GT2 Timing Belt
Revision as of 15:54, 20 February 2015 by Hexacube (talk | contribs) (Belts)
This page has been flagged as containing duplicate material that Belts_and_Pulleys also attempts to cover.
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
GT2 timing belt
Vitamin
Timing belt.
Wikipedia Toothed belt
GT2 timing belts and compatible pulleys are popular choices for RepRaps and RepStraps -- see Choosing Belts and Pulleys for alternatives.
The GT2 timing belt is a possible replacement for T2.5 and T5 timing belts that some believe may cause backlash. The GT2 series of belts are designed specifically for linear motion. They use a rounded tooth profile, with 2mm pitch, that guarantees that the belt tooth fits smoothly and accurately in the pulley groove, so when you reverse the pulley direction, there is no room for the belt to move in the groove.
Vendors
Belts
See Belts and Pulleys.
Pulleys
