parameter. That usually means that you want explicitly to set Z0.0.
The R value is the standby temperature in oC that will be used for the tool, and the S value is its operating temperature. If you don't want the head to be at a different temperature when not in use, set both values the same. See the T code (select tool) below.
The NIST G-code standard mentions an additional L parameter, which is ignored.
This command is subject to discussion.
G20: Set Units to Inches
Example: G20
G21: Set Units to Millimeters
Example: G21
Example: G90
Example: G91
G92: Set Position
Example: G92 X10 E90
M0: Stop
Example: M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M1, M112.
M1: Sleep
Example: M1
Example: M3 S4000
Example: M4 S4000
Example: M5
The spindle is turned off.
Example: M7
Example: M8
Example: M9
Example: M10
Example: M11
Example: M17
Example: M18
M20: List SD card
Example: M20
ok Files: {SQUARE.G,SQCOM.G,}
Example: M21
The SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
Example: M22
M23: Select SD file
Example: M23 filename.gco
Example: M24
M25: Pause SD print
Example: M25
Example: M26
Example: M27
Report SD print status.
Example: M28 filename.gco
Example: M29 filename.gco
Example: M30 filename.gco
filename.gco is deleted.
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
- When you press the reset button,
- When the build material runs out (if your RepRap is set up to detect this), and
- When there's an error (such as a heater failure).
M42 in ???
Example: M42
If your RepRap can detect when its material runs out, this decides the behaviour when that happens. The X and Y axes are zeroed (but not Z), and then the machine shuts all motors and heaters off. You have to press reset to reactivate the machine. In other words, it parks itself and then executes an M0 command (q.v.).
M42 in Marlin/Sprinter
Example: M42 P7 S255
M42 switches a general purpose I/O pin.
M42 in Teacup
Not needed. General purpose devices are handled like a heater, see M104.
Example: M43
M80: ATX Power On
Example: M80
Note: some firmwares, like Teacup, handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off
M81: ATX Power Off
Example: M81
Example: M82
makes the extruder interpret extrusion as absolute positions.
Example: M83
makes the extruder interpret extrusion values as relative positions.
M84: Stop idle hold
Example: M84
Example: M92 X<newsteps> Sprinter and Marlin
Example: M98
Proposed for Marlin
Example: M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
M101 in Teacup firmware
If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
M101 in other firmwares
Deprecated. Regarding filament retraction, see M227, M228, M229.
Deprecated.
M103 in Teacup firmware
If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
M103 in other firmwares
Deprecated. Regarding extruder retraction, see M227, M228, M229.
Example: M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). See also M109.
M104 in Teacup Firmware
Example: M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100 °C.
Example: M105
Request the temperature of the current extruder and the build base in degrees Celsius. The temperatures are returned to the host computer. For example, the line sent to the host in response to this command looks like: ok T:201 B:117
Expansion/generalization of M105 to be considered as noted in Pronterface I/O Monitor
M106: Fan On
yes | yes | yes |
Example: M106 S127
Turn on the cooling fan at half speed.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off. In some implementations the pwm is specified by a real fraction: M106 S0.7.
M106 in Teacup Firmware
Example: M106 P2 S255
M107: Fan Off
Deprecated. Use M106 S0 instead.
Sets speed of extruder motor. (Deprecated in current firmware, see M113)
??? | not needed | see text | yes | ??? |
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port)
Example: M109 S185
M109 in Sprinter (4pi port)
Example: M109 S185 R240 //sets extruder temperature to 185 and waits for the temperature to be between 185 - 240.
??? | not needed | ??? | ??? | ??? |
Example: M110 N123
Example: M111 S6
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2)
Example: M253
Debug |
Example: M112
Example: M113
M113 S0.7
Example: M114
Example: M115
sample data from firmware:
M116: 대기
예제: M116
모든 온도와 다른 천천히 변하는 변수들이 설정된 값에 도달할 때까지 대기한다. M109 참조
Example: M117
예제: M117 Hello World
이것은 메시지를 상태를 표시하기 위해 컨트롤러에 연결된 LCD에 메시지를보낸다. 위의 명령은 Hello World를 표시하도록 할 것이다.
