GLKLN
Revision as of 15:43, 14 January 2020 by KonstG (talk | contribs) (Full Assembly Instruction)
GLKLN Documentation
GLKLN
GLKLN designed by Konstantin Gulitski.
Introduction
The main idea of this printer is to create a new design of a 3D printer with a cubic cartesian scheme which includes as many as possible parts from plastic. I.e. it supports the RepRap concept to create some kind of easy reproducible 3d printer to make it more achievable for a wide engineer society. One of the main concepts is that all plastic parts designed to be printed by one hotend 3d printer without using supports.
This work is licensed under the Creative Commons Attribution-ShareAlike 4.0 International License. To view a copy of this license, visit [1] or send a letter to Creative Commons, PO Box 1866, Mountain View, CA 94042, USA.
Specifications
Working volume (max) 240mm (X) x 290mm (Y) x 310mm (Z)
Working volume (nominal) 220mm (X) x 220mm (Y) x 210mm (Z)
Working materials PLA, ABS, others
Nominal Speed 120mm/sec
Max Speed 200 mm/s (depending on the object to be printed)
Filament 1.75mm
Configuration XYZ Cartesian drive using stepper motors
Computer interface USB
Layer thickness Adjustable 0.1mm, 0.2mm, 0.3mm, 0.4mm
Material handling Two fixed material deposition extruders
Hotend nozzle size 0.1mm, 0.2mm, 0.3mm, 0.4mm
Positioning accuracy XY 0.1 mm
Motherboard Makerbase MKS Gen L V1.0
Power supply 25A/12V DC, 300W
Firmware Marlin
Host SW Repetier-Host
Exterior dimensions 528 mm wide x 541 mm deep x 433 mm high
Weight about 18 Kg
Cost < $300 (USD)
Main features/improvements
  1. Cubic construction – Strong and Stable
    • The cubic construction is still to be the most strong construction that provides the best quality at the cheaper cost.
  2. Simple construction – The hotbed Z-axes are the part of the construction
    • Four vertical cornels of cubic construction are the Z-axes of the hotbed. It decreases the number of parts and cost.
  3. The Hotbed can be increased – up to 240mm x 290mm
    • The nominal hotbed is 220mm x 220mm. You can upgrade up to 240mm x 290mm.
  4. The Z-axis can be increased – up to 310mm
    • The nominal Z-axis has a 310 mm length. You can upgrade up to 350mm.
  5. The belt connection is simple and confident.
  6. Almost all parts of construction made of plastic.
Development
This is the first version that represents the nominal configuration. Several parts planned to be developed such as a cable holder, filament roller holders, ventilation system for hotends. The development of the GLKLN is hosted on the: GitHub.
Printed Parts
files for the printed parts are available on the: GitHub.
Corner LU – Front Left Upper Corner: 1 pcs
Corner LU B – Back Left Upper Corner: 1 pcs.
Corner RU F – Front Right Upper Corner: 1 pcs.
Corner RU B – Back Right Upper Corner: 1 pcs.
Corner L – Lower Corner: 4 pcs.
Corner B1 – Corners of the hotbed: 4 pcs.
Cross – Hotbed cross 1 pcs.
Wheel holder: The holder for X-axis timing wheels, 2pcs.
Motor Holder 1: The holder for Z-axis motors, 2pcs.
Front panel: The panel for Screen 2004, 1pcs.
Front Train: The front carriage, 1pcs.
Extruder Flap: 1pcs.
Cap MkB: The upper panel over MKB, 1pcs.
Back Train: The back carriage, 1pcs.
Y Train body: The carriage, 1pcs.
End Stop holder: 6pcs if you want to use two end-stop switches for each axis.
Timing belt holder: The holder required for fixing the timing belt end. 6pcs.
Side panel: The panel for all four sides of the printer, 4pcs.
Side panel lead: The connector between the side panel and the profiles of upper and lower frames. 14pcs.
The side panel assembly
Side panel lead L: The connector between the backside panel and the upper frame profile at left. 1pcs.
Side panel lead R: The connector between the backside panel and the upper frame profile at right. 1pcs
The back side panel assembly. 1pcs
Power Supply Holder: The holder for power supply cable connector with fuse, 1pcs.
Power Supply Holder Cap: The cap of the holder for power supply cable connector with fuse, 1pcs.
Extruder Holder: 1pcs.
Bill of Materials (BOM)
The updated version of the BOM can be downloaded from the project repository on the: GitHub
Electrcal parts
Stepper Motors
The GLKLN printer uses 6 stepper motors:
  • 42BYGH40 motor - 2pcs, for X and Y axes.
  • 42BYGH48 motor - 2pcs, for two extruders.
  • 42BYGH34 motor - 2pcs, for Z-axis which is synchronized by connection to one Z-axis driver through Dual Z Stepper Motor Adapter.
A4988 Stepper Motor Driver With Heat sink is used for all motors. Each one configured for 1/16 subdividing step.
Controller Electronics
The nominal model of the GLKLN printer is based on the MKS-GEN L V1.0 motherboard. However, it can be used any other motherboard which supports the 6 motors and two extruders. The 2004 LCD Display RepRapDiscount Smart Controller is used for autonomy printer control.
Extruder
V6 Dual Nozzle 2 In 2 Out Double Head with 3010 Fun.
Heated Bed
HotBed is Aluminium 220mm x 220mm x 3mm.
Filament Holder
The Filament holder under development and shall be added in the future. Currently, the filament can be put close to the feeders.
The updated version of the Full Assembly Instruction can be downloaded from the project repository on the: GitHub
Videos
https://www.youtube.com/watch?v=GEYLdS9rxzs
https://www.youtube.com/watch?v=eaGODYXviRs
