GUS Simpson bill of materials
Printed Parts
Quantity | Part Name | Comment | Photo | 3 |
Shoulder |
This part is the bottom of GUS's arms, also used as extruder mount and for holding base plates together |
3 |
Motor arm |
This part is the hardest one to print, and it serves as motor holder as well as the manipulator part |
3 |
Slave arm |
This part is used as a third part of manipulator, and connects to the Hub. |
3 |
Pulley |
It is better to make steel pulley if you can |
1 |
Hub bottom |
The bottom of the hub with hotend mount, partially compatible with Kossel |
1 |
Hub center |
The center of the hub |
1 |
Hub top |
The top of the hub |
1 |
Hub washer |
Washer to be inserted between hub center and hub top |
1 |
Hub screw |
Structural element for the hub - it holds the hub together. Also it has a nut slot for a bowden tube |
1 |
Lock nut |
A nut to hold the hub together |
1 |
Bowden nut |
A nut to hold the filament bowden tube's nut on the hub screw |
3 |
Eccentric stop |
Plastic endstop pusher |
3 |
Plastic washer |
A washers for the shoulder holding screws on plates - makes the whole thing more pretty |
Waterjet parts
Quantity | Part Name | Comment | Photo | 1 |
Bottom plate |
Bottom plate of the GUS |
100px | 1 |
Top plate |
Top plate of the GUS, have a space for the heater |
100px |
Vitamins
Quantity | Part Name | Comment | 1 |
Teflon (PTFE) bowden tube |
4mm OD x 2mm ID x 24 inches |
19 |
608 Bearing |
Better to be rubber-sealed |
12 |
M8 washer |
3 |
M8x100 Hex bolt |
3 |
Tuting peg |
A tuning peg for guitar |
3 |
M3x16 bolt |
9 |
M2x16 bolt |
12 |
M8x60 Hex bolt |
MUST be partially-threaded, DIN931 |
6 |
M8x55 Hex bolt |
12 |
M3x6 bolt |
6 |
M3x8 bolt |
6 |
M3x20 bolt |
2 |
M3x25 bolt |
2 |
M3x30 bolt |
2 |
M3x35 bolt |
4 |
6702 bearing |
2 |
M4 full nut |
1 |
MK drive gear |
3 |
Stretch spring |
33 |
M8 Nylock stop nut |
11 |
M3 Nylock stop nut |
1 |
String |
80lb+ tested braided fishing line |
Electronics
Quantity | Part Name | Comment | 4 |
Nema 17 stepper |
4.5kg*cm |
3 |
Micro limit switch |
611-ZMA00A080L04PC or similar |
1 |
3D printer controller |
Could be RAMPS 1.4 |
1 |
Power supply |
24v recommended if the controller supports it |
1 |
Round heated bed |
Circular 24V silicone rubber heater bed 200mm diameter (8") |
1 |
Hot end |
anUBIS recommended |
