HackerBot BOM
Revision as of 09:54, 2 January 2014 by Balestrino (talk | contribs) (Created page with "{| {{table}} border=1 |+ '''Structure''' | width="50" align="center" style="background:#f0f0f0;"|'''qty''' | width="350" align="center" style="background:#f0f0f0;"|'''part nam...")
qty | part name | description/notes |
13 | Aluminum profile 30x30 450mm | |
4 | Aluminum profile 30x30 600mm | |
26 | Internal bracket (Bosch 3842535577) | back plate may support upper backside profile, so four less brackets |
10 | Plexy support |
2 | Stepper motor Nema17 | 1.7A or 2.5A, shaft 5mm |
1 | Front right support plate | |
1 | Front left support plate | |
1 | Back right support plate | |
1 | Back Left support plate | |
20 | Collar nut (Bosch 3842523925) | fixes the support plate with alu profiles |
20 | T-Bolts (Bosch 3842523920) | fixes the support plate with alu profiles |
32 | M3x16 screw set | fixes the bearing supports with support plates |
8 | 608 Bearings | |
8 | Bearing housing | 3D printed |
8 | PTFE shim | or POM / Delrin |
8 | GT2 20 teeth pulley with 8mm bore | |
2 | GT2 20 teeth pulley with 5mm bore | |
4 | Cubic slider | |
8 | Cubic slider belt clamp | 3D printed |
8 | M3x15mm | for cubic slider |
4 | Cubic slider PTFE bushing | |
2 | Shaft 8mm length 465mm | |
2 | Shaft 8mm length 438mm | |
2 | Shaft 8mm length 370mm | Head shaft support |
1 | Head v2 | assembled (4x LM8UU, Pneufit) |
4 | GT2 open belt length 830mm | XY core belts |
1 | GT2 closed belt 72 teeth | stepper motor belt |
1 | GT2 closed belt 62 teeth | stepper motor belt |
1 | Belt Tightener | with screws and 624zz bearing |
1 | Belt Tightener short | with screws and 624zz bearing |
1 | X endstop holder | 3D printed |
1 | Y endstop holder | 3D printed |
2 | microswitch / endstop |
1 | Z Stepper plate | |
1 | Z Stepper motor | nema 17 1.7A |
1 | Z Stepper motor screw kit | 4x M4x20 screws, 4x washer |
4 | SK10 Shaft support | 10mm shaft |
10 | Collar nut (Bosch 3842523925) | used for stepper plate and SK10 |
10 | T-Bolts (Bosch 3842523920) | used for stepper plate and SK10 |
1 | Motor-Trapezoidal screw coupler | |
1 | Trapezoidal screw 12x3 length 410mm | |
2 | Z shaft 10mm length 390mm | |
2 | LM10LUU | 10mm linear bearing with housing |
1 | LM10LUU screw kit | 8x M5x20 screw, 8x M5 washer |
1 | Print area support L-shaped | |
1 | Trapezoidal nut | |
1 | Aluminium heatbed support | |
4 | Springs | |
1 | Z endstop holder | |
1 | Z endstop tuning | |
1 | Z endstop knob | |
1 | Z endstop spring | |
1 | Collar nut (Bosch 3842523925) | used for Z endstop holder |
1 | T-Bolts (Bosch 3842523920) | used for Z endstop holder |
1 | M4 threaded rod length 60mm | |
1 | Mechanical Z endstop |
1 | Door Plexy | |
2 | Aluminum profile 20x20 length 408mm | |
2 | Aluminum profile 20x20 length 384mm | |
4 | Cubic joint 20x20 2 way | Bosch 3842524484 |
2 | Hinge | Bosch 3842544526 |
1 | Handle | ? |
1 | LCD screen | XXL screen from RRD |
1 | Power Supply | 24V Switching power supply 350W |
1 | Power Inlet | Bulgin BVA01/Z0000/11 (RS 352-1825) |
1 | RUMBA electronics | |
1 | RAMPS electronics | |
1 | microswitch | |
1 | Silicon cable | RS code? |
1 | LIYY cabling | RS (4918983) Unitronic LIYY 4X0,25mmq |
1 | LIYY cabling | RS (4451395) Unitronic LIYY 2X0.14mmq |
