HackerBot electronics
Revision as of 12:24, 19 April 2016 by Balestrino (talk | contribs) (Motor cabling)
HackerBot Documentation
Electronics diagram
Power supply
** PLEASE TAKE CARE! RISK OF INJURY, ELECTRIC SHOCK OR FIRE **
PSU Wiring
qty part name description/notes
1 Power cable L. 25cm, 3 x 1mm power cable
1 Power cable 2° PSU L. 20cm, 3 x 1mm power cable
1 Power cable L. 10cm, 2 x 1mm power cable
1 Earth cable L. 30cm, 1.5mm cable
6 Female fast-on connector fully insulated type (ex: RS 624-1178)
1 Female fast-on connector for earth cable not insulated type (ex: RS 624-1178)
HackerBot Power supply wiring
Power supply Inlet
1 Back panel PMMA 449x79x5mm
2 M3x15 countersunk screws, 2x M3 nyloc nuts, 2x M3 washer
1 Power inlet Bulgin BVA01/Z0000/11 with Light (RS: 352-1825)
OR Power inlet Bulgin BVA01/Z0000/10 w/o Light (RS: 352-1819)
1 Power inlet fuse 230V use a 2A fuse (20mm type) - 110V use a 4A fuse.
Bulgin Inlet connector datasheet: [1]
Assemble back panel with Bulgin inlet:
HackerBot Power supply inlet
** 110V / 230V is lethal. Please do not do wirings if you are not a tech and are you very sure what are you doing. **
CHECK OUT the numbers/letters on the inlet backpanel. Dual pole switch are on A-A, and B-B. So same cable color on same letter.
HackerBot Inlet connections
cable all together:
Bulgin inlet is VERY DANGEROUS because one power joint is not isolated! PLEASE USE HOT GLUE TO INSULATE ALL THE INLET BACK
HackerBot inlet insulation
DO EARTH CONNECTION TO CHASSIS, THIS IS MANDATORY. EVERY METAL PARTS MUST BE EARTHED!
YOU MUST PLACE A VERY DEATH DANGER ADHESIVE!
HackerBot voltage danger
Controller
  • n.1 RUMBA Controller board
  • n.4 DRV8825 Stepper motor Driver
  • n.4 M3x6 socket head scews (for pcb)
  • n.1 RUMBA BOX
  • n.4 M3x8 countersink socket head screws (rumba box cover)
  • n.4 M3x12 socket head screw
  • n.4 M3 nuts + washer
  • n.1 FAN 60x60x10
  • n.4 M3x25 socket head screw + nuts + washer (fan screws)
RUMBA
HackerBot RUMBA
Motor cabling
Motor cabling
2 X motor cable 4x0.25 mm2 , length: 85cm (RS: 491-8983)
2 Y motor cable 4x0.25 mm2 , length: 1,3m (RS: 491-8983)
1 Z motor cable 4x0.25 mm2 , length: 50cm (RS: 491-8983)
2 GX16-4 Panel connectors 4 pins
* Shrink tube
Stepper motor wiring scheme:
MOTOR CablePANEL CONNECTORCABLE (LiYY 4x0.25)Phase
REDpin 1 Yellow1A
BLUpin 2White1B
GREENpin 3Green2A
BLACKpin 4Brown2B
Wire the X Y and Z motor:
HackerBot motor cabling
Extruder cable
HotEnd cable
2 silicon cable 0.5 mm2 length: 1m (red & black)
1 2x0.14 mm2 LiYY cable length: 80cm
1 GX16-4 Panel connector 4 pins
* Shrink tube
NOTICE: ONE EXTRUDER PROCEDURE. (repeat x times if you need multiple extruders,expect the fan cable, you need one ofan cable also with multiple extruders)
Wiring scheme:
PANEL CONNECTORCABLEnote
1 «SILICON REDExtruder power +
2 «SILICON BLACKExtruder power ground
3 «LiYY BROWNNTC
4 «LiYY WHITENTC
HackerBot Hotend cable
Extruder motor cable
1 4x0.25 mm2 LiYY cable length: 75cm
* Shrink tube
HackerBot cabling
Fan Cabling
Fan cabling
1 2x0.14 mm2 LiYY cable length: 105cm
1 GX12-2 Panel connector 2 pins
* Shrink tube
This is the fan that cools the uppper layer of the printed part.
Hotend Fan Cabling
Hotend Fan cabling
1 2x0.14 mm2 LiYY cable length: 105cm ?
1 GX16-5 Panel connector  ?
* Shrink tube
Hotend Fan is needed to cool the hotend (E3D). Connector is GX16-5 (AUX, see photo below)
Panel connectors
Panel connector layout:
HackerBot motor panel connector
Endstop
Endstop
1 X end stop holder File:X Endstop holder.stl
2 X end stop holder screw M3x10 + washer + nut
1 Y end stop holder File:Y Endstop holder.stl
1 Y end stop holder screw M3x10 + washer + nut
2 X/Y end stop mechanical endstop with lever
2 M5x12 Socket head screw
2 M5 post assembly nut
2 3x0.15 LiYY cable
2 3x1 dupont connector
HackerBot X Endstop
  • INSERT IMAGE OF ENDSTOP POSITION (endstops are in back-left position)
LCD Controller
LCD Controller
1 RepRapDiscount XXL LCD
1 XXL LCD case File:Bottom Case XXL.stl
1 XXL LCD case cover File:Top Case XXL.stl
1 XXL LCD knob File:Controller knob 2.stl
1 XXL LCD kill button File:Kill Button XXL.stl
4 KA20x15 screws for plastic
2 Velcro strips 50x20 mm
HackerBot XXL LCD
HackerBot XXL LCD Case
Power supply unit cabling
Power supply
1 Switching power supply DC 12v - 30A
2 M4x6 hex screw + washers
0.7m Red+Black 1mm2 silicon cable (PSU to controller main power)
0.7m Red+Black 1mm2 silicon cable (PSU to controller heatbed power)
PSU
** ELECTRONICS COMPLETE **
** GO TO >> HackerBot extruder **
