G3D driver
Revision as of 02:37, 19 October 2012 by Gadgets3d (talk | contribs)
A4988 G3D Stepper Drivers
New generation stepper motor driver
CC (Noncommercial)
Electronics
Summary
This is the new innovative stepper motor driver for your 3D printer or any task involved stepper motors! It is a new generation as replacement for Pololu/StepStick.
Professional design ensure stable operation of this driver - it contain 2oz copper PCB for better heat dissipation and 0.1ohm sense resistors which let it working up to 2A (heatsink and additional air cooling is needed for operating over 1A).
Using standard A4988 drivers you face the problem of vibration / shaking stepper motors and frame when stepper motors are moving (most noticeable on Z stage). These drivers solves this problem by using an additional 30k trimpot to correctly select the off-time settings.
Is it complicated to use?
No, you only need to turn second trimpot (OSC) fully counterclokwise and that's all - you can enjoy smoother and quieter stepper motors operation and no more lost motor steps because of non-optimal off-time settings.
For what we need second trimpot ?
This is just 30k trimpot which turned fully counterclokwise pulling ROSC pin into ground and turning it clockwise let you to choose reference.
Quotet from A4988 datasheet:
"By pulling the ROSC pin to ground (second trimpot turned fully counter clockwise in our driver), mixed decay is set to be active 100% of the time, for both rising and falling currents, and prevents missed steps. If this is not an issue, it is recommended that automatically-selected mixed decay be used, because it will produce reduced ripple currents. Refer to the Fixed Off-Time section for details."
You can check A4988 datasheet for more informations.
Where to get it?
4pcs or 5pcs G3D Drivers fully soldered and assembled and ready to use:
4pcs GADGETS3D.com
5pcs GADGETS3D.com
Fabster3D Ebay
You can also build it by yourself design files you can find at bottom of page.
VREF Calculation Formula
REF = I_TripMax * 8 * 0.1 I_TripMax - Trip current of your motor (A)
Example: 0.4A * 8 * 0.1 = 0.32V
Pictures
Design Files
Schematic
Gerber files
Licences
