Hot end assembly
Revision as of 20:56, 27 December 2014 by Glenn (talk | contribs) (+ Category:Ormerod)
The airflow system
Supplied fan is very noisy, users in the forum made supports to accomodate a bigger and quieter fan.
Recipe lists that the Heat Sink and the Aluminium cooling block are part of the hardware kit. These are actually part of the Hot End Set. Later on in the instructions page there are more references to hot end set parts as being part of the hardware set
The stacking height of the fan, heatsink duct, fan duct and the heatsink adds to 40mm, which leaves the 40mm screws too short to connect these parts.
A workaround that was employed was to file away part of the fan body such that a few extra thread turns were exposed to the aluminium cooling block
