Glue
Revision as of 18:14, 30 July 2018 by Jobo (talk | contribs)
Gluing plastics
rogerw tried glues for PLA
ABS glue 'can be found at the aisle with the ABS pipe'. (bit vague advice that) I also heard about glueing by dissolving ABS in aceton and putting it between the parts to be glued, the idea is that the aceton disolves some more and then evaporates binding the ABS together.(Not sure if that works)
Glue gun
The glue gun as an extruder for Glue
