Harvey
Release status: Design
Description | design of Harvey
License | unknown
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | KiCAD
External Link |
Harvey is yet another reprap electronics / reprap controller Board. It is built around a STM32F102 Cortex M3 and uses Sanyo LV8549M Stepper Drivers, everything on one small PCB.
Beware, this has not yet been assembled and tested. If anyone wants to check the design, please do so. In #reprap I'm gnurbs, jabber mesages go to [email protected] |
Design
This Board was designed by ari, with his personal design conceptions: SMD-Parts where available, single sided, very compact single PCB. In fact it is so small, it will need a Heat spreader for the stepper driver. Ari finds SMD-parts more convenient, especially if one produces the pcb oneself - less drilling.
Logic power (+3.3V) is supplied by USB, Power (VDD) by a 5.5/2.5 mm Jack. 8-16V are allowed, the actual voltage is measured by the µC
Definitions
symbol | definition |
Pex | expansion Header |
Pprog | programming header |
Logic
This Board features an STM32F102 microcontroller. relevant for this Board:
- 48 MHz Cortex M3 core
- builtin USB
- 2 Timers with 4 PWM channels each
- 12-bit ADC
programming header
Pprog is the programming header. You can flash the µC over USART1 when BOOT0 is asserted during reset. These plus USART1s clock are on the header
expansion header
This header is intended for future extension. It has all the unsused pins of the
Power
Stepper Drivers are Sanyo LV8549M which are pretty dumb but require no external parts. They are not much more than two H-bridges that are controlled by two pins setting the pase and one enable. They cannot do microstepping on their own, but doing this by hand should be possible. They have an enable-pin that is said to accept PWM for current setting, but the datasheet gives no details. They are wired to PWM-channels of the µC anyway.
The Board has two
ToDo
- check if all pins on the expansion Header are 5V-tolerant.
- connect Boot0 to Pex:11
- put a cap between nRST and GND
