HackerBot Z system
Revision as of 04:28, 15 May 2016 by Balestrino (talk | contribs) (Z Endstop adjustment)
HackerBot Documentation
Z System assembly
Z System assembly
qty part name description/notes
1 Print area support L-shaped File:Print area support-L-shaped plate.PDF
2 SC12LUU 12mm linear bearing with housing
2 12mm Shafts length: 350mm
8 M5x20 socket cap hex screw with washers
1 Z mechanical endstop position it with nylon spacers and n.2 M3x5 button hex head screw
1 Trapezoidal screw 12x2 (MTSBRA12-330-S10-Q8) or 12x3
1 Trapezoidal nut 12x2 (MTSFR12) or 12x3
4 M4x20 hex screw and nut Trapezoidal nut screws
4 SK12-kit Shaft supports with M5x12 screws and HNTF6-5 t-nut
Z stepper motor assembly
Z motor
1 Z Stepper motor support plate
2 M6x12 socket head screw
2 M6 post assembly nut Misumi HNTF6-6 or Bosch 3842501753
1 Z Stepper motor nema 17 1.7A
4 M3x10 hex screws + washer motor screws
1 Motor-Trapezoidal coupler flexible coupling 5 mm and 8 mm diameter
Take the stepper motor for the z-axis and join the motor shaft toward top to stepper plate with the screws and washers (stepper motor kit of this section checklist).
On the other side of the stepper plate, add the flexible coupling to the motor shaft (5mm of diameter).
HackerBot step 27
Print plate (Heatbed)
Print Plate (Heatbed)
1 Aluminium BED support File:Aluminium heatbed support.dwg
5 M5x20 + washer + nut
HackerBot step 29
1 Z endstop tuning support File:Z Endstop tuning.pdf
1 Z endstop knob
1 Z endstop spring
1 M3 threaded rod length 65mm Only bowden type head
1 M3 threaded rod length 80mm Only direct type head with Vulcano E3D hotend
1 M5 Socket head screw M5x16
1 HNTF6-5 T-nut
Assemble Z endstop knob, M4 threaded rod with a grub screw (or use Loctite 243)
HackerBot step 30.1
** Z COMPLETE **
** GO TO: HackerBot door **
