Herringbone Extruder Driver
Revision as of 14:41, 18 November 2010 by RhysJones (talk | contribs)
Release status: Experimental
Geared Nema 17 Extruder
GPL
I've always liked different aspects of Wade's and Adrian's Extruders. Specifically, I like Adrian’s general layout, his extruder clamping system, and the use of gears with a prime number of teeth to even out the wear. Similarly, I really like Wade's hobbed bolt solution.
This is an attempt to combine the best of the two. In addition, I've also jumped on the trend to have herringbone gears to reduce backlash and for quiet running (Although your 3D printer will need to be running well to print them I suspect). Further, the hole for the grub screw of the captive nut on the small gear is at the root of one of the teeth in this design. I've printed it fine on our Stratasys, but I haven’t had the chance to RepRap it yet and suspect that the way I've done the grub hole might be a little intricate. The gears have the same pitch as Adrian's, so they should print fine anyway. I'd appreciate feed back or better yet if someone wants to improve it feel free.... Instructions
Manufacture of the bolt is the same as Wades, but you'll need an M8x70 instead. Also, on my pictures you'll notice the layout of the bolt goes - Gear, 2X Washers, Spacer, Washer, Bearing, Washer, Gap, Washer, Bearing, Washer, 2X m8 Nuts.
You should really put 3 washers at the beginning instead of 2, (I screwed up the hobbing of the bolt). Equally, the final two nuts do not need to be done up tightly, doing so would mean the bearings become a little rough. The herringbone gears should keep everything aligned by themselves and the bolt takes all the torque, so the nuts only need to be lightly tightened...
