Heated bed assembly
Revision as of 06:21, 20 December 2013 by Frankiebee (talk | contribs) (Thermistor assembly)
Thermistor assembly
After soldering the ends, it's easy to get confused about which way to insert these into the male crimp terminal. The way that was found to get the terminals into the housing was to rotate them 90-degrees to the most natural appearing way The U-shaped channel needs facing towards the keyed notch shown at the bottom of the image. Ormerod base temp sensor conn.jpg
