HackerBot print area
Revision as of 10:36, 23 May 2016 by Balestrino (talk | contribs) (Assembling Print area)
HackerBot Documentation
Print area 300x300
qty part name description/notes
1 Print bed PCB 300x300 heatbed
1 Heatbed Aluminum 300x300 12V/24V
4 Heatbed springs 25mm length compression spring (1.2mm wire)
4 M3x35 socket head cap screw use a washer to avoid scratching the heatbed
1 Cable holder support
2 M3x14 socket head cap screw cable holder support screws
4 Back binder clip
First assemble and check: MK Heatbed wiring
** Print area COMPLETE **
** GO TO >> HackerBot base **
