HICTOP Prusa i3
Release status: Working
Description | Prusa i3 Mendel variation
License | BSD
Author | |
Contributors | |
Based-on | |
Categories | Prusa i3, Prusa i3 Development, Prusa Mendel Development, Prusa Mendel, Mendel Variations, Cartesian-XZ-head
CAD Models | on Thingiverse
External Link |
This page is mainly for HICTOP Prusa i3 configuration and troubleshooting For more variants, guides, and information, please visit the Prusa i3 page. |
This page is still under development If you would like to add more information to it, please edit appropriately. |
About the Models
The HICTOP Prusa i3 is a Prusa i3 variant by HIC Technology, a Chinese 3D printer fabrication company. There are two variants from HICTOP, the Acrylic High Accuracy Aurora and the Aluminum Frame, with the only difference being the frame material and a slightly taller printing area for the former. They both come in fully assembled and encased or complete DIY kits. The acrylic version will be used for reference and specifications.
Specifications
- Structure: Acrylic (or Aluminum)
- Extruder quantity: 1
- Board: Arduino Mega 2560 with Ramps 1.4
- Printing size: 270*200*170(190)mm
- Layer sickness: 0.1-0.4mm
- LCD screen: RepRapDiscount Smart Controller
- Printing speed: max 120mm/s | recommended 40mm/s
- Standard extruder diameter: 0.4mm
- Extruder temperature: 250
- Hot bed temperature: 110*
- Hot bed parts material: Acrylic, aluminum, PCB
- XY axis positioning accuracy: 0.011mm
- Z axis positioning accuracy: 0.004mm
- Printing material support: ABS, PLA
- Printing material diameter: 1.75mm
- Software language: English
- Date import format: STL, G-Code
- Device dimension: 430*505*380mm
- Device weight: 8kg
- Packing dimension: 470*470*330mm
- Packing weight: 11KG
- Power supply: 12V
- Working condition Temp: 10-30 degree, Humidity:20-50%
*spec states 110 degrees C is possible, but realistic temperature is around 80-90 degrees max without enclosure.
Known Issues
HICTOP ships preconfigured firmware with the printer. The firmware marks the z-step for 394 steps/mm when it should be 2560 steps/mm. The downloads section has the fixed aftermarket firmware.
IF YOUR PRINTER WORKS FINE DO NOT INSTALL THIS FIRMWARE.
The installation CD is available for sharing upon request If allowed, the contents will be made available publicly through either the wiki or another filehosting site. |