Example: M118 P42
yes | yes | yes |
Example: M119
M120: Push
- Current feedrate, and
- Whether moves (and separately extrusion) are relative or absolute
M121: Pop
M122: Diagnose
M126: Open Valve
Example: M126 P500
M127: Close Valve
Example: M127 P400
Example: M128 S255
Example: M129 P100
yes |
Example: M130 P 0 S 8.0 # Sets heater 0 P factor to 8.0
yes |
Example: M130 P 1 S 0.5 # Sets heater 1 I factor to 0.5
yes |
Example: M130 P 0 S 24 # Sets heater 0 D factor to 24.0
yes |
Example: M130 P 1 S 264 # Sets heater 0 I limit value to 264
yes |
Example: M134
Example: M135 S300
Debug |
Example: M136 P1 # print heater 0 PID parameters to host
Example: M140 S55
Set the temperature of the build bed to 55oC and return control to the host immediately (i.e. before that temperature has been reached by the bed).
Example: M141 S30
Example: M142 S1
Example: M143 S275
Example: M160 S4
When N >= 2, then the E field that controls extrusion requires N+1 values separated by spaces after it like this:
M160 S4 G1 X90.6 Y13.8 E22.4 0.1 0.1 0.1 0.7 G1 X70.6 E42.4 0.0 0.0 0.0 1.0 G1 E42.4 1.0 0.0 0.0 0.0
The second line moves straight to the point (90.6, 13.8) extruding 22.4mm of filament. The mix ratio at the end of the move is 0.1:0.1:0.1:0.7.
The third line moves back 20mm in X extruding 20mm of filament. The mix varies linearly from 0.1:0.1:0.1:0.7 to 0:0:0:1 as the move is made.
The fourth line has no physical effect, but sets the mix proportions for the start of the next move to 1:0:0:0.
obsolete, see M116 | yes | yes |
Example: M190 S60
yes |
M200 sets the filament diameter.
Question: what does a firmware do with filament diameter? Has this an effect on how much an E command moves the extruder motor? --Traumflug 11:34, 14 October 2012 (UTC)
in units/s^2 for print moves (M201 X1000 Y1000)
that your machine can sustain (M203 X200 Y200 Z300 E10000) in mm/sec
Note: this should be in units/minute, just like the F code.
Example: M206 X10.0 Y10.0 Z-0.4
Example: M207
Example: M208 X250 Y210 Z180
Example: M209 S1
Example: M210 X1000 Y1500
Example: M220 S80
S<factor in percent>- set speed factor override percentage
Example: M221 S70
S<factor in percent>- set extrude factor override percentage
Example: M226
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
Debug: Echo off |
Example: M240
Debug: Echo on |
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
Usage: M300 S<frequency Hz> P<duration ms>
Example: M300 S300 P1000
PID |
Example: M301 P1 I2 D3 C5
Sets Proportional, Integral and Derivative values for hot end, the value C refers to an extrusion rate.
Alternate implementation
Example: M301 W125
This tells the printer to allow movement of the extruder motor, when the hotend is not at printing temperature
Example: M302
PID | PID |
Hotend Usage: M303 S<temperature> C<cycles> Bed Usage: M303 E-1 C<cycles> S<temperature> Example: M303 C8 S175
Generate Proportional, Integral and Derivative values for the hotend or bed (E-1). Send the appropriate code and wait for the output to update the firmware.
PID |
Example: M304 P1 I2 D3
Sets Proportional, Integral and Derivative values for bed
Finishes all current moves and and thus clears the buffer. That's identical to G4 P0
Example: M400
Example: M420 R255 E255 B255
M550: Set Name
Example: M550 PGodzilla
M551: Set Password
Example: M551 Pmy-very-secret-word
On machines that need a password to activate them, set that password. The code 'P' is not part of the password. Note that as this is sent in clear it does not (nor is it intended to) offer a very high level of security. But on machines that are (say) on a network, it prevents idle messing about by the unauthorised. The password can contain any printable charcters except ';', which still means start comment.
Example: M552 P192.168.1.14
Sets the IP address of the RepRap machine to (in this case) 192.168.1.14. If no P field is specified, this echos the existing IP address.
