G3D driver
Revision as of 15:45, 17 October 2012 by Gadgets3d (talk | contribs) (Created page with '{{Development <!--Header--> |name = A4988 G3D Stepper Drivers |status = working <!--Image--> |image = G3d_1.jpg <!--General--> |description = New generation stepper motor driver …')
CC (Noncommercial)
Electronics
Summary
This is the new innovative stepper motor driver for your 3D printer or any task involved stepper motors! It is a new generation as replacement for Pololu/StepStick it is fully compatible with Pololu and StepStick.
Professional design ensure stable operation of this driver - it contain double copper PCB for better heat dissipation.
Using standard A4988 drivers you face the problem of vibration / shaking stepper motors and frame when stepper motors are moving (most noticeable on Z stage). These drivers solves this problem by using an additional 30k trimpot to correctly select the off-time settings. Is it complicated to use? No, you only need to turn second trimpot (OSC) fully counterclokwise and that's all - you can enjoy smoother and quieter stepper motors operation and no more lost motor steps because of non-optimal off-time settings.
Where to get it?
4pcs or 5pcs G3D Drivers fully soldered and assembled and ready to use:
4pcs GADGETS3D.com
5pcs GADGETS3D.com
Fabster3D Ebay
You can also build it by yourself design files you can find at bottom of page.
VREF Calculation Formula
REF = I_TripMax * 8 * 0.1 I_TripMax - Trip current of your motor (A)
Example: 0.4A * 8 * 0.1 = 0.32V
Pictures
Design Files
Files will be available within 24-48h.
Licences
