HackerBot Build Manual
Revision as of 06:57, 11 October 2013 by Balestrino (talk | contribs) (Created page with "{{RepRapNavigation|name=HackerBot}} =Before You Begin= Before assembling a HackerBot, make sure you have all the parts necessary. For the bill of materials, see HackerBot...")
HackerBot Documentation
Before You Begin
Before assembling a HackerBot, make sure you have all the parts necessary. For the bill of materials, see HackerBot BOM.
Assembly Instructions
Aluminum Frame
code qty part name description est.price
1 13 strut profile 350mm Aluminum Bosch profile 30x30mm, length 350mm € 40,00
2 4 strut profile 500 mm Aluminum Bosch profile 30x30mm, length 500mm € 16,00
3 24 internal bracket Bosch internal bracket 30x30 (3842.535.577) € 80,00
XY System
5 1 L_50x50_L front-sx XY support plate € 20
13 1 L_50x50_R front-dx XY support plate € 20
16 1 L_plate 50x50 more_bore_L back-sx XY support plate € 20
17 1 L_50x50 more_bore_R back-dx XY support plate € 20
11 8 Radial ball Bearing 628 bearings for XY shafts € 16
20 2 shaft x-y XY Shaft 8mm, lenght 350mm ? € 5,15
21 2 short shaft x-y XY Shaft (short) 8mm, lenght: 345mm ? € 5,15
31 2 extruder axis Head support shaft 8mm, lenght: 330mm ? € 4,97
32 1 extruder support v2 Head (3d printed ABS) € 10
33 6 linear bearing Linear Bearings 8mm € 12
22 8 Teflon Thickness PTFE shims for XY shafts € 16
23 10 timing_belt_Pulley GT2 pulley (8mm bore) € 70
25 2 geared_pulley_Stepper. GT2 pulley (5mm bore) € 12
26 4 cubic slider XY Cube support € 40
27 4 Cubic slider teflon Bush XY Cube PTFE bushings € 20
28 8 belt clamp XY Cube belt stops € 16
57 2 belt tightener small bearing 608 bearings for tightner € 4
58 2 belt tightener tightner € 4
59 4 belt xy axis XY GT2 belt. 640mm lenght € 25,6
60 1 stepper short belt 2 GT2 72? teeth pulley € 8
61 1 stepper short belt 1 GT2 62? teeth pulley € 8
62 2 main_stepper Stepper asse x-y € 30
63 8 Screw M3 x 12 --- 12N M3 screw. lenght 12 mm (XY plate) € 0
65 8 Screw M3 x 30 --- 18N M3 screw. lenght 30 mm € 0
Z System
38 2 z-axis Z axis shaft 8mm, lenght 230mm ? € 4,07
39 1 z-stepper plate Z support plate € 5
40 1 coupling Z stepper joint € 4
41 1 shaft adaptor Z axis adapter (motor-screw) € 7
42 1 trapezoidal thread trapezoidal screw (12x3) lenght: 250mm € 3,5
43 1 L_plate piano di stampa L aluminum plate support € 5
44 1 flangia filettata trapezoidal screw chiocciola TPN12 € 18
45 4 Screw M3 x 20 --- 20N M3 screw for chiocciola € 0
46 1 Lastra alluminio base 245x225x4 base plate € 30
47 2 linear bearing support Supports for Z bearings € 10
36 4 linear shaft support shaft supports small adapter € 8
52 1 heatbed 12/24V HeatBed € 25
53 4 spring springs for heatbed € 4
64 4 spacer bar Z stepper spacer € 8
Extruder
34 2 JHead extruder with nozzle JHead complete with nozzle € 100
90 2 Wade's extruder Wade extruder complete € 40
62 2 stepper motor Extruder stepper motor € 30
Front Door
79 2 Prof struc 310 20X20 6 mm Barra di alluminio 20X20 lunghezza 310 mm per lo sportello € 2,48
80 2 Prof struc 320 20x20 6 mm Barra di alluminio 20X20 lunghezza 320 mm per lo sportello € 2,56
81 2 Cerniere Bosch Cerniere sportello anteriore ( incluse viti) € 24
82 4 Cubic joint Bosch Connettori cubici per lo sportello anteriore( incluse le viti) € 12
83 1 vetro pannello € 10
84 68 Screw M3 x 10 ---10N Viti di lunghezza M3 di lunghezza 10 mm € 0
Electronics
87 3 micro switch endstop € 6
88 2 micro switch support 3d printed supports for endstops € 0
89 1 Lcd screen+ case LCD screen 40x4 with case € 50
78 1 ArduinoMega Arduino mega 2560 € 30
91 1 Elettronica da aggiungere RAMPS 1.4 € 45
69 1 ventola 60x60 fan € 8
70 1 cappa ventola stampata 3d printed fan guard € 2
73 1 Plug IEC with Switch with Fuse Interrutore posteriore € 12
76 1 MW_switching_25A Alimentatore stampante da 25 A € 30
77 4 Screw M3 x 5 --- 5N Viti M3 per bloccare l'alimentatore alla stampante € 0
1 cabling € 30
Other Parts Required