M553: Set Netmask
Example: M553 P255.255.255.0
Sets the IP address of the RepRap machine to (in this case) 255.255.255.0. If no P field is specified, this echos the existing Netmask.
M554: Set Gateway
Example: M554 P192.168.1.1
Sets the Gateway of the RepRap machine to (in this case) 192.168.1.1. If no P field is specified, this echos the existing Gateway.
Example: M555 P1
For firmware that can do it, sets the firmware to a mode where its input and (especially) output behaves exactly like other established firmware. The value of the P argument is:
P value | Firmware |
0 | Native (i.e. whatever the firmware actually is) |
1 | RepRap_Firmware |
2 | Marlin |
3 | Teacup |
4 | Sprinter |
5 | Repetier |
Example: M556 S100 X0.7 Y-0.2 Z0.6
Example: M557 P1 X30 Y40.5
Example: M558 P0
A Z probe may be a switch (the default) an IR proximity sensor, or some other device. This selects which to use. P0 gives a switch. P1 gives an IR probe. See also G31 and G32.
Example: M559
Example: M560
For RepRaps that have web support and that can be driven by a web browser, this uploads the file that is the control page for the RepRap. After sending M560 the file (usually an HTML file) should be sent, terminated by the string<!-- **EoF** -->. Clearly that string cannot exist in the body of the file, but can be put on the end to facilitate this process. This should not be too serious a restriction...
Example: M561
Example: M906 X300 Y500 Z200 E350
Example: M998 P34
Request a resend of line 34. In some implementations the input-handling code overwrites the incomming G Code with this when it detects, for example, a checksum error. Then it leaves it up to the GCode interpreter actually to request the resend.
Example: M999
T: Select Tool
Example: T1
Select extruder number 1 to build with.
The sequence followed is:
- Set the current extruder to its standby temperature specified by G10 (see above),
- Set the new extruder to its operating temperature specified by G10 and wait for all temperatures to stabilise,
- Apply any X, Y, Z offset for the new extruder specified by G10,
- Use the new extruder.
Selecting a non-existent tool (100, say) just does Step 1. above. That is to say it leaves all tools in their standby state. You can, of course, use the G10 command beforehand to set that standby temperature to anything you like.
If the Z value changes in the offsets and the head moves up, then the Z move is made before the X and Y moves. If Z moves down, X and Y are done first.
After a reset extruders will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0, M1 and M112 commands turn them all off. You can, of course, turn them all off with the M1 command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
Extruder numbering starts at 0.
In order to ease calibration of Reprap Morgan, the following M-codes are used to set the machine up Implemented in qharley/Marlin armlevel branch.
Display the bed level calibration matrix
Store the calibration to EEPROM using M500
Marlin uses these codes to manipulate EEPROM values.
M500: stores paramters in EEPROM
M501: reads parameters from EEPROM
If you need to reset them after you changed them temporarily
M502: reverts to the default "factory settings".
You still need to store them in EEPROM afterwards if you want to.
M503: Print settings
xx can be one of:
ok
rs
ok
start
Exceptions: Marlin 1.0.0 Gen6 Firmware does not follow the two character rule. 'rs' is actually 'Resend' and '!!' is 'Error'.
Example Lines:
- Error: Line Number is not current line + 1. Last Line: 7
- Resend: 8
- Writing to File: print.gco
- Done saving file.
- File opened:print.gco Size:22992
- File selected
Problem to solve
Each line of G-code sent from the host to the controller is answered with an ok before the next line can be sent without locking communcations up. This makes operations very slow, as the usual USB-TTL converters and probably also the host's operating system drivers come with substantial latency, often 10 milliseconds.
For more details on this proposal, and some suggested solutions, and comments please see GCODE_buffer_multiline_proposal
- Main article: Firmware/Alternative#alternatives to G-code
- Wikipedia: STEP-NC: "STEP-NC was designed to replace ... G-codes ... adding tolerance data ... [with a] XML format."
- Elegant multispline motion controller "will not use G-code. It will use a custom language based on cubic Bezier curves. This allows for much better description of arcs and will result in much higher quality prints with a much lower data throughput requirements."
- GCODE buffer multiline proposal This may have some relevance to developers
