HIPS
Revision as of 06:58, 27 February 2015 by Traumflug (talk | contribs) (Reduce advertising.)
High Impact Polystyrene (HIPS) is a great support material for ABS parts as it is very similar to ABS in its properties (read more at Wikipedia), but works with different solvents (Limonene for HIPS vs acetone for ABS). Experiments are ongoing for HIPS as a support material due to Limonene not affecting ABS, and a similar cost (vs double for PVA). HIPS can be easily torn from the ABS leaving an even finish behind. Also, HIPS is soluble in chemical called Limonen, which doesn't affect ABS.
Known vendors
GizmoDorks 123inkt.nl 3Dfilamenta SainSmart 3ddirect ReprapWorld
MatterHackers 3DPartistry 3D Inkspot 3D-Prima 3D2PRINT Filament & meer
LulzBot Cubic-Print Thingibox ToyBuilder Labs meXhibit Subassembly India
Links
