HELLOPRINTER
Revision as of 01:44, 9 February 2015 by DavidCary (talk | contribs) (add "development" template)
HELLOPRINTER
Open Source Multi-Maker (3D printer, CNC, Laser cutter/engraver)
GPL
Based on the work of josef prusa, model prusa I3 link: github /josefprusa/Prusa3
Base model characteristics:
Build Size: 200mm x 200mm x 200mm max 500mm x 500mm x 500mm
Extruders: up to 3
Resolution: Base nozzle has 3 diferent resolutions 0,2 , 0,3 and 0,5, if you choose the chess extruder you can go as high as 1.5mm, ideal for the bigger versions.
Z Resolution: Best achieved with a normal calbration 0,1mm , when well calibrated you can reach resolutions of 0,01mm
Materials: ABS, ABS-PC,ABS-Carborn, Glow In The Dark ABS and PLA, PLA, HIPS, Laywoo, Claywoo,BronzeFill, CopperFill, Nylon, PVA and others
Speed: Up to 100mm/s (tested with 2000mm/s set up and worked) Prepared for touchless automatic bed levelling
Monkey Extruder Compatible - Super lightweight Dual extruder ( motors with half the weight of a nema 17 max extruders set by the electronics) with the capability of separating both nozzles up to half the bed lenght, making possible the print of 2 objects in diferent materials or colors at the same time saving 50% of the building time for not having to do the same path twice.
Stainless Steel Structure - Needed for having enough weight to withstand the CNC function
Endstops: Hall
LCD: With controls and SD card Reader for autonomous printing
Heated bed: Yes
PSU: 12v 30A
Software recomended Kisslicer or Slic3r and pronterface
GITHUB LINK WITH BUILD MANUAL:
Monkey Build Manual and english versions very soon!!!!!
