HackerBot
Revision as of 09:24, 4 February 2016 by Balestrino (talk | contribs)
HackerBot Documentation
HackerBot
CC-SA-BY
Introduction
PLEASE CHECK THE HACKERBOT OFFICIAL GIT REPOSITORY FOR THE LATEST UPDATE AT https://github.com/OSHW/HackerBot/
Current version of the HackerBot is 2.2 (26/Jan/2016): https://github.com/OSHW/HackerBot/releases
Official support forum: http://forum.oshw.it/index.php
Autodesk Fusion 360: http://a360.co/1mfSjol
The HackerBot is an open source 3D Printer under CC-SA-BY license.
Hackerbot 3D printer is based on Ultimaker XY core design
It was build using CNC aluminium parts, quality chromed shafts and bushings, a reliable extruder and E3D hotends for ultimate performance. Enclosure is made in 5mm Polycarbonate and PMMA
Hackerbot has been build to last a lifetime.
We also added a Raspberry Pi for WiFi and Ethernet connection (Octoprint) and as optional big stepper motor drivers for smooth, quiet and reliable motion.
We designed it observing, when it was possible, the standards used in RepRap community so you will find easy to change some parts with others (ex. hotends, extruders, etc.)
Current version of the HackerBot is 2.2 (26-Jan-2016)
Main Features
  • Print area: 300x200x200mm
  • Modular aluminum Head. Dual extruder with second extruder interchangeable.
  • High quality aluminium frame and parts. Lasts a lifetime.
  • Ease of use: Wifi (Octoprint) and/or big LCD display & SD Card
  • know printable materials: ABS, PLA, HIPS, Nylon, Polycarbonate
  • Optional: Big stepper drivers for trouble free operation
  • width: 510mm
  • height: 650mm
  • depth: 510mm
  • weight: about 25kg
